[U-Boot-Users] [PATCH 03/25] include/configs: Use new CONFIG_CMD_* in TQM board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/TQM5200.h | 90 +++++++++++++++++++++------------------------ include/configs/TQM823L.h | 36 ++++++++---------- include/configs/TQM823M.h | 25 +++++++----- include/configs/TQM8260.h | 23 ++++++----- include/configs/TQM8272.h | 33 +++++++++------- include/configs/TQM834x.h | 48 ++++++++++------------- include/configs/TQM850L.h | 24 ++++++----- include/configs/TQM850M.h | 24 ++++++----- include/configs/TQM855L.h | 25 +++++++----- include/configs/TQM855M.h | 29 ++++++++------ include/configs/TQM860L.h | 29 ++++++++------ include/configs/TQM860M.h | 29 ++++++++------ include/configs/TQM862L.h | 25 +++++++----- include/configs/TQM862M.h | 25 +++++++----- include/configs/TQM866M.h | 25 +++++++----- include/configs/TQM885D.h | 35 +++++++++-------- 16 files changed, 273 insertions(+), 252 deletions(-)
diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index aa3627b..24114b8 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -47,11 +47,6 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) -# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - /* * Serial console configuration */ @@ -105,12 +100,6 @@ #define CONFIG_NS8382X 1 #endif /* CONFIG_STK52XX */
-#ifdef CONFIG_PCI -#define ADD_PCI_CMD CFG_CMD_PCI -#else -#define ADD_PCI_CMD 0 -#endif - /* * Video console */ @@ -133,11 +122,6 @@ #define CFG_CONSOLE_IS_IN_ENV #endif /* #ifndef CONFIG_TQM5200S */
-#ifdef CONFIG_VIDEO -#define ADD_BMP_CMD CFG_CMD_BMP -#else -#define ADD_BMP_CMD 0 -#endif
/* Partitions */ #define CONFIG_MAC_PARTITION @@ -147,10 +131,7 @@ /* USB */ #if defined(CONFIG_STK52XX) || defined(CONFIG_FO300) #define CONFIG_USB_OHCI -#define ADD_USB_CMD CFG_CMD_USB | CFG_CMD_FAT #define CONFIG_USB_STORAGE -#else -#define ADD_USB_CMD 0 #endif
#ifndef CONFIG_CAM5200 @@ -168,37 +149,45 @@ #define CFG_CMD_POST_DIAG 0 #endif
-/* IDE */ -#if defined (CONFIG_MINIFAP) || defined (CONFIG_STK52XX) || defined(CONFIG_FO300) -#define ADD_IDE_CMD (CFG_CMD_IDE | CFG_CMD_FAT | CFG_CMD_EXT2) -#else -#define ADD_IDE_CMD 0 -#endif
/* - * Supported commands + * Command line configuration. */ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - ADD_BMP_CMD | \ - ADD_IDE_CMD | \ - ADD_PCI_CMD | \ - ADD_USB_CMD | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_EEPROM | \ - CFG_CMD_I2C | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_MII | \ - CFG_CMD_NFS | \ - CFG_CMD_PING | \ - CFG_CMD_POST_DIAG | \ - CFG_CMD_REGINFO | \ - CFG_CMD_SNTP | \ - CFG_CMD_BSP) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MII +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PING +#define CONFIG_CMD_POST_DIAG +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SNTP +#define CONFIG_CMD_BSP + +#ifdef CONFIG_VIDEO + #define CONFIG_CMD_BMP +#endif + +#ifdef CONFIG_PCI +#define CONFIG_CMD_CMD_PCI +#endif + +#if defined(CONFIG_MINIFAP) || defined(CONFIG_STK52XX) || defined(CONFIG_FO300) + #define CONFIG_CMD_IDE + #define CONFIG_CMD_FAT + #define CONFIG_CMD_EXT2 +#endif + +#if defined(CONFIG_STK52XX) || defined(CONFIG_FO300) + #define CONFIG_CFG_USB + #define CONFIG_CFG_FAT +#endif +
#define CONFIG_TIMESTAMP /* display image timestamps */
@@ -566,7 +555,12 @@ #define CFG_HUSH_PARSER 1 /* use "hush" command parser */ #define CFG_PROMPT_HUSH_PS2 "> "
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +#define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index 247f705..86df7f6 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -95,27 +95,23 @@
#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */
+ +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_IDE +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP + #ifdef CONFIG_SPLASH_SCREEN -# define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_BMP | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP ) -#else -# define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP ) + #define CONFIG_CMD_BMP #endif
/* * Miscellaneous configurable options @@ -129,7 +125,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -212,7 +208,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index 1461b5f..bd33efb 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -95,16 +95,19 @@
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP )
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_IDE +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP +
/* * Miscellaneous configurable options @@ -118,7 +121,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -202,7 +205,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM8260.h b/include/configs/TQM8260.h index ffd5c0b..3089fef 100644 --- a/include/configs/TQM8260.h +++ b/include/configs/TQM8260.h @@ -222,15 +222,18 @@
#define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT|CONFIG_BOOTP_BOOTFILESIZE)
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_DHCP | \ - CFG_CMD_I2C | \ - CFG_CMD_EEPROM | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP )
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP +
/* * Miscellaneous configurable options @@ -244,7 +247,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -385,7 +388,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM8272.h b/include/configs/TQM8272.h index 925bf34..b7a1bae 100644 --- a/include/configs/TQM8272.h +++ b/include/configs/TQM8272.h @@ -274,18 +274,21 @@
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_NAND | \ - CFG_CMD_DHCP | \ - CFG_CMD_PING | \ - ADD_CMD_I2C | \ - CFG_CMD_NFS | \ - CFG_CMD_MII | \ - CFG_CMD_PCI | \ - CFG_CMD_SNTP ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_I2C +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_SNTP +
/* * Miscellaneous configurable options @@ -301,7 +304,7 @@ #endif #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -392,7 +395,7 @@ * NAND-FLASH stuff *----------------------------------------------------------------------- */ -#if (CONFIG_COMMANDS & CFG_CMD_NAND) +#if defined(CONFIG_CMD_NAND)
