[PATCH] ti: common: Remove additional i2c read for board detection
There shouldn't be a need to call additional i2c read if above failed already. Based on comment it should be enough to try to detect legacy boards which are mentioned in the comment.
Fixes: 2463f6728e82 ("ti: common: board_detect: Allow DM I2C without CONFIG_DM_I2C_COMPAT") Fixes: 0bea813d0018 ("ARM: omap-common: Add standard access for board description EEPROM") Signed-off-by: Michal Simek michal.simek@xilinx.com ---
Found based on reading the code. Untested on HW but also not explain why additional same read should be called again. --- board/ti/common/board_detect.c | 18 ++++++------------ 1 file changed, 6 insertions(+), 12 deletions(-)
diff --git a/board/ti/common/board_detect.c b/board/ti/common/board_detect.c index e09ecda4d7e6..8b3b4bc82539 100644 --- a/board/ti/common/board_detect.c +++ b/board/ti/common/board_detect.c @@ -113,18 +113,15 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr,
/* Corrupted data??? */ if (hdr_read != header) { - rc = dm_i2c_read(dev, 0, (uint8_t *)&hdr_read, 4); /* * read the eeprom header using i2c again, but use only a * 1 byte address (some legacy boards need this..) */ - if (rc) { - rc = i2c_set_chip_offset_len(dev, 1); - if (rc) - return rc; + rc = i2c_set_chip_offset_len(dev, 1); + if (rc) + return rc;
- rc = dm_i2c_read(dev, 0, (uint8_t *)&hdr_read, 4); - } + rc = dm_i2c_read(dev, 0, (uint8_t *)&hdr_read, 4); if (rc) return rc; } @@ -153,16 +150,13 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr,
/* Corrupted data??? */ if (hdr_read != header) { - rc = i2c_read(dev_addr, 0x0, byte, (uint8_t *)&hdr_read, 4); /* * read the eeprom header using i2c again, but use only a * 1 byte address (some legacy boards need this..) */ byte = 1; - if (rc) { - rc = i2c_read(dev_addr, 0x0, byte, (uint8_t *)&hdr_read, - 4); - } + rc = i2c_read(dev_addr, 0x0, byte, (uint8_t *)&hdr_read, + 4); if (rc) return rc; }
Thanks for the patch. Merged into u-boot-ti.
Thanks and regards, Lokesh
Lokesh Vutla
Michal Simek
