[U-Boot] [PATCH 0/5] Convert omap24xx-i2c driver to Driver Model
Hi Simon,
This patchset tries to convert the TI omap24xx_i2c driver to Driver Model. It has been tested on a TI BeagleBoard xM.
Best Regards Christophe
Christophe Ricard (5): i2c: omap24xx: Convert to DM i2c: omap24xx: Fix waitdelay value for I2C HS i2c: omap24xx: Remove unused I2C_WAIT macro i2c: omap24xx: Fix high speed trimming calculation i2c: omap24xx: Convert fully to DM_I2C
drivers/i2c/Kconfig | 8 + drivers/i2c/omap24xx_i2c.c | 395 ++++++++++++++++++++++++++++++--------------- drivers/i2c/omap24xx_i2c.h | 154 ------------------ 3 files changed, 276 insertions(+), 281 deletions(-) delete mode 100644 drivers/i2c/omap24xx_i2c.h
Convert omap24xx_i2c driver to DM
Signed-off-by: Christophe Ricard christophe-h.ricard@st.com ---
drivers/i2c/Kconfig | 8 ++ drivers/i2c/omap24xx_i2c.c | 280 +++++++++++++++++++++++++++++++++++++++++++-- 2 files changed, 277 insertions(+), 11 deletions(-)
diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 14adda2..3498af1 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -58,6 +58,14 @@ config DM_I2C_GPIO bindings are supported. Binding info: doc/device-tree-bindings/i2c/i2c-gpio.txt
+config SYS_I2C_OMAP24XX + bool "Texas Instrument OMAP I2C driver" + depends on DM_I2C + help + Enable support for the I2C interface on the Texas Instruments + OMAP1/2 family of processors. Like OMAP1510/1610/1710/5912 and OMAP242x. + For details see http://www.ti.com/omap. + config SYS_I2C_ROCKCHIP bool "Rockchip I2C driver" depends on DM_I2C diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 79a5c94..f3a4d96 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -36,13 +36,18 @@ * Copyright (c) 2014 Hannes Schmelzer oe5hpm@oevsv.at, B&R * - Added support for set_speed * + * Copyright (c) 2016 Christophe Ricard christophe.ricard@gmail.com + * - Added support for DM_I2C + * */
#include <common.h> #include <i2c.h> +#include <dm.h>
#include <asm/arch/i2c.h> #include <asm/io.h> +#include <asm/errno.h>
#include "omap24xx_i2c.h"
@@ -53,10 +58,26 @@ DECLARE_GLOBAL_DATA_PTR; /* Absolutely safe for status update at 100 kHz I2C: */ #define I2C_WAIT 200
+#ifdef CONFIG_DM_I2C +struct omap24_i2c_bus { + int bus_num; + int waitdelay; + unsigned clock_frequency; + struct i2c *i2c_base; +}; +#endif + +#ifdef CONFIG_SYS_I2C static int wait_for_bb(struct i2c_adapter *adap); static struct i2c *omap24_get_base(struct i2c_adapter *adap); static u16 wait_for_event(struct i2c_adapter *adap); static void flush_fifo(struct i2c_adapter *adap); +#else +static int wait_for_bb(struct udevice *dev); +static u16 wait_for_event(struct udevice *dev); +static void flush_fifo(struct udevice *dev); +#endif + static int omap24_i2c_findpsc(u32 *pscl, u32 *psch, uint speed) { unsigned int sampleclk, prescaler; @@ -90,13 +111,27 @@ static int omap24_i2c_findpsc(u32 *pscl, u32 *psch, uint speed) } return -1; } + +#ifdef CONFIG_SYS_I2C static uint omap24_i2c_setspeed(struct i2c_adapter *adap, uint speed) +#else +static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) +#endif { - struct i2c *i2c_base = omap24_get_base(adap); + struct i2c *i2c_base; int psc, fsscll = 0, fssclh = 0; int hsscll = 0, hssclh = 0; u32 scll = 0, sclh = 0;
+#ifdef CONFIG_SYS_I2C + i2c_base = omap24_get_base(adap); +#else + struct omap24_i2c_bus *i2c_bus; + + i2c_bus = dev_get_priv(adap); + i2c_base = i2c_bus->i2c_base; +#endif + if (speed >= OMAP_I2C_HIGH_SPEED) { /* High speed */ psc = I2C_IP_CLK / I2C_INTERNAL_SAMPLING_CLK; @@ -142,8 +177,14 @@ static uint omap24_i2c_setspeed(struct i2c_adapter *adap, uint speed) } }
+#ifdef CONFIG_SYS_I2C adap->speed = speed; adap->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */ +#else + i2c_bus->clock_frequency = speed; + i2c_bus->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */ +#endif + writew(0, &i2c_base->con); writew(psc, &i2c_base->psc); writew(scll, &i2c_base->scll); @@ -154,13 +195,26 @@ static uint omap24_i2c_setspeed(struct i2c_adapter *adap, uint speed) return 0; }
+#ifdef CONFIG_SYS_I2C static void omap24_i2c_deblock(struct i2c_adapter *adap) +#else +static int omap24_i2c_deblock(struct udevice *adap) +#endif { - struct i2c *i2c_base = omap24_get_base(adap); + struct i2c *i2c_base; int i; u16 systest; u16 orgsystest;
+#ifdef CONFIG_SYS_I2C + i2c_base = omap24_get_base(adap); +#else + struct omap24_i2c_bus *i2c_bus; + + i2c_bus = dev_get_priv(adap); + i2c_base = i2c_bus->i2c_base; +#endif + /* set test mode ST_EN = 1 */ orgsystest = readw(&i2c_base->systest); systest = orgsystest; @@ -198,14 +252,31 @@ static void omap24_i2c_deblock(struct i2c_adapter *adap)
/* restore original mode */ writew(orgsystest, &i2c_base->systest); + +#ifdef CONFIG_DM_I2C + return 0; +#endif }
+#ifdef CONFIG_SYS_I2C static void omap24_i2c_init(struct i2c_adapter *adap, int speed, int slaveadd) +#else +static void omap24_i2c_init(struct udevice *adap, int speed, int slaveadd) +#endif { - struct i2c *i2c_base = omap24_get_base(adap); + struct i2c *i2c_base; int timeout = I2C_TIMEOUT; int deblock = 1;
+#ifdef CONFIG_SYS_I2C + i2c_base = omap24_get_base(adap); +#else + struct omap24_i2c_bus *i2c_bus; + + i2c_bus = dev_get_priv(adap); + i2c_base = i2c_bus->i2c_base; +#endif + retry: if (readw(&i2c_base->con) & I2C_CON_EN) { writew(0, &i2c_base->con); @@ -253,11 +324,24 @@ retry: } }
+#ifdef CONFIG_SYS_I2C static void flush_fifo(struct i2c_adapter *adap) +#else +static void flush_fifo(struct udevice *adap) +#endif { - struct i2c *i2c_base = omap24_get_base(adap); + struct i2c *i2c_base; u16 stat;
+#ifdef CONFIG_SYS_I2C + i2c_base = omap24_get_base(adap); +#else + struct omap24_i2c_bus *i2c_bus; + + i2c_bus = dev_get_priv(adap); + i2c_base = i2c_bus->i2c_base; +#endif + /* * note: if you try and read data when its not there or ready * you get a bus error @@ -277,12 +361,25 @@ static void flush_fifo(struct i2c_adapter *adap) * i2c_probe: Use write access. Allows to identify addresses that are * write-only (like the config register of dual-port EEPROMs) */ +#ifdef CONFIG_SYS_I2C static int omap24_i2c_probe(struct i2c_adapter *adap, uchar chip) +#else +static int omap24_i2c_probe(struct udevice *adap, uint chip, uint chip_flags) +#endif { - struct i2c *i2c_base = omap24_get_base(adap); + struct i2c *i2c_base; u16 status; int res = 1; /* default = fail */
+#ifdef CONFIG_SYS_I2C + i2c_base = omap24_get_base(adap); +#else + struct omap24_i2c_bus *i2c_bus; + + i2c_bus = dev_get_priv(adap); + i2c_base = i2c_bus->i2c_base; +#endif + if (chip == readw(&i2c_base->oa)) return res;
@@ -305,17 +402,26 @@ static int omap24_i2c_probe(struct i2c_adapter *adap, uchar chip) * silent exit is desired upon unconfigured bus, remove the * following 'if' section: */ - if (status == I2C_STAT_XRDY) + if (status == I2C_STAT_XRDY) { +#ifdef CONFIG_SYS_I2C printf("i2c_probe: pads on bus %d probably not configured (status=0x%x)\n", adap->hwadapnr, status); - +#else + printf("i2c_probe: pads on bus %d probably not configured (status=0x%x)\n", + i2c_bus->bus_num, status); +#endif + } goto pr_exit; }
/* Check for ACK (!NAK) */ if (!(status & I2C_STAT_NACK)) { res = 0; /* Device found */ +#ifdef CONFIG_SYS_I2C udelay(adap->waitdelay);/* Required by AM335X in SPL */ +#else + udelay(i2c_bus->waitdelay); +#endif /* Abort transfer (force idle state) */ writew(I2C_CON_MST | I2C_CON_TRX, &i2c_base->con); /* Reset */ udelay(1000); @@ -341,13 +447,27 @@ pr_exit: * or that do not need a register address at all (such as some clock * distributors). */ +#ifdef CONFIG_SYS_I2C static int omap24_i2c_read(struct i2c_adapter *adap, uchar chip, uint addr, int alen, uchar *buffer, int len) +#else +static int omap24_i2c_read(struct udevice *adap, uchar chip, uint addr, + int alen, uchar *buffer, int len) +#endif { - struct i2c *i2c_base = omap24_get_base(adap); + struct i2c *i2c_base; int i2c_error = 0; u16 status;
+#ifdef CONFIG_SYS_I2C + i2c_base = omap24_get_base(adap); +#else + struct omap24_i2c_bus *i2c_bus; + + i2c_bus = dev_get_priv(adap); + i2c_base = i2c_bus->i2c_base; +#endif + if (alen < 0) { puts("I2C read: addr len < 0\n"); return 1; @@ -397,8 +517,13 @@ static int omap24_i2c_read(struct i2c_adapter *adap, uchar chip, uint addr, /* Try to identify bus that is not padconf'd for I2C */ if (status == I2C_STAT_XRDY) { i2c_error = 2; +#ifdef CONFIG_SYS_I2C printf("i2c_read (addr phase): pads on bus %d probably not configured (status=0x%x)\n", adap->hwadapnr, status); +#else + printf("i2c_read (addr phase): pads on bus %d probably not configured (status=0x%x)\n", + i2c_bus->bus_num, status); +#endif goto rd_exit; } if (status == 0 || (status & I2C_STAT_NACK)) { @@ -441,8 +566,13 @@ static int omap24_i2c_read(struct i2c_adapter *adap, uchar chip, uint addr, */ if (status == I2C_STAT_XRDY) { i2c_error = 2; +#ifdef CONFIG_SYS_I2C printf("i2c_read (data phase): pads on bus %d probably not configured (status=0x%x)\n", adap->hwadapnr, status); +#else + printf("i2c_read (data phase): pads on bus %d probably not configured (status=0x%x)\n", + i2c_bus->bus_num, status); +#endif goto rd_exit; } if (status == 0 || (status & I2C_STAT_NACK)) { @@ -466,15 +596,29 @@ rd_exit: }