#define CFG_NAND_CS_DIST 0x80 #define CFG_NAND_UPM_WRITE_CMD_OFS 0x20 @@ -502,7 +505,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 4a5f8b6..9628703 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -316,38 +316,32 @@ extern int tqm834x_num_flash_banks; #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
-/* Common commands */ -#define CFG_CMD_TQM8349_COMMON CFG_CMD_DATE | CFG_CMD_I2C | CFG_CMD_DTT\ - | CFG_CMD_PING | CFG_CMD_EEPROM \ - | CFG_CMD_MII | CFG_CMD_JFFS2
-#if defined(CFG_RAMBOOT) +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DTT +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING
#if defined(CONFIG_PCI) -#define CONFIG_COMMANDS ((CONFIG_CMD_DFL | CFG_CMD_PCI \ - | CFG_CMD_TQM8349_COMMON) \ - & \ - ~(CFG_CMD_ENV | CFG_CMD_LOADS)) -#else -#define CONFIG_COMMANDS ((CONFIG_CMD_DFL \ - | CFG_CMD_TQM8349_COMMON) \ - & \ - ~(CFG_CMD_ENV | CFG_CMD_LOADS)) + #define CONFIG_CMD_PCI #endif
-#else /* CFG_RAMBOOT */ - -#if defined(CONFIG_PCI) -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | CFG_CMD_PCI \ - | CFG_CMD_TQM8349_COMMON) -#else -#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ - | CFG_CMD_TQM8349_COMMON) +#if defined(CFG_RAMBOOT) + #undef CONFIG_CMD_ENV + #undef CONFIG_CMD_LOADS #endif
-#endif /* CFG_RAMBOOT */
/* * Miscellaneous configurable options @@ -362,7 +356,7 @@ extern int tqm834x_num_flash_banks; #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -387,7 +381,7 @@ extern int tqm834x_num_flash_banks; */ #define CFG_DCACHE_SIZE 32768 #define CFG_CACHELINE_SIZE 32 -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value*/ #endif
@@ -495,7 +489,7 @@ extern int tqm834x_num_flash_banks; #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed of kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index 90ecbad..923d4e5 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -87,16 +87,18 @@
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP ) +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_IDE +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP
/* * Miscellaneous configurable options @@ -110,7 +112,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -193,7 +195,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index b3f8f8d..c257fc5 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -85,16 +85,18 @@
/* * Miscellaneous configurable options @@ -108,7 +110,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -192,7 +194,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index 49aaeea..7da7b0b 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -90,16 +90,19 @@
/* * Miscellaneous configurable options @@ -113,7 +116,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -196,7 +199,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index 50df49e..e66bbc4 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -123,17 +123,20 @@
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_EEPROM | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_IDE +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP +
/* * Miscellaneous configurable options @@ -147,7 +150,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -231,7 +234,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index 9be5db1..495760a 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -90,19 +90,22 @@
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_ELF | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP )
-#define CONFIG_NETCONSOLE +/* + * Command line configuration. + */ +#include <config_cmd_default.h>
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IDE +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP + + +#define CONFIG_NETCONSOLE
/* * Miscellaneous configurable options @@ -116,7 +119,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -199,7 +202,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index 37f6c98..e86e5fb 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -90,17 +90,20 @@
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_ELF | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IDE +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP +
/* * Miscellaneous configurable options @@ -114,7 +117,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -198,7 +201,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index f03690a..0512251 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -93,16 +93,19 @@
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -200,7 +203,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index 4959340..df141a7 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -93,16 +93,19 @@
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -201,7 +204,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index 148490b..27e37e2 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -134,16 +134,19 @@
#define CONFIG_TIMESTAMP /* but print image timestmps */
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DHCP | \ - CFG_CMD_EEPROM | \ - CFG_CMD_I2C | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS )
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_NFS +
/* * Miscellaneous configurable options @@ -157,7 +160,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -241,7 +244,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index d470ade..4731988 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -140,19 +140,22 @@
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_EEPROM | \ - CFG_CMD_I2C | \ - CFG_CMD_IDE | \ - CFG_CMD_MII | \ - CFG_CMD_NFS | \ - CFG_CMD_PING ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_MII +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PING +
/* * Miscellaneous configurable options @@ -166,7 +169,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -258,7 +261,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
@@ -478,7 +481,7 @@ #define CONFIG_ETHER_ON_FEC1 /* ... for FEC1 */ #define CONFIG_ETHER_ON_FEC2 /* ... for FEC2 */
-#if (CONFIG_COMMANDS & CFG_CMD_MII) +#if defined(CONFIG_CMD_MII) #define CFG_DISCOVER_PHY #endif
Jon Loeliger
