[U-Boot] [PATCH 0/7] SF: Cadence QSPI driver fixes and clean up
This series has fixes, patches to clean the code up, and add support for specifying the sampling edge.
Phil Edworthy (7): spi: cadence_qspi: Fix clearing of pol/pha bits spi: cadence_qspi: Fix baud rate calculation spi: cadence_qspi: Use #define for bits instead of bit shifts spi: cadence_qspi: Clean up the #define names spi: cadence_qspi: Remove returns from end of void functions spi: cadence_qspi: Fix CQSPI_CAL_DELAY calculation spi: cadence_qspi: Support specifying the sample edge used
doc/device-tree-bindings/spi/spi-cadence.txt | 2 + drivers/spi/cadence_qspi.c | 10 +- drivers/spi/cadence_qspi.h | 3 +- drivers/spi/cadence_qspi_apb.c | 164 +++++++++++++-------------- 4 files changed, 88 insertions(+), 91 deletions(-)
Or'ing together bit positions is clearly wrong.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- drivers/spi/cadence_qspi_apb.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index e285d3c..2403e71 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -311,8 +311,8 @@ void cadence_qspi_apb_set_clk_mode(void *reg_base,
cadence_qspi_apb_controller_disable(reg_base); reg = readl(reg_base + CQSPI_REG_CONFIG); - reg &= ~(1 << - (CQSPI_REG_CONFIG_CLK_POL_LSB | CQSPI_REG_CONFIG_CLK_PHA_LSB)); + reg &= ~(1 << CQSPI_REG_CONFIG_CLK_POL_LSB); + reg &= ~(1 << CQSPI_REG_CONFIG_CLK_PHA_LSB);
reg |= ((clk_pol & 0x1) << CQSPI_REG_CONFIG_CLK_POL_LSB); reg |= ((clk_pha & 0x1) << CQSPI_REG_CONFIG_CLK_PHA_LSB);
With the existing code, when the requested SPI clock rate is near to the lowerest that can be achieved by the hardware (max divider of the ref clock is 32), the generated clock rate is wrong. For example, with a 50MHz ref clock, when asked for anything less than a 1.5MHz SPI clock, the code sets up the divider to generate 25MHz.
This change fixes the calculation.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- drivers/spi/cadence_qspi_apb.c | 23 +++++++---------------- 1 file changed, 7 insertions(+), 16 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 2403e71..71bde1f 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -273,22 +273,13 @@ void cadence_qspi_apb_config_baudrate_div(void *reg_base, reg = readl(reg_base + CQSPI_REG_CONFIG); reg &= ~(CQSPI_REG_CONFIG_BAUD_MASK << CQSPI_REG_CONFIG_BAUD_LSB);
- div = ref_clk_hz / sclk_hz; - - if (div > 32) - div = 32; - - /* Check if even number. */ - if ((div & 1)) { - div = (div / 2); - } else { - if (ref_clk_hz % sclk_hz) - /* ensure generated SCLK doesn't exceed user - specified sclk_hz */ - div = (div / 2); - else - div = (div / 2) - 1; - } + /* + * The baud_div field in the config reg is 4 bits, and the ref clock is + * divided by 2 * (baud_div + 1). Round up the divider to ensure the + * SPI clock rate is less than or equal to the requested clock rate. + */ + div = (ref_clk_hz + sclk_hz - 1) / sclk_hz; + div = ((div + 1) / 2) - 1;
debug("%s: ref_clk %dHz sclk %dHz Div 0x%x\n", __func__, ref_clk_hz, sclk_hz, div);
- if (div > 32)
div = 32;
- if ((div & 1)) {
div = (div / 2);
- } else {
div = (div / 2);
else
- div = (ref_clk_hz + sclk_hz - 1) / sclk_hz;
DIV_ROUND_UP()
- div = ((div + 1) / 2) - 1;
Is this roundup() ?
Hi Marek,
*reg_base,
- if (div > 32)
div = 32;
- if ((div & 1)) {
div = (div / 2);
- } else {
div = (div / 2);
else
DIV_ROUND_UP()
Ah yes, that would be clearer!
Is this roundup() ?
