[U-Boot] [PATCH 0/2] ARM: omapl138: Enable DM and DT support
Enable DM and DT support for omapl138.
Logs: https://pastebin.ubuntu.com/p/9WS4qRXQR6/
Lokesh Vutla (2): ARM: dts: da850-lcdk: Sync from Linux 4.16 configs: omapl138: Enable DM and DT
arch/arm/dts/da850-lcdk-u-boot.dtsi | 13 ++ arch/arm/dts/da850-lcdk.dts | 339 ++++++++++++++++++++++++++++++++++++ arch/arm/dts/da850.dtsi | 15 +- configs/omapl138_lcdk_defconfig | 8 +- include/configs/omapl138_lcdk.h | 13 +- 5 files changed, 380 insertions(+), 8 deletions(-) create mode 100644 arch/arm/dts/da850-lcdk-u-boot.dtsi create mode 100644 arch/arm/dts/da850-lcdk.dts
Sync dts from Linux 4.16 and also add u-boot specific dtsi for OMAPl138 board.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/da850-lcdk-u-boot.dtsi | 13 ++ arch/arm/dts/da850-lcdk.dts | 339 ++++++++++++++++++++++++++++++++++++ arch/arm/dts/da850.dtsi | 15 +- 3 files changed, 363 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/da850-lcdk-u-boot.dtsi create mode 100644 arch/arm/dts/da850-lcdk.dts
diff --git a/arch/arm/dts/da850-lcdk-u-boot.dtsi b/arch/arm/dts/da850-lcdk-u-boot.dtsi new file mode 100644 index 0000000000..c67c3ddbf7 --- /dev/null +++ b/arch/arm/dts/da850-lcdk-u-boot.dtsi @@ -0,0 +1,13 @@ +/* + * da850-lcdk U-Boot Additions + * + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/ { + aliases { + i2c0 = &i2c0; + }; +}; diff --git a/arch/arm/dts/da850-lcdk.dts b/arch/arm/dts/da850-lcdk.dts new file mode 100644 index 0000000000..a1f4d6d5a5 --- /dev/null +++ b/arch/arm/dts/da850-lcdk.dts @@ -0,0 +1,339 @@ +/* + * Copyright (c) 2016 BayLibre, Inc. + * + * Licensed under GPLv2. + */ +/dts-v1/; +#include "da850.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> + +/ { + model = "DA850/AM1808/OMAP-L138 LCDK"; + compatible = "ti,da850-lcdk", "ti,da850"; + + aliases { + serial2 = &serial2; + ethernet0 = ð0; + }; + + chosen { + stdout-path = "serial2:115200n8"; + }; + + memory { + device_type = "memory"; + reg = <0xc0000000 0x08000000>; + }; + + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + dsp_memory_region: dsp-memory@c3000000 { + compatible = "shared-dma-pool"; + reg = <0xc3000000 0x1000000>; + reusable; + status = "okay"; + }; + }; + + sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "DA850/OMAP-L138 LCDK"; + simple-audio-card,widgets = + "Line", "Line In", + "Line", "Line Out"; + simple-audio-card,routing = + "LINE1L", "Line In", + "LINE1R", "Line In", + "Line Out", "LLOUT", + "Line Out", "RLOUT"; + simple-audio-card,format = "dsp_b"; + simple-audio-card,bitclock-master = <&link0_codec>; + simple-audio-card,frame-master = <&link0_codec>; + simple-audio-card,bitclock-inversion; + + simple-audio-card,cpu { + sound-dai = <&mcasp0>; + system-clock-frequency = <24576000>; + }; + + link0_codec: simple-audio-card,codec { + sound-dai = <&tlv320aic3106>; + system-clock-frequency = <24576000>; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + + user1 { + label = "GPIO Key USER1"; + linux,code = <BTN_0>; + gpios = <&gpio 36 GPIO_ACTIVE_LOW>; + }; + + user2 { + label = "GPIO Key USER2"; + linux,code = <BTN_1>; + gpios = <&gpio 37 GPIO_ACTIVE_LOW>; + }; + }; + + vga-bridge { + compatible = "ti,ths8135"; + #address-cells = <1>; + #size-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + vga_bridge_in: endpoint { + remote-endpoint = <&lcdc_out_vga>; + }; + }; + + port@1 { + reg = <1>; + + vga_bridge_out: endpoint { + remote-endpoint = <&vga_con_in>; + }; + }; + }; + }; + + vga { + compatible = "vga-connector"; + + ddc-i2c-bus = <&i2c0>; + + port { + vga_con_in: endpoint { + remote-endpoint = <&vga_bridge_out>; + }; + }; + }; +}; + +&pmx_core { + status = "okay"; + + mcasp0_pins: pinmux_mcasp0_pins { + pinctrl-single,bits = < + /* AHCLKX AFSX ACLKX */ + 0x00 0x00101010 0x00f0f0f0 + /* ARX13 ARX14 */ + 0x04 0x00000110 0x00000ff0 + >; + }; + + nand_pins: nand_pins { + pinctrl-single,bits = < + /* EMA_WAIT[0], EMA_OE, EMA_WE, EMA_CS[3] */ + 0x1c 0x10110010 0xf0ff00f0 + /* + * EMA_D[0], EMA_D[1], EMA_D[2], + * EMA_D[3], EMA_D[4], EMA_D[5], + * EMA_D[6], EMA_D[7] + */ + 0x24 0x11111111 0xffffffff + /* + * EMA_D[8], EMA_D[9], EMA_D[10], + * EMA_D[11], EMA_D[12], EMA_D[13], + * EMA_D[14], EMA_D[15] + */ + 0x20 0x11111111 0xffffffff + /* EMA_A[1], EMA_A[2] */ + 0x30 0x01100000 0x0ff00000 + >; + }; +}; + +&serial2 { + pinctrl-names = "default"; + pinctrl-0 = <&serial2_rxtx_pins>; + status = "okay"; +}; + +&wdt { + status = "okay"; +}; + +&rtc0 { + status = "okay"; +}; + +&gpio { + status = "okay"; +}; + +&sata { + status = "okay"; +}; + +&mdio { + pinctrl-names = "default"; + pinctrl-0 = <&mdio_pins>; + bus_freq = <2200000>; + status = "okay"; +}; + +ð0 { + pinctrl-names = "default"; + pinctrl-0 = <&mii_pins>; + status = "okay"; +}; + +&mmc0 { + max-frequency = <50000000>; + bus-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + cd-gpios = <&gpio 64 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + clock-frequency = <100000>; + status = "okay"; + + tlv320aic3106: tlv320aic3106@18 { + #sound-dai-cells = <0>; + compatible = "ti,tlv320aic3106"; + reg = <0x18>; + status = "okay"; + }; +}; + +&mcasp0 { + #sound-dai-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&mcasp0_pins>; + status = "okay"; + + op-mode = <0>; /* DAVINCI_MCASP_IIS_MODE */ + tdm-slots = <2>; + serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ + 0 0 0 0 + 0 0 0 0 + 0 0 0 0 + 0 1 2 0 + >; + tx-num-evt = <32>; + rx-num-evt = <32>; +}; + +&usb_phy { + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&usb1 { + status = "okay"; +}; + +&aemif { + pinctrl-names = "default"; + pinctrl-0 = <&nand_pins>; + status = "okay"; + cs3 { + #address-cells = <2>; + #size-cells = <1>; + clock-ranges; + ranges; + + ti,cs-chipselect = <3>; + + nand@2000000,0 { + compatible = "ti,davinci-nand"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0 0x02000000 0x02000000 + 1 0x00000000 0x00008000>; + + ti,davinci-chipselect = <1>; + ti,davinci-mask-ale = <0>; + ti,davinci-mask-cle = <0>; + ti,davinci-mask-chipsel = <0>; + + ti,davinci-nand-buswidth = <16>; + ti,davinci-ecc-mode = "hw"; + ti,davinci-ecc-bits = <4>; + ti,davinci-nand-use-bbt; + + /* + * The OMAP-L132/L138 Bootloader doc SPRAB41E reads: + * "To boot from NAND Flash, the AIS should be written + * to NAND block 1 (NAND block 0 is not used by default)". + * The same doc mentions that for ROM "Silicon Revision 2.1", + * "Updated NAND boot mode to offer boot from block 0 or block 1". + * However the limitaion is left here by default for compatibility + * with older silicon and because it needs new boot pin settings + * not possible in stock LCDK. + */ + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "u-boot env"; + reg = <0 0x020000>; + }; + partition@20000 { + /* The LCDK defaults to