[PATCH v2 05/11] rockchip: idb: add sector1 info
Add Rockchip IDB sector1 info to make it easier to identify the IDB date and version. Sector1 data is currently not added by U-boot tools, but is generated by external tools that have support for it.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
optional --- arch/arm/mach-rockchip/rockchip_idb.c | 46 +++++++++++++++++++++++++++ 1 file changed, 46 insertions(+)
diff --git a/arch/arm/mach-rockchip/rockchip_idb.c b/arch/arm/mach-rockchip/rockchip_idb.c index 0692ce1a..37fe6ff2 100644 --- a/arch/arm/mach-rockchip/rockchip_idb.c +++ b/arch/arm/mach-rockchip/rockchip_idb.c @@ -59,6 +59,11 @@ #define NAND_CMD_ERASE2 0xd0 #define NAND_CMD_RESET 0xff
+#define BCD2INT(num) (((((num) >> 12) & 0x0F) * 1000) + \ + ((((num) >> 8) & 0x0F) * 100) + \ + ((((num) >> 4) & 0x0F) * 10) + \ + ((num) & 0x0F)) + #define DATA_STEP 1024 #define OOB_STEP 4 #define LBA 64 + 512 + 33 @@ -80,6 +85,35 @@ struct sector0 { u8 reserved2[2]; } __packed;
+struct sector1 { + u16 sys_reserved_block; + u16 disk0_size; + u16 disk1_size; + u16 disk2_size; + u16 disk3_size; + u32 chip_tag; + u32 machine_id; + u16 loader_year; + u16 loader_date; + u16 loader_ver; + u8 reserved[72]; + u16 flash_data_offset; + u16 flash_data_len; + u8 reserved2[384]; + u32 flash_chip_size; + u8 reserved1; + u8 access_time; + u16 phy_block_size; + u8 phy_page_size; + u8 ecc_bits; + u8 reserved3[8]; + u16 id_block0; + u16 id_block1; + u16 id_block2; + u16 id_block3; + u16 id_block4; +} __packed; + struct nand_para_info { u8 id_bytes; u8 nand_id[6]; @@ -1475,10 +1509,22 @@ int rk_idb_stop(void)
void rk_idb_print_idb_data(u32 *data) { + struct sector1 *sec1 = (struct sector1 *)((u8 *)data + 512); struct sector0 *sec0 = (struct sector0 *)data;
printf("\n");
+ printf("DATE : %d-%d-%d\n", + BCD2INT(sec1->loader_year), + BCD2INT(sec1->loader_date >> 8), + BCD2INT(sec1->loader_date & 0xff)); + + printf("VERSION : %d.%d\n", + BCD2INT(sec1->loader_ver >> 8), + BCD2INT(sec1->loader_ver & 0xff)); + + printf("\n"); + printf("magic : %08x\n" "rc4_flag : %08x\n" "boot_code1_offset: %d\n"
Johan Jonker
