[U-Boot] [RFC PATCH 0/3] ARM: omap3: beagle, evm: synchronize common setup
This short series is an attempt to make this set of boards use the same default configuration items where possible. This was prompted by an investigation into enabling SERIAL_SEARCH_ALL on omap3_evm. This feature now works for omap3_evm after this series.
The 'RFC' is because of changes in the default NAND layout of MTDPARTS_DEFAULT and using ENV_IS_IN_FAT. More detail is provided with the patches. As most things are configurable now, this should not be an issue. I am trying to get simple defaults that just boot and expose the common core features.
Derald D. Woods (3): ARM: omap3: beagle: Set 'mtdids' and 'mtdparts' in board file ARM: omap3: beagle: Enable DM_SERIAL, update distro usage and NAND layout ARM: omap3: evm: Sync with omap3_beagle configuration
board/ti/beagle/beagle.c | 8 ++ configs/omap3_beagle_defconfig | 29 ++++- configs/omap3_evm_defconfig | 25 +++-- include/configs/omap3_beagle.h | 241 +++++++++++++++++++++++------------------ include/configs/omap3_evm.h | 71 +++++++----- 5 files changed, 220 insertions(+), 154 deletions(-)
BeagleBoard 'xM' does not really have NAND. CONFIG_MTDIDS_DEFAULT and CONFIG_MTDPARTS_DEFAULT can/should be empty for 'xM'. This commit sets the defined values if they exist.
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- board/ti/beagle/beagle.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index d8402f2675..1d55264733 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -521,6 +521,14 @@ int misc_init_r(void) if (generate_fake_mac) omap_die_id_usbethaddr();
+#if defined(CONFIG_MTDIDS_DEFAULT) && defined(CONFIG_MTDPARTS_DEFAULT) + if (strlen(CONFIG_MTDIDS_DEFAULT)) + env_set("mtdids", CONFIG_MTDIDS_DEFAULT); + + if (strlen(CONFIG_MTDPARTS_DEFAULT)) + env_set("mtdparts", CONFIG_MTDPARTS_DEFAULT); +#endif + return 0; }
This commit does the following for BeagleBoard{-xM}:
- Enable DM_SERIAL which also enables SPL_DM_SERIAL - Misc. config updates in support of DM_SERIAL - Use CONFIG_ENV_IS_IN_FAT because BeagleBoard-xM has no NAND - Use updated NAND layout (BeagleBoard):
device nand0 <omap2-nand.0>, # parts = 6
#: name size offset ------------------------------------------------- 0: spl 0x00080000(512k) 0x00000000 1: u-boot 0x001e0000(1920k) 0x00080000 2: u-boot-env 0x00020000(128k) 0x00260000 3: dtb 0x00020000(128k) 0x00280000 4: kernel 0x00600000(6m) 0x002a0000 5: rootfs 0x0f760000(-) 0x008a0000 -------------------------------------------------
- Use MMC and UBIFS support from config_distro_bootcmd.h - Use LEGACY_MMC and NAND support defined in omap3_beagle.h
[MMC(0:1)/extlinux/extlinux.conf] ---8<------------------------------------------------------------------- default omap3-beagle-mmc-fat label omap3-beagle-mmc-fat kernel /zImage fdt /omap3-beagle.dtb append console=ttyO2,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait ---8<-------------------------------------------------------------------
[LEGACY_MMC(0:2)/boot/extlinux/extlinux.conf] ---8<------------------------------------------------------------------- default omap3-beagle-mmc-ext4 label omap3-beagle-mmc-ext4 kernel /boot/zImage fdt /boot/omap3-beagle.dtb append console=ttyO2,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait ---8<-------------------------------------------------------------------
[UBIFS(ubi0:rootfs)/boot/extlinux/extlinux.conf] ---8<------------------------------------------------------------------- default omap3-beagle-nand-ubifs label omap3-beagle-nand-ubifs kernel /boot/zImage fdt /boot/omap3-beagle.dtb append console=ttyO2,115200n8 root=ubi0:rootfs rw ubi.mtd=rootfs rootfstype=ubifs rootwait ---8<-------------------------------------------------------------------
The board's 'bootcmd' can also be overridden with:
CONFIG_BOOTCOMMAND="run findfdt; run mmcboot" CONFIG_BOOTCOMMAND="run findfdt; run nandboot" CONFIG_BOOTCOMMAND="run findfdt; run ramboot"
or
CONFIG_BOOTCOMMAND="run findfdt; run somethingelse"
The use of 'run findfdt' is required.
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- configs/omap3_beagle_defconfig | 29 ++++- include/configs/omap3_beagle.h | 241 +++++++++++++++++++++++------------------ 2 files changed, 157 insertions(+), 113 deletions(-)
diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index f0169a4544..51e1976899 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -4,32 +4,43 @@ CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_OMAP3_BEAGLE=y CONFIG_DEFAULT_DEVICE_TREE="omap3-beagle" CONFIG_DISTRO_DEFAULTS=y -# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-beagle.dtb" CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y +# CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y +CONFIG_SYS_PROMPT="BeagleBoard # " CONFIG_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_CMD_SPL=y -CONFIG_CMD_SPL_NAND_OFS=0x240000 +CONFIG_CMD_SPL_NAND_OFS=0x280000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=nand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot-env),4m(kernel),-(fs)" +CONFIG_CMD_FS_UUID=y +CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(spl),1920k(u-boot),128k(u-boot-env),128k(dtb),6m(kernel),-(rootfs)" +CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_SPL_PARTITION_UUIDS=y CONFIG_OF_CONTROL=y -CONFIG_ENV_IS_IN_NAND=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_SPL_DM=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=1 @@ -45,11 +56,15 @@ CONFIG_LED_STATUS_CMD=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OMAP3=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_OMAP2PLUS=y CONFIG_TWL4030_USB=y @@ -65,3 +80,5 @@ CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_FAT_WRITE=y CONFIG_BCH=y +CONFIG_SPL_OF_LIBFDT=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index d3dfe60bb0..c992485af8 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -12,7 +12,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */
#include <configs/ti_omap3_common.h>
@@ -47,22 +47,17 @@ #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 -#define CONFIG_ENV_IS_IN_NAND 1 -#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_SYS_ENV_SECT_SIZE SZ_128K #define CONFIG_ENV_OFFSET 0x260000 #define CONFIG_ENV_ADDR 0x260000 #define CONFIG_ENV_OVERWRITE #define CONFIG_MTD_PARTITIONS /* required for UBI partition support */ /* NAND: SPL falcon mode configs */ #if defined(CONFIG_SPL_OS_BOOT) -#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x2a0000 #endif /* CONFIG_SPL_OS_BOOT */ #endif /* CONFIG_NAND */
-/* MUSB */ -#define CONFIG_USB_OMAP3 - /* USB EHCI */ #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 147
@@ -75,88 +70,77 @@ /* TWL4030 LED Support */ #define CONFIG_TWL4030_LED
+/* Environment */ +#define CONFIG_ENV_SIZE SZ_128K + +#define CONFIG_PREBOOT "usb start" + +#include <config_distro_defaults.h> + +#define MEM_LAYOUT_ENV_SETTINGS \ + DEFAULT_LINUX_BOOT_ENV + +#define BOOTENV_DEV_LEGACY_MMC(devtypeu, devtypel, instance) \ + "bootcmd_" #devtypel #instance "=" \ + "setenv mmcdev " #instance "; " \ + "run mmcboot\0" +#define BOOTENV_DEV_NAME_LEGACY_MMC(devtypeu, devtypel, instance) \ + #devtypel #instance " " + +#if defined(CONFIG_NAND) + +#define BOOTENV_DEV_NAND(devtypeu, devtypel, instance) \ + "bootcmd_" #devtypel #instance "=" \ + "if test ${mtdids} = '' || test ${mtdparts} = '' ; then " \ + "echo NAND boot disabled: No mtdids and/or mtdparts; " \ + "else " \ + "run nandboot; " \ + "fi\0" +#define BOOTENV_DEV_NAME_NAND(devtypeu, devtypel, instance) \ + #devtypel #instance " " + #define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) - -#define CONFIG_BOOTCOMMAND \ - "run findfdt; " \ - "run distro_bootcmd; " \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "if run userbutton; then " \ - "setenv bootenv uEnv.txt;" \ - "else " \ - "setenv bootenv user.txt;" \ - "fi;" \ - "echo SD/MMC found on device ${mmcdev};" \ - "if run loadbootenv; then " \ - "echo Loaded environment from ${bootenv};" \ - "run importbootenv;" \ - "fi;" \ - "if test -n $uenvcmd; then " \ - "echo Running uenvcmd ...;" \ - "run uenvcmd;" \ - "fi;" \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loadimage; then " \ - "run loadfdt;" \ - "run mmcboot;" \ - "fi;" \ - "fi; " \ - "fi;" \ - "run nandboot;" \ - "setenv bootfile zImage;" \ - "if run loadimage; then " \ - "run loadfdt;" \ - "run mmcbootz; " \ - "fi; " \ + func(MMC, mmc, 0) \ + func(LEGACY_MMC, legacy_mmc, 0) \ + func(UBIFS, ubifs, 0) \ + func(NAND, nand, 0) + +#else /* !CONFIG_NAND */ + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(LEGACY_MMC, legacy_mmc, 0) + +#endif /* CONFIG_NAND */
#include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \ - DEFAULT_LINUX_BOOT_ENV \ + MEM_LAYOUT_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_high=0xffffffff\0" \ - "usbtty=cdc_acm\0" \ - "bootfile=uImage\0" \ - "ramdisk=ramdisk.gz\0" \ + "console=ttyO2,115200n8\0" \ "bootdir=/boot\0" \ + "bootenv=uEnv.txt\0" \ + "bootfile=zImage\0" \ "bootpart=0:2\0" \ - "console=ttyO2,115200n8\0" \ + "bootubivol=rootfs\0" \ + "bootubipart=rootfs\0" \ + "usbtty=cdc_acm\0" \ "mpurate=auto\0" \ "buddy=none\0" \ - "optargs=\0" \ "camera=none\0" \ "vram=12M\0" \ "dvimode=640x480MR-16@60\0" \ "defaultdisplay=dvi\0" \ - "mmcdev=0\0" \ - "mmcroot=/dev/mmcblk0p2 rw\0" \ - "mmcrootfstype=ext4 rootwait\0" \ - "nandroot=ubi0:rootfs ubi.mtd=4\0" \ - "nandrootfstype=ubifs\0" \ - "ramroot=/dev/ram0 rw ramdisk_size=65536 initrd=0x81000000,64M\0" \ - "ramrootfstype=ext2\0" \ - "mmcargs=setenv bootargs console=${console} " \ - "${optargs} " \ + "defaultargs=setenv defargs " \ "mpurate=${mpurate} " \ "buddy=${buddy} "\ "camera=${camera} "\ "vram=${vram} " \ "omapfb.mode=dvi:${dvimode} " \ - "omapdss.def_disp=${defaultdisplay} " \ - "root=${mmcroot} " \ - "rootfstype=${mmcrootfstype}\0" \ - "nandargs=setenv bootargs console=${console} " \ - "${optargs} " \ - "mpurate=${mpurate} " \ - "buddy=${buddy} "\ - "camera=${camera} "\ - "vram=${vram} " \ - "omapfb.mode=dvi:${dvimode} " \ - "omapdss.def_disp=${defaultdisplay} " \ - "root=${nandroot} " \ - "rootfstype=${nandrootfstype}\0" \ + "omapdss.def_disp=${defaultdisplay}\0" \ + "optargs=\0" \ "findfdt=" \ "if test $beaglerev = AxBx; then " \ "setenv fdtfile omap3-beagle.dtb; fi; " \ @@ -169,49 +153,92 @@ "if test $beaglerev = xMC; then " \ "setenv fdtfile omap3-beagle-xm.dtb; fi; " \ "if test $fdtfile = undefined; then " \ - "echo WARNING: Could not determine device tree to use; fi; \0" \ + "echo WARNING: Could not determine device tree to use; fi\0" \ + "mmcdev=0\0" \ + "mmcpart=2\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "mmcrootfstype=ext4 rootwait\0" \ + "mmcargs=run defaultargs; setenv bootargs console=${console} " \ + "${mtdparts} " \ + "${defargs} " \ + "${optargs} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "userbutton_xm=gpio input 4;\0" \ + "userbutton_nonxm=gpio input 7;\0" \ + "userbutton=if gpio input 173; then " \ + "run userbutton_xm; " \ + "else " \ + "run userbutton_nonxm; " \ + "fi;\0" \ + "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ + "ext4bootenv=ext4load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootenv}\0" \ + "importbootenv=echo Importing environment from mmc${mmcdev} ...; " \ + "env import -t ${loadaddr} ${filesize}\0" \ + "mmcbootenv=setenv bootpart ${mmcdev}:${mmcpart}; " \ + "mmc dev ${mmcdev}; " \ + "if mmc rescan; then " \ + "if run userbutton; then " \ + "setenv bootenv uEnv.txt;" \ + "else " \ + "setenv bootenv user.txt;" \ + "fi;" \ + "run loadbootenv && run importbootenv; " \ + "run ext4bootenv && run importbootenv; " \ + "if test -n $uenvcmd; then " \ + "echo Running uenvcmd ...; " \ + "run uenvcmd; " \ + "fi; " \ + "fi\0" \ "validatefdt=" \ "if test $beaglerev = xMAB; then " \ "if test ! -e mmc ${bootpart} ${bootdir}/${fdtfile}; then " \ "setenv fdtfile omap3-beagle-xm.dtb; " \ "fi; " \ "fi; \0" \ - "bootenv=uEnv.txt\0" \ - "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ - "importbootenv=echo Importing environment from mmc ...; " \ - "env import -t -r $loadaddr $filesize\0" \ - "ramargs=setenv bootargs console=${console} " \ + "loadimage=ext4load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootfile}\0" \ + "loaddtb=run validatefdt; ext4load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \ + "mmcboot=run mmcbootenv; " \ + "if run loadimage && run loaddtb; then " \ + "echo Booting ${bootdir}/${bootfile} from mmc ${bootpart} ...; " \ + "run mmcargs; " \ + "if test ${bootfile} = uImage; then " \ + "bootm ${loadaddr} - ${fdtaddr}; " \ + "fi; " \ + "if test ${bootfile} = zImage; then " \ + "bootz ${loadaddr} - ${fdtaddr}; " \ + "fi; " \ + "fi\0" \ + "nandroot=ubi0:rootfs ubi.mtd=rootfs rw\0" \ + "nandrootfstype=ubifs rootwait\0" \ + "nandargs=run defaultargs; setenv bootargs console=${console} " \ + "${mtdparts} " \ + "${defargs} " \ "${optargs} " \ - "mpurate=${mpurate} " \ - "buddy=${buddy} "\ - "vram=${vram} " \ - "omapfb.mode=dvi:${dvimode} " \ - "omapdss.def_disp=${defaultdisplay} " \ - "root=${ramroot} " \ - "rootfstype=${ramrootfstype}\0" \ - "loadramdisk=load mmc ${bootpart} ${rdaddr} ${bootdir}/${ramdisk}\0" \ - "loadimage=load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootfile}\0" \ - "loadbootscript=load mmc ${mmcdev} ${loadaddr} boot.scr\0" \ - "bootscript=echo Running bootscript from mmc${mmcdev} ...; " \ - "source ${loadaddr}\0" \ - "loadfdt=run validatefdt; load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \ - "mmcboot=echo Booting ${bootfile} with DT from mmc${mmcdev} ...; " \ - "run mmcargs; " \ - "bootm ${loadaddr} - ${fdtaddr}\0" \ - "mmcbootz=echo Booting ${bootfile} with DT from mmc${mmcdev} ...; " \ - "run mmcargs; " \ - "bootz ${loadaddr} - ${fdtaddr}\0" \ - "nandboot=echo Booting from nand ...; " \ - "run nandargs; " \ - "nand read ${loadaddr} 280000 400000; " \ - "bootm ${loadaddr}\0" \ - "ramboot=echo Booting from ramdisk ...; " \ - "run ramargs; " \ - "bootm ${loadaddr}\0" \ - "userbutton=if gpio input 173; then run userbutton_xm; " \ - "else run userbutton_nonxm; fi;\0" \ - "userbutton_xm=gpio input 4;\0" \ - "userbutton_nonxm=gpio input 7;\0" \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "nandboot=if nand read ${loadaddr} kernel && nand read ${fdtaddr} dtb; then " \ + "echo Booting uImage from NAND MTD 'kernel' partition ...; " \ + "run nandargs; " \ + "bootm ${loadaddr} - ${fdtaddr}; " \ + "fi\0" \ + "loadramdisk=ext4load mmc ${bootpart} ${rdaddr} ${bootdir}/${ramdisk}\0" \ + "ramdisk=rootfs.ext2.gz.uboot\0" \ + "ramdisk_size=16384\0" \ + "ramroot=/dev/ram rw\0" \ + "ramrootfstype=ext2\0" \ + "ramargs=run defaultargs; setenv bootargs console=${console} " \ + "${mtdparts} " \ + "${defargs} " \ + "${optargs} " \ + "root=${ramroot} ramdisk_size=${ramdisk_size} " \ + "rootfstype=${ramrootfstype}\0" \ + "ramboot=run mmcbootenv; " \ + "if run loadimage && run loaddtb && run loadramdisk; then " \ + "echo Booting ${bootdir}/${bootfile} from mmc ${bootpart} w/ramdisk ...; " \ + "run ramargs; " \ + "bootz ${loadaddr} ${rdaddr} ${fdtaddr}; " \ + "fi\0" \ BOOTENV
#endif /* __CONFIG_H */
This commit does the following for OMAP3 EVM:
- Track omap3_beagle changes where possible - Remove CONFIG_SYS_MPUCLK and CONFIG_MTD which are not needed for the default board configuration to work. - Remove CONFIG_SPL_SYS_MALLOC_SIMPLE and CONFIG_SYS_MALLOC_F_LEN from default config. CONFIG_SYS_MALLOC_F_LEN=0x400 is set by configuration automatically. [allows board to boot with SERIAL_SEARCH_ALL=y] - Use CONFIG_ENV_IS_IN_FAT because of development flexibility - Use updated NAND layout:
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- configs/omap3_evm_defconfig | 25 +++++++++------- include/configs/omap3_evm.h | 71 ++++++++++++++++++++++++++------------------- 2 files changed, 55 insertions(+), 41 deletions(-)
diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 34998777a0..6ed470fe1e 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -1,22 +1,22 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80100000 -CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_SYS_MPUCLK=720 CONFIG_TARGET_OMAP3_EVM=y CONFIG_DEFAULT_DEVICE_TREE="omap3-evm" CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-evm.dtb" CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_ENV_SUPPORT=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="OMAP3_EVM # " -# CONFIG_CMD_IMI is not set +CONFIG_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x82000000 +CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x280000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -30,23 +30,27 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_UUID=y CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(spl),1792k(u-boot),128k(dtb),128k(u-boot-env),6m(kernel),-(rootfs)" +CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(spl),1920k(u-boot),128k(u-boot-env),128k(dtb),6m(kernel),-(rootfs)" CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set CONFIG_SPL_PARTITION_UUIDS=y CONFIG_OF_CONTROL=y -CONFIG_ENV_IS_IN_NAND=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SPL_DM=y CONFIG_MMC_OMAP_HS=y -CONFIG_MTD=y CONFIG_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y CONFIG_NETDEVICES=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x2C000000 CONFIG_SMC911X_32_BIT=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y @@ -54,14 +58,13 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_OMAP3=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_OMAP2PLUS=y +CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0x5678 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_FAT_WRITE=y CONFIG_BCH=y -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_SPL_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index c143c5af5c..d74be94c79 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -56,26 +56,20 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 -#define CONFIG_ENV_IS_IN_NAND 1 -#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_SYS_ENV_SECT_SIZE SZ_128K #define CONFIG_ENV_OFFSET 0x260000 #define CONFIG_ENV_ADDR 0x260000 #define CONFIG_ENV_OVERWRITE #define CONFIG_MTD_PARTITIONS /* required for UBI partition support */ /* NAND: SPL falcon mode configs */ #if defined(CONFIG_SPL_OS_BOOT) -#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x2a0000 #endif /* CONFIG_SPL_OS_BOOT */ #endif /* CONFIG_NAND */
-/* MUSB */ - -/* USB EHCI */ -#define CONFIG_SYS_USB_FAT_BOOT_PARTITION 1 - /* Environment */ +#define CONFIG_ENV_SIZE SZ_128K + #define CONFIG_PREBOOT "usb start"
#include <config_distro_defaults.h> @@ -83,26 +77,39 @@ #define MEM_LAYOUT_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV
-#define BOOTENV_DEV_NAND(devtypeu, devtypel, instance) \ - "bootcmd_" #devtypel #instance "=" \ - "run nandboot\0" -#define BOOTENV_DEV_NAME_NAND(devtypeu, devtypel, instance) \ - #devtypel #instance " " - #define BOOTENV_DEV_LEGACY_MMC(devtypeu, devtypel, instance) \ "bootcmd_" #devtypel #instance "=" \ "setenv mmcdev " #instance "; " \ - "setenv bootpart " #instance ":${mmcpart} ; " \ "run mmcboot\0" #define BOOTENV_DEV_NAME_LEGACY_MMC(devtypeu, devtypel, instance) \ #devtypel #instance " "
+#if defined(CONFIG_NAND) + +#define BOOTENV_DEV_NAND(devtypeu, devtypel, instance) \ + "bootcmd_" #devtypel #instance "=" \ + "if test ${mtdids} = '' || test ${mtdparts} = '' ; then " \ + "echo NAND boot disabled: No mtdids and/or mtdparts; " \ + "else " \ + "run nandboot; " \ + "fi\0" +#define BOOTENV_DEV_NAME_NAND(devtypeu, devtypel, instance) \ + #devtypel #instance " " + #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ func(LEGACY_MMC, legacy_mmc, 0) \ func(UBIFS, ubifs, 0) \ func(NAND, nand, 0)
+#else /* !CONFIG_NAND */ + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(LEGACY_MMC, legacy_mmc, 0) + +#endif /* CONFIG_NAND */ + #include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \ @@ -111,31 +118,29 @@ "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ "fdt_high=0xffffffff\0" \ + "console=ttyO0,115200n8\0" \ "bootdir=/boot\0" \ "bootenv=uEnv.txt\0" \ "bootfile=zImage\0" \ + "bootpart=0:2\0" \ "bootubivol=rootfs\0" \ "bootubipart=rootfs\0" \ "optargs=\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ - "bootpart=${mmcdev}:${mmcpart}\0" \ - "console=ttyO0,115200n8\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "mmcrootfstype=ext4 rootwait\0" \ "mmcargs=setenv bootargs console=${console} " \ "${mtdparts} " \ "${optargs} " \ - "root=/dev/mmcblk0p2 rw " \ - "rootfstype=ext4 rootwait\0" \ - "nandargs=setenv bootargs console=${console} " \ - "${mtdparts} " \ - "${optargs} " \ - "root=ubi0:rootfs rw ubi.mtd=rootfs noinitrd " \ - "rootfstype=ubifs rootwait\0" \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ "ext4bootenv=ext4load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootenv}\0" \ - "importbootenv=echo Importing environment from mmc ...; " \ + "importbootenv=echo Importing environment from mmc${mmcdev} ...; " \ "env import -t ${loadaddr} ${filesize}\0" \ - "mmcbootenv=mmc dev ${mmcdev}; " \ + "mmcbootenv=setenv bootpart ${mmcdev}:${mmcpart}; " \ + "mmc dev ${mmcdev}; " \ "if mmc rescan; then " \ "run loadbootenv && run importbootenv; " \ "run ext4bootenv && run importbootenv; " \ @@ -157,8 +162,14 @@ "bootz ${loadaddr} - ${fdtaddr}; " \ "fi; " \ "fi\0" \ - "nandboot=" \ - "if nand read ${loadaddr} kernel && nand read ${fdtaddr} dtb; then " \ + "nandroot=ubi0:rootfs ubi.mtd=rootfs rw noinitrd\0" \ + "nandrootfstype=ubifs rootwait\0" \ + "nandargs=setenv bootargs console=${console} " \ + "${mtdparts} " \ + "${optargs} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "nandboot=if nand read ${loadaddr} kernel && nand read ${fdtaddr} dtb; then " \ "echo Booting uImage from NAND MTD 'kernel' partition ...; " \ "run nandargs; " \ "bootm ${loadaddr} - ${fdtaddr}; " \
The series changes the default NAND layout of MTDPARTS_DEFAULT and uses ENV_IS_IN_FAT. More detail is provided with the patches. As most things are configurable now, this should not be an issue. I am trying to get simple defaults that just boot and expose the common core features. This will make future testing and maintenance a bit more predictable, as there will be a very similar comparable set of boards.
