[U-Boot] Please pull u-boot-ppc4xx/next
The following changes since commit d70d8ccc200db8c16a6654cb726c3d74b6640b32:
silence config step commands display during MAKEALL builds (2010-09-21 21:46:49 +0200)
are available in the git repository at: git://www.denx.de/git/u-boot-ppc4xx.git next
Matthias Fuchs (1): ppx4xx: remove unused functionality for DU405 boards
Stefan Roese (9): ppc4xx: Remove unreferenced file include/405_dimm.h ppc4xx: Move ppc4xx headers to powerpc include directory ppc4xx: Move gpio.h to ppc4xx-gpio.h since its ppc4xx specific ppc4xx: Big header cleanup, mostly PPC440 related ppc4xx: Big header cleanup part 2, mostly PPC405 related ppc4xx: Use common NS16550 driver for PPC4xx UART ppc4xx: Remove now unused CONFIG_UART1_CONSOLE Remove unused CONFIG_SERIAL_SOFTWARE_FIFO feature ppc4xx: Cleanup of PVR detection code in cpu.c
Victor Gallardo (1): ppc4xx: Disable trace broadcast for 44x non debug mode
README | 19 - arch/i386/lib/board.c | 7 - arch/m68k/lib/board.c | 4 - arch/powerpc/cpu/ppc4xx/40x_spd_sdram.c | 2 +- arch/powerpc/cpu/ppc4xx/44x_spd_ddr.c | 2 +- arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c | 4 +- arch/powerpc/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c | 2 +- arch/powerpc/cpu/ppc4xx/4xx_pci.c | 36 +- arch/powerpc/cpu/ppc4xx/4xx_pcie.c | 2 +- arch/powerpc/cpu/ppc4xx/4xx_uart.c | 827 ++------- arch/powerpc/cpu/ppc4xx/cache.S | 2 +- arch/powerpc/cpu/ppc4xx/cmd_ecctest.c | 2 +- arch/powerpc/cpu/ppc4xx/cpu.c | 146 +- arch/powerpc/cpu/ppc4xx/cpu_init.c | 16 +- arch/powerpc/cpu/ppc4xx/dcr.S | 2 +- arch/powerpc/cpu/ppc4xx/denali_data_eye.c | 2 +- arch/powerpc/cpu/ppc4xx/denali_spd_ddr2.c | 2 +- arch/powerpc/cpu/ppc4xx/ecc.c | 2 +- arch/powerpc/cpu/ppc4xx/fdt.c | 2 +- arch/powerpc/cpu/ppc4xx/gpio.c | 7 +- arch/powerpc/cpu/ppc4xx/interrupts.c | 2 +- arch/powerpc/cpu/ppc4xx/kgdb.S | 2 +- arch/powerpc/cpu/ppc4xx/miiphy.c | 4 +- arch/powerpc/cpu/ppc4xx/reginfo.c | 8 +- arch/powerpc/cpu/ppc4xx/sdram.c | 2 +- arch/powerpc/cpu/ppc4xx/speed.c | 4 +- arch/powerpc/cpu/ppc4xx/start.S | 5 +- arch/powerpc/cpu/ppc4xx/tlb.c | 2 +- arch/powerpc/cpu/ppc4xx/uic.c | 2 +- arch/powerpc/cpu/ppc4xx/xilinx_irq.c | 2 +- arch/powerpc/include/asm/4xx_pcie.h | 2 +- arch/powerpc/include/asm/ppc405.h | 80 + arch/powerpc/include/asm/ppc405cr.h | 105 ++ arch/powerpc/include/asm/ppc405ep.h | 252 +++ arch/powerpc/include/asm/ppc405ex.h | 90 + arch/powerpc/include/asm/ppc405ez.h | 102 + arch/powerpc/include/asm/ppc405gp.h | 108 ++ arch/powerpc/include/asm/ppc440.h | 190 ++ arch/powerpc/include/asm/ppc440ep_gr.h | 244 +++ arch/powerpc/include/asm/ppc440epx_grx.h | 464 +++++ arch/powerpc/include/asm/ppc440gp.h | 72 + arch/powerpc/include/asm/ppc440gx.h | 102 + arch/powerpc/include/asm/ppc440sp.h | 98 + arch/powerpc/include/asm/ppc440spe.h | 114 ++ arch/powerpc/include/asm/ppc460ex_gt.h | 222 +++ arch/powerpc/include/asm/ppc460sx.h | 44 + .../powerpc/include/asm/ppc4xx-emac.h | 8 +- arch/powerpc/include/asm/{gpio.h => ppc4xx-gpio.h} | 0 .../powerpc/include/asm/ppc4xx-i2c.h | 0 arch/powerpc/include/asm/ppc4xx-mal.h | 168 ++ arch/powerpc/include/asm/ppc4xx-sdram.h | 2 - arch/powerpc/include/asm/ppc4xx.h | 344 ++++ arch/powerpc/lib/board.c | 7 - arch/sparc/lib/board.c | 4 - board/amcc/acadia/memory.c | 2 +- board/amcc/acadia/pll.c | 30 +- board/amcc/bamboo/bamboo.c | 6 +- board/amcc/bamboo/bamboo.h | 11 - board/amcc/bamboo/flash.c | 6 +- board/amcc/bubinga/flash.c | 2 +- board/amcc/canyonlands/canyonlands.c | 4 +- board/amcc/common/flash.c | 2 +- board/amcc/ebony/flash.c | 2 +- board/amcc/ebony/init.S | 1 + board/amcc/katmai/init.S | 1 + board/amcc/katmai/katmai.c | 4 +- board/amcc/kilauea/kilauea.c | 4 +- board/amcc/luan/flash.c | 2 +- board/amcc/luan/init.S | 1 + board/amcc/luan/luan.c | 2 +- board/amcc/makalu/makalu.c | 6 +- board/amcc/ocotea/flash.c | 2 +- board/amcc/ocotea/init.S | 1 + board/amcc/ocotea/ocotea.c | 2 +- board/amcc/redwood/init.S | 1 + board/amcc/redwood/redwood.c | 2 +- board/amcc/sequoia/sdram.c | 2 +- board/amcc/sequoia/sequoia.c | 8 +- board/amcc/taihu/flash.c | 2 +- board/amcc/taihu/lcd.c | 2 +- board/amcc/taihu/taihu.c | 2 +- board/amcc/taishan/init.S | 1 + board/amcc/taishan/taishan.c | 2 +- board/amcc/walnut/flash.c | 2 +- board/amcc/yosemite/yosemite.c | 2 +- board/amcc/yucca/flash.c | 4 +- board/amcc/yucca/init.S | 1 + board/amcc/yucca/yucca.c | 2 +- board/amirix/ap1000/init.S | 2 +- board/amirix/ap1000/pci.c | 2 +- board/cray/L1/L1.c | 2 +- board/cray/L1/flash.c | 2 +- board/cray/L1/init.S | 2 +- board/csb272/csb272.c | 2 +- board/csb272/init.S | 2 +- board/csb472/csb472.c | 2 +- board/csb472/init.S | 2 +- board/dave/PPChameleonEVB/flash.c | 2 +- board/dave/common/pci.c | 2 +- board/eric/flash.c | 2 +- board/eric/init.S | 2 +- board/esd/adciop/flash.c | 2 +- board/esd/ar405/flash.c | 2 +- board/esd/ash405/flash.c | 2 +- board/esd/canbt/flash.c | 2 +- board/esd/cms700/flash.c | 2 +- board/esd/common/flash.c | 2 +- board/esd/common/pci.c | 2 +- board/esd/cpci2dp/flash.c | 2 +- board/esd/cpci405/flash.c | 2 +- board/esd/cpciiser4/flash.c | 2 +- board/esd/dasa_sim/flash.c | 2 +- board/esd/dp405/flash.c | 2 +- board/esd/du405/du405.c | 4 +- board/esd/du405/flash.c | 2 +- board/esd/du440/du440.c | 6 +- board/esd/hh405/flash.c | 2 +- board/esd/hub405/flash.c | 2 +- board/esd/ocrtc/flash.c | 2 +- board/esd/pci405/flash.c | 2 +- board/esd/pci405/pci405.c | 1 - board/esd/pci405/writeibm.S | 2 +- board/esd/plu405/flash.c | 2 +- board/esd/pmc405de/pmc405de.c | 2 +- board/esd/pmc440/pmc440.c | 12 +- board/esd/pmc440/sdram.c | 2 +- board/esd/tasreg/flash.c | 2 +- board/esd/voh405/flash.c | 2 +- board/esd/vom405/flash.c | 2 +- board/esd/wuh405/flash.c | 2 +- board/gdsys/dlvision/dlvision.c | 2 +- board/gdsys/gdppc440etx/gdppc440etx.c | 2 +- board/gdsys/intip/intip.c | 4 +- board/jse/flash.c | 2 +- board/jse/init.S | 2 +- board/jse/jse.c | 2 +- board/jse/sdram.c | 2 +- board/korat/korat.c | 8 +- board/lwmon5/lwmon5.c | 12 +- board/lwmon5/sdram.c | 2 +- board/ml2/init.S | 2 +- board/mosaixtech/icon/icon.c | 4 +- board/mosaixtech/icon/init.S | 1 + board/mpl/common/flash.c | 2 +- board/mpl/common/memtst.c | 2 +- board/mpl/mip405/init.S | 3 +- board/mpl/mip405/mip405.c | 3 +- board/mpl/pip405/init.S | 3 +- board/netstal/common/fixed_sdram.c | 2 +- board/netstal/hcu4/hcu4.c | 2 +- board/netstal/hcu5/hcu5.c | 26 +- board/netstal/hcu5/sdram.c | 2 +- board/netstal/mcu25/mcu25.c | 2 +- board/pcs440ep/pcs440ep.c | 2 +- board/prodrive/alpr/alpr.c | 2 +- board/prodrive/alpr/fpga.c | 2 +- board/prodrive/alpr/init.S | 1 + board/prodrive/p3p440/init.S | 1 + board/quad100hd/nand.c | 2 +- board/quad100hd/quad100hd.c | 2 +- board/sandburst/common/flash.c | 2 +- board/sandburst/common/ppc440gx_i2c.c | 4 +- board/sandburst/common/ppc440gx_i2c.h | 4 +- board/sandburst/karef/init.S | 1 + board/sandburst/metrobox/init.S | 1 + board/sc3/init.S | 2 +- board/sc3/sc3.c | 10 +- board/snmc/qs850/flash.c | 2 +- board/snmc/qs860t/flash.c | 2 +- board/t3corp/t3corp.c | 4 +- board/tb0229/flash.c | 2 +- board/w7o/flash.c | 2 +- board/w7o/init.S | 2 +- board/w7o/post1.S | 2 +- board/xes/xpedite1000/init.S | 1 + board/zeus/update.c | 2 +- board/zeus/zeus.c | 2 +- common/serial.c | 15 +- common/stdio.c | 8 - doc/README.ppc440 | 6 - drivers/i2c/ppc4xx_i2c.c | 4 +- drivers/mtd/nand/ndfc.c | 2 +- drivers/net/4xx_enet.c | 9 +- drivers/serial/serial_netarm.c | 5 - include/405_dimm.h | 4 - include/405_mal.h | 129 -- include/common.h | 11 +- include/configs/AP1000.h | 6 - include/configs/APC405.h | 6 + include/configs/AR405.h | 6 + include/configs/ASH405.h | 17 +- include/configs/ATUM8548.h | 1 - include/configs/CANBT.h | 6 + include/configs/CATcenter.h | 18 +- include/configs/CMS700.h | 19 +- include/configs/CPCI2DP.h | 7 +- include/configs/CPCI405.h | 6 + include/configs/CPCI4052.h | 6 + include/configs/CPCI405AB.h | 6 + include/configs/CPCI405DT.h | 6 + include/configs/CPCIISER4.h | 6 + include/configs/CRAYL1.h | 6 + include/configs/DP405.h | 19 +- include/configs/DU405.h | 37 +- include/configs/DU440.h | 9 +- include/configs/ERIC.h | 6 + include/configs/G2000.h | 17 +- include/configs/HH405.h | 17 +- include/configs/HUB405.h | 17 +- include/configs/JSE.h | 14 +- include/configs/KAREF.h | 7 +- include/configs/METROBOX.h | 7 +- include/configs/MIP405.h | 6 + include/configs/ML2.h | 10 - include/configs/MPC8308RDB.h | 1 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC8323ERDB.h | 1 - include/configs/MPC832XEMDS.h | 1 - include/configs/MPC8349EMDS.h | 1 - include/configs/MPC8349ITX.h | 1 - include/configs/MPC8360EMDS.h | 1 - include/configs/MPC8360ERDK.h | 1 - include/configs/MPC837XEMDS.h | 1 - include/configs/MPC837XERDB.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8540ADS.h | 1 - include/configs/MPC8540EVAL.h | 1 - include/configs/MPC8541CDS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8548CDS.h | 1 - include/configs/MPC8555CDS.h | 1 - include/configs/MPC8568MDS.h | 1 - include/configs/MPC8569MDS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/MVBLM7.h | 1 - include/configs/OCRTC.h | 6 + include/configs/ORSG.h | 6 + include/configs/P1_P2_RDB.h | 1 - include/configs/P2020DS.h | 1 - include/configs/PCI405.h | 6 + include/configs/PIP405.h | 6 + include/configs/PLU405.h | 17 +- include/configs/PM854.h | 1 - include/configs/PMC405.h | 6 + include/configs/PMC405DE.h | 7 +- include/configs/PMC440.h | 11 +- include/configs/PPChameleonEVB.h | 29 +- include/configs/SBC8540.h | 1 - include/configs/TQM834x.h | 1 - include/configs/TQM85xx.h | 1 - include/configs/VOH405.h | 17 +- include/configs/VOM405.h | 19 +- include/configs/W7OLMC.h | 6 + include/configs/W7OLMG.h | 6 + include/configs/WUH405.h | 17 +- include/configs/XPEDITE1000.h | 7 +- include/configs/acadia.h | 1 + include/configs/alpr.h | 8 +- include/configs/amcc-common.h | 6 +- include/configs/aria.h | 1 - include/configs/bamboo.h | 6 +- include/configs/bubinga.h | 12 +- include/configs/canyonlands.h | 4 +- include/configs/csb272.h | 6 + include/configs/csb472.h | 6 + include/configs/dlvision.h | 2 +- include/configs/eNET.h | 1 - include/configs/ebony.h | 3 +- include/configs/gdppc440etx.h | 7 +- include/configs/hcu5.h | 5 - include/configs/icon.h | 3 +- include/configs/intip.h | 4 +- include/configs/katmai.h | 3 +- include/configs/kilauea.h | 4 +- include/configs/kmeter1.h | 1 - include/configs/korat.h | 10 +- include/configs/luan.h | 4 +- include/configs/lwmon5.h | 10 +- include/configs/makalu.h | 4 +- include/configs/mcu25.h | 7 - include/configs/mecp5123.h | 1 - include/configs/mpc5121ads.h | 1 - include/configs/neo.h | 7 +- include/configs/netstal-common.h | 5 + include/configs/ocotea.h | 3 +- include/configs/p3p440.h | 7 +- include/configs/pcs440ep.h | 8 +- include/configs/quad100hd.h | 15 +- include/configs/redwood.h | 6 +- include/configs/sbc405.h | 6 + include/configs/sbc8349.h | 1 - include/configs/sbc8548.h | 1 - include/configs/sbc8560.h | 1 - include/configs/sbc8641d.h | 1 - include/configs/sc3.h | 13 +- include/configs/sequoia.h | 6 +- include/configs/socrates.h | 1 - include/configs/stxssa.h | 1 - include/configs/t3corp.h | 4 +- include/configs/taihu.h | 3 +- include/configs/taishan.h | 3 +- include/configs/vme8349.h | 1 - include/configs/walnut.h | 2 +- include/configs/yosemite.h | 4 +- include/configs/yucca.h | 4 +- include/configs/zeus.h | 22 +- include/ppc405.h | 832 --------- include/ppc440.h | 1958 -------------------- include/ppc4xx.h | 225 --- nand_spl/board/amcc/bamboo/sdram.c | 2 +- nand_spl/board/amcc/canyonlands/ddr2_fixed.c | 4 +- post/board/lwmon5/watchdog.c | 2 +- post/cpu/ppc4xx/denali_ecc.c | 2 +- post/cpu/ppc4xx/ether.c | 4 +- post/cpu/ppc4xx/fpu.c | 2 +- 317 files changed, 3689 insertions(+), 4578 deletions(-) create mode 100644 arch/powerpc/include/asm/ppc405.h create mode 100644 arch/powerpc/include/asm/ppc405cr.h create mode 100644 arch/powerpc/include/asm/ppc405ep.h create mode 100644 arch/powerpc/include/asm/ppc405ex.h create mode 100644 arch/powerpc/include/asm/ppc405ez.h create mode 100644 arch/powerpc/include/asm/ppc405gp.h create mode 100644 arch/powerpc/include/asm/ppc440.h create mode 100644 arch/powerpc/include/asm/ppc440ep_gr.h create mode 100644 arch/powerpc/include/asm/ppc440epx_grx.h create mode 100644 arch/powerpc/include/asm/ppc440gp.h create mode 100644 arch/powerpc/include/asm/ppc440gx.h create mode 100644 arch/powerpc/include/asm/ppc440sp.h create mode 100644 arch/powerpc/include/asm/ppc440spe.h create mode 100644 arch/powerpc/include/asm/ppc460ex_gt.h create mode 100644 arch/powerpc/include/asm/ppc460sx.h rename include/ppc4xx_enet.h => arch/powerpc/include/asm/ppc4xx-emac.h (98%) rename arch/powerpc/include/asm/{gpio.h => ppc4xx-gpio.h} (100%) rename include/4xx_i2c.h => arch/powerpc/include/asm/ppc4xx-i2c.h (100%) create mode 100644 arch/powerpc/include/asm/ppc4xx-mal.h create mode 100644 arch/powerpc/include/asm/ppc4xx.h delete mode 100644 include/405_dimm.h delete mode 100644 include/405_mal.h delete mode 100644 include/ppc405.h delete mode 100644 include/ppc440.h delete mode 100644 include/ppc4xx.h
Dear Stefan Roese,
Sorry, this does not apply:
-> git fetch u-boot-ppc4xx.git next:next
From git://git.denx.de/u-boot-ppc4xx
! [rejected] next -> next (non-fast-forward)
Hi Wolfgang,
-> git fetch u-boot-ppc4xx.git next:next From git://git.denx.de/u-boot-ppc4xx ! [rejected] next -> next (non-fast-forward)
Hmmm, not sure what went wrong here. I just rebased u-boot-ppc4xx/next on current mainline/next and pushed it out again. Could you please try to pull this repository again?
Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Dear Stefan Roese,
Applied to next, thanks.
Stefan Roese
