[PATCH 1/2] board: sifive: compile stuff only related to SPL in SPL build
As (3581811dc26f "riscv: sifive/fu540: Move SPL related functions to spl.c"), we put the SPL stuff in spl.c, we don't need to compile unleashed.c and unmatched.c in SPL build.
Signed-off-by: Zong Li zong.li@sifive.com --- board/sifive/unleashed/Makefile | 4 ++-- board/sifive/unmatched/Makefile | 3 ++- 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/board/sifive/unleashed/Makefile b/board/sifive/unleashed/Makefile index 5821679dd9..98e9111cbc 100644 --- a/board/sifive/unleashed/Makefile +++ b/board/sifive/unleashed/Makefile @@ -2,8 +2,8 @@ # # Copyright (c) 2019 Western Digital Corporation or its affiliates.
-obj-y += unleashed.o - ifdef CONFIG_SPL_BUILD obj-y += spl.o +else +obj-y += unleashed.o endif diff --git a/board/sifive/unmatched/Makefile b/board/sifive/unmatched/Makefile index e00b330e8c..1345330089 100644 --- a/board/sifive/unmatched/Makefile +++ b/board/sifive/unmatched/Makefile @@ -2,9 +2,10 @@ # # Copyright (c) 2020-2021 SiFive, Inc
-obj-y += unmatched.o obj-$(CONFIG_ID_EEPROM) += hifive-platform-i2c-eeprom.o
ifdef CONFIG_SPL_BUILD obj-y += spl.o +else +obj-y += unmatched.o endif
Add board_fdt_blob_setup to return the device tree location which is passed by prior stage in u-boot proper. The generic board_fdt_blob_setup always returns _end, it mignt be ok because u-boot SPL would currently put the dtb there, but it would be broken if we put the dtb to another place and assigned the location into a1 register for u-boot proper. Use the location passed by prior stage would make more sence, because we actually pass the location to u-boot proper and want to use that one, rather than the dtb which in _end.
We can't use CONFIG_OF_PRIOR_STAGE because it doens't distinguish the implementation of u-boot SPL and u-boot proper, so u-boot SPL need to reply on the prior stage to pass device tree location as well, but we don't pass the DT from boot rom now. In addition, when CONFIG_OF_PRIOR_STAGE is enabled, the u-boot-spl.bin and u-boot.itb won't include the device tree.
Signed-off-by: Zong Li zong.li@sifive.com --- board/sifive/unleashed/unleashed.c | 11 +++++++++++ board/sifive/unmatched/unmatched.c | 11 +++++++++++ 2 files changed, 22 insertions(+)
diff --git a/board/sifive/unleashed/unleashed.c b/board/sifive/unleashed/unleashed.c index a4e78220cb..fa65fcade0 100644 --- a/board/sifive/unleashed/unleashed.c +++ b/board/sifive/unleashed/unleashed.c @@ -16,6 +16,7 @@ #include <misc.h> #include <spl.h> #include <asm/arch/cache.h> +#include <asm/sections.h>
/* * This define is a value used for error/unknown serial. @@ -113,6 +114,16 @@ int misc_init_r(void)
#endif
+void *board_fdt_blob_setup(void) +{ + if (IS_ENABLED(CONFIG_OF_SEPARATE)) { + if (gd->arch.firmware_fdt_addr) + return (ulong *)gd->arch.firmware_fdt_addr; + else + return (ulong *)&_end; + } +} + int board_init(void) { int ret; diff --git a/board/sifive/unmatched/unmatched.c b/board/sifive/unmatched/unmatched.c index 6d60559588..da23a6ce24 100644 --- a/board/sifive/unmatched/unmatched.c +++ b/board/sifive/unmatched/unmatched.c @@ -9,6 +9,17 @@ #include <common.h> #include <dm.h> #include <asm/arch/cache.h> +#include <asm/sections.h> + +void *board_fdt_blob_setup(void) +{ + if (IS_ENABLED(CONFIG_OF_SEPARATE)) { + if (gd->arch.firmware_fdt_addr) + return (ulong *)gd->arch.firmware_fdt_addr; + else + return (ulong *)&_end; + } +}
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Leo Liang
Zong Li
