[U-Boot] [PATCH v2 0/5] Add support for Pinebook
This series adds support for the Pinebook, an allwinner A64 laptop produced by Pine64. It also syncs sun50i-a64.dtsi with linux, adds support for mmc delay calibration, R_I2C controller, and addresses the issue with activating video bridge when any of GPIOs is missing.
v2: - sync sun50i-a64.dtsi with linux instead of adding missing nodes - take sun50i-a64-pinebook.dts from linux - don't introduce new Kconfig for A64 MMC calibration - improve code in video bridge uclass to check for presensce of GPIO instead of ingoring EINVAL errors
Vasily Khoruzhick (5): mmc: sunxi: A64: add support for automatic delay calibration dm: video: bridge: don't fail to activate bridge if reset or sleep GPIO is missing sunxi: DT: A64: update device tree file for Allwinner A64 SoC sun50i: A64: add support for R_I2C controller sunxi: DT: add support for Pinebook
arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun50i-a64-pinebook.dts | 306 +++++++++++++++++++++ arch/arm/dts/sun50i-a64.dtsi | 122 ++++++-- arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/include/asm/arch-sunxi/mmc.h | 6 +- arch/arm/mach-sunxi/Kconfig | 1 + board/sunxi/board.c | 6 + configs/pinebook_defconfig | 27 ++ drivers/mmc/sunxi_mmc.c | 21 +- drivers/video/bridge/video-bridge-uclass.c | 14 +- 10 files changed, 481 insertions(+), 26 deletions(-) create mode 100644 arch/arm/dts/sun50i-a64-pinebook.dts create mode 100644 configs/pinebook_defconfig
A64 supports automatic delay calibration and Linux driver uses it instead of hardcoded delays. Add support for it to u-boot driver.
Fixes eMMC instability on Pinebook
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- arch/arm/include/asm/arch-sunxi/mmc.h | 6 +++++- drivers/mmc/sunxi_mmc.c | 21 ++++++++++++++++++++- 2 files changed, 25 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/mmc.h b/arch/arm/include/asm/arch-sunxi/mmc.h index d98c53faaa..f2deafddd2 100644 --- a/arch/arm/include/asm/arch-sunxi/mmc.h +++ b/arch/arm/include/asm/arch-sunxi/mmc.h @@ -46,7 +46,9 @@ struct sunxi_mmc { u32 cbda; /* 0x94 */ u32 res2[26]; #if defined(CONFIG_SUNXI_GEN_SUN6I) || defined(CONFIG_MACH_SUN50I_H6) - u32 res3[64]; + u32 res3[17]; + u32 samp_dl; + u32 res4[46]; #endif u32 fifo; /* 0x100 / 0x200 FIFO access address */ }; @@ -130,5 +132,7 @@ struct sunxi_mmc { #define SUNXI_MMC_COMMON_CLK_GATE (1 << 16) #define SUNXI_MMC_COMMON_RESET (1 << 18)
+#define SUNXI_MMC_CAL_DL_SW_EN (0x1 << 7) + struct mmc *sunxi_mmc_init(int sdc_no); #endif /* _SUNXI_MMC_H */ diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 39f15eb423..9e08ad59c6 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -99,11 +99,16 @@ static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) { unsigned int pll, pll_hz, div, n, oclk_dly, sclk_dly; bool new_mode = false; + bool calibrate = false; u32 val = 0;
if (IS_ENABLED(CONFIG_MMC_SUNXI_HAS_NEW_MODE) && (priv->mmc_no == 2)) new_mode = true;
+#ifdef CONFIG_MACH_SUN50I + calibrate = true; +#endif + /* * The MMC clock has an extra /2 post-divider when operating in the new * mode. @@ -174,7 +179,11 @@ static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) val = CCM_MMC_CTRL_MODE_SEL_NEW; setbits_le32(&priv->reg->ntsr, SUNXI_MMC_NTSR_MODE_SEL_NEW); #endif - } else { + } else if (!calibrate) { + /* + * Use hardcoded delay values if controller doesn't support + * calibration + */ val = CCM_MMC_CTRL_OCLK_DLY(oclk_dly) | CCM_MMC_CTRL_SCLK_DLY(sclk_dly); } @@ -228,6 +237,16 @@ static int mmc_config_clock(struct sunxi_mmc_priv *priv, struct mmc *mmc) rval &= ~SUNXI_MMC_CLK_DIVIDER_MASK; writel(rval, &priv->reg->clkcr);
+#ifdef CONFIG_MACH_SUN50I + /* A64 supports calibration of delays on MMC controller and we + * have to set delay of zero before starting calibration. + * Allwinner BSP driver sets a delay only in the case of + * using HS400 which is not supported by mainline U-Boot or + * Linux at the moment + */ + writel(SUNXI_MMC_CAL_DL_SW_EN, &priv->reg->samp_dl); +#endif + /* Re-enable Clock */ rval |= SUNXI_MMC_CLK_ENABLE; writel(rval, &priv->reg->clkcr);
- u32 res3[64];
- u32 res3[17];
- u32 samp_dl;
- u32 res4[46];
According to the Linux driver this applies to the H6 eMMC controller as well. So can you please add CONFIG_MACH_SUN50I_H6 here as well? Same below, of course.
Rest looks fine to me.
Cheers, Andre.
- calibrate = true;
- The MMC clock has an extra /2 post-divider when operating in the new
- mode.