/* i2c_write: Address (reg offset) may be 0, 1 or 2 bytes long. */ +#ifdef CONFIG_SYS_I2C static int omap24_i2c_write(struct i2c_adapter *adap, uchar chip, uint addr, int alen, uchar *buffer, int len) +#else +static int omap24_i2c_write(struct udevice *adap, uchar chip, uint addr, + int alen, uchar *buffer, int len) +#endif { - struct i2c *i2c_base = omap24_get_base(adap); + struct i2c *i2c_base; int i; u16 status; int i2c_error = 0; int timeout = I2C_TIMEOUT;
+#ifdef CONFIG_SYS_I2C + i2c_base = omap24_get_base(adap); +#else + struct omap24_i2c_bus *i2c_bus; + + i2c_bus = dev_get_priv(adap); + i2c_base = i2c_bus->i2c_base; +#endif + if (alen < 0) { puts("I2C write: addr len < 0\n"); return 1; @@ -519,8 +663,13 @@ static int omap24_i2c_write(struct i2c_adapter *adap, uchar chip, uint addr, /* Try to identify bus that is not padconf'd for I2C */ if (status == I2C_STAT_XRDY) { i2c_error = 2; +#ifdef CONFIG_SYS_I2C printf("i2c_write: pads on bus %d probably not configured (status=0x%x)\n", adap->hwadapnr, status); +#else + printf("i2c_write: pads on bus %d probably not configured (status=0x%x)\n", + i2c_bus->bus_num, status); +#endif goto wr_exit; } if (status == 0 || (status & I2C_STAT_NACK)) { @@ -579,12 +728,25 @@ wr_exit: * Wait for the bus to be free by checking the Bus Busy (BB) * bit to become clear */ +#ifdef CONFIG_SYS_I2C static int wait_for_bb(struct i2c_adapter *adap) +#else +static int wait_for_bb(struct udevice *adap) +#endif { - struct i2c *i2c_base = omap24_get_base(adap); + struct i2c *i2c_base; int timeout = I2C_TIMEOUT; u16 stat;
+#ifdef CONFIG_SYS_I2C + i2c_base = omap24_get_base(adap); +#else + struct omap24_i2c_bus *i2c_bus; + + i2c_bus = dev_get_priv(adap); + i2c_base = i2c_bus->i2c_base; +#endif + writew(0xFFFF, &i2c_base->stat); /* clear current interrupts...*/ #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) while ((stat = readw(&i2c_base->stat) & I2C_STAT_BB) && timeout--) { @@ -594,7 +756,11 @@ static int wait_for_bb(struct i2c_adapter *adap) I2C_STAT_BB) && timeout--) { #endif writew(stat, &i2c_base->stat); +#ifdef CONFIG_SYS_I2C udelay(adap->waitdelay); +#else + udelay(i2c_bus->waitdelay); +#endif }
if (timeout <= 0) { @@ -610,14 +776,31 @@ static int wait_for_bb(struct i2c_adapter *adap) * Wait for the I2C controller to complete current action * and update status */ +#ifdef CONFIG_SYS_I2C static u16 wait_for_event(struct i2c_adapter *adap) +#else +static u16 wait_for_event(struct udevice *adap) +#endif { - struct i2c *i2c_base = omap24_get_base(adap); + struct i2c *i2c_base; u16 status; int timeout = I2C_TIMEOUT;
+#ifdef CONFIG_SYS_I2C + i2c_base = omap24_get_base(adap); +#else + struct omap24_i2c_bus *i2c_bus; + + i2c_bus = dev_get_priv(adap); + i2c_base = i2c_bus->i2c_base; +#endif + do { +#ifdef CONFIG_SYS_I2C udelay(adap->waitdelay); +#else + udelay(i2c_bus->waitdelay); +#endif #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) status = readw(&i2c_base->stat); #else @@ -636,8 +819,13 @@ static u16 wait_for_event(struct i2c_adapter *adap) * If status is still 0 here, probably the bus pads have * not been configured for I2C, and/or pull-ups are missing. */ +#ifdef CONFIG_SYS_I2C printf("Check if pads/pull-ups of bus %d are properly configured\n", adap->hwadapnr); +#else + printf("Check if pads/pull-ups of bus %d are properly configured\n", + i2c_bus->bus_num); +#endif writew(0xFFFF, &i2c_base->stat); status = 0; } @@ -645,6 +833,7 @@ static u16 wait_for_event(struct i2c_adapter *adap) return status; }
+#ifdef CONFIG_SYS_I2C static struct i2c *omap24_get_base(struct i2c_adapter *adap) { switch (adap->hwadapnr) { @@ -735,3 +924,72 @@ U_BOOT_I2C_ADAP_COMPLETE(omap24_4, omap24_i2c_init, omap24_i2c_probe, #endif #endif #endif +#endif + +#ifdef CONFIG_DM_I2C +static int omap24_i2c_xfer(struct udevice *adap, struct i2c_msg *msg, + int nmsgs) +{ + int ret; + + for (; nmsgs > 0; nmsgs--, msg++) { + if (msg->flags & I2C_M_RD) { + ret = omap24_i2c_read(adap, msg->addr, 0, 0, msg->buf, + msg->len); + } else { + ret = omap24_i2c_write(adap, msg->addr, 0, 0, msg->buf, + msg->len); + } + + if (ret) + return -EREMOTEIO; + } + + return 0; +} + +static int omap24_i2c_ofdata_to_platdata(struct udevice *adap) +{ + const void *blob = gd->fdt_blob; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + int node; + + node = adap->of_offset; + + i2c_bus->clock_frequency = fdtdec_get_int(blob, node, + "clock-frequency", 100000); + i2c_bus->i2c_base = (struct i2c *)dev_get_addr(adap); + i2c_bus->waitdelay = (10000000 / i2c_bus->clock_frequency) * 2; /* wait for 20 clkperiods */ + + i2c_bus->bus_num = adap->seq; + + omap24_i2c_init(adap, i2c_bus->clock_frequency, 1); + + return 0; +} + +static const struct dm_i2c_ops omap24_i2c_ops = { + .xfer = omap24_i2c_xfer, + .probe_chip = omap24_i2c_probe, + .set_bus_speed = omap24_i2c_setspeed, + .deblock = omap24_i2c_deblock, +}; + +static const struct udevice_id omap24_i2c_ids[] = { + { .compatible = "ti,omap3-i2c" }, + { .compatible = "ti,omap4-i2c" }, + { .compatible = "ti,omap2430-i2c" }, + { .compatible = "ti,omap2420-i2c" }, + { } +}; + +U_BOOT_DRIVER(omap_i2c) = { + .name = "omap_i2c", + .id = UCLASS_I2C, + .of_match = omap24_i2c_ids, + .ofdata_to_platdata = omap24_i2c_ofdata_to_platdata, + .per_child_auto_alloc_size = sizeof(struct dm_i2c_chip), + .priv_auto_alloc_size = sizeof(struct omap24_i2c_bus), + .ops = &omap24_i2c_ops, +}; +#endif
Hello Christophe,
Am 17.01.2016 um 12:09 schrieb Christophe Ricard:
Looks good to me, Thanks!
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
- bool "Texas Instrument OMAP I2C driver"
- depends on DM_I2C
- help
- config SYS_I2C_ROCKCHIP bool "Rockchip I2C driver" depends on DM_I2C
- Copyright (c) 2014 Hannes Schmelzer oe5hpm@oevsv.at, B&R
- Copyright (c) 2016 Christophe Ricard christophe.ricard@gmail.com
+#include <dm.h>
- int bus_num;
- int waitdelay;
- unsigned clock_frequency;
- struct i2c *i2c_base;
+}; +#endif
- static int omap24_i2c_findpsc(u32 *pscl, u32 *psch, uint speed) { unsigned int sampleclk, prescaler;
- struct i2c *i2c_base; int psc, fsscll = 0, fssclh = 0; int hsscll = 0, hssclh = 0; u32 scll = 0, sclh = 0;
- i2c_base = omap24_get_base(adap);
+#else
- struct omap24_i2c_bus *i2c_bus;
- i2c_bus = dev_get_priv(adap);
- i2c_base = i2c_bus->i2c_base;
- if (speed >= OMAP_I2C_HIGH_SPEED) { /* High speed */ psc = I2C_IP_CLK / I2C_INTERNAL_SAMPLING_CLK;
- i2c_bus->clock_frequency = speed;
- i2c_bus->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */
- writew(0, &i2c_base->con); writew(psc, &i2c_base->psc); writew(scll, &i2c_base->scll);
- struct i2c *i2c_base; int i; u16 systest; u16 orgsystest;
+#else
- /* set test mode ST_EN = 1 */ orgsystest = readw(&i2c_base->systest); systest = orgsystest;
+#endif }
- struct i2c *i2c_base; int timeout = I2C_TIMEOUT; int deblock = 1;
+#else
- retry: if (readw(&i2c_base->con) & I2C_CON_EN) { writew(0, &i2c_base->con);
- struct i2c *i2c_base; u16 stat;
+#else
- note: if you try and read data when its not there or ready
- you get a bus error
- i2c_probe: Use write access. Allows to identify addresses that are
- struct i2c *i2c_base; u16 status; int res = 1; /* default = fail */
+#else
- if (chip == readw(&i2c_base->oa)) return res;
+#else
goto pr_exit; }
distributors).
+#endif {
- struct i2c *i2c_base; int i2c_error = 0; u16 status;
+#else
- if (alen < 0) { puts("I2C read: addr len < 0\n"); return 1;
+#endif {
- struct i2c *i2c_base; int i; u16 status; int i2c_error = 0; int timeout = I2C_TIMEOUT;
+#else
- if (alen < 0) { puts("I2C write: addr len < 0\n"); return 1;
- Wait for the bus to be free by checking the Bus Busy (BB)
- bit to become clear
- struct i2c *i2c_base; int timeout = I2C_TIMEOUT; u16 stat;
+#else
- writew(0xFFFF, &i2c_base->stat); /* clear current interrupts...*/ #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) while ((stat = readw(&i2c_base->stat) & I2C_STAT_BB) && timeout--) {
+#endif }
- Wait for the I2C controller to complete current action
- and update status
- struct i2c *i2c_base; u16 status; int timeout = I2C_TIMEOUT;
+#else
- do {
i2c_bus->bus_num);
int nmsgs)
- int ret;
- for (; nmsgs > 0; nmsgs--, msg++) {
msg->len);
} else {
msg->len);
if (ret)
return -EREMOTEIO;
- const void *blob = gd->fdt_blob;
- struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap);
- int node;
- node = adap->of_offset;
- i2c_bus->clock_frequency = fdtdec_get_int(blob, node,
- i2c_bus->i2c_base = (struct i2c *)dev_get_addr(adap);
- i2c_bus->waitdelay = (10000000 / i2c_bus->clock_frequency) * 2; /* wait for 20 clkperiods */
- i2c_bus->bus_num = adap->seq;
- omap24_i2c_init(adap, i2c_bus->clock_frequency, 1);
- .xfer = omap24_i2c_xfer,
- .probe_chip = omap24_i2c_probe,
- .set_bus_speed = omap24_i2c_setspeed,
- .deblock = omap24_i2c_deblock,
- { .compatible = "ti,omap3-i2c" },
- { .compatible = "ti,omap4-i2c" },
- { .compatible = "ti,omap2430-i2c" },
- { .compatible = "ti,omap2420-i2c" },
- .name = "omap_i2c",
- .id = UCLASS_I2C,
- .of_match = omap24_i2c_ids,
- .ofdata_to_platdata = omap24_i2c_ofdata_to_platdata,
- .per_child_auto_alloc_size = sizeof(struct dm_i2c_chip),
- .priv_auto_alloc_size = sizeof(struct omap24_i2c_bus),
- .ops = &omap24_i2c_ops,
+}; +#endif
On 17 January 2016 at 04:09, Christophe Ricard christophe.ricard@gmail.com wrote:
After several testings and experiment, it appears that waitdelay calculation formula was giving different behavior on the i2c status registers.
