[U-Boot] [PATCH] mtd: nand: mxs: fix PIO_WORD number
There is only one pio_word in this DMA transaction so data field must be 1.
Signed-off-by: Luca Ellero luca.ellero@brickedbrain.com --- drivers/mtd/nand/mxs_nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index 7a064ab..616c9ca 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -305,7 +305,7 @@ static void mxs_nand_cmd_ctrl(struct mtd_info *mtd, int data, unsigned int ctrl) d->cmd.data = MXS_DMA_DESC_COMMAND_DMA_READ | MXS_DMA_DESC_IRQ | MXS_DMA_DESC_CHAIN | MXS_DMA_DESC_DEC_SEM | - MXS_DMA_DESC_WAIT4END | (3 << MXS_DMA_DESC_PIO_WORDS_OFFSET) | + MXS_DMA_DESC_WAIT4END | (1 << MXS_DMA_DESC_PIO_WORDS_OFFSET) | (nand_info->cmd_queue_len << MXS_DMA_DESC_BYTES_OFFSET);
d->cmd.address = (dma_addr_t)nand_info->cmd_buf;
Hi Luca,
(nand_info->cmd_queue_len << MXS_DMA_DESC_BYTES_OFFSET);MXS_DMA_DESC_WAIT4END | (1 << MXS_DMA_DESC_PIO_WORDS_OFFSET) |
What error or problem does this incorrect setup cause in your case? I'm asking since I'm also using this driver in some mx6 system and have not seen any issues.
Thanks, Stefan
Hi Stefan,
On 12/12/2014 09:43, Stefan Roese wrote:
Hi Luca,
As far as I can see, it doesn't seem to cause any issue. But, if you read the iMX6 Reference Manual (chapter 14.2) this field should reflect the number of PIO_WORDS appended to the DMA command, in this case 1.
Hi Luca,
Okay. I just wanted to check if this patch fixes a real problem that you have experienced. Thanks for the explanation.
Thanks, Stefan
On Friday, December 12, 2014 at 01:43:22 PM, Stefan Roese wrote:
Hi Luca,
The patch does in fact change the behavior such that it no longer clears the ECCCTRL and COMPARE registers both on MX28 and on MX6 . Could this have some impact?
Best regards, Marek Vasut
Hi Marek,
Hi Luca,
I'm not sure. The manual doesn't tell much about it. Anyway if we want to clear COMPARE and ECCCTRL register, we should at least ensure that pio_words 1 and 2 are 0 before executing the DMA chain.
Something like this:
d->cmd.pio_words[1] = 0; d->cmd.pio_words[2] = 0;
What do you think?
regards
On Friday, December 12, 2014 at 04:03:14 PM, Luca Ellero wrote:
Hi Marek,
Hi Luca,
What do you think?
I believe the descriptor is zeroed out in mxs_nand_return_dma_descs(), though I admit depending on such behavior is pretty iffy.
The question is, does your patch introduce a side-effect ? My proposal would be to schedule the patch for -next and see what happens. I believe the patch would be just fine and won't break anything.
What do you think ?
Hi Marek,
Hi Marek,
Hi Luca,
On 10.12.2014 09:24, Luca Ellero wrote: > There is only one pio_word in this DMA transaction so data field must > be 1. > > Signed-off-by: Luca Ellero luca.ellero@brickedbrain.com > --- > > drivers/mtd/nand/mxs_nand.c | 2 +- > 1 file changed, 1 insertion(+), 1 deletion(-) > > diff --git a/drivers/mtd/nand/mxs_nand.c > b/drivers/mtd/nand/mxs_nand.c index 7a064ab..616c9ca 100644 > --- a/drivers/mtd/nand/mxs_nand.c > +++ b/drivers/mtd/nand/mxs_nand.c > @@ -305,7 +305,7 @@ static void mxs_nand_cmd_ctrl(struct mtd_info > *mtd, int data, unsigned int ctrl) > > d->cmd.data = > > MXS_DMA_DESC_COMMAND_DMA_READ | MXS_DMA_DESC_IRQ | > MXS_DMA_DESC_CHAIN | MXS_DMA_DESC_DEC_SEM | > > - MXS_DMA_DESC_WAIT4END | (3 << MXS_DMA_DESC_PIO_WORDS_OFFSET) > | + MXS_DMA_DESC_WAIT4END | (1 << > MXS_DMA_DESC_PIO_WORDS_OFFSET) | > > (nand_info->cmd_queue_len << MXS_DMA_DESC_BYTES_OFFSET);
What do you think?