- } else {
- } else if (!calibrate) {
* calibration
val = CCM_MMC_CTRL_OCLK_DLY(oclk_dly) | CCM_MMC_CTRL_SCLK_DLY(sclk_dly); }*/
- /* A64 supports calibration of delays on MMC controller and we
- writel(SUNXI_MMC_CAL_DL_SW_EN, &priv->reg->samp_dl);
- /* Re-enable Clock */ rval |= SUNXI_MMC_CLK_ENABLE; writel(rval, &priv->reg->clkcr);
Both GPIOs are optional, so we shouldn't fail if any is missing. Without this fix reset is not deasserted when sleep GPIO is missing.
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- drivers/video/bridge/video-bridge-uclass.c | 14 ++++++++++---- 1 file changed, 10 insertions(+), 4 deletions(-)
diff --git a/drivers/video/bridge/video-bridge-uclass.c b/drivers/video/bridge/video-bridge-uclass.c index cd4959cc71..7542097769 100644 --- a/drivers/video/bridge/video-bridge-uclass.c +++ b/drivers/video/bridge/video-bridge-uclass.c @@ -109,10 +109,16 @@ int video_bridge_set_active(struct udevice *dev, bool active) int ret;
debug("%s: %d\n", __func__, active); - ret = dm_gpio_set_value(&uc_priv->sleep, !active); - if (ret) - return ret; - if (active) { + if (uc_priv->sleep.dev) { + ret = dm_gpio_set_value(&uc_priv->sleep, !active); + if (ret) + return ret; + } + + if (!active) + return 0; + + if (uc_priv->reset.dev) { ret = dm_gpio_set_value(&uc_priv->reset, true); if (ret) return ret;
That looks much better now, thanks. One small thing:
This needs to be initialised now.
Cheers, Andre.
- if (ret)
return ret;
- if (active) {
- if (uc_priv->sleep.dev) {
if (ret)
return ret;
- if (!active)
- if (uc_priv->reset.dev) { ret = dm_gpio_set_value(&uc_priv->reset, true); if (ret) return ret;
Updates the device tree file from the the Linux tree as of v4.19-rc4, exactly Linux commit:
commit 7876320f8880 (tag: v4.19-rc4) Author: Linus Torvalds torvalds@linux-foundation.org Date: Sun Sep 16 11:52:37 2018 -0700
Linux 4.19-rc4
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- arch/arm/dts/sun50i-a64.dtsi | 122 +++++++++++++++++++++++++++++------ 1 file changed, 103 insertions(+), 19 deletions(-)
diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index 7a083637c4..d3daf90a87 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -43,9 +43,12 @@ */
#include <dt-bindings/clock/sun50i-a64-ccu.h> +#include <dt-bindings/clock/sun8i-de2.h> #include <dt-bindings/clock/sun8i-r-ccu.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/reset/sun50i-a64-ccu.h> +#include <dt-bindings/reset/sun8i-de2.h> +#include <dt-bindings/reset/sun8i-r-ccu.h>
/ { interrupt-parent = <&gic>; @@ -57,17 +60,21 @@ #size-cells = <1>; ranges;
-/* - * The pipeline mixer0-lcd0 depends on clock CLK_MIXER0 from DE2 CCU. - * However there is no support for this clock on A64 yet, so we depend - * on the upstream clocks here to keep them (and thus CLK_MIXER0) up. - */ simplefb_lcd: framebuffer-lcd { compatible = "allwinner,simple-framebuffer", "simple-framebuffer"; allwinner,pipeline = "mixer0-lcd0"; clocks = <&ccu CLK_TCON0>, - <&ccu CLK_DE>, <&ccu CLK_BUS_DE>; + <&display_clocks CLK_MIXER0>; + status = "disabled"; + }; + + simplefb_hdmi: framebuffer-hdmi { + compatible = "allwinner,simple-framebuffer", + "simple-framebuffer"; + allwinner,pipeline = "mixer1-lcd1-hdmi"; + clocks = <&display_clocks CLK_MIXER1>, + <&ccu CLK_TCON1>, <&ccu CLK_HDMI>; status = "disabled"; }; }; @@ -168,10 +175,46 @@ #size-cells = <1>; ranges;
+ de2@1000000 { + compatible = "allwinner,sun50i-a64-de2"; + reg = <0x1000000 0x400000>; + allwinner,sram = <&de2_sram 1>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1000000 0x400000>; + + display_clocks: clock@0 { + compatible = "allwinner,sun50i-a64-de2-clk"; + reg = <0x0 0x100000>; + clocks = <&ccu CLK_DE>, + <&ccu CLK_BUS_DE>; + clock-names = "mod", + "bus"; + resets = <&ccu RST_BUS_DE>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + }; + syscon: syscon@1c00000 { - compatible = "allwinner,sun50i-a64-system-controller", - "syscon"; + compatible = "allwinner,sun50i-a64-system-control"; reg = <0x01c00000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + sram_c: sram@18000 { + compatible = "mmio-sram"; + reg = <0x00018000 0x28000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x00018000 0x28000>; + + de2_sram: sram-section@0 { + compatible = "allwinner,sun50i-a64-sram-c"; + reg = <0x0000 0x28000>; + }; + }; };
