[U-Boot] [PATCHv4 1/2] power: as3722: Allow using on any i2c bus with any address
The init simply hardcoded the i2c bus and address to those used on jetson. Extend the init function to take the bus number and device address as parameter. As only jetson is using this code for now just fix this single use of the function.
Signed-off-by: Alban Bedel alban.bedel@avionic-design.de Reviewed-by: Julian Scheel julian@jusst.de Signed-off-by: Julian Scheel julian@jusst.de --- Changes in v2: - add signed off by me --- arch/arm/mach-tegra/board2.c | 2 +- board/nvidia/jetson-tk1/jetson-tk1.c | 2 +- drivers/power/as3722.c | 4 +--- include/power/as3722.h | 2 +- 4 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-tegra/board2.c b/arch/arm/mach-tegra/board2.c index 141d6e1..896c1cc 100644 --- a/arch/arm/mach-tegra/board2.c +++ b/arch/arm/mach-tegra/board2.c @@ -148,7 +148,7 @@ int board_init(void) # endif # endif /* CONFIG_TEGRA_PMU */ #ifdef CONFIG_AS3722_POWER - err = as3722_init(NULL); + err = as3722_init(NULL, 0, 0x40); if (err && err != -ENODEV) return err; #endif diff --git a/board/nvidia/jetson-tk1/jetson-tk1.c b/board/nvidia/jetson-tk1/jetson-tk1.c index 14f0ce5..7f16a4a 100644 --- a/board/nvidia/jetson-tk1/jetson-tk1.c +++ b/board/nvidia/jetson-tk1/jetson-tk1.c @@ -39,7 +39,7 @@ int tegra_pcie_board_init(void) struct udevice *pmic; int err;
- err = as3722_init(&pmic); + err = as3722_init(&pmic, 0, 0x40); if (err) { error("failed to initialize AS3722 PMIC: %d\n", err); return err; diff --git a/drivers/power/as3722.c b/drivers/power/as3722.c index c09e1de..321d65d 100644 --- a/drivers/power/as3722.c +++ b/drivers/power/as3722.c @@ -243,12 +243,10 @@ int as3722_get(struct udevice **devp) return i2c_get_chip_for_busnum(bus, address, 1, devp); }
-int as3722_init(struct udevice **devp) +int as3722_init(struct udevice **devp, unsigned int bus, unsigned int address) { struct udevice *pmic; u8 id, revision; - const unsigned int bus = 0; - const unsigned int address = 0x40; int err;
err = i2c_get_chip_for_busnum(bus, address, 1, &pmic); diff --git a/include/power/as3722.h b/include/power/as3722.h index 0f22482..c37b43a 100644 --- a/include/power/as3722.h +++ b/include/power/as3722.h @@ -14,7 +14,7 @@
struct udevice;
-int as3722_init(struct udevice **devp); +int as3722_init(struct udevice **devp, unsigned int bus, unsigned int address); int as3722_sd_enable(struct udevice *pmic, unsigned int sd); int as3722_sd_set_voltage(struct udevice *pmic, unsigned int sd, u8 value); int as3722_ldo_enable(struct udevice *pmic, unsigned int ldo);
Add support for platforms based on the Meerkat COM module. Includes support for the minimal reference platform called Kein Baseboard, which in fact is sufficient to run most existing Meerkat carriers.
