[PATCH v7 0/2] Add support to fetch baudrate from dtb
In this patch series - Add support in Kconfig and convert for armada boards - Fetch baudrate from the dtb and update
Changes in v7: - Updated the commit message.
Changes in v6: - Changed Kconfig OF_SERIAL_DT_BAUD to OF_SERIAL_BAUD. - Added IS_ENABLED() in place of #ifdef CONFIG_OF_SERIAL_AUD
Changes in v5: - Adding DEFAULT_ENV_IS_RW Kconfig in missing files - Updating DEFAULT_ENV_IS_RW to CONFIG_DEFAULT_ENV_IS_RW
Changes in v4: - Moved SERIAL_DT_BAUD to another patch - Added doc file for fetching serial baudrate from DT. - Changed Kconfig SERIAL_DT_BAUD to OF_SERIAL_DT_BAUD - Added function docs wherever required. - Moved changes from fdtdec api to ofnode - Changed serial_get_valid_baudrate to check_valid_baudrate - Added function fetch_baud_from_dtb to fetch baud from DT - Used dectoul() for parsing baudrate
Changes in v3: - Add SERIAL_DT_BAUD to Kconfig - Moved DEFAULT_ENV_IS_RW to Kconfig also updated armada files - Moved filler changes from zynqmp.h to generic file env_default.h - Removed ENV_RW_FILLER and added padding in the generic file env_default.h. - Print baudrate parameter properly when SERIAL_DT is enabled.
Changes in v2: - Changed to #ifdef from #if CONFIG_IS_ENABLED to enable patching in spl. - Added SPL_ENV_SUPPORT dependency in SERIAL_DT_BAUD to allow SPL compilation. - Moved DEFAULT_ENV_IS_RW to Kconfig also updated armada files - Moved ENV_RW_FILLER to generic file env_default.h. - Increased the ENV_RW_FILLER padding to support 8000000 baud.
Algapally Santosh Sagar (2): configs: Add support in Kconfig and convert for armada boards serial: zynqmp: Fetch baudrate from dtb and update
configs/eDPU_defconfig | 1 + configs/mvebu_db-88f3720_defconfig | 1 + configs/mvebu_espressobin-88f3720_defconfig | 1 + configs/uDPU_defconfig | 1 + doc/README.serial_dt_baud | 41 ++++++++++++++++++++ drivers/core/ofnode.c | 18 +++++++++ drivers/serial/Kconfig | 15 +++++++ drivers/serial/serial-uclass.c | 43 +++++++++++++++++++++ include/configs/mvebu_armada-37xx.h | 1 - include/dm/ofnode.h | 14 ++++++- include/env_default.h | 8 +++- include/env_internal.h | 2 +- include/serial.h | 15 +++++++ 13 files changed, 155 insertions(+), 6 deletions(-) create mode 100644 doc/README.serial_dt_baud
From: Algapally Santosh Sagar santoshsagar.algapally@amd.com
Move the DEFAULT_ENV_IS_RW to Kconfig for easier configuration. Hence, add the CONFIG_DEFAULT_ENV_IS_RW config to the defconfig files to allow enabling them for armada boards.
Signed-off-by: Algapally Santosh Sagar santoshsagar.algapally@amd.com Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Reviewed-by: Simon Glass sjg@chromium.org --- configs/eDPU_defconfig | 1 + configs/mvebu_db-88f3720_defconfig | 1 + configs/mvebu_espressobin-88f3720_defconfig | 1 + configs/uDPU_defconfig | 1 + drivers/serial/Kconfig | 6 ++++++ include/configs/mvebu_armada-37xx.h | 1 - include/env_default.h | 2 +- include/env_internal.h | 2 +- 8 files changed, 12 insertions(+), 3 deletions(-)
diff --git a/configs/eDPU_defconfig b/configs/eDPU_defconfig index 77ea2b2eec..61fb9bd2a5 100644 --- a/configs/eDPU_defconfig +++ b/configs/eDPU_defconfig @@ -21,6 +21,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DEFAULT_ENV_IS_RW=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index 829567014f..e6fb80167a 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -22,6 +22,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DEFAULT_ENV_IS_RW=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index fc394a7e9d..64ee99d64b 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -24,6 +24,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DEFAULT_ENV_IS_RW=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y diff --git a/configs/uDPU_defconfig b/configs/uDPU_defconfig index fa1989518b..4d3d53ac7e 100644 --- a/configs/uDPU_defconfig +++ b/configs/uDPU_defconfig @@ -21,6 +21,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DEFAULT_ENV_IS_RW=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_MAXARGS=32 diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 8c54bc9c47..4d27034c3f 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -24,6 +24,12 @@ config BAUDRATE in the SPL stage (most drivers) or for choosing a default baudrate in the absence of an environment setting (serial_mxc.c).