It's DIV_ROUND_UP() - 1
-- Best regards, Marek Vasut
Thanks Phil
Most of the code already uses #defines for the bit value, rather than the shift required to get the value. This changes the remaining code over.
Whislt at it, fix the names of the "Rd Data Capture" register defs.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- drivers/spi/cadence_qspi_apb.c | 37 +++++++++++++++++++------------------ 1 file changed, 19 insertions(+), 18 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 71bde1f..d1e1b49 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -57,9 +57,9 @@ * Controller's configuration and status register (offset from QSPI_BASE) ****************************************************************************/ #define CQSPI_REG_CONFIG 0x00 -#define CQSPI_REG_CONFIG_CLK_POL_LSB 1 -#define CQSPI_REG_CONFIG_CLK_PHA_LSB 2 #define CQSPI_REG_CONFIG_ENABLE_MASK BIT(0) +#define CQSPI_REG_CONFIG_CLK_POL BIT(1) +#define CQSPI_REG_CONFIG_CLK_PHA BIT(2) #define CQSPI_REG_CONFIG_DIRECT_MASK BIT(7) #define CQSPI_REG_CONFIG_DECODE_MASK BIT(9) #define CQSPI_REG_CONFIG_XIP_IMM_MASK BIT(18) @@ -94,10 +94,10 @@ #define CQSPI_REG_DELAY_TSD2D_MASK 0xFF #define CQSPI_REG_DELAY_TSHSL_MASK 0xFF
-#define CQSPI_READLCAPTURE 0x10 -#define CQSPI_READLCAPTURE_BYPASS_LSB 0 -#define CQSPI_READLCAPTURE_DELAY_LSB 1 -#define CQSPI_READLCAPTURE_DELAY_MASK 0xF +#define CQSPI_REG_RD_DATA_CAPTURE 0x10 +#define CQSPI_REG_RD_DATA_CAPTURE_BYPASS BIT(0) +#define CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB 1 +#define CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK 0xF
#define CQSPI_REG_SIZE 0x14 #define CQSPI_REG_SIZE_ADDRESS_LSB 0 @@ -244,20 +244,20 @@ void cadence_qspi_apb_readdata_capture(void *reg_base, unsigned int reg; cadence_qspi_apb_controller_disable(reg_base);
- reg = readl(reg_base + CQSPI_READLCAPTURE); + reg = readl(reg_base + CQSPI_REG_RD_DATA_CAPTURE);
if (bypass) - reg |= (1 << CQSPI_READLCAPTURE_BYPASS_LSB); + reg |= CQSPI_REG_RD_DATA_CAPTURE_BYPASS; else - reg &= ~(1 << CQSPI_READLCAPTURE_BYPASS_LSB); + reg &= ~CQSPI_REG_RD_DATA_CAPTURE_BYPASS;
- reg &= ~(CQSPI_READLCAPTURE_DELAY_MASK - << CQSPI_READLCAPTURE_DELAY_LSB); + reg &= ~(CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK + << CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB);
- reg |= ((delay & CQSPI_READLCAPTURE_DELAY_MASK) - << CQSPI_READLCAPTURE_DELAY_LSB); + reg |= ((delay & CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK) + << CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB);
- writel(reg, reg_base + CQSPI_READLCAPTURE); + writel(reg, reg_base + CQSPI_REG_RD_DATA_CAPTURE);
cadence_qspi_apb_controller_enable(reg_base); return; @@ -302,11 +302,12 @@ void cadence_qspi_apb_set_clk_mode(void *reg_base,
cadence_qspi_apb_controller_disable(reg_base); reg = readl(reg_base + CQSPI_REG_CONFIG); - reg &= ~(1 << CQSPI_REG_CONFIG_CLK_POL_LSB); - reg &= ~(1 << CQSPI_REG_CONFIG_CLK_PHA_LSB); + reg &= ~(CQSPI_REG_CONFIG_CLK_POL | CQSPI_REG_CONFIG_CLK_PHA);
- reg |= ((clk_pol & 0x1) << CQSPI_REG_CONFIG_CLK_POL_LSB); - reg |= ((clk_pha & 0x1) << CQSPI_REG_CONFIG_CLK_PHA_LSB); + if (clk_pol) + reg |= CQSPI_REG_CONFIG_CLK_POL; + if (clk_pha) + reg |= CQSPI_REG_CONFIG_CLK_PHA;
writel(reg, reg_base + CQSPI_REG_CONFIG);
A lot of the #defines are for single bits in a register, where the name has _MASK on the end. Since this can be used for both a mask and the value, remove _MASK from them.
