[PATCH v3] config: Add 'update_bootimg' command to update flash.bin on Phytec's imx8mm
This command allows easy update on SD card or eMMC of the flash.bin generated (with binman) during u-boot build.
Signed-off-by: Lukasz Majewski lukma@denx.de --- Changes for v2: - Remove 'update_mmc_part' variable - Change path for hostname - Use full version of dhcp command (${loadaddr} added)
Changes for v3: - Remove +1 when calculating the size of binary to be written --- include/configs/phycore_imx8mm.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index ce6dc87c69..361e665676 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -29,6 +29,16 @@ "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ "mmcpart=1\0" \ "mmcroot=2\0" \ + "update_offset=0x42\0" \ + "update_filename=flash.bin\0" \ + "hostname=/srv/tftp/\0" \ + "update_bootimg=" \ + "mmc dev ${mmcdev} ; " \ + "if dhcp ${loadaddr} ${hostname}/${update_filename} ; then " \ + "setexpr fw_sz ${filesize} / 0x200 ; " /* SD block size */ \ + "setexpr fw_sz ${fw_sz} ; " \ + "mmc write ${loadaddr} ${update_offset} ${fw_sz} ; " \ + "fi\0" \ "mmcautodetect=yes\0" \ "mmcargs=setenv bootargs console=${console} " \ "root=/dev/mmcblk${mmcdev}p${mmcroot} rootwait rw\0" \
Hi Lukasz,
Changes for v2:
Changes for v3:
It looks good to me now.
Teresa/Benjamin/Cem,
Are you happy with this version?
Thanks
Hi Lukasz,
Changes for v2:
Changes for v3:
- "update_offset=0x42\0" \
- "update_filename=flash.bin\0" \
- "hostname=/srv/tftp/\0" \
- "update_bootimg=" \
The dhcp and tftp command should take the filepath from the tftp directory and get the tftp directory automatically not the absolute path. So this will try to get the file from /path_to_tftp_folder/srv/tftp/flash.bin and will fail because it can't find it. So you can drop the ${hostname}. Also drop the initialization of ${hostname} above since it is no longer needed.
Should be like this:
dhcp ${loadaddr} ${update_filename}
I think you can drop this line since it does not do anything.
Benjamin
"mmcautodetect=yes\0" \ "mmcargs=setenv bootargs console=${console} " \ "root=/dev/mmcblk${mmcdev}p${mmcroot} rootwait rw\0" \"fi\0" \
Hi Benjamin,
Hi Lukasz,
Changes for v2:
Changes for v3:
And that is why you do have the ${hostname}/${update_filename}, so when you have several exported directories - you can specify which one without the need to modify the 'update_bootimg' command.
I would prefer to keep the ${hostname}/${update_filename} part.
IMHO the line shall be:
SD block size */ \
Ok.
Benjamin
"mmcautodetect=yes\0" \ "mmcargs=setenv bootargs console=${console} " \ "root=/dev/mmcblk${mmcdev}p${mmcroot} rootwait"fi\0" \
rw\0" \
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Erika Unter HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hello Lukasz,
Am Mittwoch, dem 07.08.2024 um 13:04 +0200 schrieb Lukasz Majewski:
Hi Benjamin,
Hi Lukasz,
Changes for v2:
Changes for v3:
do I understand it correct that you just want to be able to define sub dirs with a variable? This does make sense but you should not pre- define them here.
And I think the variable name $hostname is kind of miss leading. Maybe you can find some different name for it?
Regards, Teresa
Ok.
Benjamin
Lukasz Majewski
Hi Teresa,
Hello Lukasz,
Hi Benjamin,
Hi Lukasz,
Changes for v2:
Changes for v3:
Yes, correct.
Ok. I will remove the "hostname=/srv/tftp" environment variable.
The ${hostname} is used in a few places already in that way. Maybe you have better idea for this variable's name?
Regards, Teresa
Ok.
Benjamin
Lukasz Majewski
Lukasz Majewski
Hello Lukasz
Am Donnerstag, dem 08.08.2024 um 12:25 +0200 schrieb Lukasz Majewski:
Hi Teresa,
Hello Lukasz,
Hi Benjamin,
Hi Lukasz,
Changes for v2:
Changes for v3:
Yes, correct.
As it is ${update_filename} maybe ${update_filepath}?
Teresa
Regards, Teresa
Ok.
Benjamin
Lukasz Majewski
Lukasz Majewski
Benjamin Hahn
Fabio Estevam
Lukasz Majewski
Teresa Remmet
