[U-Boot] [PATCH 0/1] Fix README for Khadas VIM board
This patch fix the README file to be able to cross-compile U-Boot on Khadas VIM board.
Loic Devulder (1): Fix README for Khadas VIM board
board/amlogic/khadas-vim/README | 32 +++++++++++++++++++++++++------- 1 file changed, 25 insertions(+), 7 deletions(-)
Fix documentation to be able to cross-compile U-Boot on Khadas VIM board.
Signed-off-by: Loic Devulder ldevulder@suse.de --- board/amlogic/khadas-vim/README | 32 +++++++++++++++++++++++++------- 1 file changed, 25 insertions(+), 7 deletions(-)
diff --git a/board/amlogic/khadas-vim/README b/board/amlogic/khadas-vim/README index 7eaca724f8..0f912e9fcd 100644 --- a/board/amlogic/khadas-vim/README +++ b/board/amlogic/khadas-vim/README @@ -20,12 +20,19 @@ Currently the u-boot port supports the following devices: - serial - eMMC, microSD - Ethernet + - USB
U-Boot compilation ==================
+ > mkdir ~/cross-compile + > cd ~/cross-compile + > wget -c https://releases.linaro.org/components/toolchain/binaries/latest/aarch64-elf... + > tar xvfJ gcc-linaro-7.2.1-2017.11-x86_64_aarch64-elf.tar.xz + > export PATH=$PWD/gcc-linaro-7.2.1-2017.11-x86_64_aarch64-elf:$PATH + > cd <u-boot_src_directory>
export ARCH=arm
- > export CROSS_COMPILE=aarch64-none-elf- + > export CROSS_COMPILE=aarch64-elf-
make khadas-vim_defconfig make
@@ -36,20 +43,31 @@ Amlogic doesn't provide sources for the firmware and for tools needed to create the bootloader image, so it is necessary to obtain them from the git tree published by the board vendor:
- > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... - > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... +To be able to compile the *old* U-Boot (if needed): + > Remove the *new* gcc-7.2 from the PATH + > cd ~/cross-compile + > wget -c https://releases.linaro.org/components/toolchain/binaries/4.9-2017.01/aarch6...
tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz
+ > export PATH=$PWD/gcc-linaro-4.9.4-2017.01-x86_64_aarch64-elf/bin:$PATH + +To compile the ATF firmware: + > cd ~/cross-compile + > wget -c https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-...
tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz
- > export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH + > export PATH=$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH + + > cd <where_you_want_to_put_vim-u-boot>
git clone https://github.com/khadas/u-boot -b Vim vim-u-boot cd vim-u-boot
+ > export ARCH=arm + > export CROSS_COMPILE=aarch64-elf-
make kvim_defconfig make
- > export FIPDIR=$PWD/fip
Go back to mainline U-Boot source tree then : + > export FIPDIR=$PWD/fip + > cd <u-boot_src_directory>
mkdir fip
cp $FIPDIR/gxl/bl2.bin fip/ cp $FIPDIR/gxl/acs.bin fip/ cp $FIPDIR/gxl/bl21.bin fip/
@@ -67,7 +85,7 @@ Go back to mainline U-Boot source tree then : fip/bl30_new.bin \ bl30
- > $FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0 + > python $FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0
$FIPDIR/blx_fix.sh \
fip/bl2_acs.bin \
Hi Loic,
- serial
- eMMC, microSD
- Ethernet
- USB
This will collide with my previous patch "boards: amlogic: Fix boards README"
U-Boot compilation
mkdir ~/cross-compile cd ~/cross-compile wget -c https://releases.linaro.org/components/toolchain/binaries/latest/aarch64-elf... tar xvfJ gcc-linaro-7.2.1-2017.11-x86_64_aarch64-elf.tar.xz export PATH=$PWD/gcc-linaro-7.2.1-2017.11-x86_64_aarch64-elf:$PATH cd <u-boot_src_directory> export ARCH=arm
export CROSS_COMPILE=aarch64-elf- make khadas-vim_defconfig make@@ -36,20 +43,31 @@ Amlogic doesn't provide sources for the firmware and for tools needed to create the bootloader image, so it is necessary to obtain them from the git tree published by the board vendor:
wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-...+To be able to compile the *old* U-Boot (if needed):
Remove the *new* gcc-7.2 from the PATH cd ~/cross-compile wget -c https://releases.linaro.org/components/toolchain/binaries/4.9-2017.01/aarch6... tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz export PATH=$PWD/gcc-linaro-4.9.4-2017.01-x86_64_aarch64-elf/bin:$PATH+To compile the ATF firmware:
cd ~/cross-compile wget -c https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz
export PATH=$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH cd <where_you_want_to_put_vim-u-boot> git clone https://github.com/khadas/u-boot -b Vim vim-u-boot cd vim-u-boot export ARCH=arm export CROSS_COMPILE=aarch64-elf- make kvim_defconfig make
export FIPDIR=$PWD/fipGo back to mainline U-Boot source tree then :
export FIPDIR=$PWD/fip cd <u-boot_src_directory> mkdir fip
cp $FIPDIR/gxl/bl2.bin fip/ cp $FIPDIR/gxl/acs.bin fip/ cp $FIPDIR/gxl/bl21.bin fip/@@ -67,7 +85,7 @@ Go back to mainline U-Boot source tree then : fip/bl30_new.bin \ bl30
Apart this line, I don't see the point of all the other changes ? Can you elaborate ?
These instructions are already made to cross-compile U-boot, is there an issue with the instructions ?
fip/bl2_acs.bin \
Neil
Hi Neil,
On 07/10/2018 03:43 PM, Neil Armstrong wrote:
Hi Loic,
- serial
- eMMC, microSD
- Ethernet
- USB
I was not aware of it sorry, so yes this can be removed.
U-Boot compilation
python $FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0Apart this line, I don't see the point of all the other changes ? Can you elaborate ?
I had some issues with the cross compiler, mainly since U-Boot needs or more recent gcc, that's why I added a section/example with gcc v7.
It took me some times to find the correct configuration, that's why I do this changes, for people like me :)
But yes the 'python' part is the most important I think, to avoid failing compilation on some Linux OSes. As for the other changes, if you think that they are not needed no problem, I can remove them.
fip/bl2_acs.bin \
Neil
Loic Devulder
Neil Armstrong