+config DEFAULT_ENV_IS_RW + bool "Make default environment as writable" + help + Select this to enable to make default environment writable. This + allows modifying the default environment. + config REQUIRE_SERIAL_CONSOLE bool "Require a serial port for console" # Running without a serial console is not supported by the diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index 76e148f55e..18b55be0d8 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -30,7 +30,6 @@ /* * Environment */ -#define DEFAULT_ENV_IS_RW /* required for configuring default fdtfile= */
#ifdef CONFIG_MMC #define BOOT_TARGET_DEVICES_MMC(func, i) func(MMC, mmc, i) diff --git a/include/env_default.h b/include/env_default.h index b16c22d5a2..227cad7c34 100644 --- a/include/env_default.h +++ b/include/env_default.h @@ -21,7 +21,7 @@ env_t embedded_environment __UBOOT_ENV_SECTION__(environment) = { { #elif defined(DEFAULT_ENV_INSTANCE_STATIC) static char default_environment[] = { -#elif defined(DEFAULT_ENV_IS_RW) +#elif defined(CONFIG_DEFAULT_ENV_IS_RW) char default_environment[] = { #else const char default_environment[] = { diff --git a/include/env_internal.h b/include/env_internal.h index 6a69494646..fcb464263f 100644 --- a/include/env_internal.h +++ b/include/env_internal.h @@ -89,7 +89,7 @@ typedef struct environment_s { extern env_t embedded_environment; #endif /* ENV_IS_EMBEDDED */
-#ifdef DEFAULT_ENV_IS_RW +#ifdef CONFIG_DEFAULT_ENV_IS_RW extern char default_environment[]; #else extern const char default_environment[];
The baudrate configured in .config is taken by default by serial. If change of baudrate is required then the .config needs to changed and u-boot recompilation is required or the u-boot environment needs to be updated.
To avoid this, support is added to fetch the baudrate directly from the device tree file and update. The serial, prints the log with the configured baudrate in the dtb. The commit c4df0f6f315c ("arm: mvebu: Espressobin: Set default value for $fdtfile env variable") is taken as reference for changing the default environment variable.
The default environment stores the default baudrate value, When default baudrate and dtb baudrate are not same glitches are seen on the serial. So, the environment also needs to be updated with the dtb baudrate to avoid the glitches on the serial.
Signed-off-by: Algapally Santosh Sagar santoshsagar.algapally@amd.com Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- doc/README.serial_dt_baud | 41 ++++++++++++++++++++++++++++++++ drivers/core/ofnode.c | 18 ++++++++++++++ drivers/serial/Kconfig | 9 +++++++ drivers/serial/serial-uclass.c | 43 ++++++++++++++++++++++++++++++++++ include/dm/ofnode.h | 14 +++++++++-- include/env_default.h | 6 ++++- include/serial.h | 15 ++++++++++++ 7 files changed, 143 insertions(+), 3 deletions(-) create mode 100644 doc/README.serial_dt_baud
diff --git a/doc/README.serial_dt_baud b/doc/README.serial_dt_baud new file mode 100644 index 0000000000..f8768d0e1b --- /dev/null +++ b/doc/README.serial_dt_baud @@ -0,0 +1,41 @@ +Fetch serial baudrate from DT +----------------------------- + +To support fetching of baudrate from DT, the following is done:- + +The baudrate configured in Kconfig symbol CONFIG_BAUDRATE is taken by default by serial. +If change of baudrate is required then the Kconfig symbol CONFIG_BAUDRATE needs to +changed and U-Boot recompilation is required or the U-Boot environment needs to be updated. + +To avoid this, add support to fetch the baudrate directly from the device tree file and +update the environment. + +The default environment stores the default baudrate value. When default baudrate and dtb +baudrate are not same glitches are seen on the serial. +So, the environment also needs to be updated with the dtb baudrate to avoid the glitches on +the serial which is enabled by OF_SERIAL_BAUD. + +The Kconfig SPL_ENV_SUPPORT needs to be enabled to allow patching in SPL. + +The Kconfig DEFAULT_ENV_IS_RW which is enabled by OF_SERIAL_BAUD with making the environment +writable. + +The ofnode_read_baud() function parses and fetches the baudrate value from the DT. This value +is validated and updated to baudrate during serial