[U-Boot] [PATCH v2 0/2] at91: serial initialization cleanup
Hello,
I took up the suggestions from Jean-Christophe and the discussion in http://lists.denx.de/pipermail/u-boot/2008-November/043131.html and reworked the patch so that cpu specfic code goes to specfic files. This results to less ifdefs.
An argument to at91_serial_hw_init() is not needed because all can be done against CONFIG_USARTx in a91xyz_serial.c and atmel_usart.c.
Additionally I extended the patch to rename CONFIG_USART3 to CONFIG_USART_DBGU on at91 plattforms.
Michael Roth
Created a new function at91_serial_hw_init() which sets up the dedicated PIO pins of several at91 SoC according to CONFIG_USARTx.
Please note that the used pins for serial communication varies on different at91 SoC independently of the logic functionality equality of the serial hardware. But for each serial channel there is only one possibility for IO pin multiplexing so there is no need for board specific PIO setup. So the usage of SoC specific PIO setup is advisable.
Signed-off-by: Michael Roth mroth@nessie.de --- board/afeb9260/afeb9260.c | 30 +--------------- board/atmel/at91cap9adk/at91cap9adk.c | 30 +--------------- board/atmel/at91sam9260ek/at91sam9260ek.c | 30 +--------------- board/atmel/at91sam9261ek/at91sam9261ek.c | 30 +--------------- board/atmel/at91sam9263ek/at91sam9263ek.c | 30 +--------------- board/atmel/at91sam9rlek/at91sam9rlek.c | 30 +--------------- cpu/arm926ejs/at91/Makefile | 20 +++++++++++ cpu/arm926ejs/at91/at91cap9_serial.c | 53 +++++++++++++++++++++++++++++ cpu/arm926ejs/at91/at91sam9260_serial.c | 53 +++++++++++++++++++++++++++++ cpu/arm926ejs/at91/at91sam9261_serial.c | 53 +++++++++++++++++++++++++++++ cpu/arm926ejs/at91/at91sam9263_serial.c | 53 +++++++++++++++++++++++++++++ cpu/arm926ejs/at91/at91sam9rl_serial.c | 53 +++++++++++++++++++++++++++++ include/asm-arm/arch-at91/at91_serial.h | 25 +++++++++++++ 13 files changed, 322 insertions(+), 168 deletions(-) create mode 100644 cpu/arm926ejs/at91/at91cap9_serial.c create mode 100644 cpu/arm926ejs/at91/at91sam9260_serial.c create mode 100644 cpu/arm926ejs/at91/at91sam9261_serial.c create mode 100644 cpu/arm926ejs/at91/at91sam9263_serial.c create mode 100644 cpu/arm926ejs/at91/at91sam9rl_serial.c create mode 100644 include/asm-arm/arch-at91/at91_serial.h
diff --git a/board/afeb9260/afeb9260.c b/board/afeb9260/afeb9260.c index 32445ab..95950c7 100644 --- a/board/afeb9260/afeb9260.c +++ b/board/afeb9260/afeb9260.c @@ -29,6 +29,7 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> +#include <asm/arch/at91_serial.h> #include <asm/arch/gpio.h> #include <asm/arch/io.h> #include <asm/arch/hardware.h> @@ -44,33 +45,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void afeb9260_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PB4, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PB5, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PB6, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PB7, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PB8, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PB9, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PB14, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PB15, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - static void afeb9260_nand_hw_init(void) { unsigned long csa; @@ -201,7 +175,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- afeb9260_serial_hw_init(); + at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND afeb9260_nand_hw_init(); #endif diff --git a/board/atmel/at91cap9adk/at91cap9adk.c b/board/atmel/at91cap9adk/at91cap9adk.c index f7d68b7..29b51ee 100644 --- a/board/atmel/at91cap9adk/at91cap9adk.c +++ b/board/atmel/at91cap9adk/at91cap9adk.c @@ -28,6 +28,7 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> +#include <asm/arch/at91_serial.h> #include <asm/arch/gpio.h> #include <asm/arch/io.h> #include <asm/arch/hardware.h> @@ -47,33 +48,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void at91cap9_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PA22, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA23, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - static void at91cap9_slowclock_hw_init(void) { /* @@ -367,7 +341,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91cap9_serial_hw_init(); + at91_serial_hw_init(); at91cap9_slowclock_hw_init(); at91cap9_nor_hw_init(); #ifdef CONFIG_CMD_NAND diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index ef99b8b..686bfe2 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -28,6 +28,7 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> +#include <asm/arch/at91_serial.h> #include <asm/arch/gpio.h> #include <asm/arch/io.h> #include <asm/arch/hardware.h> @@ -43,33 +44,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void at91sam9260ek_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PB4, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PB5, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PB6, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PB7, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PB8, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PB9, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PB14, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PB15, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - #ifdef