[U-Boot] [PATCH 0/2] efi_loader: implement deprecated Unicode collation protocol
In EFI 1.10 a version of the Unicode collation protocol using ISO 639-2 language codes existed. This protocol is not part of the UEFI specification any longer. Unfortunately it is required to run the UEFI Self Certification Test (SCT) II, version 2.6, 2017. So we implement it here for the sole purpose of running the SCT. It can be removed once a compliant SCT is available.
The configuration option defaults to no.
Heinrich Schuchardt (2): efi_loader: rename Unicode collation protocol 2 variables efi_loader: implement deprecated Unicode collation protocol
include/efi_api.h | 5 ++++ include/efi_loader.h | 9 +++++-- lib/efi_loader/Kconfig | 15 ++++++++++-- lib/efi_loader/Makefile | 2 +- lib/efi_loader/efi_root_node.c | 7 +++++- lib/efi_loader/efi_unicode_collation.c | 33 +++++++++++++++++++++++--- lib/efi_selftest/Makefile | 3 ++- 7 files changed, 64 insertions(+), 10 deletions(-)
-- 2.20.1
Rename variables to make it clear they refer to the Unicode collation protocol identified by the EFI_UNICODE_PROTOCOL2_GUID.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_loader.h | 4 ++-- lib/efi_loader/Kconfig | 4 ++-- lib/efi_loader/Makefile | 2 +- lib/efi_loader/efi_root_node.c | 6 +++--- lib/efi_loader/efi_unicode_collation.c | 6 +++--- lib/efi_selftest/Makefile | 3 ++- 6 files changed, 13 insertions(+), 12 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index 07ef14ba1c..835007e179 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -108,7 +108,7 @@ extern const struct efi_device_path_utilities_protocol efi_device_path_utilities; /* Implementation of the EFI_UNICODE_COLLATION_PROTOCOL */ extern const struct efi_unicode_collation_protocol - efi_unicode_collation_protocol; + efi_unicode_collation_protocol2; extern const struct efi_hii_config_routing_protocol efi_hii_config_routing; extern const struct efi_hii_config_access_protocol efi_hii_config_access; extern const struct efi_hii_database_protocol efi_hii_database; @@ -146,7 +146,7 @@ extern const efi_guid_t efi_file_info_guid; extern const efi_guid_t efi_file_system_info_guid; extern const efi_guid_t efi_guid_device_path_utilities_protocol; /* GUID of the Unicode collation protocol */ -extern const efi_guid_t efi_guid_unicode_collation_protocol; +extern const efi_guid_t efi_guid_unicode_collation_protocol2; extern const efi_guid_t efi_guid_hii_config_routing_protocol; extern const efi_guid_t efi_guid_hii_config_access_protocol; extern const efi_guid_t efi_guid_hii_database_protocol; diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 6501ee56aa..7e13ee54b2 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -36,14 +36,14 @@ config EFI_LOADER_HII U-Boot implements enough of its features to be able to run the UEFI Shell, but not more than that.
-config EFI_UNICODE_COLLATION_PROTOCOL +config EFI_UNICODE_COLLATION_PROTOCOL2 bool "Unicode collation protocol" default y help The Unicode collation protocol is used for lexical comparisons. It is required to run the UEFI shell.
-if EFI_UNICODE_COLLATION_PROTOCOL +if EFI_UNICODE_COLLATION_PROTOCOL2
config EFI_UNICODE_CAPITALIZATION bool "Support Unicode capitalization" diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index f3d6773bf6..01769ea58b 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -30,7 +30,7 @@ obj-y += efi_memory.o obj-y += efi_root_node.o obj-y += efi_runtime.o obj-y += efi_setup.o -obj-$(CONFIG_EFI_UNICODE_COLLATION_PROTOCOL) += efi_unicode_collation.o +obj-$(CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2) += efi_unicode_collation.o obj-y += efi_variable.o obj-y += efi_watchdog.o obj-$(CONFIG_LCD) += efi_gop.o diff --git a/lib/efi_loader/efi_root_node.c b/lib/efi_loader/efi_root_node.c index d8496cc3c2..2b7277de05 100644 --- a/lib/efi_loader/efi_root_node.c +++ b/lib/efi_loader/efi_root_node.c @@ -60,10 +60,10 @@ efi_status_t efi_root_node_register(void) /* Device path utilities protocol */ &efi_guid_device_path_utilities_protocol, (void *)&efi_device_path_utilities, -#if CONFIG_IS_ENABLED(EFI_UNICODE_COLLATION_PROTOCOL) +#if CONFIG_IS_ENABLED(EFI_UNICODE_COLLATION_PROTOCOL2) /* Unicode collation protocol */ - &efi_guid_unicode_collation_protocol, - (void *)&efi_unicode_collation_protocol, + &efi_guid_unicode_collation_protocol2, + (void *)&efi_unicode_collation_protocol2, #endif #if CONFIG_IS_ENABLED(EFI_LOADER_HII) /* HII string protocol */ diff --git a/lib/efi_loader/efi_unicode_collation.c b/lib/efi_loader/efi_unicode_collation.c index 7f3ea3c77e..e04a4de5b7 100644 --- a/lib/efi_loader/efi_unicode_collation.c +++ b/lib/efi_loader/efi_unicode_collation.c @@ -26,8 +26,8 @@ static const u16 codepage[] = CP1250; static const u16 codepage[] = CP437; #endif