Whilst doing so, also remove the unneccesary brackets around the constants.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- drivers/spi/cadence_qspi_apb.c | 86 +++++++++++++++++++++--------------------- 1 file changed, 43 insertions(+), 43 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index d1e1b49..639780c 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -32,37 +32,37 @@ #include <spi.h> #include "cadence_qspi.h"
-#define CQSPI_REG_POLL_US (1) /* 1us */ -#define CQSPI_REG_RETRY (10000) -#define CQSPI_POLL_IDLE_RETRY (3) +#define CQSPI_REG_POLL_US 1 /* 1us */ +#define CQSPI_REG_RETRY 10000 +#define CQSPI_POLL_IDLE_RETRY 3
-#define CQSPI_FIFO_WIDTH (4) +#define CQSPI_FIFO_WIDTH 4
-#define CQSPI_REG_SRAM_THRESHOLD_WORDS (50) +#define CQSPI_REG_SRAM_THRESHOLD_WORDS 50
/* Transfer mode */ -#define CQSPI_INST_TYPE_SINGLE (0) -#define CQSPI_INST_TYPE_DUAL (1) -#define CQSPI_INST_TYPE_QUAD (2) +#define CQSPI_INST_TYPE_SINGLE 0 +#define CQSPI_INST_TYPE_DUAL 1 +#define CQSPI_INST_TYPE_QUAD 2
-#define CQSPI_STIG_DATA_LEN_MAX (8) - -#define CQSPI_DUMMY_CLKS_PER_BYTE (8) -#define CQSPI_DUMMY_BYTES_MAX (4) +#define CQSPI_STIG_DATA_LEN_MAX 8
+#define CQSPI_DUMMY_CLKS_PER_BYTE 8 +#define CQSPI_DUMMY_BYTES_MAX 4
#define CQSPI_REG_SRAM_FILL_THRESHOLD \ ((CQSPI_REG_SRAM_SIZE_WORD / 2) * CQSPI_FIFO_WIDTH) + /**************************************************************************** * Controller's configuration and status register (offset from QSPI_BASE) ****************************************************************************/ #define CQSPI_REG_CONFIG 0x00 -#define CQSPI_REG_CONFIG_ENABLE_MASK BIT(0) +#define CQSPI_REG_CONFIG_ENABLE BIT(0) #define CQSPI_REG_CONFIG_CLK_POL BIT(1) #define CQSPI_REG_CONFIG_CLK_PHA BIT(2) -#define CQSPI_REG_CONFIG_DIRECT_MASK BIT(7) -#define CQSPI_REG_CONFIG_DECODE_MASK BIT(9) -#define CQSPI_REG_CONFIG_XIP_IMM_MASK BIT(18) +#define CQSPI_REG_CONFIG_DIRECT BIT(7) +#define CQSPI_REG_CONFIG_DECODE BIT(9) +#define CQSPI_REG_CONFIG_XIP_IMM BIT(18) #define CQSPI_REG_CONFIG_CHIPSELECT_LSB 10 #define CQSPI_REG_CONFIG_BAUD_LSB 19 #define CQSPI_REG_CONFIG_IDLE_LSB 31 @@ -123,18 +123,18 @@ #define CQSPI_REG_IRQMASK 0x44
#define CQSPI_REG_INDIRECTRD 0x60 -#define CQSPI_REG_INDIRECTRD_START_MASK BIT(0) -#define CQSPI_REG_INDIRECTRD_CANCEL_MASK BIT(1) -#define CQSPI_REG_INDIRECTRD_INPROGRESS_MASK BIT(2) -#define CQSPI_REG_INDIRECTRD_DONE_MASK BIT(5) +#define CQSPI_REG_INDIRECTRD_START BIT(0) +#define CQSPI_REG_INDIRECTRD_CANCEL BIT(1) +#define CQSPI_REG_INDIRECTRD_INPROGRESS BIT(2) +#define CQSPI_REG_INDIRECTRD_DONE BIT(5)
