[U-Boot] [PATCH] efi_loader: Move to normal debug infrastructure
We introduced special "DEBUG_EFI" defines when the efi loader support was new. After giving it a bit of thought, turns out we really didn't have to - the normal #define DEBUG infrastructure works well enough for efi loader as well.
So this patch switches to the common debug() and #define DEBUG way of printing debug information.
Signed-off-by: Alexander Graf agraf@suse.de --- cmd/bootefi.c | 4 +--- include/efi_loader.h | 10 +--------- lib/efi_loader/efi_boottime.c | 6 +----- lib/efi_loader/efi_disk.c | 11 ++++------- lib/efi_loader/efi_memory.c | 2 -- lib/efi_loader/efi_runtime.c | 14 +++----------- 6 files changed, 10 insertions(+), 37 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 2a62dce..2169065 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -206,9 +206,7 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt) #endif
/* Call our payload! */ -#ifdef DEBUG_EFI - printf("%s:%d Jumping to 0x%lx\n", __func__, __LINE__, (long)entry); -#endif + debug("%s:%d Jumping to 0x%lx\n", __func__, __LINE__, (long)entry);
if (setjmp(&loaded_image_info.exit_jmp)) { efi_status_t status = loaded_image_info.exit_status; diff --git a/include/efi_loader.h b/include/efi_loader.h index 3332d61..9738835 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -15,18 +15,10 @@
#include <linux/list.h>
-/* #define DEBUG_EFI */ - -#ifdef DEBUG_EFI #define EFI_ENTRY(format, ...) do { \ efi_restore_gd(); \ - printf("EFI: Entry %s(" format ")\n", __func__, ##__VA_ARGS__); \ + debug("EFI: Entry %s(" format ")\n", __func__, ##__VA_ARGS__); \ } while(0) -#else -#define EFI_ENTRY(format, ...) do { \ - efi_restore_gd(); \ - } while(0) -#endif
#define EFI_EXIT(ret) efi_exit_func(ret);
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 15a1b90..be6f5e8 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -6,8 +6,6 @@ * SPDX-License-Identifier: GPL-2.0+ */
-/* #define DEBUG_EFI */ - #include <common.h> #include <efi_loader.h> #include <malloc.h> @@ -76,9 +74,7 @@ efi_status_t efi_exit_func(efi_status_t ret)
static efi_status_t efi_unsupported(const char *funcname) { -#ifdef DEBUG_EFI - printf("EFI: App called into unimplemented function %s\n", funcname); -#endif + debug("EFI: App called into unimplemented function %s\n", funcname); return EFI_EXIT(EFI_UNSUPPORTED); }
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index f9ad615..c434c92 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -84,10 +84,8 @@ static efi_status_t EFIAPI efi_disk_rw_blocks(struct efi_block_io *this, blocks = buffer_size / blksz; lba += diskobj->offset;
-#ifdef DEBUG_EFI - printf("EFI: %s:%d blocks=%x lba=%"PRIx64" blksz=%x dir=%d\n", __func__, - __LINE__, blocks, lba, blksz, direction); -#endif + debug("EFI: %s:%d blocks=%x lba=%"PRIx64" blksz=%x dir=%d\n", __func__, + __LINE__, blocks, lba, blksz, direction);
/* We only support full block access */ if (buffer_size & (blksz - 1)) @@ -101,9 +99,8 @@ static efi_status_t EFIAPI efi_disk_rw_blocks(struct efi_block_io *this, /* We don't do interrupts, so check for timers cooperatively */ efi_timer_check();
-#ifdef DEBUG_EFI - printf("EFI: %s:%d n=%lx blocks=%x\n", __func__, __LINE__, n, blocks); -#endif + debug("EFI: %s:%d n=%lx blocks=%x\n", __func__, __LINE__, n, blocks); + if (n != blocks) return EFI_EXIT(EFI_DEVICE_ERROR);
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index 5d59bf8..df2381e 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -6,8 +6,6 @@ * SPDX-License-Identifier: GPL-2.0+ */
-/* #define DEBUG_EFI */ - #include <common.h> #include <efi_loader.h> #include <malloc.h> diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index 11d0126..99b5ef1 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -165,9 +165,7 @@ static void efi_runtime_detach(ulong offset) ulong *p = efi_runtime_detach_list[i].ptr; ulong newaddr = patchto ? (patchto + patchoff) : 0;
-#ifdef DEBUG_EFI - printf("%s: Setting %p to %lx\n", __func__, p, newaddr); -#endif + debug("%s: Setting %p to %lx\n", __func__, p, newaddr); *p = newaddr; } } @@ -182,10 +180,7 @@ void efi_runtime_relocate(ulong offset, struct efi_mem_desc *map) static ulong lastoff = CONFIG_SYS_TEXT_BASE; #endif
-#ifdef DEBUG_EFI - printf("%s: Relocating to offset=%lx\n", __func__, offset); -#endif - + debug("%s: Relocating to offset=%lx\n", __func__, offset); for (; (ulong)rel < (ulong)&__efi_runtime_rel_stop; rel++) { ulong base = CONFIG_SYS_TEXT_BASE; ulong *p; @@ -212,10 +207,7 @@ void efi_runtime_relocate(ulong offset, struct efi_mem_desc *map) continue; }
-#ifdef DEBUG_EFI - printf("%s: Setting %p to %lx\n", __func__, p, newaddr); -#endif - + debug("%s: Setting %p to %lx\n", __func__, p, newaddr); *p = newaddr; flush_dcache_range((ulong)p & ~(EFI_CACHELINE_SIZE - 1), ALIGN((ulong)&p[1], EFI_CACHELINE_SIZE));
Alexander Graf