dma: dma-controller@1c02000 { @@ -364,6 +407,11 @@ bias-pull-up; };
+ pwm_pin: pwm_pin { + pins = "PD22"; + function = "pwm"; + }; + rmii_pins: rmii_pins { pins = "PD10", "PD11", "PD13", "PD14", "PD17", "PD18", "PD19", "PD20", "PD22", "PD23"; @@ -474,15 +522,6 @@ status = "disabled"; };
- pwm: pwm@1c21400 { - compatible = "allwinner,sun50i-a64-pwm", - "allwinner,sun5i-a13-pwm"; - reg = <0x01c21400 0x8>; - clocks = <&osc24M>; - #pwm-cells = <3>; - status = "disabled"; - }; - uart0: serial@1c28000 { compatible = "snps,dw-apb-uart"; reg = <0x01c28000 0x400>; @@ -617,8 +656,6 @@ clocks = <&ccu CLK_BUS_EMAC>; clock-names = "stmmaceth"; status = "disabled"; - #address-cells = <1>; - #size-cells = <0>;
mdio: mdio { compatible = "snps,dwmac-mdio"; @@ -638,11 +675,25 @@ #interrupt-cells = <3>; };
+ pwm: pwm@1c21400 { + compatible = "allwinner,sun50i-a64-pwm", + "allwinner,sun5i-a13-pwm"; + reg = <0x01c21400 0x400>; + clocks = <&osc24M>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm_pin>; + #pwm-cells = <3>; + status = "disabled"; + }; + rtc: rtc@1f00000 { compatible = "allwinner,sun6i-a31-rtc"; reg = <0x01f00000 0x54>; interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + clock-output-names = "rtc-osc32k", "rtc-osc32k-out"; + clocks = <&osc32k>; + #clock-cells = <1>; };
r_intc: interrupt-controller@1f00c00 { @@ -664,6 +715,29 @@ #reset-cells = <1>; };
+ r_i2c: i2c@1f02400 { + compatible = "allwinner,sun50i-a64-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x01f02400 0x400>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu CLK_APB0_I2C>; + resets = <&r_ccu RST_APB0_I2C>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + r_pwm: pwm@1f03800 { + compatible = "allwinner,sun50i-a64-pwm", + "allwinner,sun5i-a13-pwm"; + reg = <0x01f03800 0x400>; + clocks = <&osc24M>; + pinctrl-names = "default"; + pinctrl-0 = <&r_pwm_pin>; + #pwm-cells = <3>; + status = "disabled"; + }; + r_pio: pinctrl@1f02c00 { compatible = "allwinner,sun50i-a64-r-pinctrl"; reg = <0x01f02c00 0x400>; @@ -675,6 +749,16 @@ interrupt-controller; #interrupt-cells = <3>;
+ r_i2c_pins_a: i2c-a { + pins = "PL8", "PL9"; + function = "s_i2c"; + }; + + r_pwm_pin: pwm { + pins = "PL10"; + function = "s_pwm"; + }; + r_rsb_pins: rsb { pins = "PL0", "PL1"; function = "s_rsb";
Linux 4.19-rc4
+CC Jernej
- The pipeline mixer0-lcd0 depends on clock CLK_MIXER0 from DE2 CCU.
- However there is no support for this clock on A64 yet, so we depend
- on the upstream clocks here to keep them (and thus CLK_MIXER0) up.
}; };<&ccu CLK_TCON1>, <&ccu CLK_HDMI>; status = "disabled";
de2@1000000 {
#size-cells = <1>;
<&ccu CLK_BUS_DE>;
"bus";
#clock-cells = <1>;
#reset-cells = <1>;
- syscon: syscon@1c00000 {
"syscon";
#size-cells = <1>;
ranges;
#size-cells = <1>;
pwm_pin: pwm_pin {
pins = "PD22";
function = "pwm";
pwm: pwm@1c21400 {
clocks = <&osc24M>;
#pwm-cells = <3>;
#size-cells = <0>; mdio: mdio { compatible = "snps,dwmac-mdio";
pwm: pwm@1c21400 {
clocks = <&osc24M>;
#pwm-cells = <3>;
clocks = <&osc32k>;
#clock-cells = <1>;
#size-cells = <0>;
clocks = <&osc24M>;
#pwm-cells = <3>;
- r_pio: pinctrl@1f02c00 { compatible = "allwinner,sun50i-a64-r-pinctrl"; reg = <0x01f02c00 0x400>;
function = "s_i2c";
r_pwm_pin: pwm {
pins = "PL10";
function = "s_pwm";
Dne sreda, 17. oktober 2018 ob 17:03:23 CEST je Vasily Khoruzhick napisal(a):
Linux 4.19-rc4
Wouldn't be best to use latest version from linux-next?
Best regards, Jernej
+CC Jernej
@@ -57,17 +60,21 @@
de2@1000000 {
#size-cells = <1>;
<&ccu CLK_BUS_DE>;
"bus";
#clock-cells = <1>;
#reset-cells = <1>;
"syscon";
#size-cells = <1>;
ranges;
#size-cells = <1>;
bias-pull-up; };
pwm_pin: pwm_pin {
pins = "PD22";
function = "pwm";
pwm: pwm@1c21400 {
clocks = <&osc24M>;
#pwm-cells = <3>;
@@ -617,8 +656,6 @@
pwm: pwm@1c21400 {
clocks = <&osc24M>;
#pwm-cells = <3>;
clocks = <&osc32k>;
#clock-cells = <1>;
#reset-cells = <1>;
#size-cells = <0>;
clocks = <&osc24M>;
#pwm-cells = <3>;
function = "s_i2c";
r_pwm_pin: pwm {
pins = "PL10";
function = "s_pwm";
r_rsb_pins: rsb {
On Tue, 16 Oct 2018 22:09:30 -0700 Vasily Khoruzhick anarsoul@gmail.com wrote:
Does this work easily without syncing the .dts files as well?
