minor regression in U-Boot 2022.04
Hi!
I'm about to bump the U-Boot build for MediaTek MT7622 boards in OpenWrt to U-Boot 2022.04. While practially everything seems to work fine, I've noticed an error message early in the serial output which was not present in U-Boot 2022.01. It is even followed by a bunch of random characters which are different on every boot (hints to a read-out-of-bounds on uninitialzed memory or the like): serial_mtk serial@11002000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19�CC�
At another boot: serial_mtk serial@11002000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19��H�H�UI��$&L�1.04-OpenWrt-r19423-c9c2b01b84 (Apr 11 2022 - 19:25:34 +0000)
This is probably related to recent changes in dm and pinctrl, as there haven't been any changes to mtk_serial itself.
Log including ROM and ARM Trusted Firmware A serial output:
F0: 102B 0000 F6: 0000 0000 V0: 0000 0000 [0001] 00: 0000 0000 BP: 0400 0041 [0000] G0: 1190 0000 T0: 0000 02AD [000F] Jump to BL
NOTICE: BL2: v2.4(release):OpenWrt v2021-05-08-d2c75b21-2 (mt7622-snand-2ddr) NOTICE: BL2: Built : 12:03:10, Apr 11 2022 NOTICE: SPI-NAND: W25N01GV (128MB) NOTICE: BL2: Booting BL31 NOTICE: BL31: v2.4(release):OpenWrt v2021-05-08-d2c75b21-2 (mt7622-snand-2ddr) NOTICE: BL31: Built : 12:03:10, Apr 11 2022 serial_mtk serial@11002000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19�CC� U-Boot 2022.04-OpenWrt-r19423-c9c2b01b84 (Apr 11 2022 - 19:25:34 +0000)
CPU: MediaTek MT7622 Model: mt7622-bpi-r64 DRAM: 1 GiB Core: 55 devices, 18 uclasses, devicetree: separate MMC: mmc@11230000: 0, mmc@11240000: 1 Loading Environment from UBI... SPI-NAND: W25N01GV (128MB) ...
I will most likely not investigate this any further, but thought it might be good to let you know.
Best regards
Daniel
Hi Daniel,
I've also noticed this error message. It seems that some struct variables containing all zero data of the pinctrl driver are not set to const, which causes these variables to be put into .bss section, instead of .rodata section. As you know the .bss section does not exist in board_init_f stage, and its place is overlapped by dtb used by u-boot. This will result in incorrect data used by the pinctrl driver.
I'll try to fix it later.
Best Regards
Weijie
-----邮件原件----- 发件人: Daniel Golle daniel@makrotopia.org 发送时间: 2022年4月12日 6:44 收件人: u-boot@lists.denx.de; Weijie Gao (高惟杰) Weijie.Gao@mediatek.com 主题: minor regression in U-Boot 2022.04
Hi!
I'm about to bump the U-Boot build for MediaTek MT7622 boards in OpenWrt to U-Boot 2022.04. While practially everything seems to work fine, I've noticed an error message early in the serial output which was not present in U-Boot 2022.01. It is even followed by a bunch of random characters which are different on every boot (hints to a read-out-of-bounds on uninitialzed memory or the like): serial_mtk serial@11002000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 CC
At another boot: serial_mtk serial@11002000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 H H UI $&L 1.04-OpenWrt-r19423-c9c2b01b84 (Apr 11 2022 - 19:25:34 +0000)
NOTICE: BL2: v2.4(release):OpenWrt v2021-05-08-d2c75b21-2 (mt7622-snand-2ddr) NOTICE: BL2: Built : 12:03:10, Apr 11 2022 NOTICE: SPI-NAND: W25N01GV (128MB) NOTICE: BL2: Booting BL31 NOTICE: BL31: v2.4(release):OpenWrt v2021-05-08-d2c75b21-2 (mt7622-snand-2ddr) NOTICE: BL31: Built : 12:03:10, Apr 11 2022 serial_mtk serial@11002000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 CC U-Boot 2022.04-OpenWrt-r19423-c9c2b01b84 (Apr 11 2022 - 19:25:34 +0000)
Best regards
Daniel
Hi Weijie,
On Tue, Apr 12, 2022 at 01:40:00AM +0000, Weijie Gao (高惟杰) wrote:
Hi Daniel,
Any news about the gobbled serial output issue? It would be nice to update uboot-mediatek in OpenWrt to v2022.04, so MT798x patches will easily apply on top.
Cheers
Daniel
Best Regards
Weijie
Hi!
Best regards
Daniel
Hi Daniel,
It turns out that pinctrl uclass can't work properly in board_f stage. Removing pinctrl properties of uart0 node can solve this issue. I've sent a patch: https://patchwork.ozlabs.org/project/uboot/patch/20220713031639.1452-1-weiji...
Best Regards, Weijie
-----邮件原件----- 发件人: Daniel Golle daniel@makrotopia.org 发送时间: 2022年6月29日 6:44 收件人: Weijie Gao (高惟杰) Weijie.Gao@mediatek.com 抄送: u-boot@lists.denx.de; GSS_MTK_Uboot_upstream GSS_MTK_Uboot_upstream@mediatek.com 主题: Re: 回复: minor regression in U-Boot 2022.04
Hi Weijie,
Hi Daniel,
Cheers
Daniel
Best Regards
Weijie
Hi!
Best regards
Daniel
Daniel Golle
Weijie Gao (高惟杰)
