[U-Boot] [PATCH] arm64: versal: Setup DM_ETH/MMC if NET/MMC is enabled
Setup proper ETH/MMC dependency for the whole platform.
arch/arm/Kconfig | 2 ++ configs/xilinx_versal_virt_defconfig | 2 -- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d6b1629a00a6..d69958b5a254 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -886,6 +886,8 @@ config ARCH_VERSAL select ARM64 select CLK select DM + select DM_ETH if NET + select DM_MMC if MMC select DM_SERIAL select OF_CONTROL
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 668c313a2914..e1797db9821b 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -42,7 +42,6 @@ CONFIG_OF_BOARD=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DM_GPIO=y -CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_DM_SPI_FLASH=y @@ -55,7 +54,6 @@ CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHY_FIXED=y -CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y CONFIG_MII=y CONFIG_ZYNQ_GEM=y
Michal Simek
