The following changes since commit fbf87b1823dd5ebc2a384711ea2c677543019ece:
arm: optimize relocate_code routine (2013-06-21 23:05:50 +0200)
git://git.denx.de/u-boot-pxa.git master
for you to fetch changes up to 9dc8fef2583f23ca6a99c6f5e709a8b80018364f:
pxa: fix memory coherency problem after relocation (2013-06-22 15:25:28 +0200)
---------------------------------------------------------------- Mike Dunn (5): pxa: add support for palmtreo680 board pxa: palmtreo680 flash programming utility pxa: turn icache off in cpu_init_crit() pxa: use -mcpu=xscale compiler option pxa: fix memory coherency problem after relocation
CREDITS | 4 + MAINTAINERS | 3 + arch/arm/cpu/pxa/config.mk | 2 +- arch/arm/cpu/pxa/start.S | 3 +- arch/arm/lib/relocate.S | 9 +++ board/palmtreo680/Makefile | 34 +++++++++ board/palmtreo680/README | 581 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/palmtreo680/palmtreo680.c | 148 +++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/palmtreo680.h | 286 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ tools/palmtreo680/flash_u-boot.c | 177 ++++++++++++++++++++++++++++++++++++++++++ 11 files changed, 1245 insertions(+), 3 deletions(-) create mode 100644 board/palmtreo680/Makefile create mode 100644 board/palmtreo680/README create mode 100644 board/palmtreo680/palmtreo680.c create mode 100644 include/configs/palmtreo680.h create mode 100644 tools/palmtreo680/flash_u-boot.c
Hi Marek,
gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-1ubuntu1)
fails with warnings for palmtreo680:
pxa27x_udc.c: In function 'udc_read_urb': pxa27x_udc.c:154:21: warning: variable 'is_short' set but not used [-Wunused-but-set-variable] pxa27x_udc.c: In function 'udc_state_changed': pxa27x_udc.c:405:25: warning: variable 'alternate' set but not used [-Wunused-but-set-variable] pxa27x_udc.c:405:14: warning: variable 'interface' set but not used [-Wunused-but-set-variable] pxa27x_udc.c:405:6: warning: variable 'config' set but not used [-Wunused-but-set-variable] docg4_spl.c: In function 'docg4_load_block_reliable': docg4_spl.c:116:32: warning: variable 'magic_low' set but not used [-Wunused-but-set-variable] docg4_spl.c:116:20: warning: variable 'magic_high' set but not used [-Wunused-but-set-variable] docg4_spl.c:116:11: warning: variable 'discard' set but not used [-Wunused-but-set-variable]
Mike, please fix the warnings; Marek, please update u-boot-pxa/master and submit a new PR.
Amicalement,
On 06/22/2013 09:57 AM, Albert ARIBAUD wrote:
Hi Marek,
I don't get these warnings, despite the u-boot makefiles passing -Wall to gcc. I'm using gcc version 4.5.4... I guess maybe I need to update gcc because later versions are stricter? I'll go ahead and do that, and if this produces the warnings, I'll submit patches that eliminates them. Sorry.
Thanks, Mike
Hi Mike,
Hi Marek,
No need to be sorry -- you were using a toolchain that does not emit these warnings, so you could not be expected to see them.
FYI, I am using the ARM cross-toolchain available in my Ubuntu 13.04.
Thanks, Mike
Amicalement,
Dear Albert ARIBAUD,
Hi Mike,
Hi Marek,
are available in the git repository at: git://git.denx.de/u-boot-pxa.git master
for you to fetch changes up to 9dc8fef2583f23ca6a99c6f5e709a8b80018364f: pxa: fix memory coherency problem after relocation (2013-06-22 15:25:28 +0200)
For some reason, I feel the linaro ones were always stuffed with experimental and semi-broken stuff :-(
Best regards, Marek Vasut
Hi Marek,
Maybe they were; all I can say is, the Ubuntu/Linaro toolchain never failed me in any way.
Amicalement,
On 06/23/2013 03:13 AM, Albert ARIBAUD wrote:
Hi Marek,
I build my toolchain using the crossdev script, which is a gentoo package. I've been doing this for years without any problems, except that occasionally building requires some trial-and-error because of incompatibilities between gcc/binutils/glibc. But other than that, I am able to choose the version of each tool.
Mike
Dear Mike Dunn,
Hi Marek,
I'll just add my bit into this toolchain onanism ... I build my toolchains with buildcross (it's a debian thing) ... fap fap.
Hi Marek,
Applied to u-boot-arm/master despite palmtreo680 build warnings as fixes are going to come from other repos.
Amicalement,
Albert ARIBAUD
Mike Dunn
