[U-Boot] [PATCH 2/2] powerpc: make espi can read more than 0xFFFA bytes
espi flash read returns invalid data if the read length is more than 0xFFFA bytes, it supports maximum transaction of 2^16 bytes at a time, resister spcom[TRANLEN] is 16 bits. If the transaction length is greater than 0xFFFF, it need to be split into multiple transactions.
Signed-off-by: Shaohui Xie b21989@freescale.com Cc: Mike Frysinger vapier@gentoo.org --- this patch is rebased on Mike's sf unify patches.
drivers/mtd/spi/spi_flash.c | 30 ++++++++++++++++++++++++++++++ drivers/spi/fsl_espi.c | 6 ++++++ include/spi.h | 2 ++ 3 files changed, 38 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index f745def..f50ca63 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -127,11 +127,41 @@ int spi_flash_cmd_read_fast(struct spi_flash *flash, u32 offset, { u8 cmd[5];
+#ifndef CONFIG_FSL_ESPI cmd[0] = CMD_READ_ARRAY_FAST; spi_flash_addr(offset, cmd); cmd[4] = 0x00;
return spi_flash_read_common(flash, cmd, sizeof(cmd), data, len); +#else + int max_tran_len, num_chunks, tran_len, ret; + + max_tran_len = flash->spi->max_transfer_length; + num_chunks = len / max_tran_len + (len % max_tran_len ? 1 : 0); + + while (num_chunks--) { + tran_len = min(len , max_tran_len); + + cmd[0] = CMD_READ_ARRAY_FAST; + spi_flash_addr(offset, cmd); + cmd[4] = 0x00; + + debug("READ: 0x%x => cmd = + { 0x%02x 0x%02x%02x%02x%02x } tran_len = 0x%x\n", + offset, cmd[0], cmd[1], cmd[2], cmd[3], cmd[4], tran_len); + + ret = spi_flash_read_common( + flash, cmd, sizeof(cmd), data, tran_len); + if (ret < 0) + return ret; + + offset += max_tran_len; + data += max_tran_len; + len -= max_tran_len; + } + + return ret; +#endif }
int spi_flash_cmd_poll_bit(struct spi_flash *flash, unsigned long timeout, diff --git a/drivers/spi/fsl_espi.c b/drivers/spi/fsl_espi.c index f4ff884..66ae1a8 100644 --- a/drivers/spi/fsl_espi.c +++ b/drivers/spi/fsl_espi.c @@ -53,6 +53,8 @@ ESPI_CSMODE_CSBEF(0) | ESPI_CSMODE_CSAFT(0) | \ ESPI_CSMODE_CSCG(1))
+#define ESPI_MAX_DATA_TRANSFER_LEN 0xFFF0 + struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode) { @@ -72,6 +74,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs,
slave->bus = bus; slave->cs = cs; + slave->max_transfer_length = ESPI_MAX_DATA_TRANSFER_LEN;
/* Enable eSPI interface */ espi->mode = ESPI_MODE_RXTHR(3) | ESPI_MODE_TXTHR(4) | ESPI_MODE_EN; @@ -153,6 +156,9 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, unsigned char *ch; int num_bytes = len % 4;
+ if (t->data_len > ESPI_MAX_DATA_TRANSFER_LEN) + return -1; + debug("spi_xfer: slave %u:%u dout %08X(%08x) din %08X(%08x) len %u\n", slave->bus, slave->cs, *(uint *) dout, dout, *(uint *) din, din, len); diff --git a/include/spi.h b/include/spi.h index 423899f..b0e13d5 100644 --- a/include/spi.h +++ b/include/spi.h @@ -77,12 +77,14 @@ struct espi_transfer { * * bus: ID of the bus that the slave is attached to. * cs: ID of the chip select connected to the slave. + * max_txn_length: maximum data transfer length supported by the slave. * transfer: Represent an eSPI transaction. */ struct spi_slave { unsigned int bus; unsigned int cs;
+ unsigned int max_transfer_length; struct espi_transfer *transfer; };
Shaohui Xie
