[RESEND v2 0/1] Agilex5 enablement
V1: https://patchwork.ozlabs.org/project/uboot/patch/20240220143603.22091-1-jit.... V2: Fixed Git auto-merge causing misalignment of code and insert/delete
Jit Loon Lim (1): arch: arm: Agilex5 enablement
arch/arm/Kconfig | 4 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 71 ++ arch/arm/dts/socfpga_agilex5.dtsi | 575 ++++++++++++++ .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 134 ++++ arch/arm/dts/socfpga_agilex5_socdk.dts | 163 ++++ arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi | 38 +- arch/arm/mach-socfpga/Kconfig | 19 +- arch/arm/mach-socfpga/Makefile | 14 +- arch/arm/mach-socfpga/board.c | 56 +- arch/arm/mach-socfpga/clock_manager_agilex5.c | 89 +++ .../include/mach/base_addr_soc64.h | 38 +- .../mach-socfpga/include/mach/clock_manager.h | 4 +- .../include/mach/clock_manager_agilex5.h | 12 + .../mach-socfpga/include/mach/handoff_soc64.h | 31 +- .../mach-socfpga/include/mach/mailbox_s10.h | 1 + arch/arm/mach-socfpga/mmu-arm64_s10.c | 59 +- board/intel/agilex5-socdk/MAINTAINERS | 8 + configs/socfpga_agilex5_defconfig | 116 +++ drivers/clk/altera/Makefile | 1 + drivers/clk/altera/clk-agilex5.c | 743 ++++++++++++++++++ drivers/clk/altera/clk-agilex5.h | 284 +++++++ include/configs/socfpga_agilex5_socdk.h | 12 + include/configs/socfpga_soc64_common.h | 143 +++- include/dt-bindings/clock/agilex5-clock.h | 71 ++ include/dt-bindings/reset/altr,rst-mgr-agx5.h | 80 ++ 26 files changed, 2731 insertions(+), 36 deletions(-) create mode 100644 arch/arm/dts/socfpga_agilex5-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk.dts create mode 100644 arch/arm/mach-socfpga/clock_manager_agilex5.c create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_agilex5.h create mode 100644 board/intel/agilex5-socdk/MAINTAINERS create mode 100644 configs/socfpga_agilex5_defconfig create mode 100644 drivers/clk/altera/clk-agilex5.c create mode 100644 drivers/clk/altera/clk-agilex5.h create mode 100644 include/configs/socfpga_agilex5_socdk.h create mode 100644 include/dt-bindings/clock/agilex5-clock.h create mode 100644 include/dt-bindings/reset/altr,rst-mgr-agx5.h
This patch is to enable Agilex5 platform for Intel product. Changes, modification and new files are created for board, dts, configs and makefile to create the base for Agilex5.
Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com
--- Changes v1 -> v2: - fixed git auto merge issue --- arch/arm/Kconfig | 4 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 71 ++ arch/arm/dts/socfpga_agilex5.dtsi | 575 ++++++++++++++ .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 134 ++++ arch/arm/dts/socfpga_agilex5_socdk.dts | 163 ++++ arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi | 38 +- arch/arm/mach-socfpga/Kconfig | 19 +- arch/arm/mach-socfpga/Makefile | 14 +- arch/arm/mach-socfpga/board.c | 56 +- arch/arm/mach-socfpga/clock_manager_agilex5.c | 89 +++ .../include/mach/base_addr_soc64.h | 38 +- .../mach-socfpga/include/mach/clock_manager.h | 4 +- .../include/mach/clock_manager_agilex5.h | 12 + .../mach-socfpga/include/mach/handoff_soc64.h | 31 +- .../mach-socfpga/include/mach/mailbox_s10.h | 1 + arch/arm/mach-socfpga/mmu-arm64_s10.c | 59 +- board/intel/agilex5-socdk/MAINTAINERS | 8 + configs/socfpga_agilex5_defconfig | 116 +++ drivers/clk/altera/Makefile | 1 + drivers/clk/altera/clk-agilex5.c | 743 ++++++++++++++++++ drivers/clk/altera/clk-agilex5.h | 284 +++++++ include/configs/socfpga_agilex5_socdk.h | 12 + include/configs/socfpga_soc64_common.h | 143 +++- include/dt-bindings/clock/agilex5-clock.h | 71 ++ include/dt-bindings/reset/altr,rst-mgr-agx5.h | 80 ++ 26 files changed, 2731 insertions(+), 36 deletions(-) create mode 100644 arch/arm/dts/socfpga_agilex5-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk.dts create mode 100644 arch/arm/mach-socfpga/clock_manager_agilex5.c create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_agilex5.h create mode 100644 board/intel/agilex5-socdk/MAINTAINERS create mode 100644 configs/socfpga_agilex5_defconfig create mode 100644 drivers/clk/altera/clk-agilex5.c create mode 100644 drivers/clk/altera/clk-agilex5.h create mode 100644 include/configs/socfpga_agilex5_socdk.h create mode 100644 include/dt-bindings/clock/agilex5-clock.h create mode 100644 include/dt-bindings/reset/altr,rst-mgr-agx5.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index fde85dc0d5..6df805f44c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -28,6 +28,7 @@ config COUNTER_FREQUENCY ROCKCHIP_RK3288 || ROCKCHIP_RK322X || ROCKCHIP_RK3036 default 25000000 if ARCH_LX2160A || ARCH_LX2162A || ARCH_LS1088A default 100000000 if ARCH_ZYNQMP + default 200000000 if ARCH_SOCFPGA && ARM64 && TARGET_SOCFPGA_AGILEX5 default 0 help For platforms with ARMv8-A and ARMv7-A which features a system @@ -1124,7 +1125,8 @@ config ARCH_SOCFPGA select SYS_THUMB_BUILD if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select SYSRESET select SYSRESET_SOCFPGA if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 - select SYSRESET_SOCFPGA_SOC64 if TARGET_SOCFPGA_SOC64 + select SYSRESET_SOCFPGA_SOC64 if !TARGET_SOCFPGA_AGILEX5 && \ + TARGET_SOCFPGA_SOC64 imply CMD_DM imply CMD_MTDPARTS imply CRC32_VERIFY diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d9725030d5..2b4f896ad2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -548,6 +548,7 @@ dtb-$(CONFIG_TARGET_THUNDERX_88XX) += thunderx-88xx.dtb
dtb-$(CONFIG_ARCH_SOCFPGA) += \ socfpga_agilex_socdk.dtb \ + socfpga_agilex5_socdk.dtb \ socfpga_arria5_secu1.dtb \ socfpga_arria5_socdk.dtb \ socfpga_arria10_chameleonv3_270_2.dtb \ diff --git a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi new file mode 100644 index 0000000000..a8167e5c14 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * U-Boot additions + * + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#include "socfpga_soc64_fit-u-boot.dtsi" + +/{ + memory { + #address-cells = <2>; + #size-cells = <2>; + bootph-all; + }; +}; + +&clkmgr { + bootph-all; +}; + +&i2c0 { + reset-names = "i2c"; +}; + +&i2c1 { + reset-names = "i2c"; +}; + +&i2c2 { + reset-names = "i2c"; +}; + +&i2c3 { + reset-names = "i2c"; +}; + +&mmc { + resets = <&rst SDMMC_RESET>, <&rst SDMMC_OCP_RESET>; +}; + +&porta { + bank-name = "porta"; +}; + +&portb { + bank-name = "portb"; +}; + +&qspi { + bootph-all; +}; + +&rst { + compatible = "altr,rst-mgr"; + altr,modrst-offset = <0x24>; + bootph-all; +}; + +&sysmgr { + compatible = "altr,sys-mgr", "syscon"; + bootph-all; +}; + +&uart0 { + bootph-all; +}; + +&watchdog0 { + bootph-all; +}; diff --git a/arch/arm/dts/socfpga_agilex5.dtsi b/arch/arm/dts/socfpga_agilex5.dtsi new file mode 100644 index 0000000000..03b5504049 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5.dtsi @@ -0,0 +1,575 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +/dts-v1/; +#include <dt-bindings/reset/altr,rst-mgr-agx5.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/agilex5-clock.h> + +/ { + compatible = "intel,socfpga-agilex"; + #address-cells = <2>; + #size-cells = <2>; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + service_reserved: svcbuffer@0 { + compatible = "shared-dma-pool"; + reg = <0x0 0x0 0x0 0x1000000>; + alignment = <0x1000>; + no-map; + }; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@0 { + compatible = "arm,cortex-a55"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x0>; + }; + + cpu1: cpu@1 { + compatible = "arm,cortex-a55"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x1>; + }; + + cpu2: cpu@2 { + compatible = "arm,cortex-a76"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x2>; + }; + + cpu3: cpu@3 { + compatible = "arm,cortex-a76"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x3>; + }; + }; + + pmu { + compatible = "arm,armv8-pmuv3"; + interrupts = <0 170 4>, + <0 171 4>, + <0 172 4>, + <0 173 4>; + interrupt-affinity = <&cpu0>, + <&cpu1>, + <&cpu2>, + <&cpu3>; + interrupt-parent = <&intc>; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + intc: intc@fffc1000 { + compatible = "arm,gic-400", "arm,cortex-a15-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x0 0x1d000000 0x0 0x10000>; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + device_type = "soc"; + interrupt-parent = <&intc>; + ranges = <0 0 0 0xffffffff>; + + base_fpga_region { + #address-cells = <0x1>; + #size-cells = <0x1>; + compatible = "fpga-region"; + fpga-mgr = <&fpga_mgr>; + }; + + clkmgr: clock-controller@10d10000 { + compatible = "intel,agilex5-clkmgr"; + reg = <0x10d10000 0x1000>; + #clock-cells = <1>; + }; + + clocks { + cb_intosc_hs_div2_clk: cb-intosc-hs-div2-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + cb_intosc_ls_clk: cb-intosc-ls-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + f2s_free_clk: f2s-free-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + osc1: osc1 { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + qspi_clk: qspi-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <200000000>; + }; + }; + gmac0: ethernet@10810000 { + compatible = "intel,socfpga-dwxgmac", "snps,dwxgmac-2.10", "snps,dwxgmac"; + reg = <0x10810000 0x3500>; + interrupts = <0 190 4>; + interrupt-names = "macirq"; + mac-address = [00 00 00 00 00 00]; + resets = <&rst EMAC0_RESET>, <&rst EMAC0_OCP_RESET>; + reset-names = "stmmaceth", "stmmaceth-ocp"; + tx-fifo-depth = <32768>; + rx-fifo-depth = <16384>; + iommus = <&smmu 1>; + altr,sysmgr-syscon = <&sysmgr 0x44 0>; + clocks = <&clkmgr AGILEX5_EMAC0_CLK>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gmac1: ethernet@10820000 { + compatible = "intel,socfpga-dwxgmac", "snps,dwxgmac-2.10", "snps,dwxgmac"; + reg = <0x10820000 0x3500>; + interrupts = <0 207 4>; + interrupt-names = "macirq"; + mac-address = [00 00 00 00 00 00]; + resets = <&rst EMAC1_RESET>, <&rst EMAC1_OCP_RESET>; + reset-names = "stmmaceth", "stmmaceth-ocp"; + tx-fifo-depth = <32768>; + rx-fifo-depth = <16384>; + iommus = <&smmu 2>; + altr,sysmgr-syscon = <&sysmgr 0x48 0>; + clocks = <&clkmgr AGILEX5_EMAC1_CLK>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gmac2: ethernet@10830000 { + compatible = "intel,socfpga-dwxgmac", "snps,dwxgmac-2.10", "snps,dwxgmac"; + reg = <0x10830000 0x3500>; + interrupts = <0 224 4>; + interrupt-names = "macirq"; + mac-address = [00 00 00 00 00 00]; + resets = <&rst EMAC2_RESET>, <&rst EMAC2_OCP_RESET>; + reset-names = "stmmaceth", "stmmaceth-ocp"; + tx-fifo-depth = <32768>; + rx-fifo-depth = <16384>; + iommus = <&smmu 3>; + altr,sysmgr-syscon = <&sysmgr 0x4c 0>; + clocks = <&clkmgr AGILEX5_EMAC2_CLK>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gpio0: gpio@10c03200 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0x10c03200 0x80>; + resets = <&rst GPIO0_RESET>; + status = "disabled"; + + porta: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <24>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 110 4>; + }; + }; + + gpio1: gpio@10c03300 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0x10c03300 0x80>; + resets = <&rst GPIO1_RESET>; + status = "disabled"; + + portb: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <24>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 111 4>; + }; + }; + + i2c0: i2c@10c02800 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0x10c02800 0x100>; + interrupts = <0 103 4>; + resets = <&rst I2C0_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + i2c1: i2c@10c02900 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0x10c02900 0x100>; + interrupts = <0 104 4>; + resets = <&rst I2C1_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + i2c2: i2c@10c02a00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0x10c02a00 0x100>; + interrupts = <0 105 4>; + resets = <&rst I2C2_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + i2c3: i2c@10c02b00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0x10c02b00 0x100>; + interrupts = <0 106 4>; + resets = <&rst I2C3_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + i2c4: i2c@10c02c00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0x10c02c00 0x100>; + interrupts = <0 107 4>; + resets = <&rst I2C4_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + i3c0: i3c@10da0000 { + compatible = "snps,dw-i3c-master-1.00a"; + reg = <0x10da0000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 164 4>; + resets = <&rst I3C0_RESET>; + max_devices = <11>; + clocks = <&clkmgr AGILEX5_L4_MP_CLK>; + status = "disabled"; + }; + + i3c1: i3c@10da1000 { + compatible = "snps,dw-i3c-master-1.00a"; + reg = <0x10da1000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 165 4>; + resets = <&rst I3C1_RESET>; + clocks = <&clkmgr AGILEX5_L4_MP_CLK>; + max_devices = <11>; + status = "disabled"; + }; + + combophy0: combophy@0 { + #phy-cells = <0>; + phy-type = <1>; + compatible = "cdns,combophy"; + reg = <0x10808000 0x1000>; + resets = <&rst COMBOPHY_RESET>; + reset-names = "reset"; + status = "disabled"; + }; + + mmc: mmc0@10808000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "cdns,sd4hc"; + reg = <0x10808000 0x1000>; + interrupts = <0 96 4>; + phys = <&combophy0>; + phy-names = "combo-phy"; + clocks = <&clkmgr AGILEX5_L4_MP_CLK>, + <&clkmgr AGILEX5_SDMMC_CLK>; + clock-names = "biu", "ciu"; + fifo-depth = <0x800>; + resets = <&rst SDMMC_RESET>; + reset-names = "reset"; + iommus = <&smmu 5>; + status = "disabled"; + }; + + ocram: sram@00000000 { + compatible = "mmio-sram"; + reg = <0x00000000 0x200000>; + }; + + rst: rstmgr@10d11000 { + #reset-cells = <1>; + compatible = "altr,stratix10-rst-mgr"; + reg = <0x10d11000 0x1000>; + }; + + smmu: iommu@16000000 { + compatible = "arm,mmu-500", "arm,smmu-v2"; + reg = <0x16000000 0x40000>; + #global-interrupts = <2>; + #iommu-cells = <1>; + interrupt-parent = <&intc>; + interrupts = <0 128 4>, /* Global Secure Fault */ + <0 129 4>, /* Global Non-secure Fault */ + /* Non-secure Context Interrupts (32) */ + <0 138 4>, <0 139 4>, <0 140 4>, <0 141 4>, + <0 142 4>, <0 143 4>, <0 144 4>, <0 145 4>, + <0 146 4>, <0 147 4>, <0 148 4>, <0 149 4>, + <0 150 4>, <0 151 4>, <0 152 4>, <0 153 4>, + <0 154 4>, <0 155 4>, <0 156 4>, <0 157 4>, + <0 158 4>, <0 159 4>, <0 160 4>, <0 161 4>, + <0 162 4>, <0 163 4>, <0 164 4>, <0 165 4>, + <0 166 4>, <0 167 4>, <0 168 4>, <0 169 4>; + stream-match-mask = <0x7ff0>; + status = "disabled"; + }; + + spi0: spi@10da4000 { + compatible = "intel,agilex-spi", + "snps,dw-apb-ssi-4.00a", "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x10da4000 0x1000>; + interrupts = <0 99 4>; + resets = <&rst SPIM0_RESET>; + reg-io-width = <4>; + num-cs = <4>; + clocks = <&clkmgr AGILEX5_L4_MAIN_CLK>; + status = "disabled"; + }; + + spi1: spi@10da5000 { + compatible = "intel,agilex-spi", + "snps,dw-apb-ssi-4.00a", "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x10da5000 0x1000>; + interrupts = <0 100 4>; + resets = <&rst SPIM1_RESET>; + reg-io-width = <4>; + num-cs = <4>; + clocks = <&clkmgr AGILEX5_L4_MAIN_CLK>; + status = "disabled"; + }; + + sysmgr: sysmgr@10d12000 { + compatible = "altr,sys-mgr-s10","altr,sys-mgr"; + reg = <0x10d12000 0x500>; + }; + + /* Local timer */ + timer { + compatible = "arm,armv8-timer"; + interrupts = <1 13 0xf08>, + <1 14 0xf08>, + <1 11 0xf08>, + <1 10 0xf08>; + }; + + timer0: timer0@10c03000 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 113 4>; + reg = <0x10c03000 0x100>; + resets = <&rst SPTIMER0_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + clock-names = "timer"; + status = "disabled"; + }; + + timer1: timer1@10c03100 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 114 4>; + reg = <0x10c03100 0x100>; + resets = <&rst SPTIMER1_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + clock-names = "timer"; + status = "disabled"; + }; + + timer2: timer2@10d00000 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 115 4>; + reg = <0x10d00000 0x100>; + resets = <&rst L4SYSTIMER0_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + clock-names = "timer"; + status = "disabled"; + }; + + timer3: timer3@10d00100 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 116 4>; + reg = <0x10d00100 0x100>; + resets = <&rst L4SYSTIMER1_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + clock-names = "timer"; + status = "disabled"; + }; + + uart0: serial0@10c02000 { + compatible = "snps,dw-apb-uart"; + reg = <0x10c02000 0x100>; + interrupts = <0 108 4>; + reg-shift = <2>; + reg-io-width = <4>; + resets = <&rst UART0_RESET>; + status = "disabled"; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + clock-frequency = <100000000>; + }; + + uart1: serial1@10c02100 { + compatible = "snps,dw-apb-uart"; + reg = <0x10c02100 0x100>; + interrupts = <0 109 4>; + reg-shift = <2>; + reg-io-width = <4>; + resets = <&rst UART1_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + usbphy0: usbphy@0 { + #phy-cells = <0>; + compatible = "usb-nop-xceiv"; + clocks = <&clkmgr AGILEX5_USB_CLK>; + status = "disabled"; + }; + + usb0: usb@10b00000 { + compatible = "snps,dwc2"; + reg = <0x10b00000 0x40000>; + interrupts = <0 93 4>; + phys = <&usbphy0>; + phy-names = "usb2-phy"; + resets = <&rst USB0_RESET>, <&rst USB0_OCP_RESET>; + reset-names = "dwc2", "dwc2-ecc"; + clocks = <&clkmgr AGILEX5_USB_CLK>; + iommus = <&smmu 6>; + status = "disabled"; + }; + + usb31: usb31@11000000 { + compatible = "snps,dwc3"; + reg = <0x11000000 0x100000>; + resets = <&rst USB1_RESET>; + phys = <&usbphy0>, <&usbphy0>; + phy-names = "usb2-phy", "usb3-phy"; + dr_mode = "host"; + maximum-speed = "super-speed"; + snps,dis_u2_susphy_quirk; + status = "disabled"; + }; + + watchdog0: watchdog@10d00200 { + compatible = "snps,dw-wdt"; + reg = <0x10d00200 0x100>; + interrupts = <0 117 4>; + resets = <&rst WATCHDOG0_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + watchdog1: watchdog@10d00300 { + compatible = "snps,dw-wdt"; + reg = <0x10d00300 0x100>; + interrupts = <0 118 4>; + resets = <&rst WATCHDOG1_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + watchdog2: watchdog@10d00400 { + compatible = "snps,dw-wdt"; + reg = <0x10d00400 0x100>; + interrupts = <0 125 4>; + resets = <&rst WATCHDOG2_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + watchdog3: watchdog@10d00500 { + compatible = "snps,dw-wdt"; + reg = <0x10d00500 0x100>; + interrupts = <0 126 4>; + resets = <&rst WATCHDOG3_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + watchdog4: watchdog@10d00600 { + compatible = "snps,dw-wdt"; + reg = <0x10d00600 0x100>; + interrupts = <0 175 4>; + resets = <&rst WATCHDOG4_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + /* QSPI address not available yet */ + qspi: spi@108d2000 { + compatible = "cdns,qspi-nor"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x108d2000 0x100>, + <0x10900000 0x100000>; + interrupts = <0 3 4>; + cdns,fifo-depth = <128>; + cdns,fifo-width = <4>; + cdns,trigger-address = <0x00000000>; + clocks = <&qspi_clk>; + + status = "disabled"; + }; + + firmware { + svc { + compatible = "intel,stratix10-svc"; + method = "smc"; + memory-region = <&service_reserved>; + + fpga_mgr: fpga-mgr { + compatible = "intel,stratix10-soc-fpga-mgr"; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi new file mode 100644 index 0000000000..fb86b1d9d7 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi @@ -0,0 +1,134 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * U-Boot additions + * + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#include "socfpga_agilex5-u-boot.dtsi" + +/{ + aliases { + spi0 = &qspi; + freeze_br0 = &freeze_controller; + }; + + soc { + freeze_controller: freeze_controller@0x20000450 { + compatible = "altr,freeze-bridge-controller"; + reg = <0x20000450 0x00000010>; + status = "disabled"; + }; + }; + + memory { + /* 8GB */ + reg = <0 0x80000000 0 0x80000000>, + <8 0x80000000 1 0x80000000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + u-boot,spl-boot-order = &mmc,&flash0,"/memory"; + }; +}; + +&flash0 { + compatible = "jedec,spi-nor"; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + bootph-all; + /delete-property/ cdns,read-delay; +}; + +&i3c0 { + bootph-all; +}; + +&i3c1 { + bootph-all; +}; + +&mmc { + status = "okay"; + bus-width = <4>; + sd-uhs-sdr50; + cap-mmc-highspeed; + bootph-all; +}; + +&combophy0 { + status = "okay"; + bootph-all; + cdns,phy-use-ext-lpbk-dqs = <1>; + cdns,phy-use-lpbk-dqs = <1>; + cdns,phy-use-phony-dqs = <1>; + cdns,phy-use-phony-dqs-cmd = <1>; + cdns,phy-io-mask-always-on = <0>; + cdns,phy-io-mask-end = <5>; + cdns,phy-io-mask-start = <0>; + cdns,phy-data-select-oe-end = <1>; + cdns,phy-sync-method = <1>; + cdns,phy-sw-half-cycle-shift = <0>; + cdns,phy-rd-del-sel = <52>; + cdns,phy-underrun-suppress = <1>; + cdns,phy-gate-cfg-always-on = <1>; + cdns,phy-param-dll-bypass-mode = <1>; + cdns,phy-param-phase-detect-sel = <2>; + cdns,phy-param-dll-start-point = <254>; + cdns,phy-read-dqs-cmd-delay = <0>; + cdns,phy-clk-wrdqs-delay = <0>; + cdns,phy-clk-wr-delay = <0>; + cdns,phy-read-dqs-delay = <0>; + cdns,phy-phony-dqs-timing = <0>; + cdns,hrs09-rddata-en = <1>; + cdns,hrs09-rdcmd-en = <1>; + cdns,hrs09-extended-wr-mode = <1>; + cdns,hrs09-extended-rd-mode = <1>; + cdns,hrs10-hcsdclkadj = <3>; + cdns,hrs16-wrdata1-sdclk-dly = <0>; + cdns,hrs16-wrdata0-sdclk-dly = <0>; + cdns,hrs16-wrcmd1-sdclk-dly = <0>; + cdns,hrs16-wrcmd0-sdclk-dly = <0>; + cdns,hrs16-wrdata1-dly = <0>; + cdns,hrs16-wrdata0-dly = <0>; + cdns,hrs16-wrcmd1-dly = <0>; + cdns,hrs16-wrcmd0-dly = <0>; + cdns,hrs07-rw-compensate = <10>; + cdns,hrs07-idelay-val = <0>; +}; + +&qspi { + status = "okay"; +}; + +&timer0 { + bootph-all; +}; + +&timer1 { + bootph-all; +}; + +&timer2 { + bootph-all; +}; + +&timer3 { + bootph-all; +}; + +&watchdog0 { + bootph-all; +}; + +#if !defined(CONFIG_SOCFPGA_SECURE_VAB_AUTH) +&fdt_0_blob { + filename = "arch/arm/dts/socfpga_agilex5_socdk.dtb"; +}; + +&binman { + /delete-node/ kernel; +}; +#endif + diff --git a/arch/arm/dts/socfpga_agilex5_socdk.dts b/arch/arm/dts/socfpga_agilex5_socdk.dts new file mode 100644 index 0000000000..852e1e5ae3 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5_socdk.dts @@ -0,0 +1,163 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ +#include "socfpga_agilex5.dtsi" + +/ { + model = "SoCFPGA Agilex5 SoCDK"; + + aliases { + serial0 = &uart0; + ethernet0 = &gmac0; + ethernet2 = &gmac2; + }; + + leds { + compatible = "gpio-leds"; + hps0 { + label = "hps_led0"; + gpios = <&portb 20 GPIO_ACTIVE_HIGH>; + }; + + hps1 { + label = "hps_led1"; + gpios = <&portb 19 GPIO_ACTIVE_HIGH>; + }; + + hps2 { + label = "hps_led2"; + gpios = <&portb 21 GPIO_ACTIVE_HIGH>; + }; + }; + + memory { + device_type = "memory"; + /* We expect the bootloader to fill in the reg */ + reg = <0 0 0 0>; + }; + + soc { + clocks { + osc1 { + clock-frequency = <25000000>; + }; + }; + }; +}; + +&gpio0 { + status = "okay"; +}; + +&gpio1 { + status = "okay"; +}; + +&i2c0 { + status = "okay"; +}; + +&i2c1 { + status = "okay"; +}; + +&i3c0 { + status = "okay"; +}; + +&i3c1 { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&usbphy0 { + status = "okay"; +}; + +&usb0 { + status = "okay"; + disable-over-current; +}; + +&watchdog0 { + status = "okay"; +}; + +&watchdog1 { + status = "okay"; +}; + +&watchdog2 { + status = "okay"; +}; + +&watchdog3 { + status = "okay"; +}; + +&watchdog4 { + status = "okay"; +}; + +&timer0 { + status = "okay"; +}; + +&timer1 { + status = "okay"; +}; + +&timer2 { + status = "okay"; +}; + +&timer3 { + status = "okay"; +}; + +&spi0 { + status = "okay"; +}; + +&spi1 { + status = "okay"; +}; + +&qspi { + flash0: flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mt25qu02g"; + reg = <0>; + spi-max-frequency = <100000000>; + + m25p,fast-read; + cdns,page-size = <256>; + cdns,block-size = <16>; + cdns,read-delay = <1>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + qspi_boot: partition@0 { + label = "u-boot"; + reg = <0x0 0x04200000>; + }; + + root: partition@4200000 { + label = "root"; + reg = <0x04200000 0x0BE00000>; + }; + }; + }; +}; diff --git a/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi b/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi index 84b91e8df0..15306db600 100644 --- a/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi +++ b/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi @@ -2,7 +2,7 @@ /* * U-Boot additions * - * Copyright (C) 2020 Intel Corporation <www.intel.com> + * Copyright (C) 2020-2024 Intel Corporation <www.intel.com> */
