[PATCH 0/2] board: hoperun: Fix issues caused by upstream DTS changes
We've seen some issues after switching to using upstream Linux device trees that have stopped the hihope family of platforms from booting correctly.
The first patch corrects the MMC device used to store the U-Boot env. The second patch removes the U-Boot specific DTS changes so that we use the Linux device trees as-is.
Kind regards, Chris
Chris Paterson (1): configs: hihope_rzg2: Set correct MMC device for U-Boot env
Lad Prabhakar (1): board: hoperun: Switch to use complete DTS files from upstream DTS
.../dts/r8a774a1-hihope-rzg2m-ex-u-boot.dtsi | 8 ++++ .../arm/dts/r8a774a1-hihope-rzg2m-u-boot.dtsi | 26 ----------- arch/arm/dts/r8a774a1-u-boot.dtsi | 42 ----------------- .../dts/r8a774b1-hihope-rzg2n-ex-u-boot.dtsi | 8 ++++ .../arm/dts/r8a774b1-hihope-rzg2n-u-boot.dtsi | 26 ----------- arch/arm/dts/r8a774b1-u-boot.dtsi | 40 ---------------- .../dts/r8a774e1-hihope-rzg2h-ex-u-boot.dtsi | 8 ++++ .../arm/dts/r8a774e1-hihope-rzg2h-u-boot.dtsi | 26 ----------- arch/arm/dts/r8a774e1-u-boot.dtsi | 46 ------------------- board/hoperun/hihope-rzg2/hihope-rzg2.c | 6 +-- configs/hihope_rzg2_defconfig | 10 ++-- 11 files changed, 32 insertions(+), 214 deletions(-) create mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m-ex-u-boot.dtsi delete mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dtsi create mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n-ex-u-boot.dtsi delete mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dtsi create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-ex-u-boot.dtsi delete mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dtsi
Currently we set CONFIG_SYS_MMC_ENV_DEV=1 which is wrong: Loading Environment from MMC... MMC: no card present *** Warning - No block device, using default environment
This issue was introduced when we switched to using upstream Linux device trees for the hihope boards which named the MMC devices differently.
Correct to dev 0 so that the U-Boot environment can be loaded from the correct storage device.
Fixes: 18fb23b13158 ("ARM: dts: renesas: Switch to using upstream DT on 64bit Renesas SoCs")
Signed-off-by: Chris Paterson chris.paterson2@renesas.com Signed-off-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- configs/hihope_rzg2_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/hihope_rzg2_defconfig b/configs/hihope_rzg2_defconfig index 6266f3cbc564..f51660300c6b 100644 --- a/configs/hihope_rzg2_defconfig +++ b/configs/hihope_rzg2_defconfig @@ -24,7 +24,7 @@ CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_SYS_MMC_ENV_DEV=0 CONFIG_SYS_MMC_ENV_PART=2 CONFIG_GPIO_HOG=y CONFIG_DM_PCA953X=y
From: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com
For upstream Linux kernel we use below DTBs for HiHope boards: - r8a774a1-hihope-rzg2m-ex.dtb - r8a774e1-hihope-rzg2h-ex.dtb - r8a774b1-hihope-rzg2n-ex.dtb
Update the CONFIG_OF_LIST to match the above. Now that we have switched upstream DTS, drop deleting the nodes and also rename the r8a774*-u-boot.dtsi files to r8a774*-ex-u-boot.dtsi to match the OF_LIST files so that the `bootph-all` property gets applied to required nodes in upstream DTS.
