[U-Boot] [PATCH V3] OMAP3EVM: Added NAND support
Changes:
- Changed default configuration from ONENAND to NAND - User can choose between ONENAND and NAND, define either CMD_NAND or CMD_ONENAND in omap3_evm.h
Signed-off-by: Vaibhav Hiremath hvaibhav@ti.com --- include/configs/omap3_evm.h | 9 ++++++++- 1 files changed, 8 insertions(+), 1 deletions(-)
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index a5514ae..71bab7d 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -110,7 +110,8 @@
#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_MMC /* MMC support */ -#define CONFIG_CMD_ONENAND /* ONENAND support */ +/*#define CONFIG_CMD_ONENAND*/ /* ONENAND support */ +#define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_DHCP #define CONFIG_CMD_PING
@@ -268,7 +269,13 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
+#if defined(CONFIG_CMD_NAND) +#define CONFIG_NAND_OMAP_GPMC +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 +#define CONFIG_ENV_IS_IN_NAND 1 +#elif defined(CONFIG_CMD_ONENAND) #define CONFIG_ENV_IS_IN_ONENAND 1 +#endif #define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */
-- 1.6.2.4
hvaibhav@ti.com