#if defined(CONFIG_FIT) @@ -21,14 +21,18 @@ description = "FIT with firmware and bootloader"; #address-cells = <1>;
- images { + images: images { uboot { description = "U-Boot SoC64"; type = "standalone"; os = "U-Boot"; arch = "arm64"; compression = "none"; + #if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) + load = <0x80200000>; + #else load = <0x00200000>; + #endif uboot_blob: blob-ext { filename = "u-boot-nodtb.bin"; }; @@ -43,8 +47,13 @@ os = "arm-trusted-firmware"; arch = "arm64"; compression = "none"; + #if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) + load = <0x80000000>; + entry = <0x80000000>; + #else load = <0x00001000>; entry = <0x00001000>; + #endif atf_blob: blob-ext { filename = "bl31.bin"; }; @@ -53,11 +62,11 @@ }; };
- fdt { - description = "U-Boot SoC64 flat device-tree"; + fdt-0 { + description = "socfpga_socdk"; type = "flat_dt"; compression = "none"; - uboot_fdt_blob: blob-ext { + fdt_0_blob: blob-ext { filename = "u-boot.dtb"; }; hash { @@ -66,17 +75,18 @@ }; };
- configurations { - default = "conf"; - conf { - description = "Intel SoC64 FPGA"; + board_config: configurations { + default = "board-0"; + + board-0 { + description = "board_0"; firmware = "atf"; loadables = "uboot"; - fdt = "fdt"; + fdt = "fdt-0"; signature { algo = "crc32"; key-name-hint = "dev"; - sign-images = "atf", "fdt", "uboot"; + sign-images = "atf", "uboot", "fdt-0"; }; }; }; @@ -96,8 +106,8 @@ arch = "arm64"; os = "linux"; compression = "none"; - load = <0x4080000>; - entry = <0x4080000>; + load = <0x6000000>; + entry = <0x6000000>; kernel_blob: blob-ext { filename = "Image"; }; @@ -146,7 +156,7 @@ filename = "signed-bl31.bin"; };
-&uboot_fdt_blob { +&fdt_0_blob { filename = "signed-u-boot.dtb"; };
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 114d243812..1008232cac 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -8,7 +8,8 @@ config NR_DRAM_BANKS
config SOCFPGA_SECURE_VAB_AUTH bool "Enable boot image authentication with Secure Device Manager" - depends on TARGET_SOCFPGA_AGILEX || TARGET_SOCFPGA_N5X + depends on TARGET_SOCFPGA_AGILEX || TARGET_SOCFPGA_N5X || \ + TARGET_SOCFPGA_AGILEX5 select FIT_IMAGE_POST_PROCESS select SHA384 select SHA512 @@ -58,6 +59,15 @@ config TARGET_SOCFPGA_AGILEX select SPL_CLK if SPL select TARGET_SOCFPGA_SOC64
+config TARGET_SOCFPGA_AGILEX5 + bool + select BINMAN if SPL_ATF + select CLK + select FPGA_INTEL_SDM_MAILBOX + select GICV3 + select SPL_CLK if SPL + select TARGET_SOCFPGA_SOC64 + config TARGET_SOCFPGA_ARRIA5 bool select TARGET_SOCFPGA_GEN5 @@ -129,6 +139,10 @@ config TARGET_SOCFPGA_AGILEX_SOCDK bool "Intel SOCFPGA SoCDK (Agilex)" select TARGET_SOCFPGA_AGILEX
+config TARGET_SOCFPGA_AGILEX5_SOCDK + bool "Intel SOCFPGA SoCDK (Agilex5)" + select TARGET_SOCFPGA_AGILEX5 + config TARGET_SOCFPGA_ARIES_MCVEVK bool "Aries MCVEVK (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5 @@ -202,6 +216,7 @@ config TARGET_SOCFPGA_TERASIC_SOCKIT endchoice
config SYS_BOARD + default "agilex5-socdk" if TARGET_SOCFPGA_AGILEX5_SOCDK default "agilex-socdk" if TARGET_SOCFPGA_AGILEX_SOCDK default "arria5-socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK default "arria10-socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK @@ -223,6 +238,7 @@ config SYS_BOARD default "vining_fpga" if TARGET_SOCFPGA_SOFTING_VINING_FPGA
config SYS_VENDOR + default "intel" if TARGET_SOCFPGA_AGILEX5_SOCDK default "intel" if TARGET_SOCFPGA_AGILEX_SOCDK default "intel" if TARGET_SOCFPGA_N5X_SOCDK default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK @@ -245,6 +261,7 @@ config SYS_SOC default "socfpga"
config SYS_CONFIG_NAME + default "socfpga_agilex5_socdk" if TARGET_SOCFPGA_AGILEX5_SOCDK default "socfpga_agilex_socdk" if TARGET_SOCFPGA_AGILEX_SOCDK default "socfpga_arria5_secu1" if TARGET_SOCFPGA_ARRIA5_SECU1 default "socfpga_arria5_socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index ec38b64dd4..67c6a8dfec 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -4,7 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # Copyright (C) 2012-2017 Altera Corporation <www.altera.com> -# Copyright (C) 2017-2021 Intel Corporation <www.intel.com> +# Copyright (C) 2017-2024 Intel Corporation <www.intel.com>
obj-y += board.o obj-y += clock_manager.o @@ -56,6 +56,15 @@ obj-y += wrap_handoff_soc64.o obj-y += wrap_pll_config_soc64.o endif
+ifdef CONFIG_TARGET_SOCFPGA_AGILEX5 +obj-y += clock_manager_agilex5.o +obj-y += mailbox_s10.o +obj-y += misc_soc64.o +obj-y += mmu-arm64_s10.o +obj-y += reset_manager_s10.o +obj-y += wrap_pll_config_soc64.o +endif + ifdef CONFIG_TARGET_SOCFPGA_N5X obj-y += clock_manager_n5x.o obj-y += lowlevel_init_soc64.o @@ -95,6 +104,9 @@ endif ifdef CONFIG_TARGET_SOCFPGA_N5X obj-y += spl_n5x.o endif +ifdef CONFIG_TARGET_SOCFPGA_AGILEX5 +obj-y += spl_soc64.o +endif else obj-$(CONFIG_SPL_ATF) += secure_reg_helper.o obj-$(CONFIG_SPL_ATF) += smc_api.o diff --git a/arch/arm/mach-socfpga/board.c b/arch/arm/mach-socfpga/board.c index 09e09192fb..616e1afe5d 100644 --- a/arch/arm/mach-socfpga/board.c +++ b/arch/arm/mach-socfpga/board.c @@ -7,9 +7,11 @@
#include <common.h> #include <asm/arch/clock_manager.h> +#include <asm/arch/mailbox_s10.h> #include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/secure_vab.h> +#include <asm/arch/smc_api.h> #include <asm/global_data.h> #include <asm/io.h> #include <errno.h> @@ -23,6 +25,8 @@
DECLARE_GLOBAL_DATA_PTR;
+#define DEFAULT_JTAG_USERCODE 0xFFFFFFFF + void s_init(void) { #ifndef CONFIG_ARM64 /* @@ -92,13 +96,50 @@ int g_dnl_board_usb_cable_connected(void) } #endif
-#ifdef CONFIG_SPL_BUILD -__weak int board_fit_config_name_match(const char *name) +u8 socfpga_get_board_id(void) { - /* Just empty function now - can't decide what to choose */ - debug("%s: %s\n", __func__, name); + u8 board_id = 0; + u32 jtag_usercode; + int err;
- return 0; +#if !IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_SPL_ATF) + err = smc_get_usercode(&jtag_usercode); +#else + u32 resp_len = 1; + + err = mbox_send_cmd(MBOX_ID_UBOOT, MBOX_GET_USERCODE, MBOX_CMD_DIRECT, 0, + NULL, 0, &resp_len, &jtag_usercode); +#endif + + if (err) { + puts("Fail to read JTAG Usercode. Default Board ID to 0\n"); + return board_id; + } + + debug("Valid JTAG Usercode: %u\n", jtag_usercode); + + if (jtag_usercode == DEFAULT_JTAG_USERCODE) { + debug("JTAG Usercode is not set. Default Board ID to 0\n"); + } else if (jtag_usercode >= 0 && jtag_usercode <= 255) { + board_id = jtag_usercode; + debug("Valid JTAG Usercode. Set Board ID to %u\n", board_id); + } else { + puts("Board ID is not in range 0 to 255\n"); + } + + return board_id; +} + +#if IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_TARGET_SOCFPGA_SOC64) +int board_fit_config_name_match(const char *name) +{ + char board_name[10]; + + sprintf(board_name, "board_%u", socfpga_get_board_id()); + + debug("Board name: %s\n", board_name); + + return strcmp(name, board_name); } #endif
@@ -116,6 +157,8 @@ void board_fit_image_post_process(const void *fit, int node, void **p_image, #if !IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_FIT) void board_prep_linux(struct bootm_headers *images) { + bool use_fit = false; + if (!images->fit_uname_cfg) { if (IS_ENABLED(CONFIG_SOCFPGA_SECURE_VAB_AUTH) && !IS_ENABLED(CONFIG_SOCFPGA_SECURE_VAB_AUTH_ALLOW_NON_FIT_IMAGE)) { @@ -127,12 +170,13 @@ void board_prep_linux(struct bootm_headers *images) hang(); } } else { + use_fit = true; /* Update fdt_addr in enviroment variable */ env_set_hex("fdt_addr", (ulong)images->ft_addr); debug("images->ft_addr = 0x%08lx\n", (ulong)images->ft_addr); }
- if (IS_ENABLED(CONFIG_CADENCE_QSPI)) { + if (use_fit && IS_ENABLED(CONFIG_CADENCE_QSPI)) { if (env_get("linux_qspi_enable")) run_command(env_get("linux_qspi_enable"), 0); } diff --git a/arch/arm/mach-socfpga/clock_manager_agilex5.c b/arch/arm/mach-socfpga/clock_manager_agilex5.c new file mode 100644 index 0000000000..b92f0b3af8 --- /dev/null +++ b/arch/arm/mach-socfpga/clock_manager_agilex5.c @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + * + */ + +#include <clk.h> +#include <config.h> +#include <dm.h> +#include <errno.h> +#include <log.h> +#include <malloc.h> +#include <stdarg.h> +#include <stdio.h> +#include <time.h> +#include <vsprintf.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/u-boot.h> +#include <linux/kernel.h> +#include <linux/string.h> +#include <linux/types.h> +#include <asm/arch/clock_manager.h> +#include <asm/arch/system_manager.h> +#include <dt-bindings/clock/agilex5-clock.h> + +DECLARE_GLOBAL_DATA_PTR; + +static ulong cm_get_rate_dm(u32 id) +{ + struct udevice *dev; + struct clk clk; + ulong rate; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_CLK, + DM_DRIVER_GET(socfpga_agilex5_clk), + &dev); + if (ret) + return 0; + + clk.id = id; + ret = clk_request(dev, &clk); + if (ret < 0) + return 0; + + rate = clk_get_rate(&clk); + + if ((rate == (unsigned long)-ENOSYS) || + (rate == (unsigned long)-ENXIO) || + (rate == (unsigned long)-EIO)) { + debug("%s id %u: clk_get_rate err: %ld\n", + __func__, id, rate); + return 0; + } + + return rate; +} + +static u32 cm_get_rate_dm_khz(u32 id) +{ + return cm_get_rate_dm(id) / 1000; +} + +unsigned long cm_get_mpu_clk_hz(void) +{ + return cm_get_rate_dm(AGILEX5_MPU_CLK); +} + +unsigned int cm_get_l4_sys_free_clk_hz(void) +{ + return cm_get_rate_dm(AGILEX5_L4_SYS_FREE_CLK); +} + +void cm_print_clock_quick_summary(void) +{ + printf("MPU %10d kHz\n", + cm_get_rate_dm_khz(AGILEX5_MPU_CLK)); + printf("L4 Main %8d kHz\n", + cm_get_rate_dm_khz(AGILEX5_L4_MAIN_CLK)); + printf("L4 sys free %8d kHz\n", + cm_get_rate_dm_khz(AGILEX5_L4_SYS_FREE_CLK)); + printf("L4 MP %8d kHz\n", + cm_get_rate_dm_khz(AGILEX5_L4_MP_CLK)); + printf("L4 SP %8d kHz\n", + cm_get_rate_dm_khz(AGILEX5_L4_SP_CLK)); + printf("SDMMC %8d kHz\n", + cm_get_rate_dm_khz(AGILEX5_SDMMC_CLK)); +} diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h index 3f899fcfa3..65721098b2 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h @@ -1,11 +1,46 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * Copyright (C) 2016-2021 Intel Corporation <www.intel.com> + * Copyright (C) 2016-2024 Intel Corporation <www.intel.com> */
#ifndef _SOCFPGA_SOC64_BASE_HARDWARE_H_ #define _SOCFPGA_SOC64_BASE_HARDWARE_H_
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SOCFPGA_CCU_ADDRESS 0x1c000000 +#define SOCFPGA_F2SDRAM_MGR_ADDRESS 0x18001000 +#define SOCFPGA_SMMU_ADDRESS 0x16000000 +#define SOCFPGA_OCRAM_FIREWALL_ADDRESS 0x108cc400 +#define SOCFPGA_MAILBOX_ADDRESS 0x10a30000 +#define SOCFPGA_UART0_ADDRESS 0x10c02000 +#define SOCFPGA_UART1_ADDRESS 0x10c02100 +#define SOCFPGA_SPTIMER0_ADDRESS 0x10c03000 +#define SOCFPGA_SPTIMER1_ADDRESS 0x10c03100 +#define SOCFPGA_SYSTIMER0_ADDRESS 0x10d00000 +#define SOCFPGA_SYSTIMER1_ADDRESS 0x10d00100 +#define SOCFPGA_L4WD0_ADDRESS 0x10d00200 +#define SOCFPGA_L4WD1_ADDRESS 0x10d00300 +#define SOCFPGA_L4WD2_ADDRESS 0x10d00400 +#define SOCFPGA_L4WD3_ADDRESS 0x10d00500 +#define SOCFPGA_L4WD4_ADDRESS 0x10d00600 +#define SOCFPGA_GTIMER_SEC_ADDRESS 0x10d01000 +#define SOCFPGA_GTIMER_NSEC_ADDRESS 0x10d02000 +#define SOCFPGA_CLKMGR_ADDRESS 0x10d10000 +#define SOCFPGA_RSTMGR_ADDRESS 0x10d11000 +#define SOCFPGA_SYSMGR_ADDRESS 0x10d12000 +#define SOCFPGA_OCRAM_ADDRESS 0x00000000 +#define SOCFPGA_FW_DDR_CCU_DMI0_ADDRESS 0x18000800 +#define SOCFPGA_FW_DDR_CCU_DMI1_ADDRESS 0x18000A00 +#define SOCFPGA_FW_TBU2NOC_ADDRESS 0x18000C00 +#define SOCFPGA_FIREWALL_L4_PER 0x10d21000 +#define SOCFPGA_FIREWALL_L4_SYS 0x10d21100 +#define SOCFPGA_FIREWALL_SOC2FPGA 0x10d21200 +#define SOCFPGA_FIREWALL_LWSOC2FPGA 0x10d21300 +#define SOCFPGA_FIREWALL_TCU 0x10d21400 +#define SOCFPGA_FIREWALL_PRIV_MEMORYMAP_PRIV 0x10d24800 +#define GICD_BASE 0x1d000000 +#define GICR_BASE 0x1d060000 +#else #define SOCFPGA_CCU_ADDRESS 0xf7000000 #define SOCFPGA_SDR_SCHEDULER_ADDRESS 0xf8000400 #define SOCFPGA_HMC_MMR_IO48_ADDRESS 0xf8010000 @@ -44,5 +79,6 @@ #define SOCFPGA_OCRAM_ADDRESS 0xffe00000 #define GICD_BASE 0xfffc1000 #define GICC_BASE 0xfffc2000 +#endif /* IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) */
#endif /* _SOCFPGA_SOC64_BASE_HARDWARE_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index a8cb07a1c4..6c9d32b9dd 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2024 Altera Corporation <www.altera.com> */
#ifndef _CLOCK_MANAGER_H_ @@ -28,6 +28,8 @@ int cm_set_qspi_controller_clk_hz(u32 clk_hz); #include <asm/arch/clock_manager_s10.h> #elif defined(CONFIG_TARGET_SOCFPGA_AGILEX) #include <asm/arch/clock_manager_agilex.h> +#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#include <asm/arch/clock_manager_agilex5.h> #elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) #include <asm/arch/clock_manager_n5x.h> #endif diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_agilex5.h b/arch/arm/mach-socfpga/include/mach/clock_manager_agilex5.h new file mode 100644 index 0000000000..1ae0a92603 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_agilex5.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#ifndef _CLOCK_MANAGER_AGILEX5_ +#define _CLOCK_MANAGER_AGILEX5_ + +#include <asm/arch/clock_manager_soc64.h> +#include "../../../../../drivers/clk/altera/clk-agilex5.h" + +#endif /* _CLOCK_MANAGER_AGILEX5_ */ diff --git a/arch/arm/mach-socfpga/include/mach/handoff_soc64.h b/arch/arm/mach-socfpga/include/mach/handoff_soc64.h index 9b85e5865b..2684b84a08 100644 --- a/arch/arm/mach-socfpga/include/mach/handoff_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/handoff_soc64.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0 * - * Copyright (C) 2016-2021 Intel Corporation <www.intel.com> + * Copyright (C) 2016-2024 Intel Corporation <www.intel.com> * */
@@ -17,7 +17,12 @@ #define SOC64_HANDOFF_MAGIC_FPGA 0x46504741 #define SOC64_HANDOFF_MAGIC_DELAY 0x444C4159 #define SOC64_HANDOFF_MAGIC_CLOCK 0x434C4B53 +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SOC64_HANDOFF_MAGIC_PERI 0x50455249 +#define SOC64_HANDOFF_MAGIC_SDRAM 0x5344524d +#else #define SOC64_HANDOFF_MAGIC_MISC 0x4D495343 +#endif
#define SOC64_HANDOFF_OFFSET_LENGTH 0x4 #define SOC64_HANDOFF_OFFSET_DATA 0x10 @@ -27,6 +32,8 @@ IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX) #define SOC64_HANDOFF_BASE 0xFFE3F000 #define SOC64_HANDOFF_MISC (SOC64_HANDOFF_BASE + 0x610) +#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SOC64_HANDOFF_BASE 0x0007F000 #elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) #define SOC64_HANDOFF_BASE 0xFFE5F000 #define SOC64_HANDOFF_MISC (SOC64_HANDOFF_BASE + 0x630) @@ -58,13 +65,21 @@ #define SOC64_HANDOFF_FPGA (SOC64_HANDOFF_BASE + 0x330) #define SOC64_HANDOFF_DELAY (SOC64_HANDOFF_BASE + 0x3F0) #define SOC64_HANDOFF_CLOCK (SOC64_HANDOFF_BASE + 0x580) +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SOC64_HANDOFF_PERI (SOC64_HANDOFF_BASE + 0x620) +#define SOC64_HANDOFF_SDRAM (SOC64_HANDOFF_BASE + 0x634) +#define SOC64_HANDOFF_SDRAM_LEN 1 +#endif
#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_STRATIX10) -#define SOC64_HANDOFF_CLOCK_OSC (SOC64_HANDOFF_BASE + 0x608) -#define SOC64_HANDOFF_CLOCK_FPGA (SOC64_HANDOFF_BASE + 0x60C) +#define SOC64_HANDOFF_CLOCK_OSC (SOC64_HANDOFF_BASE + 0x608) +#define SOC64_HANDOFF_CLOCK_FPGA (SOC64_HANDOFF_BASE + 0x60C) +#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SOC64_HANDOFF_CLOCK_OSC (SOC64_HANDOFF_BASE + 0x60c) +#define SOC64_HANDOFF_CLOCK_FPGA (SOC64_HANDOFF_BASE + 0x610) #else -#define SOC64_HANDOFF_CLOCK_OSC (SOC64_HANDOFF_BASE + 0x5fc) -#define SOC64_HANDOFF_CLOCK_FPGA (SOC64_HANDOFF_BASE + 0x600) +#define SOC64_HANDOFF_CLOCK_OSC (SOC64_HANDOFF_BASE + 0x5fc) +#define SOC64_HANDOFF_CLOCK_FPGA (SOC64_HANDOFF_BASE + 0x600) #endif
#define SOC64_HANDOFF_MUX_LEN 96 @@ -78,6 +93,12 @@
#ifndef __ASSEMBLY__ #include <asm/types.h> +enum endianness { + LITTLE_ENDIAN = 0, + BIG_ENDIAN, + UNKNOWN_ENDIANNESS +}; + int socfpga_get_handoff_size(void *handoff_address); int socfpga_handoff_read(void *handoff_address, void *table, u32 table_len); #endif diff --git a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h index fbaf11597e..2cc7c89044 100644 --- a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h +++ b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h @@ -119,6 +119,7 @@ enum ALT_SDM_MBOX_RESP_CODE { #define MBOX_RECONFIG_DATA 8 #define MBOX_RECONFIG_STATUS 9 #define MBOX_VAB_SRC_CERT 11 +#define MBOX_GET_USERCODE 19 #define MBOX_QSPI_OPEN 50 #define MBOX_QSPI_CLOSE 51 #define MBOX_QSPI_DIRECT 59 diff --git a/arch/arm/mach-socfpga/mmu-arm64_s10.c b/arch/arm/mach-socfpga/mmu-arm64_s10.c index a55b7b7cf3..b1e327a24e 100644 --- a/arch/arm/mach-socfpga/mmu-arm64_s10.c +++ b/arch/arm/mach-socfpga/mmu-arm64_s10.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2016-2018 Intel Corporation <www.intel.com> + * Copyright (C) 2016-2024 Intel Corporation <www.intel.com> * */
@@ -10,6 +10,62 @@
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +static struct mm_region socfpga_agilex5_mem_map[] = { + { + /* OCRAM 512KB */ + .virt = 0x00000000UL, + .phys = 0x00000000UL, + .size = 0x00080000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE, + }, { + /* DEVICE */ + .virt = 0x10808000UL, + .phys = 0x10808000UL, + .size = 0x0F7F8000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* FPGA 1.5GB */ + .virt = 0x20000000UL, + .phys = 0x20000000UL, + .size = 0x60000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* FPGA 15GB */ + .virt = 0x440000000UL, + .phys = 0x440000000UL, + .size = 0x3C0000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* FPGA 240GB */ + .virt = 0x4400000000UL, + .phys = 0x4400000000UL, + .size = 0x3E80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* MEM 2GB */ + .virt = 0x80000000UL, + .phys = 0x80000000UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE, + }, { + /* List terminator */ + }, +}; + +struct mm_region *mem_map = socfpga_agilex5_mem_map; + +#else static struct mm_region socfpga_stratix10_mem_map[] = { { /* MEM 2GB*/ @@ -70,3 +126,4 @@ static struct mm_region socfpga_stratix10_mem_map[] = { };
