[PATCH v2 0/5] arm: mach-k3: Fixes for j721e/j7200 clock data and drivers
Hi, This is v2 of series with fixes for TI j721e and j7200 platforms data and also some fixes for TI clock drivers that make use of this data.
Updates are to patch 3 to address comments from Lokesh and Suman. Patch 3 now contains a note with contact for issues with autogenerated files, http->https in URLs, and an extra blank line before first header.
As with v1, all fixes are related to PLL post dividers reporting the wrong frequency, and now the new frequencies for below clocks match what registers are actually configured for.
Clock: Old Frequency -> New Frequency ----------------------------------------- postdiv2_16fft_main_0_hsdivout6_clk: 66666667 -> 200000000 postdiv2_16fft_main_1_hsdivout5_clk: 320000000 -> 960000000 postdiv2_16fft_main_1_hsdivout7_clk: 320000000 -> 960000000
Regards, Dave
[v1] https://patchwork.ozlabs.org/project/uboot/list/?series=257518
Dave Gerlach (2): arm: mach-k3: Add note to auto-generated files clk: ti: k3-pll: Change DIV_CTRL programming to read-modify-write
Suman Anna (3): arm: mach-k3: j721e: Fix clk-data parenting for postdiv PLL clocks arm: mach-k3: j7200: Fix clk-data parenting for postdiv PLL clocks clk: ti: k3: Update driver to account for divider flags
arch/arm/mach-k3/j7200/clk-data.c | 91 ++++++++++++----------- arch/arm/mach-k3/j7200/dev-data.c | 6 +- arch/arm/mach-k3/j721e/clk-data.c | 117 ++++++++++++++++-------------- arch/arm/mach-k3/j721e/dev-data.c | 6 +- drivers/clk/ti/clk-k3-pll.c | 13 +++- drivers/clk/ti/clk-k3.c | 4 +- include/k3-clk.h | 30 ++++---- 7 files changed, 149 insertions(+), 118 deletions(-)
The TI K3 Fractional PLLs use two programmable POSTDIV1 and POSTDIV2 divisors to generate the final FOUTPOSTDIV clock. These are in sequence with POSTDIV2 following the POSTDIV1 clock. The current J721E clock data has the POSTDIV2 clock as the parent for the POSTDIV1 clock, which is opposite of the actual implementation. Fix the data by simply adjusting the register bit-shifts.
The Main PLL1 POSTDIV clocks were also defined incorrectly using Main PLL0 register values, fix these as well.
Fixes: 277729eaf373 ("arm: mach-k3: Add platform data for j721e and j7200") Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Dave Gerlach d-gerlach@ti.com --- arch/arm/mach-k3/j721e/clk-data.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-k3/j721e/clk-data.c b/arch/arm/mach-k3/j721e/clk-data.c index 953ac457130b..ff9262d7bcee 100644 --- a/arch/arm/mach-k3/j721e/clk-data.c +++ b/arch/arm/mach-k3/j721e/clk-data.c @@ -463,8 +463,8 @@ static const struct clk_data clk_list[] = { CLK_MUX("wkup_fref_clksel_out0", wkup_fref_clksel_out0_parents, 2, 0x43008050, 8, 1, 0), CLK_MUX("main_pll_hfosc_sel_out1", main_pll_hfosc_sel_out1_parents, 2, 0x43008084, 0, 1, 0), CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_main_1_foutvcop_clk", "main_pll_hfosc_sel_out1", 0x681000, 0, 1920000000), - CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x680038, 24, 3, 0), - CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x681038, 16, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x681038, 24, 3, 0), CLK_PLL("pllfrac2_ssmod_16fft_mcu_0_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d00000, 0), CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d01000, 0, 2400000000), CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d02000, 0, 2000000000), @@ -523,8 +523,8 @@ static const struct clk_data clk_list[] = { CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout3_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d0208c, 0, 7, 0), CLK_FIXED_RATE("j7_wakeup_16ff_wkup_0_wkup_rcosc_32k_clk", 32000, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_0_foutvcop_clk", "main_pll_hfosc_sel_out0", 0x680000, 0), - CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 24, 3, 0), - CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 16, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 24, 3, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_13_foutvcop_clk", "main_pll_hfosc_sel_out13", 0x68d000, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_14_foutvcop_clk", "main_pll_hfosc_sel_out14", 0x68e000, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_16_foutvcop_clk", "main_pll_hfosc_sel_out16", 0x690000, 0),
The TI K3 Fractional PLLs use two programmable POSTDIV1 and POSTDIV2 divisors to generate the final FOUTPOSTDIV clock. These are in sequence with POSTDIV2 following the POSTDIV1 clock. The current J7200 clock data has the POSTDIV2 clock as the parent for the POSTDIV1 clock, which is opposite of the actual implementation. Fix the data by simply adjusting the register bit-shifts.
