[U-Boot] [PATCH] ARM: dts: rmobile: Move the PHY reset GPIO back
The current state of RAVB driver expects the PHY reset GPIO in the RAVB mode, move it back from the PHY node to avoid breakage.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- arch/arm/dts/salvator-common.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/salvator-common.dtsi b/arch/arm/dts/salvator-common.dtsi index 514c57b2c8..6b176ea36a 100644 --- a/arch/arm/dts/salvator-common.dtsi +++ b/arch/arm/dts/salvator-common.dtsi @@ -257,6 +257,7 @@ pinctrl-names = "default"; phy-handle = <&phy0>; phy-mode = "rgmii-txid"; + reset-gpios = <&gpio2 10 GPIO_ACTIVE_LOW>; status = "okay";
phy0: ethernet-phy@0 { @@ -264,7 +265,6 @@ reg = <0>; interrupt-parent = <&gpio2>; interrupts = <11 IRQ_TYPE_LEVEL_LOW>; - reset-gpios = <&gpio2 10 GPIO_ACTIVE_LOW>; }; };
