[U-Boot] [PULL] rockchip patch-queue 2018-10-05
Tom,
Another set of fixes for u-boot-rockchip is ready for integration. A Travis-CI report is at https://travis-ci.org/ptomsich/u-boot-rockchip/builds/437333443
Thanks, Philipp.
The following changes since commit a1588ac8228881f9fe65539fa8e31f0ee3556864:
Merge tag 'rockchip-for-v2018.11' of git://git.denx.de/u-boot-rockchip (2018-10-03 12:09:19 -0400)
git://git.denx.de/u-boot-rockchip.git tags/rockchip-for-v2018.11-rc2
for you to fetch changes up to f25c1755a715d0d1794bd0827549367c20182501:
rockchip: Fix rkimage format for SPL boot over USB (2018-10-04 22:55:47 +0200)
---------------------------------------------------------------- Rockchip-focused changes for v2018.11-rc2: - fixes to rkimage for SPL boot via USB - fixes to make_fit_atf.py, incl. entry-point calculation and python3 compatibility - OP-TEE support for ARMv7-based SoCs - fixes to RGMII/GMII selection on the RK3328
---------------------------------------------------------------- Andreas Färber (1): rockchip: make_fit_atf.py depends on u-boot
Daniel Gröber (1): rockchip: Fix rkimage format for SPL boot over USB
Janine Hagemann (2): net: gmac_rockchip: Fix a register write in rk3328_gmac_set_to_rgmii net: gmac_rockchip: Add handling for RGMII_ID/RXID/TXID
Kever Yang (3): rockchip: make_fit_atf: fix warning unit_address_vs_reg spl: add support to booting with OP-TEE rockchip: add fit source file for pack itb with op-tee
Mian Yousaf Kaukab (2): rockchip: make_fit_atf: use elf entry point rockchip: make_fit_atf: make python3 compatible
Makefile | 5 ++++- arch/arm/mach-rockchip/fit_spl_optee.its | 50 ++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-rockchip/make_fit_atf.py | 96 +++++++++++++++++++++++++++++++++++++++++++++++++----------------------------------------------- common/spl/Kconfig | 7 +++++++ common/spl/Makefile | 1 + common/spl/spl.c | 7 +++++++ common/spl/spl_optee.S | 12 ++++++++++++ drivers/net/gmac_rockchip.c | 80 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++----------------- include/spl.h | 13 +++++++++++++ tools/rkimage.c | 5 ++--- 10 files changed, 208 insertions(+), 68 deletions(-) create mode 100644 arch/arm/mach-rockchip/fit_spl_optee.its create mode 100644 common/spl/spl_optee.S
On Fri, Oct 05, 2018 at 11:01:38PM +0200, Philipp Tomsich wrote:
Tom,
Thanks, Philipp.
Philipp Tomsich