struct mm_region *mem_map = socfpga_stratix10_mem_map; +#endif diff --git a/board/intel/agilex5-socdk/MAINTAINERS b/board/intel/agilex5-socdk/MAINTAINERS new file mode 100644 index 0000000000..b696f788c8 --- /dev/null +++ b/board/intel/agilex5-socdk/MAINTAINERS @@ -0,0 +1,8 @@ +SOCFPGA BOARD +M: Tien Fong Chee tien.fong.chee@intel.com +M: Teik Heng Chong teik.heng.chong@intel.com +M: Jit Loon Lim jit.loon.lim@intel.com +S: Maintained +F: board/intel/agilex5-socdk/ +F: include/configs/socfpga_agilex5_socdk.h +F: configs/socfpga_agilex5_defconfig diff --git a/configs/socfpga_agilex5_defconfig b/configs/socfpga_agilex5_defconfig new file mode 100644 index 0000000000..f39954aea8 --- /dev/null +++ b/configs/socfpga_agilex5_defconfig @@ -0,0 +1,116 @@ +CONFIG_ARM=y +CONFIG_SPL_LDSCRIPT="arch/arm/mach-socfpga/u-boot-spl-soc64.lds" +CONFIG_SYS_SPI_U_BOOT_OFFS=0x04000000 +CONFIG_ARCH_SOCFPGA=y +CONFIG_TEXT_BASE=0x80200000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x04100000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="socfpga_agilex5_socdk" +CONFIG_TARGET_SOCFPGA_AGILEX5_SOCDK=y +CONFIG_IDENT_STRING="socfpga_agilex5" +CONFIG_SPL_FS_FAT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x82000000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 initrd=0x90000000 root=/dev/ram0 rw init=/sbin/init ramdisk_size=10000000 earlycon panic=-1 nosmp kvm-arm.mode=nvhe" +CONFIG_LEGACY_IMAGE_FORMAT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_CRC32=y +CONFIG_SPL_CACHE=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_SYS_PROMPT="SOCFPGA_AGILEX5 # " +CONFIG_CMD_NVEDIT_SELECT=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_SF=y +CONFIG_DOS_PARTITION=y +CONFIG_SPL_DOS_PARTITION=y +CONFIG_SPL_SYS_DISABLE_DCACHE_OPS=y +CONFIG_CMD_MTD=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +CONFIG_SPL_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_CMD_UBI=y +CONFIG_CMD_UBIFS=y +CONFIG_MTD_UBI=y +CONFIG_MTD_UBI_WL_THRESHOLD=4096 +CONFIG_MTD_UBI_BEB_LIMIT=20 +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_LIST="" +CONFIG_ENV_IS_IN_UBI=y +CONFIG_ENV_UBI_PART="root" +CONFIG_ENV_UBI_VOLUME="env" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_ALTERA_SDRAM=y +CONFIG_FPGA_INTEL_PR=y +CONFIG_DWAPB_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_DW=y +CONFIG_MISC=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SF_DEFAULT_MODE=0x2003 +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_UBI_SILENCE_MSG=y +CONFIG_DM_ETH=y +CONFIG_RGMII=y +CONFIG_DM_RESET=y +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_DESIGNWARE_SPI=y +CONFIG_USB=y +CONFIG_USB_DWC2=y +CONFIG_USB_XHCI_HCD=y +CONFIG_UBIFS_SILENCE_MSG=y +# CONFIG_SPL_USE_TINY_PRINTF is not set +CONFIG_PANIC_HANG=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_WDT=y +CONFIG_CMD_WDT=y +CONFIG_DESIGNWARE_WATCHDOG=y +CONFIG_SPL_WDT=y +CONFIG_WATCHDOG_AUTOSTART=n +CONFIG_TIMER=y +CONFIG_DESIGNWARE_APB_TIMER=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80300000 +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0xbff00000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x7f000 +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xbfa00000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_BSS_MAX_SIZE=0x100000 +# CONFIG_EFI_LOADER is not set +CONFIG_I3C=y +CONFIG_DW_I3C_MASTER=y +CONFIG_CMD_I3C=y +CONFIG_SYS_MAXARGS=32 +CONFIG_CMD_TIMER=y +# CONFIG_BOOTFILE="Image" is not set for CONFIG_SPL_ATF=y +CONFIG_USE_BOOTFILE=y +CONFIG_BOOTFILE="kernel.itb" diff --git a/drivers/clk/altera/Makefile b/drivers/clk/altera/Makefile index 33db092918..61ffa4179a 100644 --- a/drivers/clk/altera/Makefile +++ b/drivers/clk/altera/Makefile @@ -7,3 +7,4 @@ obj-$(CONFIG_TARGET_SOCFPGA_AGILEX) += clk-agilex.o obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clk-arria10.o obj-$(CONFIG_TARGET_SOCFPGA_N5X) += clk-n5x.o obj-$(CONFIG_TARGET_SOCFPGA_N5X) += clk-mem-n5x.o +obj-$(CONFIG_TARGET_SOCFPGA_AGILEX5) += clk-agilex5.o diff --git a/drivers/clk/altera/clk-agilex5.c b/drivers/clk/altera/clk-agilex5.c new file mode 100644 index 0000000000..c3b614ace4 --- /dev/null +++ b/drivers/clk/altera/clk-agilex5.c @@ -0,0 +1,743 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#include <clk-uclass.h> +#include <config.h> +#include <errno.h> +#include <dm.h> +#include <log.h> +#include <stdarg.h> +#include <stdio.h> +#include <time.h> +#include <vsprintf.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/system.h> +#include <asm/u-boot.h> +#include <dm/lists.h> +#include <dm/util.h> +#include <linux/bitops.h> +#include <linux/kernel.h> +#include <linux/string.h> +#include <linux/types.h> +#include <asm/arch/clock_manager.h> +#include <dt-bindings/clock/agilex5-clock.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct socfpga_clk_plat { + void __iomem *regs; +}; + +/* + * function to write the bypass register which requires a poll of the + * busy bit + */ +static void clk_write_bypass_mainpll(struct socfpga_clk_plat *plat, u32 val) +{ + CM_REG_WRITEL(plat, val, CLKMGR_MAINPLL_BYPASS); + cm_wait_for_fsm(); +} + +static void clk_write_bypass_perpll(struct socfpga_clk_plat *plat, u32 val) +{ + CM_REG_WRITEL(plat, val, CLKMGR_PERPLL_BYPASS); + cm_wait_for_fsm(); +} + +/* function to write the ctrl register which requires a poll of the busy bit */ +static void clk_write_ctrl(struct socfpga_clk_plat *plat, u32 val) +{ + CM_REG_WRITEL(plat, val, CLKMGR_CTRL); + cm_wait_for_fsm(); +} + +static const struct { + u32 reg; + u32 val; + u32 mask; +} membus_pll[] = { + { + MEMBUS_CLKSLICE_REG, + /* + * BIT[7:7] + * Enable source synchronous mode + */ + BIT(7), + BIT(7) + }, + { + MEMBUS_SYNTHCALFOSC_INIT_CENTERFREQ_REG, + /* + * BIT[0:0] + * Sets synthcalfosc_init_centerfreq=1 to limit overshoot + * frequency during lock + */ + BIT(0), + BIT(0) + }, + { + MEMBUS_SYNTHPPM_WATCHDOGTMR_VF01_REG, + /* + * BIT[0:0] + * Sets synthppm_watchdogtmr_vf0=1 to give the pll more time + * to settle before lock is asserted. + */ + BIT(0), + BIT(0) + }, + { + MEMBUS_CALCLKSLICE0_DUTY_LOCOVR_REG, + /* + * BIT[6:0] + * Centering duty cycle for clkslice0 output + */ + 0x4a, + GENMASK(6, 0) + }, + { + MEMBUS_CALCLKSLICE1_DUTY_LOCOVR_REG, + /* + * BIT[6:0] + * Centering duty cycle for clkslice1 output + */ + 0x4a, + GENMASK(6, 0) + }, +}; + +static int membus_wait_for_req(struct socfpga_clk_plat *plat, u32 pll, + int timeout) +{ + int cnt = 0; + u32 req_status; + + if (pll == MEMBUS_MAINPLL) + req_status = CM_REG_READL(plat, CLKMGR_MAINPLL_MEM); + else + req_status = CM_REG_READL(plat, CLKMGR_PERPLL_MEM); + + while ((cnt < timeout) && (req_status & CLKMGR_MEM_REQ_SET_MSK)) { + if (pll == MEMBUS_MAINPLL) + req_status = CM_REG_READL(plat, CLKMGR_MAINPLL_MEM); + else + req_status = CM_REG_READL(plat, CLKMGR_PERPLL_MEM); + cnt++; + } + + if (cnt >= timeout) + return -ETIMEDOUT; + + return 0; +} + +static int membus_write_pll(struct socfpga_clk_plat *plat, u32 pll, + u32 addr_offset, u32 wdat, int timeout) +{ + u32 addr; + u32 val; + + addr = ((addr_offset | CLKMGR_MEM_ADDR_START) & CLKMGR_MEM_ADDR_MASK); + + val = (CLKMGR_MEM_REQ_SET_MSK | CLKMGR_MEM_WR_SET_MSK | + (wdat << CLKMGR_MEM_WDAT_LSB_OFFSET) | addr); + + if (pll == MEMBUS_MAINPLL) + CM_REG_WRITEL(plat, val, CLKMGR_MAINPLL_MEM); + else + CM_REG_WRITEL(plat, val, CLKMGR_PERPLL_MEM); + + debug("MEMBUS: Write 0x%08x to addr = 0x%08x\n", wdat, addr); + + return membus_wait_for_req(plat, pll, timeout); +} + +static int membus_read_pll(struct socfpga_clk_plat *plat, u32 pll, + u32 addr_offset, u32 *rdata, int timeout) +{ + u32 addr; + u32 val; + + addr = ((addr_offset | CLKMGR_MEM_ADDR_START) & CLKMGR_MEM_ADDR_MASK); + + val = ((CLKMGR_MEM_REQ_SET_MSK & ~CLKMGR_MEM_WR_SET_MSK) | addr); + + if (pll == MEMBUS_MAINPLL) + CM_REG_WRITEL(plat, val, CLKMGR_MAINPLL_MEM); + else + CM_REG_WRITEL(plat, val, CLKMGR_PERPLL_MEM); + + *rdata = 0; + + if (membus_wait_for_req(plat, pll, timeout)) + return -ETIMEDOUT; + + if (pll == MEMBUS_MAINPLL) + *rdata = CM_REG_READL(plat, CLKMGR_MAINPLL_MEMSTAT); + else + *rdata = CM_REG_READL(plat, CLKMGR_PERPLL_MEMSTAT); + + debug("MEMBUS: Read 0x%08x from addr = 0x%08x\n", *rdata, addr); + + return 0; +} + +static void membus_pll_configs(struct socfpga_clk_plat *plat, u32 pll) +{ + int i; + u32 rdata; + + for (i = 0; i < ARRAY_SIZE(membus_pll); i++) { + membus_read_pll(plat, pll, membus_pll[i].reg, + &rdata, MEMBUS_TIMEOUT); + membus_write_pll(plat, pll, membus_pll[i].reg, + ((rdata & ~membus_pll[i].mask) | membus_pll[i].val), + MEMBUS_TIMEOUT); + } +} + +static u32 calc_vocalib_pll(u32 pllm, u32 pllglob) +{ + u32 mdiv, refclkdiv, arefclkdiv, drefclkdiv, mscnt, hscnt, vcocalib; + + mdiv = pllm & CLKMGR_PLLM_MDIV_MASK; + arefclkdiv = (pllglob & CLKMGR_PLLGLOB_AREFCLKDIV_MASK) >> + CLKMGR_PLLGLOB_AREFCLKDIV_OFFSET; + drefclkdiv = (pllglob & CLKMGR_PLLGLOB_DREFCLKDIV_MASK) >> + CLKMGR_PLLGLOB_DREFCLKDIV_OFFSET; + refclkdiv = (pllglob & CLKMGR_PLLGLOB_REFCLKDIV_MASK) >> + CLKMGR_PLLGLOB_REFCLKDIV_OFFSET; + mscnt = CLKMGR_VCOCALIB_MSCNT_CONST / (mdiv * BIT(drefclkdiv)); + if (!mscnt) + mscnt = 1; + hscnt = (mdiv * mscnt * BIT(drefclkdiv) / refclkdiv) - + CLKMGR_VCOCALIB_HSCNT_CONST; + vcocalib = (hscnt & CLKMGR_VCOCALIB_HSCNT_MASK) | + ((mscnt << CLKMGR_VCOCALIB_MSCNT_OFFSET) & + CLKMGR_VCOCALIB_MSCNT_MASK); + + /* Dump all the pll calibration settings for debug purposes */ + debug("mdiv : %d\n", mdiv); + debug("arefclkdiv : %d\n", arefclkdiv); + debug("drefclkdiv : %d\n", drefclkdiv); + debug("refclkdiv : %d\n", refclkdiv); + debug("mscnt : %d\n", mscnt); + debug("hscnt : %d\n", hscnt); + debug("vcocalib : 0x%08x\n", vcocalib); + + return vcocalib; +} + +/* + * Setup clocks while making no assumptions about previous state of the clocks. + */ +static void clk_basic_init(struct udevice *dev, + const struct cm_config * const cfg) +{ + struct socfpga_clk_plat *plat = dev_get_plat(dev); + u32 vcocalib; + + if (!cfg) + return; + + if (IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5_EMU)) { + /* Take both PLL out of reset and power up */ + CM_REG_SETBITS(plat, CLKMGR_MAINPLL_PLLGLOB, + CLKMGR_PLLGLOB_PD_MASK | CLKMGR_PLLGLOB_RST_MASK); + CM_REG_SETBITS(plat, CLKMGR_PERPLL_PLLGLOB, + CLKMGR_PLLGLOB_PD_MASK | CLKMGR_PLLGLOB_RST_MASK); + + cm_wait_for_lock(CLKMGR_STAT_ALLPLL_LOCKED_MASK); + + /* Put both PLLs in bypass */ + clk_write_bypass_mainpll(plat, CLKMGR_BYPASS_MAINPLL_ALL); + clk_write_bypass_perpll(plat, CLKMGR_BYPASS_PERPLL_ALL); + + /* Take all PLLs out of bypass */ + clk_write_bypass_mainpll(plat, 0); + clk_write_bypass_perpll(plat, 0); + + /* Out of boot mode */ + clk_write_ctrl(plat, + CM_REG_READL(plat, CLKMGR_CTRL) & ~CLKMGR_CTRL_BOOTMODE); + } else { +#ifdef CONFIG_SPL_BUILD + /* Always force clock manager into boot mode before any configuration */ + clk_write_ctrl(plat, + CM_REG_READL(plat, CLKMGR_CTRL) | CLKMGR_CTRL_BOOTMODE); +#else + /* Skip clock configuration in SSBL if it's not in boot mode */ + if (!(CM_REG_READL(plat, CLKMGR_CTRL) & CLKMGR_CTRL_BOOTMODE)) + return; +#endif + + /* Put both PLLs in bypass */ + clk_write_bypass_mainpll(plat, CLKMGR_BYPASS_MAINPLL_ALL); + clk_write_bypass_perpll(plat, CLKMGR_BYPASS_PERPLL_ALL); + + /* Put both PLLs in Reset and Power Down */ + CM_REG_CLRBITS(plat, CLKMGR_MAINPLL_PLLGLOB, + CLKMGR_PLLGLOB_PD_MASK | CLKMGR_PLLGLOB_RST_MASK); + CM_REG_CLRBITS(plat, CLKMGR_PERPLL_PLLGLOB, + CLKMGR_PLLGLOB_PD_MASK | CLKMGR_PLLGLOB_RST_MASK); + + /* setup main PLL dividers where calculate the vcocalib value */ + vcocalib = calc_vocalib_pll(cfg->main_pll_pllm, cfg->main_pll_pllglob); + CM_REG_WRITEL(plat, cfg->main_pll_pllglob & ~CLKMGR_PLLGLOB_RST_MASK, + CLKMGR_MAINPLL_PLLGLOB); + CM_REG_WRITEL(plat, cfg->main_pll_fdbck, CLKMGR_MAINPLL_FDBCK); + CM_REG_WRITEL(plat, vcocalib, CLKMGR_MAINPLL_VCOCALIB); + CM_REG_WRITEL(plat, cfg->main_pll_pllc0, CLKMGR_MAINPLL_PLLC0); + CM_REG_WRITEL(plat, cfg->main_pll_pllc1, CLKMGR_MAINPLL_PLLC1); + CM_REG_WRITEL(plat, cfg->main_pll_pllc2, CLKMGR_MAINPLL_PLLC2); + CM_REG_WRITEL(plat, cfg->main_pll_pllc3, CLKMGR_MAINPLL_PLLC3); + CM_REG_WRITEL(plat, cfg->main_pll_pllm, CLKMGR_MAINPLL_PLLM); + CM_REG_WRITEL(plat, cfg->main_pll_nocclk, CLKMGR_MAINPLL_NOCCLK); + CM_REG_WRITEL(plat, cfg->main_pll_nocdiv, CLKMGR_MAINPLL_NOCDIV); + + /* setup peripheral PLL dividers where calculate the vcocalib value */ + vcocalib = calc_vocalib_pll(cfg->per_pll_pllm, cfg->per_pll_pllglob); + CM_REG_WRITEL(plat, cfg->per_pll_pllglob & ~CLKMGR_PLLGLOB_RST_MASK, + CLKMGR_PERPLL_PLLGLOB); + CM_REG_WRITEL(plat, cfg->per_pll_fdbck, CLKMGR_PERPLL_FDBCK); + CM_REG_WRITEL(plat, vcocalib, CLKMGR_PERPLL_VCOCALIB); + CM_REG_WRITEL(plat, cfg->per_pll_pllc0, CLKMGR_PERPLL_PLLC0); + CM_REG_WRITEL(plat, cfg->per_pll_pllc1, CLKMGR_PERPLL_PLLC1); + CM_REG_WRITEL(plat, cfg->per_pll_pllc2, CLKMGR_PERPLL_PLLC2); + CM_REG_WRITEL(plat, cfg->per_pll_pllc3, CLKMGR_PERPLL_PLLC3); + CM_REG_WRITEL(plat, cfg->per_pll_pllm, CLKMGR_PERPLL_PLLM); + CM_REG_WRITEL(plat, cfg->per_pll_emacctl, CLKMGR_PERPLL_EMACCTL); + CM_REG_WRITEL(plat, cfg->per_pll_gpiodiv, CLKMGR_PERPLL_GPIODIV); + + /* Configure ping pong counters in control group */ + CM_REG_WRITEL(plat, cfg->ctl_emacactr, CLKMGR_CTL_EMACACTR); + CM_REG_WRITEL(plat, cfg->ctl_emacbctr, CLKMGR_CTL_EMACBCTR); + CM_REG_WRITEL(plat, cfg->ctl_emacptpctr, CLKMGR_CTL_EMACPTPCTR); + CM_REG_WRITEL(plat, cfg->ctl_gpiodbctr, CLKMGR_CTL_GPIODBCTR); + CM_REG_WRITEL(plat, cfg->ctl_s2fuser0ctr, CLKMGR_CTL_S2FUSER0CTR); + CM_REG_WRITEL(plat, cfg->ctl_s2fuser1ctr, CLKMGR_CTL_S2FUSER1CTR); + CM_REG_WRITEL(plat, cfg->ctl_psirefctr, CLKMGR_CTL_PSIREFCTR); + CM_REG_WRITEL(plat, cfg->ctl_usb31ctr, CLKMGR_CTL_USB31CTR); + CM_REG_WRITEL(plat, cfg->ctl_dsuctr, CLKMGR_CTL_DSUCTR); + CM_REG_WRITEL(plat, cfg->ctl_core01ctr, CLKMGR_CTL_CORE01CTR); + CM_REG_WRITEL(plat, cfg->ctl_core23ctr, CLKMGR_CTL_CORE23CTR); + CM_REG_WRITEL(plat, cfg->ctl_core2ctr, CLKMGR_CTL_CORE2CTR); + CM_REG_WRITEL(plat, cfg->ctl_core3ctr, CLKMGR_CTL_CORE3CTR); + + /* Take both PLL out of reset and power up */ + CM_REG_SETBITS(plat, CLKMGR_MAINPLL_PLLGLOB, + CLKMGR_PLLGLOB_PD_MASK | CLKMGR_PLLGLOB_RST_MASK); + CM_REG_SETBITS(plat, CLKMGR_PERPLL_PLLGLOB, + CLKMGR_PLLGLOB_PD_MASK | CLKMGR_PLLGLOB_RST_MASK); + + /* Membus programming for mainpll */ + membus_pll_configs(plat, MEMBUS_MAINPLL); + /* Membus programming for peripll */ + membus_pll_configs(plat, MEMBUS_PERPLL); + + /* Enable Main pll clkslices */ + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_MAINPLL_PLLC0) | + CLKMGR_PLLCX_EN_SET_MSK, + CLKMGR_MAINPLL_PLLC0); + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_MAINPLL_PLLC1) | + CLKMGR_PLLCX_EN_SET_MSK, + CLKMGR_MAINPLL_PLLC1); + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_MAINPLL_PLLC2) | + CLKMGR_PLLCX_EN_SET_MSK, + CLKMGR_MAINPLL_PLLC2); + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_MAINPLL_PLLC3) | + CLKMGR_PLLCX_EN_SET_MSK, + CLKMGR_MAINPLL_PLLC3); + + /* Enable Periph pll clkslices */ + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_PERPLL_PLLC0) | + CLKMGR_PLLCX_EN_SET_MSK, + CLKMGR_PERPLL_PLLC0); + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_PERPLL_PLLC1) | + CLKMGR_PLLCX_EN_SET_MSK, + CLKMGR_PERPLL_PLLC1); + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_PERPLL_PLLC2) | + CLKMGR_PLLCX_EN_SET_MSK, + CLKMGR_PERPLL_PLLC2); + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_PERPLL_PLLC3) | + CLKMGR_PLLCX_EN_SET_MSK, + CLKMGR_PERPLL_PLLC3); + + cm_wait_for_lock(CLKMGR_STAT_ALLPLL_LOCKED_MASK); + + CM_REG_WRITEL(plat, CLKMGR_LOSTLOCK_SET_MASK, CLKMGR_MAINPLL_LOSTLOCK); + CM_REG_WRITEL(plat, CLKMGR_LOSTLOCK_SET_MASK, CLKMGR_PERPLL_LOSTLOCK); + + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_MAINPLL_PLLGLOB) | + CLKMGR_PLLGLOB_CLR_LOSTLOCK_BYPASS_MASK, + CLKMGR_MAINPLL_PLLGLOB); + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_PERPLL_PLLGLOB) | + CLKMGR_PLLGLOB_CLR_LOSTLOCK_BYPASS_MASK, + CLKMGR_PERPLL_PLLGLOB); + + /* Take all PLLs out of bypass */ + clk_write_bypass_mainpll(plat, 0); + clk_write_bypass_perpll(plat, 0); + + /* Clear the loss of lock bits (write 1 to clear) */ + CM_REG_CLRBITS(plat, CLKMGR_INTRCLR, + CLKMGR_INTER_PERPLLLOST_MASK | + CLKMGR_INTER_MAINPLLLOST_MASK); + + /* Take all ping pong counters out of reset */ + CM_REG_CLRBITS(plat, CLKMGR_CTL_EXTCNTRST, + CLKMGR_CTL_EXTCNTRST_ALLCNTRST); + +#ifdef COUNTER_FREQUENCY_REAL + u32 cntfrq = COUNTER_FREQUENCY_REAL; + u32 counter_freq = 0; + + /* Update with accurate clock frequency */ + if (current_el() == 3) { + asm volatile("msr cntfrq_el0, %0" : : "r" (cntfrq) : "memory"); + asm volatile("mrs %0, cntfrq_el0" : "=r" (counter_freq)); + debug("Counter freq = 0x%x\n", counter_freq); + } +#endif + + /* Out of boot mode */ + clk_write_ctrl(plat, + CM_REG_READL(plat, CLKMGR_CTRL) & ~CLKMGR_CTRL_BOOTMODE); + } +} + +static u64 clk_get_vco_clk_hz(struct socfpga_clk_plat *plat, + u32 pllglob_reg, u32 pllm_reg) +{ + u64 fref, arefdiv, mdiv, reg, vco; + + reg = CM_REG_READL(plat, pllglob_reg); + + fref = (reg & CLKMGR_PLLGLOB_VCO_PSRC_MASK) >> + CLKMGR_PLLGLOB_VCO_PSRC_OFFSET; + + switch (fref) { + case CLKMGR_VCO_PSRC_EOSC1: + fref = cm_get_osc_clk_hz(); + break; + case CLKMGR_VCO_PSRC_INTOSC: + fref = cm_get_intosc_clk_hz(); + break; + case CLKMGR_VCO_PSRC_F2S: + fref = cm_get_fpga_clk_hz(); + break; + } + + arefdiv = (reg & CLKMGR_PLLGLOB_AREFCLKDIV_MASK) >> + CLKMGR_PLLGLOB_AREFCLKDIV_OFFSET; + + mdiv = CM_REG_READL(plat, pllm_reg) & CLKMGR_PLLM_MDIV_MASK; + + vco = fref / arefdiv; + vco = vco * mdiv; + + return vco; +} + +static u64 clk_get_main_vco_clk_hz(struct socfpga_clk_plat *plat) +{ + return clk_get_vco_clk_hz(plat, CLKMGR_MAINPLL_PLLGLOB, + CLKMGR_MAINPLL_PLLM); +} + +static u64 clk_get_per_vco_clk_hz(struct socfpga_clk_plat *plat) +{ + return clk_get_vco_clk_hz(plat, CLKMGR_PERPLL_PLLGLOB, + CLKMGR_PERPLL_PLLM); +} + +static u32 clk_get_5_1_clk_src(struct socfpga_clk_plat *plat, u64 reg) +{ + u32 clksrc = CM_REG_READL(plat, reg); + + return (clksrc & CLKMGR_CLKSRC_MASK) >> CLKMGR_CLKSRC_OFFSET; +} + +static u64 clk_get_clksrc_hz(struct socfpga_clk_plat *plat, u32 clksrc_reg, + u32 main_reg, u32 per_reg) +{ + u64 clock; + u32 clklsrc = clk_get_5_1_clk_src(plat, clksrc_reg); + + switch (clklsrc) { + case CLKMGR_CLKSRC_MAIN: + clock = clk_get_main_vco_clk_hz(plat); + clock /= (CM_REG_READL(plat, main_reg) & + CLKMGR_CLKCNT_MSK); + break; + + case CLKMGR_CLKSRC_PER: + clock = clk_get_per_vco_clk_hz(plat); + clock /= (CM_REG_READL(plat, per_reg) & + CLKMGR_CLKCNT_MSK); + break; + + case CLKMGR_CLKSRC_OSC1: + clock = cm_get_osc_clk_hz(); + break; + + case CLKMGR_CLKSRC_INTOSC: + clock = cm_get_intosc_clk_hz(); + break; + + case CLKMGR_CLKSRC_FPGA: + clock = cm_get_fpga_clk_hz(); + break; + default: + return 0; + } + + return clock; +} + +static u64 clk_get_mpu_clk_hz(struct socfpga_clk_plat *plat) +{ + u64 clock; + u32 ctr_reg; + u32 cpu = ((read_mpidr() >> MPIDR_AFF1_OFFSET) & MPIDR_AFF1_OFFSET); + + if (cpu > CORE1) { + ctr_reg = CLKMGR_CTL_CORE23CTR; + + clock = clk_get_clksrc_hz(plat, ctr_reg, + CLKMGR_MAINPLL_PLLC0, + CLKMGR_PERPLL_PLLC0); + } else { + ctr_reg = CLKMGR_CTL_CORE01CTR; + + clock = clk_get_clksrc_hz(plat, ctr_reg, + CLKMGR_MAINPLL_PLLC1, + CLKMGR_PERPLL_PLLC0); + } + + if (cpu == CORE3) + ctr_reg = CLKMGR_CTL_CORE3CTR; + else if (cpu == CORE2) + ctr_reg = CLKMGR_CTL_CORE2CTR; + else + ctr_reg = CLKMGR_CTL_CORE01CTR; + + clock /= 1 + (CM_REG_READL(plat, ctr_reg) & + CLKMGR_CLKCNT_MSK); + + return clock; +} + +static u32 clk_get_l3_main_clk_hz(struct socfpga_clk_plat *plat) +{ + return clk_get_clksrc_hz(plat, CLKMGR_MAINPLL_NOCCLK, + CLKMGR_MAINPLL_PLLC3, + CLKMGR_PERPLL_PLLC1); +} + +static u32 clk_get_l4_main_clk_hz(struct socfpga_clk_plat *plat) +{ + u64 clock = clk_get_l3_main_clk_hz(plat); + + return clock; +} + +static u32 clk_get_l4_sp_clk_hz(struct socfpga_clk_plat *plat) +{ + u64 clock = clk_get_l3_main_clk_hz(plat); + clock /= BIT((CM_REG_READL(plat, CLKMGR_MAINPLL_NOCDIV) >> + CLKMGR_NOCDIV_L4SPCLK_OFFSET) & + CLKMGR_NOCDIV_DIVIDER_MASK); + + return clock; +} + +static u32 clk_get_l4_mp_clk_hz(struct socfpga_clk_plat *plat) +{ + u64 clock = clk_get_l3_main_clk_hz(plat); + + clock /= BIT((CM_REG_READL(plat, CLKMGR_MAINPLL_NOCDIV) >> + CLKMGR_NOCDIV_L4MPCLK_OFFSET) & + CLKMGR_NOCDIV_DIVIDER_MASK); + + return clock; +} + +static u32 clk_get_sdmmc_clk_hz(struct socfpga_clk_plat *plat) +{ + u64 clock = clk_get_l4_mp_clk_hz(plat); + + clock /= BIT((CM_REG_READL(plat, CLKMGR_MAINPLL_NOCDIV) >> + CLKMGR_NOCDIV_SOFTPHY_OFFSET) & + CLKMGR_NOCDIV_DIVIDER_MASK); + + return clock; +} + +static u32 clk_get_l4_sys_free_clk_hz(struct socfpga_clk_plat *plat) +{ + if (CM_REG_READL(plat, CLKMGR_STAT) & CLKMGR_STAT_BOOTMODE) + return clk_get_l3_main_clk_hz(plat) / 2; + + return clk_get_l3_main_clk_hz(plat) / 4; +} + +static u32 clk_get_emac_clk_hz(struct socfpga_clk_plat *plat, u32 emac_id) +{ + u32 ctl; + u32 ctr_reg; + u32 clock; + u32 div; + u32 reg; + + if (emac_id == AGILEX5_EMAC_PTP_CLK) { + reg = CM_REG_READL(plat, CLKMGR_CTL_EMACPTPCTR); + ctr_reg = CLKMGR_CTL_EMACPTPCTR; + } else { + reg = CM_REG_READL(plat, CLKMGR_CTL_EMACACTR); + ctl = CM_REG_READL(plat, CLKMGR_PERPLL_EMACCTL); + if (emac_id == AGILEX5_EMAC0_CLK) + ctl = (ctl & CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_MASK) >> + CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_OFFSET; + else if (emac_id == AGILEX5_EMAC1_CLK) + ctl = (ctl & CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_MASK) >> + CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_OFFSET; + else if (emac_id == AGILEX5_EMAC2_CLK) + ctl = (ctl & CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_MASK) >> + CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_OFFSET; + else + return 0; + + if (ctl) { + /* EMAC B source */ + ctr_reg = CLKMGR_CTL_EMACBCTR; + } else { + /* EMAC A source */ + ctr_reg = CLKMGR_CTL_EMACACTR; + } + } + /* Get EMAC clock source */ + clock = (reg & CLKMGR_CTL_EMACCTR_SRC_MASK) + >> CLKMGR_CTL_EMACCTR_SRC_OFFSET; + + reg = CM_REG_READL(plat, ctr_reg); + div = (reg & CLKMGR_CTL_EMACCTR_CNT_MASK) + >> CLKMGR_CTL_EMACCTR_CNT_OFFSET; + + switch (clock) { + case CLKMGR_CLKSRC_MAIN: + clock = clk_get_main_vco_clk_hz(plat); + + if (emac_id == AGILEX5_EMAC_PTP_CLK) { + clock /= (CM_REG_READL(plat, CLKMGR_MAINPLL_PLLC3) & + CLKMGR_CLKCNT_MSK); + } else { + clock /= (CM_REG_READL(plat, CLKMGR_MAINPLL_PLLC1) & + CLKMGR_CLKCNT_MSK); + } + break; + + case CLKMGR_CLKSRC_PER: + clock = clk_get_per_vco_clk_hz(plat); + + clock /= (CM_REG_READL(plat, CLKMGR_PERPLL_PLLC3) & + CLKMGR_CLKCNT_MSK); + break; + + case CLKMGR_CLKSRC_OSC1: + clock = cm_get_osc_clk_hz(); + break; + + case CLKMGR_CLKSRC_INTOSC: + clock = cm_get_intosc_clk_hz(); + break; + + case CLKMGR_CLKSRC_FPGA: + clock = cm_get_fpga_clk_hz(); + break; + } + + clock /= 1 + div; + + return clock; +} + +static ulong socfpga_clk_get_rate(struct clk *clk) +{ + struct socfpga_clk_plat *plat = dev_get_plat(clk->dev); + + switch (clk->id) { + case AGILEX5_MPU_CLK: + return clk_get_mpu_clk_hz(plat); + case AGILEX5_L4_MAIN_CLK: + return clk_get_l4_main_clk_hz(plat); + case AGILEX5_L4_SYS_FREE_CLK: + return clk_get_l4_sys_free_clk_hz(plat); + case AGILEX5_L4_MP_CLK: + return clk_get_l4_mp_clk_hz(plat); + case AGILEX5_L4_SP_CLK: + return clk_get_l4_sp_clk_hz(plat); + case AGILEX5_SDMMC_CLK: + case AGILEX5_NAND_CLK: + return clk_get_sdmmc_clk_hz(plat); + case AGILEX5_EMAC0_CLK: + case AGILEX5_EMAC1_CLK: + case AGILEX5_EMAC2_CLK: + case AGILEX5_EMAC_PTP_CLK: + return clk_get_emac_clk_hz(plat, clk->id); + case AGILEX5_USB_CLK: + case AGILEX5_NAND_X_CLK: + return clk_get_l4_mp_clk_hz(plat); + default: + return -ENXIO; + } +} + +static int socfpga_clk_enable(struct clk *clk) +{ + return 0; +} + +static int socfpga_clk_probe(struct udevice *dev) +{ + const struct cm_config *cm_default_cfg = cm_get_default_config(); + + clk_basic_init(dev, cm_default_cfg); + + return 0; +} + +static int socfpga_clk_of_to_plat(struct udevice *dev) +{ + struct socfpga_clk_plat *plat = dev_get_plat(dev); + fdt_addr_t addr; + + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + plat->regs = (void __iomem *)addr; + + return 0; +} + +static struct clk_ops socfpga_clk_ops = { + .enable = socfpga_clk_enable, + .get_rate = socfpga_clk_get_rate, +}; + +static const struct udevice_id socfpga_clk_match[] = { + { .compatible = "intel,agilex5-clkmgr" }, + {} +}; + +U_BOOT_DRIVER(socfpga_agilex5_clk) = { + .name = "clk-agilex5", + .id = UCLASS_CLK, + .of_match = socfpga_clk_match, + .ops = &socfpga_clk_ops, + .probe = socfpga_clk_probe, + .of_to_plat = socfpga_clk_of_to_plat, + .plat_auto = sizeof(struct socfpga_clk_plat), +}; diff --git a/drivers/clk/altera/clk-agilex5.h b/drivers/clk/altera/clk-agilex5.h new file mode 100644 index 0000000000..a4ddc1a60d --- /dev/null +++ b/drivers/clk/altera/clk-agilex5.h @@ -0,0 +1,284 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#ifndef _CLK_AGILEX5_ +#define _CLK_AGILEX5_ + +#ifndef __ASSEMBLY__ +#include <linux/bitops.h> +#endif + +#define CORE0 1 +#define CORE1 2 +#define CORE2 3 +#define CORE3 4 + +/* Derived from l4_main_clk (PSS clock) */ +#define COUNTER_FREQUENCY_REAL 400000000 + +#define CM_REG_READL(plat, reg) \ + readl((plat)->regs + (reg)) + +#define CM_REG_WRITEL(plat, data, reg) \ + writel(data, (plat)->regs + (reg)) + +#define CM_REG_CLRBITS(plat, reg, clear) \ + clrbits_le32((plat)->regs + (reg), (clear)) + +#define CM_REG_SETBITS(plat, reg, set) \ + setbits_le32((plat)->regs + (reg), (set)) + +struct cm_config { + /* main group */ + u32 main_pll_nocclk; + u32 main_pll_nocdiv; + u32 main_pll_pllglob; + u32 main_pll_fdbck; + u32 main_pll_pllc0; + u32 main_pll_pllc1; + u32 main_pll_pllc2; + u32 main_pll_pllc3; + u32 main_pll_pllm; + + /* peripheral group */ + u32 per_pll_emacctl; + u32 per_pll_gpiodiv; + u32 per_pll_pllglob; + u32 per_pll_fdbck; + u32 per_pll_pllc0; + u32 per_pll_pllc1; + u32 per_pll_pllc2; + u32 per_pll_pllc3; + u32 per_pll_pllm; + + /* control group */ + u32 ctl_emacactr; + u32 ctl_emacbctr; + u32 ctl_emacptpctr; + u32 ctl_gpiodbctr; + u32 ctl_s2fuser0ctr; + u32 ctl_s2fuser1ctr; + u32 ctl_psirefctr; + u32 ctl_usb31ctr; + u32 ctl_dsuctr; + u32 ctl_core01ctr; + u32 ctl_core23ctr; + u32 ctl_core2ctr; + u32 ctl_core3ctr; + + /* incoming clock */ + u32 hps_osc_clk_hz; + u32 fpga_clk_hz; + u32 spare[3]; +}; + +/* Clock Manager registers */ +#define CLKMGR_CTRL 0 +#define CLKMGR_STAT 4 +#define CLKMGR_TESTIOCTRL 8 +#define CLKMGR_INTRGEN 0x0c +#define CLKMGR_INTRMSK 0x10 +#define CLKMGR_INTRCLR 0x14 +#define CLKMGR_INTRSTS 0x18 +#define CLKMGR_INTRSTK 0x1c +#define CLKMGR_INTRRAW 0x20 + +/* Clock Manager Main PPL group registers */ +#define CLKMGR_MAINPLL_EN 0x24 +#define CLKMGR_MAINPLL_ENS 0x28 +#define CLKMGR_MAINPLL_ENR 0x2c +#define CLKMGR_MAINPLL_BYPASS 0x30 +#define CLKMGR_MAINPLL_BYPASSS 0x34 +#define CLKMGR_MAINPLL_BYPASSR 0x38 +#define CLKMGR_MAINPLL_NOCCLK 0x40 +#define CLKMGR_MAINPLL_NOCDIV 0x44 +#define CLKMGR_MAINPLL_PLLGLOB 0x48 +#define CLKMGR_MAINPLL_FDBCK 0x4c +#define CLKMGR_MAINPLL_MEM 0x50 +#define CLKMGR_MAINPLL_MEMSTAT 0x54 +#define CLKMGR_MAINPLL_VCOCALIB 0x58 +#define CLKMGR_MAINPLL_PLLC0 0x5c +#define CLKMGR_MAINPLL_PLLC1 0x60 +#define CLKMGR_MAINPLL_PLLC2 0x64 +#define CLKMGR_MAINPLL_PLLC3 0x68 +#define CLKMGR_MAINPLL_PLLM 0x6c +#define CLKMGR_MAINPLL_FHOP 0x70 +#define CLKMGR_MAINPLL_SSC 0x74 +#define CLKMGR_MAINPLL_LOSTLOCK 0x78 + +/* Clock Manager Peripheral PPL group registers */ +#define CLKMGR_PERPLL_EN 0x7c +#define CLKMGR_PERPLL_ENS 0x80 +#define CLKMGR_PERPLL_ENR 0x84 +#define CLKMGR_PERPLL_BYPASS 0x88 +#define CLKMGR_PERPLL_BYPASSS 0x8c +#define CLKMGR_PERPLL_BYPASSR 0x90 +#define CLKMGR_PERPLL_EMACCTL 0x94 +#define CLKMGR_PERPLL_GPIODIV 0x98 +#define CLKMGR_PERPLL_PLLGLOB 0x9c +#define CLKMGR_PERPLL_FDBCK 0xa0 +#define CLKMGR_PERPLL_MEM 0xa4 +#define CLKMGR_PERPLL_MEMSTAT 0xa8 +#define CLKMGR_PERPLL_VCOCALIB 0xac +#define CLKMGR_PERPLL_PLLC0 0xb0 +#define CLKMGR_PERPLL_PLLC1 0xb4 +#define CLKMGR_PERPLL_PLLC2 0xb8 +#define CLKMGR_PERPLL_PLLC3 0xbc +#define CLKMGR_PERPLL_PLLM 0xc0 +#define CLKMGR_PERPLL_FHOP 0xc4 +#define CLKMGR_PERPLL_SSC 0xc8 +#define CLKMGR_PERPLL_LOSTLOCK 0xcc + +/* Clock Manager Control group registers */ +#define CLKMGR_CTL_JTAG 0xd0 +#define CLKMGR_CTL_EMACACTR 0xd4 +#define CLKMGR_CTL_EMACBCTR 0xd8 +#define CLKMGR_CTL_EMACPTPCTR 0xdc +#define CLKMGR_CTL_GPIODBCTR 0xe0 +#define CLKMGR_CTL_S2FUSER0CTR 0xe8 +#define CLKMGR_CTL_S2FUSER1CTR 0xec +#define CLKMGR_CTL_PSIREFCTR 0xf0 +#define CLKMGR_CTL_EXTCNTRST 0xf4 +#define CLKMGR_CTL_USB31CTR 0xf8 +#define CLKMGR_CTL_DSUCTR 0xfc +#define CLKMGR_CTL_CORE01CTR 0x100 +#define CLKMGR_CTL_CORE23CTR 0x104 +#define CLKMGR_CTL_CORE2CTR 0x108 +#define CLKMGR_CTL_CORE3CTR 0x10C + +#define CLKMGR_CTRL_BOOTMODE BIT(0) + +#define CLKMGR_STAT_BUSY BIT(0) +#define CLKMGR_STAT_MAINPLL_LOCKED BIT(8) +#define CLKMGR_STAT_MAIN_TRANS BIT(9) +#define CLKMGR_STAT_PERPLL_LOCKED BIT(16) +#define CLKMGR_STAT_PERF_TRANS BIT(17) +#define CLKMGR_STAT_BOOTMODE BIT(24) +#define CLKMGR_STAT_BOOTCLKSRC BIT(25) + +#define CLKMGR_STAT_ALLPLL_LOCKED_MASK \ + (CLKMGR_STAT_MAINPLL_LOCKED | CLKMGR_STAT_PERPLL_LOCKED) + +#define CLKMGR_INTER_MAINPLLLOCKED_MASK 0x00000001 +#define CLKMGR_INTER_PERPLLLOCKED_MASK 0x00000002 +#define CLKMGR_INTER_MAINPLLLOST_MASK 0x00000004 +#define CLKMGR_INTER_PERPLLLOST_MASK 0x00000008 + +#define CLKMGR_CLKSRC_MASK GENMASK(18, 16) +#define CLKMGR_CLKSRC_OFFSET 16 +#define CLKMGR_CLKSRC_MAIN 0 +#define CLKMGR_CLKSRC_PER 1 +#define CLKMGR_CLKSRC_OSC1 2 +#define CLKMGR_CLKSRC_INTOSC 3 +#define CLKMGR_CLKSRC_FPGA 4 +#define CLKMGR_CLKCNT_MSK GENMASK(10, 0) + +#define CLKMGR_BYPASS_MAINPLL_ALL 0xf6 +#define CLKMGR_BYPASS_PERPLL_ALL 0xef + +#define CLKMGR_NOCDIV_SOFTPHY_DIV_ONE 0 +#define CLKMGR_NOCDIV_SOFTPHY_DIV_TWO 1 +#define CLKMGR_NOCDIV_SOFTPHY_DIV_FOUR 2 +#define CLKMGR_NOCDIV_L4SYSFREECLK_OFFSET 0 +#define CLKMGR_NOCDIV_L4MPCLK_OFFSET 4 +#define CLKMGR_NOCDIV_L4SPCLK_OFFSET 6 +#define CLKMGR_NOCDIV_SOFTPHY_OFFSET 16 +#define CLKMGR_NOCDIV_CCU_OFFSET 18 +#define CLKMGR_NOCDIV_MPUPERIPH_OFFSET 20 +#define CLKMGR_NOCDIV_CSATCLK_OFFSET 24 +#define CLKMGR_NOCDIV_CSTRACECLK_OFFSET 26 +#define CLKMGR_NOCDIV_CSPDBGCLK_OFFSET 28 +#define CLKMGR_NOCDIV_DIVIDER_MASK 0x3 + +#define CLKMGR_PLLGLOB_PD_MASK BIT(0) +#define CLKMGR_PLLGLOB_RST_MASK BIT(1) +#define CLKMGR_PLLGLOB_AREFCLKDIV_MASK GENMASK(11, 8) +#define CLKMGR_PLLGLOB_DREFCLKDIV_MASK GENMASK(13, 12) +#define CLKMGR_PLLGLOB_REFCLKDIV_MASK GENMASK(13, 8) +#define CLKMGR_PLLGLOB_MODCLKDIV_MASK GENMASK(24, 27) +#define CLKMGR_PLLGLOB_AREFCLKDIV_OFFSET 8 +#define CLKMGR_PLLGLOB_DREFCLKDIV_OFFSET 12 +#define CLKMGR_PLLGLOB_REFCLKDIV_OFFSET 8 +#define CLKMGR_PLLGLOB_MODCLKDIV_OFFSET 24 +#define CLKMGR_PLLGLOB_VCO_PSRC_MASK GENMASK(17, 16) +#define CLKMGR_PLLGLOB_VCO_PSRC_OFFSET 16 +#define CLKMGR_PLLGLOB_CLR_LOSTLOCK_BYPASS_MASK BIT(29) + +#define CLKMGR_VCO_PSRC_EOSC1 0 +#define CLKMGR_VCO_PSRC_INTOSC 1 +#define CLKMGR_VCO_PSRC_F2S 2 + +#define CLKMGR_MEM_REQ_SET_MSK BIT(24) +#define CLKMGR_MEM_WR_SET_MSK BIT(25) +#define CLKMGR_MEM_ERR_MSK BIT(26) +#define CLKMGR_MEM_WDAT_LSB_OFFSET 16 +#define CLKMGR_MEM_ADDR_MASK GENMASK(15, 0) +#define CLKMGR_MEM_ADDR_START 0x00004000 + +#define CLKMGR_PLLCX_EN_SET_MSK BIT(27) +#define CLKMGR_PLLCX_MUTE_SET_MSK BIT(28) + +#define CLKMGR_VCOCALIB_MSCNT_MASK GENMASK(23, 16) +#define CLKMGR_VCOCALIB_MSCNT_OFFSET 16 +#define CLKMGR_VCOCALIB_HSCNT_MASK GENMASK(9, 0) +#define CLKMGR_VCOCALIB_MSCNT_CONST 100 +#define CLKMGR_VCOCALIB_HSCNT_CONST 4 + +#define CLKMGR_PLLM_MDIV_MASK GENMASK(9, 0) + +#define CLKMGR_LOSTLOCK_SET_MASK BIT(0) + +#define CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK BIT(5) +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_OFFSET 26 +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_MASK BIT(26) +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_OFFSET 27 +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_MASK BIT(27) +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_OFFSET 28 +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_MASK BIT(28) + +#define CLKMGR_CTL_EMACCTR_SRC_OFFSET 16 +#define CLKMGR_CTL_EMACCTR_SRC_MASK GENMASK(18, 16) +#define CLKMGR_CTL_EMACCTR_CNT_OFFSET 0 +#define CLKMGR_CTL_EMACCTR_CNT_MASK GENMASK(10, 0) + +#define CLKMGR_CTL_EXTCNTRST_EMACACNTRST BIT(0) +#define CLKMGR_CTL_EXTCNTRST_EMACBCNTRST BIT(1) +#define CLKMGR_CTL_EXTCNTRST_EMACPTPCNTRST BIT(2) +#define CLKMGR_CTL_EXTCNTRST_GPIODBCNTRST BIT(3) +#define CLKMGR_CTL_EXTCNTRST_S2FUSER0CNTRST BIT(5) +#define CLKMGR_CTL_EXTCNTRST_S2FUSER1CNTRST BIT(6) +#define CLKMGR_CTL_EXTCNTRST_PSIREFCNTRST BIT(7) +#define CLKMGR_CTL_EXTCNTRST_USB31REFCNTRST BIT(8) +#define CLKMGR_CTL_EXTCNTRST_DSUCNTRST BIT(10) +#define CLKMGR_CTL_EXTCNTRST_CORE01CNTRST BIT(11) +#define CLKMGR_CTL_EXTCNTRST_CORE2CNTRST BIT(12) +#define CLKMGR_CTL_EXTCNTRST_CORE3CNTRST BIT(13) +#define CLKMGR_CTL_EXTCNTRST_ALLCNTRST \ + (CLKMGR_CTL_EXTCNTRST_EMACACNTRST | \ + CLKMGR_CTL_EXTCNTRST_EMACBCNTRST | \ + CLKMGR_CTL_EXTCNTRST_EMACPTPCNTRST | \ + CLKMGR_CTL_EXTCNTRST_GPIODBCNTRST | \ + CLKMGR_CTL_EXTCNTRST_S2FUSER0CNTRST | \ + CLKMGR_CTL_EXTCNTRST_S2FUSER1CNTRST | \ + CLKMGR_CTL_EXTCNTRST_PSIREFCNTRST | \ + CLKMGR_CTL_EXTCNTRST_USB31REFCNTRST | \ + CLKMGR_CTL_EXTCNTRST_DSUCNTRST | \ + CLKMGR_CTL_EXTCNTRST_CORE01CNTRST | \ + CLKMGR_CTL_EXTCNTRST_CORE2CNTRST | \ + CLKMGR_CTL_EXTCNTRST_CORE3CNTRST) + +#define MEMBUS_MAINPLL 0 +#define MEMBUS_PERPLL 1 +#define MEMBUS_TIMEOUT 1000 + +#define MEMBUS_CLKSLICE_REG 0x27 +#define MEMBUS_SYNTHCALFOSC_INIT_CENTERFREQ_REG 0xb3 +#define MEMBUS_SYNTHPPM_WATCHDOGTMR_VF01_REG 0xe6 +#define MEMBUS_CALCLKSLICE0_DUTY_LOCOVR_REG 0x03 +#define MEMBUS_CALCLKSLICE1_DUTY_LOCOVR_REG 0x07 + +#define MPIDR_AFF1_OFFSET 8 +#define MPIDR_AFF1_MASK 0x3 +#endif /* _CLK_AGILEX5_ */ diff --git a/include/configs/socfpga_agilex5_socdk.h b/include/configs/socfpga_agilex5_socdk.h new file mode 100644 index 0000000000..b5b5bd767f --- /dev/null +++ b/include/configs/socfpga_agilex5_socdk.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2024 Intel Corporation <www.intel.com> + * + */ + +#ifndef __CONFIG_SOCFGPA_AGILEX5_H__ +#define __CONFIG_SOCFGPA_AGILEX5_H__ + +#include <configs/socfpga_soc64_common.h> + +#endif /* __CONFIG_SOCFGPA_AGILEX5_H__ */ diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 820372c28b..b7ee1dbf20 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0 * - * Copyright (C) 2017-2019 Intel Corporation <www.intel.com> + * Copyright (C) 2017-2024 Intel Corporation <www.intel.com> * */
@@ -26,8 +26,13 @@ /* * U-Boot run time memory configurations */ +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define CFG_SYS_INIT_RAM_ADDR 0x0 +#define CFG_SYS_INIT_RAM_SIZE 0x80000 +#else #define CFG_SYS_INIT_RAM_ADDR 0xFFE00000 #define CFG_SYS_INIT_RAM_SIZE 0x40000 +#endif
/* * U-Boot environment configurations @@ -36,9 +41,121 @@ /* * Environment variable */ +#if IS_ENABLED(CONFIG_DISTRO_DEFAULTS) +#if IS_ENABLED(CONFIG_CMD_MMC) +#define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) +#else +#define BOOT_TARGET_DEVICES_MMC(func) +#endif + +#if IS_ENABLED(CONFIG_CMD_SF) +#define BOOT_TARGET_DEVICES_QSPI(func) func(QSPI, qspi, na) +#else +#define BOOT_TARGET_DEVICES_QSPI(func) +#endif + +#define BOOTENV_DEV_QSPI(devtypeu, devtypel, instance) \ + "bootcmd_qspi=ubi detach; sf probe && " \ + "if ubi part root && ubi readvol ${scriptaddr} script; " \ + "then echo QSPI: Running script from UBIFS; " \ + "elif sf read ${scriptaddr} ${qspiscriptaddr} ${scriptsize}; " \ + "then echo QSPI: Running script from JFFS2; fi; " \ + "echo QSPI: Trying to boot script at ${scriptaddr} && " \ + "source ${scriptaddr}; " \ + "echo QSPI: SCRIPT FAILED: continuing...; ubi detach;\0" + +#define BOOTENV_DEV_NAME_QSPI(devtypeu, devtypel, instance) \ + "qspi " + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_DEVICES_MMC(func) \ + BOOT_TARGET_DEVICES_QSPI(func) + +#include <config_distro_bootcmd.h> + +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) + #define CFG_EXTRA_ENV_SETTINGS \ + "kernel_addr_r=0x82000000\0" \ + "fdt_addr_r=0x86000000\0" \ + "qspiscriptaddr=0x02110000\0" \ + "scriptsize=0x00010000\0" \ + "qspibootimageaddr=0x02120000\0" \ + "bootimagesize=0x03200000\0" \ "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "bootfile=" CONFIG_BOOTFILE "\0" \ + "mmcroot=/dev/mmcblk0p2\0" \ + "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ + "linux_qspi_enable=if sf probe; then " \ + "echo Enabling QSPI at Linux DTB...;" \ + "fdt addr ${fdt_addr}; fdt resize;" \ + "fdt set /soc/spi@108d2000 status okay;" \ + "if fdt set /clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " elif fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " else fdt set /clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; echo QSPI clock frequency updated; fi; fi\0" \ + "scriptaddr=0x81000000\0" \ + "scriptfile=boot.scr\0" \ + "socfpga_legacy_reset_compat=1\0" \ + "smc_fid_rd=0xC2000007\0" \ + "smc_fid_wr=0xC2000008\0" \ + "smc_fid_upd=0xC2000009\0 " \ + BOOTENV + +#else + +#define CFG_EXTRA_ENV_SETTINGS \ + "kernel_addr_r=0x2000000\0" \ + "fdt_addr_r=0x6000000\0" \ + "qspiscriptaddr=0x02110000\0" \ + "scriptsize=0x00010000\0" \ + "qspibootimageaddr=0x02120000\0" \ + "bootimagesize=0x03200000\0" \ + "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "bootfile=" CONFIG_BOOTFILE "\0" \ + "mmcroot=/dev/mmcblk0p2\0" \ + "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ + "linux_qspi_enable=if sf probe; then " \ + "echo Enabling QSPI at Linux DTB...;" \ + "fdt addr ${fdt_addr}; fdt resize;" \ + "fdt set /soc/spi@ff8d2000 status okay;" \ + "if fdt set /soc/clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " elif fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " else fdt set /clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; echo QSPI clock frequency updated; fi; fi\0" \ + "scriptaddr=0x05FF0000\0" \ + "scriptfile=boot.scr\0" \ + "socfpga_legacy_reset_compat=1\0" \ + "smc_fid_rd=0xC2000007\0" \ + "smc_fid_wr=0xC2000008\0" \ + "smc_fid_upd=0xC2000009\0 " \ + BOOTENV +#endif /*#IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5)*/ + +#else + +#define CFG_EXTRA_ENV_SETTINGS \ + "kernel_comp_addr_r=0x9000000\0" \ + "kernel_comp_size=0x01000000\0" \ + "qspibootimageaddr=0x020E0000\0" \ + "qspifdtaddr=0x020D0000\0" \ + "bootimagesize=0x01F00000\0" \ + "fdtimagesize=0x00010000\0" \ + "qspiload=sf read ${loadaddr} ${qspibootimageaddr} ${bootimagesize};" \ + "sf read ${fdt_addr} ${qspifdtaddr} ${fdtimagesize}\0" \ + "qspiboot=setenv bootargs earlycon root=/dev/mtdblock1 rw " \ + "rootfstype=jffs2 rootwait;booti ${loadaddr} - ${fdt_addr}\0" \ + "qspifitload=sf read ${loadaddr} ${qspibootimageaddr} ${bootimagesize}\0" \ + "qspifitboot=setenv bootargs earlycon root=/dev/mtdblock1 rw " \ + "rootfstype=jffs2 rootwait;bootm ${loadaddr}\0" \ + "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "bootfile=" CONFIG_BOOTFILE "\0" \ "fdt_addr=8000000\0" \ "fdtimage=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "mmcroot=/dev/mmcblk0p2\0" \ @@ -53,24 +170,40 @@ "bootm ${loadaddr}\0" \ "mmcfitload=mmc rescan;" \ "load mmc 0:1 ${loadaddr} ${bootfile}\0" \ + "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ "linux_qspi_enable=if sf probe; then " \ "echo Enabling QSPI at Linux DTB...;" \ "fdt addr ${fdt_addr}; fdt resize;" \ "fdt set /soc/spi@ff8d2000 status okay;" \ - "fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency " \ - " ${qspi_clock}; fi; \0" \ + "if fdt set /soc/clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " elif fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " else fdt set /clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; echo QSPI clock frequency updated; fi; fi\0" \ "scriptaddr=0x02100000\0" \ "scriptfile=u-boot.scr\0" \ "fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};" \ - "then source ${scriptaddr}; fi\0" \ - "socfpga_legacy_reset_compat=1\0" + "then source ${scriptaddr}:script; fi\0" \ + "socfpga_legacy_reset_compat=1\0" \ + "smc_fid_rd=0xC2000007\0" \ + "smc_fid_wr=0xC2000008\0" \ + "smc_fid_upd=0xC2000009\0 " +#endif /*#if IS_ENABLED(CONFIG_DISTRO_DEFAULTS)*/
/* * External memory configurations */ +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_1_SIZE (1 * 1024 * 1024 * 1024) +#define CFG_SYS_SDRAM_BASE 0x80000000 +#else #define PHYS_SDRAM_1 0x0 #define PHYS_SDRAM_1_SIZE (1 * 1024 * 1024 * 1024) #define CFG_SYS_SDRAM_BASE 0 +#endif
/* * Serial / UART configurations diff --git a/include/dt-bindings/clock/agilex5-clock.h b/include/dt-bindings/clock/agilex5-clock.h new file mode 100644 index 0000000000..c84fa51540 --- /dev/null +++ b/include/dt-bindings/clock/agilex5-clock.h @@ -0,0 +1,71 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2024, Intel Corporation + */ + +#ifndef __AGILEX5_CLOCK_H +#define __AGILEX5_CLOCK_H + +/* fixed rate clocks */ +#define AGILEX5_OSC1 0 +#define AGILEX5_CB_INTOSC_HS_DIV2_CLK 1 +#define AGILEX5_CB_INTOSC_LS_CLK 2 +#define AGILEX5_L4_SYS_FREE_CLK 3 +#define AGILEX5_F2S_FREE_CLK 4 + +/* PLL clocks */ +#define AGILEX5_MAIN_PLL_CLK 5 +#define AGILEX5_MAIN_PLL_C0_CLK 6 +#define AGILEX5_MAIN_PLL_C1_CLK 7 +#define AGILEX5_MAIN_PLL_C2_CLK 8 +#define AGILEX5_MAIN_PLL_C3_CLK 9 +#define AGILEX5_PERIPH_PLL_CLK 10 +#define AGILEX5_PERIPH_PLL_C0_CLK 11 +#define AGILEX5_PERIPH_PLL_C1_CLK 12 +#define AGILEX5_PERIPH_PLL_C2_CLK 13 +#define AGILEX5_PERIPH_PLL_C3_CLK 14 +#define AGILEX5_MPU_FREE_CLK 15 +#define AGILEX5_MPU_CCU_CLK 16 +#define AGILEX5_BOOT_CLK 17 + +/* fixed factor clocks */ +#define AGILEX5_L3_MAIN_FREE_CLK 18 +#define AGILEX5_NOC_FREE_CLK 19 +#define AGILEX5_S2F_USR0_CLK 20 +#define AGILEX5_NOC_CLK 21 +#define AGILEX5_EMAC_A_FREE_CLK 22 +#define AGILEX5_EMAC_B_FREE_CLK 23 +#define AGILEX5_EMAC_PTP_FREE_CLK 24 +#define AGILEX5_GPIO_DB_FREE_CLK 25 +#define AGILEX5_SDMMC_FREE_CLK 26 +#define AGILEX5_S2F_USER0_FREE_CLK 27 +#define AGILEX5_S2F_USER1_FREE_CLK 28 +#define AGILEX5_PSI_REF_FREE_CLK 29 + +/* Gate clocks */ +#define AGILEX5_MPU_CLK 30 +#define AGILEX5_MPU_PERIPH_CLK 31 +#define AGILEX5_L4_MAIN_CLK 32 +#define AGILEX5_L4_MP_CLK 33 +#define AGILEX5_L4_SP_CLK 34 +#define AGILEX5_CS_AT_CLK 35 +#define AGILEX5_CS_TRACE_CLK 36 +#define AGILEX5_CS_PDBG_CLK 37 +#define AGILEX5_CS_TIMER_CLK 38 +#define AGILEX5_S2F_USER0_CLK 39 +#define AGILEX5_EMAC0_CLK 40 +#define AGILEX5_EMAC1_CLK 41 +#define AGILEX5_EMAC2_CLK 42 +#define AGILEX5_EMAC_PTP_CLK 43 +#define AGILEX5_GPIO_DB_CLK 44 +#define AGILEX5_NAND_CLK 45 +#define AGILEX5_PSI_REF_CLK 46 +#define AGILEX5_S2F_USER1_CLK 47 +#define AGILEX5_SDMMC_CLK 48 +#define AGILEX5_SPI_M_CLK 49 +#define AGILEX5_USB_CLK 50 +#define AGILEX5_NAND_X_CLK 51 +#define AGILEX5_NAND_ECC_CLK 52 +#define AGILEX5_NUM_CLKS 53 + +#endif /* __AGILEX5_CLOCK_H */ diff --git a/include/dt-bindings/reset/altr,rst-mgr-agx5.h b/include/dt-bindings/reset/altr,rst-mgr-agx5.h new file mode 100644 index 0000000000..1dba270aed --- /dev/null +++ b/include/dt-bindings/reset/altr,rst-mgr-agx5.h @@ -0,0 +1,80 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2024 Intel Corporation. All rights reserved + */ + +#ifndef _DT_BINDINGS_RESET_ALTR_RST_MGR_AGX_EDGE_H +#define _DT_BINDINGS_RESET_ALTR_RST_MGR_AGX_EDGE_H + +/* PER0MODRST */ +#define EMAC0_RESET 0 +#define EMAC1_RESET 1 +#define EMAC2_RESET 2 +#define USB0_RESET 3 +#define USB1_RESET 4 +#define NAND_RESET 5 +#define COMBOPHY_RESET 6 +#define SDMMC_RESET 7 +#define EMAC0_OCP_RESET 8 +#define EMAC1_OCP_RESET 9 +#define EMAC2_OCP_RESET 10 +#define USB0_OCP_RESET 11 +#define USB1_OCP_RESET 12 +#define NAND_OCP_RESET 13 +/* 14 is empty */ +#define SDMMC_OCP_RESET 15 +#define DMA_RESET 16 +#define SPIM0_RESET 17 +#define SPIM1_RESET 18 +#define SPIS0_RESET 19 +#define SPIS1_RESET 20 +#define DMA_OCP_RESET 21 +#define EMAC_PTP_RESET 22 +/* 23 is empty*/ +#define DMAIF0_RESET 24 +#define DMAIF1_RESET 25 +#define DMAIF2_RESET 26 +#define DMAIF3_RESET 27 +#define DMAIF4_RESET 28 +#define DMAIF5_RESET 29 +#define DMAIF6_RESET 30 +#define DMAIF7_RESET 31 + +/* PER1MODRST */ +#define WATCHDOG0_RESET 32 +#define WATCHDOG1_RESET 33 +#define WATCHDOG2_RESET 34 +#define WATCHDOG3_RESET 35 +#define L4SYSTIMER0_RESET 36 +#define L4SYSTIMER1_RESET 37 +#define SPTIMER0_RESET 38 +#define SPTIMER1_RESET 39 +#define I2C0_RESET 40 +#define I2C1_RESET 41 +#define I2C2_RESET 42 +#define I2C3_RESET 43 +#define I2C4_RESET 44 +#define I3C0_RESET 45 +#define I3C1_RESET 46 +/* 47 is empty */ +#define UART0_RESET 48 +#define UART1_RESET 49 +/* 50-55 is empty */ +#define GPIO0_RESET 56 +#define GPIO1_RESET 57 +#define WATCHDOG4_RESET 58 +/* 59-63 is empty */ + +/* BRGMODRST */ +#define SOC2FPGA_RESET 64 +#define LWHPS2FPGA_RESET 65 +#define FPGA2SOC_RESET 66 +#define F2SSDRAM_RESET 67 +/* 68-69 is empty */ +#define DDRSCH_RESET 70 +/* 71-95 is empty */ + +/* DBGMODRST */ +#define DBG_RESET 192 + +#endif
-----Original Message----- From: Lim, Jit Loon jit.loon.lim@intel.com Sent: Thursday, March 7, 2024 12:42 AM To: u-boot@lists.denx.de Cc: Jagan Teki jagan@amarulasolutions.com; Marek marex@denx.de; Simon simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com; Maniyam, Dinesh dinesh.maniyam@intel.com; Ng, Boon Khai boon.khai.ng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Chong, Teik Heng teik.heng.chong@intel.com; Zamri, Muhammad Hazim Izzat muhammad.hazim.izzat.zamri@intel.com; Lim, Jit Loon jit.loon.lim@intel.com; Tang, Sieu Mun sieu.mun.tang@intel.com; Bin Meng bmeng.cn@gmail.com Subject: [RESEND v2 1/1] arch: arm: Agilex5 enablement
This patch is to enable Agilex5 platform for Intel product. Changes, modification and new files are created for board, dts, configs and makefile to create the base for Agilex5.
Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com
Changes v1 -> v2:
- fixed git auto merge issue
arch/arm/Kconfig | 4 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 71 ++ arch/arm/dts/socfpga_agilex5.dtsi | 575 ++++++++++++++ .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 134 ++++ arch/arm/dts/socfpga_agilex5_socdk.dts | 163 ++++ arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi | 38 +- arch/arm/mach-socfpga/Kconfig | 19 +- arch/arm/mach-socfpga/Makefile | 14 +- arch/arm/mach-socfpga/board.c | 56 +- arch/arm/mach-socfpga/clock_manager_agilex5.c | 89 +++ .../include/mach/base_addr_soc64.h | 38 +- .../mach-socfpga/include/mach/clock_manager.h | 4 +- .../include/mach/clock_manager_agilex5.h | 12 + .../mach-socfpga/include/mach/handoff_soc64.h | 31 +- .../mach-socfpga/include/mach/mailbox_s10.h | 1 + arch/arm/mach-socfpga/mmu-arm64_s10.c | 59 +- board/intel/agilex5-socdk/MAINTAINERS | 8 + configs/socfpga_agilex5_defconfig | 116 +++ drivers/clk/altera/Makefile | 1 + drivers/clk/altera/clk-agilex5.c | 743 ++++++++++++++++++ drivers/clk/altera/clk-agilex5.h | 284 +++++++ include/configs/socfpga_agilex5_socdk.h | 12 + include/configs/socfpga_soc64_common.h | 143 +++- include/dt-bindings/clock/agilex5-clock.h | 71 ++ include/dt-bindings/reset/altr,rst-mgr-agx5.h | 80 ++ 26 files changed, 2731 insertions(+), 36 deletions(-) create mode 100644 arch/arm/dts/socfpga_agilex5-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk.dts create mode 100644 arch/arm/mach-socfpga/clock_manager_agilex5.c create mode 100644 arch/arm/mach- socfpga/include/mach/clock_manager_agilex5.h create mode 100644 board/intel/agilex5-socdk/MAINTAINERS create mode 100644 configs/socfpga_agilex5_defconfig create mode 100644 drivers/clk/altera/clk-agilex5.c create mode 100644 drivers/clk/altera/clk-agilex5.h create mode 100644 include/configs/socfpga_agilex5_socdk.h create mode 100644 include/dt-bindings/clock/agilex5-clock.h create mode 100644 include/dt-bindings/reset/altr,rst-mgr-agx5.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index fde85dc0d5..6df805f44c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -28,6 +28,7 @@ config COUNTER_FREQUENCY ROCKCHIP_RK3288 || ROCKCHIP_RK322X || ROCKCHIP_RK3036 default 25000000 if ARCH_LX2160A || ARCH_LX2162A || ARCH_LS1088A default 100000000 if ARCH_ZYNQMP
- default 200000000 if ARCH_SOCFPGA && ARM64 &&
TARGET_SOCFPGA_AGILEX5 default 0 help For platforms with ARMv8-A and ARMv7-A which features a system @@ -1124,7 +1125,8 @@ config ARCH_SOCFPGA select SYS_THUMB_BUILD if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select SYSRESET select SYSRESET_SOCFPGA if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10
- select SYSRESET_SOCFPGA_SOC64 if TARGET_SOCFPGA_SOC64
- select SYSRESET_SOCFPGA_SOC64 if !TARGET_SOCFPGA_AGILEX5 &&
imply CMD_DM imply CMD_MTDPARTS imply CRC32_VERIFYTARGET_SOCFPGA_SOC64
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d9725030d5..2b4f896ad2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -548,6 +548,7 @@ dtb-$(CONFIG_TARGET_THUNDERX_88XX) += thunderx-88xx.dtb
dtb-$(CONFIG_ARCH_SOCFPGA) += \ socfpga_agilex_socdk.dtb \
- socfpga_agilex5_socdk.dtb \ socfpga_arria5_secu1.dtb \ socfpga_arria5_socdk.dtb \ socfpga_arria10_chameleonv3_270_2.dtb \
diff --git a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi new file mode 100644 index 0000000000..a8167e5c14 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- U-Boot additions
- Copyright (C) 2024 Intel Corporation <www.intel.com>
+#include "socfpga_soc64_fit-u-boot.dtsi"
- memory {
#address-cells = <2>;
#size-cells = <2>;
bootph-all;
+&clkmgr {
- bootph-all;
+&i2c0 {
- reset-names = "i2c";
+&i2c1 {
+&i2c2 {
+&i2c3 {
+&mmc {
- resets = <&rst SDMMC_RESET>, <&rst SDMMC_OCP_RESET>;
+&porta {
- bank-name = "porta";
+&portb {
- bank-name = "portb";
+&qspi {
- bootph-all;
+&rst {
- compatible = "altr,rst-mgr";
- altr,modrst-offset = <0x24>;
- bootph-all;
+&sysmgr {
- compatible = "altr,sys-mgr", "syscon";
- bootph-all;
+&uart0 {
- bootph-all;
+&watchdog0 {
- bootph-all;
+}; diff --git a/arch/arm/dts/socfpga_agilex5.dtsi b/arch/arm/dts/socfpga_agilex5.dtsi new file mode 100644 index 0000000000..03b5504049 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5.dtsi @@ -0,0 +1,575 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+/dts-v1/; +#include <dt-bindings/reset/altr,rst-mgr-agx5.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/agilex5-clock.h>
- compatible = "intel,socfpga-agilex";
- #address-cells = <2>;
- #size-cells = <2>;
- reserved-memory {
#size-cells = <2>;
ranges;
service_reserved: svcbuffer@0 {
compatible = "shared-dma-pool";
reg = <0x0 0x0 0x0 0x1000000>;
alignment = <0x1000>;
no-map;
- cpus {
#address-cells = <1>;
#size-cells = <0>;
cpu0: cpu@0 {
compatible = "arm,cortex-a55";
device_type = "cpu";
enable-method = "psci";
reg = <0x0>;
cpu1: cpu@1 {
reg = <0x1>;
cpu2: cpu@2 {
compatible = "arm,cortex-a76";
reg = <0x2>;
cpu3: cpu@3 {
reg = <0x3>;
- pmu {
compatible = "arm,armv8-pmuv3";
interrupts = <0 170 4>,
<0 171 4>,
<0 172 4>,
<0 173 4>;
interrupt-affinity = <&cpu0>,
<&cpu1>,
<&cpu2>,
<&cpu3>;
interrupt-parent = <&intc>;
- psci {
compatible = "arm,psci-0.2";
method = "smc";
- intc: intc@fffc1000 {
compatible = "arm,gic-400", "arm,cortex-a15-gic";
#interrupt-cells = <3>;
interrupt-controller;
reg = <0x0 0x1d000000 0x0 0x10000>;
- soc {
#size-cells = <1>;
compatible = "simple-bus";
device_type = "soc";
ranges = <0 0 0 0xffffffff>;
base_fpga_region {
#address-cells = <0x1>;
#size-cells = <0x1>;
compatible = "fpga-region";
fpga-mgr = <&fpga_mgr>;
clkmgr: clock-controller@10d10000 {
compatible = "intel,agilex5-clkmgr";
reg = <0x10d10000 0x1000>;
#clock-cells = <1>;
clocks {
cb_intosc_hs_div2_clk: cb-intosc-hs-div2-clk {
#clock-cells = <0>;
compatible = "fixed-clock";
cb_intosc_ls_clk: cb-intosc-ls-clk {
#clock-cells = <0>;
f2s_free_clk: f2s-free-clk {
#clock-cells = <0>;
osc1: osc1 {
#clock-cells = <0>;
qspi_clk: qspi-clk {
#clock-cells = <0>;
clock-frequency = <200000000>;
gmac0: ethernet@10810000 {
compatible = "intel,socfpga-dwxgmac",
"snps,dwxgmac-2.10", "snps,dwxgmac";
reg = <0x10810000 0x3500>;
interrupts = <0 190 4>;
interrupt-names = "macirq";
mac-address = [00 00 00 00 00 00];
resets = <&rst EMAC0_RESET>, <&rst
EMAC0_OCP_RESET>;
reset-names = "stmmaceth", "stmmaceth-ocp";
tx-fifo-depth = <32768>;
rx-fifo-depth = <16384>;
iommus = <&smmu 1>;
altr,sysmgr-syscon = <&sysmgr 0x44 0>;
clocks = <&clkmgr AGILEX5_EMAC0_CLK>;
clock-names = "stmmaceth";
status = "disabled";
gmac1: ethernet@10820000 {
reg = <0x10820000 0x3500>;
interrupts = <0 207 4>;
resets = <&rst EMAC1_RESET>, <&rst
EMAC1_OCP_RESET>;
iommus = <&smmu 2>;
altr,sysmgr-syscon = <&sysmgr 0x48 0>;
clocks = <&clkmgr AGILEX5_EMAC1_CLK>;
gmac2: ethernet@10830000 {
reg = <0x10830000 0x3500>;
interrupts = <0 224 4>;
resets = <&rst EMAC2_RESET>, <&rst
EMAC2_OCP_RESET>;
iommus = <&smmu 3>;
altr,sysmgr-syscon = <&sysmgr 0x4c 0>;
clocks = <&clkmgr AGILEX5_EMAC2_CLK>;
gpio0: gpio@10c03200 {
#size-cells = <0>;
compatible = "snps,dw-apb-gpio";
reg = <0x10c03200 0x80>;
resets = <&rst GPIO0_RESET>;
porta: gpio-controller@0 {
compatible = "snps,dw-apb-gpio-port";
gpio-controller;
#gpio-cells = <2>;
snps,nr-gpios = <24>;
reg = <0>;
#interrupt-cells = <2>;
interrupts = <0 110 4>;
gpio1: gpio@10c03300 {
#size-cells = <0>;
reg = <0x10c03300 0x80>;
resets = <&rst GPIO1_RESET>;
portb: gpio-controller@0 {
gpio-controller;
#gpio-cells = <2>;
reg = <0>;
interrupts = <0 111 4>;
i2c0: i2c@10c02800 {
#size-cells = <0>;
compatible = "snps,designware-i2c";
reg = <0x10c02800 0x100>;
interrupts = <0 103 4>;
resets = <&rst I2C0_RESET>;
clocks = <&clkmgr AGILEX5_L4_SP_CLK>;
i2c1: i2c@10c02900 {
#size-cells = <0>;
reg = <0x10c02900 0x100>;
interrupts = <0 104 4>;
resets = <&rst I2C1_RESET>;
i2c2: i2c@10c02a00 {
#size-cells = <0>;
reg = <0x10c02a00 0x100>;
interrupts = <0 105 4>;
resets = <&rst I2C2_RESET>;
i2c3: i2c@10c02b00 {
#size-cells = <0>;
reg = <0x10c02b00 0x100>;
interrupts = <0 106 4>;
resets = <&rst I2C3_RESET>;
i2c4: i2c@10c02c00 {
#size-cells = <0>;
reg = <0x10c02c00 0x100>;
interrupts = <0 107 4>;
resets = <&rst I2C4_RESET>;
i3c0: i3c@10da0000 {
compatible = "snps,dw-i3c-master-1.00a";
reg = <0x10da0000 0x1000>;
#size-cells = <0>;
interrupts = <0 164 4>;
resets = <&rst I3C0_RESET>;
max_devices = <11>;
clocks = <&clkmgr AGILEX5_L4_MP_CLK>;
i3c1: i3c@10da1000 {
reg = <0x10da1000 0x1000>;
#size-cells = <0>;
interrupts = <0 165 4>;
resets = <&rst I3C1_RESET>;
max_devices = <11>;
combophy0: combophy@0 {
#phy-cells = <0>;
phy-type = <1>;
compatible = "cdns,combophy";
reg = <0x10808000 0x1000>;
resets = <&rst COMBOPHY_RESET>;
reset-names = "reset";
mmc: mmc0@10808000 {
#size-cells = <0>;
compatible = "cdns,sd4hc";
interrupts = <0 96 4>;
phys = <&combophy0>;
phy-names = "combo-phy";
clocks = <&clkmgr AGILEX5_L4_MP_CLK>,
<&clkmgr AGILEX5_SDMMC_CLK>;
clock-names = "biu", "ciu";
fifo-depth = <0x800>;
resets = <&rst SDMMC_RESET>;
iommus = <&smmu 5>;
ocram: sram@00000000 {
compatible = "mmio-sram";
reg = <0x00000000 0x200000>;
rst: rstmgr@10d11000 {
#reset-cells = <1>;
compatible = "altr,stratix10-rst-mgr";
reg = <0x10d11000 0x1000>;
smmu: iommu@16000000 {
compatible = "arm,mmu-500", "arm,smmu-v2";
reg = <0x16000000 0x40000>;
#global-interrupts = <2>;
#iommu-cells = <1>;
interrupts = <0 128 4>, /* Global Secure Fault */
<0 129 4>, /* Global Non-secure Fault */
/* Non-secure Context Interrupts (32) */
<0 138 4>, <0 139 4>, <0 140 4>, <0 141 4>,
<0 142 4>, <0 143 4>, <0 144 4>, <0 145 4>,
<0 146 4>, <0 147 4>, <0 148 4>, <0 149 4>,
<0 150 4>, <0 151 4>, <0 152 4>, <0 153 4>,
<0 154 4>, <0 155 4>, <0 156 4>, <0 157 4>,
<0 158 4>, <0 159 4>, <0 160 4>, <0 161 4>,
<0 162 4>, <0 163 4>, <0 164 4>, <0 165 4>,
<0 166 4>, <0 167 4>, <0 168 4>, <0 169 4>;
stream-match-mask = <0x7ff0>;
spi0: spi@10da4000 {
compatible = "intel,agilex-spi",
"snps,dw-apb-ssi-4.00a", "snps,dw-apb-ssi";
#size-cells = <0>;
reg = <0x10da4000 0x1000>;
interrupts = <0 99 4>;
resets = <&rst SPIM0_RESET>;
reg-io-width = <4>;
num-cs = <4>;
clocks = <&clkmgr AGILEX5_L4_MAIN_CLK>;
spi1: spi@10da5000 {
#size-cells = <0>;
reg = <0x10da5000 0x1000>;
interrupts = <0 100 4>;
resets = <&rst SPIM1_RESET>;
reg-io-width = <4>;
num-cs = <4>;
sysmgr: sysmgr@10d12000 {
compatible = "altr,sys-mgr-s10","altr,sys-mgr";
reg = <0x10d12000 0x500>;
/* Local timer */
timer {
compatible = "arm,armv8-timer";
interrupts = <1 13 0xf08>,
<1 14 0xf08>,
<1 11 0xf08>,
<1 10 0xf08>;
timer0: timer0@10c03000 {
compatible = "snps,dw-apb-timer";
interrupts = <0 113 4>;
reg = <0x10c03000 0x100>;
resets = <&rst SPTIMER0_RESET>;
clock-names = "timer";
timer1: timer1@10c03100 {
interrupts = <0 114 4>;
reg = <0x10c03100 0x100>;
resets = <&rst SPTIMER1_RESET>;
timer2: timer2@10d00000 {
interrupts = <0 115 4>;
reg = <0x10d00000 0x100>;
resets = <&rst L4SYSTIMER0_RESET>;
clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>;
timer3: timer3@10d00100 {
interrupts = <0 116 4>;
reg = <0x10d00100 0x100>;
resets = <&rst L4SYSTIMER1_RESET>;
uart0: serial0@10c02000 {
compatible = "snps,dw-apb-uart";
reg = <0x10c02000 0x100>;
interrupts = <0 108 4>;
reg-shift = <2>;
reg-io-width = <4>;
resets = <&rst UART0_RESET>;
clock-frequency = <100000000>;
uart1: serial1@10c02100 {
reg = <0x10c02100 0x100>;
interrupts = <0 109 4>;
reg-shift = <2>;
reg-io-width = <4>;
resets = <&rst UART1_RESET>;
usbphy0: usbphy@0 {
#phy-cells = <0>;
compatible = "usb-nop-xceiv";
clocks = <&clkmgr AGILEX5_USB_CLK>;
usb0: usb@10b00000 {
compatible = "snps,dwc2";
reg = <0x10b00000 0x40000>;
interrupts = <0 93 4>;
phys = <&usbphy0>;
phy-names = "usb2-phy";
resets = <&rst USB0_RESET>, <&rst
USB0_OCP_RESET>;
reset-names = "dwc2", "dwc2-ecc";
iommus = <&smmu 6>;
usb31: usb31@11000000 {
compatible = "snps,dwc3";
reg = <0x11000000 0x100000>;
resets = <&rst USB1_RESET>;
phys = <&usbphy0>, <&usbphy0>;
phy-names = "usb2-phy", "usb3-phy";
dr_mode = "host";
maximum-speed = "super-speed";
snps,dis_u2_susphy_quirk;
watchdog0: watchdog@10d00200 {
compatible = "snps,dw-wdt";
reg = <0x10d00200 0x100>;
interrupts = <0 117 4>;
resets = <&rst WATCHDOG0_RESET>;
watchdog1: watchdog@10d00300 {
reg = <0x10d00300 0x100>;
interrupts = <0 118 4>;
resets = <&rst WATCHDOG1_RESET>;
watchdog2: watchdog@10d00400 {
reg = <0x10d00400 0x100>;
interrupts = <0 125 4>;
resets = <&rst WATCHDOG2_RESET>;
watchdog3: watchdog@10d00500 {
reg = <0x10d00500 0x100>;
interrupts = <0 126 4>;
resets = <&rst WATCHDOG3_RESET>;
watchdog4: watchdog@10d00600 {
reg = <0x10d00600 0x100>;
interrupts = <0 175 4>;
resets = <&rst WATCHDOG4_RESET>;
/* QSPI address not available yet */
qspi: spi@108d2000 {
compatible = "cdns,qspi-nor";
#size-cells = <0>;
reg = <0x108d2000 0x100>,
<0x10900000 0x100000>;
interrupts = <0 3 4>;
cdns,fifo-depth = <128>;
cdns,fifo-width = <4>;
cdns,trigger-address = <0x00000000>;
clocks = <&qspi_clk>;
firmware {
svc {
compatible = "intel,stratix10-svc";
method = "smc";
memory-region = <&service_reserved>;
fpga_mgr: fpga-mgr {
compatible = "intel,stratix10-soc-fpga-
mgr";
+}; diff --git a/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi new file mode 100644 index 0000000000..fb86b1d9d7 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi @@ -0,0 +1,134 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- U-Boot additions
+#include "socfpga_agilex5-u-boot.dtsi"
- aliases {
spi0 = &qspi;
freeze_br0 = &freeze_controller;
- soc {
freeze_controller: freeze_controller@0x20000450 {
compatible = "altr,freeze-bridge-controller";
reg = <0x20000450 0x00000010>;
- memory {
/* 8GB */
reg = <0 0x80000000 0 0x80000000>,
<8 0x80000000 1 0x80000000>;
- chosen {
stdout-path = "serial0:115200n8";
u-boot,spl-boot-order = &mmc,&flash0,"/memory";
+&flash0 {
- compatible = "jedec,spi-nor";
- spi-tx-bus-width = <4>;
- spi-rx-bus-width = <4>;
- bootph-all;
- /delete-property/ cdns,read-delay;
+&i3c0 {
- bootph-all;
+&i3c1 {
- bootph-all;
+&mmc {
- status = "okay";
- bus-width = <4>;
- sd-uhs-sdr50;
- cap-mmc-highspeed;
- bootph-all;
+&combophy0 {
- status = "okay";
- bootph-all;
- cdns,phy-use-ext-lpbk-dqs = <1>;
- cdns,phy-use-lpbk-dqs = <1>;
- cdns,phy-use-phony-dqs = <1>;
- cdns,phy-use-phony-dqs-cmd = <1>;
- cdns,phy-io-mask-always-on = <0>;
- cdns,phy-io-mask-end = <5>;
- cdns,phy-io-mask-start = <0>;
- cdns,phy-data-select-oe-end = <1>;
- cdns,phy-sync-method = <1>;
- cdns,phy-sw-half-cycle-shift = <0>;
- cdns,phy-rd-del-sel = <52>;
- cdns,phy-underrun-suppress = <1>;
- cdns,phy-gate-cfg-always-on = <1>;
- cdns,phy-param-dll-bypass-mode = <1>;
- cdns,phy-param-phase-detect-sel = <2>;
- cdns,phy-param-dll-start-point = <254>;
- cdns,phy-read-dqs-cmd-delay = <0>;
- cdns,phy-clk-wrdqs-delay = <0>;
- cdns,phy-clk-wr-delay = <0>;
- cdns,phy-read-dqs-delay = <0>;
- cdns,phy-phony-dqs-timing = <0>;
- cdns,hrs09-rddata-en = <1>;
- cdns,hrs09-rdcmd-en = <1>;
- cdns,hrs09-extended-wr-mode = <1>;
- cdns,hrs09-extended-rd-mode = <1>;
- cdns,hrs10-hcsdclkadj = <3>;
- cdns,hrs16-wrdata1-sdclk-dly = <0>;
- cdns,hrs16-wrdata0-sdclk-dly = <0>;
- cdns,hrs16-wrcmd1-sdclk-dly = <0>;
- cdns,hrs16-wrcmd0-sdclk-dly = <0>;
- cdns,hrs16-wrdata1-dly = <0>;
- cdns,hrs16-wrdata0-dly = <0>;
- cdns,hrs16-wrcmd1-dly = <0>;
- cdns,hrs16-wrcmd0-dly = <0>;
- cdns,hrs07-rw-compensate = <10>;
- cdns,hrs07-idelay-val = <0>;
+&qspi {
- status = "okay";
+&timer0 {
- bootph-all;
+&timer1 {
- bootph-all;
+&timer2 {
- bootph-all;
+&timer3 {
- bootph-all;
+&watchdog0 {
- bootph-all;
+#if !defined(CONFIG_SOCFPGA_SECURE_VAB_AUTH) +&fdt_0_blob {
- filename = "arch/arm/dts/socfpga_agilex5_socdk.dtb";
+&binman {
- /delete-node/ kernel;
+}; +#endif
diff --git a/arch/arm/dts/socfpga_agilex5_socdk.dts b/arch/arm/dts/socfpga_agilex5_socdk.dts new file mode 100644 index 0000000000..852e1e5ae3 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5_socdk.dts @@ -0,0 +1,163 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include "socfpga_agilex5.dtsi"
- model = "SoCFPGA Agilex5 SoCDK";
- aliases {
serial0 = &uart0;
ethernet0 = &gmac0;
ethernet2 = &gmac2;
- leds {
compatible = "gpio-leds";
hps0 {
label = "hps_led0";
gpios = <&portb 20 GPIO_ACTIVE_HIGH>;
hps1 {
label = "hps_led1";
gpios = <&portb 19 GPIO_ACTIVE_HIGH>;
hps2 {
label = "hps_led2";
gpios = <&portb 21 GPIO_ACTIVE_HIGH>;
- memory {
device_type = "memory";
/* We expect the bootloader to fill in the reg */
reg = <0 0 0 0>;
- soc {
clocks {
osc1 {
clock-frequency = <25000000>;
+&gpio0 {
- status = "okay";
+&gpio1 {
- status = "okay";
+&i2c0 {
- status = "okay";
+&i2c1 {
- status = "okay";
+&i3c0 {
- status = "okay";
+&i3c1 {
- status = "okay";
+&uart0 {
- status = "okay";
+&usbphy0 {
- status = "okay";
+&usb0 {
- status = "okay";
- disable-over-current;
+&watchdog0 {
- status = "okay";
+&watchdog1 {
- status = "okay";
+&watchdog2 {
- status = "okay";
+&watchdog3 {
- status = "okay";
+&watchdog4 {
- status = "okay";
+&timer0 {
- status = "okay";
+&timer1 {
- status = "okay";
+&timer2 {
- status = "okay";
+&timer3 {
- status = "okay";
+&spi0 {
- status = "okay";
+&spi1 {
- status = "okay";
+&qspi {
- flash0: flash@0 {
#size-cells = <1>;
compatible = "mt25qu02g";
reg = <0>;
spi-max-frequency = <100000000>;
m25p,fast-read;
cdns,page-size = <256>;
cdns,block-size = <16>;
cdns,read-delay = <1>;
cdns,tshsl-ns = <50>;
cdns,tsd2d-ns = <50>;
cdns,tchsh-ns = <4>;
cdns,tslch-ns = <4>;
partitions {
compatible = "fixed-partitions";
#size-cells = <1>;
qspi_boot: partition@0 {
label = "u-boot";
reg = <0x0 0x04200000>;
root: partition@4200000 {
label = "root";
reg = <0x04200000 0x0BE00000>;
+}; diff --git a/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi b/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi index 84b91e8df0..15306db600 100644 --- a/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi +++ b/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi @@ -2,7 +2,7 @@ /*
- U-Boot additions
- Copyright (C) 2020 Intel Corporation <www.intel.com>
- Copyright (C) 2020-2024 Intel Corporation <www.intel.com>
#if defined(CONFIG_FIT) @@ -21,14 +21,18 @@ description = "FIT with firmware and bootloader"; #address-cells = <1>;
images {
images: images { uboot { description = "U-Boot SoC64"; type = "standalone"; os = "U-Boot"; arch = "arm64"; compression = "none";
#if
load = <0x80200000>;
#else load = <0x00200000>;
#endif uboot_blob: blob-ext { filename = "u-boot-nodtb.bin"; };
@@ -43,8 +47,13 @@ os = "arm-trusted-firmware"; arch = "arm64"; compression = "none";
#if
load = <0x80000000>;
entry = <0x80000000>;
#else load = <0x00001000>; entry = <0x00001000>;
#endif atf_blob: blob-ext { filename = "bl31.bin"; };
@@ -53,11 +62,11 @@ }; };
fdt {
description = "U-Boot SoC64 flat
device-tree";
fdt-0 {
description = "socfpga_socdk"; type = "flat_dt"; compression = "none";
uboot_fdt_blob: blob-ext {
fdt_0_blob: blob-ext { filename = "u-boot.dtb"; }; hash {
@@ -66,17 +75,18 @@ }; };
configurations {
default = "conf";
conf {
description = "Intel SoC64 FPGA";
board_config: configurations {
default = "board-0";
board-0 {
description = "board_0"; firmware = "atf"; loadables = "uboot";
fdt = "fdt";
fdt = "fdt-0"; signature { algo = "crc32"; key-name-hint = "dev";
sign-images = "atf", "fdt",
"uboot";
sign-images = "atf", "uboot",
"fdt-0"; }; }; }; @@ -96,8 +106,8 @@ arch = "arm64"; os = "linux"; compression = "none";
load = <0x4080000>;
entry = <0x4080000>;
load = <0x6000000>;
entry = <0x6000000>; kernel_blob: blob-ext { filename = "Image"; };
@@ -146,7 +156,7 @@ filename = "signed-bl31.bin"; };
-&uboot_fdt_blob { +&fdt_0_blob { filename = "signed-u-boot.dtb"; };
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 114d243812..1008232cac 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -8,7 +8,8 @@ config NR_DRAM_BANKS
config SOCFPGA_SECURE_VAB_AUTH bool "Enable boot image authentication with Secure Device Manager"
- depends on TARGET_SOCFPGA_AGILEX || TARGET_SOCFPGA_N5X
- depends on TARGET_SOCFPGA_AGILEX || TARGET_SOCFPGA_N5X || \
select FIT_IMAGE_POST_PROCESS select SHA384 select SHA512TARGET_SOCFPGA_AGILEX5
@@ -58,6 +59,15 @@ config TARGET_SOCFPGA_AGILEX select SPL_CLK if SPL select TARGET_SOCFPGA_SOC64
+config TARGET_SOCFPGA_AGILEX5
- bool
- select BINMAN if SPL_ATF
- select CLK
- select FPGA_INTEL_SDM_MAILBOX
- select GICV3
- select SPL_CLK if SPL
- select TARGET_SOCFPGA_SOC64
config TARGET_SOCFPGA_ARRIA5 bool select TARGET_SOCFPGA_GEN5 @@ -129,6 +139,10 @@ config TARGET_SOCFPGA_AGILEX_SOCDK bool "Intel SOCFPGA SoCDK (Agilex)" select TARGET_SOCFPGA_AGILEX
+config TARGET_SOCFPGA_AGILEX5_SOCDK
- bool "Intel SOCFPGA SoCDK (Agilex5)"
- select TARGET_SOCFPGA_AGILEX5
