[PATCH 0/2] microblaze: Fix timer and interrupt code
this series is moving timer to generic drivers/timer/ location and it is removing unused interrupt code in architecture.
note: This patchset is based on rela and cache series.
Thanks, Michal
Michal Simek (2): microblaze: Convert axi timer to DM driver microblaze: Remove interrupt handler
MAINTAINERS | 1 + arch/Kconfig | 6 +- arch/microblaze/cpu/Makefile | 2 +- arch/microblaze/cpu/interrupts.c | 182 +----------------- arch/microblaze/cpu/timer.c | 123 ------------ arch/microblaze/include/asm/microblaze_intc.h | 37 ---- .../microblaze/include/asm/microblaze_timer.h | 26 --- drivers/timer/Kconfig | 8 + drivers/timer/Makefile | 1 + drivers/timer/xilinx-timer.c | 82 ++++++++ 10 files changed, 99 insertions(+), 369 deletions(-) delete mode 100644 arch/microblaze/cpu/timer.c delete mode 100644 arch/microblaze/include/asm/microblaze_intc.h delete mode 100644 arch/microblaze/include/asm/microblaze_timer.h create mode 100644 drivers/timer/xilinx-timer.c
Move axi timer driver from Microblaze to generic location. Origin implementation was irq based with counting down timer.
CONFIG_TIMER drivers are designed differently that timer is free running up timer with automatic reload without any interrupt. Information about clock rates are find out in timer_pre_probe() that's why there is no need to get any additional information from DT in the driver itself (only register offset).
Signed-off-by: Michal Simek michal.simek@amd.com ---
MAINTAINERS | 1 + arch/Kconfig | 5 + arch/microblaze/cpu/Makefile | 2 +- arch/microblaze/cpu/timer.c | 123 ------------------ .../microblaze/include/asm/microblaze_timer.h | 26 ---- drivers/timer/Kconfig | 8 ++ drivers/timer/Makefile | 1 + drivers/timer/xilinx-timer.c | 82 ++++++++++++ 8 files changed, 98 insertions(+), 150 deletions(-) delete mode 100644 arch/microblaze/cpu/timer.c delete mode 100644 arch/microblaze/include/asm/microblaze_timer.h create mode 100644 drivers/timer/xilinx-timer.c
diff --git a/MAINTAINERS b/MAINTAINERS index 28e4d3823861..a18762573d93 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -975,6 +975,7 @@ F: drivers/net/xilinx_emaclite.c F: drivers/serial/serial_xuartlite.c F: drivers/spi/xilinx_spi.c F: drivers/sysreset/sysreset_gpio.c +F: drivers/timer/xilinx-timer.c F: drivers/watchdog/xilinx_tb_wdt.c N: xilinx
diff --git a/arch/Kconfig b/arch/Kconfig index d91475d24747..3d02d8e71afa 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -75,6 +75,11 @@ config MICROBLAZE bool "MicroBlaze architecture" select SUPPORT_OF_CONTROL imply CMD_IRQ + imply CMD_TIMER + imply SPL_REGMAP if SPL + imply SPL_TIMER if SPL + imply TIMER + imply XILINX_TIMER
config MIPS bool "MIPS architecture" diff --git a/arch/microblaze/cpu/Makefile b/arch/microblaze/cpu/Makefile index ea65a0976eec..1c586a7de023 100644 --- a/arch/microblaze/cpu/Makefile +++ b/arch/microblaze/cpu/Makefile @@ -5,7 +5,7 @@
extra-y = start.o obj-y = irq.o -obj-y += interrupts.o cache.o exception.o timer.o cpuinfo.o +obj-y += interrupts.o cache.o exception.o cpuinfo.o obj-$(CONFIG_STATIC_RELA) += relocate.o obj-$(CONFIG_XILINX_MICROBLAZE0_PVR) += pvr.o obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/arch/microblaze/cpu/timer.c b/arch/microblaze/cpu/timer.c deleted file mode 100644 index 647bdcd5ba52..000000000000 --- a/arch/microblaze/cpu/timer.c +++ /dev/null @@ -1,123 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2007 Michal Simek - * - * Michal SIMEK monstr@monstr.eu - */ - -#include <common.h> -#include <fdtdec.h> -#include <init.h> -#include <log.h> -#include <time.h> -#include <asm/global_data.h> -#include <asm/microblaze_timer.h> -#include <asm/microblaze_intc.h> -#include <linux/delay.h> - -DECLARE_GLOBAL_DATA_PTR; - -volatile int timestamp = 0; -microblaze_timer_t *tmr; - -ulong get_timer (ulong base) -{ - if (tmr) - return timestamp - base; - return timestamp++ - base; -} - -void __udelay(unsigned long usec) -{ - u32 i; - - if (tmr) { - i = get_timer(0); - while ((get_timer(0) - i) < (usec / 1000)) - ; - } -} - -#ifndef CONFIG_SPL_BUILD -static void timer_isr(void *arg) -{ - timestamp++; - tmr->control = tmr->control | TIMER_INTERRUPT; -} - -int timer_init (void) -{ - int irq = -1; - u32 preload = 0; - u32 ret = 0; - const void *blob = gd->fdt_blob; - int node = 0; - u32 cell[2]; - - debug("TIMER: Initialization\n"); - - /* Do not init before relocation */ - if (!(gd->flags & GD_FLG_RELOC)) - return 0; - - node = fdt_node_offset_by_compatible(blob, node, - "xlnx,xps-timer-1.00.a"); - if (node != -1) { - fdt_addr_t base = fdtdec_get_addr(blob, node, "reg"); - if (base == FDT_ADDR_T_NONE) - return -1; - - debug("TIMER: Base addr %lx\n", base); - tmr = (microblaze_timer_t *)base; - - ret = fdtdec_get_int_array(blob, node, "interrupts", - cell, ARRAY_SIZE(cell)); - if (ret) - return ret; - - irq = cell[0]; - debug("TIMER: IRQ %x\n", irq); - - preload = fdtdec_get_int(blob, node, "clock-frequency", 0); - preload /= CONFIG_SYS_HZ; - } else { - return node; - } - - if (tmr && preload && irq >= 0) { - tmr->loadreg = preload; - tmr->control = TIMER_INTERRUPT | TIMER_RESET; - tmr->control = TIMER_ENABLE | TIMER_ENABLE_INTR |\ - TIMER_RELOAD | TIMER_DOWN_COUNT; - timestamp = 0; - ret = install_interrupt_handler (irq, timer_isr, (void *)tmr); - if (ret) - tmr = NULL; - } - /* No problem if timer is not found/initialized */ - return 0; -} -#else -int timer_init(void) -{ - return 0; -} -#endif - -/* - * This function is derived from PowerPC code (read timebase as long long). - * On Microblaze it just returns the timer value. - */ -unsigned long long get_ticks(void) -{ - return get_timer(0); -} - -/* - * This function is derived from PowerPC code (timebase clock frequency). - * On Microblaze it returns the number of timer ticks per second. - */ -ulong get_tbclk(void) -{ - return CONFIG_SYS_HZ; -} diff --git a/arch/microblaze/include/asm/microblaze_timer.h b/arch/microblaze/include/asm/microblaze_timer.h deleted file mode 100644 index 2ed1651ffcfa..000000000000 --- a/arch/microblaze/include/asm/microblaze_timer.h +++ /dev/null @@ -1,26 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2007 Michal Simek - * - * Michal SIMEK monstr@monstr.cz - */ - -#define TIMER_ENABLE_ALL 0x400 /* ENALL */ -#define TIMER_PWM 0x200 /* PWMA0 */ -#define TIMER_INTERRUPT 0x100 /* T0INT */ -#define TIMER_ENABLE 0x080 /* ENT0 */ -#define TIMER_ENABLE_INTR 0x040 /* ENIT0 */ -#define TIMER_RESET 0x020 /* LOAD0 */ -#define TIMER_RELOAD 0x010 /* ARHT0 */ -#define TIMER_EXT_CAPTURE 0x008 /* CAPT0 */ -#define TIMER_EXT_COMPARE 0x004 /* GENT0 */ -#define TIMER_DOWN_COUNT 0x002 /* UDT0 */ -#define TIMER_CAPTURE_MODE 0x001 /* MDT0 */ - -typedef volatile struct microblaze_timer_t { - int control; /* control/statuc register TCSR */ - int loadreg; /* load register TLR */ - int counter; /* timer/counter register */ -} microblaze_timer_t; - -int timer_init(void); diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 7b8ab56ed323..44d1a81bad3d 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -272,4 +272,12 @@ config IMX_GPT_TIMER Select this to enable support for the timer found on NXP i.MX devices.
