[U-Boot] [PATCH 1/7][v3] powerpc/mpc85xx: Move LAW_EN define outside of config
LAW_EN is only defined if CONFIG_SYS_CCSRBAR_DEFAULT is not equal to CONFIG_SYS_CCSRBAR_PHYS. in SPL framework CCSRBAR is not relocated hence both are same. This cause compilation error.
So LAW_EN define outside of configs
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Changes for v2: Sending as it is Changes for v3: Sending as it is
arch/powerpc/cpu/mpc85xx/start.S | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index dbbd8e5..67e071b 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -26,6 +26,8 @@ #undef MSR_KERNEL #define MSR_KERNEL ( MSR_ME ) /* Machine Check */
+#define LAW_EN 0x80000000 + #if defined(CONFIG_NAND_SPL) || \ (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_INIT_MINIMAL)) #define MINIMAL_SPL @@ -574,7 +576,6 @@ infinite_debug_loop: #ifdef CONFIG_FSL_CORENET
#define CCSR_LAWBARH0 (CONFIG_SYS_CCSRBAR + 0x1000) -#define LAW_EN 0x80000000 #define LAW_SIZE_4K 0xb #define CCSRBAR_LAWAR (LAW_EN | (0x1e << 20) | LAW_SIZE_4K) #define CCSRAR_C 0x80000000 /* Commit */
Prabhakar Kushwaha
