[U-Boot] [PATCH] net: Use ARRAY_SIZE at appropriate places
Use ARRAY_SIZE instead of having similar implementation in each drivers.
Signed-off-by: Axel Lin axel.lin@ingics.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Ben Warren biggerbadderben@gmail.com Cc: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Marek Vasut marex@denx.de Cc: Mike Frysinger vapier@gentoo.org Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: TsiChungLiew Tsi-Chung.Liew@freescale.com Cc: Wolfgang Denk wd@denx.de Cc: York Sun yorksun@freescale.com --- Hi, tools/checkpatch.pl shows total: 2 errors, 12 warnings, 0 checks, 89 lines checked
The errors are: ERROR: code indent should use tabs where possible
The warnings are something like below: WARNING: line over 80 characters WARNING: please, no spaces at the start of a line WARNING: Avoid CamelCase: <ixEthDBPortDefinitions>
I don't fixup the checkpatch.pl issues because I feel having the patch as is seems cleaner.
Regards, Axel
drivers/net/ax88180.c | 2 +- drivers/net/fsl_mcdmafec.c | 2 +- drivers/net/lan91c96.c | 2 +- drivers/net/mcffec.c | 2 +- drivers/net/mcfmii.c | 2 +- drivers/net/ne2000.c | 2 +- drivers/net/npe/IxEthDBFeatures.c | 4 ++-- drivers/net/npe/IxOsalIoMem.c | 3 +-- drivers/net/npe/include/IxEthDBPortDefs.h | 2 +- drivers/net/npe/include/IxOsalTypes.h | 2 +- 10 files changed, 11 insertions(+), 12 deletions(-)
diff --git a/drivers/net/ax88180.c b/drivers/net/ax88180.c index f501768..7f0cfe5 100644 --- a/drivers/net/ax88180.c +++ b/drivers/net/ax88180.c @@ -157,7 +157,7 @@ static void ax88180_mac_reset (struct eth_device *dev) OUTW (dev, MISC_RESET_MAC, MISC); tmpval = INW (dev, MISC);
- for (i = 0; i < (sizeof (program_seq) / sizeof (program_seq[0])); i++) + for (i = 0; i < ARRAY_SIZE(program_seq); i++) OUTW (dev, program_seq[i].value, program_seq[i].offset); }
diff --git a/drivers/net/fsl_mcdmafec.c b/drivers/net/fsl_mcdmafec.c index 63842cd..0e18764 100644 --- a/drivers/net/fsl_mcdmafec.c +++ b/drivers/net/fsl_mcdmafec.c @@ -520,7 +520,7 @@ int mcdmafec_initialize(bd_t * bis) u32 tmp = CONFIG_SYS_INTSRAM + 0x2000; #endif
- for (i = 0; i < sizeof(fec_info) / sizeof(fec_info[0]); i++) { + for (i = 0; i < ARRAY_SIZE(fec_info); i++) {
dev = (struct eth_device *)memalign(CONFIG_SYS_CACHELINE_SIZE, diff --git a/drivers/net/lan91c96.c b/drivers/net/lan91c96.c index 11d350e..47c15c4 100644 --- a/drivers/net/lan91c96.c +++ b/drivers/net/lan91c96.c @@ -779,7 +779,7 @@ static int lan91c96_detect_chip(struct eth_device *dev) SMC_SELECT_BANK(dev, 3); chip_id = (SMC_inw(dev, 0xA) & LAN91C96_REV_CHIPID) >> 4; SMC_SELECT_BANK(dev, 0); - for (r = 0; r < sizeof(supported_chips) / sizeof(struct id_type); r++) + for (r = 0; r < ARRAY_SIZE(supported_chips); r++) if (chip_id == supported_chips[r].id) return r; return 0; diff --git a/drivers/net/mcffec.c b/drivers/net/mcffec.c index ed7459c..7ae6320 100644 --- a/drivers/net/mcffec.c +++ b/drivers/net/mcffec.c @@ -559,7 +559,7 @@ int mcffec_initialize(bd_t * bis) u32 tmp = CONFIG_SYS_INIT_RAM_ADDR + 0x1000; #endif
dev = (struct eth_device *)memalign(CONFIG_SYS_CACHELINE_SIZE, diff --git a/drivers/net/mcfmii.c b/drivers/net/mcfmii.c index 5e64dbd..63bc8f8 100644 --- a/drivers/net/mcfmii.c +++ b/drivers/net/mcfmii.c @@ -186,7 +186,7 @@ int mii_discover_phy(struct eth_device *dev) printf("PHY @ 0x%x pass %d\n", phyno, pass); #endif
- for (i = 0; (i < (sizeof(phyinfo) / sizeof(phy_info_t))) + for (i = 0; (i < ARRAY_SIZE(phyinfo)) && (phyinfo[i].phyid != 0); i++) { if (phyinfo[i].phyid == phytype) { #ifdef ET_DEBUG diff --git a/drivers/net/ne2000.c b/drivers/net/ne2000.c index 3939158..e6cd3e9 100644 --- a/drivers/net/ne2000.c +++ b/drivers/net/ne2000.c @@ -228,7 +228,7 @@ int get_prom(u8* mac_addr, u8* base_addr)
mdelay (10);
- for (i = 0; i < sizeof (program_seq) / sizeof (program_seq[0]); i++) + for (i = 0; i < ARRAY_SIZE(program_seq); i++) n2k_outb (program_seq[i].value, program_seq[i].offset);