Experiment shows waitdelay needs to be extended at least 4 times to get proper results.
drivers/i2c/omap24xx_i2c.c | 18 ++++++++++++------ 1 file changed, 12 insertions(+), 6 deletions(-)
diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index f3a4d96..d6e5fe9 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -168,6 +168,13 @@ static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) scll = (unsigned int)hsscll << 8 | (unsigned int)fsscll; sclh = (unsigned int)hssclh << 8 | (unsigned int)fssclh;
+#ifdef CONFIG_SYS_I2C + adap->speed = speed; + adap->waitdelay = (10000000 / speed) * 8; /* wait for 20 clkperiods */ +#else + i2c_bus->clock_frequency = speed; + i2c_bus->waitdelay = (10000000 / speed) * 8; /* wait for 20 clkperiods */ +#endif } else { /* Standard and fast speed */ psc = omap24_i2c_findpsc(&scll, &sclh, speed); @@ -175,15 +182,15 @@ static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) puts("Error : I2C initializing clock\n"); return -1; } - }
#ifdef CONFIG_SYS_I2C - adap->speed = speed; - adap->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */ + adap->speed = speed; + adap->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */ #else - i2c_bus->clock_frequency = speed; - i2c_bus->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */ + i2c_bus->clock_frequency = speed; + i2c_bus->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */ #endif + }
writew(0, &i2c_base->con); writew(psc, &i2c_base->psc); @@ -467,7 +474,6 @@ static int omap24_i2c_read(struct udevice *adap, uchar chip, uint addr, i2c_bus = dev_get_priv(adap); i2c_base = i2c_bus->i2c_base; #endif - if (alen < 0) { puts("I2C read: addr len < 0\n"); return 1;
Hello Christophe,
+#else
#elseadap->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */
#endifi2c_bus->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */
You change here only the "speed >= OMAP_I2C_HIGH_SPEED" case ... Is this your intention?
If so, please add this info in your commit message.
Beside of this nitpick:
bye, Heiko
I2C_WAIT macro is not used in the code. 200 is bound to a fixed 100000 Hz i2c speed based on an existing formula: ( 10000000 / speed ) * 2 where speed = 100 000.
drivers/i2c/omap24xx_i2c.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index d6e5fe9..48ca446 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -55,9 +55,6 @@ DECLARE_GLOBAL_DATA_PTR;
#define I2C_TIMEOUT 1000
-/* Absolutely safe for status update at 100 kHz I2C: */ -#define I2C_WAIT 200 - #ifdef CONFIG_DM_I2C struct omap24_i2c_bus { int bus_num;
Hello Christophe,
Thanks!
bye, Heiko
Work based on i2c-omap.c from linux kernel.
fsscll/fssclh and hsscll/hssclh was always negative in high speed.
i2c high speed frequency start after 400Khz.
drivers/i2c/omap24xx_i2c.c | 17 +++++++++-------- 1 file changed, 9 insertions(+), 8 deletions(-)
diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 48ca446..774edaf 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -129,7 +129,9 @@ static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) i2c_base = i2c_bus->i2c_base; #endif
- if (speed >= OMAP_I2C_HIGH_SPEED) { + if (speed > 400000) { + unsigned long scl; + /* High speed */ psc = I2C_IP_CLK / I2C_INTERNAL_SAMPLING_CLK; psc -= 1; @@ -139,12 +141,11 @@ static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) }
/* For first phase of HS mode */ - fsscll = I2C_INTERNAL_SAMPLING_CLK / (2 * speed); + scl = I2C_INTERNAL_SAMPLING_CLK / 400000;
- fssclh = fsscll; + fsscll = scl - (scl / 3) - 7; + fssclh = (scl / 3) - 5;
- fsscll -= I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM; - fssclh -= I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM; if (((fsscll < 0) || (fssclh < 0)) || ((fsscll > 255) || (fssclh > 255))) { puts("Error : I2C initializing first phase clock\n"); @@ -152,10 +153,10 @@ static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) }
/* For second phase of HS mode */ - hsscll = hssclh = I2C_INTERNAL_SAMPLING_CLK / (2 * speed); + scl = I2C_IP_CLK / speed; + hsscll = scl - (scl / 3) - 7; + hssclh = (scl / 3) - 5;
- hsscll -= I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM; - hssclh -= I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM; if (((fsscll < 0) || (fssclh < 0)) || ((fsscll > 255) || (fssclh > 255))) { puts("Error : I2C initializing second phase clock\n");
Hello Christophe,
- if (speed > 400000) {
Why you remove the define?
unsigned long scl;
- /* High speed */ psc = I2C_IP_CLK / I2C_INTERNAL_SAMPLING_CLK; psc -= 1;
fssclh = fsscll;
if (((fsscll < 0) || (fssclh < 0)) || ((fsscll > 255) || (fssclh > 255))) { puts("Error : I2C initializing first phase clock\n");fssclh -= I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM;
if (((fsscll < 0) || (fssclh < 0)) || ((fsscll > 255) || (fssclh > 255))) { puts("Error : I2C initializing second phase clock\n");hssclh -= I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM;
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
For several reasons: - code clarity - DM trends in u-boot ...
It is better to make omap24xx_i2c driver 100% DM_I2C based.
drivers/i2c/omap24xx_i2c.c | 447 +++++++++++++++++---------------------------- drivers/i2c/omap24xx_i2c.h | 154 ---------------- 2 files changed, 163 insertions(+), 438 deletions(-) delete mode 100644 drivers/i2c/omap24xx_i2c.h
diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 774edaf..baccb89 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -49,31 +49,164 @@ #include <asm/io.h> #include <asm/errno.h>
-#include "omap24xx_i2c.h" - DECLARE_GLOBAL_DATA_PTR;
+/* I2C masks */ + +/* I2C Interrupt Enable Register (I2C_IE): */ +#define I2C_IE_GC_IE (1 << 5) +#define I2C_IE_XRDY_IE (1 << 4) /* Transmit data ready interrupt enable */ +#define I2C_IE_RRDY_IE (1 << 3) /* Receive data ready interrupt enable */ +#define I2C_IE_ARDY_IE (1 << 2) /* Register access ready interrupt enable */ +#define I2C_IE_NACK_IE (1 << 1) /* No acknowledgment interrupt enable */ +#define I2C_IE_AL_IE (1 << 0) /* Arbitration lost interrupt enable */ + +/* I2C Status Register (I2C_STAT): */ + +#define I2C_STAT_SBD (1 << 15) /* Single byte data */ +#define I2C_STAT_BB (1 << 12) /* Bus busy */ +#define I2C_STAT_ROVR (1 << 11) /* Receive overrun */ +#define I2C_STAT_XUDF (1 << 10) /* Transmit underflow */ +#define I2C_STAT_AAS (1 << 9) /* Address as slave */ +#define I2C_STAT_GC (1 << 5) +#define I2C_STAT_XRDY (1 << 4) /* Transmit data ready */ +#define I2C_STAT_RRDY (1 << 3) /* Receive data ready */ +#define I2C_STAT_ARDY (1 << 2) /* Register access ready */ +#define I2C_STAT_NACK (1 << 1) /* No acknowledgment interrupt enable */ +#define I2C_STAT_AL (1 << 0) /* Arbitration lost interrupt enable */ + +/* I2C Interrupt Code Register (I2C_INTCODE): */ + +#define I2C_INTCODE_MASK 7 +#define I2C_INTCODE_NONE 0 +#define I2C_INTCODE_AL 1 /* Arbitration lost */ +#define I2C_INTCODE_NAK 2 /* No acknowledgement/general call */ +#define I2C_INTCODE_ARDY 3 /* Register access ready */ +#define I2C_INTCODE_RRDY 4 /* Rcv data ready */ +#define I2C_INTCODE_XRDY 5 /* Xmit data ready */ + +/* I2C Buffer Configuration Register (I2C_BUF): */ + +#define I2C_BUF_RDMA_EN (1 << 15) /* Receive DMA channel enable */ +#define I2C_BUF_XDMA_EN (1 << 7) /* Transmit DMA channel enable */ + +/* I2C Configuration Register (I2C_CON): */ + +#define I2C_CON_EN (1 << 15) /* I2C module enable */ +#define I2C_CON_BE (1 << 14) /* Big endian mode */ +#define I2C_CON_STB (1 << 11) /* Start byte mode (master mode only) */ +#define I2C_CON_MST (1 << 10) /* Master/slave mode */ +#define I2C_CON_TRX (1 << 9) /* Transmitter/receiver mode */ + /* (master mode only) */ +#define I2C_CON_XA (1 << 8) /* Expand address */ +#define I2C_CON_STP (1 << 1) /* Stop condition (master mode only) */ +#define I2C_CON_STT (1 << 0) /* Start condition (master mode only) */ + +/* I2C System Test Register (I2C_SYSTEST): */ + +#define I2C_SYSTEST_ST_EN (1 << 15) /* System test enable */ +#define I2C_SYSTEST_FREE (1 << 14) /* Free running mode, on brkpoint) */ +#define I2C_SYSTEST_TMODE_MASK (3 << 12) /* Test mode select */ +#define I2C_SYSTEST_TMODE_SHIFT (12) /* Test mode select */ +#define I2C_SYSTEST_SCL_I (1 << 3) /* SCL line sense input value */ +#define I2C_SYSTEST_SCL_O (1 << 2) /* SCL line drive output value */ +#define I2C_SYSTEST_SDA_I (1 << 1) /* SDA line sense input value */ +#define I2C_SYSTEST_SDA_O (1 << 0) /* SDA line drive output value */ + +/* I2C System Status Register (I2C_SYSS): */ + +#define I2C_SYSS_RDONE (1 << 0) /* Internel reset monitoring */ + +#define I2C_SCLL_SCLL 0 +#define I2C_SCLL_SCLL_M 0xFF +#define I2C_SCLL_HSSCLL 8 +#define I2C_SCLH_HSSCLL_M 0xFF +#define I2C_SCLH_SCLH 0 +#define I2C_SCLH_SCLH_M 0xFF +#define I2C_SCLH_HSSCLH 8 +#define I2C_SCLH_HSSCLH_M 0xFF + +#define OMAP_I2C_STANDARD 100000 +#define OMAP_I2C_FAST_MODE 400000 +#define OMAP_I2C_HIGH_SPEED 3400000 + +#define SYSTEM_CLOCK_12 12000000 +#define SYSTEM_CLOCK_13 13000000 +#define SYSTEM_CLOCK_192 19200000 +#define SYSTEM_CLOCK_96 96000000 + +/* Use the reference value of 96MHz if not explicitly set by the board */ +#ifndef I2C_IP_CLK +#define I2C_IP_CLK SYSTEM_CLOCK_96 +#endif + +/* + * The reference minimum clock for high speed is 19.2MHz. + * The linux 2.6.30 kernel uses this value. + * The reference minimum clock for fast mode is 9.6MHz + * The reference minimum clock for standard mode is 4MHz + * In TRM, the value of 12MHz is used. + */ +#ifndef I2C_INTERNAL_SAMPLING_CLK +#define I2C_INTERNAL_SAMPLING_CLK 19200000 +#endif + +/* + * The equation for the low and high time is + * tlow = scll + scll_trim = (sampling clock * tlow_duty) / speed + * thigh = sclh + sclh_trim = (sampling clock * (1 - tlow_duty)) / speed + * + * If the duty cycle is 50% + * + * tlow = scll + scll_trim = sampling clock / (2 * speed) + * thigh = sclh + sclh_trim = sampling clock / (2 * speed) + * + * In TRM + * scll_trim = 7 + * sclh_trim = 5 + * + * The linux 2.6.30 kernel uses + * scll_trim = 6 + * sclh_trim = 6 + * + * These are the trim values for standard and fast speed + */ +#ifndef I2C_FASTSPEED_SCLL_TRIM +#define I2C_FASTSPEED_SCLL_TRIM 6 +#endif +#ifndef I2C_FASTSPEED_SCLH_TRIM +#define I2C_FASTSPEED_SCLH_TRIM 6 +#endif + +/* These are the trim values for high speed */ +#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM +#define I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM +#endif +#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM +#define I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM +#endif +#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM +#define I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM +#endif +#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM +#define I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM +#endif + +#define I2C_PSC_MAX 0x0f +#define I2C_PSC_MIN 0x00 + #define I2C_TIMEOUT 1000
