[U-Boot] [PATCH] rockchip: make_fit_atf.py depends on u-boot
u-boot.itb depends on u-boot-nodtb.bin, which in turn depends on u-boot. u-boot.its from Rockchip make_fit_atf.py (used by {evb,firefly}-rk3399) wants to read u-boot but is lacking this dependency, so that u-boot.itb cannot be built in one go. Detect its use and add the missing dependency.
Reported-by: Yousaf Kaukab yousaf.kaukab@suse.com Signed-off-by: Andreas Färber afaerber@suse.de --- Makefile | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index f31ee60e4c..3723346c4f 100644 --- a/Makefile +++ b/Makefile @@ -1051,7 +1051,10 @@ U_BOOT_ITS = $(subst ",,$(CONFIG_SPL_FIT_SOURCE)) else ifneq ($(CONFIG_SPL_FIT_GENERATOR),"") U_BOOT_ITS := u-boot.its -$(U_BOOT_ITS): FORCE +ifeq ($(CONFIG_SPL_FIT_GENERATOR),"arch/arm/mach-rockchip/make_fit_atf.py") +U_BOOT_ITS_DEPS += u-boot +endif +$(U_BOOT_ITS): $(U_BOOT_ITS_DEPS) FORCE $(srctree)/$(CONFIG_SPL_FIT_GENERATOR) \ $(patsubst %,arch/$(ARCH)/dts/%.dtb,$(subst ",,$(CONFIG_OF_LIST))) > $@ endif
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip, thanks!
Andreas Färber
Philipp Tomsich