CONFIG_CMD_NAND static void at91sam9260ek_nand_hw_init(void) { @@ -217,7 +191,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91sam9260ek_serial_hw_init(); + at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND at91sam9260ek_nand_hw_init(); #endif diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index 14f236d..7707dc3 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -28,6 +28,7 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> +#include <asm/arch/at91_serial.h> #include <asm/arch/gpio.h> #include <asm/arch/io.h> #include <lcd.h> @@ -43,33 +44,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void at91sam9261ek_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PC8, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PC9, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PC12, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PC13, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PC14, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PC15, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PA9, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PA10, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - #ifdef CONFIG_CMD_NAND static void at91sam9261ek_nand_hw_init(void) { @@ -250,7 +224,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91sam9261ek_serial_hw_init(); + at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND at91sam9261ek_nand_hw_init(); #endif diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index ebd4649..35c18b0 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -29,6 +29,7 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> +#include <asm/arch/at91_serial.h> #include <asm/arch/gpio.h> #include <asm/arch/io.h> #include <asm/arch/hardware.h> @@ -46,33 +47,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void at91sam9263ek_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PA26, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA27, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - #ifdef CONFIG_CMD_NAND static void at91sam9263ek_nand_hw_init(void) { @@ -301,7 +275,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91sam9263ek_serial_hw_init(); + at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND at91sam9263ek_nand_hw_init(); #endif diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index b6fef9d..a6ce9d9 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -28,6 +28,7 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> +#include <asm/arch/at91_serial.h> #include <asm/arch/gpio.h> #include <asm/arch/io.h> #include <lcd.h> @@ -43,33 +44,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void at91sam9rlek_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PA6, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA7, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PA11, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PA12, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PA13, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PA14, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PA21, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PA22, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - #ifdef CONFIG_CMD_NAND static void at91sam9rlek_nand_hw_init(void) { @@ -223,7 +197,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91sam9rlek_serial_hw_init(); + at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND at91sam9rlek_nand_hw_init(); #endif diff --git a/cpu/arm926ejs/at91/Makefile b/cpu/arm926ejs/at91/Makefile index 2d2a888..f94d961 100644 --- a/cpu/arm926ejs/at91/Makefile +++ b/cpu/arm926ejs/at91/Makefile @@ -30,6 +30,26 @@ COBJS-$(CONFIG_HAS_DATAFLASH) +=spi.o COBJS-y += usb.o SOBJS = lowlevel_init.o
+ifdef CONFIG_AT91CAP9 +COBJS-y += at91cap9_serial.o +endif + +ifdef CONFIG_AT91SAM9260 +COBJS-y += at91sam9260_serial.o +endif + +ifdef CONFIG_AT91SAM9261 +COBJS-y += at91sam9261_serial.o +endif + +ifdef CONFIG_AT91SAM9263 +COBJS-y += at91sam9263_serial.o +endif + +ifdef CONFIG_AT91SAM9RL +COBJS-y += at91sam9rl_serial.o +endif + SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y))
diff --git a/cpu/arm926ejs/at91/at91cap9_serial.c b/cpu/arm926ejs/at91/at91cap9_serial.c new file mode 100644 index 0000000..6dd53cf --- /dev/null +++ b/cpu/arm926ejs/at91/at91cap9_serial.c @@ -0,0 +1,53 @@ +/* + * (C) Copyright 2009 Michael Roth mroth@nessie.de + * + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#include <common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_serial.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void at91_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PA22, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PA23, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US0); +#endif +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US1); +#endif +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US2); +#endif +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} diff --git a/cpu/arm926ejs/at91/at91sam9260_serial.c b/cpu/arm926ejs/at91/at91sam9260_serial.c new file mode 100644 index 0000000..e63748b --- /dev/null +++ b/cpu/arm926ejs/at91/at91sam9260_serial.c @@ -0,0 +1,53 @@ +/* + * (C) Copyright 2009 Michael Roth mroth@nessie.de + * + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#include <common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_serial.