PRINTK ("PROM:"); diff --git a/drivers/net/npe/IxEthDBFeatures.c b/drivers/net/npe/IxEthDBFeatures.c index c5b680a..ecabec5 100644 --- a/drivers/net/npe/IxEthDBFeatures.c +++ b/drivers/net/npe/IxEthDBFeatures.c @@ -144,7 +144,7 @@ void ixEthDBFeatureCapabilityScan(void)
/* find the traffic class definition index compatible with the current NPE A functionality ID */ for (trafficClassDefinitionIndex = 0 ; - trafficClassDefinitionIndex < sizeof (ixEthDBTrafficClassDefinitions) / sizeof (ixEthDBTrafficClassDefinitions[0]); + trafficClassDefinitionIndex < ARRAY_SIZE(ixEthDBTrafficClassDefinitions); trafficClassDefinitionIndex++) { if (ixEthDBTrafficClassDefinitions[trafficClassDefinitionIndex][IX_ETH_DB_NPE_A_FUNCTIONALITY_ID_INDEX] == npeAImageId.functionalityId) @@ -155,7 +155,7 @@ void ixEthDBFeatureCapabilityScan(void) }
/* select the default case if we went over the array boundary */ - if (trafficClassDefinitionIndex == sizeof (ixEthDBTrafficClassDefinitions) / sizeof (ixEthDBTrafficClassDefinitions[0])) + if (trafficClassDefinitionIndex == ARRAY_SIZE(ixEthDBTrafficClassDefinitions)) { trafficClassDefinitionIndex = 0; /* the first record is the default case */ } diff --git a/drivers/net/npe/IxOsalIoMem.c b/drivers/net/npe/IxOsalIoMem.c index 34df92b..087fdf3 100644 --- a/drivers/net/npe/IxOsalIoMem.c +++ b/drivers/net/npe/IxOsalIoMem.c @@ -66,8 +66,7 @@ ixOsalMemMapFind (UINT32 requestedAddress, { UINT32 mapIndex;
- UINT32 numMapElements = - sizeof (ixOsalGlobalMemoryMap) / sizeof (IxOsalMemoryMap); + UINT32 numMapElements = ARRAY_SIZE(ixOsalGlobalMemoryMap);
for (mapIndex = 0; mapIndex < numMapElements; mapIndex++) { diff --git a/drivers/net/npe/include/IxEthDBPortDefs.h b/drivers/net/npe/include/IxEthDBPortDefs.h index c3acbdd..eac48cb 100644 --- a/drivers/net/npe/include/IxEthDBPortDefs.h +++ b/drivers/net/npe/include/IxEthDBPortDefs.h @@ -106,7 +106,7 @@ static const IxEthDBPortDefinition ixEthDBPortDefinitions[] = * @def IX_ETH_DB_NUMBER_OF_PORTS * @brief number of supported ports */ -#define IX_ETH_DB_NUMBER_OF_PORTS (sizeof (ixEthDBPortDefinitions) / sizeof (ixEthDBPortDefinitions[0])) +#define IX_ETH_DB_NUMBER_OF_PORTS ARRAY_SIZE(ixEthDBPortDefinitions)
/** * @def IX_ETH_DB_UNKNOWN_PORT diff --git a/drivers/net/npe/include/IxOsalTypes.h b/drivers/net/npe/include/IxOsalTypes.h index 06e71de..615c655 100644 --- a/drivers/net/npe/include/IxOsalTypes.h +++ b/drivers/net/npe/include/IxOsalTypes.h @@ -93,7 +93,7 @@ typedef volatile INT32 VINT32;
#ifndef NUMELEMS -#define NUMELEMS(x) (sizeof(x) / sizeof((x)[0])) +#define NUMELEMS(x) ARRAY_SIZE(x) #endif
Hi Axel,
Please fix these WARNINGS/ERRORS, as these comes issues comes up with your changed code-
-- Thanks, Jagan.
Regards, Axel
for (i = 0; i < ARRAY_SIZE(fec_info); i++) { dev = (struct eth_device *)memalign(CONFIG_SYS_CACHELINE_SIZE,
mdelay (10);
for (i = 0; i < ARRAY_SIZE(program_seq); i++) n2k_outb (program_seq[i].value, program_seq[i].offset); PRINTK ("PROM:");
- @def IX_ETH_DB_NUMBER_OF_PORTS
- @brief number of supported ports
- @def IX_ETH_DB_UNKNOWN_PORT
-- 1.8.1.2
Dear Axel Lin,
You can trim the CC a bit next time ;-)
No problem on my end, that's understandable.
Regards, Axel
Just kill this macro altogether please.
Best regards, Marek Vasut
2013/6/30 Marek Vasut marex@denx.de:
Dear Axel Lin,
Hi Marek,
I try to cc related people. the maintainers, the driver authers, and developer who is active in recent commits.
Is there a smarter way to find who should be CCed? Some tool like get_maintainer.pl used in linux kernel may help.
Regards, Axel
Ah, yes. I missed your comment here when I reply the mail. NUMELEMS is not used at all so it can be removed. Will fix it in v3.
I just sent v2 per Jagan Teki's request. I think I'll wait for Jagan Teki's feedback before sending v3.
Thanks for the review. Axel
Axel Lin
Jagan Teki