Fixes: 277729eaf373 ("arm: mach-k3: Add platform data for j721e and j7200") Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Dave Gerlach d-gerlach@ti.com --- arch/arm/mach-k3/j7200/clk-data.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-k3/j7200/clk-data.c b/arch/arm/mach-k3/j7200/clk-data.c index 93c067079ab6..49145bbfc8cd 100644 --- a/arch/arm/mach-k3/j7200/clk-data.c +++ b/arch/arm/mach-k3/j7200/clk-data.c @@ -319,8 +319,8 @@ static const struct clk_data clk_list[] = { CLK_MUX("wkup_fref_clksel_out0", wkup_fref_clksel_out0_parents, 2, 0x43008050, 8, 1, 0), CLK_MUX("main_pll_hfosc_sel_out1", main_pll_hfosc_sel_out1_parents, 2, 0x43008084, 0, 1, 0), CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_main_1_foutvcop_clk", "main_pll_hfosc_sel_out1", 0x681000, 0, 1920000000), - CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x680038, 24, 3, 0), - CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681038, 16, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x681038, 24, 3, 0), CLK_PLL("pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d00000, 0), CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d01000, 0, 2400000000), CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d02000, 0, 2000000000), @@ -360,8 +360,8 @@ static const struct clk_data clk_list[] = { CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout2_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02088, 0, 7, 0), CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout3_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d0208c, 0, 7, 0), CLK_PLL("pllfracf_ssmod_16fft_main_0_foutvcop_clk", "main_pll_hfosc_sel_out0", 0x680000, 0), - CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 24, 3, 0), - CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 16, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 24, 3, 0), CLK_PLL("pllfracf_ssmod_16fft_main_12_foutvcop_clk", "main_pll_hfosc_sel_out12", 0x68c000, 0), CLK_PLL("pllfracf_ssmod_16fft_main_14_foutvcop_clk", "main_pll_hfosc_sel_out14", 0x68e000, 0), CLK_PLL("pllfracf_ssmod_16fft_main_2_foutvcop_clk", "main_pll_hfosc_sel_out2", 0x682000, 0),
Add a note to the automatically generated clk-data and dev-data files for j721e and j7200 to indicate that they are in fact auto-generated and should not be hand edited.
Also adjust TI URL to use https instead of http and also add an empty line before first header inclusion.
Signed-off-by: Dave Gerlach d-gerlach@ti.com --- arch/arm/mach-k3/j7200/clk-data.c | 6 +++++- arch/arm/mach-k3/j7200/dev-data.c | 6 +++++- arch/arm/mach-k3/j721e/clk-data.c | 6 +++++- arch/arm/mach-k3/j721e/dev-data.c | 6 +++++- 4 files changed, 20 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-k3/j7200/clk-data.c b/arch/arm/mach-k3/j7200/clk-data.c index 49145bbfc8cd..7e55e48b923d 100644 --- a/arch/arm/mach-k3/j7200/clk-data.c +++ b/arch/arm/mach-k3/j7200/clk-data.c @@ -2,8 +2,12 @@ /* * J7200 specific clock platform data * - * Copyright (C) 2020-2021 Texas Instruments Incorporated - http://www.ti.com/ + * This file is auto generated. Please do not hand edit and report any issues + * to Dave Gerlach d-gerlach@ti.com. + * + * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ */ + #include "k3-clk.h"
static const char * const gluelogic_hfosc0_clkout_parents[] = { diff --git a/arch/arm/mach-k3/j7200/dev-data.c b/arch/arm/mach-k3/j7200/dev-data.c index c68bcc58e9a7..d3194ae51a93 100644 --- a/arch/arm/mach-k3/j7200/dev-data.c +++ b/arch/arm/mach-k3/j7200/dev-data.c @@ -2,8 +2,12 @@ /* * J7200 specific device platform data * - * Copyright (C) 2020-2021 Texas Instruments Incorporated - http://www.ti.com/ + * This file is auto generated. Please do not hand edit and report any issues + * to Dave Gerlach d-gerlach@ti.com. + * + * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ */ + #include "k3-dev.h"
static struct ti_psc soc_psc_list[] = { diff --git a/arch/arm/mach-k3/j721e/clk-data.c b/arch/arm/mach-k3/j721e/clk-data.c index ff9262d7bcee..878b27a49aba 100644 --- a/arch/arm/mach-k3/j721e/clk-data.c +++ b/arch/arm/mach-k3/j721e/clk-data.c @@ -2,8 +2,12 @@ /* * J721E specific clock platform data * - * Copyright (C) 2020-2021 Texas Instruments Incorporated - http://www.ti.com/ + * This file is auto generated. Please do not hand edit and report any issues + * to Dave Gerlach d-gerlach@ti.com. + * + * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ */ + #include "k3-clk.h"
static const char * const gluelogic_hfosc0_clkout_parents[] = { diff --git a/arch/arm/mach-k3/j721e/dev-data.c b/arch/arm/mach-k3/j721e/dev-data.c index 96393c713278..300d998c6260 100644 --- a/arch/arm/mach-k3/j721e/dev-data.c +++ b/arch/arm/mach-k3/j721e/dev-data.c @@ -2,8 +2,12 @@ /* * J721E specific device platform data * - * Copyright (C) 2020-2021 Texas Instruments Incorporated - http://www.ti.com/ + * This file is auto generated. Please do not hand edit and report any issues + * to Dave Gerlach d-gerlach@ti.com. + * + * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ */ + #include "k3-dev.h"
There are three different divider values in the DIV_CTRL register controlled by the k3-pll driver. Currently the ti_pll_clk_set_rate function writes the entire register when programming plld, even though plld only resides in the lower 6 bits.
Change the plld programming to read-modify-write to only affect the relevant bits for plld and to preserve the other two divider values present in the upper 16 bits, otherwise they will always get set to zero when programming plld.