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void at91_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PB4, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PB5, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US0); +#endif +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PB6, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PB7, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US1); +#endif +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PB8, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PB9, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US2); +#endif +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PB14, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PB15, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} diff --git a/cpu/arm926ejs/at91/at91sam9261_serial.c b/cpu/arm926ejs/at91/at91sam9261_serial.c new file mode 100644 index 0000000..f3b4fd4 --- /dev/null +++ b/cpu/arm926ejs/at91/at91sam9261_serial.c @@ -0,0 +1,53 @@ +/* + * (C) Copyright 2009 Michael Roth mroth@nessie.de + * + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#include <common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_serial.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void at91_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PC8, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PC9, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US0); +#endif +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PC12, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PC13, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US1); +#endif +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PC14, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PC15, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US2); +#endif +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PA9, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PA10, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} diff --git a/cpu/arm926ejs/at91/at91sam9263_serial.c b/cpu/arm926ejs/at91/at91sam9263_serial.c new file mode 100644 index 0000000..0e83a21 --- /dev/null +++ b/cpu/arm926ejs/at91/at91sam9263_serial.c @@ -0,0 +1,53 @@ +/* + * (C) Copyright 2009 Michael Roth mroth@nessie.de + * + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#include <common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_serial.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void at91_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PA26, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PA27, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US0); +#endif +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US1); +#endif +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US2); +#endif +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} diff --git a/cpu/arm926ejs/at91/at91sam9rl_serial.c b/cpu/arm926ejs/at91/at91sam9rl_serial.c new file mode 100644 index 0000000..e71305c --- /dev/null +++ b/cpu/arm926ejs/at91/at91sam9rl_serial.c @@ -0,0 +1,53 @@ +/* + * (C) Copyright 2009 Michael Roth mroth@nessie.de + * + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#include <common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_serial.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void at91_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PA6, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PA7, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US0); +#endif +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PA11, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PA12, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US1); +#endif +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PA13, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PA14, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US2); +#endif +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PA21, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PA22, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} diff --git a/include/asm-arm/arch-at91/at91_serial.h b/include/asm-arm/arch-at91/at91_serial.h new file mode 100644 index 0000000..d7ce640 --- /dev/null +++ b/include/asm-arm/arch-at91/at91_serial.h @@ -0,0 +1,25 @@ +/* + * Copyright (C) 2009 Michael Roth mroth@nessie.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef __AT91_SERIAL_H__ +#define __AT91_SERIAL_H__ + +#include <common.h> + +extern void at91_serial_hw_init(void); + +#endif /* __AT91_SERIAL_H__ */
In reality there are only three usarts on at91 SoC and one serial debug port called DBGU which is a reduced functionality usart.
For reasons of clarity and consistency the prefix USART is maintained independently the fact that normally the debug port is just called DBGU.
