[PATCH v2] configs: ls1028aqds: add lpuart config
Add lpuart config to enable lpuart feature.
Signed-off-by: Vabhav Sharma vabhav.sharma@nxp.com Signed-off-by: Yuantian Tang andy.tang@nxp.com. --- v2: - fix buildman compiling warnings board/freescale/ls1028a/MAINTAINERS | 1 + configs/ls1028aqds_tfa_lpuart_defconfig | 88 +++++++++++++++++++++++++++++++++ 2 files changed, 89 insertions(+) create mode 100644 configs/ls1028aqds_tfa_lpuart_defconfig
diff --git a/board/freescale/ls1028a/MAINTAINERS b/board/freescale/ls1028a/MAINTAINERS index 2c28825..5b7a8db 100644 --- a/board/freescale/ls1028a/MAINTAINERS +++ b/board/freescale/ls1028a/MAINTAINERS @@ -8,6 +8,7 @@ F: board/freescale/ls1028a/ F: include/configs/ls1028a_common.h F: include/configs/ls1028aqds.h F: configs/ls1028aqds_tfa_defconfig +F: configs/ls1028aqds_tfa_lpuart_defconfig
LS1028ARDB BOARD M: Sudhanshu Gupta sudhanshu.gupta@nxp.com diff --git a/configs/ls1028aqds_tfa_lpuart_defconfig b/configs/ls1028aqds_tfa_lpuart_defconfig new file mode 100644 index 0000000..417f292 --- /dev/null +++ b/configs/ls1028aqds_tfa_lpuart_defconfig @@ -0,0 +1,88 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1028AQDS=y +CONFIG_TFABOOT=y +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_DM_GPIO=y +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256 video=1920x1080-32@60 cma=256M" +CONFIG_SYS_EXTRA_OPTIONS="LPUART" +CONFIG_MISC_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1028a-qds-lpuart" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_DM=y +CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y +CONFIG_FSL_CAAM=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_ATHEROS=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_FSL_ENETC=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_ECAM_GENERIC=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_RTC=y +CONFIG_RTC_PCF2127=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SP805=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y
Yuantian Tang
