Re: [U-Boot] U-boot hangs in mtest in MPC8280 Board
On Thu, 30 Jul 2009 14:41:13 +0530 wrote
On Thu, 30 Jul 2009 12:54:31 +0530 wrote
Hello GurumurthyGowdar,
GurumurthyGowdar wrote:
i am using MPC8280 in our board which has 512MB of SDRAM i.e. from micron.
Is this board in mainline, so I can look in the Source Code?
yes this board is in mainline.only one board.
Which u-boot version?
U-boot version is 1.3.1.
Which SDRAMs?
SDRAM is MT48LC32M16A2 from Micron.
when i give command mtest only for 1MB to check memory test from U-boot, machine check and program exception is coming after 40 - 60mins later it hangs giving program check exception
Hmm... maybe problems with your SDRAMs?
if it is SDRAM problem it should not work for 1hour also i think.
Is this error shown always after 40-60 mins, not sometimes also earlier?
maximum i am able to run mtest for 1hr 30 mins. sometimes it hangs with 45mins also.
Can you boot a Linux Kernel for example?
No. our job is to only give the board with U-boot boot loader, Linux booting is done by our client.
i have checked the SDRAM configuration settings everything is fine as per the device datasheet.
please i want to know where is the problem, what is the cause for this exception. why memory test fails after 40-60mins.
error output is as attached:-
U-Boot 1.3.1 (Jul 29 2009 - 22:41:55)
MPC8260 Reset Status: External Soft, External Hard
MPC8260 Clock Configuration - Bus-to-Core Mult 5x, VCO Div 2, 60x Bus Freq 20-60 , Core Freq 100-300 - dfbrg 1, corecnf 0x1b, busdf 7, cpmdf 1, plldf 0, pllmf 7, pcidf 3 - vco_out 528000000, scc_clk 132000000, brg_clk 33000000 - cpu_clk 330000000, cpm_clk 264000000, bus_clk 66000000
CPU: MPC8260 (HiP7 Rev 14, Mask 1.0 1K49M) at 330 MHz Board: MPC8280 Based Remote IO CARD.SLN Technologies Pvt Ltd. I2C: ready DRAM: 512 MB FLASH: 256.5 MB *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: FCC2 ETHERNET RIO->mtest 0x00700000 0x00800000
Pattern 00000000 Writing... Reading... Pattern FFFFFFFF Writing... Reading... Mem error @ 0x0071E65C: found 00008F3F, expected 00008F21
Pattern FFFFEA75 Writing... Reading... Mem error @ 0x00723684: found FFFF5CB6, expected FFFF5CD4
Pattern 0000158B Writing... Reading... Pattern FFFFEA74 Writing... Reading... Pattern 0000158C Writing... Reading... Pattern FFFFEA73 Writing... NIP: 1FFA1F70 XER: 20000000 LR: 1FFA1F6C REGS: 1ffa1cf8 TRAP: 0700 DAR: 00000000 MSR: 0008b002 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFA1F6C 1FFA1DE8 EFFFFFFF 00000000 00000000 00000010 1FFF6E08 00000000 GPR08: 00000000 FFFFFFD0 00000000 00000000 1FFA1B78 FFF7FEFF 1FFFE000 1FFF44B8 GPR16: 1FFF6E08 00000000 00000000 00000000 1FFF32D0 1FFF32F8 1FFF32FC 1FFF3308 GPR24: FFFFFFFF 00000000 00000000 00000000 1FFB2228 00000000 00000000 00000000 Call backtrace: Program Check Exception
MPC8260 Reset Status: Check Stop, External Soft, External Hard