v2: - update cover letter and remove 'RFC' from series - rebase and test on recent master
or
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- configs/omap3_beagle_defconfig | 29 +++-- include/configs/omap3_beagle.h | 239 +++++++++++++++++++++++------------------ 2 files changed, 155 insertions(+), 113 deletions(-)
diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index f0169a4544..51e1976899 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -4,32 +4,43 @@ CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_OMAP3_BEAGLE=y CONFIG_DEFAULT_DEVICE_TREE="omap3-beagle" CONFIG_DISTRO_DEFAULTS=y -# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-beagle.dtb" CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y +# CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y +CONFIG_SYS_PROMPT="BeagleBoard # " CONFIG_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_CMD_SPL=y -CONFIG_CMD_SPL_NAND_OFS=0x240000 +CONFIG_CMD_SPL_NAND_OFS=0x280000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=nand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot-env),4m(kernel),-(fs)" +CONFIG_CMD_FS_UUID=y +CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(spl),1920k(u-boot),128k(u-boot-env),128k(dtb),6m(kernel),-(rootfs)" +CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_SPL_PARTITION_UUIDS=y CONFIG_OF_CONTROL=y -CONFIG_ENV_IS_IN_NAND=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_SPL_DM=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=1 @@ -45,11 +56,15 @@ CONFIG_LED_STATUS_CMD=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OMAP3=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_OMAP2PLUS=y CONFIG_TWL4030_USB=y @@ -65,3 +80,5 @@ CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_FAT_WRITE=y CONFIG_BCH=y +CONFIG_SPL_OF_LIBFDT=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index ff4e601e55..85b83521e7 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -12,7 +12,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
@@ -45,22 +45,17 @@ #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 -#define CONFIG_ENV_IS_IN_NAND 1 -#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_SYS_ENV_SECT_SIZE SZ_128K #define CONFIG_ENV_OFFSET 0x260000 #define CONFIG_ENV_ADDR 0x260000 #define CONFIG_ENV_OVERWRITE #define CONFIG_MTD_PARTITIONS /* required for UBI partition support */ /* NAND: SPL falcon mode configs */ #if defined(CONFIG_SPL_OS_BOOT) -#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x2a0000 #endif /* CONFIG_SPL_OS_BOOT */ #endif /* CONFIG_NAND */
@@ -73,88 +68,75 @@ /* TWL4030 LED Support */ #define CONFIG_TWL4030_LED
+/* Environment */ +#define CONFIG_ENV_SIZE SZ_128K + +#define CONFIG_PREBOOT "usb start" + +#define MEM_LAYOUT_ENV_SETTINGS \ + DEFAULT_LINUX_BOOT_ENV + +#define BOOTENV_DEV_LEGACY_MMC(devtypeu, devtypel, instance) \ + "bootcmd_" #devtypel #instance "=" \ + "setenv mmcdev " #instance "; " \ + "run mmcboot\0" +#define BOOTENV_DEV_NAME_LEGACY_MMC(devtypeu, devtypel, instance) \ + #devtypel #instance " " + +#if defined(CONFIG_NAND) + +#define BOOTENV_DEV_NAND(devtypeu, devtypel, instance) \ + "bootcmd_" #devtypel #instance "=" \ + "if test ${mtdids} = '' || test ${mtdparts} = '' ; then " \ + "echo NAND boot disabled: No mtdids and/or mtdparts; " \ + "else " \ + "run nandboot; " \ + "fi\0" +#define BOOTENV_DEV_NAME_NAND(devtypeu, devtypel, instance) \ + #devtypel #instance " " + #define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) - -#define CONFIG_BOOTCOMMAND \ - "run findfdt; " \ - "run distro_bootcmd; " \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "if run userbutton; then " \ - "setenv bootenv uEnv.txt;" \ - "else " \ - "setenv bootenv user.txt;" \ - "fi;" \ - "echo SD/MMC found on device ${mmcdev};" \ - "if run loadbootenv; then " \ - "echo Loaded environment from ${bootenv};" \ - "run importbootenv;" \ - "fi;" \ - "if test -n $uenvcmd; then " \ - "echo Running uenvcmd ...;" \ - "run uenvcmd;" \ - "fi;" \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loadimage; then " \ - "run loadfdt;" \ - "run mmcboot;" \ - "fi;" \ - "fi; " \ - "fi;" \ - "run nandboot;" \ - "setenv bootfile zImage;" \ - "if run loadimage; then " \ - "run loadfdt;" \ - "run mmcbootz; " \ - "fi; " \ + func(MMC, mmc, 0) \ + func(LEGACY_MMC, legacy_mmc, 0) \ + func(UBIFS, ubifs, 0) \ + func(NAND, nand, 0) + +#else /* !CONFIG_NAND */ + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(LEGACY_MMC, legacy_mmc, 0) + +#endif /* CONFIG_NAND */
#define CONFIG_EXTRA_ENV_SETTINGS \ - DEFAULT_LINUX_BOOT_ENV \ + MEM_LAYOUT_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_high=0xffffffff\0" \ - "usbtty=cdc_acm\0" \ - "bootfile=uImage\0" \ - "ramdisk=ramdisk.gz\0" \ + "console=ttyO2,115200n8\0" \ "bootdir=/boot\0" \ + "bootenv=uEnv.txt\0" \ + "bootfile=zImage\0" \ "bootpart=0:2\0" \ - "console=ttyO2,115200n8\0" \ + "bootubivol=rootfs\0" \ + "bootubipart=rootfs\0" \ + "usbtty=cdc_acm\0" \ "mpurate=auto\0" \ "buddy=none\0" \ - "optargs=\0" \ "camera=none\0" \ "vram=12M\0" \ "dvimode=640x480MR-16@60\0" \ "defaultdisplay=dvi\0" \ - "mmcdev=0\0" \ - "mmcroot=/dev/mmcblk0p2 rw\0" \ - "mmcrootfstype=ext4 rootwait\0" \ - "nandroot=ubi0:rootfs ubi.mtd=4\0" \ - "nandrootfstype=ubifs\0" \ - "ramroot=/dev/ram0 rw ramdisk_size=65536 initrd=0x81000000,64M\0" \ - "ramrootfstype=ext2\0" \ - "mmcargs=setenv bootargs console=${console} " \ - "${optargs} " \ - "mpurate=${mpurate} " \ - "buddy=${buddy} "\ - "camera=${camera} "\ - "vram=${vram} " \ - "omapfb.mode=dvi:${dvimode} " \ - "omapdss.def_disp=${defaultdisplay} " \ - "root=${mmcroot} " \ - "rootfstype=${mmcrootfstype}\0" \ - "nandargs=setenv bootargs console=${console} " \ - "${optargs} " \ + "defaultargs=setenv defargs " \ "mpurate=${mpurate} " \ "buddy=${buddy} "\ "camera=${camera} "\ "vram=${vram} " \ "omapfb.mode=dvi:${dvimode} " \ - "omapdss.def_disp=${defaultdisplay} " \ - "root=${nandroot} " \ - "rootfstype=${nandrootfstype}\0" \ + "omapdss.def_disp=${defaultdisplay}\0" \ + "optargs=\0" \ "findfdt=" \ "if test $beaglerev = AxBx; then " \ "setenv fdtfile omap3-beagle.dtb; fi; " \ @@ -167,49 +149,92 @@ "if test $beaglerev = xMC; then " \ "setenv fdtfile omap3-beagle-xm.dtb; fi; " \ "if test $fdtfile = undefined; then " \ - "echo WARNING: Could not determine device tree to use; fi; \0" \ + "echo WARNING: Could not determine device tree to use; fi\0" \ + "mmcdev=0\0" \ + "mmcpart=2\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "mmcrootfstype=ext4 rootwait\0" \ + "mmcargs=run defaultargs; setenv bootargs console=${console} " \ + "${mtdparts} " \ + "${defargs} " \ + "${optargs} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "userbutton_xm=gpio input 4;\0" \ + "userbutton_nonxm=gpio input 7;\0" \ + "userbutton=if gpio input 173; then " \ + "run userbutton_xm; " \ + "else " \ + "run userbutton_nonxm; " \ + "fi;\0" \ + "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ + "ext4bootenv=ext4load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootenv}\0" \ + "importbootenv=echo Importing environment from mmc${mmcdev} ...; " \ + "env import -t ${loadaddr} ${filesize}\0" \ + "mmcbootenv=setenv bootpart ${mmcdev}:${mmcpart}; " \ + "mmc dev ${mmcdev}; " \ + "if mmc rescan; then " \ + "if run userbutton; then " \ + "setenv bootenv uEnv.txt;" \ + "else " \ + "setenv bootenv user.txt;" \ + "fi;" \ + "run loadbootenv && run importbootenv; " \ + "run ext4bootenv && run importbootenv; " \ + "if test -n $uenvcmd; then " \ + "echo Running uenvcmd ...; " \ + "run uenvcmd; " \ + "fi; " \ + "fi\0" \ "validatefdt=" \ "if test $beaglerev = xMAB; then " \ "if test ! -e mmc ${bootpart} ${bootdir}/${fdtfile}; then " \ "setenv fdtfile omap3-beagle-xm.dtb; " \ "fi; " \ "fi; \0" \ - "bootenv=uEnv.txt\0" \ - "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ - "importbootenv=echo Importing environment from mmc ...; " \ - "env import -t -r $loadaddr $filesize\0" \ - "ramargs=setenv bootargs console=${console} " \ + "loadimage=ext4load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootfile}\0" \ + "loaddtb=run validatefdt; ext4load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \ + "mmcboot=run mmcbootenv; " \ + "if run loadimage && run loaddtb; then " \ + "echo Booting ${bootdir}/${bootfile} from mmc ${bootpart} ...; " \ + "run mmcargs; " \ + "if test ${bootfile} = uImage; then " \ + "bootm ${loadaddr} - ${fdtaddr}; " \ + "fi; " \ + "if test ${bootfile} = zImage; then " \ + "bootz ${loadaddr} - ${fdtaddr}; " \ + "fi; " \ + "fi\0" \ + "nandroot=ubi0:rootfs ubi.mtd=rootfs rw\0" \ + "nandrootfstype=ubifs rootwait\0" \ + "nandargs=run defaultargs; setenv bootargs console=${console} " \ + "${mtdparts} " \ + "${defargs} " \ "${optargs} " \ - "mpurate=${mpurate} " \ - "buddy=${buddy} "\ - "vram=${vram} " \ - "omapfb.mode=dvi:${dvimode} " \ - "omapdss.def_disp=${defaultdisplay} " \ - "root=${ramroot} " \ - "rootfstype=${ramrootfstype}\0" \ - "loadramdisk=load mmc ${bootpart} ${rdaddr} ${bootdir}/${ramdisk}\0" \ - "loadimage=load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootfile}\0" \ - "loadbootscript=load mmc ${mmcdev} ${loadaddr} boot.scr\0" \ - "bootscript=echo Running bootscript from mmc${mmcdev} ...; " \ - "source ${loadaddr}\0" \ - "loadfdt=run validatefdt; load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \ - "mmcboot=echo Booting ${bootfile} with DT from mmc${mmcdev} ...; " \ - "run mmcargs; " \ - "bootm ${loadaddr} - ${fdtaddr}\0" \ - "mmcbootz=echo Booting ${bootfile} with DT from mmc${mmcdev} ...; " \ - "run mmcargs; " \ - "bootz ${loadaddr} - ${fdtaddr}\0" \ - "nandboot=echo Booting from nand ...; " \ - "run nandargs; " \ - "nand read ${loadaddr} 280000 400000; " \ - "bootm ${loadaddr}\0" \ - "ramboot=echo Booting from ramdisk ...; " \ - "run ramargs; " \ - "bootm ${loadaddr}\0" \ - "userbutton=if gpio input 173; then run userbutton_xm; " \ - "else run userbutton_nonxm; fi;\0" \ - "userbutton_xm=gpio input 4;\0" \ - "userbutton_nonxm=gpio input 7;\0" \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "nandboot=if nand read ${loadaddr} kernel && nand read ${fdtaddr} dtb; then " \ + "echo Booting uImage from NAND MTD 'kernel' partition ...; " \ + "run nandargs; " \ + "bootm ${loadaddr} - ${fdtaddr}; " \ + "fi\0" \ + "loadramdisk=ext4load mmc ${bootpart} ${rdaddr} ${bootdir}/${ramdisk}\0" \ + "ramdisk=rootfs.ext2.gz.uboot\0" \ + "ramdisk_size=16384\0" \ + "ramroot=/dev/ram rw\0" \ + "ramrootfstype=ext2\0" \ + "ramargs=run defaultargs; setenv bootargs console=${console} " \ + "${mtdparts} " \ + "${defargs} " \ + "${optargs} " \ + "root=${ramroot} ramdisk_size=${ramdisk_size} " \ + "rootfstype=${ramrootfstype}\0" \ + "ramboot=run mmcbootenv; " \ + "if run loadimage && run loaddtb && run loadramdisk; then " \ + "echo Booting ${bootdir}/${bootfile} from mmc ${bootpart} w/ramdisk ...; " \ + "run ramargs; " \ + "bootz ${loadaddr} ${rdaddr} ${fdtaddr}; " \ + "fi\0" \ BOOTENV
#endif /* __CONFIG_H */ --
v2: - 'config_distro_defaults.h' has been removed
-- 2.16.2
diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 34998777a0..6ed470fe1e 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -1,22 +1,22 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80100000 -CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_SYS_MPUCLK=720 CONFIG_TARGET_OMAP3_EVM=y CONFIG_DEFAULT_DEVICE_TREE="omap3-evm" CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-evm.dtb" CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_ENV_SUPPORT=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="OMAP3_EVM # " -# CONFIG_CMD_IMI is not set +CONFIG_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x82000000 +CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x280000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -30,23 +30,27 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_UUID=y CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(spl),1792k(u-boot),128k(dtb),128k(u-boot-env),6m(kernel),-(rootfs)" +CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(spl),1920k(u-boot),128k(u-boot-env),128k(dtb),6m(kernel),-(rootfs)" CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set CONFIG_SPL_PARTITION_UUIDS=y CONFIG_OF_CONTROL=y -CONFIG_ENV_IS_IN_NAND=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SPL_DM=y CONFIG_MMC_OMAP_HS=y -CONFIG_MTD=y CONFIG_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y CONFIG_NETDEVICES=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x2C000000 CONFIG_SMC911X_32_BIT=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y @@ -54,14 +58,13 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_OMAP3=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_OMAP2PLUS=y +CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0x5678 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_FAT_WRITE=y CONFIG_BCH=y -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_SPL_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 1392593b9d..36bf51a1c0 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -54,51 +54,58 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 -#define CONFIG_ENV_IS_IN_NAND 1 -#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_SYS_ENV_SECT_SIZE SZ_128K #define CONFIG_ENV_OFFSET 0x260000 #define CONFIG_ENV_ADDR 0x260000 #define CONFIG_ENV_OVERWRITE #define CONFIG_MTD_PARTITIONS /* required for UBI partition support */ /* NAND: SPL falcon mode configs */ #if defined(CONFIG_SPL_OS_BOOT) -#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x2a0000 #endif /* CONFIG_SPL_OS_BOOT */ #endif /* CONFIG_NAND */
