[PATCH] arm64: versal: Do not define boot command for mini configurations
Mini configuration is not design to boot anything that's why there is no reason to setup boot command. CONFIG_DISTRO_DEFAULTS is disabled anyway.
Signed-off-by: Michal Simek michal.simek@amd.com ---
configs/xilinx_versal_mini_defconfig | 2 -- configs/xilinx_versal_mini_emmc0_defconfig | 2 -- configs/xilinx_versal_mini_emmc1_defconfig | 2 -- 3 files changed, 6 deletions(-)
diff --git a/configs/xilinx_versal_mini_defconfig b/configs/xilinx_versal_mini_defconfig index 53376db9df30..78be2002fb8a 100644 --- a/configs/xilinx_versal_mini_defconfig +++ b/configs/xilinx_versal_mini_defconfig @@ -21,8 +21,6 @@ CONFIG_SYS_MEMTEST_END=0x00001000 CONFIG_REMAKE_ELF=y # CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_AUTOBOOT is not set -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y diff --git a/configs/xilinx_versal_mini_emmc0_defconfig b/configs/xilinx_versal_mini_emmc0_defconfig index 31b3c02f7389..129ddce3ef06 100644 --- a/configs/xilinx_versal_mini_emmc0_defconfig +++ b/configs/xilinx_versal_mini_emmc0_defconfig @@ -17,8 +17,6 @@ CONFIG_SYS_LOAD_ADDR=0x8000000 # CONFIG_EXPERT is not set CONFIG_REMAKE_ELF=y # CONFIG_AUTOBOOT is not set -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y diff --git a/configs/xilinx_versal_mini_emmc1_defconfig b/configs/xilinx_versal_mini_emmc1_defconfig index 5480cf1d9cc4..116ec450bda8 100644 --- a/configs/xilinx_versal_mini_emmc1_defconfig +++ b/configs/xilinx_versal_mini_emmc1_defconfig @@ -17,8 +17,6 @@ CONFIG_SYS_LOAD_ADDR=0x8000000 # CONFIG_EXPERT is not set CONFIG_REMAKE_ELF=y # CONFIG_AUTOBOOT is not set -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y
Applied. M
Michal Simek