In: serial Out: serial Err: serial Net: FCC2 ETHERNET RIO->NIP: 1FFD5834 XER: 00000000 LR: 1FFD5834 REGS: 1fed8cbe TRAP: 0600 DAR: 1FED8DB6 MSR: 00003002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFD5098 1FED8DAE EFFFFFFF 1FED8DD6 1FED8ECE 00005F81 1FFD5000 1FFF7208 GPR08: 1FFF7278 F0000080 NIP: 1FFA1DCC XER: 20000000 LR: 1FFA1DCC REGS: 1fed897c TRAP: 0700 DAR: 1FED8DB6 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFA1DCC 1FED8A6C EFFFFFFF 00000000 1FED8AA0 00000010 FFFFFFFF 00000030 GPR08: 00000041 F0000088 00000000 F0000091 1FED89EC FFF7FEFF 1FFFE000 1FFF44B8 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 1FED8CAE 00000000 1FFD5098 GPR24: 1FFD5828 1FFA1DCC 1FFF094C 1FFF0958 1FED8AA0 1FFA1F6C 1FFFE994 1FED8CBE Call backtrace: Program Check Exception
NIP: 1FFE8A30 XMSR: 83002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 6A43C291 1FFA1EEE0 %lX 5B125912 1FFA96DC 000089924 1FFA201D 3D313135 GPR08: 1FFF0314 00000000 005B1259 00000000 1FFA1CB0 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000001 00000000 1FFD5098 GPR24: 1FFD57D4 1FFA1DCC 1FFA1F20 NIP: 1FFE9648 XER: 20000000 LR: 1FFE93DC REGS: 1ffa1a68 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000030 1FFA1B58 EFFFFFFF 1FFA1C1C 00000000 00000010 FFFFFFFF 00000030 GPR08: 00000041 00000000 00000000 00000002 1FFA1B60 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 1FFdA1DE0 1FFF47F8 1FFA1BD0 GPR24: 1FFA1C14 00000041 1FFF094C 00000000 1FFF47A8 1FFA1F6C 1FFFEBBC FFFFFFFF Call backtrace: Program Check Exception
Machine check in kernel mode. Caused by (from msr): regs 1ffa1df0 Unknown values in msr NIPMSR: 00003000 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000000 1FFA1EE0 EFFFFFFF 7FBF7FFF 0000003D 0000000C 1FFA201D GPR08: 1FFF0314 1FFA200C 008639FF 1FFF0314 1FFA1CB0 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 1FFA1FB4 1FFB2010 00000010 3FF92CD0 GPR24: 1FFF7154 0000000C 7FBF7FFF 0000FFFF 00000000 1FFA1FF6C 41B8E8D8 10080000 Call backtrace: machine check
NIP: 1FFE8A58 XER: 00000000 LRR: 1FFE89CC REGS: 1ffa1df0 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 007F45CB 1FFA1EE0 EFFFFFFF 37656FÿEC 1FFA8D64 0000929C 3D313135 GPR08: 1FFF0314 00000000 0037656F 7F6A0DBB 1FFA1CBB FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000001 00000000 1FFD5098 GPR24: 1FFD587C 0000000C 1FFA1F20 00000000 1FFA2008 1FFA1F6C 1FFFEB88 1FFF715C Call backtrace: Program Check Exception
NIP: 1FFE8AA8 XER: 00000000 LR: 1FFE89CC REGS: 1ffa1df0 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 0x1 ME: 1 IR/DR: 00
GPR00: FB67CEE5 1FFA1EE0 EFFFFFFF C667A66C 1FFA7D2C 0000A2DC 1FFA201D 3D313135 GPR08: 1FFF0314 00000000 00C667A6 FBD44C65 1FFA1CB0 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000001 00000000 1FFD5098 GPR24: 1FFD5700 0000000C 1FFA1F20 00000000 1FFA2008 1FFA1F6C 1FFFEB88 %lX Call backtrace: Program Check Exception
Machine check in kernel mode. Caused by (from msr): regs 1ffa1df0 Unknown values in msr NIP: 1FFE8A40 XER: 00000000 LR: 1FFE89CC REGS: 1ffa1df0 TRAP: 0200 DAR: 00000000 MSR: 00003000 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 0000A237 1FFA1EE0 EFFFFFFF 1D1527B7 1FFA35BC 0000EA4C 1FFA201D 3D313135 GPR08: 1FFF0314 1DB71064 001D1527 C23E7D6B 1FFA1CB0 FFF7FEFF 1FFFE000 cDFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000001 00000000 1FFD5098 GPR24: 1FFD57D4 0000000C 1FFA1F20 00000000 1FFA2008 1FFA1F6C 1FFdFEB88 1FFF715C Call backtrace: machine check