Fixes: 0aa2930ca192 ("clk: add support for TI K3 SoC PLL") Signed-off-by: Dave Gerlach d-gerlach@ti.com --- drivers/clk/ti/clk-k3-pll.c | 13 +++++++++++-- 1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/drivers/clk/ti/clk-k3-pll.c b/drivers/clk/ti/clk-k3-pll.c index bf2407a020a3..bf762c558ef0 100644 --- a/drivers/clk/ti/clk-k3-pll.c +++ b/drivers/clk/ti/clk-k3-pll.c @@ -2,7 +2,7 @@ /* * Texas Instruments K3 SoC PLL clock driver * - * Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/ + * Copyright (C) 2020-2021 Texas Instruments Incorporated - http://www.ti.com/ * Tero Kristo t-kristo@ti.com */
@@ -122,6 +122,7 @@ static ulong ti_pll_clk_set_rate(struct clk *clk, ulong rate) unsigned long pllm; u32 pllfm = 0; unsigned long plld; + u32 div_ctrl; u32 rem; int shift;
@@ -175,7 +176,15 @@ static ulong ti_pll_clk_set_rate(struct clk *clk, ulong rate)
writel(pllm, pll->reg + PLL_16FFT_FREQ_CTRL0); writel(pllfm, pll->reg + PLL_16FFT_FREQ_CTRL1); - writel(plld, pll->reg + PLL_16FFT_DIV_CTRL); + + /* + * div_ctrl register contains other divider values, so rmw + * only plld and leave existing values alone + */ + div_ctrl = readl(pll->reg + PLL_16FFT_DIV_CTRL); + div_ctrl &= ~PLL_16FFT_DIV_CTRL_REF_DIV_MASK; + div_ctrl |= plld; + writel(div_ctrl, pll->reg + PLL_16FFT_DIV_CTRL);
ctrl &= ~PLL_16FFT_CTRL_BYPASS_EN; ctrl |= PLL_16FFT_CTRL_PLL_EN;
The K3 SoCs have some PLL output clocks (POSTDIV clocks) which in turn serve as inputs to other HSDIV output clocks. These clocks use the actual value to compute the divider clock rate, and need to be registered with the CLK_DIVIDER_ONE_BASED flags. The current k3-clk driver and data lacks the infrastructure to pass in divider flags. Update the driver and data to account for these divider flags.
Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Dave Gerlach d-gerlach@ti.com --- arch/arm/mach-k3/j7200/clk-data.c | 85 ++++++++++++----------- arch/arm/mach-k3/j721e/clk-data.c | 111 +++++++++++++++--------------- drivers/clk/ti/clk-k3.c | 4 +- include/k3-clk.h | 30 ++++---- 4 files changed, 118 insertions(+), 112 deletions(-)
diff --git a/arch/arm/mach-k3/j7200/clk-data.c b/arch/arm/mach-k3/j7200/clk-data.c index 7e55e48b923d..0437e30abb4f 100644 --- a/arch/arm/mach-k3/j7200/clk-data.c +++ b/arch/arm/mach-k3/j7200/clk-data.c @@ -8,6 +8,7 @@ * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ */
+#include <linux/clk-provider.h> #include "k3-clk.h"
static const char * const gluelogic_hfosc0_clkout_parents[] = { @@ -323,18 +324,18 @@ static const struct clk_data clk_list[] = { CLK_MUX("wkup_fref_clksel_out0", wkup_fref_clksel_out0_parents, 2, 0x43008050, 8, 1, 0), CLK_MUX("main_pll_hfosc_sel_out1", main_pll_hfosc_sel_out1_parents, 2, 0x43008084, 0, 1, 0), CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_main_1_foutvcop_clk", "main_pll_hfosc_sel_out1", 0x681000, 0, 1920000000), - CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681038, 16, 3, 0), - CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x681038, 24, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681038, 16, 3, 0, CLK_DIVIDER_ONE_BASED), + CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x681038, 24, 3, 0, CLK_DIVIDER_ONE_BASED), CLK_PLL("pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d00000, 0), CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d01000, 0, 2400000000), CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d02000, 0, 2000000000), - CLK_DIV("postdiv2_16fft_main_1_hsdivout5_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", 0x681094, 0, 7, 0), - CLK_DIV("hsdiv1_16fft_mcu_0_hsdivout0_clk", "pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", 0x40d00080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout3_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d0108c, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout4_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01090, 0, 7, 0), - CLK_DIV_DEFFREQ("hsdiv4_16fft_mcu_2_hsdivout4_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02090, 0, 7, 0, 166666666), + CLK_DIV("postdiv2_16fft_main_1_hsdivout5_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", 0x681094, 0, 7, 0, 0), + CLK_DIV("hsdiv1_16fft_mcu_0_hsdivout0_clk", "pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", 0x40d00080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout3_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d0108c, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout4_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01090, 0, 7, 0, 0), + CLK_DIV_DEFFREQ("hsdiv4_16fft_mcu_2_hsdivout4_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02090, 0, 7, 0, 0, 166666666), CLK_MUX_PLLCTRL("k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", k3_pll_ctrl_wrap_wkup_0_sysclkout_clk_parents, 2, 0x42010000, 0), - CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x42010118, 0, 5, 0), + CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x42010118, 0, 5, 0, 0), CLK_MUX("mcu_ospi_ref_clk_sel_out0", mcu_ospi_ref_clk_sel_out0_parents, 2, 0x40f08030, 0, 1, 0), CLK_MUX("mcuusart_clk_sel_out0", mcuusart_clk_sel_out0_parents, 2, 0x40f081c0, 0, 1, 0), CLK_MUX("wkup_gpio0_clksel_out0", wkup_gpio0_clksel_out0_parents, 4, 0x43008070, 0, 2, 0), @@ -355,46 +356,46 @@ static const struct clk_data clk_list[] = { CLK_FIXED_RATE("board_0_mcu_i2c0_scl_out", 0, 0), CLK_FIXED_RATE("board_0_wkup_lf_clkin_out", 