Linux 4.19-rc4
So this sounds like the right thing to do, but in this particular case breaks Ethernet with UEFI booting in all distribution installers or kernels out there (except >= Linux 4.19-rc1). I consider this a major use case of U-Boot's DTB, so what do we do about this? The reason is that we dropped the "syscon" compatible string at the end of the system-controller node, which older kernels rely on to find the syscon node. I suggested to re-add this[1], but didn't have much success, unfortunately. The easiest would be to re-add (or not remove) "syscon" for U-Boot's copy, but this would mean a deviation from the Linux DT's. I am fine with this, but would like to hear more opinions.
Cheers, Andre.
[1] http://lists.infradead.org/pipermail/linux-arm-kernel/2018-September/602153....
depend
de2@1000000 {
#size-cells = <1>;
compatible =
<&ccu CLK_BUS_DE>;
"bus";
#clock-cells = <1>;
#reset-cells = <1>;
compatible =
"syscon";
compatible =
#size-cells = <1>;
ranges;
#size-cells = <1>;
compatible =
pwm_pin: pwm_pin {
pins = "PD22";
function = "pwm";
pwm: pwm@1c21400 {
clocks = <&osc24M>;
#pwm-cells = <3>;
pwm: pwm@1c21400 {
clocks = <&osc24M>;
#pwm-cells = <3>;
- rtc: rtc@1f00000 { compatible = "allwinner,sun6i-a31-rtc"; reg = <0x01f00000 0x54>; interrupts = <GIC_SPI 40
"rtc-osc32k-out";
clocks = <&osc32k>;
#clock-cells = <1>;
#size-cells = <0>;
clocks = <&osc24M>;
#pwm-cells = <3>;
function = "s_i2c";
r_pwm_pin: pwm {
pins = "PL10";
function = "s_pwm";
Linux 4.19-rc4
tl; dr: You want to build something robust on top of assumptions that have never been guaranteed. I'm fine with having it as a U-Boot addition, if it's what it takes.
Maxime
On Wed, 17 Oct 2018 17:29:58 +0200 Maxime Ripard maxime.ripard@bootlin.com wrote:
Linux 4.19-rc4
I just find it sad that "we do not guarantee" translates into "we actually don't even try". My understanding of your concern is that you can't rule this breakage out forever, which I can understand. But if it is possible to avoid breaking compatibility, I believe we should try this, on a case-by-case base. We have been pretty good so far (leaving alone the MMC regulator breakage in v4.15, but A64 support was quite basic before that anyway).
Sounds good to me! Thanks!
I will check what's the easiest path to get the 4.20 DTs into U-Boot, considering a stopover at the Pinebook DTs, and send patches ASAP.
Cheers, Andre.
Linux 4.19-rc4
So do you want me to wait for you to submit a patch that syncs sun50i-a64.dtsi?
Cheers, Andre.
On Wed, 17 Oct 2018 10:09:55 -0700 Vasily Khoruzhick anarsoul@gmail.com wrote:
Linux 4.19-rc4
I will review the rest of your series later tonight and try to suggest something that's the easiest for you then.
Cheers, Andre
Well, we need r_i2c node from upstream. Jernej also wants HDMI nodes. Easiest way to do that is to sync this file.
Linux 4.19-rc4
Can you do it with a separate patch once this one merges? I have no way to test UEFI and updating sun50i-a64.dtsi doesn't break anything for me.
Cheers, Andre.
[1] http://lists.infradead.org/pipermail/linux-arm-kernel/2018-September/602153. html
@@ -57,17 +60,21 @@
depend
de2@1000000 {
#size-cells = <1>;
compatible =
<&ccu CLK_BUS_DE>;
"bus";
#clock-cells = <1>;
#reset-cells = <1>;
compatible =
"syscon";
compatible =
#size-cells = <1>;
ranges;
#size-cells = <1>;
compatible =
bias-pull-up; };
pwm_pin: pwm_pin {
pins = "PD22";
function = "pwm";
pwm: pwm@1c21400 {
clocks = <&osc24M>;
#pwm-cells = <3>;
@@ -617,8 +656,6 @@
pwm: pwm@1c21400 {
clocks = <&osc24M>;
#pwm-cells = <3>;
"rtc-osc32k-out";
clocks = <&osc32k>;
#clock-cells = <1>;
#reset-cells = <1>;
#size-cells = <0>;
clocks = <&osc24M>;
#pwm-cells = <3>;
function = "s_i2c";
r_pwm_pin: pwm {
pins = "PL10";
function = "s_pwm";
r_rsb_pins: rsb {
I understand that, but sometimes we have changes in the .dtsi that require board .dts updates at the same time (the UART pins in 4.20, for instance). This one seems to be fine, though.
Linux 4.19-rc4
Yes, that seems like the easiest way.
You actually don't need to boot UEFI, just DON'T load some .dtb, instead pass on U-Boot's copy (this is what the automated UEFI boot does).
