[U-Boot-Users] [MIPS] Rename Alchemy processor configs into CONFIGO_SOC_*
CONFIG_SOC_AU1X00
Common Alchemy Au1x00 stuff. All Alchemy processor based machines need to have this config as a system type specifier.
CONFIG_SOC_AU1000, CONFIG_SOC_AU1100, CONFIG_SOC_AU1200, CONFIG_SOC_AU1500, CONFIG_SOC_AU1550
Machine type specifiers. Each port should have one of aboves.
Signed-off-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp ---
cpu/mips/au1x00_eth.c | 12 ++++++------ cpu/mips/au1x00_serial.c | 4 ++-- cpu/mips/au1x00_usb_ohci.c | 2 +- include/asm-mips/addrspace.h | 6 +++--- include/asm-mips/au1x00.h | 6 +++--- include/configs/dbau1x00.h | 10 +++++----- include/configs/gth2.h | 4 ++-- include/configs/pb1x00.h | 8 ++++---- 8 files changed, 26 insertions(+), 26 deletions(-)
diff --git a/cpu/mips/au1x00_eth.c b/cpu/mips/au1x00_eth.c index d70c5fe..aeb9662 100644 --- a/cpu/mips/au1x00_eth.c +++ b/cpu/mips/au1x00_eth.c @@ -23,7 +23,7 @@ */ #include <config.h>
-#ifdef CONFIG_AU1X00 +#ifdef CONFIG_SOC_AU1X00
#if defined(CFG_DISCOVER_PHY) #error "PHY not supported yet" @@ -33,20 +33,20 @@
/* I assume ethernet behaves like au1000 */
-#ifdef CONFIG_AU1000 +#ifdef CONFIG_SOC_AU1000 /* Base address differ between cpu:s */ #define ETH0_BASE AU1000_ETH0_BASE #define MAC0_ENABLE AU1000_MAC0_ENABLE #else -#ifdef CONFIG_AU1100 +#ifdef CONFIG_SOC_AU1100 #define ETH0_BASE AU1100_ETH0_BASE #define MAC0_ENABLE AU1100_MAC0_ENABLE #else -#ifdef CONFIG_AU1500 +#ifdef CONFIG_SOC_AU1500 #define ETH0_BASE AU1500_ETH0_BASE #define MAC0_ENABLE AU1500_MAC0_ENABLE #else -#ifdef CONFIG_AU1550 +#ifdef CONFIG_SOC_AU1550 #define ETH0_BASE AU1550_ETH0_BASE #define MAC0_ENABLE AU1550_MAC0_ENABLE #else @@ -308,4 +308,4 @@ int au1x00_enet_initialize(bd_t *bis){ return 1; }
-#endif /* CONFIG_AU1X00 */ +#endif /* CONFIG_SOC_AU1X00 */ diff --git a/cpu/mips/au1x00_serial.c b/cpu/mips/au1x00_serial.c index 42c668e..ec10ac0 100644 --- a/cpu/mips/au1x00_serial.c +++ b/cpu/mips/au1x00_serial.c @@ -27,7 +27,7 @@
#include <config.h>
#include <common.h> #include <asm/au1x00.h> @@ -132,4 +132,4 @@ int serial_tstc (void) } return 0; } -#endif /* CONFIG_SERIAL_AU1X00 */ +#endif /* CONFIG_SOC_AU1X00 */ diff --git a/cpu/mips/au1x00_usb_ohci.c b/cpu/mips/au1x00_usb_ohci.c index dbf72dc..e03b125 100644 --- a/cpu/mips/au1x00_usb_ohci.c +++ b/cpu/mips/au1x00_usb_ohci.c @@ -35,7 +35,7 @@
#include <config.h>
-#if defined(CONFIG_AU1X00) && defined(CONFIG_USB_OHCI) +#if defined(CONFIG_SOC_AU1X00) && defined(CONFIG_USB_OHCI)
/* #include <pci.h> no PCI on the AU1x00 */
diff --git a/include/asm-mips/addrspace.h b/include/asm-mips/addrspace.h index 767804c..3a1e6d6 100644 --- a/include/asm-mips/addrspace.h +++ b/include/asm-mips/addrspace.h @@ -131,13 +131,13 @@ * Returns the uncached address of a sdram address */ #ifndef __ASSEMBLY__ -#if defined(CONFIG_AU1X00) || defined(CONFIG_TB0229) +#if defined(CONFIG_SOC_AU1X00) || defined(CONFIG_TB0229) /* We use a 36 bit physical address map here and cannot access physical memory directly from core */ #define UNCACHED_SDRAM(a) (((unsigned long)(a)) | 0x20000000) -#else /* !CONFIG_AU1X00 */ +#else /* !CONFIG_SOC_AU1X00 */ #define UNCACHED_SDRAM(a) KSEG1ADDR(a) -#endif /* CONFIG_AU1X00 */ +#endif /* CONFIG_SOC_AU1X00 */ #endif /* __ASSEMBLY__ */