0, 0), CLK_FIXED_RATE("emmcsd4ss_main_0_emmcsdss_io_clk_o", 0, 0), - CLK_DIV_DEFFREQ("hsdiv4_16fft_main_1_hsdivout0_clk", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681080, 0, 7, 0, 192000000), - CLK_DIV("hsdiv4_16fft_main_1_hsdivout2_clk", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681088, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout1_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01084, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout2_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01088, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout0_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout1_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02084, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout2_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02088, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout3_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d0208c, 0, 7, 0), + CLK_DIV_DEFFREQ("hsdiv4_16fft_main_1_hsdivout0_clk", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681080, 0, 7, 0, 0, 192000000), + CLK_DIV("hsdiv4_16fft_main_1_hsdivout2_clk", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout1_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout2_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout0_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout1_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout2_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout3_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d0208c, 0, 7, 0, 0), CLK_PLL("pllfracf_ssmod_16fft_main_0_foutvcop_clk", "main_pll_hfosc_sel_out0", 0x680000, 0), - CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 16, 3, 0), - CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 24, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 16, 3, 0, CLK_DIVIDER_ONE_BASED), + CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 24, 3, 0, CLK_DIVIDER_ONE_BASED), CLK_PLL("pllfracf_ssmod_16fft_main_12_foutvcop_clk", "main_pll_hfosc_sel_out12", 0x68c000, 0), CLK_PLL("pllfracf_ssmod_16fft_main_14_foutvcop_clk", "main_pll_hfosc_sel_out14", 0x68e000, 0), CLK_PLL("pllfracf_ssmod_16fft_main_2_foutvcop_clk", "main_pll_hfosc_sel_out2", 0x682000, 0), CLK_PLL("pllfracf_ssmod_16fft_main_3_foutvcop_clk", "main_pll_hfosc_sel_out3", 0x683000, 0), CLK_PLL("pllfracf_ssmod_16fft_main_7_foutvcop_clk", "main_pll_hfosc_sel_out7", 0x687000, 0), CLK_PLL("pllfracf_ssmod_16fft_main_8_foutvcop_clk", "main_pll_hfosc_sel_out8", 0x688000, 0), - CLK_DIV("postdiv2_16fft_main_0_hsdivout6_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", 0x680098, 0, 7, 0), - CLK_DIV("postdiv2_16fft_main_1_hsdivout7_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", 0x68109c, 0, 7, 0), + CLK_DIV("postdiv2_16fft_main_0_hsdivout6_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", 0x680098, 0, 7, 0, 0), + CLK_DIV("postdiv2_16fft_main_1_hsdivout7_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", 0x68109c, 0, 7, 0, 0), CLK_MUX("wkup_obsclk_mux_out0", wkup_obsclk_mux_out0_parents, 16, 0x43008000, 0, 4, 0), CLK_MUX("main_pll4_xref_sel_out0", main_pll4_xref_sel_out0_parents, 2, 0x43008090, 4, 1, 0), CLK_MUX("mcu_clkout_mux_out0", mcu_clkout_mux_out0_parents, 2, 0x40f08010, 0, 1, 0), - CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out0", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x1081c0, 0, 2, 0, 48000000), - CLK_DIV("hsdiv0_16fft_main_12_hsdivout0_clk", "pllfracf_ssmod_16fft_main_12_foutvcop_clk", 0x68c080, 0, 7, 0), - CLK_DIV("hsdiv0_16fft_main_7_hsdivout0_clk", "pllfracf_ssmod_16fft_main_7_foutvcop_clk", 0x687080, 0, 7, 0), - CLK_DIV("hsdiv0_16fft_main_8_hsdivout0_clk", "pllfracf_ssmod_16fft_main_8_foutvcop_clk", 0x688080, 0, 7, 0), - CLK_DIV("hsdiv1_16fft_main_14_hsdivout0_clk", "pllfracf_ssmod_16fft_main_14_foutvcop_clk", 0x68e080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_0_hsdivout0_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_0_hsdivout1_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680084, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_0_hsdivout2_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680088, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_0_hsdivout3_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x68008c, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_0_hsdivout4_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680090, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_2_hsdivout0_clk", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_2_hsdivout1_clk", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682084, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_3_hsdivout0_clk", "pllfracf_ssmod_16fft_main_3_foutvcop_clk", 0x683080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_3_hsdivout1_clk", "pllfracf_ssmod_16fft_main_3_foutvcop_clk", 0x683084, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_3_hsdivout2_clk", "pllfracf_ssmod_16fft_main_3_foutvcop_clk", 0x683088, 0, 7, 0), + CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out0", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x1081c0, 0, 2, 0, 0, 48000000), + CLK_DIV("hsdiv0_16fft_main_12_hsdivout0_clk", "pllfracf_ssmod_16fft_main_12_foutvcop_clk", 0x68c080, 0, 7, 0, 0), + CLK_DIV("hsdiv0_16fft_main_7_hsdivout0_clk", "pllfracf_ssmod_16fft_main_7_foutvcop_clk", 