=> booti $kernel_addr_r - $fdtcontroladdr
This way you can boot any kernel or distribution, without requiring it to ship your particular .dtb. And for installers: download some generic arm64 .iso image and "dd" this to a USB pen drive. Put that in a working USB socket and power on. The rest works automatically.
Cheers, Andre.
Cheers, Andre.
@@ -57,17 +60,21 @@
depend
de2@1000000 {
#size-cells = <1>;
compatible =
<&ccu CLK_BUS_DE>;
"bus";
#clock-cells = <1>;
#reset-cells = <1>;
compatible =
"syscon";
compatible =
#size-cells = <1>;
ranges;
#size-cells = <1>;
compatible =
bias-pull-up; };
pwm_pin: pwm_pin {
pins = "PD22";
function = "pwm";
pwm: pwm@1c21400 {
clocks = <&osc24M>;
#pwm-cells = <3>;
@@ -617,8 +656,6 @@
pwm: pwm@1c21400 {
clocks = <&osc24M>;
#pwm-cells = <3>;
"rtc-osc32k-out";
clocks = <&osc32k>;
#clock-cells = <1>;
#reset-cells = <1>;
#size-cells = <0>;
clocks = <&osc24M>;
#pwm-cells = <3>;
function = "s_i2c";
r_pwm_pin: pwm {
pins = "PL10";
function = "s_pwm";
r_rsb_pins: rsb {
Allwinner A64 has a I2C controller, which is in the R_ MMIO zone and has two groups of pinmuxes on PL bank, so it's called R_I2C.
Add support for this I2C controller and the pinmux which doesn't conflict with RSB.
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/mach-sunxi/Kconfig | 1 + board/sunxi/board.c | 6 ++++++ 3 files changed, 8 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index 6a5eafc3d3..2daf23f6f5 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -211,6 +211,7 @@ enum sunxi_gpio_number { #define SUN8I_H3_GPL_R_TWI 2 #define SUN8I_A23_GPL_R_TWI 3 #define SUN8I_GPL_R_UART 2 +#define SUN50I_GPL_R_TWI 2
#define SUN9I_GPN_R_RSB 3
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 686f38fec4..7ba429c744 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -272,6 +272,7 @@ config MACH_SUN50I select ARM64 select DM_I2C select PHY_SUN4I_USB + select SUN6I_PRCM select SUNXI_DE2 select SUNXI_GEN_SUN6I select SUPPORT_SPL diff --git a/board/sunxi/board.c b/board/sunxi/board.c index d1d7f9f400..90f8bc0a6e 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -168,10 +168,16 @@ void i2c_init_board(void) #endif
#ifdef CONFIG_R_I2C_ENABLE +#ifdef CONFIG_MACH_SUN50I + clock_twi_onoff(5, 1); + sunxi_gpio_set_cfgpin(SUNXI_GPL(8), SUN50I_GPL_R_TWI); + sunxi_gpio_set_cfgpin(SUNXI_GPL(9), SUN50I_GPL_R_TWI); +#else clock_twi_onoff(5, 1); sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_H3_GPL_R_TWI); sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_H3_GPL_R_TWI); #endif +#endif }
#if defined(CONFIG_ENV_IS_IN_MMC) && defined(CONFIG_ENV_IS_IN_FAT)
Reviewed-by: Andre Przywara andre.przywara@arm.com
Thanks! Andre.
- select SUN6I_PRCM select SUNXI_DE2 select SUNXI_GEN_SUN6I select SUPPORT_SPL
- clock_twi_onoff(5, 1);
- sunxi_gpio_set_cfgpin(SUNXI_GPL(8), SUN50I_GPL_R_TWI);
- sunxi_gpio_set_cfgpin(SUNXI_GPL(9), SUN50I_GPL_R_TWI);
Pinebook is a laptop produced by Pine64, with USB-connected keyboard, USB-connected touchpad and an eDP LCD panel connected via a RGB-eDP bridge from Analogix.