In: serial Out: serial Err: serial NIP: 1FFE0E78 XER: 00000000 LR: 1FFE1174 REGS: 1ffa1dd8 TRAP: 0700 DAR: 00000000 MSR: 0008b002 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFE115C 1FFA1EC8 EFFFFFFF 1FFF0CE0 00000010 00000000 00000000 00A7880D GPR08: 1FFD6E8C 1FFA200C 00000000 05309770 28000048 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000001 00000000 1FFD5098 GPR24: 1FFF7154 1FFF7154 1FFF0CE0 0000FFFF 00000010 1FFdA1F6C 1FFFE8D8 0000001C Call backtrace: Program Check Exception
NIP: 1FFE8A30 XER: 00000000 LR: 1FFE89CC REGS: 1ffa1df0 TRAP: 0700 DAR: 00000000 MSR: %ú¨þ)$ GPR00: DB7AB85A 1FFA1EE0 EFFFFFFF 1091813E 1FFA8F4C 000090B4 1FFA201D 3D313135 GPR08: 1FFF0314 00000000 00109181 00000000 1FFA1CB0 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF6DD0 0000B002 00000001 00000000 1FFD5098 GPR24: 1FFD57D4 1FFF7154 1FFA1F20 00000000 1FFA2008 1FFA1F6C 1FFFEB88 1FFF715C Call backtrace: Program Check Exception
In: serial Out: serial Err: serial Net: NIP: 1FFE1158 XER: 00000000 LR: 1FFE115C REGS: 1ffa1d80 TRAP: 0700 DAR: 00000000 MSR: 0008b002 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFE41E4 1FFA1E70 EFFFFFFF 0000003E 0000002B 0000000D 1FFB2220 1FFF7298 GPR08: 1FFF7280 1FFA200C 00000DE1 1FFB2220 1FFA1D60 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E041FFF447C 1FFF6DD0 1FFF84A8 00000001 00000000 1FFD5098 GPR24: 1FFF7154 1FFF7154 1FFF11F0 0000FFFF 00000039 1FFA1F6C 1FFFE8D8 0000003E Call backtrace: Program Check Exception
In: serial Out: serial Err: serial NIP: 1FFE1238 XER: 00000000 LR: 1FFE1238 REGS: 1ffa1d98 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFE1238 1FFA1E88 EFFFFFFF 1FFA200C 00000003 1FFA1ED8 1FFB2168 FFFFFFFF GPR08: 1FFF0314 00B2B178 00DDBA75 1FFF0314 28000048 FFF7FEFF 1FFFE000DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C Machine check in kernel mode. Caused by (from msr): regs 1ffa1a98 Unknown values in msr NIP: FFFFFFFC XER: 20000000 LR: 1FFE254C REGS: 1ffa1a98 TRAP: 0200 DAR: 00000000 MSR: 00003000 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000004 1FFA1B88 EFFFFF2E 11FFA1BBC 1FFA1BBC 00000010 FFFFFFFF 00000030 GPR08: 00000041 FFFFFFFF 00000000 00000009 1FFA1B08 FFFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 1FFA1D88 00000000 1FFD5098 GPR24: 1FFD57D4 1FFA1ED8 1FFF094C 1FFF0958 1FFA1BBC 1FFA1F6C 1FFFE994 1FFA1D98 Call backtrace: machine check
In: serial Out: serial Err: serial NIP: 1FFE41F0 XER: 00000000 LR: 1FFE41F0 REGS: 1ffa1df0 TRAP: 0600 DAR: 1FFA1F86 MSR: 0000b002 EE: 1 PR: ÿ FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFE115C 1FFA1EE0 EFFFFFFF 00000028 00000010 00000000 00000000 00A78817 GPR08: 1FFD6E8C 1FFA200C 00000000 05309770 28000048 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000001 00000000 1FFD5098 GPR24: 1FFF7154 1FFF7154 1FFF0CD4 0000FFFF 0000001D 1FFA1F6C 1FFFE8D8 00000028 Call backtrace: Alignment Exception