0x687080, 0, 7, 0, 0), + CLK_DIV("hsdiv0_16fft_main_8_hsdivout0_clk", "pllfracf_ssmod_16fft_main_8_foutvcop_clk", 0x688080, 0, 7, 0, 0), + CLK_DIV("hsdiv1_16fft_main_14_hsdivout0_clk", "pllfracf_ssmod_16fft_main_14_foutvcop_clk", 0x68e080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout0_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout1_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout2_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout3_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x68008c, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout4_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680090, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout0_clk", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout1_clk", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout0_clk", "pllfracf_ssmod_16fft_main_3_foutvcop_clk", 0x683080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout1_clk", "pllfracf_ssmod_16fft_main_3_foutvcop_clk", 0x683084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout2_clk", "pllfracf_ssmod_16fft_main_3_foutvcop_clk", 0x683088, 0, 7, 0, 0), CLK_MUX_PLLCTRL("k3_pll_ctrl_wrap_main_0_sysclkout_clk", k3_pll_ctrl_wrap_main_0_sysclkout_clk_parents, 2, 0x410000, 0), - CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x410118, 0, 5, 0), - CLK_DIV("mcu_obsclk_div_out0", "wkup_obsclk_mux_out0", 0x43008000, 8, 4, 0), + CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x410118, 0, 5, 0, 0), + CLK_DIV("mcu_obsclk_div_out0", "wkup_obsclk_mux_out0", 0x43008000, 8, 4, 0, 0), CLK_MUX("mcu_obsclk_outmux_out0", mcu_obsclk_outmux_out0_parents, 2, 0x43008000, 24, 1, 0), CLK_PLL("pllfracf_ssmod_16fft_main_4_foutvcop_clk", "main_pll4_xref_sel_out0", 0x684000, 0), CLK_MUX("clkout_mux_out0", clkout_mux_out0_parents, 2, 0x108010, 0, 1, 0), @@ -403,14 +404,14 @@ static const struct clk_data clk_list[] = { CLK_MUX("gtc_clk_mux_out0", gtc_clk_mux_out0_parents, 16, 0x108030, 0, 4, 0), CLK_MUX("obsclk1_mux_out0", obsclk1_mux_out0_parents, 4, 0x108004, 0, 2, 0), CLK_MUX("gpmc_fclk_sel_out0", gpmc_fclk_sel_out0_parents, 4, 0x1080d0, 0, 2, 0), - CLK_DIV("hsdiv2_16fft_main_4_hsdivout0_clk", "pllfracf_ssmod_16fft_main_4_foutvcop_clk", 0x684080, 0, 7, 0), - CLK_DIV("hsdiv2_16fft_main_4_hsdivout2_clk", "pllfracf_ssmod_16fft_main_4_foutvcop_clk", 0x684088, 0, 7, 0), + CLK_DIV("hsdiv2_16fft_main_4_hsdivout0_clk", "pllfracf_ssmod_16fft_main_4_foutvcop_clk", 0x684080, 0, 7, 0, 0), + CLK_DIV("hsdiv2_16fft_main_4_hsdivout2_clk", "pllfracf_ssmod_16fft_main_4_foutvcop_clk", 0x684088, 0, 7, 0, 0), CLK_MUX("audio_refclko_mux_out0", audio_refclko_mux_out0_parents, 32, 0x1082e0, 0, 5, 0), CLK_MUX("audio_refclko_mux_out1", audio_refclko_mux_out1_parents, 32, 0x1082e4, 0, 5, 0), CLK_MUX("obsclk0_mux_out0", obsclk0_mux_out0_parents, 32, 0x108000, 0, 5, 0), - CLK_DIV("osbclk0_div_out0", "obsclk0_mux_out0", 0x108000, 8, 8, 0), - CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x41011c, 0, 5, 0), - CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x4201011c, 0, 5, 0), + CLK_DIV("osbclk0_div_out0", "obsclk0_mux_out0", 0x108000, 8, 8, 0, 0), + CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x41011c, 0, 5, 0, 0), + CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x4201011c, 0, 5, 0, 0), };
static const struct dev_clk soc_dev_clk_data[] = { diff --git a/arch/arm/mach-k3/j721e/clk-data.c b/arch/arm/mach-k3/j721e/clk-data.c index 878b27a49aba..5ab795139e1d 100644 --- a/arch/arm/mach-k3/j721e/clk-data.c +++ b/arch/arm/mach-k3/j721e/clk-data.c @@ -8,6 +8,7 @@ * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ */
static const char * const gluelogic_hfosc0_clkout_parents[] = { @@ -467,18 +468,18 @@ static const struct clk_data clk_list[] = { CLK_MUX("wkup_fref_clksel_out0", wkup_fref_clksel_out0_parents, 2, 0x43008050, 8, 1, 0), CLK_MUX("main_pll_hfosc_sel_out1", main_pll_hfosc_sel_out1_parents, 2, 0x43008084, 0, 1, 0), CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_main_1_foutvcop_clk", "main_pll_hfosc_sel_out1", 0x681000, 0, 1920000000), - CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x681038, 16, 3, 0), - CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x681038, 24, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x681038, 16, 3, 0, CLK_DIVIDER_ONE_BASED), + CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x681038, 24, 3, 0, CLK_DIVIDER_ONE_BASED), CLK_PLL("pllfrac2_ssmod_16fft_mcu_0_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d00000, 0), CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d01000, 0, 2400000000), CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d02000, 0, 2000000000), - CLK_DIV("postdiv3_16fft_main_1_hsdivout5_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", 0x681094, 0, 7, 0), - CLK_DIV("hsdiv1_16fft_mcu_0_hsdivout0_clk", "pllfrac2_ssmod_16fft_mcu_0_foutvcop_clk", 0x40d00080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout3_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d0108c, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout4_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01090, 0, 7, 0), - CLK_DIV_DEFFREQ("hsdiv4_16fft_mcu_2_hsdivout4_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02090, 0, 7, 0, 166666666), + CLK_DIV("postdiv3_16fft_main_1_hsdivout5_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", 0x681094, 0, 7, 