config TARGET_SOCFPGA_ARIES_MCVEVK bool "Aries MCVEVK (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5 @@ -202,6 +216,7 @@ config TARGET_SOCFPGA_TERASIC_SOCKIT endchoice
config SYS_BOARD
- default "agilex5-socdk" if TARGET_SOCFPGA_AGILEX5_SOCDK default "agilex-socdk" if TARGET_SOCFPGA_AGILEX_SOCDK default "arria5-socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK default "arria10-socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK
@@ -223,6 +238,7 @@ config SYS_BOARD default "vining_fpga" if TARGET_SOCFPGA_SOFTING_VINING_FPGA
config SYS_VENDOR
- default "intel" if TARGET_SOCFPGA_AGILEX5_SOCDK default "intel" if TARGET_SOCFPGA_AGILEX_SOCDK default "intel" if TARGET_SOCFPGA_N5X_SOCDK default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK
@@ -245,6 +261,7 @@ config SYS_SOC default "socfpga"
config SYS_CONFIG_NAME
- default "socfpga_agilex5_socdk" if
TARGET_SOCFPGA_AGILEX5_SOCDK default "socfpga_agilex_socdk" if TARGET_SOCFPGA_AGILEX_SOCDK default "socfpga_arria5_secu1" if TARGET_SOCFPGA_ARRIA5_SECU1 default "socfpga_arria5_socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach- socfpga/Makefile index ec38b64dd4..67c6a8dfec 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -4,7 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # Copyright (C) 2012-2017 Altera Corporation <www.altera.com> -# Copyright (C) 2017-2021 Intel Corporation <www.intel.com> +# Copyright (C) 2017-2024 Intel Corporation <www.intel.com>
obj-y += board.o obj-y += clock_manager.o @@ -56,6 +56,15 @@ obj-y += wrap_handoff_soc64.o obj-y += wrap_pll_config_soc64.o endif
+ifdef CONFIG_TARGET_SOCFPGA_AGILEX5 +obj-y += clock_manager_agilex5.o +obj-y += mailbox_s10.o +obj-y += misc_soc64.o +obj-y += mmu-arm64_s10.o +obj-y += reset_manager_s10.o +obj-y += wrap_pll_config_soc64.o +endif
ifdef CONFIG_TARGET_SOCFPGA_N5X obj-y += clock_manager_n5x.o obj-y += lowlevel_init_soc64.o @@ -95,6 +104,9 @@ endif ifdef CONFIG_TARGET_SOCFPGA_N5X obj-y += spl_n5x.o endif +ifdef CONFIG_TARGET_SOCFPGA_AGILEX5 +obj-y += spl_soc64.o +endif else obj-$(CONFIG_SPL_ATF) += secure_reg_helper.o obj-$(CONFIG_SPL_ATF) += smc_api.o diff --git a/arch/arm/mach-socfpga/board.c b/arch/arm/mach-socfpga/board.c index 09e09192fb..616e1afe5d 100644 --- a/arch/arm/mach-socfpga/board.c +++ b/arch/arm/mach-socfpga/board.c @@ -7,9 +7,11 @@
#include <common.h> #include <asm/arch/clock_manager.h> +#include <asm/arch/mailbox_s10.h> #include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/secure_vab.h> +#include <asm/arch/smc_api.h> #include <asm/global_data.h> #include <asm/io.h> #include <errno.h> @@ -23,6 +25,8 @@
DECLARE_GLOBAL_DATA_PTR;
+#define DEFAULT_JTAG_USERCODE 0xFFFFFFFF
void s_init(void) { #ifndef CONFIG_ARM64 /* @@ -92,13 +96,50 @@ int g_dnl_board_usb_cable_connected(void) } #endif
-#ifdef CONFIG_SPL_BUILD -__weak int board_fit_config_name_match(const char *name) +u8 socfpga_get_board_id(void) {
- /* Just empty function now - can't decide what to choose */
- debug("%s: %s\n", __func__, name);
- u8 board_id = 0;
- u32 jtag_usercode;
- int err;
+#if !IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_SPL_ATF)
- err = smc_get_usercode(&jtag_usercode);
+#else
- u32 resp_len = 1;
- err = mbox_send_cmd(MBOX_ID_UBOOT, MBOX_GET_USERCODE,
MBOX_CMD_DIRECT, 0,
NULL, 0, &resp_len, &jtag_usercode);
- if (err) {
puts("Fail to read JTAG Usercode. Default Board ID to 0\n");
return board_id;
- debug("Valid JTAG Usercode: %u\n", jtag_usercode);
- if (jtag_usercode == DEFAULT_JTAG_USERCODE) {
debug("JTAG Usercode is not set. Default Board ID to 0\n");
- } else if (jtag_usercode >= 0 && jtag_usercode <= 255) {
board_id = jtag_usercode;
debug("Valid JTAG Usercode. Set Board ID to %u\n", board_id);
- } else {
puts("Board ID is not in range 0 to 255\n");
- return board_id;
+#if IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_TARGET_SOCFPGA_SOC64) +int board_fit_config_name_match(const char *name) +{
- char board_name[10];
- sprintf(board_name, "board_%u", socfpga_get_board_id());
- debug("Board name: %s\n", board_name);
- return strcmp(name, board_name);
} #endif
@@ -116,6 +157,8 @@ void board_fit_image_post_process(const void *fit, int node, void **p_image, #if !IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_FIT) void board_prep_linux(struct bootm_headers *images) {
bool use_fit = false;
if (!images->fit_uname_cfg) { if (IS_ENABLED(CONFIG_SOCFPGA_SECURE_VAB_AUTH) &&
!IS_ENABLED(CONFIG_SOCFPGA_SECURE_VAB_AUTH_ALLOW_NON
_FIT_IMAGE)) { @@ -127,12 +170,13 @@ void board_prep_linux(struct bootm_headers *images) hang(); } } else {
/* Update fdt_addr in enviroment variable */ env_set_hex("fdt_addr", (ulong)images->ft_addr); debug("images->ft_addr = 0x%08lx\n", (ulong)images-use_fit = true;
ft_addr);
- if (IS_ENABLED(CONFIG_CADENCE_QSPI)) {
- if (use_fit && IS_ENABLED(CONFIG_CADENCE_QSPI)) { if (env_get("linux_qspi_enable")) run_command(env_get("linux_qspi_enable"), 0); }
diff --git a/arch/arm/mach-socfpga/clock_manager_agilex5.c b/arch/arm/mach-socfpga/clock_manager_agilex5.c new file mode 100644 index 0000000000..b92f0b3af8 --- /dev/null +++ b/arch/arm/mach-socfpga/clock_manager_agilex5.c @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <clk.h> +#include <config.h> +#include <dm.h> +#include <errno.h> +#include <log.h> +#include <malloc.h> +#include <stdarg.h> +#include <stdio.h> +#include <time.h> +#include <vsprintf.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/u-boot.h> +#include <linux/kernel.h> +#include <linux/string.h> +#include <linux/types.h> +#include <asm/arch/clock_manager.h> +#include <asm/arch/system_manager.h> +#include <dt-bindings/clock/agilex5-clock.h>
+DECLARE_GLOBAL_DATA_PTR;
+static ulong cm_get_rate_dm(u32 id) +{
- struct udevice *dev;
- struct clk clk;
- ulong rate;
- int ret;
- ret = uclass_get_device_by_driver(UCLASS_CLK,
DM_DRIVER_GET(socfpga_agilex5_clk),
&dev);
- if (ret)
- clk.id = id;
- ret = clk_request(dev, &clk);
- if (ret < 0)
- rate = clk_get_rate(&clk);
- if ((rate == (unsigned long)-ENOSYS) ||
(rate == (unsigned long)-ENXIO) ||
(rate == (unsigned long)-EIO)) {
debug("%s id %u: clk_get_rate err: %ld\n",
__func__, id, rate);
- return rate;
+static u32 cm_get_rate_dm_khz(u32 id) +{
- return cm_get_rate_dm(id) / 1000;
+unsigned long cm_get_mpu_clk_hz(void) +{
- return cm_get_rate_dm(AGILEX5_MPU_CLK);
+unsigned int cm_get_l4_sys_free_clk_hz(void) +{
- return cm_get_rate_dm(AGILEX5_L4_SYS_FREE_CLK);
+void cm_print_clock_quick_summary(void) +{
- printf("MPU %10d kHz\n",
cm_get_rate_dm_khz(AGILEX5_MPU_CLK));
- printf("L4 Main %8d kHz\n",
cm_get_rate_dm_khz(AGILEX5_L4_MAIN_CLK));
- printf("L4 sys free %8d kHz\n",
cm_get_rate_dm_khz(AGILEX5_L4_SYS_FREE_CLK));
- printf("L4 MP %8d kHz\n",
cm_get_rate_dm_khz(AGILEX5_L4_MP_CLK));
- printf("L4 SP %8d kHz\n",
cm_get_rate_dm_khz(AGILEX5_L4_SP_CLK));
- printf("SDMMC %8d kHz\n",
cm_get_rate_dm_khz(AGILEX5_SDMMC_CLK));
+} diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h index 3f899fcfa3..65721098b2 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h @@ -1,11 +1,46 @@ /* SPDX-License-Identifier: GPL-2.0 */ /*
- Copyright (C) 2016-2021 Intel Corporation <www.intel.com>
- Copyright (C) 2016-2024 Intel Corporation <www.intel.com>
#ifndef _SOCFPGA_SOC64_BASE_HARDWARE_H_ #define _SOCFPGA_SOC64_BASE_HARDWARE_H_
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SOCFPGA_CCU_ADDRESS 0x1c000000 +#define SOCFPGA_F2SDRAM_MGR_ADDRESS 0x18001000 +#define SOCFPGA_SMMU_ADDRESS 0x16000000 +#define SOCFPGA_OCRAM_FIREWALL_ADDRESS 0x108cc400 +#define SOCFPGA_MAILBOX_ADDRESS 0x10a30000 +#define SOCFPGA_UART0_ADDRESS 0x10c02000 +#define SOCFPGA_UART1_ADDRESS 0x10c02100 +#define SOCFPGA_SPTIMER0_ADDRESS 0x10c03000 +#define SOCFPGA_SPTIMER1_ADDRESS 0x10c03100 +#define SOCFPGA_SYSTIMER0_ADDRESS 0x10d00000 +#define SOCFPGA_SYSTIMER1_ADDRESS 0x10d00100 +#define SOCFPGA_L4WD0_ADDRESS 0x10d00200 +#define SOCFPGA_L4WD1_ADDRESS 0x10d00300 +#define SOCFPGA_L4WD2_ADDRESS 0x10d00400 +#define SOCFPGA_L4WD3_ADDRESS 0x10d00500 +#define SOCFPGA_L4WD4_ADDRESS 0x10d00600 +#define SOCFPGA_GTIMER_SEC_ADDRESS 0x10d01000 +#define SOCFPGA_GTIMER_NSEC_ADDRESS 0x10d02000 +#define SOCFPGA_CLKMGR_ADDRESS 0x10d10000 +#define SOCFPGA_RSTMGR_ADDRESS 0x10d11000 +#define SOCFPGA_SYSMGR_ADDRESS 0x10d12000 +#define SOCFPGA_OCRAM_ADDRESS 0x00000000 +#define SOCFPGA_FW_DDR_CCU_DMI0_ADDRESS 0x18000800 +#define SOCFPGA_FW_DDR_CCU_DMI1_ADDRESS 0x18000A00 +#define SOCFPGA_FW_TBU2NOC_ADDRESS 0x18000C00 +#define SOCFPGA_FIREWALL_L4_PER 0x10d21000 +#define SOCFPGA_FIREWALL_L4_SYS 0x10d21100 +#define SOCFPGA_FIREWALL_SOC2FPGA 0x10d21200 +#define SOCFPGA_FIREWALL_LWSOC2FPGA 0x10d21300 +#define SOCFPGA_FIREWALL_TCU 0x10d21400 +#define SOCFPGA_FIREWALL_PRIV_MEMORYMAP_PRIV 0x10d24800 +#define GICD_BASE 0x1d000000 +#define GICR_BASE 0x1d060000 +#else #define SOCFPGA_CCU_ADDRESS 0xf7000000 #define SOCFPGA_SDR_SCHEDULER_ADDRESS 0xf8000400 #define SOCFPGA_HMC_MMR_IO48_ADDRESS 0xf8010000 @@ -44,5 +79,6 @@ #define SOCFPGA_OCRAM_ADDRESS 0xffe00000 #define GICD_BASE 0xfffc1000 #define GICC_BASE 0xfffc2000 +#endif /* IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) */
#endif /* _SOCFPGA_SOC64_BASE_HARDWARE_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index a8cb07a1c4..6c9d32b9dd 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /*
- Copyright (C) 2013-2017 Altera Corporation <www.altera.com>
- Copyright (C) 2013-2024 Altera Corporation <www.altera.com>
#ifndef _CLOCK_MANAGER_H_ @@ -28,6 +28,8 @@ int cm_set_qspi_controller_clk_hz(u32 clk_hz); #include <asm/arch/clock_manager_s10.h> #elif defined(CONFIG_TARGET_SOCFPGA_AGILEX) #include <asm/arch/clock_manager_agilex.h> +#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#include <asm/arch/clock_manager_agilex5.h> #elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) #include <asm/arch/clock_manager_n5x.h> #endif diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_agilex5.h b/arch/arm/mach-socfpga/include/mach/clock_manager_agilex5.h new file mode 100644 index 0000000000..1ae0a92603 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_agilex5.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#ifndef _CLOCK_MANAGER_AGILEX5_ +#define _CLOCK_MANAGER_AGILEX5_
+#include <asm/arch/clock_manager_soc64.h> +#include "../../../../../drivers/clk/altera/clk-agilex5.h"
+#endif /* _CLOCK_MANAGER_AGILEX5_ */ diff --git a/arch/arm/mach-socfpga/include/mach/handoff_soc64.h b/arch/arm/mach-socfpga/include/mach/handoff_soc64.h index 9b85e5865b..2684b84a08 100644 --- a/arch/arm/mach-socfpga/include/mach/handoff_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/handoff_soc64.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0
@@ -17,7 +17,12 @@ #define SOC64_HANDOFF_MAGIC_FPGA 0x46504741 #define SOC64_HANDOFF_MAGIC_DELAY 0x444C4159 #define SOC64_HANDOFF_MAGIC_CLOCK 0x434C4B53 +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SOC64_HANDOFF_MAGIC_PERI 0x50455249 +#define SOC64_HANDOFF_MAGIC_SDRAM 0x5344524d +#else #define SOC64_HANDOFF_MAGIC_MISC 0x4D495343 +#endif
#define SOC64_HANDOFF_OFFSET_LENGTH 0x4 #define SOC64_HANDOFF_OFFSET_DATA 0x10 @@ -27,6 +32,8 @@ IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX) #define SOC64_HANDOFF_BASE 0xFFE3F000 #define SOC64_HANDOFF_MISC (SOC64_HANDOFF_BASE + 0x610) +#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SOC64_HANDOFF_BASE 0x0007F000 #elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) #define SOC64_HANDOFF_BASE 0xFFE5F000 #define SOC64_HANDOFF_MISC (SOC64_HANDOFF_BASE + 0x630) @@ -58,13 +65,21 @@ #define SOC64_HANDOFF_FPGA (SOC64_HANDOFF_BASE + 0x330) #define SOC64_HANDOFF_DELAY (SOC64_HANDOFF_BASE + 0x3F0) #define SOC64_HANDOFF_CLOCK (SOC64_HANDOFF_BASE + 0x580) +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SOC64_HANDOFF_PERI (SOC64_HANDOFF_BASE + 0x620) +#define SOC64_HANDOFF_SDRAM (SOC64_HANDOFF_BASE + 0x634) +#define SOC64_HANDOFF_SDRAM_LEN 1 +#endif
#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_STRATIX10) -#define SOC64_HANDOFF_CLOCK_OSC (SOC64_HANDOFF_BASE + 0x608) -#define SOC64_HANDOFF_CLOCK_FPGA (SOC64_HANDOFF_BASE + 0x60C) +#define SOC64_HANDOFF_CLOCK_OSC (SOC64_HANDOFF_BASE + 0x608) +#define SOC64_HANDOFF_CLOCK_FPGA (SOC64_HANDOFF_BASE + 0x60C) +#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SOC64_HANDOFF_CLOCK_OSC (SOC64_HANDOFF_BASE + 0x60c) +#define SOC64_HANDOFF_CLOCK_FPGA (SOC64_HANDOFF_BASE + 0x610) #else -#define SOC64_HANDOFF_CLOCK_OSC (SOC64_HANDOFF_BASE + 0x5fc) -#define SOC64_HANDOFF_CLOCK_FPGA (SOC64_HANDOFF_BASE + 0x600) +#define SOC64_HANDOFF_CLOCK_OSC (SOC64_HANDOFF_BASE + 0x5fc) +#define SOC64_HANDOFF_CLOCK_FPGA (SOC64_HANDOFF_BASE + 0x600) #endif
#define SOC64_HANDOFF_MUX_LEN 96 @@ -78,6 +93,12 @@
#ifndef __ASSEMBLY__ #include <asm/types.h> +enum endianness {
- LITTLE_ENDIAN = 0,
- BIG_ENDIAN,
- UNKNOWN_ENDIANNESS
int socfpga_get_handoff_size(void *handoff_address); int socfpga_handoff_read(void *handoff_address, void *table, u32 table_len); #endif diff --git a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h index fbaf11597e..2cc7c89044 100644 --- a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h +++ b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h @@ -119,6 +119,7 @@ enum ALT_SDM_MBOX_RESP_CODE { #define MBOX_RECONFIG_DATA 8 #define MBOX_RECONFIG_STATUS 9 #define MBOX_VAB_SRC_CERT 11 +#define MBOX_GET_USERCODE 19 #define MBOX_QSPI_OPEN 50 #define MBOX_QSPI_CLOSE 51 #define MBOX_QSPI_DIRECT 59 diff --git a/arch/arm/mach-socfpga/mmu-arm64_s10.c b/arch/arm/mach- socfpga/mmu-arm64_s10.c index a55b7b7cf3..b1e327a24e 100644 --- a/arch/arm/mach-socfpga/mmu-arm64_s10.c +++ b/arch/arm/mach-socfpga/mmu-arm64_s10.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /*
- Copyright (C) 2016-2018 Intel Corporation <www.intel.com>
@@ -10,6 +10,62 @@
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +static struct mm_region socfpga_agilex5_mem_map[] = {
/* OCRAM 512KB */
.virt = 0x00000000UL,
.phys = 0x00000000UL,
.size = 0x00080000UL,
.attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) |
PTE_BLOCK_NON_SHARE,
/* DEVICE */
.virt = 0x10808000UL,
.phys = 0x10808000UL,
.size = 0x0F7F8000UL,
PTE_BLOCK_NON_SHARE |
PTE_BLOCK_PXN | PTE_BLOCK_UXN,
/* FPGA 1.5GB */
.virt = 0x20000000UL,
.phys = 0x20000000UL,
.size = 0x60000000UL,
/* FPGA 15GB */
.virt = 0x440000000UL,
.phys = 0x440000000UL,
.size = 0x3C0000000UL,
/* FPGA 240GB */
.virt = 0x4400000000UL,
.phys = 0x4400000000UL,
.size = 0x3E80000000UL,
/* MEM 2GB */
.virt = 0x80000000UL,
.phys = 0x80000000UL,
.size = 0x80000000UL,
.attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) |
PTE_BLOCK_INNER_SHARE,
/* List terminator */
+struct mm_region *mem_map = socfpga_agilex5_mem_map;
+#else static struct mm_region socfpga_stratix10_mem_map[] = { { /* MEM 2GB*/ @@ -70,3 +126,4 @@ static struct mm_region socfpga_stratix10_mem_map[] = { };
struct mm_region *mem_map = socfpga_stratix10_mem_map; +#endif diff --git a/board/intel/agilex5-socdk/MAINTAINERS b/board/intel/agilex5- socdk/MAINTAINERS new file mode 100644 index 0000000000..b696f788c8 --- /dev/null +++ b/board/intel/agilex5-socdk/MAINTAINERS @@ -0,0 +1,8 @@ +SOCFPGA BOARD +M: Tien Fong Chee tien.fong.chee@intel.com +M: Teik Heng Chong teik.heng.chong@intel.com +M: Jit Loon Lim jit.loon.lim@intel.com +S: Maintained +F: board/intel/agilex5-socdk/ +F: include/configs/socfpga_agilex5_socdk.h +F: configs/socfpga_agilex5_defconfig diff --git a/configs/socfpga_agilex5_defconfig b/configs/socfpga_agilex5_defconfig new file mode 100644 index 0000000000..f39954aea8 --- /dev/null +++ b/configs/socfpga_agilex5_defconfig @@ -0,0 +1,116 @@ +CONFIG_ARM=y +CONFIG_SPL_LDSCRIPT="arch/arm/mach-socfpga/u-boot-spl-soc64.lds" +CONFIG_SYS_SPI_U_BOOT_OFFS=0x04000000 +CONFIG_ARCH_SOCFPGA=y +CONFIG_TEXT_BASE=0x80200000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x04100000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="socfpga_agilex5_socdk" +CONFIG_TARGET_SOCFPGA_AGILEX5_SOCDK=y +CONFIG_IDENT_STRING="socfpga_agilex5" +CONFIG_SPL_FS_FAT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x82000000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 initrd=0x90000000 root=/dev/ram0 rw init=/sbin/init ramdisk_size=10000000 earlycon panic=-1 nosmp kvm-arm.mode=nvhe" +CONFIG_LEGACY_IMAGE_FORMAT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_CRC32=y +CONFIG_SPL_CACHE=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_SYS_PROMPT="SOCFPGA_AGILEX5 # " +CONFIG_CMD_NVEDIT_SELECT=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_SF=y +CONFIG_DOS_PARTITION=y +CONFIG_SPL_DOS_PARTITION=y +CONFIG_SPL_SYS_DISABLE_DCACHE_OPS=y +CONFIG_CMD_MTD=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +CONFIG_SPL_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_CMD_UBI=y +CONFIG_CMD_UBIFS=y +CONFIG_MTD_UBI=y +CONFIG_MTD_UBI_WL_THRESHOLD=4096 +CONFIG_MTD_UBI_BEB_LIMIT=20 +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_LIST="" +CONFIG_ENV_IS_IN_UBI=y +CONFIG_ENV_UBI_PART="root" +CONFIG_ENV_UBI_VOLUME="env" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_ALTERA_SDRAM=y +CONFIG_FPGA_INTEL_PR=y +CONFIG_DWAPB_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_DW=y +CONFIG_MISC=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SF_DEFAULT_MODE=0x2003 +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_UBI_SILENCE_MSG=y +CONFIG_DM_ETH=y +CONFIG_RGMII=y +CONFIG_DM_RESET=y +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_DESIGNWARE_SPI=y +CONFIG_USB=y +CONFIG_USB_DWC2=y +CONFIG_USB_XHCI_HCD=y +CONFIG_UBIFS_SILENCE_MSG=y +# CONFIG_SPL_USE_TINY_PRINTF is not set +CONFIG_PANIC_HANG=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_WDT=y +CONFIG_CMD_WDT=y +CONFIG_DESIGNWARE_WATCHDOG=y +CONFIG_SPL_WDT=y +CONFIG_WATCHDOG_AUTOSTART=n +CONFIG_TIMER=y +CONFIG_DESIGNWARE_APB_TIMER=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80300000 +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0xbff00000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x7f000 +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xbfa00000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_BSS_MAX_SIZE=0x100000 +# CONFIG_EFI_LOADER is not set +CONFIG_I3C=y +CONFIG_DW_I3C_MASTER=y +CONFIG_CMD_I3C=y +CONFIG_SYS_MAXARGS=32 +CONFIG_CMD_TIMER=y +# CONFIG_BOOTFILE="Image" is not set for CONFIG_SPL_ATF=y +CONFIG_USE_BOOTFILE=y +CONFIG_BOOTFILE="kernel.itb" diff --git a/drivers/clk/altera/Makefile b/drivers/clk/altera/Makefile index 33db092918..61ffa4179a 100644 --- a/drivers/clk/altera/Makefile +++ b/drivers/clk/altera/Makefile @@ -7,3 +7,4 @@ obj-$(CONFIG_TARGET_SOCFPGA_AGILEX) += clk-agilex.o obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clk-arria10.o obj-$(CONFIG_TARGET_SOCFPGA_N5X) += clk-n5x.o obj-$(CONFIG_TARGET_SOCFPGA_N5X) += clk-mem-n5x.o +obj-$(CONFIG_TARGET_SOCFPGA_AGILEX5) += clk-agilex5.o diff --git a/drivers/clk/altera/clk-agilex5.c b/drivers/clk/altera/clk-agilex5.c new file mode 100644 index 0000000000..c3b614ace4 --- /dev/null +++ b/drivers/clk/altera/clk-agilex5.c @@ -0,0 +1,743 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <clk-uclass.h> +#include <config.h> +#include <errno.h> +#include <dm.h> +#include <log.h> +#include <stdarg.h> +#include <stdio.h> +#include <time.h> +#include <vsprintf.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/system.h> +#include <asm/u-boot.h> +#include <dm/lists.h> +#include <dm/util.h> +#include <linux/bitops.h> +#include <linux/kernel.h> +#include <linux/string.h> +#include <linux/types.h> +#include <asm/arch/clock_manager.h> +#include <dt-bindings/clock/agilex5-clock.h>
+struct socfpga_clk_plat {
- void __iomem *regs;
- function to write the bypass register which requires a poll of the
- busy bit
+static void clk_write_bypass_mainpll(struct socfpga_clk_plat *plat, u32 val) +{
- CM_REG_WRITEL(plat, val, CLKMGR_MAINPLL_BYPASS);
- cm_wait_for_fsm();
+static void clk_write_bypass_perpll(struct socfpga_clk_plat *plat, u32 val) +{
- CM_REG_WRITEL(plat, val, CLKMGR_PERPLL_BYPASS);
+/* function to write the ctrl register which requires a poll of the busy bit */ +static void clk_write_ctrl(struct socfpga_clk_plat *plat, u32 val) +{
- CM_REG_WRITEL(plat, val, CLKMGR_CTRL);
+static const struct {
- u32 reg;
- u32 val;
- u32 mask;
+} membus_pll[] = {
MEMBUS_CLKSLICE_REG,
* BIT[7:7]
* Enable source synchronous mode
BIT(7),
BIT(7)
MEMBUS_SYNTHCALFOSC_INIT_CENTERFREQ_REG,
* BIT[0:0]
* Sets synthcalfosc_init_centerfreq=1 to limit overshoot
* frequency during lock
BIT(0),
BIT(0)
MEMBUS_SYNTHPPM_WATCHDOGTMR_VF01_REG,
* BIT[0:0]
* Sets synthppm_watchdogtmr_vf0=1 to give the pll more
time
* to settle before lock is asserted.