-#ifdef CONFIG_DM_I2C struct omap24_i2c_bus { int bus_num; int waitdelay; unsigned clock_frequency; struct i2c *i2c_base; }; -#endif
-#ifdef CONFIG_SYS_I2C -static int wait_for_bb(struct i2c_adapter *adap); -static struct i2c *omap24_get_base(struct i2c_adapter *adap); -static u16 wait_for_event(struct i2c_adapter *adap); -static void flush_fifo(struct i2c_adapter *adap); -#else static int wait_for_bb(struct udevice *dev); static u16 wait_for_event(struct udevice *dev); static void flush_fifo(struct udevice *dev); -#endif
static int omap24_i2c_findpsc(u32 *pscl, u32 *psch, uint speed) { @@ -109,26 +242,14 @@ static int omap24_i2c_findpsc(u32 *pscl, u32 *psch, uint speed) return -1; }
-#ifdef CONFIG_SYS_I2C -static uint omap24_i2c_setspeed(struct i2c_adapter *adap, uint speed) -#else static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int psc, fsscll = 0, fssclh = 0; int hsscll = 0, hssclh = 0; u32 scll = 0, sclh = 0;
-#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - if (speed > 400000) { unsigned long scl;
@@ -166,13 +287,8 @@ static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) scll = (unsigned int)hsscll << 8 | (unsigned int)fsscll; sclh = (unsigned int)hssclh << 8 | (unsigned int)fssclh;
-#ifdef CONFIG_SYS_I2C - adap->speed = speed; - adap->waitdelay = (10000000 / speed) * 8; /* wait for 20 clkperiods */ -#else i2c_bus->clock_frequency = speed; i2c_bus->waitdelay = (10000000 / speed) * 8; /* wait for 20 clkperiods */ -#endif } else { /* Standard and fast speed */ psc = omap24_i2c_findpsc(&scll, &sclh, speed); @@ -181,13 +297,8 @@ static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) return -1; }
-#ifdef CONFIG_SYS_I2C - adap->speed = speed; - adap->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */ -#else i2c_bus->clock_frequency = speed; i2c_bus->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */ -#endif }
writew(0, &i2c_base->con); @@ -200,26 +311,14 @@ static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) return 0; }
-#ifdef CONFIG_SYS_I2C -static void omap24_i2c_deblock(struct i2c_adapter *adap) -#else static int omap24_i2c_deblock(struct udevice *adap) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int i; u16 systest; u16 orgsystest;
-#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - /* set test mode ST_EN = 1 */ orgsystest = readw(&i2c_base->systest); systest = orgsystest; @@ -258,30 +357,16 @@ static int omap24_i2c_deblock(struct udevice *adap) /* restore original mode */ writew(orgsystest, &i2c_base->systest);
-#ifdef CONFIG_DM_I2C return 0; -#endif }
-#ifdef CONFIG_SYS_I2C -static void omap24_i2c_init(struct i2c_adapter *adap, int speed, int slaveadd) -#else static void omap24_i2c_init(struct udevice *adap, int speed, int slaveadd) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int timeout = I2C_TIMEOUT; int deblock = 1;
-#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - retry: if (readw(&i2c_base->con) & I2C_CON_EN) { writew(0, &i2c_base->con); @@ -329,24 +414,12 @@ retry: } }
-#ifdef CONFIG_SYS_I2C -static void flush_fifo(struct i2c_adapter *adap) -#else static void flush_fifo(struct udevice *adap) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; u16 stat;
-#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - /* * note: if you try and read data when its not there or ready * you get a bus error @@ -366,25 +439,13 @@ static void flush_fifo(struct udevice *adap) * i2c_probe: Use write access. Allows to identify addresses that are * write-only (like the config register of dual-port EEPROMs) */ -#ifdef CONFIG_SYS_I2C -static int omap24_i2c_probe(struct i2c_adapter *adap, uchar chip) -#else static int omap24_i2c_probe(struct udevice *adap, uint chip, uint chip_flags) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; u16 status; int res = 1; /* default = fail */
-#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - if (chip == readw(&i2c_base->oa)) return res;
@@ -407,26 +468,16 @@ static int omap24_i2c_probe(struct udevice *adap, uint chip, uint chip_flags) * silent exit is desired upon unconfigured bus, remove the * following 'if' section: */ - if (status == I2C_STAT_XRDY) { -#ifdef CONFIG_SYS_I2C - printf("i2c_probe: pads on bus %d probably not configured (status=0x%x)\n", - adap->hwadapnr, status); -#else + if (status == I2C_STAT_XRDY) printf("i2c_probe: pads on bus %d probably not configured (status=0x%x)\n", i2c_bus->bus_num, status); -#endif - } goto pr_exit; }
/* Check for ACK (!NAK) */ if (!(status & I2C_STAT_NACK)) { res = 0; /* Device found */ -#ifdef CONFIG_SYS_I2C - udelay(adap->waitdelay);/* Required by AM335X in SPL */ -#else udelay(i2c_bus->waitdelay); -#endif /* Abort transfer (force idle state) */ writew(I2C_CON_MST | I2C_CON_TRX, &i2c_base->con); /* Reset */ udelay(1000); @@ -452,26 +503,14 @@ pr_exit: * or that do not need a register address at all (such as some clock * distributors). */ -#ifdef CONFIG_SYS_I2C -static int omap24_i2c_read(struct i2c_adapter *adap, uchar chip, uint addr, - int alen, uchar *buffer, int len) -#else static int omap24_i2c_read(struct udevice *adap, uchar chip, uint addr, int alen, uchar *buffer, int len) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int i2c_error = 0; u16 status;
-#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif if (alen < 0) { puts("I2C read: addr len < 0\n"); return 1; @@ -521,13 +560,8 @@ static int omap24_i2c_read(struct udevice *adap, uchar chip, uint addr, /* Try to identify bus that is not padconf'd for I2C */ if (status == I2C_STAT_XRDY) { i2c_error = 2; -#ifdef CONFIG_SYS_I2C - printf("i2c_read (addr phase): pads on bus %d probably not configured (status=0x%x)\n", - adap->hwadapnr, status); -#else printf("i2c_read (addr phase): pads on bus %d probably not configured (status=0x%x)\n", i2c_bus->bus_num, status); -#endif goto rd_exit; } if (status == 0 || (status & I2C_STAT_NACK)) { @@ -570,13 +604,8 @@ static int omap24_i2c_read(struct udevice *adap, uchar chip, uint addr, */ if (status == I2C_STAT_XRDY) { i2c_error = 2; -#ifdef CONFIG_SYS_I2C - printf("i2c_read (data phase): pads on bus %d probably not configured (status=0x%x)\n", - adap->hwadapnr, status); -#else printf("i2c_read (data phase): pads on bus %d probably not configured (status=0x%x)\n", i2c_bus->bus_num, status); -#endif goto rd_exit; } if (status == 0 || (status & I2C_STAT_NACK)) { @@ -600,29 +629,16 @@ rd_exit: }
/* i2c_write: Address (reg offset) may be 0, 1 or 2 bytes long. */ -#ifdef CONFIG_SYS_I2C -static int omap24_i2c_write(struct i2c_adapter *adap, uchar chip, uint addr, - int alen, uchar *buffer, int len) -#else static int omap24_i2c_write(struct udevice *adap, uchar chip, uint addr, int alen, uchar *buffer, int len) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int i; u16 status; int i2c_error = 0; int timeout = I2C_TIMEOUT;
-#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - if (alen < 0) { puts("I2C write: addr len < 0\n"); return 1; @@ -667,13 +683,8 @@ static int omap24_i2c_write(struct udevice *adap, uchar chip, uint addr, /* Try to identify bus that is not padconf'd for I2C */ if (status == I2C_STAT_XRDY) { i2c_error = 2; -#ifdef CONFIG_SYS_I2C - printf("i2c_write: pads on bus %d probably not configured (status=0x%x)\n", - adap->hwadapnr, status); -#else printf("i2c_write: pads on bus %d probably not configured (status=0x%x)\n", i2c_bus->bus_num, status); -#endif goto wr_exit; } if (status == 0 || (status & I2C_STAT_NACK)) { @@ -732,25 +743,13 @@ wr_exit: * Wait for the bus to be free by checking the Bus Busy (BB) * bit to become clear */ -#ifdef CONFIG_SYS_I2C -static int wait_for_bb(struct i2c_adapter *adap) -#else static int wait_for_bb(struct udevice *adap) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int timeout = I2C_TIMEOUT; u16 stat;
-#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - writew(0xFFFF, &i2c_base->stat); /* clear current interrupts...*/ #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) while ((stat = readw(&i2c_base->stat) & I2C_STAT_BB) && timeout--) { @@ -760,11 +759,7 @@ static int wait_for_bb(struct udevice *adap) I2C_STAT_BB) && timeout--) { #endif writew(stat, &i2c_base->stat); -#ifdef CONFIG_SYS_I2C - udelay(adap->waitdelay); -#else udelay(i2c_bus->waitdelay); -#endif }
if (timeout <= 0) { @@ -780,31 +775,15 @@ static int wait_for_bb(struct udevice *adap) * Wait for the I2C controller to complete current action * and update status */ -#ifdef CONFIG_SYS_I2C -static u16 wait_for_event(struct i2c_adapter *adap) -#else static u16 wait_for_event(struct udevice *adap) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; u16 status; int timeout = I2C_TIMEOUT;