-/* GUID of the EFI_UNICODE_COLLATION_PROTOCOL */ -const efi_guid_t efi_guid_unicode_collation_protocol = +/* GUID of the EFI_UNICODE_COLLATION_PROTOCOL2 */ +const efi_guid_t efi_guid_unicode_collation_protocol2 = EFI_UNICODE_COLLATION_PROTOCOL2_GUID;
/** @@ -318,7 +318,7 @@ static bool EFIAPI efi_str_to_fat(struct efi_unicode_collation_protocol *this, return ret; }
-const struct efi_unicode_collation_protocol efi_unicode_collation_protocol = { +const struct efi_unicode_collation_protocol efi_unicode_collation_protocol2 = { .stri_coll = efi_stri_coll, .metai_match = efi_metai_match, .str_lwr = efi_str_lwr, diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index d0bebc7d0c..cfbb40c891 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -38,7 +38,8 @@ efi_selftest_variables.o \ efi_selftest_watchdog.o
obj-$(CONFIG_EFI_DEVICE_PATH_TO_TEXT) += efi_selftest_devicepath.o -obj-$(CONFIG_EFI_UNICODE_COLLATION_PROTOCOL) += efi_selftest_unicode_collation.o +obj-$(CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2) += \ +efi_selftest_unicode_collation.o
obj-$(CONFIG_CPU_V7) += efi_selftest_unaligned.o obj-$(CONFIG_EFI_LOADER_HII) += efi_selftest_hii.o -- 2.20.1
Signed-off-by: Rob Clark robdclark@gmail.com
Most of Rob's original patch is already merged. Only the deprecated protocol is missing. Rebase it and make it configurable.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_api.h | 5 +++++ include/efi_loader.h | 7 ++++++- lib/efi_loader/Kconfig | 11 +++++++++++ lib/efi_loader/efi_root_node.c | 7 ++++++- lib/efi_loader/efi_unicode_collation.c | 27 ++++++++++++++++++++++++++ 5 files changed, 55 insertions(+), 2 deletions(-)
diff --git a/include/efi_api.h b/include/efi_api.h index 755c405793..7dcd82b681 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -1425,6 +1425,11 @@ struct efi_driver_binding_protocol { efi_handle_t driver_binding_handle; };
+/* Deprecated version of the Unicode collation protocol */ +#define EFI_UNICODE_COLLATION_PROTOCOL_GUID \ + EFI_GUID(0x1d85cd7f, 0xf43d, 0x11d2, \ + 0x9a, 0x0c, 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d) +/* Current version of the Unicode collation protocol */ #define EFI_UNICODE_COLLATION_PROTOCOL2_GUID \ EFI_GUID(0xa4c751fc, 0x23ae, 0x4c3e, \ 0x92, 0xe9, 0x49, 0x64, 0xcf, 0x63, 0xf3, 0x49) diff --git a/include/efi_loader.h b/include/efi_loader.h index 835007e179..8167e6ffcb 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -106,7 +106,10 @@ extern const struct efi_device_path_to_text_protocol efi_device_path_to_text; /* implementation of the EFI_DEVICE_PATH_UTILITIES_PROTOCOL */ extern const struct efi_device_path_utilities_protocol efi_device_path_utilities; -/* Implementation of the EFI_UNICODE_COLLATION_PROTOCOL */ +/* deprecated version of the EFI_UNICODE_COLLATION_PROTOCOL */ +extern const struct efi_unicode_collation_protocol + efi_unicode_collation_protocol; +/* current version of the EFI_UNICODE_COLLATION_PROTOCOL */ extern const struct efi_unicode_collation_protocol efi_unicode_collation_protocol2; extern const struct efi_hii_config_routing_protocol efi_hii_config_routing; @@ -145,6 +148,8 @@ extern const efi_guid_t efi_file_info_guid; /* GUID for file system information */ extern const efi_guid_t efi_file_system_info_guid; extern const efi_guid_t efi_guid_device_path_utilities_protocol; +/* GUID of the deprecated Unicode collation protocol */ +extern const efi_guid_t efi_guid_unicode_collation_protocol; /* GUID of the Unicode collation protocol */ extern const efi_guid_t efi_guid_unicode_collation_protocol2; extern const efi_guid_t efi_guid_hii_config_routing_protocol; diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 7e13ee54b2..fc04ea39d0 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -54,6 +54,17 @@ config EFI_UNICODE_CAPITALIZATION set, only the the correct handling of the letters of the codepage used by the FAT file system is ensured.