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun50i-a64-pinebook.dts | 306 +++++++++++++++++++++++++++ configs/pinebook_defconfig | 27 +++ 3 files changed, 335 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun50i-a64-pinebook.dts create mode 100644 configs/pinebook_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index dfe9335a04..ccb93f1e46 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -404,7 +404,8 @@ dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-orangepi-win.dtb \ sun50i-a64-pine64-plus.dtb \ sun50i-a64-pine64.dtb \ - sun50i-a64-sopine-baseboard.dtb + sun50i-a64-sopine-baseboard.dtb \ + sun50i-a64-pinebook.dtb dtb-$(CONFIG_MACH_SUN9I) += \ sun9i-a80-optimus.dtb \ sun9i-a80-cubieboard4.dtb \ diff --git a/arch/arm/dts/sun50i-a64-pinebook.dts b/arch/arm/dts/sun50i-a64-pinebook.dts new file mode 100644 index 0000000000..5d111fab64 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-pinebook.dts @@ -0,0 +1,306 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.xyz + * Copyright (C) 2018 Vasily Khoruzhick anarsoul@gmail.com + * + */ + +/dts-v1/; + +#include "sun50i-a64.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pwm/pwm.h> + +/ { + model = "Pinebook"; + compatible = "pine64,pinebook", "allwinner,sun50i-a64"; + + aliases { + serial0 = &uart0; + ethernet0 = &rtl8723cs; + }; + + vdd_bl: regulator@0 { + compatible = "regulator-fixed"; + regulator-name = "bl-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&pio 7 6 GPIO_ACTIVE_HIGH>; /* PH6 */ + enable-active-high; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + pwms = <&pwm 0 50000 0>; + brightness-levels = <0 5 10 15 20 30 40 55 70 85 100>; + default-brightness-level = <2>; + enable-gpios = <&pio 3 23 GPIO_ACTIVE_HIGH>; /* PD23 */ + power-supply = <&vdd_bl>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + + framebuffer-lcd { + panel-supply = <®_dc1sw>; + dvdd25-supply = <®_dldo2>; + dvdd12-supply = <®_fldo1>; + }; + }; + + gpio_keys { + compatible = "gpio-keys"; + + lid_switch { + label = "Lid Switch"; + gpios = <&r_pio 0 12 GPIO_ACTIVE_LOW>; /* PL12 */ + linux,input-type = <EV_SW>; + linux,code = <SW_LID>; + linux,can-disable; + wakeup-source; + }; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ + }; + + speaker_amp: speaker_amp { + compatible = "simple-audio-amplifier"; + enable-gpios = <&pio 7 7 GPIO_ACTIVE_HIGH>; + }; +}; + +&ehci0 { + phys = <&usbphy 0>; + phy-names = "usb"; + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_dcdc1>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; + cd-inverted; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_dldo4>; + vqmmc-supply = <®_eldo1>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + rtl8723cs: wifi@1 { + reg = <1>; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_eldo1>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + mmc-hs200-1_8v; + status = "okay"; +}; + +&ohci0 { + phys = <&usbphy 0>; + phy-names = "usb"; + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&pwm { + status = "okay"; +}; + +&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +/* The ANX6345 eDP-bridge is on r_i2c */ +&r_i2c { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&r_i2c_pins_a>; + status = "okay"; + anx6345: edp-bridge@38 { + compatible = "analogix,anx6345"; + reg = <0x38>; + reset-gpios = <&pio 3 24 GPIO_ACTIVE_LOW>; /* PD24 */ + status = "okay"; + }; +}; + +#include "axp803.dtsi" + +®_aldo1 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "vcc-csi"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <2700000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dc1sw { + regulator-name = "vcc-lcd"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-hdmi"; +}; + +®_dldo2 { + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-name = "vcc-edp"; +}; + +®_dldo3 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "avdd-csi"; +}; + +®_dldo4 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi"; +}; + +®_eldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "cpvdd"; +}; + +®_eldo3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vdd-1v8-csi"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-1v2-hsic"; +}; + +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_ldo_io0 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-usb"; + status = "okay"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + +&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "host"; +}; + +&usbphy { + usb0_vbus-supply = <®_ldo_io0>; + usb1_vbus-supply = <®_ldo_io0>; + status = "okay"; +}; diff --git a/configs/pinebook_defconfig b/configs/pinebook_defconfig new file mode 100644 index 0000000000..f5190d96d2 --- /dev/null +++ b/configs/pinebook_defconfig @@ -0,0 +1,27 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN50I=y +CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y +CONFIG_SUNXI_DRAM_LPDDR3_STOCK=y +CONFIG_DRAM_CLK=552 +CONFIG_DRAM_ZQ=3881949 +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_R_I2C_ENABLE=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pinebook" +# CONFIG_MMC_VERBOSE is not set +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_PWM=y +CONFIG_PWM_SUNXI=y +CONFIG_USB_EHCI_HCD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +# CONFIG_USB_GADGET is not set +CONFIG_VIDEO_BRIDGE=y +CONFIG_VIDEO_BRIDGE_ANALOGIX_ANX6345=y
- sun50i-a64-sopine-baseboard.dtb \
- sun50i-a64-pinebook.dtb