-#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - do { -#ifdef CONFIG_SYS_I2C - udelay(adap->waitdelay); -#else udelay(i2c_bus->waitdelay); -#endif #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) status = readw(&i2c_base->stat); #else @@ -823,13 +802,8 @@ static u16 wait_for_event(struct udevice *adap) * If status is still 0 here, probably the bus pads have * not been configured for I2C, and/or pull-ups are missing. */ -#ifdef CONFIG_SYS_I2C - printf("Check if pads/pull-ups of bus %d are properly configured\n", - adap->hwadapnr); -#else printf("Check if pads/pull-ups of bus %d are properly configured\n", i2c_bus->bus_num); -#endif writew(0xFFFF, &i2c_base->stat); status = 0; } @@ -837,100 +811,6 @@ static u16 wait_for_event(struct udevice *adap) return status; }
-#ifdef CONFIG_SYS_I2C -static struct i2c *omap24_get_base(struct i2c_adapter *adap) -{ - switch (adap->hwadapnr) { - case 0: - return (struct i2c *)I2C_BASE1; - break; - case 1: - return (struct i2c *)I2C_BASE2; - break; -#if (I2C_BUS_MAX > 2) - case 2: - return (struct i2c *)I2C_BASE3; - break; -#if (I2C_BUS_MAX > 3) - case 3: - return (struct i2c *)I2C_BASE4; - break; -#if (I2C_BUS_MAX > 4) - case 4: - return (struct i2c *)I2C_BASE5; - break; -#endif -#endif -#endif - default: - printf("wrong hwadapnr: %d\n", adap->hwadapnr); - break; - } - return NULL; -} - -#if !defined(CONFIG_SYS_OMAP24_I2C_SPEED1) -#define CONFIG_SYS_OMAP24_I2C_SPEED1 CONFIG_SYS_OMAP24_I2C_SPEED -#endif -#if !defined(CONFIG_SYS_OMAP24_I2C_SLAVE1) -#define CONFIG_SYS_OMAP24_I2C_SLAVE1 CONFIG_SYS_OMAP24_I2C_SLAVE -#endif - -U_BOOT_I2C_ADAP_COMPLETE(omap24_0, omap24_i2c_init, omap24_i2c_probe, - omap24_i2c_read, omap24_i2c_write, omap24_i2c_setspeed, - CONFIG_SYS_OMAP24_I2C_SPEED, - CONFIG_SYS_OMAP24_I2C_SLAVE, - 0) -U_BOOT_I2C_ADAP_COMPLETE(omap24_1, omap24_i2c_init, omap24_i2c_probe, - omap24_i2c_read, omap24_i2c_write, omap24_i2c_setspeed, - CONFIG_SYS_OMAP24_I2C_SPEED1, - CONFIG_SYS_OMAP24_I2C_SLAVE1, - 1) -#if (I2C_BUS_MAX > 2) -#if !defined(CONFIG_SYS_OMAP24_I2C_SPEED2) -#define CONFIG_SYS_OMAP24_I2C_SPEED2 CONFIG_SYS_OMAP24_I2C_SPEED -#endif -#if !defined(CONFIG_SYS_OMAP24_I2C_SLAVE2) -#define CONFIG_SYS_OMAP24_I2C_SLAVE2 CONFIG_SYS_OMAP24_I2C_SLAVE -#endif - -U_BOOT_I2C_ADAP_COMPLETE(omap24_2, omap24_i2c_init, omap24_i2c_probe, - omap24_i2c_read, omap24_i2c_write, NULL, - CONFIG_SYS_OMAP24_I2C_SPEED2, - CONFIG_SYS_OMAP24_I2C_SLAVE2, - 2) -#if (I2C_BUS_MAX > 3) -#if !defined(CONFIG_SYS_OMAP24_I2C_SPEED3) -#define CONFIG_SYS_OMAP24_I2C_SPEED3 CONFIG_SYS_OMAP24_I2C_SPEED -#endif -#if !defined(CONFIG_SYS_OMAP24_I2C_SLAVE3) -#define CONFIG_SYS_OMAP24_I2C_SLAVE3 CONFIG_SYS_OMAP24_I2C_SLAVE -#endif - -U_BOOT_I2C_ADAP_COMPLETE(omap24_3, omap24_i2c_init, omap24_i2c_probe, - omap24_i2c_read, omap24_i2c_write, NULL, - CONFIG_SYS_OMAP24_I2C_SPEED3, - CONFIG_SYS_OMAP24_I2C_SLAVE3, - 3) -#if (I2C_BUS_MAX > 4) -#if !defined(CONFIG_SYS_OMAP24_I2C_SPEED4) -#define CONFIG_SYS_OMAP24_I2C_SPEED4 CONFIG_SYS_OMAP24_I2C_SPEED -#endif -#if !defined(CONFIG_SYS_OMAP24_I2C_SLAVE4) -#define CONFIG_SYS_OMAP24_I2C_SLAVE4 CONFIG_SYS_OMAP24_I2C_SLAVE -#endif - -U_BOOT_I2C_ADAP_COMPLETE(omap24_4, omap24_i2c_init, omap24_i2c_probe, - omap24_i2c_read, omap24_i2c_write, NULL, - CONFIG_SYS_OMAP24_I2C_SPEED4, - CONFIG_SYS_OMAP24_I2C_SLAVE4, - 4) -#endif -#endif -#endif -#endif - -#ifdef CONFIG_DM_I2C static int omap24_i2c_xfer(struct udevice *adap, struct i2c_msg *msg, int nmsgs) { @@ -996,4 +876,3 @@ U_BOOT_DRIVER(omap_i2c) = { .priv_auto_alloc_size = sizeof(struct omap24_i2c_bus), .ops = &omap24_i2c_ops, }; -#endif diff --git a/drivers/i2c/omap24xx_i2c.h b/drivers/i2c/omap24xx_i2c.h deleted file mode 100644 index 3dae295..0000000 --- a/drivers/i2c/omap24xx_i2c.h +++ /dev/null @@ -1,154 +0,0 @@ -/* - * (C) Copyright 2004-2010 - * Texas Instruments, <www.ti.com> - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef _OMAP2PLUS_I2C_H_ -#define _OMAP2PLUS_I2C_H_ - -/* I2C masks */ - -/* I2C Interrupt Enable Register (I2C_IE): */ -#define I2C_IE_GC_IE (1 << 5) -#define I2C_IE_XRDY_IE (1 << 4) /* Transmit data ready interrupt enable */ -#define I2C_IE_RRDY_IE (1 << 3) /* Receive data ready interrupt enable */ -#define I2C_IE_ARDY_IE (1 << 2) /* Register access ready interrupt enable */ -#define I2C_IE_NACK_IE (1 << 1) /* No acknowledgment interrupt enable */ -#define I2C_IE_AL_IE (1 << 0) /* Arbitration lost interrupt enable */ - -/* I2C Status Register (I2C_STAT): */ - -#define I2C_STAT_SBD (1 << 15) /* Single byte data */ -#define I2C_STAT_BB (1 << 12) /* Bus busy */ -#define I2C_STAT_ROVR (1 << 11) /* Receive overrun */ -#define I2C_STAT_XUDF (1 << 10) /* Transmit underflow */ -#define I2C_STAT_AAS (1 << 9) /* Address as slave */ -#define I2C_STAT_GC (1 << 5) -#define I2C_STAT_XRDY (1 << 4) /* Transmit data ready */ -#define I2C_STAT_RRDY (1 << 3) /* Receive data ready */ -#define I2C_STAT_ARDY (1 << 2) /* Register access ready */ -#define I2C_STAT_NACK (1 << 1) /* No acknowledgment interrupt enable */ -#define I2C_STAT_AL (1 << 0) /* Arbitration lost interrupt enable */ - -/* I2C Interrupt Code Register (I2C_INTCODE): */ - -#define I2C_INTCODE_MASK 7 -#define I2C_INTCODE_NONE 0 -#define I2C_INTCODE_AL 1 /* Arbitration lost */ -#define I2C_INTCODE_NAK 2 /* No acknowledgement/general call */ -#define I2C_INTCODE_ARDY 3 /* Register access ready */ -#define I2C_INTCODE_RRDY 4 /* Rcv data ready */ -#define I2C_INTCODE_XRDY 5 /* Xmit data ready */ - -/* I2C Buffer Configuration Register (I2C_BUF): */ - -#define I2C_BUF_RDMA_EN (1 << 15) /* Receive DMA channel enable */ -#define I2C_BUF_XDMA_EN (1 << 7) /* Transmit DMA channel enable */ - -/* I2C Configuration Register (I2C_CON): */ - -#define I2C_CON_EN (1 << 15) /* I2C module enable */ -#define I2C_CON_BE (1 << 14) /* Big endian mode */ -#define I2C_CON_STB (1 << 11) /* Start byte mode (master mode only) */ -#define I2C_CON_MST (1 << 10) /* Master/slave mode */ -#define I2C_CON_TRX (1 << 9) /* Transmitter/receiver mode */ - /* (master mode only) */ -#define I2C_CON_XA (1 << 8) /* Expand address */ -#define I2C_CON_STP (1 << 1) /* Stop condition (master mode only) */ -#define I2C_CON_STT (1 << 0) /* Start condition (master mode only) */ - -/* I2C System Test Register (I2C_SYSTEST): */ - -#define I2C_SYSTEST_ST_EN (1 << 15) /* System test enable */ -#define I2C_SYSTEST_FREE (1 << 14) /* Free running mode, on brkpoint) */ -#define I2C_SYSTEST_TMODE_MASK (3 << 12) /* Test mode select */ -#define I2C_SYSTEST_TMODE_SHIFT (12) /* Test mode select */ -#define I2C_SYSTEST_SCL_I (1 << 3) /* SCL line sense input value */ -#define I2C_SYSTEST_SCL_O (1 << 2) /* SCL line drive output value */ -#define I2C_SYSTEST_SDA_I (1 << 1) /* SDA line sense input value */ -#define I2C_SYSTEST_SDA_O (1 << 0) /* SDA line drive output value */ - -/* I2C System Status Register (I2C_SYSS): */ - -#define I2C_SYSS_RDONE (1 << 0) /* Internel reset monitoring */ - -#define I2C_SCLL_SCLL 0 -#define I2C_SCLL_SCLL_M 0xFF -#define I2C_SCLL_HSSCLL 8 -#define I2C_SCLH_HSSCLL_M 0xFF -#define I2C_SCLH_SCLH 0 -#define I2C_SCLH_SCLH_M 0xFF -#define I2C_SCLH_HSSCLH 8 -#define I2C_SCLH_HSSCLH_M 0xFF - -#define OMAP_I2C_STANDARD 100000 -#define OMAP_I2C_FAST_MODE 400000 -#define OMAP_I2C_HIGH_SPEED 3400000 - -#define SYSTEM_CLOCK_12 12000000 -#define SYSTEM_CLOCK_13 13000000 -#define SYSTEM_CLOCK_192 19200000 -#define SYSTEM_CLOCK_96 96000000 - -/* Use the reference value of 96MHz if not explicitly set by the board */ -#ifndef I2C_IP_CLK -#define I2C_IP_CLK SYSTEM_CLOCK_96 -#endif - -/* - * The reference minimum clock for high speed is 19.2MHz. - * The linux 2.6.30 kernel uses this value. - * The reference minimum clock for fast mode is 9.6MHz - * The reference minimum clock for standard mode is 4MHz - * In TRM, the value of 12MHz is used. - */ -#ifndef I2C_INTERNAL_SAMPLING_CLK -#define I2C_INTERNAL_SAMPLING_CLK 19200000 -#endif - -/* - * The equation for the low and high time is - * tlow = scll + scll_trim = (sampling clock * tlow_duty) / speed - * thigh = sclh + sclh_trim = (sampling clock * (1 - tlow_duty)) / speed - * - * If the duty cycle is 50% - * - * tlow = scll + scll_trim = sampling clock / (2 * speed) - * thigh = sclh + sclh_trim = sampling clock / (2 * speed) - * - * In TRM - * scll_trim = 7 - * sclh_trim = 5 - * - * The linux 2.6.30 kernel uses - * scll_trim = 6 - * sclh_trim = 6 - * - * These are the trim values for standard and fast speed - */ -#ifndef I2C_FASTSPEED_SCLL_TRIM -#define I2C_FASTSPEED_SCLL_TRIM 6 -#endif -#ifndef I2C_FASTSPEED_SCLH_TRIM -#define I2C_FASTSPEED_SCLH_TRIM 6 -#endif - -/* These are the trim values for high speed */ -#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM -#define I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM -#endif -#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM -#define I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM -#endif -#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM -#define I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM -#endif -#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM -#define I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM -#endif - -#define I2C_PSC_MAX 0x0f -#define I2C_PSC_MIN 0x00 - -#endif /* _OMAP24XX_I2C_H_ */
Hello Christophe,
- code clarity
Full Ack .. but does this patch does not breeak boards, which use this driver, and are not converted to DM ? I think, we could remove the old style only, if all boards are converted ...
bye, Heiko
Why do you remove the header file, and move all definitions into the c file?
+/* I2C masks */
- The reference minimum clock for high speed is 19.2MHz.
- The linux 2.6.30 kernel uses this value.
- The reference minimum clock for fast mode is 9.6MHz
- The reference minimum clock for standard mode is 4MHz
- In TRM, the value of 12MHz is used.