#define CONFIG_EXTRA_ENV_SETTINGS \ @@ -107,31 +114,29 @@ "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ "fdt_high=0xffffffff\0" \ + "console=ttyO0,115200n8\0" \ "bootdir=/boot\0" \ "bootenv=uEnv.txt\0" \ "bootfile=zImage\0" \ + "bootpart=0:2\0" \ "bootubivol=rootfs\0" \ "bootubipart=rootfs\0" \ "optargs=\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ - "bootpart=${mmcdev}:${mmcpart}\0" \ - "console=ttyO0,115200n8\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "mmcrootfstype=ext4 rootwait\0" \ "mmcargs=setenv bootargs console=${console} " \ "${mtdparts} " \ "${optargs} " \ - "root=/dev/mmcblk0p2 rw " \ - "rootfstype=ext4 rootwait\0" \ - "nandargs=setenv bootargs console=${console} " \ - "${mtdparts} " \ - "${optargs} " \ - "root=ubi0:rootfs rw ubi.mtd=rootfs noinitrd " \ - "rootfstype=ubifs rootwait\0" \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ "ext4bootenv=ext4load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootenv}\0" \ - "importbootenv=echo Importing environment from mmc ...; " \ + "importbootenv=echo Importing environment from mmc${mmcdev} ...; " \ "env import -t ${loadaddr} ${filesize}\0" \ - "mmcbootenv=mmc dev ${mmcdev}; " \ + "mmcbootenv=setenv bootpart ${mmcdev}:${mmcpart}; " \ + "mmc dev ${mmcdev}; " \ "if mmc rescan; then " \ "run loadbootenv && run importbootenv; " \ "run ext4bootenv && run importbootenv; " \ @@ -153,8 +158,14 @@ "bootz ${loadaddr} - ${fdtaddr}; " \ "fi; " \ "fi\0" \ - "nandboot=" \ - "if nand read ${loadaddr} kernel && nand read ${fdtaddr} dtb; then " \ + "nandroot=ubi0:rootfs ubi.mtd=rootfs rw noinitrd\0" \ + "nandrootfstype=ubifs rootwait\0" \ + "nandargs=setenv bootargs console=${console} " \ + "${mtdparts} " \ + "${optargs} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "nandboot=if nand read ${loadaddr} kernel && nand read ${fdtaddr} dtb; then " \ "echo Booting uImage from NAND MTD 'kernel' partition ...; " \ "run nandargs; " \ "bootm ${loadaddr} - ${fdtaddr}; " \
I was thinking, wouldn't we want to update the beagle code now to do env in NAND on beagleboard and env on FAT on xM? We could provide a new env_get_location() to return the right location based on board. Thanks!
I thought of that too. xM can never use NAND. So FAT is always right for it. Regular BeagleBoard(3530) can have the environment in either location. Configuration can simply handle the user preference. I did not see a reason to add any more logic into an already heavy board file. The Overo boards are equally heavy with board type logic. For now, my thinking was to allow configuration do the work.
Derald
OK, but on the other hand, xM must have an SD card inserted and vanilla does not require an SD card. So now those users need to put in an SD card. Now, I honestly don't know how big a deal that is really, so I won't nak the patches. But I do think it would be the best user experience to have classic continue to work as-is and xM to finally get functional env.
I will try to add the 'env_get_location'. So let's hold until I can push a 'v3' of the series.
The possible env locations:
ENVL_FAT ENVL_MMC ENVL_NAND ENVL_UBI
If those make sense, 'env_get_location' priority will select one of them.
Derald
Sounds good, thanks!
Using 'env_get_location' is not working with this diff:
---8<------------------------------------------------------------------ diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index 1d55264733..22e6af7bb8 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -33,6 +33,7 @@ #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <linux/usb/musb.h> +#include <environment.h> #include "beagle.h" #include <command.h>
@@ -332,6 +333,34 @@ static struct musb_hdrc_platform_data musb_plat = { }; #endif
+#if defined(CONFIG_SPL_BUILD) && \ + defined(CONFIG_ENV_IS_IN_NAND) && \ + defined(CONFIG_ENV_IS_IN_FAT) +enum env_location env_get_location(enum env_operation op, int prio) +{ + switch (prio) { + case 0: + return ENVL_FAT; + case 1: + switch (get_board_revision()) { + case REVISION_AXBX: + case REVISION_CX: + case REVISION_C4: + return ENVL_NAND; + case REVISION_XM_AB: + case REVISION_XM_C: + default: + return ENVL_FAT; + } + break; + default: + break; + } + + return ENVL_UNKNOWN; +} +#endif /* CONFIG_SPL_BUILD && CONFIG_ENV_IS_IN_{NAND,FAT} */ + /* * Routine: misc_init_r * Description: Configure board specific parts ---8<-------------------------------------------------------------------
Additionally, it will not boot without using '#if defined(CONFIG_SPL_BUILD)'. When booting on BeagleBoard-xM, I get the following:
---8<------------------------------------------------------------------- U-Boot SPL 2018.03-rc3-00033-g881e2514dd-dirty (Feb 25 2018 - 12:26:00 -0600) Trying to boot from MMC1 spl_load_image_fat_os: error reading image args, err - -2
U-Boot 2018.03-rc3-00033-g881e2514dd-dirty (Feb 25 2018 - 12:26:00 -0600)
OMAP3630/3730-GP ES1.2, CPU-OPP2, L3-200MHz, Max CPU Clock 1 GHz Model: TI OMAP3 BeagleBoard xM OMAP3 Beagle board + LPDDR/NAND I2C: ready DRAM: 256 MiB NAND: 0 MiB MMC: OMAP SD/MMC: 0 Loading Environment from FAT... *** Warning - bad CRC, using default environment
Failed (-5) Loading Environment from NAND... *** Warning - readenv() failed, using default environment
Failed (-5) Beagle xM Rev C No EEPROM on expansion board OMAP die ID: 46da00029ff800000168300f15027017 Net: usb_ether starting USB... USB0: USB EHCI 1.00 scanning bus 0 for devices... 3 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found scanning usb for ethernet devices... 1 Ethernet Device(s) found Hit any key to stop autoboot: 0 BeagleBoard-xM # env save Saving Environment to NAND... Failed (1) Saving Environment to NAND... Failed (1) Saving Environment to NAND... Failed (1) Saving Environment to NAND... Failed (1) Saving Environment to NAND... Failed (1) Saving Environment to NAND... Failed (1) ... ---8<-------------------------------------------------------------------
The configuration mix for 'env_get_location' needs some documentation and examples. The only other user is "board/sunxi/board.c". I do not have that board. This seems to be a path that is not ready to use right now. This should be handled on a separate series.
