[PATCH] pstore: Use root address-cells/size-cells as defaults for reserved-memory
u-boot adds reserve-memory node, if it's missing, with following properties:
``` reserved-memory { #address-cells = <2>; #size-cells = <2>; ranges; } ```
But with these default address-cells and size-cells values, pstore isn't working on A64. Root node for A64 defines 'address-cells' and 'size-cells' as 1.
dtc complains if reserved-memory has different address-cells and size-cells.
``` Warning (ranges_format): /reserved-memory:ranges: empty "ranges" property but its #address-cells (2) differs from / (1) ```
This patch takes into account address-cells and size-cells of the root node and uses them as values for new reserved-memory node.
Signed-off-by: Andrey Skvortsov andrej.skvortzov@gmail.com --- cmd/pstore.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/cmd/pstore.c b/cmd/pstore.c index cd6f6feb2f..9795eea2db 100644 --- a/cmd/pstore.c +++ b/cmd/pstore.c @@ -486,6 +486,8 @@ void fdt_fixup_pstore(void *blob) { char node[32]; int nodeoffset; /* node offset from libfdt */ + u32 addr_cells_root; + u32 size_cells_root; u32 addr_cells; u32 size_cells;
@@ -495,6 +497,8 @@ void fdt_fixup_pstore(void *blob) log_err("fdt_path_offset() returned %s\n", fdt_strerror(nodeoffset)); return; } + addr_cells_root = fdt_getprop_u32_default_node(blob, nodeoffset, 0, "#address-cells", 2); + size_cells_root = fdt_getprop_u32_default_node(blob, nodeoffset, 0, "#size-cells", 2);
nodeoffset = fdt_find_or_add_subnode(blob, nodeoffset, "reserved-memory"); if (nodeoffset < 0) { @@ -503,8 +507,10 @@ void fdt_fixup_pstore(void *blob) return; }
- addr_cells = fdt_getprop_u32_default_node(blob, nodeoffset, 0, "#address-cells", 2); - size_cells = fdt_getprop_u32_default_node(blob, nodeoffset, 0, "#size-cells", 2); + addr_cells = fdt_getprop_u32_default_node(blob, nodeoffset, 0, + "#address-cells", addr_cells_root); + size_cells = fdt_getprop_u32_default_node(blob, nodeoffset, 0, + "#size-cells", size_cells_root); fdt_setprop_u32(blob, nodeoffset, "#address-cells", addr_cells); fdt_setprop_u32(blob, nodeoffset, "#size-cells", size_cells);
This defines the size of cells for the children of reserved-memory and and for the ranges property. If you set the cell sizes to 1 you can no longer encode 64 bit addresses.
ranges; }
But with these default address-cells and size-cells values, pstore isn't working on A64. Root node for A64 defines 'address-cells' and 'size-cells' as 1. dtc complains if reserved-memory has different address-cells and size-cells.
I cannot find any such requirement in the Devicetree Specification 1.4. Is this a dtc bug?
Reservations may be above 4 GiB. How does your patch consider this?
Best regards
Heinrich
- u32 addr_cells_root;
- u32 size_cells_root; u32 addr_cells; u32 size_cells;
fdt_setprop_u32(blob, nodeoffset, "#address-cells", addr_cells); fdt_setprop_u32(blob, nodeoffset, "#size-cells", size_cells);"#size-cells", size_cells_root);
On Sat, 26 Aug 2023 15:10:10 +0200 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Yes, this is expected in this case, the Allwinner A64 SoC has its memory map (including DRAM) completely below 4GB, hence the root node can go with 1/1.
ranges; }
I think the culprit here is the *empty* ranges property: "If the property is defined with an <empty> value, it specifies that the parent and child address space is identical, and no address translation is required." As this is contradicted by the differing #a-c/#s-z properties, it looks like dtc has good reasons to warn.
If the root #a-c/#s-c don't allow for more than 4GB, then it's for a reason (in this case, the A64 being 32-bit only, even with AArch64 capable cores), and keeping it isn't restricting it further. So I think copying the root properties is the right thing to do. I think almost every other 64-bit core uses 2/2 anyway, so it's just the odd outlier here.
Cheers, Andre
Best regards
Heinrich
ranges; }
Cheers, Andre
Are there any comments I should fix to get this change merged or maybe another way of solving this problem?
I see, that patch requires review from Tom Rini currently on patchwork [1].
1. https://patchwork.ozlabs.org/project/uboot/patch/20230826121652.2487643-1-an...
Hi Heinrich,
This will be limited to 32 bit only for platforms, that don't support 64 bit. These platforms explicitly defines #address-cells = 1 and #size-cells = 1 in root node.
ranges; }
This is current behavior of Linux kernel. When root #address-cells and reserved-memory #address-cells don't match, then reserved-memory region is ignored. See [1].
dmesg output: ``` OF: fdt: Reserved memory: unsupported node format, ignoring ```
It's entirely possible to do on platforms, that support that. Default fallback value is still 2 for #address-cells and #size-cells.
1. https://elixir.bootlin.com/linux/latest/source/drivers/of/fdt.c#L548
Andre Przywara
Andrey Skvortsov