BIT(0),
BIT(0)
MEMBUS_CALCLKSLICE0_DUTY_LOCOVR_REG,
* BIT[6:0]
* Centering duty cycle for clkslice0 output
0x4a,
GENMASK(6, 0)
MEMBUS_CALCLKSLICE1_DUTY_LOCOVR_REG,
* BIT[6:0]
* Centering duty cycle for clkslice1 output
0x4a,
GENMASK(6, 0)
+static int membus_wait_for_req(struct socfpga_clk_plat *plat, u32 pll,
int timeout)
- int cnt = 0;
- u32 req_status;
- if (pll == MEMBUS_MAINPLL)
req_status = CM_REG_READL(plat, CLKMGR_MAINPLL_MEM);
- else
req_status = CM_REG_READL(plat, CLKMGR_PERPLL_MEM);
- while ((cnt < timeout) && (req_status &
CLKMGR_MEM_REQ_SET_MSK)) {
else
CLKMGR_PERPLL_MEM);
cnt++;
- if (cnt >= timeout)
return -ETIMEDOUT;
+static int membus_write_pll(struct socfpga_clk_plat *plat, u32 pll,
u32 addr_offset, u32 wdat, int timeout)
- u32 addr;
- u32 val;
- addr = ((addr_offset | CLKMGR_MEM_ADDR_START) &
CLKMGR_MEM_ADDR_MASK);
- val = (CLKMGR_MEM_REQ_SET_MSK | CLKMGR_MEM_WR_SET_MSK
(wdat << CLKMGR_MEM_WDAT_LSB_OFFSET) | addr);
CM_REG_WRITEL(plat, val, CLKMGR_MAINPLL_MEM);
- else
CM_REG_WRITEL(plat, val, CLKMGR_PERPLL_MEM);
- debug("MEMBUS: Write 0x%08x to addr = 0x%08x\n", wdat, addr);
- return membus_wait_for_req(plat, pll, timeout);
+static int membus_read_pll(struct socfpga_clk_plat *plat, u32 pll,
u32 addr_offset, u32 *rdata, int timeout)
- u32 addr;
- u32 val;
- val = ((CLKMGR_MEM_REQ_SET_MSK &
~CLKMGR_MEM_WR_SET_MSK) | addr);
- else
- *rdata = 0;
- if (membus_wait_for_req(plat, pll, timeout))
return -ETIMEDOUT;
*rdata = CM_REG_READL(plat, CLKMGR_MAINPLL_MEMSTAT);
- else
*rdata = CM_REG_READL(plat, CLKMGR_PERPLL_MEMSTAT);
- debug("MEMBUS: Read 0x%08x from addr = 0x%08x\n", *rdata, addr);
+static void membus_pll_configs(struct socfpga_clk_plat *plat, u32 pll) +{
- int i;
- u32 rdata;
- for (i = 0; i < ARRAY_SIZE(membus_pll); i++) {
membus_read_pll(plat, pll, membus_pll[i].reg,
&rdata, MEMBUS_TIMEOUT);
membus_write_pll(plat, pll, membus_pll[i].reg,
((rdata & ~membus_pll[i].mask) | membus_pll[i].val),
MEMBUS_TIMEOUT);
+static u32 calc_vocalib_pll(u32 pllm, u32 pllglob) +{
- u32 mdiv, refclkdiv, arefclkdiv, drefclkdiv, mscnt, hscnt, vcocalib;
- mdiv = pllm & CLKMGR_PLLM_MDIV_MASK;
- arefclkdiv = (pllglob & CLKMGR_PLLGLOB_AREFCLKDIV_MASK) >>
CLKMGR_PLLGLOB_AREFCLKDIV_OFFSET;
- drefclkdiv = (pllglob & CLKMGR_PLLGLOB_DREFCLKDIV_MASK) >>
CLKMGR_PLLGLOB_DREFCLKDIV_OFFSET;
- refclkdiv = (pllglob & CLKMGR_PLLGLOB_REFCLKDIV_MASK) >>
CLKMGR_PLLGLOB_REFCLKDIV_OFFSET;
- mscnt = CLKMGR_VCOCALIB_MSCNT_CONST / (mdiv * BIT(drefclkdiv));
- if (!mscnt)
mscnt = 1;
- hscnt = (mdiv * mscnt * BIT(drefclkdiv) / refclkdiv) -
CLKMGR_VCOCALIB_HSCNT_CONST;
- vcocalib = (hscnt & CLKMGR_VCOCALIB_HSCNT_MASK) |
((mscnt << CLKMGR_VCOCALIB_MSCNT_OFFSET) &
CLKMGR_VCOCALIB_MSCNT_MASK);
- /* Dump all the pll calibration settings for debug purposes */
- debug("mdiv : %d\n", mdiv);
- debug("arefclkdiv : %d\n", arefclkdiv);
- debug("drefclkdiv : %d\n", drefclkdiv);
- debug("refclkdiv : %d\n", refclkdiv);
- debug("mscnt : %d\n", mscnt);
- debug("hscnt : %d\n", hscnt);
- debug("vcocalib : 0x%08x\n", vcocalib);
- return vcocalib;
- Setup clocks while making no assumptions about previous state of the
clocks.
+static void clk_basic_init(struct udevice *dev,
const struct cm_config * const cfg)
- struct socfpga_clk_plat *plat = dev_get_plat(dev);
- u32 vcocalib;
- if (!cfg)
return;
- if (IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5_EMU)) {
/* Take both PLL out of reset and power up */
CM_REG_SETBITS(plat, CLKMGR_MAINPLL_PLLGLOB,
CLKMGR_PLLGLOB_PD_MASK |
CLKMGR_PLLGLOB_RST_MASK);
CM_REG_SETBITS(plat, CLKMGR_PERPLL_PLLGLOB,
cm_wait_for_lock(CLKMGR_STAT_ALLPLL_LOCKED_MASK);
/* Put both PLLs in bypass */
clk_write_bypass_mainpll(plat,
CLKMGR_BYPASS_MAINPLL_ALL);
clk_write_bypass_perpll(plat, CLKMGR_BYPASS_PERPLL_ALL);
/* Take all PLLs out of bypass */
clk_write_bypass_mainpll(plat, 0);
clk_write_bypass_perpll(plat, 0);
/* Out of boot mode */
clk_write_ctrl(plat,
CM_REG_READL(plat, CLKMGR_CTRL) &
~CLKMGR_CTRL_BOOTMODE);
- } else {
+#ifdef CONFIG_SPL_BUILD
/* Always force clock manager into boot mode before any
configuration */
CM_REG_READL(plat, CLKMGR_CTRL) |
CLKMGR_CTRL_BOOTMODE); +#else
/* Skip clock configuration in SSBL if it's not in boot mode */
if (!(CM_REG_READL(plat, CLKMGR_CTRL) &
CLKMGR_CTRL_BOOTMODE))
return;
/* Put both PLLs in Reset and Power Down */
CM_REG_CLRBITS(plat, CLKMGR_MAINPLL_PLLGLOB,
CM_REG_CLRBITS(plat, CLKMGR_PERPLL_PLLGLOB,
/* setup main PLL dividers where calculate the vcocalib value
vcocalib = calc_vocalib_pll(cfg->main_pll_pllm, cfg-
main_pll_pllglob);
CM_REG_WRITEL(plat, cfg->main_pll_pllglob &
~CLKMGR_PLLGLOB_RST_MASK,
CLKMGR_MAINPLL_PLLGLOB);
CM_REG_WRITEL(plat, cfg->main_pll_fdbck,
CLKMGR_MAINPLL_FDBCK);
CM_REG_WRITEL(plat, vcocalib,
CLKMGR_MAINPLL_VCOCALIB);
CM_REG_WRITEL(plat, cfg->main_pll_pllc0,
CLKMGR_MAINPLL_PLLC0);
CM_REG_WRITEL(plat, cfg->main_pll_pllc1,
CLKMGR_MAINPLL_PLLC1);
CM_REG_WRITEL(plat, cfg->main_pll_pllc2,
CLKMGR_MAINPLL_PLLC2);
CM_REG_WRITEL(plat, cfg->main_pll_pllc3,
CLKMGR_MAINPLL_PLLC3);
CM_REG_WRITEL(plat, cfg->main_pll_pllm,
CLKMGR_MAINPLL_PLLM);
CM_REG_WRITEL(plat, cfg->main_pll_nocclk,
CLKMGR_MAINPLL_NOCCLK);
CM_REG_WRITEL(plat, cfg->main_pll_nocdiv,
CLKMGR_MAINPLL_NOCDIV);
/* setup peripheral PLL dividers where calculate the vcocalib
value */
vcocalib = calc_vocalib_pll(cfg->per_pll_pllm, cfg-
per_pll_pllglob);
CM_REG_WRITEL(plat, cfg->per_pll_pllglob &
CLKMGR_PERPLL_PLLGLOB);
CM_REG_WRITEL(plat, cfg->per_pll_fdbck,
CLKMGR_PERPLL_FDBCK);
CM_REG_WRITEL(plat, vcocalib, CLKMGR_PERPLL_VCOCALIB);
CM_REG_WRITEL(plat, cfg->per_pll_pllc0,
CLKMGR_PERPLL_PLLC0);
CM_REG_WRITEL(plat, cfg->per_pll_pllc1,
CLKMGR_PERPLL_PLLC1);
CM_REG_WRITEL(plat, cfg->per_pll_pllc2,
CLKMGR_PERPLL_PLLC2);
CM_REG_WRITEL(plat, cfg->per_pll_pllc3,
CLKMGR_PERPLL_PLLC3);
CM_REG_WRITEL(plat, cfg->per_pll_pllm,
CLKMGR_PERPLL_PLLM);
CM_REG_WRITEL(plat, cfg->per_pll_emacctl,
CLKMGR_PERPLL_EMACCTL);
CM_REG_WRITEL(plat, cfg->per_pll_gpiodiv,
CLKMGR_PERPLL_GPIODIV);
/* Configure ping pong counters in control group */
CM_REG_WRITEL(plat, cfg->ctl_emacactr,
CLKMGR_CTL_EMACACTR);
CM_REG_WRITEL(plat, cfg->ctl_emacbctr,
CLKMGR_CTL_EMACBCTR);
CM_REG_WRITEL(plat, cfg->ctl_emacptpctr,
CLKMGR_CTL_EMACPTPCTR);
CM_REG_WRITEL(plat, cfg->ctl_gpiodbctr,
CLKMGR_CTL_GPIODBCTR);
CM_REG_WRITEL(plat, cfg->ctl_s2fuser0ctr,
CLKMGR_CTL_S2FUSER0CTR);
CM_REG_WRITEL(plat, cfg->ctl_s2fuser1ctr,
CLKMGR_CTL_S2FUSER1CTR);
CM_REG_WRITEL(plat, cfg->ctl_psirefctr,
CLKMGR_CTL_PSIREFCTR);
CM_REG_WRITEL(plat, cfg->ctl_usb31ctr,
CLKMGR_CTL_USB31CTR);
CM_REG_WRITEL(plat, cfg->ctl_dsuctr,
CLKMGR_CTL_DSUCTR);
CM_REG_WRITEL(plat, cfg->ctl_core01ctr,
CLKMGR_CTL_CORE01CTR);
CM_REG_WRITEL(plat, cfg->ctl_core23ctr,
CLKMGR_CTL_CORE23CTR);
CM_REG_WRITEL(plat, cfg->ctl_core2ctr,
CLKMGR_CTL_CORE2CTR);
CM_REG_WRITEL(plat, cfg->ctl_core3ctr,
CLKMGR_CTL_CORE3CTR);
/* Membus programming for mainpll */
membus_pll_configs(plat, MEMBUS_MAINPLL);
/* Membus programming for peripll */
membus_pll_configs(plat, MEMBUS_PERPLL);
/* Enable Main pll clkslices */
CM_REG_WRITEL(plat, CM_REG_READL(plat,
CLKMGR_MAINPLL_PLLC0) |
CLKMGR_PLLCX_EN_SET_MSK,
CLKMGR_MAINPLL_PLLC1) |
CLKMGR_MAINPLL_PLLC2) |
CLKMGR_MAINPLL_PLLC3) |
/* Enable Periph pll clkslices */
CLKMGR_PERPLL_PLLC0) |
CLKMGR_PERPLL_PLLC1) |
CLKMGR_PERPLL_PLLC2) |
CLKMGR_PERPLL_PLLC3) |
CM_REG_WRITEL(plat, CLKMGR_LOSTLOCK_SET_MASK,
CLKMGR_MAINPLL_LOSTLOCK);
CLKMGR_PERPLL_LOSTLOCK);
CLKMGR_MAINPLL_PLLGLOB) |
- CLKMGR_PLLGLOB_CLR_LOSTLOCK_BYPASS_MASK,
CLKMGR_PERPLL_PLLGLOB) |
/* Clear the loss of lock bits (write 1 to clear) */
CM_REG_CLRBITS(plat, CLKMGR_INTRCLR,
CLKMGR_INTER_PERPLLLOST_MASK |
CLKMGR_INTER_MAINPLLLOST_MASK);
/* Take all ping pong counters out of reset */
CM_REG_CLRBITS(plat, CLKMGR_CTL_EXTCNTRST,
CLKMGR_CTL_EXTCNTRST_ALLCNTRST);
+#ifdef COUNTER_FREQUENCY_REAL
- u32 cntfrq = COUNTER_FREQUENCY_REAL;
- u32 counter_freq = 0;
- /* Update with accurate clock frequency */
- if (current_el() == 3) {
asm volatile("msr cntfrq_el0, %0" : : "r" (cntfrq) : "memory");
asm volatile("mrs %0, cntfrq_el0" : "=r" (counter_freq));
debug("Counter freq = 0x%x\n", counter_freq);
+static u64 clk_get_vco_clk_hz(struct socfpga_clk_plat *plat,
u32 pllglob_reg, u32 pllm_reg)
u64 fref, arefdiv, mdiv, reg, vco;
- reg = CM_REG_READL(plat, pllglob_reg);
- fref = (reg & CLKMGR_PLLGLOB_VCO_PSRC_MASK) >>
CLKMGR_PLLGLOB_VCO_PSRC_OFFSET;
- switch (fref) {
- case CLKMGR_VCO_PSRC_EOSC1:
fref = cm_get_osc_clk_hz();
break;
- case CLKMGR_VCO_PSRC_INTOSC:
fref = cm_get_intosc_clk_hz();
break;
- case CLKMGR_VCO_PSRC_F2S:
fref = cm_get_fpga_clk_hz();
break;
- arefdiv = (reg & CLKMGR_PLLGLOB_AREFCLKDIV_MASK) >>
- mdiv = CM_REG_READL(plat, pllm_reg) &
- vco = fref / arefdiv;
- vco = vco * mdiv;
- return vco;
+static u64 clk_get_main_vco_clk_hz(struct socfpga_clk_plat *plat) +{
- return clk_get_vco_clk_hz(plat, CLKMGR_MAINPLL_PLLGLOB,
+static u64 clk_get_per_vco_clk_hz(struct socfpga_clk_plat *plat) +{
- return clk_get_vco_clk_hz(plat, CLKMGR_PERPLL_PLLGLOB,
+static u32 clk_get_5_1_clk_src(struct socfpga_clk_plat *plat, u64 reg) +{
- u32 clksrc = CM_REG_READL(plat, reg);
- return (clksrc & CLKMGR_CLKSRC_MASK) >>
CLKMGR_CLKSRC_OFFSET; +}
+static u64 clk_get_clksrc_hz(struct socfpga_clk_plat *plat, u32 clksrc_reg,
u32 main_reg, u32 per_reg)
- u64 clock;
- u32 clklsrc = clk_get_5_1_clk_src(plat, clksrc_reg);
- switch (clklsrc) {
- case CLKMGR_CLKSRC_MAIN:
clock = clk_get_main_vco_clk_hz(plat);
clock /= (CM_REG_READL(plat, main_reg) &
CLKMGR_CLKCNT_MSK);
break;
- case CLKMGR_CLKSRC_PER:
clock = clk_get_per_vco_clk_hz(plat);
clock /= (CM_REG_READL(plat, per_reg) &
CLKMGR_CLKCNT_MSK);
break;
- case CLKMGR_CLKSRC_OSC1:
clock = cm_get_osc_clk_hz();
break;
- case CLKMGR_CLKSRC_INTOSC:
clock = cm_get_intosc_clk_hz();
break;
- case CLKMGR_CLKSRC_FPGA:
clock = cm_get_fpga_clk_hz();
break;
- default:
- return clock;
+static u64 clk_get_mpu_clk_hz(struct socfpga_clk_plat *plat) +{
- u64 clock;
- u32 ctr_reg;
- u32 cpu = ((read_mpidr() >> MPIDR_AFF1_OFFSET) &
MPIDR_AFF1_OFFSET);
- if (cpu > CORE1) {
ctr_reg = CLKMGR_CTL_CORE23CTR;
clock = clk_get_clksrc_hz(plat, ctr_reg,
CLKMGR_MAINPLL_PLLC0,
- } else {
ctr_reg = CLKMGR_CTL_CORE01CTR;
CLKMGR_MAINPLL_PLLC1,
- if (cpu == CORE3)
ctr_reg = CLKMGR_CTL_CORE3CTR;
- else if (cpu == CORE2)
ctr_reg = CLKMGR_CTL_CORE2CTR;
- else
- clock /= 1 + (CM_REG_READL(plat, ctr_reg) &
CLKMGR_CLKCNT_MSK);
- return clock;
+static u32 clk_get_l3_main_clk_hz(struct socfpga_clk_plat *plat) +{
- return clk_get_clksrc_hz(plat, CLKMGR_MAINPLL_NOCCLK,
CLKMGR_MAINPLL_PLLC3,
+static u32 clk_get_l4_main_clk_hz(struct socfpga_clk_plat *plat) +{
- u64 clock = clk_get_l3_main_clk_hz(plat);
- return clock;
+static u32 clk_get_l4_sp_clk_hz(struct socfpga_clk_plat *plat) +{
- clock /= BIT((CM_REG_READL(plat, CLKMGR_MAINPLL_NOCDIV) >>
CLKMGR_NOCDIV_L4SPCLK_OFFSET) &
CLKMGR_NOCDIV_DIVIDER_MASK);
- return clock;
+static u32 clk_get_l4_mp_clk_hz(struct socfpga_clk_plat *plat) +{
CLKMGR_NOCDIV_L4MPCLK_OFFSET) &
- return clock;
+static u32 clk_get_sdmmc_clk_hz(struct socfpga_clk_plat *plat) +{
- u64 clock = clk_get_l4_mp_clk_hz(plat);
CLKMGR_NOCDIV_SOFTPHY_OFFSET) &
- return clock;
+static u32 clk_get_l4_sys_free_clk_hz(struct socfpga_clk_plat *plat) +{
- if (CM_REG_READL(plat, CLKMGR_STAT) &
CLKMGR_STAT_BOOTMODE)
return clk_get_l3_main_clk_hz(plat) / 2;
- return clk_get_l3_main_clk_hz(plat) / 4;
+static u32 clk_get_emac_clk_hz(struct socfpga_clk_plat *plat, u32 emac_id) +{
- u32 ctl;
- u32 ctr_reg;
- u32 clock;
- u32 div;
- u32 reg;
- if (emac_id == AGILEX5_EMAC_PTP_CLK) {
reg = CM_REG_READL(plat, CLKMGR_CTL_EMACPTPCTR);
ctr_reg = CLKMGR_CTL_EMACPTPCTR;
- } else {
reg = CM_REG_READL(plat, CLKMGR_CTL_EMACACTR);
ctl = CM_REG_READL(plat, CLKMGR_PERPLL_EMACCTL);
if (emac_id == AGILEX5_EMAC0_CLK)
ctl = (ctl &
CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_MASK) >>
- CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_OFFSET;
else if (emac_id == AGILEX5_EMAC1_CLK)
ctl = (ctl &
CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_MASK) >>
- CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_OFFSET;
else if (emac_id == AGILEX5_EMAC2_CLK)
ctl = (ctl &
CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_MASK) >>
- CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_OFFSET;
else
if (ctl) {
/* EMAC B source */
ctr_reg = CLKMGR_CTL_EMACBCTR;
} else {
/* EMAC A source */
ctr_reg = CLKMGR_CTL_EMACACTR;
- /* Get EMAC clock source */
- clock = (reg & CLKMGR_CTL_EMACCTR_SRC_MASK)
>> CLKMGR_CTL_EMACCTR_SRC_OFFSET;
- reg = CM_REG_READL(plat, ctr_reg);
- div = (reg & CLKMGR_CTL_EMACCTR_CNT_MASK)
>> CLKMGR_CTL_EMACCTR_CNT_OFFSET;
- switch (clock) {
CLKMGR_MAINPLL_PLLC3) &
CLKMGR_CLKCNT_MSK);
} else {
CLKMGR_MAINPLL_PLLC1) &
CLKMGR_CLKCNT_MSK);
break;
clock /= (CM_REG_READL(plat, CLKMGR_PERPLL_PLLC3) &
CLKMGR_CLKCNT_MSK);
break;
break;
break;
break;
- clock /= 1 + div;
- return clock;
+static ulong socfpga_clk_get_rate(struct clk *clk) +{
- struct socfpga_clk_plat *plat = dev_get_plat(clk->dev);
- switch (clk->id) {
- case AGILEX5_MPU_CLK:
return clk_get_mpu_clk_hz(plat);
- case AGILEX5_L4_MAIN_CLK:
return clk_get_l4_main_clk_hz(plat);
- case AGILEX5_L4_SYS_FREE_CLK:
return clk_get_l4_sys_free_clk_hz(plat);
- case AGILEX5_L4_MP_CLK:
return clk_get_l4_mp_clk_hz(plat);
- case AGILEX5_L4_SP_CLK:
return clk_get_l4_sp_clk_hz(plat);
- case AGILEX5_SDMMC_CLK:
- case AGILEX5_NAND_CLK:
return clk_get_sdmmc_clk_hz(plat);
- case AGILEX5_EMAC0_CLK:
- case AGILEX5_EMAC1_CLK:
- case AGILEX5_EMAC2_CLK:
- case AGILEX5_EMAC_PTP_CLK:
return clk_get_emac_clk_hz(plat, clk->id);
- case AGILEX5_USB_CLK:
- case AGILEX5_NAND_X_CLK:
- default:
return -ENXIO;
+static int socfpga_clk_enable(struct clk *clk) +{
+static int socfpga_clk_probe(struct udevice *dev) +{
- const struct cm_config *cm_default_cfg = cm_get_default_config();
- clk_basic_init(dev, cm_default_cfg);
+static int socfpga_clk_of_to_plat(struct udevice *dev) +{
- fdt_addr_t addr;
- addr = dev_read_addr(dev);
- if (addr == FDT_ADDR_T_NONE)
return -EINVAL;
- plat->regs = (void __iomem *)addr;
+static struct clk_ops socfpga_clk_ops = {
- .enable = socfpga_clk_enable,
- .get_rate = socfpga_clk_get_rate,
+static const struct udevice_id socfpga_clk_match[] = {
- { .compatible = "intel,agilex5-clkmgr" },
+U_BOOT_DRIVER(socfpga_agilex5_clk) = {
- .name = "clk-agilex5",
- .id = UCLASS_CLK,
- .of_match = socfpga_clk_match,
- .ops = &socfpga_clk_ops,
- .probe = socfpga_clk_probe,
- .of_to_plat = socfpga_clk_of_to_plat,
- .plat_auto = sizeof(struct socfpga_clk_plat),
+}; diff --git a/drivers/clk/altera/clk-agilex5.h b/drivers/clk/altera/clk-agilex5.h new file mode 100644 index 0000000000..a4ddc1a60d --- /dev/null +++ b/drivers/clk/altera/clk-agilex5.h @@ -0,0 +1,284 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#ifndef _CLK_AGILEX5_ +#define _CLK_AGILEX5_
+#ifndef __ASSEMBLY__ +#include <linux/bitops.h> +#endif
+#define CORE0 1 +#define CORE1 2 +#define CORE2 3 +#define CORE3 4
+/* Derived from l4_main_clk (PSS clock) */ +#define COUNTER_FREQUENCY_REAL 400000000
+#define CM_REG_READL(plat, reg) \
- readl((plat)->regs + (reg))
+#define CM_REG_WRITEL(plat, data, reg) \
- writel(data, (plat)->regs + (reg))
+#define CM_REG_CLRBITS(plat, reg, clear) \
- clrbits_le32((plat)->regs + (reg), (clear))
+#define CM_REG_SETBITS(plat, reg, set) \
- setbits_le32((plat)->regs + (reg), (set))
+struct cm_config {
- /* main group */
- u32 main_pll_nocclk;
- u32 main_pll_nocdiv;
- u32 main_pll_pllglob;
- u32 main_pll_fdbck;
- u32 main_pll_pllc0;
- u32 main_pll_pllc1;
- u32 main_pll_pllc2;
- u32 main_pll_pllc3;
- u32 main_pll_pllm;
- /* peripheral group */
- u32 per_pll_emacctl;
- u32 per_pll_gpiodiv;
- u32 per_pll_pllglob;
- u32 per_pll_fdbck;
- u32 per_pll_pllc0;
- u32 per_pll_pllc1;
- u32 per_pll_pllc2;
- u32 per_pll_pllc3;
- u32 per_pll_pllm;
- /* control group */
- u32 ctl_emacactr;
- u32 ctl_emacbctr;
- u32 ctl_emacptpctr;
- u32 ctl_gpiodbctr;
- u32 ctl_s2fuser0ctr;
- u32 ctl_s2fuser1ctr;
- u32 ctl_psirefctr;
- u32 ctl_usb31ctr;
- u32 ctl_dsuctr;
- u32 ctl_core01ctr;
- u32 ctl_core23ctr;
- u32 ctl_core2ctr;
- u32 ctl_core3ctr;
- /* incoming clock */
- u32 hps_osc_clk_hz;
- u32 fpga_clk_hz;
- u32 spare[3];
+/* Clock Manager registers */ +#define CLKMGR_CTRL 0 +#define CLKMGR_STAT 4 +#define CLKMGR_TESTIOCTRL 8 +#define CLKMGR_INTRGEN 0x0c +#define CLKMGR_INTRMSK 0x10 +#define CLKMGR_INTRCLR 0x14 +#define CLKMGR_INTRSTS 0x18 +#define CLKMGR_INTRSTK 0x1c +#define CLKMGR_INTRRAW 0x20
+/* Clock Manager Main PPL group registers */ +#define CLKMGR_MAINPLL_EN 0x24 +#define CLKMGR_MAINPLL_ENS 0x28 +#define CLKMGR_MAINPLL_ENR 0x2c +#define CLKMGR_MAINPLL_BYPASS 0x30 +#define CLKMGR_MAINPLL_BYPASSS 0x34 +#define CLKMGR_MAINPLL_BYPASSR 0x38 +#define CLKMGR_MAINPLL_NOCCLK 0x40 +#define CLKMGR_MAINPLL_NOCDIV 0x44 +#define CLKMGR_MAINPLL_PLLGLOB 0x48 +#define CLKMGR_MAINPLL_FDBCK 0x4c +#define CLKMGR_MAINPLL_MEM 0x50 +#define CLKMGR_MAINPLL_MEMSTAT 0x54 +#define CLKMGR_MAINPLL_VCOCALIB 0x58 +#define CLKMGR_MAINPLL_PLLC0 0x5c +#define CLKMGR_MAINPLL_PLLC1 0x60 +#define CLKMGR_MAINPLL_PLLC2 0x64 +#define CLKMGR_MAINPLL_PLLC3 0x68 +#define CLKMGR_MAINPLL_PLLM 0x6c +#define CLKMGR_MAINPLL_FHOP 0x70 +#define CLKMGR_MAINPLL_SSC 0x74 +#define CLKMGR_MAINPLL_LOSTLOCK 0x78
