[PATCH] board: fsl_validate: Fix resource leak issue
Free dynamically allocated memory before every return statement in calc_esbchdr_esbc_hash() function. Verified the secure boot changes using ls1046afrwy board.
Signed-off-by: Kshitiz Varshney kshitiz.varshney@nxp.com --- board/freescale/common/fsl_validate.c | 25 ++++++++++++++++++------- 1 file changed, 18 insertions(+), 7 deletions(-)
diff --git a/board/freescale/common/fsl_validate.c b/board/freescale/common/fsl_validate.c index 564a8b3b54..05d9a004e7 100644 --- a/board/freescale/common/fsl_validate.c +++ b/board/freescale/common/fsl_validate.c @@ -547,14 +547,18 @@ static int calc_esbchdr_esbc_hash(struct fsl_secboot_img_priv *img)
ret = algo->hash_init(algo, &ctx); /* Copy hash at destination buffer */ - if (ret) + if (ret) { + free(ctx); return ret; + }
/* Update hash for CSF Header */ ret = algo->hash_update(algo, ctx, (u8 *)&img->hdr, sizeof(struct fsl_secboot_img_hdr), 0); - if (ret) + if (ret) { + free(ctx); return ret; + }
/* Update the hash with that of srk table if srk flag is 1 * If IE Table is selected, key is not added in the hash @@ -581,22 +585,29 @@ static int calc_esbchdr_esbc_hash(struct fsl_secboot_img_priv *img) key_hash = 1; } #endif - if (ret) + if (ret) { + free(ctx); return ret; - if (!key_hash) + } + if (!key_hash) { + free(ctx); return ERROR_KEY_TABLE_NOT_FOUND; + }
/* Update hash for actual Image */ ret = algo->hash_update(algo, ctx, (u8 *)(*(img->img_addr_ptr)), img->img_size, 1); - if (ret) + if (ret) { + free(ctx); return ret; + }
/* Copy hash at destination buffer */ ret = algo->hash_finish(algo, ctx, hash_val, algo->digest_size); - if (ret) + if (ret) { + free(ctx); return ret; - + } return 0; }
Kshitiz Varshney