+config XILINX_TIMER + bool "Xilinx timer support" + depends on TIMER + select REGMAP + help + Select this to enable support for the timer found on + any Xilinx boards (axi timer). + endmenu diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index b2f002d59789..4d06375317e1 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -27,3 +27,4 @@ obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o obj-$(CONFIG_MTK_TIMER) += mtk_timer.o obj-$(CONFIG_MCHP_PIT64B_TIMER) += mchp-pit64b-timer.o obj-$(CONFIG_IMX_GPT_TIMER) += imx-gpt-timer.o +obj-$(CONFIG_XILINX_TIMER) += xilinx-timer.o diff --git a/drivers/timer/xilinx-timer.c b/drivers/timer/xilinx-timer.c new file mode 100644 index 000000000000..75b4473b6397 --- /dev/null +++ b/drivers/timer/xilinx-timer.c @@ -0,0 +1,82 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 Advanced Micro Devices, Inc + * Michal Simek michal.simek@amd.com + * + * (C) Copyright 2007 Michal Simek + * Michal SIMEK monstr@monstr.eu + */ + +#include <common.h> +#include <dm.h> +#include <timer.h> +#include <regmap.h> +#include <dm/device_compat.h> + +#define TIMER_ENABLE_ALL 0x400 /* ENALL */ +#define TIMER_PWM 0x200 /* PWMA0 */ +#define TIMER_INTERRUPT 0x100 /* T0INT */ +#define TIMER_ENABLE 0x080 /* ENT0 */ +#define TIMER_ENABLE_INTR 0x040 /* ENIT0 */ +#define TIMER_RESET 0x020 /* LOAD0 */ +#define TIMER_RELOAD 0x010 /* ARHT0 */ +#define TIMER_EXT_CAPTURE 0x008 /* CAPT0 */ +#define TIMER_EXT_COMPARE 0x004 /* GENT0 */ +#define TIMER_DOWN_COUNT 0x002 /* UDT0 */ +#define TIMER_CAPTURE_MODE 0x001 /* MDT0 */ + +#define TIMER_CONTROL_OFFSET 0 +#define TIMER_LOADREG_OFFSET 4 +#define TIMER_COUNTER_OFFSET 8 + +struct xilinx_timer_priv { + struct regmap *regs; +}; + +static u64 xilinx_timer_get_count(struct udevice *dev) +{ + struct xilinx_timer_priv *priv = dev_get_priv(dev); + u32 value; + + regmap_read(priv->regs, TIMER_COUNTER_OFFSET, &value); + + return value; +} + +static int xilinx_timer_probe(struct udevice *dev) +{ + struct xilinx_timer_priv *priv = dev_get_priv(dev); + int ret; + + /* uc_priv->clock_rate has already clock rate */ + ret = regmap_init_mem(dev_ofnode(dev), &priv->regs); + if (ret) { + dev_dbg(dev, "failed to get regbase of timer\n"); + return ret; + } + + regmap_write(priv->regs, TIMER_LOADREG_OFFSET, 0); + regmap_write(priv->regs, TIMER_CONTROL_OFFSET, TIMER_RESET); + regmap_write(priv->regs, TIMER_CONTROL_OFFSET, + TIMER_ENABLE | TIMER_RELOAD); + + return 0; +} + +static const struct timer_ops xilinx_timer_ops = { + .get_count = xilinx_timer_get_count, +}; + +static const struct udevice_id xilinx_timer_ids[] = { + { .compatible = "xlnx,xps-timer-1.00.a" }, + {} +}; + +U_BOOT_DRIVER(xilinx_timer) = { + .name = "xilinx_timer", + .id = UCLASS_TIMER, + .of_match = xilinx_timer_ids, + .priv_auto = sizeof(struct xilinx_timer_priv), + .probe = xilinx_timer_probe, + .ops = &xilinx_timer_ops, +};
Hi Michal,
On 6/8/22 13:38, Michal Simek wrote: [...]
depends on TIMER
select REGMAP
Tested-by: Ovidiu Panait ovidiu.panait@windriver.com
I think the SPL select should also be added:
select SPL_REGMAP if SPL
This will fix the spl link errors with the following config:
CONFIG_TIMER=y
CONFIG_SPL_TIMER=y
CONFIG_XILINX_TIMER=y
microblazeel-linux-ld.bfd: drivers/timer/xilinx-timer.o: in function `xilinx_timer_get_count': drivers/timer/xilinx-timer.c:41: undefined reference to `regmap_read' microblazeel-linux-ld.bfd: drivers/timer/xilinx-timer.o: in function `xilinx_timer_probe': drivers/timer/xilinx-timer.c:52: undefined reference to `regmap_init_mem' microblazeel-linux-ld.bfd: drivers/timer/xilinx-timer.c:58: undefined reference to `regmap_write' microblazeel-linux-ld.bfd: drivers/timer/xilinx-timer.c:59: undefined reference to `regmap_write' microblazeel-linux-ld.bfd: drivers/timer/xilinx-timer.c:60: undefined reference to `regmap_write' make[1]: *** [scripts/Makefile.spl:525: spl/u-boot-spl] Error 1
Thanks,
Ovidiu
help
- endmenu
- (C) Copyright 2022 Advanced Micro Devices, Inc
- Michal Simek michal.simek@amd.com
- (C) Copyright 2007 Michal Simek
- Michal SIMEK monstr@monstr.eu
u32 value;
return value;
int ret;
if (ret) {
return ret;
.id = UCLASS_TIMER,
2.36.1
On 6/23/22 10:37, Ovidiu Panait wrote:
CAUTION: This message has originated from an External Source. Please use proper judgment and caution when opening attachments, clicking links, or responding to this email.