+/* Clock Manager Peripheral PPL group registers */ +#define CLKMGR_PERPLL_EN 0x7c +#define CLKMGR_PERPLL_ENS 0x80 +#define CLKMGR_PERPLL_ENR 0x84 +#define CLKMGR_PERPLL_BYPASS 0x88 +#define CLKMGR_PERPLL_BYPASSS 0x8c +#define CLKMGR_PERPLL_BYPASSR 0x90 +#define CLKMGR_PERPLL_EMACCTL 0x94 +#define CLKMGR_PERPLL_GPIODIV 0x98 +#define CLKMGR_PERPLL_PLLGLOB 0x9c +#define CLKMGR_PERPLL_FDBCK 0xa0 +#define CLKMGR_PERPLL_MEM 0xa4 +#define CLKMGR_PERPLL_MEMSTAT 0xa8 +#define CLKMGR_PERPLL_VCOCALIB 0xac +#define CLKMGR_PERPLL_PLLC0 0xb0 +#define CLKMGR_PERPLL_PLLC1 0xb4 +#define CLKMGR_PERPLL_PLLC2 0xb8 +#define CLKMGR_PERPLL_PLLC3 0xbc +#define CLKMGR_PERPLL_PLLM 0xc0 +#define CLKMGR_PERPLL_FHOP 0xc4 +#define CLKMGR_PERPLL_SSC 0xc8 +#define CLKMGR_PERPLL_LOSTLOCK 0xcc
+/* Clock Manager Control group registers */ +#define CLKMGR_CTL_JTAG 0xd0 +#define CLKMGR_CTL_EMACACTR 0xd4 +#define CLKMGR_CTL_EMACBCTR 0xd8 +#define CLKMGR_CTL_EMACPTPCTR 0xdc +#define CLKMGR_CTL_GPIODBCTR 0xe0 +#define CLKMGR_CTL_S2FUSER0CTR 0xe8 +#define CLKMGR_CTL_S2FUSER1CTR 0xec +#define CLKMGR_CTL_PSIREFCTR 0xf0 +#define CLKMGR_CTL_EXTCNTRST 0xf4 +#define CLKMGR_CTL_USB31CTR 0xf8 +#define CLKMGR_CTL_DSUCTR 0xfc +#define CLKMGR_CTL_CORE01CTR 0x100 +#define CLKMGR_CTL_CORE23CTR 0x104 +#define CLKMGR_CTL_CORE2CTR 0x108 +#define CLKMGR_CTL_CORE3CTR 0x10C
+#define CLKMGR_CTRL_BOOTMODE BIT(0)
+#define CLKMGR_STAT_BUSY BIT(0) +#define CLKMGR_STAT_MAINPLL_LOCKED BIT(8) +#define CLKMGR_STAT_MAIN_TRANS BIT(9) +#define CLKMGR_STAT_PERPLL_LOCKED BIT(16) +#define CLKMGR_STAT_PERF_TRANS BIT(17) +#define CLKMGR_STAT_BOOTMODE BIT(24) +#define CLKMGR_STAT_BOOTCLKSRC BIT(25)
+#define CLKMGR_STAT_ALLPLL_LOCKED_MASK \
- (CLKMGR_STAT_MAINPLL_LOCKED | CLKMGR_STAT_PERPLL_LOCKED)
+#define CLKMGR_INTER_MAINPLLLOCKED_MASK 0x00000001 +#define CLKMGR_INTER_PERPLLLOCKED_MASK 0x00000002 +#define CLKMGR_INTER_MAINPLLLOST_MASK 0x00000004 +#define CLKMGR_INTER_PERPLLLOST_MASK 0x00000008
+#define CLKMGR_CLKSRC_MASK GENMASK(18, 16) +#define CLKMGR_CLKSRC_OFFSET 16 +#define CLKMGR_CLKSRC_MAIN 0 +#define CLKMGR_CLKSRC_PER 1 +#define CLKMGR_CLKSRC_OSC1 2 +#define CLKMGR_CLKSRC_INTOSC 3 +#define CLKMGR_CLKSRC_FPGA 4 +#define CLKMGR_CLKCNT_MSK GENMASK(10, 0)
+#define CLKMGR_BYPASS_MAINPLL_ALL 0xf6 +#define CLKMGR_BYPASS_PERPLL_ALL 0xef
+#define CLKMGR_NOCDIV_SOFTPHY_DIV_ONE 0 +#define CLKMGR_NOCDIV_SOFTPHY_DIV_TWO 1 +#define CLKMGR_NOCDIV_SOFTPHY_DIV_FOUR 2 +#define CLKMGR_NOCDIV_L4SYSFREECLK_OFFSET 0 +#define CLKMGR_NOCDIV_L4MPCLK_OFFSET 4 +#define CLKMGR_NOCDIV_L4SPCLK_OFFSET 6 +#define CLKMGR_NOCDIV_SOFTPHY_OFFSET 16 +#define CLKMGR_NOCDIV_CCU_OFFSET 18 +#define CLKMGR_NOCDIV_MPUPERIPH_OFFSET 20 +#define CLKMGR_NOCDIV_CSATCLK_OFFSET 24 +#define CLKMGR_NOCDIV_CSTRACECLK_OFFSET 26 +#define CLKMGR_NOCDIV_CSPDBGCLK_OFFSET 28 +#define CLKMGR_NOCDIV_DIVIDER_MASK 0x3
+#define CLKMGR_PLLGLOB_PD_MASK BIT(0) +#define CLKMGR_PLLGLOB_RST_MASK BIT(1) +#define CLKMGR_PLLGLOB_AREFCLKDIV_MASK GENMASK(11, 8) +#define CLKMGR_PLLGLOB_DREFCLKDIV_MASK GENMASK(13, 12) +#define CLKMGR_PLLGLOB_REFCLKDIV_MASK GENMASK(13, 8) +#define CLKMGR_PLLGLOB_MODCLKDIV_MASK GENMASK(24, 27) +#define CLKMGR_PLLGLOB_AREFCLKDIV_OFFSET 8 +#define CLKMGR_PLLGLOB_DREFCLKDIV_OFFSET 12 +#define CLKMGR_PLLGLOB_REFCLKDIV_OFFSET 8 +#define CLKMGR_PLLGLOB_MODCLKDIV_OFFSET 24 +#define CLKMGR_PLLGLOB_VCO_PSRC_MASK GENMASK(17, 16) +#define CLKMGR_PLLGLOB_VCO_PSRC_OFFSET 16 +#define CLKMGR_PLLGLOB_CLR_LOSTLOCK_BYPASS_MASK BIT(29)
+#define CLKMGR_VCO_PSRC_EOSC1 0 +#define CLKMGR_VCO_PSRC_INTOSC 1 +#define CLKMGR_VCO_PSRC_F2S 2
+#define CLKMGR_MEM_REQ_SET_MSK BIT(24) +#define CLKMGR_MEM_WR_SET_MSK BIT(25) +#define CLKMGR_MEM_ERR_MSK BIT(26) +#define CLKMGR_MEM_WDAT_LSB_OFFSET 16 +#define CLKMGR_MEM_ADDR_MASK GENMASK(15, 0) +#define CLKMGR_MEM_ADDR_START 0x00004000
+#define CLKMGR_PLLCX_EN_SET_MSK BIT(27) +#define CLKMGR_PLLCX_MUTE_SET_MSK BIT(28)
+#define CLKMGR_VCOCALIB_MSCNT_MASK GENMASK(23, 16) +#define CLKMGR_VCOCALIB_MSCNT_OFFSET 16 +#define CLKMGR_VCOCALIB_HSCNT_MASK GENMASK(9, 0) +#define CLKMGR_VCOCALIB_MSCNT_CONST 100 +#define CLKMGR_VCOCALIB_HSCNT_CONST 4
+#define CLKMGR_PLLM_MDIV_MASK GENMASK(9, 0)
+#define CLKMGR_LOSTLOCK_SET_MASK BIT(0)
+#define CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK BIT(5) +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_OFFSET 26 +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_MASK BIT(26) +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_OFFSET 27 +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_MASK BIT(27) +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_OFFSET 28 +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_MASK BIT(28)
+#define CLKMGR_CTL_EMACCTR_SRC_OFFSET 16 +#define CLKMGR_CTL_EMACCTR_SRC_MASK GENMASK(18, 16) +#define CLKMGR_CTL_EMACCTR_CNT_OFFSET 0 +#define CLKMGR_CTL_EMACCTR_CNT_MASK GENMASK(10, 0)
+#define CLKMGR_CTL_EXTCNTRST_EMACACNTRST BIT(0) +#define CLKMGR_CTL_EXTCNTRST_EMACBCNTRST BIT(1) +#define CLKMGR_CTL_EXTCNTRST_EMACPTPCNTRST BIT(2) +#define CLKMGR_CTL_EXTCNTRST_GPIODBCNTRST BIT(3) +#define CLKMGR_CTL_EXTCNTRST_S2FUSER0CNTRST BIT(5) +#define CLKMGR_CTL_EXTCNTRST_S2FUSER1CNTRST BIT(6) +#define CLKMGR_CTL_EXTCNTRST_PSIREFCNTRST BIT(7) +#define CLKMGR_CTL_EXTCNTRST_USB31REFCNTRST BIT(8) +#define CLKMGR_CTL_EXTCNTRST_DSUCNTRST BIT(10) +#define CLKMGR_CTL_EXTCNTRST_CORE01CNTRST BIT(11) +#define CLKMGR_CTL_EXTCNTRST_CORE2CNTRST BIT(12) +#define CLKMGR_CTL_EXTCNTRST_CORE3CNTRST BIT(13) +#define CLKMGR_CTL_EXTCNTRST_ALLCNTRST \
- (CLKMGR_CTL_EXTCNTRST_EMACACNTRST | \
CLKMGR_CTL_EXTCNTRST_EMACBCNTRST | \
CLKMGR_CTL_EXTCNTRST_EMACPTPCNTRST | \
CLKMGR_CTL_EXTCNTRST_GPIODBCNTRST | \
CLKMGR_CTL_EXTCNTRST_S2FUSER0CNTRST | \
CLKMGR_CTL_EXTCNTRST_S2FUSER1CNTRST | \
CLKMGR_CTL_EXTCNTRST_PSIREFCNTRST | \
CLKMGR_CTL_EXTCNTRST_USB31REFCNTRST | \
CLKMGR_CTL_EXTCNTRST_DSUCNTRST | \
CLKMGR_CTL_EXTCNTRST_CORE01CNTRST | \
CLKMGR_CTL_EXTCNTRST_CORE2CNTRST | \
CLKMGR_CTL_EXTCNTRST_CORE3CNTRST)
+#define MEMBUS_MAINPLL 0 +#define MEMBUS_PERPLL 1 +#define MEMBUS_TIMEOUT 1000
+#define MEMBUS_CLKSLICE_REG 0x27 +#define MEMBUS_SYNTHCALFOSC_INIT_CENTERFREQ_REG 0xb3 +#define MEMBUS_SYNTHPPM_WATCHDOGTMR_VF01_REG 0xe6 +#define MEMBUS_CALCLKSLICE0_DUTY_LOCOVR_REG 0x03 +#define MEMBUS_CALCLKSLICE1_DUTY_LOCOVR_REG 0x07
+#define MPIDR_AFF1_OFFSET 8 +#define MPIDR_AFF1_MASK 0x3 +#endif /* _CLK_AGILEX5_ */ diff --git a/include/configs/socfpga_agilex5_socdk.h b/include/configs/socfpga_agilex5_socdk.h new file mode 100644 index 0000000000..b5b5bd767f --- /dev/null +++ b/include/configs/socfpga_agilex5_socdk.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0
- Copyright (C) 2024 Intel Corporation <www.intel.com>
+#ifndef __CONFIG_SOCFGPA_AGILEX5_H__ +#define __CONFIG_SOCFGPA_AGILEX5_H__
+#include <configs/socfpga_soc64_common.h>
+#endif /* __CONFIG_SOCFGPA_AGILEX5_H__ */ diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 820372c28b..b7ee1dbf20 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0
- Copyright (C) 2017-2019 Intel Corporation <www.intel.com>
- Copyright (C) 2017-2024 Intel Corporation <www.intel.com>
@@ -26,8 +26,13 @@ /*
- U-Boot run time memory configurations
*/ +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define CFG_SYS_INIT_RAM_ADDR 0x0 +#define CFG_SYS_INIT_RAM_SIZE 0x80000 +#else #define CFG_SYS_INIT_RAM_ADDR 0xFFE00000 #define CFG_SYS_INIT_RAM_SIZE 0x40000 +#endif
- U-Boot environment configurations
@@ -36,9 +41,121 @@ /*
- Environment variable
*/ +#if IS_ENABLED(CONFIG_DISTRO_DEFAULTS) +#if IS_ENABLED(CONFIG_CMD_MMC) +#define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) +#else +#define BOOT_TARGET_DEVICES_MMC(func) +#endif
+#if IS_ENABLED(CONFIG_CMD_SF) +#define BOOT_TARGET_DEVICES_QSPI(func) func(QSPI, qspi, na) +#else +#define BOOT_TARGET_DEVICES_QSPI(func) +#endif
+#define BOOTENV_DEV_QSPI(devtypeu, devtypel, instance) \
- "bootcmd_qspi=ubi detach; sf probe && " \
- "if ubi part root && ubi readvol ${scriptaddr} script; " \
- "then echo QSPI: Running script from UBIFS; " \
- "elif sf read ${scriptaddr} ${qspiscriptaddr} ${scriptsize}; " \
- "then echo QSPI: Running script from JFFS2; fi; " \
- "echo QSPI: Trying to boot script at ${scriptaddr} && " \
- "source ${scriptaddr}; " \
- "echo QSPI: SCRIPT FAILED: continuing...; ubi detach;\0"
+#define BOOTENV_DEV_NAME_QSPI(devtypeu, devtypel, instance) \
- "qspi "
+#define BOOT_TARGET_DEVICES(func) \
- BOOT_TARGET_DEVICES_MMC(func) \
- BOOT_TARGET_DEVICES_QSPI(func)
+#include <config_distro_bootcmd.h>
#define CFG_EXTRA_ENV_SETTINGS \
- "kernel_addr_r=0x82000000\0" \
- "fdt_addr_r=0x86000000\0" \
- "qspiscriptaddr=0x02110000\0" \
- "scriptsize=0x00010000\0" \
- "qspibootimageaddr=0x02120000\0" \
- "bootimagesize=0x03200000\0" \ "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "bootfile=" CONFIG_BOOTFILE "\0" \
- "mmcroot=/dev/mmcblk0p2\0" \
- "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \
- "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \
- "linux_qspi_enable=if sf probe; then " \
"echo Enabling QSPI at Linux DTB...;" \
"fdt addr ${fdt_addr}; fdt resize;" \
"fdt set /soc/spi@108d2000 status okay;" \
"if fdt set /clocks/qspi-clk clock-frequency" \
" ${qspi_clock}; then echo QSPI clock frequency updated;" \
" elif fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency" \
" else fdt set /clocks/qspi-clk clock-frequency" \
" ${qspi_clock}; echo QSPI clock frequency updated; fi; fi\0" \
- "scriptaddr=0x81000000\0" \
- "scriptfile=boot.scr\0" \
- "socfpga_legacy_reset_compat=1\0" \
- "smc_fid_rd=0xC2000007\0" \
- "smc_fid_wr=0xC2000008\0" \
- "smc_fid_upd=0xC2000009\0 " \
- BOOTENV
+#else
+#define CFG_EXTRA_ENV_SETTINGS \
- "kernel_addr_r=0x2000000\0" \
- "fdt_addr_r=0x6000000\0" \
- "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \
- "bootfile=" CONFIG_BOOTFILE "\0" \
"fdt set /soc/spi@ff8d2000 status okay;" \
"if fdt set /soc/clocks/qspi-clk clock-frequency" \
- "scriptaddr=0x05FF0000\0" \
- BOOTENV
+#endif /*#IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5)*/
+#else
- "kernel_comp_addr_r=0x9000000\0" \
- "kernel_comp_size=0x01000000\0" \
- "qspibootimageaddr=0x020E0000\0" \
- "qspifdtaddr=0x020D0000\0" \
- "bootimagesize=0x01F00000\0" \
- "fdtimagesize=0x00010000\0" \
- "qspiload=sf read ${loadaddr} ${qspibootimageaddr}
${bootimagesize};" \
"sf read ${fdt_addr} ${qspifdtaddr} ${fdtimagesize}\0" \
- "qspiboot=setenv bootargs earlycon root=/dev/mtdblock1 rw " \
"rootfstype=jffs2 rootwait;booti ${loadaddr} - ${fdt_addr}\0" \
- "qspifitload=sf read ${loadaddr} ${qspibootimageaddr}
${bootimagesize}\0" \
- "qspifitboot=setenv bootargs earlycon root=/dev/mtdblock1 rw " \
"rootfstype=jffs2 rootwait;bootm ${loadaddr}\0" \
- "bootfile=" CONFIG_BOOTFILE "\0" \ "fdt_addr=8000000\0" \ "fdtimage=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "mmcroot=/dev/mmcblk0p2\0" \
@@ -53,24 +170,40 @@ "bootm ${loadaddr}\0" \ "mmcfitload=mmc rescan;" \ "load mmc 0:1 ${loadaddr} ${bootfile}\0" \
- "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ "linux_qspi_enable=if sf probe; then " \ "echo Enabling QSPI at Linux DTB...;" \ "fdt addr ${fdt_addr}; fdt resize;" \ "fdt set /soc/spi@ff8d2000 status okay;" \
"fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency " \
" ${qspi_clock}; fi; \0" \
"scriptaddr=0x02100000\0" \ "scriptfile=u-boot.scr\0" \ "fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};" \" ${qspi_clock}; echo QSPI clock frequency updated; fi; fi\0" \
"then source ${scriptaddr}; fi\0" \
"then source ${scriptaddr}:script; fi\0" \
+#endif /*#if IS_ENABLED(CONFIG_DISTRO_DEFAULTS)*/
- External memory configurations
*/ +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_1_SIZE (1 * 1024 * 1024 * 1024) +#define CFG_SYS_SDRAM_BASE 0x80000000 +#else #define PHYS_SDRAM_1 0x0 #define PHYS_SDRAM_1_SIZE (1 * 1024 * 1024 * 1024) #define CFG_SYS_SDRAM_BASE 0 +#endif
- Serial / UART configurations
diff --git a/include/dt-bindings/clock/agilex5-clock.h b/include/dt- bindings/clock/agilex5-clock.h new file mode 100644 index 0000000000..c84fa51540 --- /dev/null +++ b/include/dt-bindings/clock/agilex5-clock.h @@ -0,0 +1,71 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
- Copyright (C) 2024, Intel Corporation
+#ifndef __AGILEX5_CLOCK_H +#define __AGILEX5_CLOCK_H
+/* fixed rate clocks */ +#define AGILEX5_OSC1 0 +#define AGILEX5_CB_INTOSC_HS_DIV2_CLK 1 +#define AGILEX5_CB_INTOSC_LS_CLK 2 +#define AGILEX5_L4_SYS_FREE_CLK 3 +#define AGILEX5_F2S_FREE_CLK 4
+/* PLL clocks */ +#define AGILEX5_MAIN_PLL_CLK 5 +#define AGILEX5_MAIN_PLL_C0_CLK 6 +#define AGILEX5_MAIN_PLL_C1_CLK 7 +#define AGILEX5_MAIN_PLL_C2_CLK 8 +#define AGILEX5_MAIN_PLL_C3_CLK 9 +#define AGILEX5_PERIPH_PLL_CLK 10 +#define AGILEX5_PERIPH_PLL_C0_CLK 11 +#define AGILEX5_PERIPH_PLL_C1_CLK 12 +#define AGILEX5_PERIPH_PLL_C2_CLK 13 +#define AGILEX5_PERIPH_PLL_C3_CLK 14 +#define AGILEX5_MPU_FREE_CLK 15 +#define AGILEX5_MPU_CCU_CLK 16 +#define AGILEX5_BOOT_CLK 17
+/* fixed factor clocks */ +#define AGILEX5_L3_MAIN_FREE_CLK 18 +#define AGILEX5_NOC_FREE_CLK 19 +#define AGILEX5_S2F_USR0_CLK 20 +#define AGILEX5_NOC_CLK 21 +#define AGILEX5_EMAC_A_FREE_CLK 22 +#define AGILEX5_EMAC_B_FREE_CLK 23 +#define AGILEX5_EMAC_PTP_FREE_CLK 24 +#define AGILEX5_GPIO_DB_FREE_CLK 25 +#define AGILEX5_SDMMC_FREE_CLK 26 +#define AGILEX5_S2F_USER0_FREE_CLK 27 +#define AGILEX5_S2F_USER1_FREE_CLK 28 +#define AGILEX5_PSI_REF_FREE_CLK 29
+/* Gate clocks */ +#define AGILEX5_MPU_CLK 30 +#define AGILEX5_MPU_PERIPH_CLK 31 +#define AGILEX5_L4_MAIN_CLK 32 +#define AGILEX5_L4_MP_CLK 33 +#define AGILEX5_L4_SP_CLK 34 +#define AGILEX5_CS_AT_CLK 35 +#define AGILEX5_CS_TRACE_CLK 36 +#define AGILEX5_CS_PDBG_CLK 37 +#define AGILEX5_CS_TIMER_CLK 38 +#define AGILEX5_S2F_USER0_CLK 39 +#define AGILEX5_EMAC0_CLK 40 +#define AGILEX5_EMAC1_CLK 41 +#define AGILEX5_EMAC2_CLK 42 +#define AGILEX5_EMAC_PTP_CLK 43 +#define AGILEX5_GPIO_DB_CLK 44 +#define AGILEX5_NAND_CLK 45 +#define AGILEX5_PSI_REF_CLK 46 +#define AGILEX5_S2F_USER1_CLK 47 +#define AGILEX5_SDMMC_CLK 48 +#define AGILEX5_SPI_M_CLK 49 +#define AGILEX5_USB_CLK 50 +#define AGILEX5_NAND_X_CLK 51 +#define AGILEX5_NAND_ECC_CLK 52 +#define AGILEX5_NUM_CLKS 53
+#endif /* __AGILEX5_CLOCK_H */ diff --git a/include/dt-bindings/reset/altr,rst-mgr-agx5.h b/include/dt- bindings/reset/altr,rst-mgr-agx5.h new file mode 100644 index 0000000000..1dba270aed --- /dev/null +++ b/include/dt-bindings/reset/altr,rst-mgr-agx5.h @@ -0,0 +1,80 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
- Copyright (C) 2024 Intel Corporation. All rights reserved
+#ifndef _DT_BINDINGS_RESET_ALTR_RST_MGR_AGX_EDGE_H +#define _DT_BINDINGS_RESET_ALTR_RST_MGR_AGX_EDGE_H
+/* PER0MODRST */ +#define EMAC0_RESET 0 +#define EMAC1_RESET 1 +#define EMAC2_RESET 2 +#define USB0_RESET 3 +#define USB1_RESET 4 +#define NAND_RESET 5 +#define COMBOPHY_RESET 6 +#define SDMMC_RESET 7 +#define EMAC0_OCP_RESET 8 +#define EMAC1_OCP_RESET 9 +#define EMAC2_OCP_RESET 10 +#define USB0_OCP_RESET 11 +#define USB1_OCP_RESET 12 +#define NAND_OCP_RESET 13 +/* 14 is empty */ +#define SDMMC_OCP_RESET 15 +#define DMA_RESET 16 +#define SPIM0_RESET 17 +#define SPIM1_RESET 18 +#define SPIS0_RESET 19 +#define SPIS1_RESET 20 +#define DMA_OCP_RESET 21 +#define EMAC_PTP_RESET 22 +/* 23 is empty*/ +#define DMAIF0_RESET 24 +#define DMAIF1_RESET 25 +#define DMAIF2_RESET 26 +#define DMAIF3_RESET 27 +#define DMAIF4_RESET 28 +#define DMAIF5_RESET 29 +#define DMAIF6_RESET 30 +#define DMAIF7_RESET 31
+/* PER1MODRST */ +#define WATCHDOG0_RESET 32 +#define WATCHDOG1_RESET 33 +#define WATCHDOG2_RESET 34 +#define WATCHDOG3_RESET 35 +#define L4SYSTIMER0_RESET 36 +#define L4SYSTIMER1_RESET 37 +#define SPTIMER0_RESET 38 +#define SPTIMER1_RESET 39 +#define I2C0_RESET 40 +#define I2C1_RESET 41 +#define I2C2_RESET 42 +#define I2C3_RESET 43 +#define I2C4_RESET 44 +#define I3C0_RESET 45 +#define I3C1_RESET 46 +/* 47 is empty */ +#define UART0_RESET 48 +#define UART1_RESET 49 +/* 50-55 is empty */ +#define GPIO0_RESET 56 +#define GPIO1_RESET 57 +#define WATCHDOG4_RESET 58 +/* 59-63 is empty */
+/* BRGMODRST */ +#define SOC2FPGA_RESET 64 +#define LWHPS2FPGA_RESET 65 +#define FPGA2SOC_RESET 66 +#define F2SSDRAM_RESET 67 +/* 68-69 is empty */ +#define DDRSCH_RESET 70 +/* 71-95 is empty */
+/* DBGMODRST */ +#define DBG_RESET 192
2.19.0
Reviewed-by: Tien Fong Chee tien.fong.chee@intel.com
Regards Tien Fong
Hi Jit loon,
-----Original Message----- From: Lim, Jit Loon jit.loon.lim@intel.com Sent: Thursday, March 7, 2024 12:42 AM To: u-boot@lists.denx.de Cc: Jagan Teki jagan@amarulasolutions.com; Marek marex@denx.de; Simon simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com; Maniyam, Dinesh dinesh.maniyam@intel.com; Ng, Boon Khai boon.khai.ng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Chong, Teik Heng teik.heng.chong@intel.com; Zamri, Muhammad Hazim Izzat muhammad.hazim.izzat.zamri@intel.com; Lim, Jit Loon jit.loon.lim@intel.com; Tang, Sieu Mun sieu.mun.tang@intel.com; Bin Meng bmeng.cn@gmail.com Subject: [RESEND v2 1/1] arch: arm: Agilex5 enablement
This patch is to enable Agilex5 platform for Intel product. Changes, modification and new files are created for board, dts, configs and makefile to create the base for Agilex5.
Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com
Changes v1 -> v2:
- fixed git auto merge issue
@@ -10,6 +10,62 @@
/* OCRAM 512KB */
/* DEVICE */
/* FPGA 1.5GB */
/* FPGA 15GB */
/* FPGA 240GB */
This size is not 240GB, please correct it.
Best regards, Tien Fong
Chee, Tien Fong
Jit Loon Lim