#define CQSPI_REG_INDIRECTRDWATERMARK 0x64 #define CQSPI_REG_INDIRECTRDSTARTADDR 0x68 #define CQSPI_REG_INDIRECTRDBYTES 0x6C
#define CQSPI_REG_CMDCTRL 0x90 -#define CQSPI_REG_CMDCTRL_EXECUTE_MASK BIT(0) -#define CQSPI_REG_CMDCTRL_INPROGRESS_MASK BIT(1) +#define CQSPI_REG_CMDCTRL_EXECUTE BIT(0) +#define CQSPI_REG_CMDCTRL_INPROGRESS BIT(1) #define CQSPI_REG_CMDCTRL_DUMMY_LSB 7 #define CQSPI_REG_CMDCTRL_WR_BYTES_LSB 12 #define CQSPI_REG_CMDCTRL_WR_EN_LSB 15 @@ -150,10 +150,10 @@ #define CQSPI_REG_CMDCTRL_OPCODE_MASK 0xFF
#define CQSPI_REG_INDIRECTWR 0x70 -#define CQSPI_REG_INDIRECTWR_START_MASK BIT(0) -#define CQSPI_REG_INDIRECTWR_CANCEL_MASK BIT(1) -#define CQSPI_REG_INDIRECTWR_INPROGRESS_MASK BIT(2) -#define CQSPI_REG_INDIRECTWR_DONE_MASK BIT(5) +#define CQSPI_REG_INDIRECTWR_START BIT(0) +#define CQSPI_REG_INDIRECTWR_CANCEL BIT(1) +#define CQSPI_REG_INDIRECTWR_INPROGRESS BIT(2) +#define CQSPI_REG_INDIRECTWR_DONE BIT(5)
#define CQSPI_REG_INDIRECTWRWATERMARK 0x74 #define CQSPI_REG_INDIRECTWRSTARTADDR 0x78 @@ -197,7 +197,7 @@ void cadence_qspi_apb_controller_enable(void *reg_base) { unsigned int reg; reg = readl(reg_base + CQSPI_REG_CONFIG); - reg |= CQSPI_REG_CONFIG_ENABLE_MASK; + reg |= CQSPI_REG_CONFIG_ENABLE; writel(reg, reg_base + CQSPI_REG_CONFIG); return; } @@ -206,7 +206,7 @@ void cadence_qspi_apb_controller_disable(void *reg_base) { unsigned int reg; reg = readl(reg_base + CQSPI_REG_CONFIG); - reg &= ~CQSPI_REG_CONFIG_ENABLE_MASK; + reg &= ~CQSPI_REG_CONFIG_ENABLE; writel(reg, reg_base + CQSPI_REG_CONFIG); return; } @@ -328,9 +328,9 @@ void cadence_qspi_apb_chipselect(void *reg_base, reg = readl(reg_base + CQSPI_REG_CONFIG); /* docoder */ if (decoder_enable) { - reg |= CQSPI_REG_CONFIG_DECODE_MASK; + reg |= CQSPI_REG_CONFIG_DECODE; } else { - reg &= ~CQSPI_REG_CONFIG_DECODE_MASK; + reg &= ~CQSPI_REG_CONFIG_DECODE; /* Convert CS if without decoder. * CS0 to 4b'1110 * CS1 to 4b'1101 @@ -424,12 +424,12 @@ static int cadence_qspi_apb_exec_flash_cmd(void *reg_base, /* Write the CMDCTRL without start execution. */ writel(reg, reg_base + CQSPI_REG_CMDCTRL); /* Start execute */ - reg |= CQSPI_REG_CMDCTRL_EXECUTE_MASK; + reg |= CQSPI_REG_CMDCTRL_EXECUTE; writel(reg, reg_base + CQSPI_REG_CMDCTRL);
while (retry--) { reg = readl(reg_base + CQSPI_REG_CMDCTRL); - if ((reg & CQSPI_REG_CMDCTRL_INPROGRESS_MASK) == 0) + if ((reg & CQSPI_REG_CMDCTRL_INPROGRESS) == 0) break; udelay(1); } @@ -647,7 +647,7 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, writel(n_rx, plat->regbase + CQSPI_REG_INDIRECTRDBYTES);
