[RFC] dm: core: Report bootph-pre-ram/sram node as pre-reloc after relocation
Devices for nodes with e.g. bootph-pre-ram are initialized three times. 1. At SPL stage (always bind and probe only if used) 2. At U-Boot proper pre-reloc (always bind and probe) 3. At U-Boot proper normal (always bind and probe only if used)
Change ofnode_pre_reloc to report a node with bootph-pre-ram/sram prop with a pre-reloc status only after U-Boot proper pre-relocation stage. This prevents the device from being probed at U-Boot proper pre-reloc.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- I am not sure if U-Boot proper pre-reloc behaves like this by design and if there is some other way to signal that a device should not be probed during U-Boot proper pre-reloc stage if it has been probed at SPL stage.
For my use-case I added bootph-pre-ram prop to my RK8xx device node to make the PMIC usable in SPL. However, I have no need for this device to probe at U-Boot proper pre-reloc stage just after jumping out of TF-A. And moments later bind and probe yet again at U-Boot proper normal stage.
The bootph-pre-ram prop was used to have the device usable in SPL, else I could have used bootph-all or added bootph-some-ram prop to indicate use at U-Boot proper pre-reloc stage.
drivers/core/ofnode.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 8df16e56af5c..ebd5a408ae58 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1353,7 +1353,7 @@ bool ofnode_pre_reloc(ofnode node) */ if (ofnode_read_bool(node, "bootph-pre-ram") || ofnode_read_bool(node, "bootph-pre-sram")) - return true; + return !!(gd->flags & GD_FLG_RELOC);
if (IS_ENABLED(CONFIG_OF_TAG_MIGRATE)) { /* detect and handle old tags */
Hi Jonas,
- At SPL stage (always bind and probe only if used)
- At U-Boot proper pre-reloc (always bind and probe)
- At U-Boot proper normal (always bind and probe only if used)
This is changing how things work...we really need to have something explicit to use this new behaviour. Perhaps we can augment the binding in some way?
return true;
I believe that the compiler knows how to convert 'gd->flags & GD_FLG_RELOC' into a bool, so !! is not needed.
-- 2.41.0
Hi Jonas,
On Tue, 8 Aug 2023 at 20:03, Simon Glass sjg@chromium.org wrote:
Hi Jonas,
I had another look at this. The binding seems to be silent on this point, so I believe this patch is correct.
return true;
-- 2.41.0
Hi Simon,
On 2023-08-17 00:29, Simon Glass wrote:
Hi Jonas,
Hi Jonas,
I agree, the documentation for binding and also for driver model make this a little bit unclear:
""" ... Only drivers marked with DM_FLAG_PRE_RELOC or the device tree ‘bootph-all’ property are initialised prior to relocation. ...
It is possible to limit this to specific relocation steps, by using the more specialized ‘bootph-pre-ram’ and ‘bootph-pre-sram’ flags in the device tree node. For U-Boot proper you can use ‘bootph-some-ram’ which means that it will be processed (and a driver bound) in U-Boot proper prior to relocation, but will not be available in SPL or TPL. """
However the documentation for ofnode_pre_reloc contradict this a little:
""" There are 4 settings currently in use - bootph-some-ram: U-Boot proper pre-relocation only - bootph-all: all phases Existing platforms only use it to indicate nodes needed in SPL. Should probably be replaced by bootph-pre-ram for new platforms. - bootph-pre-ram: SPL and U-Boot pre-relocation - bootph-pre-sram: TPL and U-Boot pre-relocation """
Should I send a v2 of this and drop the "and U-Boot pre-relocation" from function doc comment? And do we need a new Kconfig option to enable or opt-out of this new/changed/fixed behavior?
Regards, Jonas
return true;
-- 2.41.0
Hi Jonas,
On Thu, 17 Aug 2023 at 00:25, Jonas Karlman jonas@kwiboo.se wrote:
Hi Simon,
Hi Jonas,
Hi Jonas,
Yes it needs doc updates but I don't think a new Kconfig option is warranted at this point. We just need to clearly document how these options are used.
Regards, SImon
Jonas Karlman