Signed-off-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Signed-off-by: Chris Paterson chris.paterson2@renesas.com --- .../dts/r8a774a1-hihope-rzg2m-ex-u-boot.dtsi | 8 ++++ .../arm/dts/r8a774a1-hihope-rzg2m-u-boot.dtsi | 26 ----------- arch/arm/dts/r8a774a1-u-boot.dtsi | 42 ----------------- .../dts/r8a774b1-hihope-rzg2n-ex-u-boot.dtsi | 8 ++++ .../arm/dts/r8a774b1-hihope-rzg2n-u-boot.dtsi | 26 ----------- arch/arm/dts/r8a774b1-u-boot.dtsi | 40 ---------------- .../dts/r8a774e1-hihope-rzg2h-ex-u-boot.dtsi | 8 ++++ .../arm/dts/r8a774e1-hihope-rzg2h-u-boot.dtsi | 26 ----------- arch/arm/dts/r8a774e1-u-boot.dtsi | 46 ------------------- board/hoperun/hihope-rzg2/hihope-rzg2.c | 6 +-- configs/hihope_rzg2_defconfig | 8 ++-- 11 files changed, 31 insertions(+), 213 deletions(-) create mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m-ex-u-boot.dtsi delete mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dtsi create mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n-ex-u-boot.dtsi delete mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dtsi create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-ex-u-boot.dtsi delete mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dtsi
diff --git a/arch/arm/dts/r8a774a1-hihope-rzg2m-ex-u-boot.dtsi b/arch/arm/dts/r8a774a1-hihope-rzg2m-ex-u-boot.dtsi new file mode 100644 index 000000000000..dd5a208cc1b4 --- /dev/null +++ b/arch/arm/dts/r8a774a1-hihope-rzg2m-ex-u-boot.dtsi @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot for the Hihope RZ/G2M board + * + * Copyright (C) 2021-2024 Renesas Electronics Corporation + */ + +#include "r8a774a1-u-boot.dtsi" diff --git a/arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dtsi b/arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dtsi deleted file mode 100644 index 3ad619bdb90a..000000000000 --- a/arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dtsi +++ /dev/null @@ -1,26 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source extras for U-Boot for the Hihope RZ/G2M board - * - * Copyright (C) 2021 Renesas Electronics Corporation - */ - -#include "r8a774a1-u-boot.dtsi" - -&gpio3 { - bt_reg_on{ - gpio-hog; - gpios = <13 GPIO_ACTIVE_HIGH>; - output-low; - line-name = "bt-reg-on"; - }; -}; - -&gpio4 { - wlan_reg_on{ - gpio-hog; - gpios = <6 GPIO_ACTIVE_HIGH>; - output-low; - line-name = "wlan-reg-on"; - }; -}; diff --git a/arch/arm/dts/r8a774a1-u-boot.dtsi b/arch/arm/dts/r8a774a1-u-boot.dtsi index 38f5bfe85fca..3530eeb27183 100644 --- a/arch/arm/dts/r8a774a1-u-boot.dtsi +++ b/arch/arm/dts/r8a774a1-u-boot.dtsi @@ -10,45 +10,3 @@ &extalr_clk { bootph-all; }; - -/delete-node/ &audma0; -/delete-node/ &audma1; -/delete-node/ &can0; -/delete-node/ &can1; -/delete-node/ &canfd; -/delete-node/ &csi20; -/delete-node/ &csi40; -/delete-node/ &du; -/delete-node/ &fcpf0; -/delete-node/ &fcpvb0; -/delete-node/ &fcpvd0; -/delete-node/ &fcpvd1; -/delete-node/ &fcpvd2; -/delete-node/ &fcpvi0; -/delete-node/ &hdmi0; -/delete-node/ &lvds0; -/delete-node/ &rcar_sound; -/delete-node/ &sound_card; -/delete-node/ &vin0; -/delete-node/ &vin1; -/delete-node/ &vin2; -/delete-node/ &vin3; -/delete-node/ &vin4; -/delete-node/ &vin5; -/delete-node/ &vin6; -/delete-node/ &vin7; -/delete-node/ &vspb; -/delete-node/ &vspd0; -/delete-node/ &vspd1; -/delete-node/ &vspd2; -/delete-node/ &vspi0; - -/ { - /delete-node/ hdmi0-out; -}; - -/ { - soc { - /delete-node/ fdp1@fe940000; - }; -}; diff --git a/arch/arm/dts/r8a774b1-hihope-rzg2n-ex-u-boot.dtsi b/arch/arm/dts/r8a774b1-hihope-rzg2n-ex-u-boot.dtsi new file mode 100644 index 000000000000..b378cabb22c7 --- /dev/null +++ b/arch/arm/dts/r8a774b1-hihope-rzg2n-ex-u-boot.dtsi @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot for the Hihope RZ/G2N board + * + * Copyright (C) 2021-2024 Renesas Electronics Corp. + */ + +#include "r8a774b1-u-boot.dtsi" diff --git a/arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dtsi b/arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dtsi deleted file mode 100644 index 6f2f6c71c2f4..000000000000 --- a/arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dtsi +++ /dev/null @@ -1,26 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source extras for U-Boot for the Hihope RZ/G2N board - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ - -#include "r8a774b1-u-boot.dtsi" - -&gpio3 { - bt_reg_on{ - gpio-hog; - gpios = <13 GPIO_ACTIVE_HIGH>; - output-low; - line-name = "bt-reg-on"; - }; -}; - -&gpio4 { - wlan_reg_on{ - gpio-hog; - gpios = <6 GPIO_ACTIVE_HIGH>; - output-low; - line-name = "wlan-reg-on"; - }; -}; diff --git a/arch/arm/dts/r8a774b1-u-boot.dtsi b/arch/arm/dts/r8a774b1-u-boot.dtsi index d4890ebc298e..07aeabc46b4a 100644 --- a/arch/arm/dts/r8a774b1-u-boot.dtsi +++ b/arch/arm/dts/r8a774b1-u-boot.dtsi @@ -10,43 +10,3 @@ &extalr_clk { bootph-all; }; - -/delete-node/ &audma0; -/delete-node/ &audma1; -/delete-node/ &can0; -/delete-node/ &can1; -/delete-node/ &canfd; -/delete-node/ &csi20; -/delete-node/ &csi40; -/delete-node/ &du; -/delete-node/ &fcpf0; -/delete-node/ &fcpvb0; -/delete-node/ &fcpvd0; -/delete-node/ &fcpvd1; -/delete-node/ &fcpvi0; -/delete-node/ &hdmi0; -/delete-node/ &lvds0; -/delete-node/ &rcar_sound; -/delete-node/ &sound_card; -/delete-node/ &vin0; -/delete-node/ &vin1; -/delete-node/ &vin2; -/delete-node/ &vin3; -/delete-node/ &vin4; -/delete-node/ &vin5; -/delete-node/ &vin6; -/delete-node/ &vin7; -/delete-node/ &vspb; -/delete-node/ &vspd0; -/delete-node/ &vspd1; -/delete-node/ &vspi0; - -/ { - /delete-node/ hdmi0-out; -}; - -/ { - soc { - /delete-node/ fdp1@fe940000; - }; -}; diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h-ex-u-boot.dtsi b/arch/arm/dts/r8a774e1-hihope-rzg2h-ex-u-boot.dtsi new file mode 100644 index 000000000000..560bea46ad7d --- /dev/null +++ b/arch/arm/dts/r8a774e1-hihope-rzg2h-ex-u-boot.dtsi @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot for the Hihope RZ/G2H board + * + * Copyright (C) 2020-2024 Renesas Electronics Corp. + */ + +#include "r8a774e1-u-boot.dtsi" diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dtsi b/arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dtsi deleted file mode 100644 index 8e57e03c899b..000000000000 --- a/arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dtsi +++ /dev/null @@ -1,26 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source extras for U-Boot for the Hihope RZ/G2H board - * - * Copyright (C) 2020 Renesas Electronics Corp. - */ - -#include "r8a774e1-u-boot.dtsi" - -&gpio3 { - bt_reg_on{ - gpio-hog; - gpios = <13 GPIO_ACTIVE_HIGH>; - output-low; - line-name = "bt-reg-on"; - }; -}; - -&gpio4 { - wlan_reg_on{ - gpio-hog; - gpios = <6 GPIO_ACTIVE_HIGH>; - output-low; - line-name = "wlan-reg-on"; - }; -}; diff --git