init. Padding is added at the end of the +default environment and the dt baudrate is updated with the latest value. + +Example:- + +The serial port options are of the form "bbbbpnf", where "bbbb" is the baud rate, "p" is parity ("n", "o", or "e"), +"n" is number of bits, and "f" is flow control ("r" for RTS or omit it). Default is "115200n8". + +chosen { + bootargs = "earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/ram0 rw init_fatal_sh=1"; + stdout-path = "serial0:115200n8"; + }; + +From the chosen node, stdout-path property is obtained as string. + + stdout-path = "serial0:115200n8"; + +The string is parsed to get the baudrate 115200. This string is converted to integer and updated to the environment. diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 8df16e56af..42f51ca93c 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -895,6 +895,24 @@ ofnode ofnode_get_chosen_node(const char *name) return ofnode_path(prop); }
+int ofnode_read_baud(void) +{ + const char *str, *p; + u32 baud; + + str = ofnode_read_chosen_string("stdout-path"); + if (!str) + return -EINVAL; + + /* Parse string serial0:115200n8 */ + p = strchr(str, ':'); + if (!p) + return -EINVAL; + + baud = dectoul(p + 1, NULL); + return baud; +} + const void *ofnode_read_aliases_prop(const char *propname, int *sizep) { ofnode node; diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 4d27034c3f..7fdf600dc5 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -24,6 +24,15 @@ config BAUDRATE in the SPL stage (most drivers) or for choosing a default baudrate in the absence of an environment setting (serial_mxc.c).
+config OF_SERIAL_BAUD + bool "Fetch serial baudrate from device tree" + depends on DM_SERIAL && SPL_ENV_SUPPORT + select DEFAULT_ENV_IS_RW + help + Select this to enable fetching and setting of the baudrate + configured in the DT. Replace the default baudrate with the DT + baudrate and also set it to the environment. + config DEFAULT_ENV_IS_RW bool "Make default environment as writable" help diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index 067fae2614..e5304b397d 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -154,12 +154,55 @@ static void serial_find_console_or_panic(void) } #endif /* CONFIG_SERIAL_PRESENT */
+int check_valid_baudrate(int baud) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(baudrate_table); ++i) { + if (baud == baudrate_table[i]) + return 0; + } + + return -EINVAL; +} + +int fetch_baud_from_dtb(void) +{ + int baud_value, ret; + + baud_value = ofnode_read_baud(); + ret = check_valid_baudrate(baud_value); + if (ret) + return ret; + + return baud_value; +} + /* Called prior to relocation */ int serial_init(void) { #if CONFIG_IS_ENABLED(SERIAL_PRESENT) serial_find_console_or_panic(); gd->flags |= GD_FLG_SERIAL_READY; + + if (IS_ENABLED(CONFIG_OF_SERIAL_BAUD)) { + int ret = 0; + char *ptr = &default_environment[0]; + + /* + * Fetch the baudrate from the dtb and update the value in the + * default environment. + */ + ret = fetch_baud_from_dtb(); + if (ret != -EINVAL && ret != -EFAULT) { + gd->baudrate = ret; + + while (*ptr != '\0' && *(ptr + 1) != '\0') + ptr++; + ptr += 2; + sprintf(ptr, "baudrate=%d", gd->baudrate); + } + } serial_setbrg(); #endif
diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 0f38b3e736..f0854cc28d 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -942,12 +942,22 @@ const char *ofnode_read_chosen_string(const char *propname); ofnode ofnode_get_chosen_node(const char *propname);
/** - * ofnode_read_aliases_prop() - get the value of a aliases property + * ofnode_read_baud() - get the baudrate from string value of chosen property * - * This looks for a property within the /aliases node and returns its value + * This looks for stdout-path property within the /chosen node and parses its + * value to return baudrate. * * This only works with the control FDT. * + * Return: baudrate value if found, else -ve error code + */ +int ofnode_read_baud(void); + +/** + * ofnode_read_aliases_prop() - get the value of a aliases property + * + * This looks for a property within the /aliases node and returns its value + * * @propname: Property name to look for * @sizep: Returns size of property, or `FDT_ERR_...