/* Start the indirect read transfer */ - writel(CQSPI_REG_INDIRECTRD_START_MASK, + writel(CQSPI_REG_INDIRECTRD_START, plat->regbase + CQSPI_REG_INDIRECTRD);
while (remaining > 0) { @@ -676,21 +676,21 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat,
/* Check indirect done status */ ret = wait_for_bit("QSPI", plat->regbase + CQSPI_REG_INDIRECTRD, - CQSPI_REG_INDIRECTRD_DONE_MASK, 1, 10, 0); + CQSPI_REG_INDIRECTRD_DONE, 1, 10, 0); if (ret) { printf("Indirect read completion error (%i)\n", ret); goto failrd; }
/* Clear indirect completion status */ - writel(CQSPI_REG_INDIRECTRD_DONE_MASK, + writel(CQSPI_REG_INDIRECTRD_DONE, plat->regbase + CQSPI_REG_INDIRECTRD);
failrd: /* Cancel the indirect read */ - writel(CQSPI_REG_INDIRECTRD_CANCEL_MASK, + writel(CQSPI_REG_INDIRECTRD_CANCEL, plat->regbase + CQSPI_REG_INDIRECTRD); return ret; } @@ -738,7 +738,7 @@ int cadence_qspi_apb_indirect_write_execute(struct cadence_spi_platdata *plat, writel(n_tx, plat->regbase + CQSPI_REG_INDIRECTWRBYTES);
/* Start the indirect write transfer */ - writel(CQSPI_REG_INDIRECTWR_START_MASK, + writel(CQSPI_REG_INDIRECTWR_START, plat->regbase + CQSPI_REG_INDIRECTWR);
while (remaining > 0) { @@ -763,20 +763,20 @@ int cadence_qspi_apb_indirect_write_execute(struct cadence_spi_platdata *plat,
/* Check indirect done status */ ret = wait_for_bit("QSPI", plat->regbase + CQSPI_REG_INDIRECTWR, - CQSPI_REG_INDIRECTWR_DONE_MASK, 1, 10, 0); + CQSPI_REG_INDIRECTWR_DONE, 1, 10, 0); if (ret) { printf("Indirect write completion error (%i)\n", ret); goto failwr; }
/* Clear indirect completion status */ - writel(CQSPI_REG_INDIRECTWR_DONE_MASK, + writel(CQSPI_REG_INDIRECTWR_DONE, plat->regbase + CQSPI_REG_INDIRECTWR); return 0;
failwr: /* Cancel the indirect write */ - writel(CQSPI_REG_INDIRECTWR_CANCEL_MASK, + writel(CQSPI_REG_INDIRECTWR_CANCEL, plat->regbase + CQSPI_REG_INDIRECTWR); return ret; } @@ -787,9 +787,9 @@ void cadence_qspi_apb_enter_xip(void *reg_base, char xip_dummy)
/* enter XiP mode immediately and enable direct mode */ reg = readl(reg_base + CQSPI_REG_CONFIG); - reg |= CQSPI_REG_CONFIG_ENABLE_MASK; - reg |= CQSPI_REG_CONFIG_DIRECT_MASK; - reg |= CQSPI_REG_CONFIG_XIP_IMM_MASK; + reg |= CQSPI_REG_CONFIG_ENABLE; + reg |= CQSPI_REG_CONFIG_DIRECT; + reg |= CQSPI_REG_CONFIG_XIP_IMM; writel(reg, reg_base + CQSPI_REG_CONFIG);
/* keep the XiP mode */
