[U-Boot] u-boot hangs after detecting DDR3 RAM and Flash.
Hi All,
I am facing an error while porting u-boot for my platform because if exception error.
After running the u-boot to detect the DDR and flash u-boot hangs after showing the serial console output. In debugger I am seeing PC at 0x00000400 address which the exception handler vector address.
But when I modify the below statement in the function int interrupt_init (void) in u-boot\lib_ppc\interrupts.c, u-boot continues and I can see the u-boot prompt and I am able to run all u-boot commands.
int interrupt_init (void) { int ret;
/* call cpu specific function from $(CPU)/interrupts.c */ ret = interrupt_init_cpu (&decrementer_count);
if (ret) return ret;
set_dec (decrementer_count);
--- set_msr (get_msr () | MSR_EE); //Removed this statement. ++ set_msr (get_msr ());
return (0); }
It seems that there is an exception error and because of this u-boot hangs. But I didn't get any error condition till now.
If someone has earlier experienced this kind of issue, please share.
Regards, Prakash
Hi Prakash,
/* call cpu specific function from $(CPU)/interrupts.c */ ret = interrupt_init_cpu (&decrementer_count); if (ret) return ret; set_dec (decrementer_count);
By not setting MSR_EE, you will not be able to receive external interrupts, or even worse, your timer will most likely not work. Try the "sleep" command.
return (0);
One thing I've noticed in other PPC4xx ports as well, is that DDR auto- calibration (with short memory tests) can lead to exceptions that need to be cleared after the DDR is fully configured. Example:
arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c:
phys_size_t initdram(int board_type) { ...
/* * Clear potential errors resulting from auto-calibration. * If not done, then we could get an interrupt later on when * exceptions are enabled. */ set_mcsr(get_mcsr());
Hard to tell, if you experience the same problem, since we have little information about your platform (which DDR3 core is used etc).
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Hi Stefan,
Thanks.
Shall I need to add sleep() command in the interrupt_init or before it?
I am using Samsung M391B2873EH1-CH9 series 1 GB DDR3 and Denali controller is being used for driving DDR3.
Regards, Prakash
On Tue, May 4, 2010 at 8:04 PM, Stefan Roese sr@denx.de wrote:
Hi Prakash,
0x00000400
return (0);
hangs.
Cheers, Stefan
Hi Prakash,
No. What I meant, was that you should try the "sleep" command on the U-Boot prompt, to check, if the timer is working or not. Check if a "sleep 3" really takes 3 seconds to return to the prompt.
OK. It would be good if you would contribute your Denali code back to mainline U-Boot.
Cheers, Stefan
Hi Stefan,
U-Boot
really
I commented he MSR_EE in interrupt_init function in cpu/ppc4xx/interrupts.c to run the u-boot and to get u-boot prompt.
when I executed "sleep 3 " command it doesn't reurns to prompt. It seems that it hangs in while loop or hangs somewhere else. what does it mean?
Regards, Prakash
On Tue, May 4, 2010 at 9:08 PM, Stefan Roese sr@denx.de wrote:
Hi Prakash,
controller
Cheers, Stefan
That means, that the timer is not running at all. Since you disabled the interrupts in the MSR register.
You need to solve the problem with the hanging trap, most likely resulting from the DDR3 setup code.
Cheers, Stefan
Hi Stefan,
But, my DDR3 initialization seems to be completed and I am not getting any error in DDR3 initialization.
Another issue I am facing that if I add 2 pritinf functions before or after DDR initialization the DDR3 initialization code hangs in between and if I remove the printf functions, everything is working fine and after disabling the EE bit I am able to see the u-boot proopt This is not desired and I am looking in that problem.
if I replace the printf whith udelay(5) then also I am facing same issue.
In BDI3000 debugger I am seeing that after set_timer(0) function in cpu/ppc4xx/board.c when I execute next fucntion /* Initialize from environment */ if ((s = getenv ("loadaddr")) != NULL) { ... } then u-boot hangs in between during the execution of getenv(..) function. What may be the reason?
Which registers I should see to check the address of instruction which causes exception?
Regards, Prakash On Wed, May 5, 2010 at 5:22 PM, Stefan Roese sr@denx.de wrote:
Cheers, Stefan
prakash bedge
Stefan Roese