- The equation for the low and high time is
- tlow = scll + scll_trim = (sampling clock * tlow_duty) / speed
- thigh = sclh + sclh_trim = (sampling clock * (1 - tlow_duty)) / speed
- If the duty cycle is 50%
- tlow = scll + scll_trim = sampling clock / (2 * speed)
- thigh = sclh + sclh_trim = sampling clock / (2 * speed)
- In TRM
- scll_trim = 7
- sclh_trim = 5
- scll_trim = 6
- sclh_trim = 6
- These are the trim values for standard and fast speed
- #define I2C_TIMEOUT 1000
- struct i2c *i2c_base = i2c_bus->i2c_base; int psc, fsscll = 0, fssclh = 0; int hsscll = 0, hssclh = 0; u32 scll = 0, sclh = 0;
-#else
-#endif
- struct i2c *i2c_base = i2c_bus->i2c_base; int i; u16 systest; u16 orgsystest;
-#else
-#endif
- struct i2c *i2c_base = i2c_bus->i2c_base; int timeout = I2C_TIMEOUT; int deblock = 1;
-#else
-#endif
- struct i2c *i2c_base = i2c_bus->i2c_base; u16 stat;
-#else
-#endif
- struct i2c *i2c_base = i2c_bus->i2c_base; u16 status; int res = 1; /* default = fail */
-#else
-#endif
-#else
-#endif
goto pr_exit; }
distributors).
- struct i2c *i2c_base = i2c_bus->i2c_base; int i2c_error = 0; u16 status;
-#else
- struct i2c *i2c_base = i2c_bus->i2c_base; int i; u16 status; int i2c_error = 0; int timeout = I2C_TIMEOUT;
-#else
-#endif
- struct i2c *i2c_base = i2c_bus->i2c_base; int timeout = I2C_TIMEOUT; u16 stat;
-#else
-#endif
- and update status
- struct i2c *i2c_base = i2c_bus->i2c_base; u16 status; int timeout = I2C_TIMEOUT;
-#else
-#endif
- do {
adap->hwadapnr);
- case 0:
break;
- case 1:
break;
- case 2:
break;
- case 3:
break;
- case 4:
break;
- default:
break;
- return NULL;
0)
1)
2)
3)
4)
- (C) Copyright 2004-2010
- Texas Instruments, <www.ti.com>
-/* I2C masks */
- In TRM
- scll_trim = 7
- sclh_trim = 5
- scll_trim = 6
- sclh_trim = 6
Hi Heiko,
I was expecting such kind of feedback on this one :). I had myself to hack around between the MLO and the u-boot.img to get it working.
For omap, i think twlxxxx drivers are kind of the main item to convert.
Would you accept to take the first 4 patches until the board are fully ready for the 5th one ?
2016-01-18 7:04 GMT+01:00 Heiko Schocher hs@denx.de:
Hello Christophe,
- code clarity
bye, Heiko
+/* I2C masks */
- In TRM
- scll_trim = 7
- sclh_trim = 5
- scll_trim = 6
- sclh_trim = 6
-#else
-#endif
-#else
-#endif
-#else
-#endif
-#else
-#endif
-#else
-#endif
-#else
} goto pr_exit; } /* Check for ACK (!NAK) */ if (!(status & I2C_STAT_NACK)) { res = 0; /* Device found */
some clock
distributors).
-#else
-#else
-#endif
-#else
-#endif
if (timeout <= 0) {
- and update status
-#else
-#endif
do {
configured\n",
adap->hwadapnr);
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
default:
break;
return NULL;
0)
1)
2)
3)
4)
-/* I2C masks */
- In TRM
- scll_trim = 7
- sclh_trim = 5
- scll_trim = 6
- sclh_trim = 6
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
Hello Christophe,
Am 18.01.2016 um 22:22 schrieb Christophe Ricard:
Hi Heiko,
Yes. If they have no checkpatch errors and apply clean ;-)
I try to look at it, today.
bye, Heiko
2016-01-18 7:04 GMT+01:00 Heiko Schocher <hs@denx.de mailto:hs@denx.de>:
Hello Christophe, Am 17.01.2016 um 12:09 schrieb Christophe Ricard: For several reasons: - code clarity - DM trends in u-boot ... It is better to make omap24xx_i2c driver 100% DM_I2C based. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com <mailto:christophe-h.ricard@st.com>> --- drivers/i2c/omap24xx_i2c.c | 447 +++++++++++++++++---------------------------- drivers/i2c/omap24xx_i2c.h | 154 ---------------- 2 files changed, 163 insertions(+), 438 deletions(-) delete mode 100644 drivers/i2c/omap24xx_i2c.h Full Ack .. but does this patch does not breeak boards, which use this driver, and are not converted to DM ? I think, we could remove the old style only, if all boards are converted ... bye, Heiko diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 774edaf..baccb89 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -49,31 +49,164 @@ #include <asm/io.h> #include <asm/errno.h> -#include "omap24xx_i2c.h" - ? Why do you remove the header file, and move all definitions into the c file? DECLARE_GLOBAL_DATA_PTR; +/* I2C masks */ + +/* I2C Interrupt Enable Register (I2C_IE): */ +#define I2C_IE_GC_IE (1 << 5) +#define I2C_IE_XRDY_IE (1 << 4) /* Transmit data ready interrupt enable */ +#define I2C_IE_RRDY_IE (1 << 3) /* Receive data ready interrupt enable */ +#define I2C_IE_ARDY_IE (1 << 2) /* Register access ready interrupt enable */ +#define I2C_IE_NACK_IE (1 << 1) /* No acknowledgment interrupt enable */ +#define I2C_IE_AL_IE (1 << 0) /* Arbitration lost interrupt enable */ + +/* I2C Status Register (I2C_STAT): */ + +#define I2C_STAT_SBD (1 << 15) /* Single byte data */ +#define I2C_STAT_BB (1 << 12) /* Bus busy */ +#define I2C_STAT_ROVR (1 << 11) /* Receive overrun */ +#define I2C_STAT_XUDF (1 << 10) /* Transmit underflow */ +#define I2C_STAT_AAS (1 << 9) /* Address as slave */ +#define I2C_STAT_GC (1 << 5) +#define I2C_STAT_XRDY (1 << 4) /* Transmit data ready */ +#define I2C_STAT_RRDY (1 << 3) /* Receive data ready */ +#define I2C_STAT_ARDY (1 << 2) /* Register access ready */ +#define I2C_STAT_NACK (1 << 1) /* No acknowledgment interrupt enable */ +#define I2C_STAT_AL (1 << 0) /* Arbitration lost interrupt enable */ + +/* I2C Interrupt Code Register (I2C_INTCODE): */ + +#define I2C_INTCODE_MASK 7 +#define I2C_INTCODE_NONE 0 +#define I2C_INTCODE_AL 1 /* Arbitration lost */ +#define I2C_INTCODE_NAK 2 /* No acknowledgement/general call */ +#define I2C_INTCODE_ARDY 3 /* Register access ready */ +#define I2C_INTCODE_RRDY 4 /* Rcv data ready */ +#define I2C_INTCODE_XRDY 5 /* Xmit data ready */ + +/* I2C Buffer Configuration Register (I2C_BUF): */ + +#define I2C_BUF_RDMA_EN (1 << 15) /* Receive DMA channel enable */ +#define I2C_BUF_XDMA_EN (1 << 7) /* Transmit DMA channel enable */ + +/* I2C Configuration Register (I2C_CON): */ + +#define I2C_CON_EN (1 << 15) /* I2C module enable */ +#define I2C_CON_BE (1 << 14) /* Big endian mode */ +#define I2C_CON_STB (1 << 11) /* Start byte mode (master mode only) */ +#define I2C_CON_MST (1 << 10) /* Master/slave mode */ +#define I2C_CON_TRX (1 << 9) /* Transmitter/receiver mode */ + /* (master mode only) */ +#define I2C_CON_XA (1 << 8) /* Expand address */ +#define I2C_CON_STP (1 << 1) /* Stop condition (master mode only) */ +#define I2C_CON_STT (1 << 0) /* Start condition (master mode only) */ + +/* I2C System Test Register (I2C_SYSTEST): */ + +#define I2C_SYSTEST_ST_EN (1 << 15) /* System test enable */ +#define I2C_SYSTEST_FREE (1 << 14) /* Free running mode, on brkpoint) */ +#define I2C_SYSTEST_TMODE_MASK (3 << 12) /* Test mode select */ +#define I2C_SYSTEST_TMODE_SHIFT (12) /* Test mode select */ +#define I2C_SYSTEST_SCL_I (1 << 3) /* SCL line sense input value */ +#define I2C_SYSTEST_SCL_O (1 << 2) /* SCL line drive output value */ +#define I2C_SYSTEST_SDA_I (1 << 1) /* SDA line sense input value */ +#define I2C_SYSTEST_SDA_O (1 << 0) /* SDA line drive output value */ + +/* I2C System Status Register (I2C_SYSS): */ + +#define I2C_SYSS_RDONE (1 << 0) /* Internel reset monitoring */ + +#define I2C_SCLL_SCLL 0 +#define I2C_SCLL_SCLL_M 0xFF +#define I2C_SCLL_HSSCLL 8 +#define I2C_SCLH_HSSCLL_M 0xFF +#define I2C_SCLH_SCLH 0 +#define I2C_SCLH_SCLH_M 0xFF +#define I2C_SCLH_HSSCLH 8 +#define I2C_SCLH_HSSCLH_M 0xFF + +#define OMAP_I2C_STANDARD 100000 +#define OMAP_I2C_FAST_MODE 400000 +#define OMAP_I2C_HIGH_SPEED 3400000 + +#define SYSTEM_CLOCK_12 12000000 +#define SYSTEM_CLOCK_13 13000000 +#define SYSTEM_CLOCK_192 19200000 +#define SYSTEM_CLOCK_96 96000000 + +/* Use the reference value of 96MHz if not explicitly set by the board */ +#ifndef I2C_IP_CLK +#define I2C_IP_CLK SYSTEM_CLOCK_96 +#endif + +/* + * The reference minimum clock for high speed is 19.2MHz. + * The linux 2.6.30 kernel uses this value. + * The reference minimum clock for fast mode is 9.6MHz + * The reference minimum clock for standard mode is 4MHz + * In TRM, the value of 12MHz is used. + */ +#ifndef I2C_INTERNAL_SAMPLING_CLK +#define I2C_INTERNAL_SAMPLING_CLK 19200000 +#endif + +/* + * The equation for the low and high time is + * tlow = scll + scll_trim = (sampling clock * tlow_duty) / speed + * thigh = sclh + sclh_trim = (sampling clock * (1 - tlow_duty)) / speed + * + * If the duty cycle is 50% + * + * tlow = scll + scll_trim = sampling clock / (2 * speed) + * thigh = sclh + sclh_trim = sampling clock / (2 * speed) + * + * In TRM + * scll_trim = 7 + * sclh_trim = 5 + * + * The linux 2.6.30 kernel uses + * scll_trim = 6 + * sclh_trim = 6 + * + * These are the trim values for standard and fast speed + */ +#ifndef I2C_FASTSPEED_SCLL_TRIM +#define I2C_FASTSPEED_SCLL_TRIM 6 +#endif +#ifndef I2C_FASTSPEED_SCLH_TRIM +#define I2C_FASTSPEED_SCLH_TRIM 6 +#endif + +/* These are the trim values for high speed */ +#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM +#define I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM +#endif +#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM +#define I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM +#endif +#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM +#define I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM +#endif +#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM +#define I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM +#endif + +#define I2C_PSC_MAX 0x0f +#define I2C_PSC_MIN 0x00 + #define I2C_TIMEOUT 1000 -#ifdef CONFIG_DM_I2C struct omap24_i2c_bus { int bus_num; int waitdelay; unsigned