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- drivers/spi/cadence_qspi_apb.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 639780c..a0edeb8 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -199,7 +199,6 @@ void cadence_qspi_apb_controller_enable(void *reg_base) reg = readl(reg_base + CQSPI_REG_CONFIG); reg |= CQSPI_REG_CONFIG_ENABLE; writel(reg, reg_base + CQSPI_REG_CONFIG); - return; }
void cadence_qspi_apb_controller_disable(void *reg_base) @@ -208,7 +207,6 @@ void cadence_qspi_apb_controller_disable(void *reg_base) reg = readl(reg_base + CQSPI_REG_CONFIG); reg &= ~CQSPI_REG_CONFIG_ENABLE; writel(reg, reg_base + CQSPI_REG_CONFIG); - return; }
/* Return 1 if idle, otherwise return 0 (busy). */ @@ -260,7 +258,6 @@ void cadence_qspi_apb_readdata_capture(void *reg_base, writel(reg, reg_base + CQSPI_REG_RD_DATA_CAPTURE);
cadence_qspi_apb_controller_enable(reg_base); - return; }
void cadence_qspi_apb_config_baudrate_div(void *reg_base, @@ -292,7 +289,6 @@ void cadence_qspi_apb_config_baudrate_div(void *reg_base, writel(reg, reg_base + CQSPI_REG_CONFIG);
void cadence_qspi_apb_set_clk_mode(void *reg_base, @@ -312,7 +308,6 @@ void cadence_qspi_apb_set_clk_mode(void *reg_base, writel(reg, reg_base + CQSPI_REG_CONFIG);
void cadence_qspi_apb_chipselect(void *reg_base, @@ -347,7 +342,6 @@ void cadence_qspi_apb_chipselect(void *reg_base, writel(reg, reg_base + CQSPI_REG_CONFIG);
void cadence_qspi_apb_delay(void *reg_base, @@ -385,7 +379,6 @@ void cadence_qspi_apb_delay(void *reg_base, writel(reg, reg_base + CQSPI_REG_DELAY);
void cadence_qspi_apb_controller_init(struct cadence_spi_platdata *plat) @@ -413,7 +406,6 @@ void cadence_qspi_apb_controller_init(struct cadence_spi_platdata *plat) writel(0, plat->regbase + CQSPI_REG_IRQMASK);
cadence_qspi_apb_controller_enable(plat->regbase); - return; }
This change copes with the delay being less than a SCLK period.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- drivers/spi/cadence_qspi_apb.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index a0edeb8..533274d 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -170,7 +170,7 @@ CQSPI_REG_CONFIG_IDLE_LSB) & 0x1)
#define CQSPI_CAL_DELAY(tdelay_ns, tref_ns, tsclk_ns) \ - ((((tdelay_ns) - (tsclk_ns)) / (tref_ns))) + ((tdelay_ns) > (tsclk_ns)) ? ((((tdelay_ns) - (tsclk_ns)) / (tref_ns))) : 0
#define CQSPI_GET_RD_SRAM_LEVEL(reg_base) \ (((readl(reg_base + CQSPI_REG_SDRAMLEVEL)) >> \
The Cadence QSPI controller has specified overheads for the various CS times that are in addition to those programmed in to the Device Delay register. The overheads are different for the delays.
In addition, the existing code does not handle the case when the delay is less than a SCLK period.