/* diff --git a/include/asm-mips/au1x00.h b/include/asm-mips/au1x00.h index 6a33197..2a948e8 100644 --- a/include/asm-mips/au1x00.h +++ b/include/asm-mips/au1x00.h @@ -137,7 +137,7 @@ static __inline__ int au_ffs(int x) #define CP0_DEBUG $23
/* SDRAM Controller */ -#ifdef CONFIG_AU1550 +#ifdef CONFIG_SOC_AU1550
#define MEM_SDMODE0 0xB4000800 #define MEM_SDMODE1 0xB4000808 @@ -156,7 +156,7 @@ static __inline__ int au_ffs(int x) #define MEM_SDWRMD1 0xB4000888 #define MEM_SDWRMD2 0xB4000890
-#else /* CONFIG_AU1550 */ +#else /* CONFIG_SOC_AU1550 */
#define MEM_SDMODE0 0xB4000000 #define MEM_SDMODE1 0xB4000004 @@ -174,7 +174,7 @@ static __inline__ int au_ffs(int x) #define MEM_SDWRMD1 0xB4000028 #define MEM_SDWRMD2 0xB400002C
-#endif /* CONFIG_AU1550 */ +#endif /* CONFIG_SOC_AU1550 */
#define MEM_SDSLEEP 0xB4000030 #define MEM_SDSMCKE 0xB4000034 diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h index ddb98ac..d039e7a 100644 --- a/include/configs/dbau1x00.h +++ b/include/configs/dbau1x00.h @@ -30,21 +30,21 @@
#define CONFIG_CPU_MIPS32_R1 1 /* MIPS32 CPU core */ #define CONFIG_DBAU1X00 1 -#define CONFIG_AU1X00 1 /* alchemy series cpu */ +#define CONFIG_SOC_AU1X00 1 /* alchemy series cpu */
#ifdef CONFIG_DBAU1000 /* Also known as Merlot */ -#define CONFIG_AU1000 1 +#define CONFIG_SOC_AU1000 1 #else #ifdef CONFIG_DBAU1100 -#define CONFIG_AU1100 1 +#define CONFIG_SOC_AU1100 1 #else #ifdef CONFIG_DBAU1500 -#define CONFIG_AU1500 1 +#define CONFIG_SOC_AU1500 1 #else #ifdef CONFIG_DBAU1550 /* Cabernet */ -#define CONFIG_AU1550 1 +#define CONFIG_SOC_AU1550 1 #else #error "No valid board set" #endif diff --git a/include/configs/gth2.h b/include/configs/gth2.h index 50487fa..a0e8481 100644 --- a/include/configs/gth2.h +++ b/include/configs/gth2.h @@ -30,9 +30,9 @@
#define CONFIG_CPU_MIPS32_R1 1 /* MIPS32 CPU core */ #define CONFIG_GTH2 1 -#define CONFIG_AU1X00 1 /* alchemy series cpu */ +#define CONFIG_SOC_AU1X00 1 /* alchemy series cpu */
#define CONFIG_MISC_INIT_R 1
diff --git a/include/configs/pb1x00.h b/include/configs/pb1x00.h index 899959a..842ec6a 100644 --- a/include/configs/pb1x00.h +++ b/include/configs/pb1x00.h @@ -30,16 +30,16 @@
#define CONFIG_CPU_MIPS32_R1 1 /* MIPS32 CPU core */ #define CONFIG_PB1X00 1 -#define CONFIG_AU1X00 1 /* alchemy series cpu */ +#define CONFIG_SOC_AU1X00 1 /* alchemy series cpu */
#ifdef CONFIG_PB1000 -#define CONFIG_AU1000 1 +#define CONFIG_SOC_AU1000 1 #else #ifdef CONFIG_PB1100 -#define CONFIG_AU1100 1 +#define CONFIG_SOC_AU1100 1 #else #ifdef CONFIG_PB1500 -#define CONFIG_AU1500 1 +#define CONFIG_SOC_AU1500 1 #else #error "No valid board set" #endif
Shinya Kuribayashi