0, 0), + CLK_DIV("hsdiv1_16fft_mcu_0_hsdivout0_clk", "pllfrac2_ssmod_16fft_mcu_0_foutvcop_clk", 0x40d00080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout3_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d0108c, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout4_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01090, 0, 7, 0, 0), + CLK_DIV_DEFFREQ("hsdiv4_16fft_mcu_2_hsdivout4_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02090, 0, 7, 0, 0, 166666666), CLK_MUX_PLLCTRL("k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", k3_pll_ctrl_wrap_wkup_0_sysclkout_clk_parents, 2, 0x42010000, 0), - CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x42010118, 0, 5, 0), + CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x42010118, 0, 5, 0, 0), CLK_MUX("mcu_ospi_ref_clk_sel_out0", mcu_ospi_ref_clk_sel_out0_parents, 2, 0x40f08030, 0, 1, 0), CLK_MUX("mcu_ospi_ref_clk_sel_out1", mcu_ospi_ref_clk_sel_out1_parents, 2, 0x40f08034, 0, 1, 0), CLK_MUX("mcuusart_clk_sel_out0", mcuusart_clk_sel_out0_parents, 2, 0x40f081c0, 0, 1, 0), @@ -517,18 +518,18 @@ static const struct clk_data clk_list[] = { CLK_FIXED_RATE("ddr32ss_16ffc_ew_dv_wrap_main_0_ddrss_io_ck_n", 0, 0), CLK_FIXED_RATE("emmc8ss_16ffc_main_0_emmcss_io_clk", 0, 0), CLK_FIXED_RATE("emmcsd4ss_main_0_emmcsdss_io_clk_o", 0, 0), - CLK_DIV_DEFFREQ("hsdiv4_16fft_main_1_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x681080, 0, 7, 0, 192000000), - CLK_DIV("hsdiv4_16fft_main_1_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x681088, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout1_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01084, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout2_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01088, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout0_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout1_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02084, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout2_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02088, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout3_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d0208c, 0, 7, 0), + CLK_DIV_DEFFREQ("hsdiv4_16fft_main_1_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x681080, 0, 7, 0, 0, 192000000), + CLK_DIV("hsdiv4_16fft_main_1_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x681088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout1_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout2_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout0_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout1_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout2_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout3_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d0208c, 0, 7, 0, 0), CLK_FIXED_RATE("j7_wakeup_16ff_wkup_0_wkup_rcosc_32k_clk", 32000, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_0_foutvcop_clk", "main_pll_hfosc_sel_out0", 0x680000, 0), - CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 16, 3, 0), - CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 24, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 16, 3, 0, CLK_DIVIDER_ONE_BASED), + CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 24, 3, 0, CLK_DIVIDER_ONE_BASED), CLK_PLL("pllfrac2_ssmod_16fft_main_13_foutvcop_clk", "main_pll_hfosc_sel_out13", 0x68d000, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_14_foutvcop_clk", "main_pll_hfosc_sel_out14", 0x68e000, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_16_foutvcop_clk", "main_pll_hfosc_sel_out16", 0x690000, 0), @@ -544,41 +545,41 @@ static const struct clk_data clk_list[] = { CLK_PLL("pllfrac2_ssmod_16fft_main_7_foutvcop_clk", "main_pll_hfosc_sel_out7", 0x687000, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_8_foutvcop_clk", "main_pll_hfosc_sel_out8", 0x688000, 0), CLK_PLL("pllfracf_ssmod_16fft_main_12_foutvcop_clk", "main_pll_hfosc_sel_out12", 0x68c000, 0), - CLK_DIV("postdiv3_16fft_main_0_hsdivout6_clk", "pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk", 0x680098, 0, 7, 0), - CLK_DIV("postdiv3_16fft_main_1_hsdivout7_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", 0x68109c, 0, 7, 0), + CLK_DIV("postdiv3_16fft_main_0_hsdivout6_clk", "pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk", 0x680098, 0, 7, 0, 0), + CLK_DIV("postdiv3_16fft_main_1_hsdivout7_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", 0x68109c, 0, 7, 0, 0), CLK_MUX("wkup_obsclk_mux_out0", wkup_obsclk_mux_out0_parents, 16, 0x43008000, 0, 4, 0), CLK_MUX("main_pll15_xref_sel_out0", main_pll15_xref_sel_out0_parents, 2, 0x430080bc, 4, 1, 0), CLK_MUX("main_pll24_hfosc_sel_out0", main_pll24_hfosc_sel_out0_parents, 2, 0x430080e0, 0, 1, 0), CLK_MUX("main_pll4_xref_sel_out0", main_pll4_xref_sel_out0_parents, 2, 0x43008090, 4, 1, 0), CLK_MUX("mcu_clkout_mux_out0", mcu_clkout_mux_out0_parents, 2, 0x40f08010, 0, 1, 0), - CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out0", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x1081c0, 0, 2, 0, 48000000), - CLK_DIV("hsdiv0_16fft_main_12_hsdivout0_clk", "pllfracf_ssmod_16fft_main_12_foutvcop_clk", 0x68c080, 0, 7, 0), - CLK_DIV("hsdiv0_16fft_main_6_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_6_foutvcop_clk", 0x686080, 0, 7, 0), - CLK_DIV("hsdiv0_16fft_main_7_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_7_foutvcop_clk", 