This change accurately calculates the additional delays in Ref clocks.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- v2: Was "spi: cadence_qspi: Fix CQSPI_CAL_DELAY calculation" Note only did the existing code not cope with the delay less than an SCLK period, but the calculation didn't round properly, and didn't take into account the delays that the QSPI Controller adds to those programmed into the Device Delay reg. --- drivers/spi/cadence_qspi_apb.c | 23 ++++++++++++----------- 1 file changed, 12 insertions(+), 11 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 72c7c79..4d53aad 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -169,9 +169,6 @@ ((readl(base + CQSPI_REG_CONFIG) >> \ CQSPI_REG_CONFIG_IDLE_LSB) & 0x1)
-#define CQSPI_CAL_DELAY(tdelay_ns, tref_ns, tsclk_ns) \ - ((((tdelay_ns) - (tsclk_ns)) / (tref_ns))) - #define CQSPI_GET_RD_SRAM_LEVEL(reg_base) \ (((readl(reg_base + CQSPI_REG_SDRAMLEVEL)) >> \ CQSPI_REG_SDRAMLEVEL_RD_LSB) & CQSPI_REG_SDRAMLEVEL_RD_MASK) @@ -357,16 +354,20 @@ void cadence_qspi_apb_delay(void *reg_base, cadence_qspi_apb_controller_disable(reg_base);
/* Convert to ns. */ - ref_clk_ns = (1000000000) / ref_clk; + ref_clk_ns = DIV_ROUND_UP(1000000000, ref_clk);
/* Convert to ns. */ - sclk_ns = (1000000000) / sclk_hz; - - /* Plus 1 to round up 1 clock cycle. */ - tshsl = CQSPI_CAL_DELAY(tshsl_ns, ref_clk_ns, sclk_ns) + 1; - tchsh = CQSPI_CAL_DELAY(tchsh_ns, ref_clk_ns, sclk_ns) + 1; - tslch = CQSPI_CAL_DELAY(tslch_ns, ref_clk_ns, sclk_ns) + 1; - tsd2d = CQSPI_CAL_DELAY(tsd2d_ns, ref_clk_ns, sclk_ns) + 1; + sclk_ns = DIV_ROUND_UP(1000000000, sclk_hz); + + /* The controller adds additional delay to that programmed in the reg */ + if (tshsl_ns >= sclk_ns + ref_clk_ns) + tshsl_ns -= sclk_ns + ref_clk_ns; + if (tchsh_ns >= sclk_ns + 3 * ref_clk_ns) + tchsh_ns -= sclk_ns + 3 * ref_clk_ns; + tshsl = DIV_ROUND_UP(tshsl_ns, ref_clk_ns); + tchsh = DIV_ROUND_UP(tchsh_ns, ref_clk_ns); + tslch = DIV_ROUND_UP(tslch_ns, ref_clk_ns); + tsd2d = DIV_ROUND_UP(tsd2d_ns, ref_clk_ns);
reg = ((tshsl & CQSPI_REG_DELAY_TSHSL_MASK) << CQSPI_REG_DELAY_TSHSL_LSB);
The HW manual does not give details about what the register value for this bit actually does, other than "Choose edge on which data outputs from flash memory will be sampled".
--- Our HW engineers tell me that it needs to be set for our hardware. --- doc/device-tree-bindings/spi/spi-cadence.txt | 2 ++ drivers/spi/cadence_qspi.c | 10 +++++++--- drivers/spi/cadence_qspi.h | 3 ++- drivers/spi/cadence_qspi_apb.c | 8 +++++++- 4 files changed, 18 insertions(+), 5 deletions(-)
diff --git a/doc/device-tree-bindings/spi/spi-cadence.txt b/doc/device-tree-bindings/spi/spi-cadence.txt index c1e2233..71aa06a 100644 --- a/doc/device-tree-bindings/spi/spi-cadence.txt +++ b/doc/device-tree-bindings/spi/spi-cadence.txt @@ -26,3 +26,5 @@ connected flash properties select (n_ss_out). - tslch-ns : Delay in master reference clocks between setting n_ss_out low and first bit transfer +- sample-edge : The edge on which data outputs from flash memory will + be sampled. diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 1051afb..afe7cb2 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -39,8 +39,10 @@ static int cadence_spi_write_speed(struct udevice *bus, uint hz) /* Calibration sequence to determine the read data capture delay register */ static int spi_calibration(struct udevice *bus, uint hz) { + struct cadence_spi_platdata *plat = bus->platdata; struct cadence_spi_priv *priv = dev_get_priv(bus); void *base = priv->regbase; + unsigned int edge = plat->sample_edge; u8 opcode_rdid = 0x9F; unsigned int idcode = 0, temp = 0; int err = 0, i, range_lo = -1, range_hi = -1; @@ -49,7 +51,7 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_spi_write_speed(bus, 1000000);
/* configure the read data capture delay register to 0 */ - cadence_qspi_apb_readdata_capture(base, 1, 0); + cadence_qspi_apb_readdata_capture(base, 1, edge, 0);