Changes in v4: - rebased to tegra/master (2016-05-22, cc9db6a)
Changes in v3: - Remove bad as3722 gpio manipulations on pcie init (this time for real)
Changes in v2: - Rename config options to TARGET_KEIN_BASEBOARD - Remove unnecessary CONFIG options from kein-baseboard.h - Add clocks to meerkat dtsi, as it was removed from tegra124-dtsi lately --- arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra124-kein-baseboard.dts | 66 ++++ arch/arm/dts/tegra124-meerkat.dtsi | 408 +++++++++++++++++++++ arch/arm/mach-tegra/tegra124/Kconfig | 9 + board/avionic-design/common/meerkat.c | 57 +++ .../avionic-design/common/pinmux-config-meerkat.h | 233 ++++++++++++ board/avionic-design/kein-baseboard/Kconfig | 15 + board/avionic-design/kein-baseboard/MAINTAINERS | 7 + board/avionic-design/kein-baseboard/Makefile | 9 + configs/kein-baseboard_defconfig | 21 ++ include/configs/kein-baseboard.h | 71 ++++ 11 files changed, 897 insertions(+) create mode 100644 arch/arm/dts/tegra124-kein-baseboard.dts create mode 100644 arch/arm/dts/tegra124-meerkat.dtsi create mode 100644 board/avionic-design/common/meerkat.c create mode 100644 board/avionic-design/common/pinmux-config-meerkat.h create mode 100644 board/avionic-design/kein-baseboard/Kconfig create mode 100644 board/avionic-design/kein-baseboard/MAINTAINERS create mode 100644 board/avionic-design/kein-baseboard/Makefile create mode 100644 configs/kein-baseboard_defconfig create mode 100644 include/configs/kein-baseboard.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0915e05..a0135b7 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -41,6 +41,7 @@ dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra30-tec-ng.dtb \ tegra114-dalmore.dtb \ tegra124-jetson-tk1.dtb \ + tegra124-kein-baseboard.dtb \ tegra124-nyan-big.dtb \ tegra124-venice2.dtb \ tegra210-e2220-1170.dtb \ diff --git a/arch/arm/dts/tegra124-kein-baseboard.dts b/arch/arm/dts/tegra124-kein-baseboard.dts new file mode 100644 index 0000000..75a0b99 --- /dev/null +++ b/arch/arm/dts/tegra124-kein-baseboard.dts @@ -0,0 +1,66 @@ +/dts-v1/; + +#include "tegra124-meerkat.dtsi" + +/ { + model = "Avionic Design Kein Baseboard"; + compatible = "ad,kein-baseboard", "ad,meerkat", "nvidia,tegra124"; + + chosen { + stdout-path = &uartd; + }; + + serial@70006300 { + status = "okay"; + }; + + sdhci@700b0400 { + status = "okay"; + }; + + usb@7d000000 { + status = "okay"; + }; + + usb@7d004000 { + status = "okay"; + }; + + usb@7d008000 { + status = "okay"; + }; + + pcie-controller@01003000 { + status = "okay"; + + pci@1,0 { + status = "okay"; + }; + + pci@2,0 { + status = "okay"; + }; + }; + + regulators { + vdd_5v0: regulator@100 { + compatible = "regulator-fixed"; + reg = <100>; + regulator-name = "+VDD_5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_3v3: regulator@101 { + compatible = "regulator-fixed"; + reg = <101>; + regulator-name = "+VDD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + }; +}; diff --git a/arch/arm/dts/tegra124-meerkat.dtsi b/arch/arm/dts/tegra124-meerkat.dtsi new file mode 100644 index 0000000..a056542 --- /dev/null +++ b/arch/arm/dts/tegra124-meerkat.dtsi @@ -0,0 +1,408 @@ + +#include "tegra124.dtsi" + +/ { + model = "Avionic-Design Meerkat"; + compatible = "ad,meerkat", "nvidia,tegra124"; + + aliases { + i2c0 = "/i2c@7000c000"; + i2c1 = "/i2c@7000c400"; + i2c2 = "/i2c@7000c500"; + i2c3 = "/i2c@7000c700"; + i2c4 = "/i2c@7000d000"; + i2c5 = "/i2c@7000d100"; + + sdhci0 = "/sdhci@700b0600"; + sdhci1 = "/sdhci@700b0400"; + + usb0 = "/usb@7d000000"; + usb1 = "/usb@7d008000"; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x80000000>; + }; + + pcie-controller@01003000 { + avddio-pex-supply = <&vdd_1v05_run>; + dvddio-pex-supply = <&vdd_1v05_run>; + avdd-pex-pll-supply = <&vdd_1v05_run>; + hvdd-pex-supply = <&vdd_3v3_lp0>; + hvdd-pex-pll-e-supply = <&vdd_3v3_lp0>; + vddio-pex-ctl-supply = <&vdd_3v3_lp0>; + avdd-pll-erefe-supply = <&avdd_1v05_run>; + }; + + /* Expansion GEN1_I2C_* */ + i2c@7000c000 { + clock-frequency = <100000>; + }; + + /* Expansion GEN2_I2C_* */ + i2c@7000c400 { + clock-frequency = <100000>; + }; + + /* Expansion CAM_I2C_* */ + i2c@7000c500 { + clock-frequency = <100000>; + }; + + /* HDMI DDC */ + hdmi_ddc: i2c@7000c700 { + clock-frequency = <100000>; + }; + + /* Expansion PWR_I2C_*, on-board components */ + i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + + pmic: pmic@40 { + compatible = "ams,as3722"; + reg = <0x40>; + interrupts = <0 86 IRQ_TYPE_LEVEL_HIGH>; + + ams,system-power-controller; + + #interrupt-cells = <2>; + interrupt-controller; + + gpio-controller; + #gpio-cells = <2>; + + pinctrl-names = "default"; + pinctrl-0 = <&as3722_default>; + + as3722_default: pinmux { + gpio0 { + pins = "gpio0"; + function = "gpio"; + bias-pull-down; + }; + + gpio1_2_4_7 { + pins = "gpio1", "gpio2", "gpio4", "gpio7"; + function = "gpio"; + bias-pull-up; + }; + + gpio3_5_6 { + pins = "gpio3", "gpio5", "gpio6"; + bias-high-impedance; + }; + }; + + regulators { + vsup-sd2-supply = <&vdd_5v0_sys>; + vsup-sd3-supply = <&vdd_5v0_sys>; + vsup-sd4-supply = <&vdd_5v0_sys>; + vsup-sd5-supply = <&vdd_5v0_sys>; + vin-ldo0-supply = <&vdd_1v35_lp0>; + vin-ldo1-6-supply = <&vdd_3v3_run>; + vin-ldo2-5-7-supply = <&vddio_1v8>; + vin-ldo3-4-supply = <&vdd_3v3_sys>; + vin-ldo9-10-supply = <&vdd_5v0_sys>; + vin-ldo11-supply = <&vdd_3v3_run>; + + vdd_cpu: sd0 { + regulator-name = "+VDD_CPU_AP"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1400000>; + regulator-min-microamp = <3500000>; + regulator-max-microamp = <3500000>; + regulator-always-on; + regulator-boot-on; + ams,ext-control = <2>; + }; + + sd1 { + regulator-name = "+VDD_CORE"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-min-microamp = <2500000>; + regulator-max-microamp = <2500000>; + regulator-always-on; + regulator-boot-on; + ams,ext-control = <1>; + }; + + vdd_1v35_lp0: sd2 { + regulator-name = "+1V35_LP0(sd2)"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + sd3 { + regulator-name = "+1V35_LP0(sd3)"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_1v05_run: sd4 { + regulator-name = "+1V05_RUN"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + }; + + vddio_1v8: sd5 { + regulator-name = "+1V8_VDDIO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + vdd_gpu: sd6 { + regulator-name = "+VDD_GPU_AP"; + regulator-min-microvolt = <650000>; + regulator-max-microvolt = <1200000>; + regulator-min-microamp = <3500000>; + regulator-max-microamp = <3500000>; + regulator-boot-on; + regulator-always-on; + }; + + avdd_1v05_run: ldo0 { + regulator-name = "+1V05_RUN_AVDD"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + regulator-boot-on; + regulator-always-on; + ams,ext-control = <1>; + }; + + ldo1 { + regulator-name = "+1V8_RUN_CAM"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + ldo2 { + regulator-name = "+1V2_GEN_AVDD"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3 { + regulator-name = "+1V05_LP0_VDD_RTC"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + ams,enable-tracking; + }; + + ldo4 { + regulator-name = "+2V8_RUN_CAM"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo5 { + regulator-name = "+1V2_RUN_CAM_FRONT"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + + vddio_sdmmc3: ldo6 { + regulator-name = "+VDDIO_SDMMC3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + ldo7 { + regulator-name = "+1V05_RUN_CAM_REAR"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + }; + + ldo9 { + regulator-name = "+3V3_RUN_TOUCH"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo10 { + regulator-name = "+2V8_RUN_CAM_AF"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo11 { + regulator-name = "+1V8_RUN_VPP_FUSE"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + }; + }; + }; + + i2c@7000d100 { + clock-frequency = <400000>; + }; + + spi@7000d400 { + spi-max-frequency = <25000000>; + }; + + spi@7000da00 { + spi-max-frequency = <25000000>; + }; + + padctl@7009f000 { + pinctrl-0 = <&padctl_default>; + pinctrl-names = "default"; + + padctl_default: pinmux { + usb3 { + nvidia,lanes = "pcie-0", "pcie-1"; + nvidia,function = "usb3"; + nvidia,iddq = <0>; + }; + + pcie { + nvidia,lanes = "pcie-2", "pcie-3", + "pcie-4"; + nvidia,function = "pcie"; + nvidia,iddq = <0>; + }; + + sata { + nvidia,lanes = "sata-0"; + nvidia,function = "sata"; + nvidia,iddq = <0>; + }; + }; + }; + + sdhci@700b0400 { + cd-gpios = <&gpio TEGRA_GPIO(V, 2) GPIO_ACTIVE_LOW>; + power-gpios = <&gpio TEGRA_GPIO(R, 0) GPIO_ACTIVE_HIGH>; + bus-width = <4>; + }; + + sdhci@700b0600 { + status = "okay"; + bus-width = <8>; + }; + + usb@7d000000 { + dr_mode = "otg"; + nvidia,vbus-gpio = <&gpio