In: serial Out: serial Err: serial Net: FCC2 ETHERNET RIO->NIP: 1FFD7018 XER: 00000000 LR: 1FFD7014 REGS: 1ffa1b90 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFD5098 1FFA1C80 EFFFFFFF 1FFA1CA0 1FFF447C 00000000 1FFF8F18 1FFFF7268 GPR08: 1FFF7278 F0000080 00000002 F0000090 42000088 FFF7FEFF 1FFFE000 1FFF44B8 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 1FFA1C90 00000000 1FFD5098 GPR24: 1FFD7008 1FFA1DCC 1FFA1DC8 00000005 1FFFD658 1FFA1F6C 1FFFE994 1FFF447C Call backtrace: Program Check Exception
In: serial Out: serial Err: serial Net: FCC2 ETHERNETNIP: 1FFE1158 XER: 00000000 LR: 1FFE115C REGS: 1ffa1d80 TRAP: 0700 DAR: 00000000 MSR: 0008b002 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFE41E4 1FFA1E70 EFFFFFFF 00000002 1FFEFF91 00000006 1FFA1EA9 FFFFFFFF GPR08: 1FFF7280 1FFA200C FFFFFFFF F0000091 1FFA1D60 FFF7FEFF 1FFFE000 1FFF0CC4 GPR16: 1FFF1240 1FFF1214 1FFF127C 1FFA1EA0 1FFF84A8 1FFF84A8 1FFEFF8C 1FFA1EAA GPR24: 1FFF7154 1FFF7154 1FFF11D4 0000FFFF 00000000 1FFA1F6C 1FFFE8D8 00000002 Call backtrace: Program Check Exception
In: serial Out: serial Err: serial Net: FCC2 ETHERNET RIO->NIP: 1FFD7018 XER: 00000000 LR: 1FFD014 REGS: 1ffa1b90 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFD5098 1FFA1C80 EFFFFFFF 1FFA1CA0 1FFF4420 00000000 1FFF8F18 1FFF7268 GPR08: 1FFF7278 F0000080 00000002 F0000090 42000088 FFF7FEFF 1FFFE000 1FFF44B8 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFFF6DD0 00003002 1FFA1C90 00000000 1FFD5098 GPR24: 1FFD7008 1FFA1DCC 1FFA1DC8 00000005 1FFFD658 1FFA1F6C 1FFFE994 1FFF447C Call backtrace: Program Check Exception
GPR00: 1FFdD5098 1FFA1C80 EFFFFFFF 1FFA1CA0 1FFF$4420 00000000 1FFF8F18 1FFF7268 GPR08: 1FFF7278 F00ÿ00080 00000002 F0000090 42e000088 FFF7FEFF 1FFFE000 1FFF44B8 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 1FFA1C90 00000000 1FFD5098 GPR24: 1FFD7008 1FFA1DCC 1FFA1DC8 00000005 1FFdFD658 1FFA1F6C 1FFFE994 00000000 Call backtrace: Program Check Exception
In: serial Out: serial Err: serial NIP: 1FFE8AA8 XER: 00000000 LR: 1FFE89CC REGS: 1ffa1d70 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: D5E8E58F 1FFA1E60 EFFFFFFF 0CAD0496 1FFA413C 0000DECC 1FFB2168 FFFFFFFF GPR08: 1FFF0314 00000000 000CAD04 D56041E4 28000048 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 1FFA1FB4 00000003 1FFA1EDC GPR24: 1FFA1EE0 1FFA1ED8 1FFF3B9A 00000003 1FFA2008 1FFA1F6C NIP: 1FFA1EE4 XER: 20000000 LR: 1FFA1ED8 REGS: 1ffa1a70 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFA1ED8 1FFA1B60 EFFFFFFF 00000000 1FFA1B94 00000010 FFFFFFFF 00000030 GPR08: 00000041 F0000088 00000000 F0000091 1FFA1AE0 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 1FFA1D60 00000000 1FFD5098 GPR24: 1FFD57D4 1FFA1ED8 1FFF094C 1FFF0958 1FFA"1B94 1FFA1F6C 1FFFE99CE0CE8100 Call backtrace: Program Check Exception
CPU: MPC8260 (HiP7 Rev 14, Mask 1.0 1K49M) at 330 MHz Board: MPC8280 Based Remote IO CARD.SLN Technologies Pvt Ltd. I2C: ready DRAM: 512 MB FLASH: 256.5 MB *** Warning - baad CRC, using default environment
Machine check in kernel mode. Caused by (from msr): regs 1ffa1df0 Unknown values in msr NIP: 1FFE8A40 XER: 00000000 LR: 1FFE89CC REGS: 1ffa1df0 TRAP: 0200 DAR: 00000000 MSR: 00003000 EE: 0 PR: 0 FP: %x MEE: 1 IR/DR: 10
