[U-Boot] [PATCH][v2] board/lx2160ardb: Add distro boot support
Add u-boot enviroments to support distro boot which scan boot.scr from external storage devices (e.g. SD/USB/SATA/SCSI disk) and execute autoboot script.
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- Depends on https://patchwork.ozlabs.org/patch/990094/ Changes for v2: xspi_bootcmd, sd_bootcmd env variables are dependent on board. So, move the definition from lx2160a_common.h file to lx2160ardb.h file
configs/lx2160ardb_tfa_defconfig | 3 +- include/configs/lx2160a_common.h | 84 +++++++++++++++++++++++++++++++++++----- include/configs/lx2160ardb.h | 29 +++++++------- 3 files changed, 90 insertions(+), 26 deletions(-)
diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index 64cc31d..86fdcfc 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -6,7 +6,6 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2160a-rdb" CONFIG_NR_DRAM_BANKS=3 CONFIG_DM=y -CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y @@ -14,7 +13,7 @@ CONFIG_TFABOOT=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" -# CONFIG_CMD_IMLS is not set +# CONFIG_USE_BOOTCOMMAND is not set CONFIG_CMD_GREPENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_GPT=y diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 19053b43a1..5b4fabe 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -194,16 +194,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */
/* Initial environment variables */ -#define XSPI_NOR_BOOTCOMMAND "fsl_mc apply dpl 0x20d00000;" \ - "sf probe 0:0;" \ - "sf read 0xa0000000 0x1000000 0x3000000;" \ - "bootm 0xa0000000" - -#define SD_BOOTCOMMAND "mmc read 0xa0000000 0x6800 0xA0;" \ - "fsl_mc apply dpl 0xa0000000;" \ - "mmc read 0xb0000000 0x8000 0x1d000;" \ - "bootm 0xb0000000" - #define XSPI_MC_INIT_CMD \ "fsl_mc start mc 0x20a00000 0x20e00000\0"
@@ -212,4 +202,78 @@ unsigned long get_board_ddr_clk(void); "mmc read 0x80100000 0x7000 0x800;" \ "fsl_mc start mc 0x80000000 0x80100000\0"
+#define EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "fdt_addr=0x64f00000\0" \ + "kernel_start=0x1000000\0" \ + "kernelheader_start=0x800000\0" \ + "scriptaddr=0x80000000\0" \ + "scripthdraddr=0x80080000\0" \ + "fdtheader_addr_r=0x80100000\0" \ + "kernelheader_addr_r=0x80200000\0" \ + "kernel_addr_r=0x81000000\0" \ + "kernelheader_size=0x40000\0" \ + "fdt_addr_r=0x90000000\0" \ + "load_addr=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "kernel_addr_sd=0x8000\0" \ + "kernel_size_sd=0x1d000\0" \ + "console=ttyAMA0,38400n8\0" \ + BOOTENV \ + "mcmemsize=0x70000000\0" \ + XSPI_MC_INIT_CMD \ + "boot_scripts=lx2160ardb_boot.scr\0" \ + "boot_script_hdr=hdr_lx2160ardb_bs.out\0" \ + "scan_dev_for_boot_part=" \ + "part list ${devtype} ${devnum} devplist; " \ + "env exists devplist || setenv devplist 1; " \ + "for distro_bootpart in ${devplist}; do " \ + "if fstype ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "bootfstype; then " \ + "run scan_dev_for_boot; " \ + "fi; " \ + "done\0" \ + "scan_dev_for_boot=" \ + "echo Scanning ${devtype} " \ + "${devnum}:${distro_bootpart}...; " \ + "for prefix in ${boot_prefixes}; do " \ + "run scan_dev_for_scripts; " \ + "done;\0" \ + "boot_a_script=" \ + "load ${devtype} ${devnum}:${distro_bootpart} " \ + "${scriptaddr} ${prefix}${script}; " \ + "env exists secureboot && load ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "${scripthdraddr} ${prefix}${boot_script_hdr} " \ + "&& esbc_validate ${scripthdraddr};" \ + "source ${scriptaddr}\0" + +#define XSPI_NOR_BOOTCOMMAND \ + "env exists mcinitcmd && env exists secureboot "\ + "&& esbc_validate 0x20780000; " \ + "env exists mcinitcmd && " \ + "fsl_mc lazyapply dpl 0x20d00000; " \ + "run distro_bootcmd;run xspi_bootcmd; " \ + "env exists secureboot && esbc_halt;" + +#define SD_BOOTCOMMAND \ + "env exists mcinitcmd && mmcinfo; " \ + "mmc read 0x80001000 0x6800 0x800; " \ + "env exists mcinitcmd && env exists secureboot " \ + " && mmc read 0x80780000 0x3C00 0x10 " \ + "&& esbc_validate 0x80780000;env exists mcinitcmd " \ + "&& fsl_mc lazyapply dpl 0x80001000;" \ + "run distro_bootcmd;run sd_bootcmd;" \ + "env exists secureboot && esbc_halt;" + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(SCSI, scsi, 0) +#include <config_distro_bootcmd.h> + #endif /* __LX2_COMMON_H */ diff --git a/include/configs/lx2160ardb.h b/include/configs/lx2160ardb.h index 67d214d..8c91fea 100644 --- a/include/configs/lx2160ardb.h +++ b/include/configs/lx2160ardb.h @@ -81,21 +81,22 @@
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ - "hwconfig=fsl_ddr:bank_intlv=auto\0" \ - "scriptaddr=0x80800000\0" \ - "kernel_addr_r=0x81000000\0" \ - "pxefile_addr_r=0x81000000\0" \ - "fdt_addr_r=0x88000000\0" \ - "ramdisk_addr_r=0x89000000\0" \ - "loadaddr=0x80100000\0" \ - "kernel_addr=0x100000\0" \ - "ramdisk_addr=0x800000\0" \ - "ramdisk_size=0x2000000\0" \ - "fdt_high=0xa0000000\0" \ - "initrd_high=0xffffffffffffffff\0" \ - "kernel_start=0x21000000\0" \ + EXTRA_ENV_SETTINGS \ "lx2160ardb_vdd_mv=800\0" \ - "mcmemsize=0x40000000\0" + "BOARD=lx2160ardb\0" \ + "xspi_bootcmd=echo Trying load from flexspi..;" \ + "sf probe 0:0 && sf read $load_addr " \ + "$kernel_start $kernel_size ; env exists secureboot &&" \ + "sf read $kernelheader_addr_r $kernelheader_start " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; "\ + " bootm $load_addr#$BOARD\0" \ + "sd_bootcmd=echo Trying load from sd card..;" \ + "mmcinfo; mmc read $load_addr " \ + "$kernel_addr_sd $kernel_size_sd ;" \ + "env exists secureboot && mmc read $kernelheader_addr_r "\ + "$kernelhdr_addr_sd $kernelhdr_size_sd " \ + " && esbc_validate ${kernelheader_addr_r};" \ + "bootm $load_addr#$BOARD\0"
#include <asm/fsl_secure_boot.h>
Priyanka Jain