I will send a 'v3' of the series to leave CONFIG_ENV_IS_IN_NAND as the default. All other changes will remain. I will take a look at 'env_get_location' again at some later time. Right now I just want to have my three OMAP3 boards booting with similar setups.
As always, I am open to suggestions.
Derald
The series changes the default NAND layout of MTDPARTS_DEFAULT. More detail is provided with the patches. As most things are configurable now, this should not be an issue. I am trying to get simple defaults that just boot and expose the common core features. This will make future testing and maintenance a bit more predictable, as there will be a very similar and comparable set of boards.
board/ti/beagle/beagle.c | 8 ++ configs/omap3_beagle_defconfig | 25 ++++- configs/omap3_evm_defconfig | 21 ++-- include/configs/omap3_beagle.h | 239 +++++++++++++++++++++++------------------ include/configs/omap3_evm.h | 71 ++++++------ 5 files changed, 212 insertions(+), 152 deletions(-)
v3: - Leave environment in NAND
- Enable DM_SERIAL which also enables SPL_DM_SERIAL - Misc. config updates in support of DM_SERIAL - Use updated NAND layout (BeagleBoard):
or
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- configs/omap3_beagle_defconfig | 25 ++++- include/configs/omap3_beagle.h | 239 +++++++++++++++++++++++------------------ 2 files changed, 152 insertions(+), 112 deletions(-)
diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index f0169a4544..35e0b3cd84 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -4,32 +4,41 @@ CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_OMAP3_BEAGLE=y CONFIG_DEFAULT_DEVICE_TREE="omap3-beagle" CONFIG_DISTRO_DEFAULTS=y -# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-beagle.dtb" CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y +# CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y +CONFIG_SYS_PROMPT="BeagleBoard # " CONFIG_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_CMD_SPL=y -CONFIG_CMD_SPL_NAND_OFS=0x240000 +CONFIG_CMD_SPL_NAND_OFS=0x280000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=nand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot-env),4m(kernel),-(fs)" +CONFIG_CMD_FS_UUID=y +CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(spl),1920k(u-boot),128k(u-boot-env),128k(dtb),6m(kernel),-(rootfs)" +CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_SPL_PARTITION_UUIDS=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_DM=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=1 @@ -45,11 +54,15 @@ CONFIG_LED_STATUS_CMD=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OMAP3=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_OMAP2PLUS=y CONFIG_TWL4030_USB=y @@ -65,3 +78,5 @@ CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_FAT_WRITE=y CONFIG_BCH=y +CONFIG_SPL_OF_LIBFDT=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index ff4e601e55..85b83521e7 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -12,7 +12,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-- 2.16.2
#: name size offset
- Track omap3_beagle changes where possible - Remove CONFIG_SYS_MPUCLK and CONFIG_MTD which are not needed for the default board configuration to work. - Remove CONFIG_SPL_SYS_MALLOC_SIMPLE and CONFIG_SYS_MALLOC_F_LEN from default config. CONFIG_SYS_MALLOC_F_LEN=0x400 is set by configuration automatically. [allows board to boot with SERIAL_SEARCH_ALL=y] - Use updated NAND layout:
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- configs/omap3_evm_defconfig | 21 +++++++------- include/configs/omap3_evm.h | 71 ++++++++++++++++++++++++++------------------- 2 files changed, 52 insertions(+), 40 deletions(-)
diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 34998777a0..55fc944d21 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -1,22 +1,22 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80100000 -CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_SYS_MPUCLK=720 CONFIG_TARGET_OMAP3_EVM=y CONFIG_DEFAULT_DEVICE_TREE="omap3-evm" CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-evm.dtb" CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_ENV_SUPPORT=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="OMAP3_EVM # " -# CONFIG_CMD_IMI is not set +CONFIG_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x82000000 +CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x280000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -30,7 +30,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_UUID=y CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(spl),1792k(u-boot),128k(dtb),128k(u-boot-env),6m(kernel),-(rootfs)" +CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(spl),1920k(u-boot),128k(u-boot-env),128k(dtb),6m(kernel),-(rootfs)" CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set @@ -39,14 +39,16 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y CONFIG_MMC_OMAP_HS=y -CONFIG_MTD=y CONFIG_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y CONFIG_NETDEVICES=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x2C000000 CONFIG_SMC911X_32_BIT=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y @@ -54,14 +56,13 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_OMAP3=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_OMAP2PLUS=y +CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0x5678 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_FAT_WRITE=y CONFIG_BCH=y -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_SPL_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 1392593b9d..36bf51a1c0 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -54,51 +54,58 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 -#define CONFIG_ENV_IS_IN_NAND 1 -#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_SYS_ENV_SECT_SIZE SZ_128K #define CONFIG_ENV_OFFSET 0x260000 #define CONFIG_ENV_ADDR 0x260000 #define CONFIG_ENV_OVERWRITE #define CONFIG_MTD_PARTITIONS /* required for UBI partition support */ /* NAND: SPL falcon mode configs */ #if defined(CONFIG_SPL_OS_BOOT) -#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x2a0000 #endif /* CONFIG_SPL_OS_BOOT */ #endif /* CONFIG_NAND */
#: name size offset
Derald D. Woods
Derald Woods
