This is what has changed since v2
10,12c10,12 < CPU9260 : fix machine ID when using a CPU9G20. < fix CPU9260/CPU9G20 compile warnings < main.c: In function 'abortboot': ---
AT91 CPU9260 Fix machine ID when using a CPU9G20. AT91 CPU9260 CPU9G20 Fix compile warnings AT91 CPUAT91 Fix compiler warning
45,46c45 < Steve Sakoman (2): < TI: OMAP3: Refactors the SM911x driver ---
Steve Sakoman (1):
117d115 < drivers/net/smc911x.c | 12 +- 161c159
This comes from rebasing the arm master-sync branch
I added the AT91 prefix to the at91 patches and fixed the subject on the subject on the CPUAT91.
I removed the sm911x patch.
I tried and failed to change the 3430sdp to point to the true author.
Tom
The following changes since commit a380279b2abe130c2d3d2c8de36f8ff98bc6b3b0: Daniel Gorsulowski (1): at91: Update MEESC board support
git://git.denx.de/u-boot-arm master-sync
Eric Benard (3): AT91 CPU9260 Fix machine ID when using a CPU9G20. AT91 CPU9260 CPU9G20 Fix compile warnings AT91 CPUAT91 Fix compiler warning
Minkyu Kang (5): s5pc1xx: support Samsung s5pc1xx SoC s5pc1xx: support onenand driver s5pc1xx: support serial driver s5pc1xx: add support SMDKC100 board s5pc1xx: SMDKC100: fix compile warnings
Nishanth Menon (4): OMAP3: export enable_gpmc_cs_config to board files OMAP3: fix warnings when NAND/ONENAND is not used OMAP3: Fix SDRC init TI OMAP3: make gpmc_config as const
Sandeep Paulraj (13): TI DaVinci DM355: Fix Compilation warning for DM355 EVM TI DaVinci DM365: Fix Compilation warning for DM365 EVM TI DaVinci DM646x: Adding initial support for DM6467 EVM TI: DaVinci: DM355 Leopard board support TI DaVinci: Maintainer for DM355 and DM365 EVM TI: OMAP3: Remove SZ_xx references TI DaVinci DM355: Add Config option for 64 bit Support TI DaVinci DM365: Add Config option for 64 bit Support TI DaVinci DVEVM: Add Config option for 64 bit Support TI DaVinci Sonata: Add Config option for 64 bit Support TI DaVinci: DM355 Leopard: Fix compilation warning TI DaVinci: Fix DM6467 EVM Compilation Warning TI DaVinci: Adding Copyright for DM365 EVM
Simon Kagstrom (1): arm926ejs: 8-byte align stack to avoid LDRD/STRD problems
Steve Sakoman (1): OMAP3: Update Overo and Beagle environment
Tom Rix (2): Zoom2 Fix serial gpmc setup TI OMAP3 SDP3430: Initial Support
kevin.morfitt@fearnside-systems.co.uk (5): CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards Clean-up of cpu_arm920t and cpu_arm920t_s3c24x0 code Clean-up of s3c24x0 header files Clean-up of s3c24x0 drivers excluding nand driver Clean-up of s3c24x0 nand driver
MAINTAINERS | 12 + MAKEALL | 4 + Makefile | 12 + board/davinci/dm355evm/dm355evm.c | 4 +- board/davinci/dm355leopard/Makefile | 52 ++ board/davinci/dm355leopard/config.mk | 6 + board/davinci/dm355leopard/dm355leopard.c | 98 +++ board/davinci/dm365evm/dm365evm.c | 5 +- board/davinci/dm6467evm/Makefile | 52 ++ board/davinci/dm6467evm/config.mk | 2 + board/davinci/dm6467evm/dm6467evm.c | 31 + board/eukrea/cpu9260/cpu9260.c | 2 +- board/logicpd/zoom2/zoom2.c | 5 +- board/mpl/vcma9/vcma9.c | 13 +- board/mpl/vcma9/vcma9.h | 20 +- board/samsung/smdk2400/smdk2400.c | 5 +- board/samsung/smdk2410/smdk2410.c | 5 +- board/samsung/smdkc100/Makefile | 55 ++ board/samsung/smdkc100/config.mk | 16 + board/samsung/smdkc100/lowlevel_init.S | 215 +++++ board/samsung/smdkc100/mem_setup.S | 197 +++++ board/samsung/smdkc100/onenand.c | 83 ++ board/samsung/smdkc100/smdkc100.c | 51 ++ board/sbc2410x/sbc2410x.c | 7 +- board/ti/sdp3430/Makefile | 49 ++ board/ti/sdp3430/config.mk | 33 + board/ti/sdp3430/sdp.c | 204 +++++ board/ti/sdp3430/sdp.h | 417 +++++++++ board/trab/cmd_trab.c | 12 +- board/trab/rs485.c | 12 +- board/trab/trab.c | 17 +- board/trab/trab_fkt.c | 26 +- board/trab/tsc2000.c | 17 +- board/trab/tsc2000.h | 4 +- board/trab/vfd.c | 12 +- common/serial.c | 18 + cpu/arm920t/s3c24x0/interrupts.c | 4 +- cpu/arm920t/s3c24x0/speed.c | 42 +- cpu/arm920t/s3c24x0/timer.c | 110 ++-- cpu/arm920t/s3c24x0/usb.c | 30 +- cpu/arm920t/s3c24x0/usb_ohci.c | 1323 +++++++++++++++-------------- cpu/arm920t/s3c24x0/usb_ohci.h | 209 +++--- cpu/arm920t/start.S | 63 +- cpu/arm926ejs/start.S | 1 + cpu/arm_cortexa8/omap3/mem.c | 21 +- cpu/arm_cortexa8/omap3/sys_info.c | 2 +- cpu/arm_cortexa8/s5pc1xx/Makefile | 53 ++ cpu/arm_cortexa8/s5pc1xx/cache.c | 43 + cpu/arm_cortexa8/s5pc1xx/clock.c | 308 +++++++ cpu/arm_cortexa8/s5pc1xx/cpu_info.c | 57 ++ cpu/arm_cortexa8/s5pc1xx/reset.S | 47 + cpu/arm_cortexa8/s5pc1xx/timer.c | 195 +++++ doc/README.s5pc1xx | 56 ++ drivers/i2c/s3c24x0_i2c.c | 273 +++--- drivers/mtd/nand/s3c2410_nand.c | 62 +- drivers/mtd/onenand/Makefile | 1 + drivers/mtd/onenand/samsung.c | 636 ++++++++++++++ drivers/rtc/s3c24x0_rtc.c | 130 ++-- drivers/serial/Makefile | 1 + drivers/serial/serial_s3c24x0.c | 160 ++-- drivers/serial/serial_s5pc1xx.c | 195 +++++ include/asm-arm/arch-davinci/hardware.h | 2 + include/asm-arm/arch-omap3/cpu.h | 1 + include/asm-arm/arch-omap3/mem.h | 8 +- include/asm-arm/arch-omap3/sys_proto.h | 2 + include/asm-arm/arch-s5pc1xx/clk.h | 32 + include/asm-arm/arch-s5pc1xx/clock.h | 94 ++ include/asm-arm/arch-s5pc1xx/cpu.h | 72 ++ include/asm-arm/arch-s5pc1xx/gpio.h | 129 +++ include/asm-arm/arch-s5pc1xx/power.h | 42 + include/asm-arm/arch-s5pc1xx/pwm.h | 59 ++ include/asm-arm/arch-s5pc1xx/uart.h | 47 + include/configs/cpu9260.h | 1 + include/configs/cpuat91.h | 4 +- include/configs/davinci_dm355evm.h | 1 + include/configs/davinci_dm355leopard.h | 162 ++++ include/configs/davinci_dm365evm.h | 2 + include/configs/davinci_dm6467evm.h | 132 +++ include/configs/davinci_dvevm.h | 1 + include/configs/davinci_sonata.h | 1 + include/configs/devkit8000.h | 15 +- include/configs/omap3_beagle.h | 42 +- include/configs/omap3_evm.h | 15 +- include/configs/omap3_overo.h | 42 +- include/configs/omap3_pandora.h | 15 +- include/configs/omap3_sdp3430.h | 369 ++++++++ include/configs/omap3_zoom1.h | 15 +- include/configs/omap3_zoom2.h | 15 +- include/configs/sbc2410x.h | 4 +- include/configs/smdk2400.h | 4 +- include/configs/smdk2410.h | 4 +- include/configs/smdkc100.h | 242 ++++++ include/configs/trab.h | 12 +- include/linux/mtd/onenand.h | 1 + include/linux/mtd/onenand_regs.h | 4 + include/linux/mtd/samsung_onenand.h | 131 +++ include/s3c2400.h | 494 +---------- include/s3c2410.h | 159 +--- include/s3c24x0.h | 605 ++------------ include/serial.h | 7 + 100 files changed, 6323 insertions(+), 2459 deletions(-) create mode 100644 board/davinci/dm355leopard/Makefile create mode 100644 board/davinci/dm355leopard/config.mk create mode 100644 board/davinci/dm355leopard/dm355leopard.c create mode 100644 board/davinci/dm6467evm/Makefile create mode 100644 board/davinci/dm6467evm/config.mk create mode 100644 board/davinci/dm6467evm/dm6467evm.c create mode 100644 board/samsung/smdkc100/Makefile create mode 100644 board/samsung/smdkc100/config.mk create mode 100644 