a/arch/arm/dts/r8a774e1-u-boot.dtsi b/arch/arm/dts/r8a774e1-u-boot.dtsi index 45ef5b782409..2202731ccb34 100644 --- a/arch/arm/dts/r8a774e1-u-boot.dtsi +++ b/arch/arm/dts/r8a774e1-u-boot.dtsi @@ -10,49 +10,3 @@ &extalr_clk { bootph-all; }; - -/delete-node/ &audma0; -/delete-node/ &audma1; -/delete-node/ &can0; -/delete-node/ &can1; -/delete-node/ &canfd; -/delete-node/ &csi20; -/delete-node/ &csi40; -/delete-node/ &du; -/delete-node/ &fcpf0; -/delete-node/ &fcpf1; -/delete-node/ &fcpvb0; -/delete-node/ &fcpvb1; -/delete-node/ &fcpvd0; -/delete-node/ &fcpvd1; -/delete-node/ &fcpvi0; -/delete-node/ &fcpvi1; -/delete-node/ &hdmi0; -/delete-node/ &lvds0; -/delete-node/ &rcar_sound; -/delete-node/ &sound_card; -/delete-node/ &vin0; -/delete-node/ &vin1; -/delete-node/ &vin2; -/delete-node/ &vin3; -/delete-node/ &vin4; -/delete-node/ &vin5; -/delete-node/ &vin6; -/delete-node/ &vin7; -/delete-node/ &vspbc; -/delete-node/ &vspbd; -/delete-node/ &vspd0; -/delete-node/ &vspd1; -/delete-node/ &vspi0; -/delete-node/ &vspi1; - -/ { - /delete-node/ hdmi0-out; -}; - -/ { - soc { - /delete-node/ fdp1@fe940000; - /delete-node/ fdp1@fe944000; - }; -}; diff --git a/board/hoperun/hihope-rzg2/hihope-rzg2.c b/board/hoperun/hihope-rzg2/hihope-rzg2.c index 0966e257464a..8b635ef71aca 100644 --- a/board/hoperun/hihope-rzg2/hihope-rzg2.c +++ b/board/hoperun/hihope-rzg2/hihope-rzg2.c @@ -96,15 +96,15 @@ static bool is_hoperun_hihope_rzg2_board(const char *board_name) int board_fit_config_name_match(const char *name) { if (is_hoperun_hihope_rzg2_board("hoperun,hihope-rzg2m") && - !strcmp(name, "r8a774a1-hihope-rzg2m-u-boot")) + !strcmp(name, "r8a774a1-hihope-rzg2m-ex")) return 0;
if (is_hoperun_hihope_rzg2_board("hoperun,hihope-rzg2n") && - !strcmp(name, "r8a774b1-hihope-rzg2n-u-boot")) + !strcmp(name, "r8a774b1-hihope-rzg2n-ex")) return 0;
if (is_hoperun_hihope_rzg2_board("hoperun,hihope-rzg2h") && - !strcmp(name, "r8a774e1-hihope-rzg2h-u-boot")) + !strcmp(name, "r8a774e1-hihope-rzg2h-ex")) return 0;
return -1; diff --git a/configs/hihope_rzg2_defconfig b/configs/hihope_rzg2_defconfig index f51660300c6b..c9753e136577 100644 --- a/configs/hihope_rzg2_defconfig +++ b/configs/hihope_rzg2_defconfig @@ -8,18 +8,18 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_TEXT_BASE=0x50000000 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xFFFE0000 -CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a774a1-hihope-rzg2m" +CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a774a1-hihope-rzg2m-ex" CONFIG_TARGET_HIHOPE_RZG2=y # CONFIG_SPL is not set CONFIG_USE_BOOTARGS=y CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="tftp 0x48080000 Image; tftp 0x48000000 Image-r8a774a1-hihope-rzg2m.dtb; booti 0x48080000 - 0x48000000" -CONFIG_DEFAULT_FDT_FILE="r8a774a1-hihope-rzg2m.dtb" +CONFIG_BOOTCOMMAND="tftp 0x48080000 Image; tftp 0x48000000 Image-r8a774a1-hihope-rzg2m-ex.dtb; booti 0x48080000 - 0x48000000" +CONFIG_DEFAULT_FDT_FILE="r8a774a1-hihope-rzg2m-ex.dtb" # CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_CMD_MMC=y CONFIG_CMD_PART=y CONFIG_CMD_USB=y -CONFIG_OF_LIST="renesas/r8a774a1-hihope-rzg2m renesas/r8a774b1-hihope-rzg2n renesas/r8a774e1-hihope-rzg2h" +CONFIG_OF_LIST="renesas/r8a774a1-hihope-rzg2m-ex renesas/r8a774b1-hihope-rzg2n-ex renesas/r8a774e1-hihope-rzg2h-ex" CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_IS_IN_MMC=y
Chris Paterson