This should be ordered by alphabetical order. Otherwise, the whole series looks sane to me:
Acked-by: Maxime Ripard maxime.ripard@bootlin.com
Thanks! Maxime
+CC Jernej
- Copyright (C) 2017 Icenowy Zheng icenowy@aosc.xyz
- Copyright (C) 2018 Vasily Khoruzhick anarsoul@gmail.com
+/dts-v1/;
- model = "Pinebook";
- compatible = "pine64,pinebook", "allwinner,sun50i-a64";
- aliases {
serial0 = &uart0;
- vdd_bl: regulator@0 {
enable-active-high;
- backlight: backlight {
- chosen {
framebuffer-lcd {
- gpio_keys {
lid_switch {
linux,can-disable;
wakeup-source;
- reg_vcc3v3: vcc3v3 {
- wifi_pwrseq: wifi_pwrseq {
- speaker_amp: speaker_amp {
+&ehci0 {
- phys = <&usbphy 0>;
- phy-names = "usb";
- status = "okay";
+&ehci1 {
- status = "okay";
+&mmc0 {
- pinctrl-names = "default";
- pinctrl-0 = <&mmc0_pins>;
- vmmc-supply = <®_dcdc1>;
- cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>;
- cd-inverted;
- disable-wp;
- bus-width = <4>;
- status = "okay";
+&mmc1 {
- pinctrl-0 = <&mmc1_pins>;
- vmmc-supply = <®_dldo4>;
- vqmmc-supply = <®_eldo1>;
- mmc-pwrseq = <&wifi_pwrseq>;
- bus-width = <4>;
- non-removable;
- status = "okay";
- rtl8723cs: wifi@1 {
reg = <1>;
+&mmc2 {
- pinctrl-0 = <&mmc2_pins>;
- bus-width = <8>;
- non-removable;
- cap-mmc-hw-reset;
- mmc-hs200-1_8v;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci1 {
- status = "okay";
+&pwm {
- status = "okay";
+&r_rsb {
- status = "okay";
- axp803: pmic@3a3 {
reg = <0x3a3>;
- clock-frequency = <100000>;
- pinctrl-0 = <&r_i2c_pins_a>;
- status = "okay";
- anx6345: edp-bridge@38 {
reg = <0x38>;
status = "okay";
+®_aldo1 {
- regulator-min-microvolt = <2800000>;
- regulator-max-microvolt = <2800000>;
- regulator-name = "vcc-csi";
+®_aldo2 {
- regulator-always-on;
- regulator-min-microvolt = <1800000>;
- regulator-max-microvolt = <3300000>;
- regulator-name = "vcc-pl";
+®_aldo3 {
- regulator-min-microvolt = <2700000>;
- regulator-name = "vcc-pll-avcc";
+®_dc1sw {
- regulator-name = "vcc-lcd";
+®_dcdc1 {
- regulator-min-microvolt = <3300000>;
- regulator-name = "vcc-3v3";
+®_dcdc2 {
- regulator-min-microvolt = <1000000>;
- regulator-max-microvolt = <1300000>;
- regulator-name = "vdd-cpux";
+®_dcdc5 {
- regulator-min-microvolt = <1200000>;
- regulator-max-microvolt = <1200000>;
- regulator-name = "vcc-dram";
+®_dcdc6 {
- regulator-min-microvolt = <1100000>;
- regulator-max-microvolt = <1100000>;
- regulator-name = "vdd-sys";
+®_dldo1 {
- regulator-name = "vcc-hdmi";
+®_dldo2 {
- regulator-min-microvolt = <2500000>;
- regulator-max-microvolt = <2500000>;
- regulator-name = "vcc-edp";
+®_dldo3 {
- regulator-name = "avdd-csi";
+®_dldo4 {
- regulator-name = "vcc-wifi";
+®_eldo1 {
- regulator-max-microvolt = <1800000>;
- regulator-name = "cpvdd";
+®_eldo3 {
- regulator-name = "vdd-1v8-csi";
+®_fldo1 {
- regulator-name = "vcc-1v2-hsic";
+®_fldo2 {
- regulator-name = "vdd-cpus";
+®_ldo_io0 {
- regulator-name = "vcc-usb";
- status = "okay";
+®_rtc_ldo {
- regulator-name = "vcc-rtc";
+&simplefb_hdmi {
- vcc-hdmi-supply = <®_dldo1>;
+&uart0 {
- pinctrl-0 = <&uart0_pins_a>;
- status = "okay";
+&usb_otg {
- dr_mode = "host";
+&usbphy {
- usb0_vbus-supply = <®_ldo_io0>;
- usb1_vbus-supply = <®_ldo_io0>;
- status = "okay";
Hi!
Dne sreda, 17. oktober 2018 ob 17:13:42 CEST je Vasily Khoruzhick napisal(a):
+CC Jernej
+/dts-v1/;
- aliases {
serial0 = &uart0;
enable-active-high;
- chosen {
framebuffer-lcd {
- gpio_keys {
lid_switch {
linux,can-disable;
wakeup-source;
+&ehci0 {
- status = "okay";
+&ehci1 {
- status = "okay";
+&mmc0 {
- cd-inverted;
- disable-wp;
- bus-width = <4>;
- status = "okay";
+&mmc1 {
- bus-width = <4>;
- non-removable;
- status = "okay";
reg = <1>;
+&mmc2 {
- bus-width = <8>;
- non-removable;
- cap-mmc-hw-reset;
- mmc-hs200-1_8v;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci1 {
- status = "okay";
+&pwm {
- status = "okay";
+&r_rsb {
- status = "okay";
reg = <0x3a3>;
- status = "okay";
reg = <0x38>;
status = "okay";
Given that this node is currently U-Boot specific, wouldn't be better to leave sun50i-a64-pinebook.dts as it is in Linux and add additional sun50i-a64- pinebook-u-boot.dts with U-Boot specific nodes as it is already done with a lot of other DT files?
That way there is less chance to mistakenly left out something when syncing DT files from Linux.
+®_aldo1 {
+®_aldo2 {
+®_aldo3 {
+®_dc1sw {
+®_dcdc1 {
+®_dcdc2 {
+®_dcdc5 {
+®_dcdc6 {
+®_dldo1 {
+®_dldo2 {
+®_dldo3 {
+®_dldo4 {
+®_eldo1 {
+®_eldo3 {
+®_fldo1 {
+®_fldo2 {
+®_ldo_io0 {
- status = "okay";
+®_rtc_ldo {
+&simplefb_hdmi {
+&uart0 {
- status = "okay";
+&usb_otg {
- dr_mode = "host";
+&usbphy {
- status = "okay";
On Wednesday, October 17, 2018 8:22:51 AM PDT Jernej Škrabec wrote:
Hi!
napisal(a):
+CC Jernej
+/dts-v1/;
- aliases {
serial0 = &uart0;
enable-active-high;
- chosen {
framebuffer-lcd {
- gpio_keys {
lid_switch {
linux,can-disable;
wakeup-source;
+&ehci0 {
- status = "okay";
+&ehci1 {
- status = "okay";
+&mmc0 {
- cd-inverted;
- disable-wp;
- bus-width = <4>;
- status = "okay";
+&mmc1 {
- bus-width = <4>;
- non-removable;
- status = "okay";
reg = <1>;
+&mmc2 {
- bus-width = <8>;
- non-removable;
- cap-mmc-hw-reset;
- mmc-hs200-1_8v;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci1 {
- status = "okay";
+&pwm {
- status = "okay";
+&r_rsb {
- status = "okay";
reg = <0x3a3>;
- status = "okay";
reg = <0x38>;
status = "okay";
Sounds good, will do in v3.