TEGRA_GPIO(N, 4) GPIO_ACTIVE_HIGH>; + }; + + usb@7d004000 { + phy_type = "utmi"; + nvidia,vbus-gpio = <&gpio TEGRA_GPIO(N, 5) GPIO_ACTIVE_HIGH>; + }; + + usb@7d008000 { + nvidia,vbus-gpio = <&gpio TEGRA_GPIO(FF, 1) GPIO_ACTIVE_HIGH>; + }; + + clocks { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + clk32k_in: clock@0 { + compatible = "fixed-clock"; + reg = <0>; + #clock-cells = <0>; + clock-frequency = <32768>; + }; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + vdd_mux: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "+VDD_MUX"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_5v0>; + }; + + vdd_5v0_sys: regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "+5V_SYS"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_mux>; + }; + + vdd_3v3_sys: regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "+3.3V_SYS"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_3v3>; + }; + + vdd_3v3_run: regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + regulator-name = "+3.3V_RUN"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + gpio = <&pmic 1 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_3v3_sys>; + }; + + vdd_3v3_hdmi: regulator@4 { + compatible = "regulator-fixed"; + reg = <4>; + regulator-name = "+3.3V_AVDD_HDMI_AP_GATED"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vdd_3v3_run>; + }; + + vdd_3v3_lp0: regulator@5 { + compatible = "regulator-fixed"; + reg = <5>; + regulator-name = "+3.3V_LP0"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + gpio = <&pmic 2 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_3v3_sys>; + }; + + vdd_hdmi_pll: regulator@6 { + compatible = "regulator-fixed"; + reg = <6>; + regulator-name = "+1.05V_RUN_AVDD_HDMI_PLL"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + gpio = <&gpio TEGRA_GPIO(H, 7) GPIO_ACTIVE_LOW>; + vin-supply = <&vdd_1v05_run>; + }; + }; +}; diff --git a/arch/arm/mach-tegra/tegra124/Kconfig b/arch/arm/mach-tegra/tegra124/Kconfig index f3324ff..dd65d5d 100644 --- a/arch/arm/mach-tegra/tegra124/Kconfig +++ b/arch/arm/mach-tegra/tegra124/Kconfig @@ -21,6 +21,14 @@ config TARGET_NYAN_BIG config TARGET_VENICE2 bool "NVIDIA Tegra124 Venice2"
+config TARGET_KEIN_BASEBOARD + bool "Avionic Design Kein Baseboard" + select CPU_V7_HAS_NONSEC if !SPL_BUILD + select CPU_V7_HAS_VIRT if !SPL_BUILD + help + Minimal baseboard for Avionic Design Meerkat COM. Should work with most + baseboard that follow the reference design. + endchoice
config SYS_SOC @@ -29,5 +37,6 @@ config SYS_SOC source "board/nvidia/jetson-tk1/Kconfig" source "board/nvidia/nyan-big/Kconfig" source "board/nvidia/venice2/Kconfig" +source "board/avionic-design/kein-baseboard/Kconfig"
endif diff --git a/board/avionic-design/common/meerkat.c b/board/avionic-design/common/meerkat.c new file mode 100644 index 0000000..30def80 --- /dev/null +++ b/board/avionic-design/common/meerkat.c @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2014, NVIDIA Corporation <www.nvidia.com> + * (C) Copyright 2015, Avionic Design <www.avionic-design.de> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <power/as3722.h> + +#include <asm/arch/gpio.h> +#include <asm/arch/pinmux.h> +#include "pinmux-config-meerkat.h" + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_set_tristate_input_clamping(); + + pinmux_config_pingrp_table(meerkat_pingrps, + ARRAY_SIZE(meerkat_pingrps)); + + pinmux_config_drvgrp_table(meerkat_drvgrps, + ARRAY_SIZE(meerkat_drvgrps)); +} + +#ifdef CONFIG_PCI_TEGRA +int tegra_pcie_board_init(void) +{ + struct udevice *pmic; + int err; + + err = as3722_init(&pmic, 4, 0x40); + if (err) { + error("failed to initialize AS3722 PMIC: %d\n", err); + return err; + } + + err = as3722_sd_enable(pmic, 4); + if (err < 0) { + error("failed to enable SD4: %d\n", err); + return err; + } + + err = as3722_sd_set_voltage(pmic, 4, 0x24); + if (err < 0) { + error("failed to set SD4 voltage: %d\n", err); + return err; + } + + return 0; +} +#endif /* PCI */ diff --git a/board/avionic-design/common/pinmux-config-meerkat.h b/board/avionic-design/common/pinmux-config-meerkat.h new file mode 100644 index 0000000..6be55fd --- /dev/null +++ b/board/avionic-design/common/pinmux-config-meerkat.h @@ -0,0 +1,233 @@ +/* + * Copyright (c) 2014, NVIDIA CORPORATION. All rights reserved. + * Copyright (c) 2015, Avionic