[PATCH] Revert "lib: sparse: Make CHUNK_TYPE_RAW buffer aligned"
This reverts commit 62649165cb02ab95b57360bb362886935f524f26.
The patch decreased the write performance quite a bit. Here is an example on an i.MX 8M Quad platform. - Before the revert: Sending sparse 'vendor' 1/2 (516436 KB) OKAY [ 5.113s] Writing 'vendor' OKAY [128.335s] Sending sparse 'vendor' 2/2 (76100 KB) OKAY [ 0.802s] Writing 'vendor' OKAY [ 27.902s] - After the revert: Sending sparse 'vendor' 1/2 (516436 KB) OKAY [ 5.310s] Writing 'vendor' OKAY [ 18.041s] Sending sparse 'vendor' 2/2 (76100 KB) OKAY [ 1.244s] Writing 'vendor' OKAY [ 2.663s]
Considering that the patch only moves buffer around to avoid a warning message about misaligned buffers, let's keep the best performances.
Signed-off-by: Gary Bisson gary.bisson@boundarydevices.com Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com --- lib/image-sparse.c | 69 ++++++---------------------------------------- 1 file changed, 8 insertions(+), 61 deletions(-)
diff --git a/lib/image-sparse.c b/lib/image-sparse.c index 5ec0f94ab3e..d80fdbbf58e 100644 --- a/lib/image-sparse.c +++ b/lib/image-sparse.c @@ -46,66 +46,9 @@ #include <asm/cache.h>
#include <linux/math64.h> -#include <linux/err.h>
static void default_log(const char *ignored, char *response) {}
-static lbaint_t write_sparse_chunk_raw(struct sparse_storage *info, - lbaint_t blk, lbaint_t blkcnt, - void *data, - char *response) -{ - lbaint_t n = blkcnt, write_blks, blks = 0, aligned_buf_blks = 100; - uint32_t *aligned_buf = NULL; - - if (CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) { - write_blks = info->write(info, blk, n, data); - if (write_blks < n) - goto write_fail; - - return write_blks; - } - - aligned_buf = memalign(ARCH_DMA_MINALIGN, info->blksz * aligned_buf_blks); - if (!aligned_buf) { - info->mssg("Malloc failed for: CHUNK_TYPE_RAW", response); - return -ENOMEM; - } - - while (blkcnt > 0) { - n = min(aligned_buf_blks, blkcnt); - memcpy(aligned_buf, data, n * info->blksz); - - /* write_blks might be > n due to NAND bad-blocks */ - write_blks = info->write(info, blk + blks, n, aligned_buf); - if (write_blks < n) { - free(aligned_buf); - goto write_fail; - } - - blks += write_blks; - data += n * info->blksz; - blkcnt -= n; - } - - free(aligned_buf); - return blks; - -write_fail: - if (IS_ERR_VALUE(write_blks)) { - printf("%s: Write failed, block #" LBAFU " [" LBAFU "] (%lld)\n", - __func__, blk + blks, n, (long long)write_blks); - info->mssg("flash write failure", response); - return write_blks; - } - - /* write_blks < n */ - printf("%s: Write failed, block #" LBAFU " [" LBAFU "]\n", - __func__, blk + blks, n); - info->mssg("flash write failure(incomplete)", response); - return -1; -} - int write_sparse_image(struct sparse_storage *info, const char *part_name, void *data, char *response) { @@ -209,11 +152,15 @@ int write_sparse_image(struct sparse_storage *info, return -1; }
- blks = write_sparse_chunk_raw(info, blk, blkcnt, - data, response); - if (blks < 0) + blks = info->write(info, blk, blkcnt, data); + /* blks might be > blkcnt (eg. NAND bad-blocks) */ + if (blks < blkcnt) { + printf("%s: %s" LBAFU " [" LBAFU "]\n", + __func__, "Write failed, block #", + blk, blks); + info->mssg("flash write failure", response); return -1; - + } blk += blks; bytes_written += ((u64)blkcnt) * info->blksz; total_blocks += chunk_header->chunk_sz;
- After the revert:
So what is the point of this warning?
--Sean
void *data,
char *response)
if (write_blks < n)
goto write_fail;
return write_blks;
return -ENOMEM;
free(aligned_buf);
goto write_fail;
blks += write_blks;
blkcnt -= n;
- return blks;
-write_fail:
return write_blks;
- return -1;
data, response);
if (blks < 0)
blk, blks);
- After the revert:
Well the warning does say something true that the cache operation is not aligned. Better ask Simon as he's the one who changed the print from a debug to warn_non_spl one: bcc53bf0958 arm: Show cache warnings in U-Boot proper only
BTW, in my case I couldn't see the misaligned messages, yet I saw the performance hit described above.
Regards, Gary
- After the revert:
Maybe it is better to keep this as a Kconfig? Some arches may support unaligned access but others may not. I wonder if we have something like this already.
--Seam
Hi Gary, Sean,
- After the revert:
I also reproduce this problem on AM62x SK EVM.
Before the revert: Sending sparse 'super' 1/2 (768793 KB) OKAY [ 23.954s] Writing 'super' OKAY [ 75.926s] Sending sparse 'super' 2/2 (629819 KB) OKAY [ 19.641s] Writing 'super' OKAY [ 62.849s] Finished. Total time: 182.474s
After the revert: Sending sparse 'super' 1/2 (768793 KB) OKAY [ 23.895s] Writing 'super' OKAY [ 12.961s] Sending sparse 'super' 2/2 (629819 KB) OKAY [ 19.562s] Writing 'super' OKAY [ 12.805s] Finished. Total time: 69.327s
And like Gary, I did not observe the misaligned messages.
Did we come up with a solution for this performance regression?
I will continue looking on my end but please let me know if you already solved this.
Thanks,
Matijs
--Seam
On ven., juin 16, 2023 at 13:56, Mattijs Korpershoek mkorpershoek@baylibre.com wrote:
Hi Gary, Sean,
- After the revert:
Answering to myself here. My attempt of solving this problem has been submitted here:
https://lore.kernel.org/r/20230616-sparse-flash-fix-v1-1-6bafeacc567b@baylib...
Thanks,
Matijs
--Seam
Hi Gary, Sean,
- After the revert:
Thanks for digging in to this!
Gary Bisson
Mattijs Korpershoek
Sean Anderson