Hi Michal,
No problem with it. Patch sent.
Thanks, Michal
The primary purpose for this code was timer. By converting it to CONFIG_TIMER there is no code which uses this implementation that's why remove it. If there is a need to handle interrupts this patch can be reverted in future.
arch/Kconfig | 1 - arch/microblaze/cpu/interrupts.c | 182 +----------------- arch/microblaze/include/asm/microblaze_intc.h | 37 ---- 3 files changed, 1 insertion(+), 219 deletions(-) delete mode 100644 arch/microblaze/include/asm/microblaze_intc.h
diff --git a/arch/Kconfig b/arch/Kconfig index 3d02d8e71afa..a8d0123b8106 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -74,7 +74,6 @@ config M68K config MICROBLAZE bool "MicroBlaze architecture" select SUPPORT_OF_CONTROL - imply CMD_IRQ imply CMD_TIMER imply SPL_REGMAP if SPL imply SPL_TIMER if SPL diff --git a/arch/microblaze/cpu/interrupts.c b/arch/microblaze/cpu/interrupts.c index fe65f3728fdb..ac53208bda67 100644 --- a/arch/microblaze/cpu/interrupts.c +++ b/arch/microblaze/cpu/interrupts.c @@ -8,17 +8,8 @@ */
#include <common.h> -#include <command.h> -#include <fdtdec.h> -#include <irq_func.h> -#include <log.h> -#include <malloc.h> -#include <asm/global_data.h> -#include <asm/microblaze_intc.h> #include <asm/asm.h>
-DECLARE_GLOBAL_DATA_PTR; - void enable_interrupts(void) { debug("Enable interrupts for the whole CPU\n"); @@ -34,183 +25,12 @@ int disable_interrupts(void) return (msr & 0x2) != 0; }
-static struct irq_action *vecs; -static u32 irq_no; - -/* mapping structure to interrupt controller */ -microblaze_intc_t *intc; - -/* default handler */ -static void def_hdlr(void) -{ - puts("def_hdlr\n"); -} - -static void enable_one_interrupt(int irq) -{ - int mask; - int offset = 1; - - offset <<= irq; - mask = intc->ier; - intc->ier = (mask | offset); - - debug("Enable one interrupt irq %x - mask %x,ier %x\n", offset, mask, - intc->ier); - debug("INTC isr %x, ier %x, iar %x, mer %x\n", intc->isr, intc->ier, - intc->iar, intc->mer); -} - -static void disable_one_interrupt(int irq) -{ - int mask; - int offset = 1; - - offset <<= irq; - mask = intc->ier; - intc->ier = (mask & ~offset); - - debug("Disable one interrupt irq %x - mask %x,ier %x\n", irq, mask, - intc->ier); - debug("INTC isr %x, ier %x, iar %x, mer %x\n", intc->isr, intc->ier, - intc->iar, intc->mer); -} - -int install_interrupt_handler(int irq, interrupt_handler_t *hdlr, void *arg) -{ - struct irq_action *act; - - /* irq out of range */ - if ((irq < 0) || (irq > irq_no)) { - puts("IRQ out of range\n"); - return -1; - } - act = &vecs[irq]; - if (hdlr) { /* enable */ - act->handler = hdlr; - act->arg = arg; - act->count = 0; - enable_one_interrupt(irq); - return 0; - } - - /* Disable */ - act->handler = (interrupt_handler_t *)def_hdlr; - act->arg = (void *)irq; - disable_one_interrupt(irq); - return 1; -} - -/* initialization interrupt controller - hardware */ -static void intc_init(void) -{ - intc->mer = 0; - intc->ier = 0; - intc->iar = 0xFFFFFFFF; - /* XIntc_Start - hw_interrupt enable and all interrupt enable */ - intc->mer = 0x3; - - debug("INTC isr %x, ier %x, iar %x, mer %x\n", intc->isr, intc->ier, - intc->iar, intc->mer); -} - int interrupt_init(void) { - int i; - const void *blob = gd->fdt_blob; - int node = 0; - - debug("INTC: Initialization\n"); - - node = fdt_node_offset_by_compatible(blob, node, - "xlnx,xps-intc-1.00.a"); - if (node != -1) { - fdt_addr_t base = fdtdec_get_addr(blob, node, "reg"); - if (base == FDT_ADDR_T_NONE) - return -1; - - debug("INTC: Base addr %lx\n", base); - intc = (microblaze_intc_t *)base; - irq_no = fdtdec_get_int(blob, node, "xlnx,num-intr-inputs", 0); - debug("INTC: IRQ NO %x\n", irq_no); - } else { - return node; - } - - if (irq_no) { - vecs = calloc(1, sizeof(struct irq_action) * irq_no); - if (vecs == NULL) { - puts("Interrupt vector allocation failed\n"); - return -1; - } - - /* initialize irq list */ - for (i = 0; i < irq_no; i++) { - vecs[i].handler = (interrupt_handler_t *)def_hdlr; - vecs[i].arg = (void *)i; - vecs[i].count = 0; - } - /* initialize intc controller */ - intc_init(); - enable_interrupts(); - } else { - puts("Undefined interrupt controller\n"); - } return 0; }
void interrupt_handler(void) { - int irqs = intc->ivr; /* find active interrupt */ - int mask = 1; - int value; - struct irq_action *act = vecs + irqs; - - debug("INTC isr %x, ier %x, iar %x, mer %x\n", intc->isr, intc->ier, - intc->iar, intc->mer); -#ifdef DEBUG - R14(value); -#endif - debug("Interrupt handler on %x line, r14 %x\n", irqs, value); - - debug("Jumping to interrupt handler rutine addr %x,count %x,arg %x\n", - (u32)act->handler, act->count, (u32)act->arg); - act->handler(act->arg); - act->count++; - - intc->iar = mask << irqs; - - debug("Dump INTC reg, isr %x, ier %x, iar %x, mer %x\n", intc->isr, - intc->ier, intc->iar, intc->mer); -#ifdef DEBUG - R14(value); -#endif - debug("Interrupt handler on %x line, r14 %x\n", irqs, value); -} - -#if defined(CONFIG_CMD_IRQ) -int do_irqinfo(struct cmd_tbl *cmdtp, int flag, int argc, const char *argv[]) -{ - int i; - struct irq_action *act = vecs; - - if (irq_no) { - puts("\nInterrupt-Information:\n\n" - "Nr Routine Arg Count\n" - "-----------------------------\n"); - - for (i = 0; i < irq_no; i++) { - if (act->handler != (interrupt_handler_t *)def_hdlr) { - printf("%02d %08x %08x %d\n", i, - (int)act->handler, (int)act->arg, - act->count); - } - act++; - } - puts("\n"); - } else { - puts("Undefined interrupt controller\n"); - } - return 0; + panic("Interrupt occurred\n"); } -#endif diff --git a/arch/microblaze/include/asm/microblaze_intc.h b/arch/microblaze/include/asm/microblaze_intc.h deleted file mode 100644 index a7e8715851ea..000000000000 --- a/arch/microblaze/include/asm/microblaze_intc.h +++ /dev/null @@ -1,37 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2007 Michal Simek - * - * Michal SIMEK monstr@monstr.cz - */ - -#include <irq_func.h> - -typedef volatile struct microblaze_intc_t { - int isr; /* interrupt status register */ - int ipr; /* interrupt pending register */ - int ier; /* interrupt enable register */ - int iar; /* interrupt acknowledge register */ - int sie; /* set interrupt enable bits */ - int cie; /* clear interrupt enable bits */ - int ivr; /* interrupt vector register */ - int mer; /* master enable register */ -} microblaze_intc_t; - -struct irq_action { - interrupt_handler_t *handler; /* pointer to interrupt rutine */ - void *arg; - int count; /* number of interrupt */ -}; - -/** - * Register and unregister interrupt handler rutines - * - * @param irq IRQ number - * @param hdlr Interrupt handler rutine - * @param arg Pointer to argument which is passed to int. handler rutine - * Return: 0 if registration pass, 1 if unregistration pass, - * or an error code < 0 otherwise - */ -int install_interrupt_handler(int irq, interrupt_handler_t *hdlr, - void *arg);
st 8. 6. 2022 v 12:39 odesílatel Michal Simek monstr@monstr.eu napsal:
Thanks, Michal
-- 2.36.1
Applied. M
Michal Simek
Michal Simek
Ovidiu Panait
