[PATCH 0/1] arm: provide noncached_set_region prototype to fix build
In OpenWrt project, an issue recently occured after updating u-boot for mediatek to v2024.10. When building with GCC-14 toolchain, it fails with: cmd/cache.c: In function 'do_dcache': cmd/cache.c:57:25: error: implicit declaration of function 'noncached_set_region' [-Wimplicit-function-declaration]
It is presumably caused by commit 7d6cee2cd0 ("cmd: cache: Remove weak functions") which removes the prototypes. Arm architecture provides an implementation for 'noncached_set_region', however it is not available to 'cmd/cache.c'.
The issue was already discussed in https://github.com/openwrt/openwrt/issues/16697 and temporarily fixed downstream in https://github.com/openwrt/openwrt/commit/92ca322dd1f48158b8829fec59319a12e4.... Another user reported the issue in u-boot too, and confirmed the solution working (https://source.denx.de/u-boot/u-boot/-/issues/42).
I'd like to discuss here if this is a proper solution to the issue or if there is a better proposal. Since this is my first contribution, I have barely an overview of the u-boot internals. Please give also hints regarding any wording or explanations in the commit message.
Signed-off-by: Jonas Jelonek jelonek.jonas@gmail.com Cc: Tom Rini trini@konsulko.com
--- Jonas Jelonek (1): arm: provide noncached_set_region prototype to fix build
arch/arm/include/asm/system.h | 1 + cmd/cache.c | 1 + 2 files changed, 2 insertions(+)
Due to the removal of weak functions in 7d6cee2cd0 ("cmd: cache: Remove weak function"), uboot fails to compile after updating to v2024.10 for mediatek target in OpenWrt with GCC-14 with error: cmd/cache.c: In function 'do_dcache': cmd/cache.c:57:25: error: implicit declaration of function 'noncached_set_region' [-Wimplicit-function-declaration]
Thus, provide a prototype in arm's include/asm/system.h to fix a build error in cmd/cache.c, since related prototypes are also located there. Also add an include of asm/system.h in cmd/cache.c to have the function available there.
The issue occured after the update of uboot-mediatek in OpenWrt to v2024.10, in combination with GCC-14 toolchain. It was reported and discussed in https://github.com/openwrt/openwrt/issues/16697, and temporarily fixed with https://github.com/openwrt/openwrt/commit/92ca322dd1f48158b8829fec59319a12e4....
Signed-off-by: Jonas Jelonek jelonek.jonas@gmail.com Cc: Tom Rini trini@konsulko.com --- arch/arm/include/asm/system.h | 1 + cmd/cache.c | 1 + 2 files changed, 2 insertions(+)
diff --git a/arch/arm/include/asm/system.h b/arch/arm/include/asm/system.h index 2237d7d006..0100096202 100644 --- a/arch/arm/include/asm/system.h +++ b/arch/arm/include/asm/system.h @@ -668,6 +668,7 @@ void mmu_set_region_dcache_behaviour(phys_addr_t start, size_t size, * Return: 0 if OK */ int noncached_init(void); +void noncached_set_region(void);
phys_addr_t noncached_alloc(size_t size, size_t align); #endif /* CONFIG_SYS_NONCACHED_MEMORY */ diff --git a/cmd/cache.c b/cmd/cache.c index 3049f5c305..f873f2c8fb 100644 --- a/cmd/cache.c +++ b/cmd/cache.c @@ -10,6 +10,7 @@ #include <command.h> #include <cpu_func.h> #include <linux/compiler.h> +#include <asm/system.h>
static int parse_argv(const char *);
Should be "U-Boot" but I can fix that on applying.
Thanks!
Reviewed-by: Tom Rini trini@konsulko.com Link: https://github.com/openwrt/openwrt/issues/16697 Link: https://github.com/openwrt/openwrt/commit/92ca322dd1f48158b8829fec59319a12e4... Fixes: 7d6cee2cd0 ("cmd: cache: Remove weak function")
Jonas Jelonek