+®_aldo1 {
+®_aldo2 {
+®_aldo3 {
+®_dc1sw {
+®_dcdc1 {
+®_dcdc2 {
+®_dcdc5 {
+®_dcdc6 {
+®_dldo1 {
+®_dldo2 {
+®_dldo3 {
+®_dldo4 {
+®_eldo1 {
+®_eldo3 {
+®_fldo1 {
+®_fldo2 {
+®_ldo_io0 {
- status = "okay";
+®_rtc_ldo {
+&simplefb_hdmi {
+&uart0 {
- status = "okay";
+&usb_otg {
- dr_mode = "host";
+&usbphy {
- status = "okay";
+/dts-v1/;
- aliases {
serial0 = &uart0;
enable-active-high;
- chosen {
framebuffer-lcd {
- gpio_keys {
lid_switch {
linux,can-disable;
wakeup-source;
I see that this is the only sound related node not dependent on any .dtsi nodes, but how useful is it to have it in here on its own? Shouldn't we wait until all sound nodes are agreed upon and merged?
+&ehci0 {
- status = "okay";
+&ehci1 {
- status = "okay";
+&mmc0 {
- cd-inverted;
- disable-wp;
- bus-width = <4>;
- status = "okay";
+&mmc1 {
- bus-width = <4>;
- non-removable;
- status = "okay";
reg = <1>;
+&mmc2 {
- bus-width = <8>;
- non-removable;
- cap-mmc-hw-reset;
- mmc-hs200-1_8v;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci1 {
- status = "okay";
+&pwm {
- status = "okay";
+&r_rsb {
- status = "okay";
reg = <0x3a3>;
- status = "okay";
Nit: please add an empty line here, to separate the slave section from the master.
reg = <0x38>;
status = "okay";
Do you have any plans on upstreaming this binding?
+®_aldo1 {
+®_aldo2 {
+®_aldo3 {
+®_dc1sw {
+®_dcdc1 {
+®_dcdc2 {
+®_dcdc5 {
+®_dcdc6 {
+®_dldo1 {
+®_dldo2 {
+®_dldo3 {
+®_dldo4 {
+®_eldo1 {
+®_eldo3 {
+®_fldo1 {
+®_fldo2 {
+®_ldo_io0 {
- status = "okay";
+®_rtc_ldo {
+&simplefb_hdmi {
+&uart0 {
- status = "okay";
+&usb_otg {
- dr_mode = "host";
+&usbphy {
- status = "okay";
I think you can drop this.
Why these two? I see that they save 219 bytes of the SPL, but the image size is still way below the limit. So I'd prefer to not deviate from the other boards here.
Why this one? Doesn't seem to affect SPL size?
Cheers, Andre.
+/dts-v1/;
- aliases {
serial0 = &uart0;
enable-active-high;
- chosen {
framebuffer-lcd {
- gpio_keys {
lid_switch {
linux,can-disable;
wakeup-source;
I'll drop it for v3.
+&ehci0 {
- status = "okay";
+&ehci1 {
- status = "okay";
+&mmc0 {
- cd-inverted;
- disable-wp;
- bus-width = <4>;
- status = "okay";
+&mmc1 {
- bus-width = <4>;
- non-removable;
- status = "okay";
reg = <1>;
+&mmc2 {
- bus-width = <8>;
- non-removable;
- cap-mmc-hw-reset;
- mmc-hs200-1_8v;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci1 {
- status = "okay";
+&pwm {
- status = "okay";
+&r_rsb {
- status = "okay";
reg = <0x3a3>;
- status = "okay";
I'll move it to sun50i-a64-pinebook-u-boot.dtsi for v3 as Jernej suggested, so we can drop it when anx6345 merges into linux.
reg = <0x38>;
status = "okay";
Icenowy has plans to merge it.
+®_aldo1 {
+®_aldo2 {
+®_aldo3 {
+®_dc1sw {
+®_dcdc1 {
+®_dcdc2 {
+®_dcdc5 {
+®_dcdc6 {
+®_dldo1 {
+®_dldo2 {
+®_dldo3 {
+®_dldo4 {
+®_eldo1 {
+®_eldo3 {
+®_fldo1 {
+®_fldo2 {
+®_ldo_io0 {
- status = "okay";
+®_rtc_ldo {
+&simplefb_hdmi {
+&uart0 {
- status = "okay";
+&usb_otg {
- dr_mode = "host";
+&usbphy {
- status = "okay";
OK
OK, I'll drop these.
OK, will keep it.
Cheers, Andre.
participants (5)
Andre Przywara
André Przywara
Jernej Škrabec
Maxime Ripard
Vasily Khoruzhick