GPR00: 00008140 1FFA1EE0 EFFFFFFF 455E1CD9 1FFA30A4 0000EF64 1FFA201D 3D313135 GPR08: 1FFF0314 45DF5C75 04455E1C 6B402E54 1FFA1CB0 FFF7EFF 1FFFE000 DFFD2000 GPR16:1FFF2AB0 %X 1FFF6DD0 00003002 00000001 00000000 1FFD5098 GPR24: 1FFD57D4 1FFA1ED 1FFA1F20 00000000 1FFA2008 1FFA1F6C 1FFFEB88 1FFF715C Call backtrace: machine check
In: serial Out: serial Err: serial NIP: 1FFE41F0 XER: 00000000 LR: 1FFE41F0 REGS: 1ffa1df0 TRAP: 0600 DAR: 1FFA1F86 MSR: 0000b002 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 000
GPR00: 1FFE115C 1FFA1EE0 EFFFFFFF 0000001B 00000000 00000000 00000000 00A7880C GPR08: 1FFD6E8C 1FFA200C 00000000 05309770 28000048 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000001 00000010 1FLFD5098 GPR24: 1FFF7154 1FFF7154 1FFF0CD4 0000FFFF 00000010 1FFA1F6C %lX 0000001B Call backtrace: Alignment Exception
In: serial Out: serial Err: serial Net: FCC2 ETHERN®TNIP: 1FFE1158 XER: 00000000 LR: 1FFE115C REGS: 1ffa1d80 TRAP: 0700 DAR: 00000000 NIP: 00000034 XER: 20000000 LR: 1FFE93DC REGS: 1ffba19f8 TRAP: 0700 DAR: 00000000 MSR: 0008b002 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000000 1FFA1AE8 EFFFFFFF 1FFA1BC8 00000001 00000010 00000001 00000030 GPR08: 00000001 Machine check in kernel mode. Caused by (from msr): regs 1ffa16f8 Unknown values in msr NIP: FFFFFFFC XER: 20000000 LR: 1FFE254C REGS: 1ffa16f8 TRAP: 0200 DAR: 00000000 MSR: 0000b000 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000004 1FFA17E8 EFFFFFFF 1FFA181C 1FFA181C 00000010 FFFFFFFF 00000030 GPR08: 00000041 FFFFFFFF 00000000 00000003 1FFA1768 FFF7FEFF 1FFFE000 1FFF0CC4 GPR16: 1FFF1240 1FFF1214 NIP: 00000000 XER: 20000000 LR: 00000001 REGS: 1ffa1400 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000001 1FFA"14F0 EFFFFFFF 00000000 1FFA1524 00000010 FFFFFFFF 00000030 GPR08: 00000041 F0000088 00000000 F0000091 1FFA1470 NIP: 1FFE2548 XER: 20000000 LR: 1FFE2518 REGS: 1ffa1100 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000004 1FFA11F0 EFFFFFFF 1FFA1224 1FFA1224 00000010 FFFFFFFF 00000030 GPR08: 00000041 1FFEDA08 00000000 00000009 1FFA1170 FFF7FEFF 1FFFE000 1FFF0CC4 GPR16: 1FFF1240 1FFF1214 1FFF127C 1FFA1EA0 00003002 1FFA13F0 00000000 1FFD5098 GPR24: 1FFD57D4 00000001 1FFF094C 1FFF0958 1FFA1224 1FFA1F6C 1FFFE994 1FFA1400 Call backtrace: Program Check Exception
NIP: 1FFE8A30 XER: 00000000 LR: 1FFE899CC REGS: 1ffa1df0 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 446BA781 1FFA1EE0 EFFFFFFF 3A858DD6 1FFA9F3C 000080C4 1FFA201D 3D313135 GPR08: 1FFF0314 NIP: 1FFE9648 XER: 20000000 LR: 1FFE93DC REGS: 1ffa1a68 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000030 1FFA1B58 EFFFFFFF 1FFA1C1C 00000000 00000010 FFFFFFFF 00000030 GPR08: 00000041 00000000 00000000 00000002 1FFA1B60 FFF7FEFF 1FFFE000 DFFD2000 GPR16: 1FFF1240 1FFF1214 1FFF127C 1FFA1EA0 00003002 1FFA1DE0 1FFF47F8 1FFA1BD0 GPR24: 1FFA1C14 00000041 1FFF094C 00000000 1FFF47A8 1FFA1F6C 1FFF$EBBC FFFFFFFF Call backtraace: Program Check Exception