` error code if function * returns NULL diff --git a/include/env_default.h b/include/env_default.h index 227cad7c34..2ca4a087d3 100644 --- a/include/env_default.h +++ b/include/env_default.h @@ -42,7 +42,7 @@ const char default_environment[] = { #if defined(CONFIG_BOOTDELAY) "bootdelay=" __stringify(CONFIG_BOOTDELAY) "\0" #endif -#if defined(CONFIG_BAUDRATE) && (CONFIG_BAUDRATE >= 0) +#if !defined(CONFIG_OF_SERIAL_BAUD) && defined(CONFIG_BAUDRATE) && (CONFIG_BAUDRATE >= 0) "baudrate=" __stringify(CONFIG_BAUDRATE) "\0" #endif #ifdef CONFIG_LOADS_ECHO @@ -118,6 +118,10 @@ const char default_environment[] = { #endif #ifdef CFG_EXTRA_ENV_SETTINGS CFG_EXTRA_ENV_SETTINGS +#endif +#ifdef CONFIG_OF_SERIAL_BAUD + /* Padding for baudrate at the end when environment is writable */ + "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0" #endif "\0" #else /* CONFIG_USE_DEFAULT_ENV_FILE */ diff --git a/include/serial.h b/include/serial.h index 42bdf3759c..31a97ca9cf 100644 --- a/include/serial.h +++ b/include/serial.h @@ -337,6 +337,21 @@ int serial_setconfig(struct udevice *dev, uint config); */ int serial_getinfo(struct udevice *dev, struct serial_device_info *info);
+/** + * check_valid_baudrate() - Check whether baudrate is valid or not + * + * @baud: baud rate to check + * Return: 0 if OK, -ve on error + */ +int check_valid_baudrate(int baud); + +/** + * fetch_baud_from_dtb() - Fetch the baudrate value from DT + * + * Return: baudrate if OK, -ve on error + */ +int fetch_baud_from_dtb(void); + void atmel_serial_initialize(void); void mcf_serial_initialize(void); void mpc85xx_serial_initialize(void);
+Example:-
+chosen {
- stdout-path = "serial0:115200n8";
I expect Simon will want to have test to cover this too.
- const char *str, *p;
- u32 baud;
- str = ofnode_read_chosen_string("stdout-path");
- if (!str)
return -EINVAL;
- /* Parse string serial0:115200n8 */
- p = strchr(str, ':');
- if (!p)
return -EINVAL;
- baud = dectoul(p + 1, NULL);
- return baud;
- const void *ofnode_read_aliases_prop(const char *propname, int *sizep) { ofnode node;
- bool "Fetch serial baudrate from device tree"
- depends on DM_SERIAL && SPL_ENV_SUPPORT
- select DEFAULT_ENV_IS_RW
- help
- config DEFAULT_ENV_IS_RW bool "Make default environment as writable" help
make this static is called only once in this file.
- int i;
- for (i = 0; i < ARRAY_SIZE(baudrate_table); ++i) {
- return -EINVAL;
Maybe enough to test this function which also cover ofnode_read_baud too.
- int baud_value, ret;
- baud_value = ofnode_read_baud();
- ret = check_valid_baudrate(baud_value);
- if (ret)
return ret;
- return baud_value;
- /* Called prior to relocation */ int serial_init(void) { #if CONFIG_IS_ENABLED(SERIAL_PRESENT) serial_find_console_or_panic(); gd->flags |= GD_FLG_SERIAL_READY;
- if (IS_ENABLED(CONFIG_OF_SERIAL_BAUD)) {
int ret = 0;
to avoid compilation warning
char *ptr = (char *)&default_environment[0];
gd->baudrate = ret;
ptr++;
ptr += 2;
- } serial_setbrg(); #endif
- ofnode_read_aliases_prop() - get the value of a aliases property
- ofnode_read_baud() - get the baudrate from string value of chosen property
- This looks for a property within the /aliases node and returns its value
- This looks for stdout-path property within the /chosen node and parses its
- value to return baudrate.
- This only works with the control FDT.
- Return: baudrate value if found, else -ve error code
- @propname: Property name to look for
- @sizep: Returns size of property, or `FDT_ERR_...` error code if function
- returns NULL
- /* Padding for baudrate at the end when environment is writable */
- "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0" #endif "\0" #else /* CONFIG_USE_DEFAULT_ENV_FILE */
- check_valid_baudrate() - Check whether baudrate is valid or not
- @baud: baud rate to check
- Return: 0 if OK, -ve on error
Move this kernel-doc to drivers/serial/serial-uclass.c
and remove this line.
- fetch_baud_from_dtb() - Fetch the baudrate value from DT
- Return: baudrate if OK, -ve on error
- void atmel_serial_initialize(void); void mcf_serial_initialize(void); void mpc85xx_serial_initialize(void);
M
Michal Simek