+config EFI_UNICODE_COLLATION_PROTOCOL + bool "Deprecated version of the Unicode collation protocol" + default n + help + In EFI 1.10 a version of the Unicode collation protocol using ISO + 639-2 language codes existed. This protocol is not part of the UEFI + specification any longer. Unfortunately it is required to run the + UEFI Self Certification Test (SCT) II, version 2.6, 2017. + + Choose this option for testing only. It is bound to be removed. + endif
config EFI_LOADER_BOUNCE_BUFFER diff --git a/lib/efi_loader/efi_root_node.c b/lib/efi_loader/efi_root_node.c index 2b7277de05..f68b0fdc61 100644 --- a/lib/efi_loader/efi_root_node.c +++ b/lib/efi_loader/efi_root_node.c @@ -61,7 +61,12 @@ efi_status_t efi_root_node_register(void) &efi_guid_device_path_utilities_protocol, (void *)&efi_device_path_utilities, #if CONFIG_IS_ENABLED(EFI_UNICODE_COLLATION_PROTOCOL2) - /* Unicode collation protocol */ +#if CONFIG_IS_ENABLED(EFI_UNICODE_COLLATION_PROTOCOL) + /* Deprecated Unicode collation protocol */ + &efi_guid_unicode_collation_protocol, + (void *)&efi_unicode_collation_protocol, +#endif + /* Current Unicode collation protocol */ &efi_guid_unicode_collation_protocol2, (void *)&efi_unicode_collation_protocol2, #endif diff --git a/lib/efi_loader/efi_unicode_collation.c b/lib/efi_loader/efi_unicode_collation.c index e04a4de5b7..06fddca1c4 100644 --- a/lib/efi_loader/efi_unicode_collation.c +++ b/lib/efi_loader/efi_unicode_collation.c @@ -327,3 +327,30 @@ const struct efi_unicode_collation_protocol efi_unicode_collation_protocol2 = { .str_to_fat = efi_str_to_fat, .supported_languages = "en", }; + +/* + * In EFI 1.10 a version of the Unicode collation protocol using ISO 639-2 + * language codes existed. This protocol is not part of the UEFI specification + * any longer. Unfortunately it is required to run the UEFI Self Certification + * Test (SCT) II, version 2.6, 2017. So we implement it here for the sole + * purpose of running the SCT. It can be removed when a compliant SCT is + * available. + */ +#if CONFIG_IS_ENABLED(EFI_UNICODE_COLLATION_PROTOCOL) + +/* GUID of the EFI_UNICODE_COLLATION_PROTOCOL */ +const efi_guid_t efi_guid_unicode_collation_protocol = + EFI_UNICODE_COLLATION_PROTOCOL_GUID; + +const struct efi_unicode_collation_protocol efi_unicode_collation_protocol = { + .stri_coll = efi_stri_coll, + .metai_match = efi_metai_match, + .str_lwr = efi_str_lwr, + .str_upr = efi_str_upr, + .fat_to_str = efi_fat_to_str, + .str_to_fat = efi_str_to_fat, + /* ISO 639-2 language code */ + .supported_languages = "eng", +}; + +#endif -- 2.20.1
Heinrich,
I remember that Alex always rejected this kind of patch, saying that an upstream (SCT in this case) should be fixed in the first place.
Do you want to change this policy? (I'm just asking.)
-Takahiro Akashi
-- 2.20.1
On 5/24/19 3:02 AM, AKASHI Takahiro wrote:
Heinrich,
I am using SCT a lot to test my patches. I want to be able to run the tests on the final code.
I have raised a ticket for upstream SCT but did not see any reaction up to now.
Making this deprecated protocol a config option deselected by default is the most plausible solution to me. In the Kconfig comment I made it clear that this protocol is going to be removed when the SCT has been corrected.
Best regards
Heinrich
-Takahiro Akashi
-- 2.20.1
Heinrich,
but less than two weeks have passed. Why not ping again?
It is likely that your patch will be reverted soon in 2019.09. (I don't know release cycle of UEFI SCT though.) I believe that such a patch should be maintained only in your local repository.
-Takahiro Akashi
Best regards
Heinrich
-Takahiro Akashi
-- 2.20.1
On Fri, May 24, 2019 at 6:19 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Heinrich,
Wouldn't it be better to patch/fork the upstream SCT that blindly pulling in obsolete code that is basically already dead?
Got a reference to the ticket?
I disagree, I think if it's obsolete not having the code in the first case in the most plausible option IMO.
Best regards
Heinrich
-Takahiro Akashi
-- 2.20.1
Heinrich,
If you could submit a patch for SCT, that surely would help.
https://bugzilla.tianocore.org/show_bug.cgi?id=1802
Best regards
Heinrich
Best regards
Heinrich
-Takahiro Akashi
-- 2.20.1
Heinrich,
Since it's hidden behind a default-n config option, I'd not be terribly opposed to it. I do agree that fixing SCT is the better path forward.
Leif, how long do you think fixing this properly in SCT is going to take?
Alex
Well, as usual, patches welcome :)
However, I think the problem is more that the separate SCT area of bugzilla is a fairly recent addition and they forgot to change the default assignee to someone who actually works on SCT...
I have now added the SCT maintainers to cc on https://bugzilla.tianocore.org/show_bug.cgi?id=1802
/ Leif
participants (5)
AKASHI Takahiro
Alexander Graf
Leif Lindholm
Peter Robinson
