[U-Boot] WARNING: space prohibited between function name and open parenthesis '('
I'm getting a lot of the following when running checkpatch:
Should I ignore these?
So far, I've written completely new code such that it doesn't trigger this warning, but where editing existing code (e.g. just changing the name of a function), I've avoided fixing this checkpatch warning so it's more obvious what my diff is doing; equally, fixing this would cause the lines I edit to be inconsistent with those around them.
Any guidance appreciated. Thanks.
Dear Stephen Warren,
In message 74CDBE0F657A3D45AFBB94109FB122FF173B23B59F@HQMAIL01.nvidia.com you wrote:
No, these should be fixed.
The normal procedure is to submit a [COSMETIC] patch first that fixes the coding style issues of the affected file (and _only_ these), and then submit a chackpatch-clean patch with the actual changes.
you'll probably hit a bit of this for a while as there is a lot of existing/old code in u-boot which doesn't follow checkpatch :(
hopefully that'll become less frequent over time -mike
Mike Frysinger
Stephen Warren