0x687080, 0, 7, 0), - CLK_DIV("hsdiv0_16fft_main_8_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_8_foutvcop_clk", 0x688080, 0, 7, 0), - CLK_DIV("hsdiv1_16fft_main_14_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_14_foutvcop_clk", 0x68e080, 0, 7, 0), - CLK_DIV("hsdiv1_16fft_main_16_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_16_foutvcop_clk", 0x690080, 0, 7, 0), - CLK_DIV("hsdiv1_16fft_main_17_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_17_foutvcop_clk", 0x691080, 0, 7, 0), - CLK_DIV("hsdiv1_16fft_main_18_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_18_foutvcop_clk", 0x692080, 0, 7, 0), - CLK_DIV("hsdiv1_16fft_main_19_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_19_foutvcop_clk", 0x693080, 0, 7, 0), - CLK_DIV("hsdiv1_16fft_main_23_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_23_foutvcop_clk", 0x697080, 0, 7, 0), - CLK_DIV("hsdiv1_16fft_main_25_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_25_foutvcop_clk", 0x699080, 0, 7, 0), - CLK_DIV("hsdiv3_16fft_main_13_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_13_foutvcop_clk", 0x68d080, 0, 7, 0), - CLK_DIV("hsdiv3_16fft_main_5_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_5_foutvcop_clk", 0x685080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_0_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_0_hsdivout1_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680084, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_0_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680088, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_0_hsdivout3_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x68008c, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_0_hsdivout4_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680090, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_2_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_2_foutvcop_clk", 0x682080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_2_hsdivout1_clk", "pllfrac2_ssmod_16fft_main_2_foutvcop_clk", 0x682084, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_2_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_2_foutvcop_clk", 0x682088, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_3_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_3_foutvcop_clk", 0x683080, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_3_hsdivout1_clk", "pllfrac2_ssmod_16fft_main_3_foutvcop_clk", 0x683084, 0, 7, 0), - CLK_DIV("hsdiv4_16fft_main_3_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_3_foutvcop_clk", 0x683088, 0, 7, 0), + CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out0", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x1081c0, 0, 2, 0, 0, 48000000), + CLK_DIV("hsdiv0_16fft_main_12_hsdivout0_clk", "pllfracf_ssmod_16fft_main_12_foutvcop_clk", 0x68c080, 0, 7, 0, 0), + CLK_DIV("hsdiv0_16fft_main_6_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_6_foutvcop_clk", 0x686080, 0, 7, 0, 0), + CLK_DIV("hsdiv0_16fft_main_7_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_7_foutvcop_clk", 0x687080, 0, 7, 0, 0), + CLK_DIV("hsdiv0_16fft_main_8_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_8_foutvcop_clk", 0x688080, 0, 7, 0, 0), + CLK_DIV("hsdiv1_16fft_main_14_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_14_foutvcop_clk", 0x68e080, 0, 7, 0, 0), + CLK_DIV("hsdiv1_16fft_main_16_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_16_foutvcop_clk", 0x690080, 0, 7, 0, 0), + CLK_DIV("hsdiv1_16fft_main_17_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_17_foutvcop_clk", 0x691080, 0, 7, 0, 0), + CLK_DIV("hsdiv1_16fft_main_18_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_18_foutvcop_clk", 0x692080, 0, 7, 0, 0), + CLK_DIV("hsdiv1_16fft_main_19_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_19_foutvcop_clk", 0x693080, 0, 7, 0, 0), + CLK_DIV("hsdiv1_16fft_main_23_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_23_foutvcop_clk", 0x697080, 0, 7, 0, 0), + CLK_DIV("hsdiv1_16fft_main_25_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_25_foutvcop_clk", 0x699080, 0, 7, 0, 0), + CLK_DIV("hsdiv3_16fft_main_13_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_13_foutvcop_clk", 0x68d080, 0, 7, 0, 0), + CLK_DIV("hsdiv3_16fft_main_5_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_5_foutvcop_clk", 0x685080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout1_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout3_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x68008c, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout4_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680090, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_2_foutvcop_clk", 0x682080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout1_clk", "pllfrac2_ssmod_16fft_main_2_foutvcop_clk", 0x682084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_2_foutvcop_clk", 0x682088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_3_foutvcop_clk", 0x683080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout1_clk", "pllfrac2_ssmod_16fft_main_3_foutvcop_clk", 0x683084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_3_foutvcop_clk", 0x683088, 0, 7, 0, 0), CLK_MUX_PLLCTRL("k3_pll_ctrl_wrap_main_0_sysclkout_clk", k3_pll_ctrl_wrap_main_0_sysclkout_clk_parents, 2, 0x410000, 0), - CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x410118, 0, 5, 0), - CLK_DIV("mcu_obsclk_div_out0", "wkup_obsclk_mux_out0", 0x43008000, 8, 4, 0), + CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x410118, 0, 5, 0, 0), + CLK_DIV("mcu_obsclk_div_out0", "wkup_obsclk_mux_out0", 0x43008000, 8, 4, 0, 0), CLK_MUX("mcu_obsclk_outmux_out0", mcu_obsclk_outmux_out0_parents, 2, 0x43008000, 24, 1, 0), CLK_MUX("obsclk1_mux_out0", obsclk1_mux_out0_parents, 4, 0x108004, 0, 2, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_15_foutvcop_clk", "main_pll15_xref_sel_out0", 0x68f000, 0), @@ -588,19 +589,19 @@ static const struct clk_data clk_list[] = { CLK_MUX("emmcsd_refclk_sel_out1", emmcsd_refclk_sel_out1_parents, 4, 0x1080b4, 0, 2, 0), CLK_MUX("gtc_clk_mux_out0", gtc_clk_mux_out0_parents, 16, 0x108030, 0, 4, 0), CLK_MUX("gpmc_fclk_sel_out0", gpmc_fclk_sel_out0_parents, 4, 0x1080d0, 0, 2, 0), - CLK_DIV("hsdiv0_16fft_main_24_hsdivout0_clk", "plldeskew_16fft_main_24_foutp_clk", 0x698080, 0, 0, 0), - CLK_DIV("hsdiv3_16fft_main_15_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_15_foutvcop_clk", 0x68f080, 0, 7, 0), - CLK_DIV("hsdiv3_16fft_main_15_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_15_foutvcop_clk", 0x68f088, 0, 7, 0), - CLK_DIV("hsdiv3_16fft_main_4_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_4_foutvcop_clk", 0x684080, 0, 7, 0), - CLK_DIV("hsdiv3_16fft_main_4_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_4_foutvcop_clk", 0x684088, 0, 7, 0), + CLK_DIV("hsdiv0_16fft_main_24_hsdivout0_clk", "plldeskew_16fft_main_24_foutp_clk", 0x698080, 0, 0, 0, 0), + CLK_DIV("hsdiv3_16fft_main_15_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_15_foutvcop_clk", 0x68f080, 0, 7, 0, 0), + CLK_DIV("hsdiv3_16fft_main_15_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_15_foutvcop_clk", 0x68f088, 0, 7, 0, 0), + CLK_DIV("hsdiv3_16fft_main_4_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_4_foutvcop_clk", 0x684080, 0, 7, 0, 0), + CLK_DIV("hsdiv3_16fft_main_4_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_4_foutvcop_clk", 0x684088, 0, 7, 0, 0), CLK_MUX("mcasp_ahclko_mux_out0", mcasp_ahclko_mux_out0_parents, 33, 0x1082e0, 0, 5, 0), CLK_MUX("mcasp_ahclko_mux_out1", mcasp_ahclko_mux_out1_parents, 33, 0x1082e4, 0, 5, 0), CLK_MUX("mcasp_ahclko_mux_out2", mcasp_ahclko_mux_out2_parents, 33, 0x1082e8, 0, 5, 0), CLK_MUX("mcasp_ahclko_mux_out3", mcasp_ahclko_mux_out3_parents, 33, 0x1082ec, 0, 5, 0), CLK_MUX("obsclk0_mux_out0", obsclk0_mux_out0_parents, 32, 0x108000, 0, 5, 0), - CLK_DIV("osbclk0_div_out0", "obsclk0_mux_out0", 0x108000, 8, 8, 0), - CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x41011c, 0, 5, 0), - CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x4201011c, 0, 5, 0), + CLK_DIV("osbclk0_div_out0", "obsclk0_mux_out0", 0x108000, 8, 8, 0, 0), + CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x41011c, 0, 5, 0, 0), + CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x4201011c, 0, 5, 0, 0), };
static const struct dev_clk soc_dev_clk_data[] = { diff --git a/drivers/clk/ti/clk-k3.c b/drivers/clk/ti/clk-k3.c index e921894e7a20..e04c57eff252 100644 --- a/drivers/clk/ti/clk-k3.c +++ b/drivers/clk/ti/clk-k3.c @@ -2,7 +2,7 @@ /* * Texas Instruments K3 clock driver * - * Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/ + * Copyright (C) 2020-2021 Texas Instruments Incorporated - http://www.ti.com/ * Tero Kristo t-kristo@ti.com */
@@ -112,7 +112,7 @@ static int ti_clk_probe(struct udevice *dev) map_physmem(ti_clk_data->clk.div.reg, 0, MAP_NOCACHE), ti_clk_data->clk.div.shift, ti_clk_data->clk.div.width, - 0); + ti_clk_data->clk.div.div_flags); break; case CLK_TYPE_MUX: name = ti_clk_data->clk.mux.name; diff --git a/include/k3-clk.h b/include/k3-clk.h index 073522857980..59c76db86ead 100644 --- a/include/k3-clk.h +++ b/include/k3-clk.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * (C) Copyright 2020 - Texas Instruments Incorporated - http://www.ti.com + * (C) Copyright 2020-2021 Texas Instruments Incorporated - http://www.ti.com * Tero Kristo t-kristo@ti.com */
@@ -54,6 +54,7 @@ struct div_data { u32 flags; int shift; int width; + u32 div_flags; };
struct hfosc_data { @@ -105,20 +106,23 @@ struct clk_data { .width = _width, .flags = _flags } \ }
-#define CLK_DIV(_name, _parent, _reg, _shift, _width, _flags) \ - { \ - .type = CLK_TYPE_DIV, \ - .clk.div = {.name = _name, .parent = _parent, .reg = _reg, .shift = _shift, .width = _width, .flags = _flags } \ +#define CLK_DIV(_name, _parent, _reg, _shift, _width, _flags, _div_flags) \ + { \ + .type = CLK_TYPE_DIV, \ + .clk.div = { \ + .name = _name, .parent = _parent, .reg = _reg, \ + .shift = _shift, .width = _width, \ + .flags = _flags, .div_flags = _div_flags } \ }
-#define CLK_DIV_DEFFREQ(_name, _parent, _reg, _shift, _width, _flags, _freq) \ - { \ - .type = CLK_TYPE_DIV, \ - .default_freq = _freq, \ - .clk.div = { \ - .name = _name, .parent = _parent, \ - .reg = _reg, .shift = _shift, \ - .width = _width, .flags = _flags } \ +#define CLK_DIV_DEFFREQ(_name, _parent, _reg, _shift, _width, _flags, _div_flags, _freq) \ + { \ + .type = CLK_TYPE_DIV, \ + .default_freq = _freq, \ + .clk.div = { \ + .name = _name, .parent = _parent, .reg = _reg, \ + .shift = _shift, .width = _width, \ + .flags = _flags, .div_flags = _div_flags } \ }
#define CLK_PLL(_name, _parent, _reg, _flags) \
Dave Gerlach