In: serial Out: serial Err: serial Net: FCC2 ETHERNETNIP: 1FFE41F0 XER: 00000000 LR: 1FFE41F0 REGS: 1ffa1d70 TRAP: 0600 DAR: 1FFA1F06 MSR: 0000b002 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFE115C 1FFA1E60 EFFFFFFF 0000004D 0000002B 00000006 FFFFFFFFF GPR08: 1FFF7280 1FFA200C FFFFFFFF F0000091 1FFA1D60 FFF7FEFF 1FFFE000 1FFF0CC4 GPR16: 1FFF1240 1FFF1214 1FFF127C 1FFA1EA0 1FFF84A8 1FFF84A8 1FFEFF8C 1FFA1EAA GPR24: 1FFF7154 1FFF7154 1FFF11D4 0000FFFF 00000039 NIP: 00000000 XER: 20000000 LR: 1FFE93DC REGS: 1ffa19e8 TRAP: 0700 DAR: 1FFA1F06 MSR: 0008b002 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000000 1FFA1AD8 EFFFFFFF 1FFA1B94 00000000 00000010 00000000 00000030 GPR08: 00000041 00000008 00000000 00000008 1FFA1AE0 FFF7FEFF 1FFFE000 1FFF0CC4 GPR16: 1FFF1240 1FFF1214 1FFF127C 1FFA1EA0 0000B002 1FFA1D60 1FFF47F8 1FFA1B50 GPR24: 1FFA1B94 00000041 1FFF094C 00000000 1FFF47A8 1FFA1F6C 1FFFEBBC FFFFFFFF Call backtrace: Program Check Exception
In: serial Out: serial Err: serial NIP: 1FFE1158 XER: 00000000 LR: 1FFE115C REGS: 1ffa1e00 TRAP: 0700 DAR: 00000000 MSR: 0008b002 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFE41E4 1FFA1EF0 EFFFFFFF 00000023 00000010 00000000 00000000 00A7881C GPR08: 1FFD6E8C 1FFA200C 00000000 05309770 28000048 FFF7FEFF 1FFFE02E DFFD2000 GPR16: 1FFF1240 1FFF1214 1FFF127C 1FFA1EA0 0000B002 00000001 00000000 GPR24: 1FFF7154 1FFF7154 1FFF0CE0 0000FFFF 0000001D 1FFA1F6C 1FFFE8D8 00000023 Call backtrace:
In: serial Out: serial Err: serial Net: FCC2 ETHERNET RIO->NIP: 1FFD5834 XER: 00000000 LR: 1FFD5834 REGS: 1ff391ee TRAP: 0600 DAR: 1FF392E6 MSR: 00003002 EE: PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFD5098 1FF392DE EFFFFFFF 1FF39306 1FF393FE 00005F81 1FFD5000 1FFF7268 GPR08: 1FFF7278 F0000080 00000002 F0000090 42000080 0028EE00 1FFFE000 1FFF44B8 NIP: 1FFA1F70 XER: 20000000 LR: 1FFA1F6C REGS: 1ff38ebc TRAP: 0700 DAR: 1FF392FC MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFA1F6C 1FF38FAC EFFFFFFF 00000000 1FF38FD0 00000010 FFFFFFFF FFFFFFF
In: Machine check in kernel mode. Caused by (from msr): regs 1ffa1c38 Unknown values in msr NIP: 1FFE2544 XER: 00000000 LR: 1FFE2518 REGS: 1ffa1c38 TRAP: 0200 DAR: 00000000 MSR: 00003000 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000004 1FFA1D28 EFFFFFFF 1FFA1D5C 1FFA1D5C 1FFA1D50 1FFB2168 FFFFFFFF GPR08: 1FFEDA08 00247D29 FFFFFFFF 00000006 28000048 0028EE00 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 80000022 00000001 00000000 00003002 GPR24: 1FF38CE0 1FFF80A8 00000001 1FFB2058 1FFA1D5C 1FFA1F6C 1FFFE994 1FFB2058 Call backtrace: machine check
In: serial Out: serial Err: serial Net: FCC2 ETHERNETNIP: 1FFE0E78 XER: 00000000 LR: 1FFE1174 REGS: 1ffa1d58 TRAP: 0700 DAR: 00000000 MSR: 0008b002 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFE115C 1FFA1E48 EFFFFFFF 1FFA1EAA 00000039 1FFA1E28 1FFB2220 FFFFFFFF GPR08: 1FFF7280 1FFA200C FFFFFFFF F0000091 1FFA1D60 0028EE00 1FFFE000 1FFF0CC4 GPR16: 1FFF1240 1FFF1214 1FFF127C 1FFA1EA0 1FFF84A8 1FFF84A8 1FFEFF8C 1FFA1EAA GPR24: 1FFF7154 1FFF7154 1FFA1EAA 0000FFFF 00000039 1FFA1F6C 1FFFE8D8 0000004D Call backtrace: Program Check Exception
