[U-Boot] [PATCH 0/2] SF: add support for sst26wf016, sst26wf032, sst26wf064
Add support for the SST sst26wf016, sst26wf032 and sst26wf064 flash IC:
sst26wf*** flash series block protection implementation differs from other SST series, so we add implementation for sst26wf*** lock/unlock/is_locked functions.
Add sst26wf016, sst26wf032 and sst26wf064 flash IC info to spi_flash_ids list.
Eugeniy Paltsev (2): SPI Flash: add support of sst26wf* flash series SF: add support for sst26wf016, sst26wf032, sst26wf064
drivers/mtd/spi/spi_flash.c | 188 ++++++++++++++++++++++++++++++++++++++++ drivers/mtd/spi/spi_flash_ids.c | 3 + 2 files changed, 191 insertions(+)
sst26wf flash series block protection implementation differs from other SST series, so add implementation for sst26wf lock/unlock/is_locked functions.
Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com --- drivers/mtd/spi/spi_flash.c | 188 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 188 insertions(+)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 294d9f9..ec3f5bc 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -842,6 +842,184 @@ int stm_unlock(struct spi_flash *flash, u32 ofs, size_t len) } #endif
+#if defined(CONFIG_SPI_FLASH_SST) +#define SST26_CMD_READ_BPR 0x72 +#define SST26_CMD_WRITE_BPR 0x42 + +#define BLOCK_64K_SZ 0x10000 +#define MAX_BPR_REG_LEN (18 + 1) +#define SST26WF_BOUND_REG_SIZE ((32 + 4 * 8) * 1024) + +bool sst26_check_bpr(u32 bpr_size, u8 *cmd, u32 bit) +{ + return !!(cmd[bpr_size - (bit / 8) - 1] & BIT(bit % 8)); +} + +bool sst26_clear_bpr(u32 bpr_size, u8 *cmd, u32 bit) +{ + cmd[bpr_size - (bit / 8) - 1] &= ~BIT(bit % 8); + return false; +} + +bool sst26_set_bpr(u32 bpr_size, u8 *cmd, u32 bit) +{ + cmd[bpr_size - (bit / 8) - 1] |= BIT(bit % 8); + return false; +} + +enum lock_ctl { + CTL_LOCK, + CTL_UNLOCK, + CTL_CHECK +}; + +/* + * sst26wf016/sst26wf032/sst26wf064 have next block protection: + * 4x - 8 KByte blocks - read & write protection bits - upper addresses + * 1x - 32 KByte blocks - write protection bits + * rest - 64 KByte blocks - write protection bits + * 1x - 32 KByte blocks - write protection bits + * 4x - 8 KByte blocks - read & write protection bits - lower addresses + * + * We'll support only per 64k lock/unlock so lower and upper 64 KByte region + * will be treated as single block. + */ + +/* + * Lock, unlock or check lock status of the flash region of the flash (depending + * on the lock_ctl value) + */ +int sst26_lock_ctl(struct spi_flash *flash, u32 ofs, size_t len, enum lock_ctl ctl) +{ + u32 i, bpr_ptr, rptr_64k, lptr_64k, bpr_size; + bool lower_64k = false, upper_64k = false; + u8 cmd, bpr_buff[MAX_BPR_REG_LEN] = {}; + int ret; + + bool (* bpr_bit_process) (u32 bpr_size, u8 *, u32); + + /* Check length and offset for 64k alignment */ + if ((ofs & 0xFFFF) || (len & 0xFFFF)) + return -EINVAL; + + if (ofs + len > flash->size) + return -EINVAL; + + /* SST26 family has only 16 Mbit, 32 Mbit and 64 Mbit IC */ + if (flash->size != 0x200000 && + flash->size != 0x400000 && + flash->size != 0x800000) + return -EINVAL; + + bpr_size = 2 + (flash->size / BLOCK_64K_SZ / 8); + + cmd = SST26_CMD_READ_BPR; + ret = spi_flash_read_common(flash, &cmd, 1, bpr_buff, bpr_size); + if (ret < 0) { + printf("SF: fail to read block-protection register\n"); + return ret; + } + + if (ctl == CTL_LOCK) + bpr_bit_process = sst26_set_bpr; + else if (ctl == CTL_UNLOCK) + bpr_bit_process = sst26_clear_bpr; + else + bpr_bit_process = sst26_check_bpr; + + rptr_64k = min_t(u32, ofs + len , flash->size - SST26WF_BOUND_REG_SIZE); + lptr_64k = max_t(u32, ofs, SST26WF_BOUND_REG_SIZE); + + upper_64k = ((ofs + len) > (flash->size - SST26WF_BOUND_REG_SIZE)); + lower_64k = (ofs < SST26WF_BOUND_REG_SIZE); + + /* Lower bits in block-protection register are about 64k region */ + bpr_ptr = lptr_64k / BLOCK_64K_SZ - 1; + + /* Process 64K blocks region */ + while (lptr_64k < rptr_64k) { + if (bpr_bit_process(bpr_size, bpr_buff, bpr_ptr)) + return 1; + + bpr_ptr++; + lptr_64k += BLOCK_64K_SZ; + } + + /* 32K and 8K region bits in BPR are after 64k region bits */ + bpr_ptr = (flash->size - 2 * SST26WF_BOUND_REG_SIZE) / BLOCK_64K_SZ; + + /* Process lower 32K block region */ + if (lower_64k) + if (bpr_bit_process(bpr_size, bpr_buff, bpr_ptr)) + return 1; + + bpr_ptr++; + + /* Process upper 32K block region */ + if (upper_64k) + if (bpr_bit_process(bpr_size, bpr_buff, bpr_ptr)) + return 1; + + bpr_ptr++; + + /* Process lower 8K block region */ + for (i = 0; i < 4; i++) { + if (lower_64k) + if (bpr_bit_process(bpr_size, bpr_buff, bpr_ptr)) + return 1; + + /* In 8K area BPR has both read and write protection bits */ + bpr_ptr += 2; + } + + /* Process upper 8K block region */ + for (i = 0; i < 4; i++) { + if (upper_64k) + if (bpr_bit_process(bpr_size, bpr_buff, bpr_ptr)) + return 1; + + /* In 8K area BPR has both read and write protection bits */ + bpr_ptr += 2; + } + + /* If we check region status we don't need to write BPR back */ + if (ctl == CTL_CHECK) + return 0; + + cmd = SST26_CMD_WRITE_BPR; + ret = spi_flash_write_common(flash, &cmd, 1, bpr_buff, bpr_size); + if (ret < 0) { + printf("SF: fail to write block-protection register\n"); + return ret; + } + + return 0; +} + +int sst26_unlock(struct spi_flash *flash, u32 ofs, size_t len) +{ + return sst26_lock_ctl(flash, ofs, len, CTL_UNLOCK); +} + +int sst26_lock(struct spi_flash *flash, u32 ofs, size_t len) +{ + return sst26_lock_ctl(flash, ofs, len, CTL_LOCK); +} + +int sst26_is_locked(struct spi_flash *flash, u32 ofs, size_t len) +{ + /* + * is_locked function is used for check before reading or erasing flash + * region, so offset and length might be not 64k allighned, so adjust + * them to be 64k allighned as sst26_lock_ctl works only with 64k + * allighned regions. + */ + ofs -= ofs & 0xFFFF; + len = len & 0xFFFF ? (len & ~0xFFFF) + BLOCK_64K_SZ : len; + + return sst26_lock_ctl(flash, ofs, len, CTL_CHECK); +} +#endif
#ifdef CONFIG_SPI_FLASH_MACRONIX static int macronix_quad_enable(struct spi_flash *flash) @@ -1033,6 +1211,16 @@ int spi_flash_scan(struct spi_flash *flash) } #endif
+/* sst26wf series block protection implementation differs from other series */ +#if defined(CONFIG_SPI_FLASH_SST) + if (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_SST && + (JEDEC_ID(info) >> 8) == 0x26) { + flash->flash_lock = sst26_lock; + flash->flash_unlock = sst26_unlock; + flash->flash_is_locked = sst26_is_locked; + } +#endif + /* Compute the flash size */ flash->shift = (flash->dual_flash & SF_DUAL_PARALLEL_FLASH) ? 1 : 0; flash->page_size = info->page_size;
Hi Jagan,
Maybe you have any comments or remarks about this patch? And if you don't could you please apply it. Thanks!
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 294d9f9..ec3f5bc 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -842,6 +842,184 @@ int stm_unlock(struct spi_flash *flash, u32 ofs, size_t len) } #endif +#if defined(CONFIG_SPI_FLASH_SST) +#define SST26_CMD_READ_BPR 0x72 +#define SST26_CMD_WRITE_BPR 0x42
- return !!(cmd[bpr_size - (bit / 8) - 1] & BIT(bit % 8));
- cmd[bpr_size - (bit / 8) - 1] &= ~BIT(bit % 8);
- return false;
- cmd[bpr_size - (bit / 8) - 1] |= BIT(bit % 8);
- return false;
+enum lock_ctl {
- CTL_LOCK,
- CTL_UNLOCK,
- CTL_CHECK
- sst26wf016/sst26wf032/sst26wf064 have next block protection:
- 4x - 8 KByte blocks - read & write protection bits - upper addresses
- 1x - 32 KByte blocks - write protection bits
- rest - 64 KByte blocks - write protection bits
- 4x - 8 KByte blocks - read & write protection bits - lower addresses
- We'll support only per 64k lock/unlock so lower and upper 64 KByte region
- will be treated as single block.
