[PATCH v3 1/3] riscv: Avoid the reserved memory fixup if src and dst point to the same place
The copy of reserved memory node from source dtb to destination dtb can be avoided if they point to the same place. This is useful when OF_PRIOR_STAGE is used.
Signed-off-by: Bin Meng bin.meng@windriver.com Reviewed-by: Rick Chen rick@andestech.com ---
(no changes since v1)
arch/riscv/lib/fdt_fixup.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/arch/riscv/lib/fdt_fixup.c b/arch/riscv/lib/fdt_fixup.c index 6db48ad..5f523f0 100644 --- a/arch/riscv/lib/fdt_fixup.c +++ b/arch/riscv/lib/fdt_fixup.c @@ -82,10 +82,9 @@ int riscv_fdt_copy_resv_mem_node(const void *src, void *dst) * @fdt: Pointer to the device tree in which reserved memory node needs to be * added. * - * In RISC-V, any board compiled with OF_SEPARATE needs to copy the reserved - * memory node from the device tree provided by the firmware to the device tree - * used by U-Boot. This is a common function that individual board fixup - * functions can invoke. + * In RISC-V, any board needs to copy the reserved memory node from the device + * tree provided by the firmware to the device tree used by U-Boot. This is a + * common function that individual board fixup functions can invoke. * * Return: 0 on success or error otherwise. */ @@ -95,6 +94,11 @@ int riscv_board_reserved_mem_fixup(void *fdt) void *src_fdt_addr;
src_fdt_addr = map_sysmem(gd->arch.firmware_fdt_addr, 0); + + /* avoid the copy if we are using the same device tree */ + if (src_fdt_addr == fdt) + return 0; + err = riscv_fdt_copy_resv_mem_node(src_fdt_addr, fdt); if (err < 0) return err;
The FDT blob might not have sufficient space to hold a copy of reserved memory node. Expand it before the copy.
Reported-by: Rick Chen rick@andestech.com Signed-off-by: Bin Meng bin.meng@windriver.com ---
Changes in v3: - Extend the FDT size by 1024 bytes
arch/riscv/lib/fdt_fixup.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/riscv/lib/fdt_fixup.c b/arch/riscv/lib/fdt_fixup.c index 5f523f0..160ccca 100644 --- a/arch/riscv/lib/fdt_fixup.c +++ b/arch/riscv/lib/fdt_fixup.c @@ -41,6 +41,18 @@ int riscv_fdt_copy_resv_mem_node(const void *src, void *dst) return 0; }
+ /* + * Extend the FDT by the following estimated size: + * + * Each PMP memory region entry occupies 64 bytes. + * With 16 PMP memory regions we need 64 * 16 = 1024 bytes. + */ + err = fdt_open_into(dst, dst, fdt_totalsize(dst) + 1024); + if (err < 0) { + printf("Device Tree can't be expanded to accommodate new node"); + return err; + } + fdt_for_each_subnode(node, src, offset) { name = fdt_get_name(src, node, NULL);
Changes in v3:
if (err < 0) {
return err;
-- 2.7.4
Reviewed-by: Atish Patra atish.patra@wdc.com
Starting from OpenSBI v0.7, the SBI firmware inserts/fixes up the reserved memory node for PMP protected memory regions. All RISC-V boards needs to copy the reserved memory node from the device tree provided by the firmware to the device tree used by U-Boot.
Turn on CONFIG_OF_BOARD_FIXUP by default for OF_SEPARATE.
Changes in v3: - change to "default y if OF_SEPARATE"
arch/riscv/Kconfig | 3 +++ configs/sifive_fu540_defconfig | 1 - 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index d9854f5..ff8a9f8 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -273,4 +273,7 @@ config STACK_SIZE_SHIFT int default 14
+config OF_BOARD_FIXUP + default y if OF_SEPARATE + endmenu diff --git a/configs/sifive_fu540_defconfig b/configs/sifive_fu540_defconfig index 8d412f8..32347c2 100644 --- a/configs/sifive_fu540_defconfig +++ b/configs/sifive_fu540_defconfig @@ -16,7 +16,6 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_OF_BOARD_FIXUP=y CONFIG_DEFAULT_DEVICE_TREE="hifive-unleashed-a00" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_CLK=y
nits: /s/needs/need
Changes in v3:
endmenu diff --git a/configs/sifive_fu540_defconfig b/configs/sifive_fu540_defconfig index 8d412f8..32347c2 100644 --- a/configs/sifive_fu540_defconfig +++ b/configs/sifive_fu540_defconfig @@ -16,7 +16,6 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_OF_BOARD_FIXUP=y CONFIG_DEFAULT_DEVICE_TREE="hifive-unleashed-a00" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_CLK=y -- 2.7.4
- @fdt: Pointer to the device tree in which reserved memory node needs to be
added.
- In RISC-V, any board compiled with OF_SEPARATE needs to copy the reserved
- memory node from the device tree provided by the firmware to the device tree
- used by U-Boot. This is a common function that individual board fixup
- functions can invoke.
- In RISC-V, any board needs to copy the reserved memory node from the device
- tree provided by the firmware to the device tree used by U-Boot. This is a
- common function that individual board fixup functions can invoke.
- Return: 0 on success or error otherwise.
-- 2.7.4
Atish Patra
Bin Meng