In: serial Out: serial Err: serial Machine check in kernel mode. Caused by (from msr): regs 1ffa1df0 Unknown values in msr NIP: 1FFE4224 XER: 00000000 LR: 1FFE41F0 REGS: 1ffa1df0 TRAP: 0200 DAR: 00000000 MSR: 0000b000 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFE0ED8 1FFA1EE0 EFFFFFFF 000000BB 00000010 00000000 00000000 00A78827 GPR08: 1FFD6E8C 1FFA200C 00000000 05309770 28000048 0028EE00 1FFFE000 DFFD2000 GPR16: 1FFF1240 1FFF1214 1FFF127C 1FFA1EA0 0000B002 00000001 00000000 1FFD5098 GPR24: 1FFF7154 1FFF7154 1FFF7199 1FFF7198 000000FF 1FFA1F6C 1FFFE9F0 0000001C Call backtrace: machine check
In: serial Out: serial Err: serial Net: FCC2 ETHERNET RIO->NIP: 1FFD5834 XER: 00000000 LR: 1FFD5834 REGS: 1fce8076 TRAP: 0600 DAR: 1FCE816E MSR: 00003002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFD5098 1FCE8166 EFFFFFFF NIP: 00000000 XER: 20000000 LR: 1FFE93DC REGS: 1fce7cac TRAP: 0700 DAR: 1FCE816E MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000000 1FCE7D9C EFFFFFFF 1FCE7E58 00000000 00000010 00000000 00000030 GPR08: 00000041 00000008 00000000 00000008 1FCE7DA4 0028EE00 1FFFE000 1FFF44B8 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 1FCE8066 1FFF47F8 1FCE7E14 GPR24: 1FCE7E58 00000041 1FFF094C 00000000 1FFF47A8 1FFA1F6C 1FFFEBBC FFFFFFFF Call backtrace: NIP: 1FFE2548 XER: 00000000 LR: 1FFE2518 REGS: 1fce79bc TRAP: 7700 DAR: 1FCE816E MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000004 1FCE7AAC EFFFFFFF 1FCE7AD4 1FCE7AD4 1FCE7C0C FFFFFFFF 00000030 GPR08: 00000041 1FFEDA08 00000000 F0000091 1FCE7A1C 0028EE00 1FFFE000 1FFF44B8 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 1FCE7C9C 00000000 1FFD5098 GPR24: 1FFD57D4 00000041 1FFF094C 00000000 1FCE7AD4 1FFA1F6C 1FFFE994 FFFFFFFF Call backtrace: Program Check Exception
In: serial Out: serial Err: serial NIP: 1FFE0F18 XER: 00000000 LR: 1FFE0F08 REGS: 1ffa1dd8 TRAP: 0700 DAR: 00000000 MSR: 0008b002 EE: 1 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 1FFE1174 1FFA1EC8 EFFFFFFF 00000073 0000002B 00000000 00000000 00A78817 GPR08: 1FFD6E8C 1FFA200C 00000000 05309770 28000048 0028EE00 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000_}Õ7ï¿ïW÷_]UÕû³ë½ûÿÿï¾/¸º/ÿöþÙÝ]W¿wÝ7W¯ÿï01 00000000 1FFD5098 GPR24: 1FFF7154 1FFE41E4 FFFFFFFF 0000002B 00000000 1FFFA1F6C 1FFFE8D8 1FFFB199 Call backtrace: Program Check Exception
In: serial Out: serial Err: serial Machine check in kernel mode. Caused by (from msr): regs 1ffa1d70 Unknown values in msr NIP: 1FFE8A40 XER: 00000000 LR: 1FFE89CC REGS: 1ffa1d70 TRAP: 0200 DAR: 00000000 MSR: 00003000 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00008E93 1FFA1E60 EFFFFFFF FB5ADF2A 1FFA5D14 0000C2F4 1FFB2168 FFFFFFFF GPR08: 1FFF0314 FBD44C65 00FB5ADF 00C23E7D 28000048 0028EE00 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 1FFA1FB4 00000003 1FFA1EDC 1FFA200C GPR24: 1FFA1EE0 1FFA1ED8 1FFF3BAB 00000003 1FFA2008 1FFA1F6C 1FFFEB88 1FFA2044 Call backtrace: machine check
In: Machine check in kernel mode. Caused by (from msr): regs 1ffa1c38 Unknown values in msr NIP: 1FFE2544 XER: 00000000 LR: 1FFE2518 REGS: 1ffa1c38 TRAP: 0200 DAR: 00000000 MSR: 00003000 EEE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000004 1FFA1D28 EFFFFFFF 1FFA1D5C 1FFA1D5C 1FFA1D50 1FFB2168 FFFFFFFF GPR08: 1FFEDA08 00247D29 FFFFFFFF 00000006 28000048 0028EE00 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000001 00000000 11FFD5098 GPR24: 1FFD587C 1FFF80A8 00000001 1FFB2058 1FFdA1D5C 1FFA1F6C 1FFFE994 1FFB2058 Call backtrace: machine check
