[U-Boot] [PATCH 1/2] fsl-ddr: add the override for write leveling
add the override for write leveling sampling and start time according to specific board.
Signed-off-by: Dave Liu daveliu@freescale.com --- cpu/mpc8xxx/ddr/ctrl_regs.c | 20 ++++++++++++++------ cpu/mpc8xxx/ddr/options.c | 1 + include/asm-ppc/fsl_ddr_sdram.h | 5 +++++ 3 files changed, 20 insertions(+), 6 deletions(-)
diff --git a/cpu/mpc8xxx/ddr/ctrl_regs.c b/cpu/mpc8xxx/ddr/ctrl_regs.c index 2736006..5f0c611 100644 --- a/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -1004,8 +1004,8 @@ static void set_ddr_zq_cntl(fsl_ddr_cfg_regs_t *ddr, unsigned int zq_en) }
/* DDR Write Leveling Control (DDR_WRLVL_CNTL) */ -static void set_ddr_wrlvl_cntl(fsl_ddr_cfg_regs_t *ddr, - unsigned int wrlvl_en) +static void set_ddr_wrlvl_cntl(fsl_ddr_cfg_regs_t *ddr, unsigned int wrlvl_en, + const memctl_options_t *popts) { /* * First DQS pulse rising edge after margining mode @@ -1032,8 +1032,9 @@ static void set_ddr_wrlvl_cntl(fsl_ddr_cfg_regs_t *ddr, /* tWL_DQSEN min = 25 nCK, we set it 32 */ wrlvl_dqsen = 0x5; /* - * Write leveling sample time at least need 14 clocks - * due to tWLO = 9, we set it 15 clocks + * Write leveling sample time at least need 6 clocks + * higher than tWLO to allow enough time for progagation + * delay and sampling the prime data bits. */ wrlvl_smpl = 0xf; /* @@ -1046,9 +1047,16 @@ static void set_ddr_wrlvl_cntl(fsl_ddr_cfg_regs_t *ddr, * Write leveling start time * The value use for the DQS_ADJUST for the first sample * when write leveling is enabled. - * we set it 1 clock delay */ wrlvl_start = 0x8; + /* + * Override the write leveling sample and start time + * according to specific board + */ + if (popts->wrlvl_override) { + wrlvl_smpl = popts->wrlvl_sample; + wrlvl_start = popts->wrlvl_start; + } }
ddr->ddr_wrlvl_cntl = (0 @@ -1334,7 +1342,7 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, set_timing_cfg_5(ddr);
set_ddr_zq_cntl(ddr, zq_en); - set_ddr_wrlvl_cntl(ddr, wrlvl_en); + set_ddr_wrlvl_cntl(ddr, wrlvl_en, popts);
set_ddr_sr_cntr(ddr, sr_it);
diff --git a/cpu/mpc8xxx/ddr/options.c b/cpu/mpc8xxx/ddr/options.c index 26ac480..32ff12b 100644 --- a/cpu/mpc8xxx/ddr/options.c +++ b/cpu/mpc8xxx/ddr/options.c @@ -198,6 +198,7 @@ unsigned int populate_memctl_options(int all_DIMMs_registered, * meet the tQDSS under different loading. */ popts->wrlvl_en = 1; + popts->wrlvl_override = 0; #endif
/* diff --git a/include/asm-ppc/fsl_ddr_sdram.h b/include/asm-ppc/fsl_ddr_sdram.h index 69b857b..d978d70 100644 --- a/include/asm-ppc/fsl_ddr_sdram.h +++ b/include/asm-ppc/fsl_ddr_sdram.h @@ -177,6 +177,11 @@ typedef struct memctl_options_s { unsigned int clk_adjust; /* */ unsigned int cpo_override; unsigned int write_data_delay; /* DQS adjust */ + + unsigned int wrlvl_override; + unsigned int wrlvl_sample; /* Write leveling */ + unsigned int wrlvl_start; + unsigned int half_strength_driver_enable; unsigned int twoT_en; unsigned int threeT_en;
Dave Liu