/* Enable QSPI */ cadence_qspi_apb_controller_enable(base); @@ -69,7 +71,7 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_qspi_apb_controller_disable(base);
/* reconfigure the read data capture delay register */ - cadence_qspi_apb_readdata_capture(base, 1, i); + cadence_qspi_apb_readdata_capture(base, 1, edge, i);
/* Enable back QSPI */ cadence_qspi_apb_controller_enable(base); @@ -105,7 +107,8 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_qspi_apb_controller_disable(base);
/* configure the final value for read data capture delay register */ - cadence_qspi_apb_readdata_capture(base, 1, (range_hi + range_lo) / 2); + cadence_qspi_apb_readdata_capture(base, 1, edge, + (range_hi + range_lo) / 2); debug("SF: Read data capture delay calibrated to %i (%i - %i)\n", (range_hi + range_lo) / 2, range_lo, range_hi);
@@ -318,6 +321,7 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) plat->tchsh_ns = fdtdec_get_int(blob, subnode, "tchsh-ns", 20); plat->tslch_ns = fdtdec_get_int(blob, subnode, "tslch-ns", 20); plat->sram_size = fdtdec_get_int(blob, node, "sram-size", 128); + plat->sample_edge = fdtdec_get_int(blob, subnode, "sample-edge", 0);
debug("%s: regbase=%p ahbbase=%p max-frequency=%d page-size=%d\n", __func__, plat->regbase, plat->ahbbase, plat->max_hz, diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index a849f7b..3cd3b00 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -26,6 +26,7 @@ struct cadence_spi_platdata { u32 tchsh_ns; u32 tslch_ns; u32 sram_size; + unsigned int sample_edge; };
struct cadence_spi_priv { @@ -73,6 +74,6 @@ void cadence_qspi_apb_delay(void *reg_base, unsigned int tchsh_ns, unsigned int tslch_ns); void cadence_qspi_apb_enter_xip(void *reg_base, char xip_dummy); void cadence_qspi_apb_readdata_capture(void *reg_base, - unsigned int bypass, unsigned int delay); + unsigned int bypass, unsigned int edge, unsigned int delay);
#endif /* __CADENCE_QSPI_H__ */ diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 533274d..c43fde6 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -98,6 +98,7 @@ #define CQSPI_REG_RD_DATA_CAPTURE_BYPASS BIT(0) #define CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB 1 #define CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK 0xF +#define CQSPI_REG_RD_DATA_CAPTURE_EDGE BIT(5)
#define CQSPI_REG_SIZE 0x14 #define CQSPI_REG_SIZE_ADDRESS_LSB 0 @@ -237,7 +238,7 @@ static unsigned int cadence_qspi_wait_idle(void *reg_base) }
void cadence_qspi_apb_readdata_capture(void *reg_base, - unsigned int bypass, unsigned int delay) + unsigned int bypass, unsigned int edge, unsigned int delay) { unsigned int reg; cadence_qspi_apb_controller_disable(reg_base); @@ -249,6 +250,11 @@ void cadence_qspi_apb_readdata_capture(void *reg_base, else reg &= ~CQSPI_REG_RD_DATA_CAPTURE_BYPASS;
+ if (edge) + reg |= CQSPI_REG_RD_DATA_CAPTURE_EDGE; + else + reg &= ~CQSPI_REG_RD_DATA_CAPTURE_EDGE; + reg &= ~(CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK << CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB);
be sampled.
Could this be changed to bool property say sample-edge-rising?
sample-edge-rising(optional): data outputs from flash memory will be sampled at the rising edge. Default is falling edge
Hi Vignesh,
memory will
be sampled.
Whilst this makes sense, the trouble I have is that I don't know if the register setting is making it use rising or falling edge sampling. I'll try to find out again...
-- Regards Vignesh
Thanks Phil
Hi Jagan,
I've sent a couple of new versions of some of these patches based on feedback and something I noticed, but most have not had any comments. Would you like me to send the whole series again with the latest versions?
Thanks Phil
On Fri, Nov 25, 2016 at 6:02 PM, Phil Edworthy phil.edworthy@renesas.com wrote:
Hi Jagan,
Yes, please do that.
thanks!
Jagan Teki
Phil Edworthy
Vignesh R
