[U-Boot] Pull request - mpc85xx
The following changes since commit 6ca9da4d42aeb43df5ef29f7d0518009df583b2f: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-ppc4xx
git://git.denx.de/u-boot-mpc85xx master
Anton Vorontsov (1): mpc85xx: Add 4-bits eSDHC support for MPC8569E-MDS boards
Becky Bruce (1): ppc/p4080: Add Corenet Platform Cache (CPC) registers
Dave Liu (5): p4080: add readback to bootpage translation window fsl-ddr: Fix power-down timing settings fsl-ddr: add the override for write leveling fsl-ddr: add override for the Rtt_Wr fsl-ddr: setup ODT_RD_CFG & ODT_WR_CFG when we interleave
Kumar Gala (23): 85xx: Add support for e500mc cache stashing ppc/p4080: Added p4080 SERDES registers & USB offset ppc/8xxx: Don't use pci_cfg on FSL_CORENET platforms 85xx: Add support to set DPAA (data path) devices clock frequencies NET: Base support for etsec2.0 ppc/85xx: Clean up MPC8544 DS PCI setup code ppc/85xx: Clean up MPC8569 MDS PCI setup code ppc/85xx: Clean up MPC8568 MDS PCI setup code ppc/85xx: Clean up ATUM8548 PCI setup code ppc/85xx: Clean up MPC8548 CDS PCI setup code ppc/86xx: Clean up MPC8610 HPCD PCI setup code ppc/85xx: Move to using fsl_setup_hose on MPC8572 DS ppc/85xx: Move to using fsl_setup_hose on P1/P2 RDB ppc/85xx: Move to using fsl_setup_hose on P2020 DS ppc/85xx: Move to using fsl_setup_hose on TQM 85xx ppc/8xxx: Remove is_fsl_pci_agent ppc/85xx: Add tracking of TLB CAM usage ppc/85xx: Make SPD DDR TLB setup code use dynamic entry allocation ppc/85xx: Remove CONFIG_SYS_DDR_TLB_START ppc/85xx: Make flash TLB entry determined at runtime on FSL boards ppc: Added macro to test for specific SVR revision ppc/85xx: Map boot page guarded for MP boot ppc/p4080: Fix reporting of PME & FM clock frequencies
Li Yang (1): fsl_law: add SRIO2 target id and law_size_bits() macro
Mingkai Hu (1): ppc/85xx: Clean up MPC8536 DS PCI setup code
Sandeep Gopalpet (1): NET: Move MDIO regs out of TSEC Space
board/atum8548/atum8548.c | 162 ++++++------------- board/freescale/mpc8536ds/mpc8536ds.c | 259 ++++++++--------------------- board/freescale/mpc8544ds/mpc8544ds.c | 249 ++++++++-------------------- board/freescale/mpc8548cds/mpc8548cds.c | 141 ++++++---------- board/freescale/mpc8568mds/mpc8568mds.c | 137 +++++---------- board/freescale/mpc8569mds/mpc8569mds.c | 100 +++++------- board/freescale/mpc8572ds/mpc8572ds.c | 16 +- board/freescale/mpc8572ds/tlb.c | 2 +- board/freescale/mpc8610hpcd/mpc8610hpcd.c | 199 +++++++--------------- board/freescale/p1_p2_rdb/p1_p2_rdb.c | 2 +- board/freescale/p1_p2_rdb/pci.c | 10 +- board/freescale/p1_p2_rdb/tlb.c | 2 +- board/freescale/p2020ds/p2020ds.c | 14 +- board/freescale/p2020ds/tlb.c | 2 +- board/tqc/tqm85xx/tqm85xx.c | 8 +- cpu/mpc85xx/cpu_init.c | 6 + cpu/mpc85xx/fdt.c | 54 ++++++ cpu/mpc85xx/mp.c | 5 +- cpu/mpc85xx/release.S | 17 ++- cpu/mpc85xx/speed.c | 12 +- cpu/mpc85xx/start.S | 8 +- cpu/mpc85xx/tlb.c | 76 ++++++++- cpu/mpc8xxx/ddr/ctrl_regs.c | 40 +++-- cpu/mpc8xxx/ddr/options.c | 1 + cpu/mpc8xxx/pci_cfg.c | 47 +----- drivers/net/tsec.c | 21 +-- drivers/pci/fsl_pci_init.c | 9 + include/asm-ppc/config.h | 13 ++ include/asm-ppc/fsl_ddr_sdram.h | 8 +- include/asm-ppc/fsl_law.h | 3 + include/asm-ppc/fsl_pci.h | 5 +- include/asm-ppc/global_data.h | 3 + include/asm-ppc/immap_83xx.h | 8 +- include/asm-ppc/immap_85xx.h | 171 +++++++++++++++++++ include/asm-ppc/immap_86xx.h | 8 +- include/asm-ppc/mmu.h | 2 + include/asm-ppc/processor.h | 3 + include/configs/ATUM8548.h | 18 +- include/configs/MPC8569MDS.h | 4 + include/configs/MPC8572DS.h | 1 - include/configs/P1_P2_RDB.h | 2 - include/configs/P2020DS.h | 1 - include/tsec.h | 52 ++++--- 43 files changed, 885 insertions(+), 1016 deletions(-)
Has updated commit message for 'fsl-ddr: add override for the Rtt_Wr' and fixed CPC immap #define issue.
- k
Dear Kumar Gala,
In message Pine.LNX.4.64.1001051356180.29574@localhost.localdomain you wrote:
Applied, thanks.
Kumar Gala