Machine check in kernel mode. Caused by (from msr): reegs 1ffa1df0 Unknown values in msr NIP: 1FFE8A40 XER: 00000000 LR: 1FFE89CC REGS: 1ffa1df0 TRAP: 0200 DAR: 00000000 MSR: 00003000 E GPPR00: _}Õ7ï¿ïW÷_]UÕû³ë½ûÿÿï¾/¸º/ÿöþÙÝ]W¿wÝ7W¯ÿï42464420 00303030 20450052 3A203030 30303030 3030204C 523A2031 GPR08: 46464538 39434320 52454753 66613164 66302054 5241503A 20303230 GPR16: 30204441 523A2030 30303030 3030300A 00EE001F FFE000DF FD20001F FF2AB01F GPR24: FF8E041F FF447C1F FFF6DD000 00300200 00000100 0000001F FD50981F FD587C1F Call backtrace: machhine check
NIP: 1FFE8AA8 XER: 00000000 LR: 1FFE89CC REGS: 1ffa1df0 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 GPR00: E3A3E210 1FFA1EE0 EFFFFFFF 7FB5CF66 1FFA6094 0000BF74 1FFA201D 3D313135 GPR08: 1FFF0314 00000000 007FB5CF E3630B12 1FFA1CB0 0028EE00 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000001 00000000 1FFDÿ5098 GPR24: 1FFD5800 1FFF80A8 1FFA1F20 00000000 1FFA202E 1FFA1F6C 1FFFEB2E 1FFF715C Call backtrace: Program Check Exception
GPR00: 00006F65 1FFA1E60 EFFFFFFF B5BFAA53 1FFAF55C 00002AAC1FFB2168 FFFFFFFF GPR08: 1FFF0314 B5D0CF31 00B5BFAA 00C23E7D 28000048 0028EE00 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E041FFF447C 1FFF6DD0 1FFA1FB4 00000003 1FFA1EDC 1FFA200C GPR24: 1FFA1EE0 1FFA1ED8 1FFF3B9A 00000003 1FFA2008 1FFA1F6C 1FFFEB88 1FFA2028 Call backtrace: machine check
Machine check in kernel mode. Caused by (from msr): regs 1ffa1df0 Unknown values in msr NIP: 1FFE8A40 XER: 00000000 LR: 1FFE89CC REGS: 1ffa1df0 TRAP: 0200 DAR: 00000000 MSR: 00003000 EE: 0 PR: GPR00: 0000A712 1FFA1EE0 EFFFFFFF 181w05544 1FFA7304 0000AD04 1FFA201D 3D313135 GPR08: 1FFF0314 18B74777 00181055 00C23E7D 1FFA1CB0 0028EE00 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000001 00000010 1FFD5098 GPR24: 1FFD58000 1FFA1ED8 1FFA1F20 00000000 1FFA2008 1FFA1F6C 1FFFEB88 1FFF$715C Call backtrace: machinne check
CPU: MPC8260 (HiP7 Rev 14, Mask 1.0 1K49M) at 330 MHz Board: MPC8280 Based Remote IO CARD.SLN Technologies Pvt Ltd. I2C: ready DRAM: 512 MB FLASH: NIP: 1FLFE97F8 XER: 00000000 LR: 1FFE973C REGS: 1ffa1c28 TRAP: 0700 DAR: 00000000 MSR: 00083002 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00000002 1FFA1D18 EFFFFFFF 1FFA1D64 1FFF4788 1FFdA1D58 00000000 006558038 GPR08: 1FFD6E8C 00000032 1FFF4789 00100000 F0003CD8 0028EE00 1FFFE000 DFFD2000 GPR16: 1FFF2AB0 1FFF8E04 1FFF447C 1FFF6DD0 00003002 00000001 1FFFF47F8 1FFA1D20 GPR24: 1FFA1D64 00000000 1FFA1F20 0000004D 1FFA1D64 1FFA1F6C 1FFFEBBC 1FFA1D58 Call backtrace: Program Check Exception
i am stuck here, dont know where to check if it hangs after 40-60mins.
Maybe a temperature problem?
not able to identify what is the exact problem tll now
do help me out in this regard,
If I can ... share more informations, and maybe I can.
please help me out if you can, let me know if any more informations required.
bye Heiko -- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
GurumurthyGowdar