Signed-off-by: Michael Roth mroth@nessie.de --- drivers/serial/atmel_usart.c | 23 ++++++++++++++--------- include/asm-arm/arch-at91/clk.h | 5 +++++ include/asm-arm/arch-at91/memory-map.h | 8 ++++---- include/configs/afeb9260.h | 2 +- include/configs/at91cap9adk.h | 2 +- include/configs/at91sam9260ek.h | 2 +- include/configs/at91sam9261ek.h | 2 +- include/configs/at91sam9263ek.h | 2 +- include/configs/at91sam9rlek.h | 2 +- 9 files changed, 29 insertions(+), 19 deletions(-)
diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index f3b146c..f310dcd 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -22,17 +22,22 @@ #include <asm/arch/memory-map.h>
#if defined(CONFIG_USART0) -# define USART_ID 0 -# define USART_BASE USART0_BASE +# define GET_USART_CLK_RATE() get_usart_clk_rate(0) +# define USART_BASE USART0_BASE #elif defined(CONFIG_USART1) -# define USART_ID 1 -# define USART_BASE USART1_BASE +# define GET_USART_CLK_RATE() get_usart_clk_rate(1) +# define USART_BASE USART1_BASE #elif defined(CONFIG_USART2) -# define USART_ID 2 -# define USART_BASE USART2_BASE +# define GET_USART_CLK_RATE() get_usart_clk_rate(2) +# define USART_BASE USART2_BASE #elif defined(CONFIG_USART3) -# define USART_ID 3 -# define USART_BASE USART3_BASE +# define GET_USART_CLK_RATE() get_usart_clk_rate(3) +# define USART_BASE USART3_BASE +#elif defined(CONFIG_USART_DBGU) +# define GET_USART_CLK_RATE() get_usart_dbgu_clk_rate() +# define USART_BASE USART_DBGU_BASE +#else +# error No CONFIG_USARTx defined! #endif
#include "atmel_usart.h" @@ -49,7 +54,7 @@ void serial_setbrg(void) * Baud Rate = -------------- * 16 * CD */ - usart_hz = get_usart_clk_rate(USART_ID); + usart_hz = GET_USART_CLK_RATE(); divisor = (usart_hz / 16 + gd->baudrate / 2) / gd->baudrate; usart3_writel(BRGR, USART3_BF(CD, divisor)); } diff --git a/include/asm-arm/arch-at91/clk.h b/include/asm-arm/arch-at91/clk.h index 1b502c8..51a90a9 100644 --- a/include/asm-arm/arch-at91/clk.h +++ b/include/asm-arm/arch-at91/clk.h @@ -36,6 +36,11 @@ static inline unsigned long get_usart_clk_rate(unsigned int dev_id) return AT91_MASTER_CLOCK; }
+static inline unsigned long get_usart_dbgu_clk_rate(void) +{ + return AT91_MASTER_CLOCK; +} + static inline unsigned long get_lcdc_clk_rate(unsigned int dev_id) { return AT91_MASTER_CLOCK; diff --git a/include/asm-arm/arch-at91/memory-map.h b/include/asm-arm/arch-at91/memory-map.h index 8015dad..0013022 100644 --- a/include/asm-arm/arch-at91/memory-map.h +++ b/include/asm-arm/arch-at91/memory-map.h @@ -26,9 +26,9 @@
-#define USART0_BASE AT91_USART0 -#define USART1_BASE AT91_USART1 -#define USART2_BASE AT91_USART2 -#define USART3_BASE (AT91_BASE_SYS + AT91_DBGU) +#define USART0_BASE AT91_USART0 +#define USART1_BASE AT91_USART1 +#define USART2_BASE AT91_USART2 +#define USART_DBGU_BASE (AT91_BASE_SYS + AT91_DBGU)
#endif /* __ASM_ARM_ARCH_MEMORYMAP_H__ */ diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 9eed342..815483a 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -52,7 +52,7 @@ #undef CONFIG_USART0 #undef CONFIG_USART1 #undef CONFIG_USART2 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_USART_DBGU 1
#define CONFIG_BOOTDELAY 3
diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index 01da99b..39d13ee 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -56,7 +56,7 @@ #undef CONFIG_USART0 #undef CONFIG_USART1 #undef CONFIG_USART2 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_USART_DBGU 1
/* LCD */ #define CONFIG_LCD 1 diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 2f1a41f..2b81cb0 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -56,7 +56,7 @@ #undef CONFIG_USART0 #undef CONFIG_USART1 #undef CONFIG_USART2 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_USART_DBGU 1
diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index ebecfa4..3db0cca 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -55,7 +55,7 @@ #undef CONFIG_USART0 #undef CONFIG_USART1 #undef CONFIG_USART2 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_USART_DBGU 1
/* LCD */ #define CONFIG_LCD 1 diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 09b871a..ff9ce46 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -56,7 +56,7 @@ #undef CONFIG_USART0 #undef CONFIG_USART1 #undef CONFIG_USART2 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_USART_DBGU 1
/* LCD */ #define CONFIG_LCD 1 diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 5bef1fe..b6adcb8 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -55,7 +55,7 @@ #undef CONFIG_USART0 #undef CONFIG_USART1 #undef CONFIG_USART2 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_USART_DBGU 1
Dear Michael Roth,
If I understand correctly, we are waiting for an updated / rebased version of this patch from you. Are you going to submit one any time soon?
please do remove my Copyright and orignial sob
I've done this for the serial to add multiple serial support please do not remvoe
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD
Michael Roth