- Lock, unlock or check lock status of the flash region of the flash (depending
- on the lock_ctl value)
- u32 i, bpr_ptr, rptr_64k, lptr_64k, bpr_size;
- bool lower_64k = false, upper_64k = false;
- u8 cmd, bpr_buff[MAX_BPR_REG_LEN] = {};
- int ret;
- bool (* bpr_bit_process) (u32 bpr_size, u8 *, u32);
- /* Check length and offset for 64k alignment */
- if ((ofs & 0xFFFF) || (len & 0xFFFF))
return -EINVAL;
- if (ofs + len > flash->size)
return -EINVAL;
- /* SST26 family has only 16 Mbit, 32 Mbit and 64 Mbit IC */
- if (flash->size != 0x200000 &&
- flash->size != 0x400000 &&
- flash->size != 0x800000)
return -EINVAL;
- bpr_size = 2 + (flash->size / BLOCK_64K_SZ / 8);
- cmd = SST26_CMD_READ_BPR;
- ret = spi_flash_read_common(flash, &cmd, 1, bpr_buff, bpr_size);
- if (ret < 0) {
return ret;
- if (ctl == CTL_LOCK)
- else if (ctl == CTL_UNLOCK)
- else
- rptr_64k = min_t(u32, ofs + len , flash->size - SST26WF_BOUND_REG_SIZE);
- lptr_64k = max_t(u32, ofs, SST26WF_BOUND_REG_SIZE);
- upper_64k = ((ofs + len) > (flash->size - SST26WF_BOUND_REG_SIZE));
- lower_64k = (ofs < SST26WF_BOUND_REG_SIZE);
- /* Lower bits in block-protection register are about 64k region */
- bpr_ptr = lptr_64k / BLOCK_64K_SZ - 1;
- /* Process 64K blocks region */
- while (lptr_64k < rptr_64k) {
return 1;
bpr_ptr++;
- /* 32K and 8K region bits in BPR are after 64k region bits */
- bpr_ptr = (flash->size - 2 * SST26WF_BOUND_REG_SIZE) / BLOCK_64K_SZ;
- /* Process lower 32K block region */
- if (lower_64k)
return 1;
- bpr_ptr++;
- /* Process upper 32K block region */
- if (upper_64k)
return 1;
- bpr_ptr++;
- /* Process lower 8K block region */
- for (i = 0; i < 4; i++) {
if (lower_64k)
return 1;
bpr_ptr += 2;
- /* Process upper 8K block region */
if (upper_64k)
return 1;
bpr_ptr += 2;
- /* If we check region status we don't need to write BPR back */
- if (ctl == CTL_CHECK)
- cmd = SST26_CMD_WRITE_BPR;
- ret = spi_flash_write_common(flash, &cmd, 1, bpr_buff, bpr_size);
- if (ret < 0) {
return ret;
- return sst26_lock_ctl(flash, ofs, len, CTL_UNLOCK);
- return sst26_lock_ctl(flash, ofs, len, CTL_LOCK);
- * is_locked function is used for check before reading or erasing flash
- * region, so offset and length might be not 64k allighned, so adjust
- * them to be 64k allighned as sst26_lock_ctl works only with 64k
- * allighned regions.
- ofs -= ofs & 0xFFFF;
- len = len & 0xFFFF ? (len & ~0xFFFF) + BLOCK_64K_SZ : len;
- return sst26_lock_ctl(flash, ofs, len, CTL_CHECK);
+} +#endif #ifdef CONFIG_SPI_FLASH_MACRONIX static int macronix_quad_enable(struct spi_flash *flash) @@ -1033,6 +1211,16 @@ int spi_flash_scan(struct spi_flash *flash) } #endif +/* sst26wf series block protection implementation differs from other series */ +#if defined(CONFIG_SPI_FLASH_SST)
- if (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_SST &&
- (JEDEC_ID(info) >> 8) == 0x26) {
On Tue, Feb 6, 2018 at 8:45 PM, Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com wrote:
How it is different from existing SST implementation, Linux has support this similar part and use normal SST?
Hi Jagan,
Looks like the person, who add sst26wf* flash series support to Linux only use/test reading from these flash ICs and reading works fine as only write protection implementation was changed.
Also it ids possible that these write protection bits were cleared by prebootloader on platform there that patch was test - so flash IC was already unlocked.
BTW: I have plans to port this patch to linux too.
This commit adds support for the SST sst26wf016, sst26wf032 and sst26wf064 flash IC.
Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com --- drivers/mtd/spi/spi_flash_ids.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mtd/spi/spi_flash_ids.c b/drivers/mtd/spi/spi_flash_ids.c index 262d81e..dedc232 100644 --- a/drivers/mtd/spi/spi_flash_ids.c +++ b/drivers/mtd/spi/spi_flash_ids.c @@ -150,6 +150,9 @@ const struct spi_flash_info spi_flash_ids[] = { {"sst25wf040", INFO(0xbf2504, 0x0, 64 * 1024, 8, SECT_4K | SST_WR) }, {"sst25wf040b", INFO(0x621613, 0x0, 64 * 1024, 8, SECT_4K) }, {"sst25wf080", INFO(0xbf2505, 0x0, 64 * 1024, 16, SECT_4K | SST_WR) }, + {"sst26wf016", INFO(0xbf2651, 0x0, 64 * 1024, 32, SECT_4K) }, + {"sst26wf032", INFO(0xbf2622, 0x0, 64 * 1024, 64, SECT_4K) }, + {"sst26wf064", INFO(0xbf2643, 0x0, 64 * 1024, 128, SECT_4K) }, #endif #ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ {"w25p80", INFO(0xef2014, 0x0, 64 * 1024, 16, 0) },
Eugeniy Paltsev
Jagan Teki