clock_frequency; struct i2c *i2c_base; }; -#endif -#ifdef CONFIG_SYS_I2C -static int wait_for_bb(struct i2c_adapter *adap); -static struct i2c *omap24_get_base(struct i2c_adapter *adap); -static u16 wait_for_event(struct i2c_adapter *adap); -static void flush_fifo(struct i2c_adapter *adap); -#else static int wait_for_bb(struct udevice *dev); static u16 wait_for_event(struct udevice *dev); static void flush_fifo(struct udevice *dev); -#endif static int omap24_i2c_findpsc(u32 *pscl, u32 *psch, uint speed) { @@ -109,26 +242,14 @@ static int omap24_i2c_findpsc(u32 *pscl, u32 *psch, uint speed) return -1; } -#ifdef CONFIG_SYS_I2C -static uint omap24_i2c_setspeed(struct i2c_adapter *adap, uint speed) -#else static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int psc, fsscll = 0, fssclh = 0; int hsscll = 0, hssclh = 0; u32 scll = 0, sclh = 0; -#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - if (speed > 400000) { unsigned long scl; @@ -166,13 +287,8 @@ static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) scll = (unsigned int)hsscll << 8 | (unsigned int)fsscll; sclh = (unsigned int)hssclh << 8 | (unsigned int)fssclh; -#ifdef CONFIG_SYS_I2C - adap->speed = speed; - adap->waitdelay = (10000000 / speed) * 8; /* wait for 20 clkperiods */ -#else i2c_bus->clock_frequency = speed; i2c_bus->waitdelay = (10000000 / speed) * 8; /* wait for 20 clkperiods */ -#endif } else { /* Standard and fast speed */ psc = omap24_i2c_findpsc(&scll, &sclh, speed); @@ -181,13 +297,8 @@ static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) return -1; } -#ifdef CONFIG_SYS_I2C - adap->speed = speed; - adap->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */ -#else i2c_bus->clock_frequency = speed; i2c_bus->waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */ -#endif } writew(0, &i2c_base->con); @@ -200,26 +311,14 @@ static int omap24_i2c_setspeed(struct udevice *adap, unsigned int speed) return 0; } -#ifdef CONFIG_SYS_I2C -static void omap24_i2c_deblock(struct i2c_adapter *adap) -#else static int omap24_i2c_deblock(struct udevice *adap) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int i; u16 systest; u16 orgsystest; -#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - /* set test mode ST_EN = 1 */ orgsystest = readw(&i2c_base->systest); systest = orgsystest; @@ -258,30 +357,16 @@ static int omap24_i2c_deblock(struct udevice *adap) /* restore original mode */ writew(orgsystest, &i2c_base->systest); -#ifdef CONFIG_DM_I2C return 0; -#endif } -#ifdef CONFIG_SYS_I2C -static void omap24_i2c_init(struct i2c_adapter *adap, int speed, int slaveadd) -#else static void omap24_i2c_init(struct udevice *adap, int speed, int slaveadd) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int timeout = I2C_TIMEOUT; int deblock = 1; -#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - retry: if (readw(&i2c_base->con) & I2C_CON_EN) { writew(0, &i2c_base->con); @@ -329,24 +414,12 @@ retry: } } -#ifdef CONFIG_SYS_I2C -static void flush_fifo(struct i2c_adapter *adap) -#else static void flush_fifo(struct udevice *adap) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; u16 stat; -#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - /* * note: if you try and read data when its not there or ready * you get a bus error @@ -366,25 +439,13 @@ static void flush_fifo(struct udevice *adap) * i2c_probe: Use write access. Allows to identify addresses that are * write-only (like the config register of dual-port EEPROMs) */ -#ifdef CONFIG_SYS_I2C -static int omap24_i2c_probe(struct i2c_adapter *adap, uchar chip) -#else static int omap24_i2c_probe(struct udevice *adap, uint chip, uint chip_flags) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; u16 status; int res = 1; /* default = fail */ -#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - if (chip == readw(&i2c_base->oa)) return res; @@ -407,26 +468,16 @@ static int omap24_i2c_probe(struct udevice *adap, uint chip, uint chip_flags) * silent exit is desired upon unconfigured bus, remove the * following 'if' section: */ - if (status == I2C_STAT_XRDY) { -#ifdef CONFIG_SYS_I2C - printf("i2c_probe: pads on bus %d probably not configured (status=0x%x)\n", - adap->hwadapnr, status); -#else + if (status == I2C_STAT_XRDY) printf("i2c_probe: pads on bus %d probably not configured (status=0x%x)\n", i2c_bus->bus_num, status); -#endif - } goto pr_exit; } /* Check for ACK (!NAK) */ if (!(status & I2C_STAT_NACK)) { res = 0; /* Device found */ -#ifdef CONFIG_SYS_I2C - udelay(adap->waitdelay);/* Required by AM335X in SPL */ -#else udelay(i2c_bus->waitdelay); -#endif /* Abort transfer (force idle state) */ writew(I2C_CON_MST | I2C_CON_TRX, &i2c_base->con); /* Reset */ udelay(1000); @@ -452,26 +503,14 @@ pr_exit: * or that do not need a register address at all (such as some clock * distributors). */ -#ifdef CONFIG_SYS_I2C -static int omap24_i2c_read(struct i2c_adapter *adap, uchar chip, uint addr, - int alen, uchar *buffer, int len) -#else static int omap24_i2c_read(struct udevice *adap, uchar chip, uint addr, int alen, uchar *buffer, int len) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int i2c_error = 0; u16 status; -#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif if (alen < 0) { puts("I2C read: addr len < 0\n"); return 1; @@ -521,13 +560,8 @@ static int omap24_i2c_read(struct udevice *adap, uchar chip, uint addr, /* Try to identify bus that is not padconf'd for I2C */ if (status == I2C_STAT_XRDY) { i2c_error = 2; -#ifdef CONFIG_SYS_I2C - printf("i2c_read (addr phase): pads on bus %d probably not configured (status=0x%x)\n", - adap->hwadapnr, status); -#else printf("i2c_read (addr phase): pads on bus %d probably not configured (status=0x%x)\n", i2c_bus->bus_num, status); -#endif goto rd_exit; } if (status == 0 || (status & I2C_STAT_NACK)) { @@ -570,13 +604,8 @@ static int omap24_i2c_read(struct udevice *adap, uchar chip, uint addr, */ if (status == I2C_STAT_XRDY) { i2c_error = 2; -#ifdef CONFIG_SYS_I2C - printf("i2c_read (data phase): pads on bus %d probably not configured (status=0x%x)\n", - adap->hwadapnr, status); -#else printf("i2c_read (data phase): pads on bus %d probably not configured (status=0x%x)\n", i2c_bus->bus_num, status); -#endif goto rd_exit; } if (status == 0 || (status & I2C_STAT_NACK)) { @@ -600,29 +629,16 @@ rd_exit: } /* i2c_write: Address (reg offset) may be 0, 1 or 2 bytes long. */ -#ifdef CONFIG_SYS_I2C -static int omap24_i2c_write(struct i2c_adapter *adap, uchar chip, uint addr, - int alen, uchar *buffer, int len) -#else static int omap24_i2c_write(struct udevice *adap, uchar chip, uint addr, int alen, uchar *buffer, int len) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int i; u16 status; int i2c_error = 0; int timeout = I2C_TIMEOUT; -#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - if (alen < 0) { puts("I2C write: addr len < 0\n"); return 1; @@ -667,13 +683,8 @@ static int omap24_i2c_write(struct udevice *adap, uchar chip, uint addr, /* Try to identify bus that is not padconf'd for I2C */ if (status == I2C_STAT_XRDY) { i2c_error = 2; -#ifdef CONFIG_SYS_I2C - printf("i2c_write: pads on bus %d probably not configured (status=0x%x)\n", - adap->hwadapnr, status); -#else printf("i2c_write: pads on bus %d probably not configured (status=0x%x)\n", i2c_bus->bus_num, status); -#endif goto wr_exit; } if (status == 0 || (status & I2C_STAT_NACK)) { @@ -732,25 +743,13 @@ wr_exit: * Wait for the bus to be free by checking the Bus Busy (BB) * bit to become clear */ -#ifdef CONFIG_SYS_I2C -static int wait_for_bb(struct i2c_adapter *adap) -#else static int wait_for_bb(struct udevice *adap) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; int timeout = I2C_TIMEOUT; u16 stat; -#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - writew(0xFFFF, &i2c_base->stat); /* clear current interrupts...*/ #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) while ((stat = readw(&i2c_base->stat) & I2C_STAT_BB) && timeout--) { @@ -760,11 +759,7 @@ static int wait_for_bb(struct udevice *adap) I2C_STAT_BB) && timeout--) { #endif writew(stat, &i2c_base->stat); -#ifdef CONFIG_SYS_I2C - udelay(adap->waitdelay); -#else udelay(i2c_bus->waitdelay); -#endif } if (timeout <= 0) { @@ -780,31 +775,15 @@ static int wait_for_bb(struct udevice *adap) * Wait for the I2C controller to complete current action * and update status */ -#ifdef CONFIG_SYS_I2C -static u16 wait_for_event(struct i2c_adapter *adap) -#else static u16 wait_for_event(struct udevice *adap) -#endif { - struct i2c *i2c_base; + struct omap24_i2c_bus *i2c_bus = dev_get_priv(adap); + struct i2c *i2c_base = i2c_bus->i2c_base; u16 status; int timeout = I2C_TIMEOUT; -#ifdef CONFIG_SYS_I2C - i2c_base = omap24_get_base(adap); -#else - struct omap24_i2c_bus *i2c_bus; - - i2c_bus = dev_get_priv(adap); - i2c_base = i2c_bus->i2c_base; -#endif - do { -#ifdef CONFIG_SYS_I2C - udelay(adap->waitdelay); -#else udelay(i2c_bus->waitdelay); -#endif #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) status = readw(&i2c_base->stat); #else @@ -823,13 +802,8 @@ static u16 wait_for_event(struct udevice *adap) * If status is still 0 here, probably the bus pads have * not been configured for I2C, and/or pull-ups are missing. */ -#ifdef CONFIG_SYS_I2C - printf("Check if pads/pull-ups of bus %d are properly configured\n", - adap->hwadapnr); -#else printf("Check if pads/pull-ups of bus %d are properly configured\n", i2c_bus->bus_num); -#endif writew(0xFFFF, &i2c_base->stat); status = 0; } @@ -837,100 +811,6 @@ static u16 wait_for_event(struct udevice *adap) return status; } -#ifdef CONFIG_SYS_I2C -static struct i2c *omap24_get_base(struct i2c_adapter *adap) -{ - switch (adap->hwadapnr) { - case 0: - return (struct i2c *)I2C_BASE1; - break; - case 1: - return (struct i2c *)I2C_BASE2; - break; -#if (I2C_BUS_MAX > 2) - case 2: - return (struct i2c *)I2C_BASE3; - break; -#if (I2C_BUS_MAX > 3) - case 3: - return (struct i2c *)I2C_BASE4; - break; -#if (I2C_BUS_MAX > 4) - case 4: - return (struct i2c *)I2C_BASE5; - break; -#endif -#endif -#endif - default: - printf("wrong hwadapnr: %d\n", adap->hwadapnr); - break; - } - return NULL; -} - -#if !defined(CONFIG_SYS_OMAP24_I2C_SPEED1) -#define CONFIG_SYS_OMAP24_I2C_SPEED1 CONFIG_SYS_OMAP24_I2C_SPEED -#endif -#if !defined(CONFIG_SYS_OMAP24_I2C_SLAVE1) -#define CONFIG_SYS_OMAP24_I2C_SLAVE1 CONFIG_SYS_OMAP24_I2C_SLAVE -#endif - -U_BOOT_I2C_ADAP_COMPLETE(omap24_0, omap24_i2c_init, omap24_i2c_probe, - omap24_i2c_read, omap24_i2c_write, omap24_i2c_setspeed, - CONFIG_SYS_OMAP24_I2C_SPEED, - CONFIG_SYS_OMAP24_I2C_SLAVE, - 0) -U_BOOT_I2C_ADAP_COMPLETE(omap24_1, omap24_i2c_init, omap24_i2c_probe, - omap24_i2c_read, omap24_i2c_write, omap24_i2c_setspeed, - CONFIG_SYS_OMAP24_I2C_SPEED1, - CONFIG_SYS_OMAP24_I2C_SLAVE1, - 1) -#if (I2C_BUS_MAX > 2) -#if !defined(CONFIG_SYS_OMAP24_I2C_SPEED2) -#define CONFIG_SYS_OMAP24_I2C_SPEED2 CONFIG_SYS_OMAP24_I2C_SPEED -#endif -#if !defined(CONFIG_SYS_OMAP24_I2C_SLAVE2) -#define CONFIG_SYS_OMAP24_I2C_SLAVE2 CONFIG_SYS_OMAP24_I2C_SLAVE -#endif - -U_BOOT_I2C_ADAP_COMPLETE(omap24_2, omap24_i2c_init, omap24_i2c_probe, - omap24_i2c_read, omap24_i2c_write, NULL, - CONFIG_SYS_OMAP24_I2C_SPEED2, - CONFIG_SYS_OMAP24_I2C_SLAVE2, - 2) -#if (I2C_BUS_MAX > 3) -#if !defined(CONFIG_SYS_OMAP24_I2C_SPEED3) -#define CONFIG_SYS_OMAP24_I2C_SPEED3 CONFIG_SYS_OMAP24_I2C_SPEED -#endif -#if !defined(CONFIG_SYS_OMAP24_I2C_SLAVE3) -#define CONFIG_SYS_OMAP24_I2C_SLAVE3 CONFIG_SYS_OMAP24_I2C_SLAVE -#endif - -U_BOOT_I2C_ADAP_COMPLETE(omap24_3, omap24_i2c_init, omap24_i2c_probe, - omap24_i2c_read, omap24_i2c_write, NULL, - CONFIG_SYS_OMAP24_I2C_SPEED3, - CONFIG_SYS_OMAP24_I2C_SLAVE3, - 3) -#if (I2C_BUS_MAX > 4) -#if !defined(CONFIG_SYS_OMAP24_I2C_SPEED4) -#define CONFIG_SYS_OMAP24_I2C_SPEED4 CONFIG_SYS_OMAP24_I2C_SPEED -#endif -#if !defined(CONFIG_SYS_OMAP24_I2C_SLAVE4) -#define CONFIG_SYS_OMAP24_I2C_SLAVE4 CONFIG_SYS_OMAP24_I2C_SLAVE -#endif - -U_BOOT_I2C_ADAP_COMPLETE(omap24_4, omap24_i2c_init, omap24_i2c_probe, - omap24_i2c_read, omap24_i2c_write, NULL, - CONFIG_SYS_OMAP24_I2C_SPEED4, - CONFIG_SYS_OMAP24_I2C_SLAVE4, - 4) -#endif -#endif -#endif -#endif - -#ifdef CONFIG_DM_I2C static int omap24_i2c_xfer(struct udevice *adap, struct i2c_msg *msg, int nmsgs) { @@ -996,4 +876,3 @@ U_BOOT_DRIVER(omap_i2c) = { .priv_auto_alloc_size = sizeof(struct omap24_i2c_bus), .ops = &omap24_i2c_ops, }; -#endif diff --git a/drivers/i2c/omap24xx_i2c.h b/drivers/i2c/omap24xx_i2c.h deleted file mode 100644 index 3dae295..0000000 --- a/drivers/i2c/omap24xx_i2c.h +++ /dev/null @@ -1,154 +0,0 @@ -/* - * (C) Copyright 2004-2010 - * Texas Instruments, <www.ti.com <http://www.ti.com>> - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef _OMAP2PLUS_I2C_H_ -#define _OMAP2PLUS_I2C_H_ - -/* I2C masks */ - -/* I2C Interrupt Enable Register (I2C_IE): */ -#define I2C_IE_GC_IE (1 << 5) -#define I2C_IE_XRDY_IE (1 << 4) /* Transmit data ready interrupt enable */ -#define I2C_IE_RRDY_IE (1 << 3) /* Receive data ready interrupt enable */ -#define I2C_IE_ARDY_IE (1 << 2) /* Register access ready interrupt enable */ -#define I2C_IE_NACK_IE (1 << 1) /* No acknowledgment interrupt enable */ -#define I2C_IE_AL_IE (1 << 0) /* Arbitration lost interrupt enable */ - -/* I2C Status Register (I2C_STAT): */ - -#define I2C_STAT_SBD (1 << 15) /* Single byte data */ -#define I2C_STAT_BB (1 << 12) /* Bus busy */ -#define I2C_STAT_ROVR (1 << 11) /* Receive overrun */ -#define I2C_STAT_XUDF (1 << 10) /* Transmit underflow */ -#define I2C_STAT_AAS (1 << 9) /* Address as slave */ -#define I2C_STAT_GC (1 << 5) -#define I2C_STAT_XRDY (1 << 4) /* Transmit data ready */ -#define I2C_STAT_RRDY (1 << 3) /* Receive data ready */ -#define I2C_STAT_ARDY (1 << 2) /* Register access ready */ -#define I2C_STAT_NACK (1 << 1) /* No acknowledgment interrupt enable */ -#define I2C_STAT_AL (1 << 0) /* Arbitration lost interrupt enable */ - -/* I2C Interrupt Code Register (I2C_INTCODE): */ - -#define I2C_INTCODE_MASK 7 -#define I2C_INTCODE_NONE 0 -#define I2C_INTCODE_AL 1 /* Arbitration lost */ -#define I2C_INTCODE_NAK 2 /* No acknowledgement/general call */ -#define I2C_INTCODE_ARDY 3 /* Register access ready */ -#define I2C_INTCODE_RRDY 4 /* Rcv data ready */ -#define I2C_INTCODE_XRDY 5 /* Xmit data ready */ - -/* I2C Buffer Configuration Register (I2C_BUF): */ - -#define I2C_BUF_RDMA_EN (1 << 15) /* Receive DMA channel enable */ -#define I2C_BUF_XDMA_EN (1 << 7) /* Transmit DMA channel enable */ - -/* I2C Configuration Register (I2C_CON): */ - -#define I2C_CON_EN (1 << 15) /* I2C module enable */ -#define I2C_CON_BE (1 << 14) /* Big endian mode */ -#define I2C_CON_STB (1 << 11) /* Start byte mode (master mode only) */ -#define I2C_CON_MST (1 << 10) /* Master/slave mode */ -#define I2C_CON_TRX (1 << 9) /* Transmitter/receiver mode */ - /* (master mode only) */ -#define I2C_CON_XA (1 << 8) /* Expand address */ -#define I2C_CON_STP (1 << 1) /* Stop condition (master mode only) */ -#define I2C_CON_STT (1 << 0) /* Start condition (master mode only) */ - -/* I2C System Test Register (I2C_SYSTEST): */ - -#define I2C_SYSTEST_ST_EN (1 << 15) /* System test enable */ -#define I2C_SYSTEST_FREE (1 << 14) /* Free running mode, on brkpoint) */ -#define I2C_SYSTEST_TMODE_MASK (3 << 12) /* Test mode select */ -#define I2C_SYSTEST_TMODE_SHIFT (12) /* Test mode select */ -#define I2C_SYSTEST_SCL_I (1 << 3) /* SCL line sense input value */ -#define I2C_SYSTEST_SCL_O (1 << 2) /* SCL line drive output value */ -#define I2C_SYSTEST_SDA_I (1 << 1) /* SDA line sense input value */ -#define I2C_SYSTEST_SDA_O (1 << 0) /* SDA line drive output value */ - -/* I2C System Status Register (I2C_SYSS): */ - -#define I2C_SYSS_RDONE (1 << 0) /* Internel reset monitoring */ - -#define I2C_SCLL_SCLL 0 -#define I2C_SCLL_SCLL_M 0xFF -#define I2C_SCLL_HSSCLL 8 -#define I2C_SCLH_HSSCLL_M 0xFF -#define I2C_SCLH_SCLH 0 -#define I2C_SCLH_SCLH_M 0xFF -#define I2C_SCLH_HSSCLH 8 -#define I2C_SCLH_HSSCLH_M 0xFF - -#define OMAP_I2C_STANDARD 100000 -#define OMAP_I2C_FAST_MODE 400000 -#define OMAP_I2C_HIGH_SPEED 3400000 - -#define SYSTEM_CLOCK_12 12000000 -#define SYSTEM_CLOCK_13 13000000 -#define SYSTEM_CLOCK_192 19200000 -#define SYSTEM_CLOCK_96 96000000 - -/* Use the reference value of 96MHz if not explicitly set by the board */ -#ifndef I2C_IP_CLK -#define I2C_IP_CLK SYSTEM_CLOCK_96 -#endif - -/* - * The reference minimum clock for high speed is 19.2MHz. - * The linux 2.6.30 kernel uses this value. - * The reference minimum clock for fast mode is 9.6MHz - * The reference minimum clock for standard mode is 4MHz - * In TRM, the value of 12MHz is used. - */ -#ifndef I2C_INTERNAL_SAMPLING_CLK -#define I2C_INTERNAL_SAMPLING_CLK 19200000 -#endif - -/* - * The equation for the low and high time is - * tlow = scll + scll_trim = (sampling clock * tlow_duty) / speed - * thigh = sclh + sclh_trim = (sampling clock * (1 - tlow_duty)) / speed - * - * If the duty cycle is 50% - * - * tlow = scll + scll_trim = sampling clock / (2 * speed) - * thigh = sclh + sclh_trim = sampling clock / (2 * speed) - * - * In TRM - * scll_trim = 7 - * sclh_trim = 5 - * - * The linux 2.6.30 kernel uses - * scll_trim = 6 - * sclh_trim = 6 - * - * These are the trim values for standard and fast speed - */ -#ifndef I2C_FASTSPEED_SCLL_TRIM -#define I2C_FASTSPEED_SCLL_TRIM 6 -#endif -#ifndef I2C_FASTSPEED_SCLH_TRIM -#define I2C_FASTSPEED_SCLH_TRIM 6 -#endif - -/* These are the trim values for high speed */ -#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM -#define I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM -#endif -#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM -#define I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM -#endif -#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM -#define I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM -#endif -#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM -#define I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM -#endif - -#define I2C_PSC_MAX 0x0f -#define I2C_PSC_MIN 0x00 - -#endif /* _OMAP24XX_I2C_H_ */ -- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
Hello Richard,
Hi Simon,
This patchset tries to convert the TI omap24xx_i2c driver to Driver Model. It has been tested on a TI BeagleBoard xM.
Sorry for the very late reply ...
Seems this patchset got not applied, as I have it now in my ToDo list... I think, I thought it has to go through the DM subsystem ...
It does not apply clean anymore ... may you can rebase it against current ML ?
Thanks!
bye, Heiko
Best Regards Christophe
Christophe Ricard (5): i2c: omap24xx: Convert to DM i2c: omap24xx: Fix waitdelay value for I2C HS i2c: omap24xx: Remove unused I2C_WAIT macro i2c: omap24xx: Fix high speed trimming calculation i2c: omap24xx: Convert fully to DM_I2C
drivers/i2c/Kconfig | 8 + drivers/i2c/omap24xx_i2c.c | 395 ++++++++++++++++++++++++++++++--------------- drivers/i2c/omap24xx_i2c.h | 154 ------------------ 3 files changed, 276 insertions(+), 281 deletions(-) delete mode 100644 drivers/i2c/omap24xx_i2c.h
Christophe Ricard
Heiko Schocher