Design GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _PINMUX_CONFIG_MEERKAT_H_ +#define _PINMUX_CONFIG_MEERKAT_H_ + +#define PINCFG(_pingrp, _mux, _pull, _tri, _io, _od, _rcv_sel) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .od = PMUX_PIN_OD_##_od, \ + .rcv_sel = PMUX_PIN_RCV_SEL_##_rcv_sel, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +static const struct pmux_pingrp_config meerkat_pingrps[] = { + /* pingrp, mux, pull, tri, e_input, od, rcv_sel */ + PINCFG(CLK_32K_OUT_PA0, SOC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_CTS_N_PA1, UARTC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_FS_PA2, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_SCLK_PA3, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DIN_PA4, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DOUT_PA5, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PB0, UARTD, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PB1, UARTD, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RTS_N_PC0, UARTC, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_TXD_PC2, IRDA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RXD_PC3, IRDA, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PC7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG2, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG3, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG4, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG5, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG6, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG7, SPI4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH0, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH1, PWM1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH4, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI1, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI3, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PJ2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART2_CTS_N_PJ5, UARTB, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ7, UARTD, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK0, SOC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_OUT_PK5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_IN_PK6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK7, UARTD, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_FS_PN0, I2S0, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DIN_PN1, I2S0, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DOUT_PN2, SATA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_SCLK_PN3, I2S0, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN0_PN4, USB, UP, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(USB_VBUS_EN1_PN5, USB, UP, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(HDMI_INT_PN7, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(ULPI_DATA7_PO0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA0_PO1, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA1_PO2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA2_PO3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA3_PO4, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA4_PO5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA5_PO6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA6_PO7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_FS_PP0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DIN_PP1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DOUT_PP2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_SCLK_PP3, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_FS_PP4, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DIN_PP5, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DOUT_PP6, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_SCLK_PP7, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL0_PQ0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL1_PQ1, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL2_PQ2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL3_PQ3, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL4_PQ4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL5_PQ5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL6_PQ6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL7_PQ7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW0_PR0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW1_PR1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW2_PR2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW3_PR3, SYS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW4_PR4, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW5_PR5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW6_PR6, DISPLAYA_ALT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW7_PR7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW8_PS0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW9_PS1, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW10_PS2, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW11_PS3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW12_PS4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW13_PS5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW14_PS6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW15_PS7, SOC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW16_PT0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW17_PT1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU1, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU2, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PV0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PV1, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CD_N_PV2, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_WP_N_PV3, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(GPIO_W2_AUD_PW2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_W3_AUD_PW3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_PW4, EXTPERIPH1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_OUT_PW5, EXTPERIPH2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RXD_PW7, UARTC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_PWM_PX0, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X1_AUD_PX1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_CLK_PX2, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X3_AUD_PX3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X4_AUD_PX4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X5_AUD_PX5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X6_AUD_PX6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X7_AUD_PX7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_CLK_PY0, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DIR_PY1, SPI1, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_NXT_PY2, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_STP_PY3, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT3_PY4, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT2_PY5, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT1_PY6, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT0_PY7, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CLK_PZ0, SDMMC1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CMD_PZ1, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PBB0, VIMCLK2_ALT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PBB3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB4, VGP4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_MCLK_PCC0, VI_ALT3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PCC1, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PCC2, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_REQ_PCC5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_RST_N_PDD1, PE0, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_CLKREQ_N_PDD2, PE0, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_WAKE_N_PDD3, PE, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_RST_N_PDD5, PE1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_CLKREQ_N_PDD6, PE1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_REQ_PEE1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_REQ_PEE2, SATA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC3_CLK_LB_OUT_PEE4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_LB_IN_PEE5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DP_HPD_PFF0, DP, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN2_PFF1, USB, UP, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PFF2, DEFAULT, UP, NORMAL, INPUT, DISABLE, DEFAULT), + PINCFG(CORE_PWR_REQ, PWRON, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CPU_PWR_REQ, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PWR_INT_N, PMI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(RESET_OUT_N, RESET_OUT_N, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(OWR, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, NORMAL), + PINCFG(CLK_32K_IN, RSVD2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(JTAG_RTCK, RTCK, UP, NORMAL, OUTPUT, DEFAULT, DEFAULT), +}; + +#define DRVCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ + { \ + .drvgrp = PMUX_DRVGRP_##_drvgrp, \ + .slwf = _slwf, \ + .slwr = _slwr, \ + .drvup = _drvup, \ + .drvdn = _drvdn, \ + .lpmd = PMUX_LPMD_##_lpmd, \ + .schmt = PMUX_SCHMT_##_schmt, \ + .hsm = PMUX_HSM_##_hsm, \ + } + +static const struct pmux_drvgrp_config meerkat_drvgrps[] = { +}; + +#endif /* PINMUX_CONFIG_MEERKAT_H */ diff --git a/board/avionic-design/kein-baseboard/Kconfig b/board/avionic-design/kein-baseboard/Kconfig new file mode 100644 index 0000000..a185a54 --- /dev/null +++ b/board/avionic-design/kein-baseboard/Kconfig @@ -0,0 +1,15 @@ +if TARGET_KEIN_BASEBOARD + +config SYS_BOARD + string + default "kein-baseboard" + +config SYS_VENDOR + string + default "avionic-design" + +config SYS_CONFIG_NAME + string + default "kein-baseboard" + +endif diff --git a/board/avionic-design/kein-baseboard/MAINTAINERS b/board/avionic-design/kein-baseboard/MAINTAINERS new file mode 100644 index 0000000..4fa20a9 --- /dev/null +++ b/board/avionic-design/kein-baseboard/MAINTAINERS @@ -0,0 +1,7 @@ +Kein Baseboard +M: Julian Scheel julian@jusst.de +M: Alban Bedel alban.bedel@avionic-design.de +S: Maintained +F: board/avionic-design/kein-baseboard +F: include/configs/kein-baseboard.h +F: configs/kein-baseboard_defconfig diff --git a/board/avionic-design/kein-baseboard/Makefile b/board/avionic-design/kein-baseboard/Makefile new file mode 100644 index 0000000..59760f6 --- /dev/null +++ b/board/avionic-design/kein-baseboard/Makefile @@ -0,0 +1,9 @@ +# +# (C) Copyright 2015 +# Avionic Design GmbH <www.avionic-design.de> +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += ../../nvidia/venice2/as3722_init.o +obj-y += ../common/meerkat.o diff --git a/configs/kein-baseboard_defconfig b/configs/kein-baseboard_defconfig new file mode 100644 index 0000000..8c9b422 --- /dev/null +++ b/configs/kein-baseboard_defconfig @@ -0,0 +1,21 @@ +CONFIG_ARM=y +CONFIG_TEGRA=y +CONFIG_SPL_DM=y +CONFIG_TEGRA124=y +CONFIG_TARGET_KEIN_BASEBOARD=y +CONFIG_DEFAULT_DEVICE_TREE="tegra124-kein-baseboard" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_SYS_PROMPT="Tegra124 (kein-baseboard) # " +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NFS is not set +CONFIG_PCI_TEGRA=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_GADGET=y +CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/include/configs/kein-baseboard.h b/include/configs/kein-baseboard.h new file mode 100644 index 0000000..16b8901 --- /dev/null +++ b/include/configs/kein-baseboard.h @@ -0,0 +1,71 @@ +/* + * (C) Copyright 2014-2016 Avionic Design GmbH + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +/* enable PMIC */ +#define CONFIG_AS3722_POWER + +#include "tegra124-common.h" + +/* High-level configuration options */ +#define CONFIG_TEGRA_BOARD_STRING "Avionic-Design Kein Baseboard" + +/* Board-specific serial config */ +#define CONFIG_TEGRA_ENABLE_UARTD +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE + +/* I2C */ +#define CONFIG_SYS_I2C_TEGRA +#define CONFIG_CMD_I2C + +/* SD/MMC */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_TEGRA_MMC +#define CONFIG_CMD_MMC +#define CONFIG_CMD_GPT +#define CONFIG_RANDOM_UUID + +/* Environment in eMMC, at the end of 2nd "boot sector" */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 2 + +/* USB Host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_USB + +/* USB networking support */ +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_RNDIS +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_MCS7830 +#define CONFIG_USB_ETHER_SMSC95XX + +/* PCI host support */ +#define CONFIG_PCI +#define CONFIG_PCI_PNP +#define CONFIG_CMD_PCI + +/* General networking support */ +#define CONFIG_CMD_DHCP + +#include "tegra-common-usb-gadget.h" +#include "tegra-common-post.h" + +#define CONFIG_ARMV7_PSCI 1 +/* Reserve top 1M for secure RAM */ +#define CONFIG_ARMV7_SECURE_BASE 0xfff00000 +#define CONFIG_ARMV7_SECURE_RESERVE_SIZE 0x00100000 + +#endif /* __CONFIG_H */
Julian Scheel
