[U-Boot] [PATCH] tools: use read-only mmap in fit_check_sign
Add an option to open files in read-only mode in mmap_fdt so that fit_check_sign can be used to inspect files on read-only filesystems. For example, this is useful when a key is shipped in a read-only rootfs or squashfs.
Signed-off-by: Luca Boccassi luca.boccassi@microsoft.com --- tools/fit_check_sign.c | 4 ++-- tools/fit_common.c | 9 ++++++--- tools/fit_common.h | 4 +++- tools/fit_image.c | 10 ++++++---- tools/fit_info.c | 2 +- 5 files changed, 18 insertions(+), 11 deletions(-)
diff --git a/tools/fit_check_sign.c b/tools/fit_check_sign.c index 62adc751cb..4528743792 100644 --- a/tools/fit_check_sign.c +++ b/tools/fit_check_sign.c @@ -70,10 +70,10 @@ int main(int argc, char **argv) usage(*argv); }
- ffd = mmap_fdt(cmdname, fdtfile, 0, &fit_blob, &fsbuf, false); + ffd = mmap_fdt(cmdname, fdtfile, 0, &fit_blob, &fsbuf, false, true); if (ffd < 0) return EXIT_FAILURE; - kfd = mmap_fdt(cmdname, keyfile, 0, &key_blob, &ksbuf, false); + kfd = mmap_fdt(cmdname, keyfile, 0, &key_blob, &ksbuf, false, true); if (kfd < 0) return EXIT_FAILURE;
diff --git a/tools/fit_common.c b/tools/fit_common.c index 9506390214..cdf987d3c1 100644 --- a/tools/fit_common.c +++ b/tools/fit_common.c @@ -41,13 +41,14 @@ int fit_check_image_types(uint8_t type) }
int mmap_fdt(const char *cmdname, const char *fname, size_t size_inc, - void **blobp, struct stat *sbuf, bool delete_on_error) + void **blobp, struct stat *sbuf, bool delete_on_error, + bool read_only) { void *ptr; int fd;
/* Load FIT blob into memory (we need to write hashes/signatures) */ - fd = open(fname, O_RDWR | O_BINARY); + fd = open(fname, (read_only ? O_RDONLY : O_RDWR) | O_BINARY);
if (fd < 0) { fprintf(stderr, "%s: Can't open %s: %s\n", @@ -71,7 +72,9 @@ int mmap_fdt(const char *cmdname, const char *fname, size_t size_inc, }
errno = 0; - ptr = mmap(0, sbuf->st_size, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0); + ptr = mmap(0, sbuf->st_size, + (read_only ? PROT_READ : PROT_READ | PROT_WRITE), MAP_SHARED, + fd, 0); if ((ptr == MAP_FAILED) || (errno != 0)) { fprintf(stderr, "%s: Can't read %s: %s\n", cmdname, fname, strerror(errno)); diff --git a/tools/fit_common.h b/tools/fit_common.h index 9e09624f64..1e81d4c68b 100644 --- a/tools/fit_common.h +++ b/tools/fit_common.h @@ -32,9 +32,11 @@ int fit_check_image_types(uint8_t type); * @blobp: Returns pointer to FDT blob * @sbuf: File status information is stored here * @delete_on_error: true to delete the file if we get an error + * @read_only: true to open in read-only mode * @return 0 if OK, -1 on error. */ int mmap_fdt(const char *cmdname, const char *fname, size_t size_inc, - void **blobp, struct stat *sbuf, bool delete_on_error); + void **blobp, struct stat *sbuf, bool delete_on_error, + bool read_only);
#endif /* _FIT_COMMON_H_ */ diff --git a/tools/fit_image.c b/tools/fit_image.c index 3b867e0656..5aca634b5e 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -33,7 +33,8 @@ static int fit_add_file_data(struct image_tool_params *params, size_t size_inc, void *ptr; int ret = 0;
- tfd = mmap_fdt(params->cmdname, tmpfile, size_inc, &ptr, &sbuf, true); + tfd = mmap_fdt(params->cmdname, tmpfile, size_inc, &ptr, &sbuf, true, + false); if (tfd < 0) return -EIO;
@@ -41,7 +42,8 @@ static int fit_add_file_data(struct image_tool_params *params, size_t size_inc, struct stat dest_sbuf;
destfd = mmap_fdt(params->cmdname, params->keydest, size_inc, - &dest_blob, &dest_sbuf, false); + &dest_blob, &dest_sbuf, false, + false); if (destfd < 0) { ret = -EIO; goto err_keydest; @@ -420,7 +422,7 @@ static int fit_extract_data(struct image_tool_params *params, const char *fname) int images; int node;
- fd = mmap_fdt(params->cmdname, fname, 0, &fdt, &sbuf, false); + fd = mmap_fdt(params->cmdname, fname, 0, &fdt, &sbuf, false, false); if (fd < 0) return -EIO; fit_size = fdt_totalsize(fdt); @@ -531,7 +533,7 @@ static int fit_import_data(struct image_tool_params *params, const char *fname) int images; int node;
- fd = mmap_fdt(params->cmdname, fname, 0, &old_fdt, &sbuf, false); + fd = mmap_fdt(params->cmdname, fname, 0, &old_fdt, &sbuf, false, false); if (fd < 0) return -EIO; fit_size = fdt_totalsize(old_fdt); diff --git a/tools/fit_info.c b/tools/fit_info.c index 45e0b310f7..b2642ec5b7 100644 --- a/tools/fit_info.c +++ b/tools/fit_info.c @@ -80,7 +80,7 @@ int main(int argc, char **argv) fprintf(stderr, "%s: Missing property name\n", *argv); usage(*argv); } - ffd = mmap_fdt(cmdname, fdtfile, 0, &fit_blob, &fsbuf, false); + ffd = mmap_fdt(cmdname, fdtfile, 0, &fit_blob, &fsbuf, false, false);
if (ffd < 0) { printf("Could not open %s\n", fdtfile);