booting from this partition */ + label = "u-boot"; + reg = <0x020000 0x080000>; + }; + partition@a0000 { + label = "free space"; + reg = <0x0a0000 0>; + }; + }; + }; + }; +}; + +&prictrl { + status = "okay"; +}; + +&memctrl { + status = "okay"; +}; + +&lcdc { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&lcd_pins>; + + port { + lcdc_out_vga: endpoint { + remote-endpoint = <&vga_bridge_in>; + }; + }; +}; + +&vpif { + pinctrl-names = "default"; + pinctrl-0 = <&vpif_capture_pins>; + status = "okay"; +}; + +&dsp { + memory-region = <&dsp_memory_region>; + status = "okay"; +}; diff --git a/arch/arm/dts/da850.dtsi b/arch/arm/dts/da850.dtsi index 02e2f8f258..c66cf78953 100644 --- a/arch/arm/dts/da850.dtsi +++ b/arch/arm/dts/da850.dtsi @@ -23,11 +23,18 @@ reg = <0xfffee000 0x2000>; }; }; - - aliases { - spi0 = &spi0; + dsp: dsp@11800000 { + compatible = "ti,da850-dsp"; + reg = <0x11800000 0x40000>, + <0x11e00000 0x8000>, + <0x11f00000 0x8000>, + <0x01c14044 0x4>, + <0x01c14174 0x8>; + reg-names = "l2sram", "l1pram", "l1dram", "host1cfg", "chipsig"; + interrupt-parent = <&intc>; + interrupts = <28>; + status = "disabled"; }; - soc@1c00000 { compatible = "simple-bus"; model = "da850";
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Enable Driver Model and Device-tree support for omapl138 board in U-Boot. Also enable DM_SERIAL and DM_I2C.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- configs/omapl138_lcdk_defconfig | 8 ++++++-- include/configs/omapl138_lcdk.h | 13 +++++++++++-- 2 files changed, 17 insertions(+), 4 deletions(-)
diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index ccb308bf01..0890b8f901 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -9,11 +9,11 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="da850-lcdk" CONFIG_BOOTDELAY=3 CONFIG_LOGLEVEL=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_BOARD_INIT=y @@ -27,9 +27,13 @@ CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_BOOTP_DNS=y +CONFIG_DM=y +CONFIG_DM_I2C=y +CONFIG_DM_I2C_COMPAT=y CONFIG_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y @@ -38,6 +42,6 @@ CONFIG_SPL_NAND_SIMPLE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_DAVINCI_SPI=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index ea7bdf133d..6ab565ec7d 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -19,6 +19,14 @@ #undef CONFIG_SYS_USE_NOR #define CONFIG_USE_NAND
+/* +* Disable DM_* for SPL build and can be re-enabled after adding +* DM support in SPL +*/ +#ifdef CONFIG_SPL_BUILD +#undef CONFIG_DM_I2C +#undef CONFIG_DM_I2C_COMPAT +#endif /* * SoC Configuration */ @@ -104,12 +112,14 @@ /* * Serial Driver info */ +#define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) +#if !defined(CONFIG_DM_SERIAL) #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE -4 /* NS16550 register size */ #define CONFIG_SYS_NS16550_COM1 DAVINCI_UART2_BASE /* Base address of UART2 */ -#define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) #define CONFIG_CONS_INDEX 1 /* use UART0 for console */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } +#endif
#define CONFIG_SPI #define CONFIG_SYS_SPI_BASE DAVINCI_SPI1_BASE @@ -126,7 +136,6 @@ /* * I2C Configuration */ -#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_DAVINCI #define CONFIG_SYS_DAVINCI_I2C_SPEED 25000 #define CONFIG_SYS_DAVINCI_I2C_SLAVE 10 /* Bogus, master-only in U-Boot */
Lokesh Vutla