What do you think ?
Scheduling the patch for -next it's ok for me. However there are other two points where pio_words number doesn't reflect the pio_words really initiated, one is in mxs_nand_read_buf() and one is in mxs_nand_write_buf(). Each one declares 4 pio_words but only one is initiated. I wonder what we should do in this cases. Regards
On Monday, December 15, 2014 at 09:45:13 AM, Luca Ellero wrote:
Hi Marek,
Hi Marek,
Hi Luca,
> On 10.12.2014 09:24, Luca Ellero wrote: >> There is only one pio_word in this DMA transaction so data field >> must be 1. >> >> Signed-off-by: Luca Ellero luca.ellero@brickedbrain.com >> --- >> >> drivers/mtd/nand/mxs_nand.c | 2 +- >> 1 file changed, 1 insertion(+), 1 deletion(-) >> >> diff --git a/drivers/mtd/nand/mxs_nand.c >> b/drivers/mtd/nand/mxs_nand.c index 7a064ab..616c9ca 100644 >> --- a/drivers/mtd/nand/mxs_nand.c >> +++ b/drivers/mtd/nand/mxs_nand.c >> @@ -305,7 +305,7 @@ static void mxs_nand_cmd_ctrl(struct mtd_info >> *mtd, int data, unsigned int ctrl) >> >> d->cmd.data = >> >> MXS_DMA_DESC_COMMAND_DMA_READ | MXS_DMA_DESC_IRQ | >> MXS_DMA_DESC_CHAIN | MXS_DMA_DESC_DEC_SEM | >> >> - MXS_DMA_DESC_WAIT4END | (3 << >> MXS_DMA_DESC_PIO_WORDS_OFFSET) >> >> | + MXS_DMA_DESC_WAIT4END | (1 << >> >> MXS_DMA_DESC_PIO_WORDS_OFFSET) | >> >> (nand_info->cmd_queue_len << >> MXS_DMA_DESC_BYTES_OFFSET); > > What error or problem does this incorrect setup cause in your case? > I'm asking since I'm also using this driver in some mx6 system and > have not seen any issues.
Something like this: d->cmd.pio_words[1] = 0; d->cmd.pio_words[2] = 0;
What do you think?
What do you think ?
You can fix those as well. I recall that all this goop came from the original (2.6.35) GPMI NAND driver, which is likely where all those bugs came from as well.
Thank you!
Hi Marek,
Hi Marek,
Hi Luca,
On 12.12.2014 13:40, Luca Ellero wrote: >> On 10.12.2014 09:24, Luca Ellero wrote: >>> There is only one pio_word in this DMA transaction so data field >>> must be 1. >>> >>> Signed-off-by: Luca Ellero luca.ellero@brickedbrain.com >>> --- >>> >>> drivers/mtd/nand/mxs_nand.c | 2 +- >>> 1 file changed, 1 insertion(+), 1 deletion(-) >>> >>> diff --git a/drivers/mtd/nand/mxs_nand.c >>> b/drivers/mtd/nand/mxs_nand.c index 7a064ab..616c9ca 100644 >>> --- a/drivers/mtd/nand/mxs_nand.c >>> +++ b/drivers/mtd/nand/mxs_nand.c >>> @@ -305,7 +305,7 @@ static void mxs_nand_cmd_ctrl(struct mtd_info >>> *mtd, int data, unsigned int ctrl) >>> >>> d->cmd.data = >>> >>> MXS_DMA_DESC_COMMAND_DMA_READ | MXS_DMA_DESC_IRQ | >>> MXS_DMA_DESC_CHAIN | MXS_DMA_DESC_DEC_SEM | >>> >>> - MXS_DMA_DESC_WAIT4END | (3 << >>> MXS_DMA_DESC_PIO_WORDS_OFFSET) >>> >>> | + MXS_DMA_DESC_WAIT4END | (1 << >>> >>> MXS_DMA_DESC_PIO_WORDS_OFFSET) | >>> >>> (nand_info->cmd_queue_len << >>> MXS_DMA_DESC_BYTES_OFFSET); >> >> What error or problem does this incorrect setup cause in your case? >> I'm asking since I'm also using this driver in some mx6 system and >> have not seen any issues. > > As far as I can see, it doesn't seem to cause any issue. But, if you > read the iMX6 Reference Manual (chapter 14.2) this field should > reflect the number of PIO_WORDS appended to the DMA command, in this > case 1.