board/samsung/smdkc100/lowlevel_init.S create mode 100644 board/samsung/smdkc100/mem_setup.S create mode 100644 board/samsung/smdkc100/onenand.c create mode 100644 board/samsung/smdkc100/smdkc100.c create mode 100644 board/ti/sdp3430/Makefile create mode 100644 board/ti/sdp3430/config.mk create mode 100644 board/ti/sdp3430/sdp.c create mode 100644 board/ti/sdp3430/sdp.h create mode 100644 cpu/arm_cortexa8/s5pc1xx/Makefile create mode 100644 cpu/arm_cortexa8/s5pc1xx/cache.c create mode 100644 cpu/arm_cortexa8/s5pc1xx/clock.c create mode 100644 cpu/arm_cortexa8/s5pc1xx/cpu_info.c create mode 100644 cpu/arm_cortexa8/s5pc1xx/reset.S create mode 100644 cpu/arm_cortexa8/s5pc1xx/timer.c create mode 100644 doc/README.s5pc1xx create mode 100644 drivers/mtd/onenand/samsung.c create mode 100644 drivers/serial/serial_s5pc1xx.c create mode 100644 include/asm-arm/arch-s5pc1xx/clk.h create mode 100644 include/asm-arm/arch-s5pc1xx/clock.h create mode 100644 include/asm-arm/arch-s5pc1xx/cpu.h create mode 100644 include/asm-arm/arch-s5pc1xx/gpio.h create mode 100644 include/asm-arm/arch-s5pc1xx/power.h create mode 100644 include/asm-arm/arch-s5pc1xx/pwm.h create mode 100644 include/asm-arm/arch-s5pc1xx/uart.h create mode 100644 include/configs/davinci_dm355leopard.h create mode 100644 include/configs/davinci_dm6467evm.h create mode 100644 include/configs/omap3_sdp3430.h create mode 100644 include/configs/smdkc100.h create mode 100644 include/linux/mtd/samsung_onenand.h
Steve Sakoman (1):
I understand this is the one Wolfgang objected to but I have explained the situation and I am confident this is a valid commit and was definitely sent to the mailing list. Besides even Ben was OK with it.
Tom
The patch just needs to have From: David Brownell < his e-mail>
Sandeep, On Sun, Oct 18, 2009 at 5:37 PM, Paulraj, Sandeep s-paulraj@ti.com wrote:
Steve Sakoman (1):
I'm still OK with it, but let's try to clean up our workflow next release... I know you guys had quite a mess to clean up with ARM, so to some extent this chaos is understandable.
regards, Ben
Dear Ben Warren,
In message f8328f7c0910181853t3f8c305ai62841e6d7b487fab@mail.gmail.com you wrote:
Thanks for pointing this out.
I also want to stress that I in no way intend to criticize anybody. I am well aware what amount of work you have been doing, and that all of this is completely new to many of you. I just want to point out the few rough edges we should try to iron out or even better to avoid next time. Big thanks to everybody.
Steve Sakoman (1):
After this is discussed now, could we apply it again?
Without this patch it will be broken.
Thanks
Dirk
Steve Sakoman (1):
I believe the issue is only about the workflow process of the patch. I believe to resolve, the patch needs to be reposted, unchanged, to the list and to have Ben's ack-ed by added.
Once this is done, I can apply it. Tom
Thanks
Dirk
Hi Tom and Wolfgang!
On Sun, 18 Oct 2009 17:58:48 -0500 Tom Tom.Rix@windriver.com wrote:
[...] The following changes since commit a380279b2abe130c2d3d2c8de36f8ff98bc6b3b0: Daniel Gorsulowski (1): at91: Update MEESC board support
Has this pull been forgotten or is it in the works still?
// Simon
// Simon
This is still in the works. There are some changes I need to incorporate and have been busy with a board bringup. I will have a new and hopefully final version out this weekend. Tom
participants (6)
Ben Warren
Dirk Behme
Paulraj, Sandeep
Simon Kagstrom
Tom