What do you think?
What do you think ?
Thank you!
OK, I will send a patch to fix them. Regards
Hi Marek,
Hi Marek,
On Friday, December 12, 2014 at 01:43:22 PM, Stefan Roese wrote: > Hi Luca, > > On 12.12.2014 13:40, Luca Ellero wrote: >>> On 10.12.2014 09:24, Luca Ellero wrote: >>>> There is only one pio_word in this DMA transaction so data field >>>> must be 1. >>>> >>>> Signed-off-by: Luca Ellero luca.ellero@brickedbrain.com >>>> --- >>>> >>>> drivers/mtd/nand/mxs_nand.c | 2 +- >>>> 1 file changed, 1 insertion(+), 1 deletion(-) >>>> >>>> diff --git a/drivers/mtd/nand/mxs_nand.c >>>> b/drivers/mtd/nand/mxs_nand.c index 7a064ab..616c9ca 100644 >>>> --- a/drivers/mtd/nand/mxs_nand.c >>>> +++ b/drivers/mtd/nand/mxs_nand.c >>>> @@ -305,7 +305,7 @@ static void mxs_nand_cmd_ctrl(struct mtd_info >>>> *mtd, int data, unsigned int ctrl) >>>> >>>> d->cmd.data = >>>> >>>> MXS_DMA_DESC_COMMAND_DMA_READ | MXS_DMA_DESC_IRQ | >>>> MXS_DMA_DESC_CHAIN | MXS_DMA_DESC_DEC_SEM | >>>> >>>> - MXS_DMA_DESC_WAIT4END | (3 << >>>> MXS_DMA_DESC_PIO_WORDS_OFFSET) >>>> >>>> | + MXS_DMA_DESC_WAIT4END | (1 << >>>> >>>> MXS_DMA_DESC_PIO_WORDS_OFFSET) | >>>> >>>> (nand_info->cmd_queue_len << >>>> MXS_DMA_DESC_BYTES_OFFSET); >>> >>> What error or problem does this incorrect setup cause in your >>> case? I'm asking since I'm also using this driver in some mx6 >>> system and have not seen any issues. >> >> As far as I can see, it doesn't seem to cause any issue. But, if >> you read the iMX6 Reference Manual (chapter 14.2) this field >> should reflect the number of PIO_WORDS appended to the DMA >> command, in this case 1. > > Okay. I just wanted to check if this patch fixes a real problem that > you have experienced. Thanks for the explanation. > > Reviewed-by: Stefan Roese sr@denx.de
What do you think?
What do you think ?
Thank you!
Thanks!
Hi Luca,
Thank you!
Do you plan to send a V2 patch for fixing all the issues at once ?
Best regards, Stefano Babic
On 10/02/2015 14:14, Stefano Babic wrote:
Hi Luca,
Thank you!
Hi Stefano, yes, I can send a patch with all the fixes, that's fine. I plan to send it tomorrow. Regards Luca
Hi Luca,
Thank you!
Thank you :)
Luca Ellero
Stefan Roese
Stefano Babic
